This page provides information on the Text Panel in the Property PanelThe Text Property Panel allows you to adjust the text mark-up annotations.
Page Contents
Properties
The Text Panel is part of Pdplayer's Property Panel. It is active when you have selected a Text Layer and it allows you to control its settings.
width50%
UI Path: ||Property Panel||
Text panel
Properties
Image Removed
This rollout becomes active when you have selected a Text Layer (Image Added).
Text – Holds the actual text that is displayed by
the Text Layer. You can change it by double clicking on the Text field or by holding Shift and double clicking on
the Text Layer
 in the Preview Area.
Alignment
Controls for the horizontal and vertical alignment of the text.
Font Specifies the text font, size, and color. The following controls allow you to add effects like Outline and Shadow to the text. The last settings allow you to put a background color for the text and set a transparency for that background.
width5%
width45%
Image Added
Embedded Fields
The text in text layers may contain embedded fields of the form {object:property}. Such fields are replaced with their values before the text is displayed.
For example, {timeline:frame} is replaced with the current frame, and {4:timecode} is replaced with the embedded timecode of layer 4.
This is useful for burn-ins when creating previews and dailies.
For more information about the syntax check the Text fields reference.
Image Removed
Image Added
Chaos Player set with frame number in the text field.
