This page provides information on the Placement Panel in the Property Panel.
Page Contents
Table of Contents | ||
The Placement Panel is part of Pdplayer's Property Panel and allows you to adjust settings related to The Transform Property Panel allows you to adjust the layer position, scale, and pixel aspect ratio.
HideElements | ||
Properties
UI Path: ||Property Panel|| > Placement panel
Properties
> Transform panel
Transform properties are available when a layer is selected in the layer stackThe second panel of the Property Panel is the Placement Panel.
Section |
Name / Group ID – Specifies a Name and Group ID for the current layer. The Name is displayed on the layer and the Group ID can be used to create selection sets. The user can also use those unique names when writing embedded text fields.
