Official release
Date - November 9, 2020
Release NotesV-Ray 5
Download
V-RAY VISION
Now with V-Ray Vision you can visualize your designs in real-time while you work in SketchUp. Move around your model, apply materials, set up lights and cameras—all in a live real-time view of your scene. And when you’re ready for photo quality renders, V-Ray is ready to go. With V-Ray Vision  you can:
  • Explore your designs in real-time
  • Produce images from multiple camera angles
  • Create 360 panoramas
  • Render animations in real-time
LIGHTING MADE EASY
Adjust the lights in your scene even after you render. With Light Mix, once your scene is rendered, you can interactively adjust the brightness and color of any light without having to render again
POST-PROCESS YOUR RENDERS RIGHT IN V-RAY
V-Ray 5 features a new V-Ray Frame Buffer. With built-in compositing, you can make color corrections, combine render elements, and save them as presets to be used in the future - all without needing another app.
SEE YOUR DESIGNS IN THEIR BEST LIGHT
Light Gen is a new V-Ray tool that automatically generates thumbnails of your SketchUp scene each one presenting a unique lighting scenario. Choose your favorite look and you’re ready to render.
NEW LAYERED V-RAY MATERIAL
The V-Ray Material now includes built-in Coat and Sheen layers. Coat makes it easy to create materials with reflective coatings like varnished wood, and Sheen makes it easy to create fabrics like silk, satin, and velvet.
IMPROVED CONTOUR RENDERING
The global Contours control gives you more control over linework, making it easier than ever to give your renders an illustrative look.
IMPROVED MATERIAL LIBRARY
Efficiently browse and download from a library of over 500 render-ready, high-resolution materials including metals, glass, wood, and more.
IMPROVED SUN AND SKY MODEL
Render your scene at the perfect light of magic hour. The Improved Sun & Sky model is more accurate, with a better-looking sunrise and sunset, even as the sun dips below the horizon.
ADD RANDOMNESS FOR REALISM
To create more realistic materials, we’ve added new tools that randomize textures and colors.
The VRayUVWRandomizer lets you randomize texture coordinates and includes Stochastic Tiling that automatically fixes repeating textures.
DIRT AND WEATHERING
Give your SketchUp models a weathered look with the improved V-Ray Dirt texture. Add dirt and streaks anywhere—in corners or across entire surfaces.
V-RAY CORE
Optimized V-Ray core and improved V-Ray GPU for an even faster and more stable rendering experience.
NEW SOFTWARE ARCHITECTURE
Much faster scene loading and scene export thanks to the newly refactored V-Ray backend.
NEW API DOCUMENTATION
For developers looking to create and connect tools with V-Ray for SketchUp, we’ve added a new fully documented API to make it as easy as possible.
