This page provides information on the Brush Panel in the Property PanelThe Brush Property Panel allows you to control the brush paint-over mark-ups.
Page Contents
stylecircle
The Brush Panel is part of Pdplayer's Property Panel. It is available when you have selected a Brush Layer or a Brush Sequence Layer.
HideElements
cssselector#tocVertical, #tocHorizontal
Properties
UI Path: ||Property Panel|| > Brush panel
width
Image Removed
50%
Becomes available when you have selected a Brush Layer (Image Added) or a Brush Sequence Layer (Image Added).
The following four sliders control the brush properties. You can change their values like you do with all sliders – by dragging the slider or by double clicking on the slider and entering a number in the box.
Size – Controls the size of the brush. You can also hold down ctrl key and drag left and right in
the Brush preview
 area to change this value.
Softness
 – Controls the softness or hardness of the brush edges. You can also hold down ctrl key and drag up and down in
the Brush preview
Spacing – Controls the spacing for brush strokes.
Opacity – Controls the brush opacity.
Brush preview – Shows the size and softness of the brush.
Brush color chooser – Specifies a color for the brush.
width5%
width45%
Image Added
