A wrapper around JPEG data in memory. It's meant to be stack allocated to free the data when done.
More...
#include <vraysdk.hpp>
| LocalJpeg (const VRayImage *img, const VRayRenderer &renderer, int quality=0) |
| | Same as the other constructor. The renderer is used to log error messages.
| | LocalJpeg (const VRayImage *img, int quality=0) |
| LocalJpeg (LocalJpeg &&other) noexcept |
void * | getBuf () const noexcept |
| | Returns a pointer to the image data.
size_t | getLen () const noexcept |
| | Returns size of image data in bytes.
| operator size_t () const noexcept |
bool | saveToFile (const char *fileName) const |
| | Write the data to disk.
bool | saveToFile (const std::string &fileName) const |
| | This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void | swap (CompressImage &ci) noexcept |
| CompressImage (CompressImage &&ci) noexcept |
void * | bufAddr |
size_t | bufSize |
◆ LocalJpeg()
| VRay::LocalJpeg::LocalJpeg |
const VRayImage * |
img, |
int |
quality = 0 |
inline |
Compression is performed in this constructor
- Parameters
| img | The source image to compress. The source is not modified. |
| quality | If negative, abs(quality) is used and progressive encoding is performed |
The documentation for this class was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
