The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer. Deep output – Specifies whether to include this render element in deep images. Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawReflectionFilter.vrimg). Denoise – Enables the render element's denoising, provided the Denoiser render element is present. This render element is not supported with V-Ray GPU rendering. |
