Floatingpagetoc
CSS Stylesheet |
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size { vertical-align: text-bottom; } |
This page provides information about Chaos Vantage's Animation Editor.
UI
The Animation editor can be accessed by clicking on the Animation Editor button() in the bottom toolbar
Button | Description | ||||||||||
Expands the Animation Editor. | |||||||||||
Sets the playback speed. | |||||||||||
Plays the animation. (Shortcut: Space ) | |||||||||||
When enabled loops the animation. | |||||||||||
Sets start of animation sequence | |||||||||||
Sets end of animation sequence | |||||||||||
Updates image sequences for the current frame of the timeline. | |||||||||||
Opens Render setup dialog.
Quick saves high quality snapshot in the project folder from where the .vrscene file has been imported. |
UI Text Box | ||
You can crop your animation sequence using the Set Start and Set End markers |
Animation Editor Parameters
Left Side Parameters
Right Side Parameters
Timeline
Section | ||||||||||||||||||||||||||||||||||||||||||||||
Animation Editor Modes
Time Mode
Time mode of the animation editor enables the following workflow:
Fancy Bullets | ||
Shot Mode
Shot mode of the animation editor enables the following workflow:
Fancy Bullets | ||
Context Menus
Additional parameters of the clips can be accessed by right-clicking on an item to display a context menu. In the camera animation track, you can have the following items with context menu options:
Right-click on camera clip:
Right-click on Scene animation:
Right-click on transition item:
Right-click on pause item:
