The V-Ray for Revit config.json file allows you to define a custom setup for some V-Ray settings as well as for all V-Ray Swarm settings.
The config.json file can be found in the following folder on your computer: C:\Users\<user name>\AppData\Roaming\Chaos Group\V-Ray for Revit 20**  (where 20** is the Revit version).
Below is a description of the settings that can be predefined in the V-Ray for Revit config.json file.
"telemetry":
Controls the anonymous collection of usage statistics. More information can be found on the Chaos Telemetry page.
true – the anonymous collection of usage statistics is enabled.
false – the anonymous collection of usage statistics is disabled.
"allowedRenderEngines":
["CPU", "CUDA", "RTX"]
Specifies which render engines can be used for rendering. If only one engine is selected, the other one will be hidden from the UI.
"allowedSamplerModes":
["Buckets", "Progressive"]
Specifies which sampler modes can be used for rendering. If only one sampler is selected, the other one will be hidden from the UI.
"assetsDownloadDir"Specifies a download folder for the V-Ray material library.
"assetsDownloadUpdatesCheck"
Specifies whether the V-Ray Asset Editor should check for library updates when launched.
true – checking for updates is enabled by default.
false – checking for updates is disabled by default.
"defaultSamplerMode":
Specifies the default sampler mode.
"Progressive" – the Sampler is set to Progressive by default.
"Buckets" – the Sampler is set to Buckets by default.
"swarmUIState":
Specifies the V-Ray Swarm settings visibility in the V-Ray for Revit UI.
"enabled" – V-Ray Swarm settings are visible and active in the UI.
"disabled" – V-Ray Swarm settings are visible in the UI but are disabled and cannot be modified.
"hidden" – The entire V-Ray Swarm tab is hidden from the UI. In this case, the V-Ray Swarm setup is accessible only through the V-Ray for Revit config.json file.
"swarmIsEnabled":
Specifies whether V-Ray Swarm distributed rendering is enabled or disabled.
false – V-Ray Swarm rendering is disabled.
true – V-Ray Swarm rendering is enabled.
"swarmDoNotUseLocalMachine":
Specifies whether the local machine is used during V-Ray Swarm distributed rendering or not.
false – the local machine is used during distributed rendering.
true – the local machine is excluded from distributed rendering.
"swarmUseAutoDiscovery":
Specifies whether the Coordinator for V-Ray Swarm distributed rendering is selected automatically or not.
true – Coordinator is selected automatically.
false – Coordinator is selected via the IP specified by the "swarmCoordinatorIP" parameter.
"swarmCoordinatorIP":Specifies the IP of the machine to be dedicated as a Coordinator.
"swarmResourceUsageGoal":Specifies the percentage of computing power to be used when V-Ray Swarm distributed rendering is enabled.
"swarmTags":Specifies the tags of the machines to be used for V-Ray Swarm distributed rendering.
"interactiveVRaySceneIsEnabled"
Experimental feature that enables or disables interactive actions with Proxy Scenes (.vrscene files).
false – The feature is disabled by default.
true The feature is enabled.
