The Brush Property Panel allows you to control the brush paint-over mark-ups.
Properties
UI Path: ||Property Panel|| > Brush panel
Becomes available when you have selected a Brush Layer ( Brush Sequence Layer ( ).
) or aThe following four sliders control the brush properties. You can change their values like you do with all sliders – by dragging the slider or by double clicking on the slider and entering a number in the box.
Size – Controls the size of the brush. You can also hold down ctrl key and drag left and right in the Brush preview area to change this value.
Softness – Controls the softness or hardness of the brush edges. You can also hold down ctrl key and drag up and down in the Brush preview area to change this value.
Spacing – Controls the spacing for brush strokes.
Opacity – Controls the brush opacity.
Brush preview – Shows the size and softness of the brush.
Brush color chooser – Specifies a color for the brush.
