| | LocalPng (const VRayImage *img, bool preserveAlpha=false) |
| LocalPng (const VRayImage *img, const VRayRenderer &renderer, bool preserveAlpha=false) |
| | Same as the other constructor. The renderer is used to log error messages.
| LocalPng (LocalPng &&other) noexcept |
void * | getBuf () const noexcept |
| | Returns a pointer to the image data.
size_t | getLen () const noexcept |
| | Returns size of image data in bytes.
| operator size_t () const noexcept |
bool | saveToFile (const char *fileName) const |
| | Write the data to disk.
bool | saveToFile (const std::string &fileName) const |
| | This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void | swap (CompressImage &ci) noexcept |
| CompressImage (CompressImage &&ci) noexcept |
void * | bufAddr |
size_t | bufSize |
◆ LocalPng()
| VRay::LocalPng::LocalPng |
const VRayImage * |
img, |
bool |
preserveAlpha = false |
inline |
Compression is performed in this constructor
- Parameters
| img | The source image to compress. The source is not modified. |
| preserveAlpha | You need to set this explicitly to true to keep the alpha channel in the PNG |
The documentation for this class was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
