VRay SDK for C++
Loading...
Searching...
No Matches
VRay::VRayServer Class Reference
Public Member Functions
 VRayServer (const ServerOptions &serverOptions)
int addHosts (const char *hosts)
std::string exportSceneBuffer (int flags) const
ExternalString * exportSceneBufferFast (size_t &length, int flags) const
char * getActiveHosts (int *size) const
char * getAllHosts (int *size) const
char * getInactiveHosts (int *size) const
LicenseError getLicenseError () const
 operator bool () const
int removeHosts (const char *hosts)
int resetHosts (const char *hosts)
int run ()
 Starts V-Ray Server. Blocking call.
template<class T , void(T::*)(VRayServer &, const char *msg, double, void *) TMethod>
void setOnConnect (T &object, const void *userData=nullptr)
void setOnConnect (void(*callback)(VRayServer &, const char *msg, double instant, void *), const void *userData=nullptr)
void setOnDisconnect (T &object, const void *userData=nullptr)
void setOnDisconnect (void(*callback)(VRayServer &, const char *msg, double instant, void *), const void *userData=nullptr)
template<class T , void(T::*)(VRayServer &, const char *msg, MessageLevel level, double, void *) TMethod>
void setOnLogMessage (T &object, MessageLevel minLevel=MessageInfo, const void *userData=nullptr)
void setOnLogMessage (void(*callback)(VRayServer &, const char *msg, MessageLevel level, double instant, void *), MessageLevel minLevel=MessageInfo, const void *userData=nullptr)
template<class T , void(T::*)(VRayServer &, const char *msg, int elementNumber, int elementsCount, double instant, void *userData) TMethod>
void setOnProgress (T &object, const void *userData=nullptr)
void setOnProgress (void(*callback)(VRayServer &, const char *msg, int elementNumber, int elementsCount, double instant, void *), const void *userData=nullptr)
template<class T , void(T::*)(VRayServer &, int, uint64_t, uint64_t, const char *name, double instant, void *userData) TMethod>
void setOnSceneUpdate (T &object, const void *userData=nullptr)
 This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void setOnSceneUpdate (void(*callback)(VRayServer &vray, int action, uint64_t changeIndex, uint64_t pluginId, const char *name, double instant, void *), const void *userData=nullptr)
template<class T , void(T::*)(VRayServer &, double, void *) TMethod>
void setOnServerClose (T &object, const void *userData=nullptr)
void setOnServerClose (void(*callback)(VRayServer &, double instant, void *), const void *userData=nullptr)
void setOnServerStart (T &object, const void *userData=nullptr)
void setOnServerStart (void(*callback)(VRayServer &, double instant, void *), const void *userData=nullptr)
int start ()
 Starts V-Ray Server in a separate thread. Non-blocking call.
void stop ()
 Terminates the server started by 'start' in a separate thread.
Member Function Documentation
◆ exportSceneBuffer()
std::string VRay::VRayServer::exportSceneBuffer ( int  flags) const
inline
Exports the current scene contents and return the generated vrscene stream as a string. The exporter serializes all plugins in text format.
flagsCustom export options (see ExportSceneFlags enum)
Returns
the vrscene stream as a string.
◆ exportSceneBufferFast()
ExternalString * VRay::VRayServer::exportSceneBufferFast ( size_t &  length,
int  flags
) const
inline
Exports the current scene contents and return the generated vrscene stream as a sequence of chars. The exporter serializes all plugins in text format.
Returns
the vrscene string stream.
◆ operator bool()
VRay::VRayServer::operator bool ( ) const
inline
If exceptions are not enabled use this function to test whether you have a valid server
Returns
true - server instance is valid, false - server instance is invalid
◆ setOnSceneUpdate()
void VRay::VRayServer::setOnSceneUpdate ( void(*)(VRayServer &vray, int action, uint64_t changeIndex, uint64_t pluginId, const char *name, double instant, void *)  callback,
const void *  userData = nullptr
inline
Set callback function for the event when the current scene is updated Callback arguments: vray - The VRayServer which produced the event. action - an action code representing the update event being processed. changeIndex - A linearly growing index reflecting the number of changes applied to the scene or 0 if not applicable. pluginId - the plugin instance id being affected by the change or 0 if not applicable. name - Depending on the action code, hold either the name of the plugin or the parameter being updated, or nullptr if not applicable. instant - Relative time of the event in seconds since V-Ray initialization.
The documentation for this class was generated from the following file:
