This page provides details on how to use the optimized Bump Material in V-Ray.
The V-Ray Bump Material gives the ability to add bump map and normal map effects when using any material.
Connect a material into the V-Ray Bump to add additional bump or normal map functionality. Stacking multiple Bump materials together can create a more complex surface material by allowing the use of several bump and/or normal maps together easily.
UI Paths
||V-Ray|| > Bump Material
||Create|| > V-Ray > Bump Material (disabled Separate menu for V-Ray materials)
Base Material – Allows the user to select the base material to which the bump/normal effect is added.
Map Type – Allows the user to specify whether a bump map or a normal map effect is added to the base material.
Bump Map
Normal map in tangent space
Normal map in object space
Normal map in screen space
Normal map in world space
From texture bump output
Explicit normal
Texture Map – Specifies the bump/normal map that is used.
Bump Multiplier – A multiplier for the bump/normal effect.
Bump Delta Scale – Scale for sampling the bitmap when using bump mapping. The exact value is calculated automatically by V-Ray, but can be scaled here.
Bump Shadows – When enabled, V-Ray considers the bump maps when rendering shadows produced by objects with the bump material applied to them.
Options
MATERIAL ID
Material Id Enabled – Enables the use of Material ID.
Material ID – The color used by the Material ID render element. You can also use a shader here.
Multimatte ID – The integer ID of the material to be used by the Multi Matte render element.
ROUND EDGES
Round Edges Enabled – Enables the round edges effect which uses bump mapping to smooth out the edges of the geometry during render time.
Radius – Specify a radius (in world units) for the round edges effect. Since the actual geometry is not being changed and only the normals of the faces are affected, large values may produce undesirable effects.
Consider Same Object Only – When enabled, the rounded corners are produced only along edges that belong to the object which has the attribute applied. When disabled, rounded corners are also produced along edges formed when the object with the attribute intersects other objects in the scene.
Corners – Choose which edges are considered in the calculation. Possible options are:
Covex and Concave – Considers all edges.
Convex Only – Only applies Round Edges effect to edges with convex angles.
Concave Only – Only applies Round Edges effect to edges with concave angles.
Example: Bump Material vs V-Ray Material bump
In this example, bump maps are used for the surface of the table. Both V-Ray Material and Bump Material can control the strength of the bump map by using a multiplier.
