This page provides details on the V-Ray for Revit UI and how it is integrated into the Revit interface.
The V-Ray for Revit Ribbon gives you access to all of the settings and options that you will need with V-Ray.
This allows you to select which one of the Revit 3D views to render.
Allows you to choose your Render type and open up the V-Ray Frame Buffer.
Provides a drop down menu with a specific set of presets. They provide preset settings ranging from very low quality “Low” settings to “High+” settings.
Allows you to choose your Output and Crop Box resolution size.
Gives you access to the options for the V-Ray Sun, V-Ray Dome Light, No V-Ray Lights and Artificial Lights.
Gives you access to the V-Ray Asset Editor and V-Ray Appearance Manger.
Gives you access to the V-Ray Camera settings.
Gives you access to the V-Ray Settings.
Opens the online V-Ray for Revit Help documents.
The following Render options are accessible through the panel:
Allows you to acquire your license and gives you access to the Online License Server.
