BRDF Type – Determines the type of BRDF (the shape of the highlight and glossy reflections). This parameter has an effect only if the Reflection Color is different from black and Reflection Glossiness is different from 1.0. For more information, see the BRDF Type example below. Phong – Phong highlight/reflections. Specular highlights have a bright center with no falloff. Blinn – Blinn highlight/reflections. Specular highlights have a bright center with a tight falloff. Ward – Ward highlight/reflections. Specular highlights have a bright center with a falloff broader than Blinn, but tighter than Microfacet GTR (GGX). GGX – GGX Microfacet highlight/reflections. Specular highlights have a bright center with a longer falloff. GGX is the most modern and flexible BRDF (Bidirectional reflectance distribution function) type and is able to better represent a broad range of materials thanks to its ability to control the shape of the specular lobe. There currently isn't any particular performance difference between models and there is little reason to choose any of the other types. Historically, the Phong, Blinn, Ward and GGX are successive reflectance models developed over the years in computer graphics where each model aimed to improve on the limitations of the previous ones. For example, the specular highlights with the Phong model have a very narrow and bright center with no falloff, but it doesn't work well with anisotropic reflections. The Blinn model has broader highlight center with a tight falloff. The Ward model has an even broader center and falloff. The GGX model has a bright center and an even longer falloff (at default settings). In the past, each model's characteristics resembled more closely a certain type of material, for example Phong could be used for plastics, Ward for cloth and metals, and Blinn for other common surfaces. However with the introduction of the GGX model, all of these surfaces can be approximated well, thus reducing the need for using the other models. It should be noted that no principled model is able to represent all possible materials entirely accurately, and where those models fail - for example when the material isn’t viewed frontally - only approaches such as that of V-Ray Chaos Scans are able to capture the correct material representation. |
GGX Tail Falloff – Controls the transition from highlighted areas to non-highlighted areas when the BRDF Type is set to GGX. Color – Reflection color. Note that the reflection color dims the Diffuse Color. For more information, see the Reflection Color example below. Glossiness – Controls the sharpness of reflections. A value of 1.0 means perfect mirror-like reflection; lower values produce blurry or glossy reflections. For more information, see the Reflection Glossiness example below. Use Fresnel – Makes the reflection strength dependent on the viewing angle of the surface. Some materials in nature (glass, etc.) reflect light in this manner. Note that the Fresnel effect depends on the index of refraction (IOR) as well. For more information, see the Use Fresnel example below. Glossy Fresnel – Uses glossy Fresnel to interpolate glossy reflections and refractions. It takes the Fresnel equation into account for each "microfacet" of the glossy reflections, rather than just the angle between the viewing ray and the surface normal. The most apparent effect is less brightening of the grazing edges as the glossiness is decreased. With the regular Fresnel, objects with low glossiness may appear to be unnaturally bright and "glowing" at the edges. The Glossy Fresnel calculations make this effect more natural. Lock Fresnel IOR to Refraction IOR – Unlocks the Fresnel IOR parameter for finer control over the reflections. When the Lock Fresnel IOR to Refraction IOR is enabled, the Fresnel IOR is locked to the Refraction IOR. Fresnel IOR – The IOR to use when calculating Fresnel reflections. Normally this is locked to the Refraction IOR parameter, but you can unlock it for finer control. Note that this parameter has no effect on metallic materials with Metalness value of 1.0 and no metallic map assigned. For more information, see the Use Fresnel example below. Metalness – Controls the reflection model of the material from dielectric (metalness 0.0) to metallic (metalness 1.0). Note that intermediate values between 0.0 and 1.0 do not correspond to any physical material. This parameter can be used with PBR setups coming from other applications. The reflection color should typically be set to white for real world materials. Thin FilmEnabled – Turns on/off the thin film effect. Min. Thickness (nm) – Determines the minimum thickness of the thin film in nanometers. For more information, see the Thin Film Thickness example below. Max. Thickness (nm) – Determines the maximum thickness of the thin film in nanometers. A map can be used to blend between the Min and Max Thickness parameters, and is expected to be in the range of 0-1. If there is no texture map, only the Min thickness value is used. Thickness Blend – A map used to blend between the Min and Max Thickness parameters. It is expected to be in the range of 0-1. IOR – Specifies the reflective index of the thin film. A map can be attached to this slot. For more information, see the Thin Film IOR example below. AnisotropyAnisotropy – Determines the shape of the highlight. A value of 0.0 means isotropic highlights. Negative and positive values simulate "brushed" surfaces. For more information, see the Anisotropy example below. Rotation – Determines the orientation of the anisotropic effect in a float value between 0 and 1 (where 0 is 0 degrees and 1 is 360 degrees). For more information, see the Anisotropy Rotation example below. Uv Vectors Derivation – Specifies the method for deriving anisotropy axes: Local Axis – Uses a local axis for the anisotropy effect. UVW Generator – Allows you to assign a UVW Generator for the anisotropy effect. Axis – Specifies a local object axis for the anisotropy effect when Uv Vectors Derivation is set to Local Axis. AdvancedTrace Reflections – Enables reflections for the material. Exit Color – If a ray has reached its maximum reflection depth, this color is returned without tracing the ray further. Max Depth – The number of times a ray can be reflected. Scenes with lots of reflective and refractive surfaces may require higher values to look correct. Enable Dim Distance – Enables the Dim Distance parameter which allows you to stop tracing reflection rays after a certain distance. Dim Distance – Specifies a distance after which the reflection rays are not traced. Dim Fall-off – A fall off radius for the dim distance. Soften – Softens the edge of the BRDF at light/shadow transitions Affect Channels – Allows you to specify which channels are going to be affected by the reflectivity of the material. Color Only – The reflectivity affects only the RGB channel of the final render. Color+Alpha – Causes the material to transmit the alpha of the reflected objects, instead of displaying an opaque alpha. All Channels – All channels and render elements are affected by the reflectivity of the material. |
