This page provides details on the V-Ray for Revit UI and how it is integrated into the Revit interface.
The V-Ray for Revit Ribbon gives you access to all of the settings and options that you will need with V-Ray.
This allows you to select which one of the Revit 3D views to render.
Allows you to choose your Render type and open up the V-Ray Frame Buffer.
Provides a drop down menu with a specific set of presets. They provide preset settings ranging from very low quality “Draft” settings to “Very High Quality” settings.
Allows you to choose your Output and Crop Box resolution size.
Gives you access to the options for the V-Ray Sun, V-Ray Dome Light, No V-Ray Lights and Artificial Lights.
Gives you access to the V-Ray Asset Editor and V-Ray Appearance Manger.
Gives you access to the V-Ray Camera settings.
Gives you access to the V-Ray Settings.
Opens the online V-Ray for Revit Help documents.
Allows you to acquire your license and gives you access to the Online License Server.
