© Taichi Kobayashi
This page provides information on the V-Ray Coat Reflection Render Element.
The Coat Reflection Render Element is analogous to the Reflection Render Element.
The Coat Reflection RE stores reflection information calculated from the materials' coat layer. Surfaces with the Coat Amount parameter set to 0 contain no information in the render pass and therefore render as black.
The parameters for this render channel appear in the Parameters tab under the out Network and within the render elements node.
Name – The text added to the end of the rendered file when saved as a separate file.
Color Mapping – Applies the color mapping options specified in the Color mapping tab of the V-Ray Renderer to this render element.
Consider For AA – When enabled, antialiasing is considered where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the AA sub-tab of the Sampler tab of the V-Ray Renderer node.
Derive RAW Channels – Generates data in the raw channels by combining the respective color and the filter color channels.
Denoise – Enables the render element's denoising, provided the Denoiser render element is added.
Deep Output – Specifies whether to include this render element in deep images.
