This page provides information on the Raw Coat Filter Render Element.
The Raw Coat Filter Render Element is similar to the Coat Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection calculated from the VRayMtl Coat Layer.
||Render Setup window|| > Render Elements tab > Add button > VRayRawCoatFilter |
