Square Enix © Goodbye Kansas
This page describes the Raw Diffuse Filter Render Element.
The Raw Diffuse Filter Render Element is similar to the Diffuse Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the pure diffuse color as set in the V-Ray Material's settings.
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawDiffuseFilter.vrimg).
Denoise – Enables the render element's denoising, provided the Denoiserrender element is present.
This render element is not supported with V-Ray GPU rendering.
