The parameters for this render element appear in the V-Ray RenderChannelColor render channels node. Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present. Consider For AA – When enabled, anti-aliasing is used where possible. Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the V-Ray Renderer node. Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel. Derive Raw Channels – Generates data in the raw channels by combining the respective color and the filter color channels. VFB Color Corrections – Applies the post render color adjustments made from the VFB. |
