« Previous Version 2 Next »
See Release Notes for all previous V-Ray versions here.
V-Ray 7, (7.00.00)
Official release
Date - Mar 11, 2025
Improvements
  • General: V-Ray Core updated to version 7.00.10
  • General: Asset Editor updated to version 7.0.3
  • General: License Server updated to version 6.2.0
  • General: Unified Login Application updated to version 2024.10.17
  • General: Chaos Cosmos Browser updated to version 2025.1.8
  • General: Chaos Cloud Client updated to version 1.33.4
  • Geometry: Added Gaussian splats
  • Geometry: Added support for point cloud rendering
  • Scatter: Added ability to scatter items along a path/line
  • Scatter: Added ability to scatter items over a bounding box
  • Scatter: Added grid distribution mode for surface scattering
  • Scatter: Extended the random offset, scale and rotation controls of the scattered items
  • Scatter: Added ability to pick areas and exclude/include them to Scatter
  • Scatter: Added proximity-based fall off controls of the scattered items
  • Scatter: Added ability to scatter lights
  • Scatter: Added various internal optimizations
  • Asset Editor: Added ability to composite multiple textures together via a Layered texture
  • Asset Editor: Added ability to associate the Gradient map color positions with textures
  • Asset Editor: Added ability to procedurally colorize a grayscale texture based on gradient map values
  • Asset Editor: Added ability to apply a custom remap curve to the Falloff transition
  • VFB: Added Chromatic aberrations effect
  • VFB: Added Vignetting layer
  • VFB: Added color correction presets/filters
  • VFB: Improved usability of the Curves layer
  • VFB: Added polygon render region
  • VFB: Added ability to stop the rendering while preserving the post effects
  • Collaboration: Added ability to auto-generate panorama tours
  • Cosmos: Added ability to detect animated assets in Chaos Vantage and Envision
  • Swarm: Moved the Swarm settings to the Asset Editor
  • Swarm: Implemented Swarm 2 distributed rendering system
  • General: Implemented new standardized agreements acceptance workflow
  • UX/UI: Added a redirect message within the VFB History panel on how to enable history
  • UX/UI: Improved installer experience and consistency
Bug Fixes
  • General: Fixed Revit 2023.1.4 crash when enabling V-Ray
  • General: Crash when switching the GPU engine from RTX to Cuda with Buckets sampler on
  • General: Fixed “Unable to find an entry point named 'VRay_VRayRenderer_logVfbMessage' in DLL 'VRaySDKLibrary’” issue
  • General: Revit stops responding when opening VFB before first rendering
  • General: DirectoryNotFoundException on render start after enabling artificial lights
  • General: Fixed issue with saving to Revit’s Project Browser not working
  • General: Fixed core exception on render start with Scatter
  • General: Fixed issue with missing interactive updates when geometries are changed
  • Interactive: Crash when changing Scatter Density with a density map applied
  • Environment: Changing the View Distance of Aerial Perspective automatically sets to 0
  • VFB: Fixed issue with VFB not being displayed in some Revit versions
  • VFB: Crash on attempt to load a layers preset
  • VFB: Fixed Undo and Redo behavior when there is a Background layer
  • Cosmos: Fixed issue with Cancel/Esc not being applied properly after placing an asset
  • Cosmos: Fixed issue with V-Ray renderer not starting when the project contains Cosmos assets
  • Materials: AccessViolationException on .vrmat file migration in specific scene
V-Ray 7 New Features
