« Previous Version 3 Current »
This page provides information about using Python to script scene modifications between translation and exportation.
Page Contents
The V-Ray scene access Python API allows you to modify the V-Ray scene after it is translated by the V-Ray for Nuke translator and before it is rendered and/or exported to a .vrscene file. Note that the V-Ray scene may be quite different from its representation in Nuke. As such, some knowledge about the way V-Ray translates various Nuke constructs may be required. One of the best ways to learn this is to study .vrscene files exported by V-Ray for Nuke.
The scene access API allows you to expand the V-Ray for Nuke translator by providing custom translation for constructs that are not recognized by V-Ray, or for modifying the scene before rendering without changing the original Nuke scene.
You can specify the Python script to be executed in the VRayCommon tab of the Render Settings dialog, in the MEL/Python callbacks rollout. The script is executed right after the scene is translated and before it is rendered and/or exported to a .vrscene file. When rendering an animation, the script is executed just once, before any frame is rendered.
UI Path: ||Select VRayRenderer|| > Properties Panel > Post Translate tab
Available Python Functions
The following python functions are available in the vray.utils module.
create(pluginType, pluginName) – Create a plugin with the given name and type.
delete(pluginName) – Delete a plugin with the given name.
findByName(pattern) – Return a list of all plugins of a given type. pattern may contain wildcards.
findByType(pattern) – Return a list of all plugins of a given type. pattern may contain wildcards.
getPluginParams(plugin, getValues= False, onlyExisting= False ) – Return a list of all available parameters for the given plugin. If getValues is True the value for each parameter is also returned. If onlyExisting is True , then only parameters that are actually set in the V-Ray scene are returned; otherwise all plugin parameters are returned and the ones that are not set in the V-Ray scene are listed with their default values.
getTypeParams(pluginType) – Return a list of all parameters for a given plugin type.
exportTexture(textureName) – Export the texture from the Nuke scene and return the exported plugin. This function can be useful if the texture hasn't been exported while translating the scene.
exportMaterial(materialName) – Export the material from the Nuke scene and return the exported plugin. This function can be useful if the material hasn't been exported while translating the scene.
addSceneContent(scenefile, prefix="") – Load all plugins from the given .vrscene file and insert them in the current scene. You can optionally specify a prefix that will be prepended to every plugin's name. The scene file is loaded in a new namespace from the rest of the scene - if there are plugins that have the same name as other plugins in the scene, they remain as separate plugins.
appendSceneContent(scenefile, prefix="") – Load all plugins from the given .vrscene file and append them to the current scene, with an optional prefix. The plugins are appended in the namespace of the last loaded scene, so if there are already existing plugins with the same names, the data for their parameters is appended to the existing plugins. This can be used to load multiple .vrscene files from the same animated sequence. Wildcards can be used to specify scene files.
Available Python Classes
The following python classes are available in the vray.utils module.
Plugin
This class represents an instance of a V-Ray plugin in the scene.
duplicate(self, newName) – Return a new plugin instance of the same type and with the same parameters.
get(self, paramName) – Return the value of a parameter.
has(self, paramName) – Check whether the plugin instance has a parameter with this name.
name(self) – Return the name of the plugin instance.
params(self, getValues= False, onlyExisting= False ) – Return a list of all available parameters for this plugin. If getValues isTrue the value for each parameter is also returned. If onlyExisting is True, then only parameters that are actually set in the V-Ray scene are returned; otherwise all plugin parameters are returned and the ones that are not set in the V-Ray scene are listed with their default values.
output(self, paramName) – Return a reference to a plugin output parameter, which can be set as a value for parameters of other plugins.
set(self, paramName, value) – Set the value of a parameter.
type(self) – Get the type of the plugin instance.
Classes Representing Plugin Parameter Values
Parameters of the V-Ray plugins in the scene can be simple numbers, or more complex data types. Simple values can be directly manipulated, whereas complex types are represented by a dedicated python class.
PluginOutput
This class represents a reference to an output parameter of a V-Ray plugin. It is used whenever one plugin is connected to another plugin's output parameter.
AColor
This class represents a four-component color value (red, green, blue, alpha).
Color
This class represents a three-component color value (red, green, blue).
Vector
This class represents a three-component vector or point in 3D space.
Matrix
This class represents a 3x3 matrix.
Transform
This class represents a 3x4 transformation in 3D space.
Examples
Example: Changing the Color of a Material and Moving a Node
This example script changes the color of the material of the first node in the scene (assuming the original material is a lambert one) and moves the node one unit up.
from vray.utils import *
l=findByType("Node") # Get all Node plugins
p=l[0].get("material") # Get the material of the first node
brdf=p.get("brdf") # Get the BRDF for the material
brdf.set("color_tex", Color(1.0, 0.0, 0.0)) # Set the BRDF color to red
t=l[0].get("transform") # Get the transformation for the first node
t.offs+=Vector(0.0, 1.0, 0.0) # Add one unit up
l[0].set("transform", t) # Set the new transformation
Example: Converting Meshes to Subdivision Surfaces
This example shows how to converts all regular meshes in the scene to subdivision surfaces.
def smooth(geom, maxSubdivs = None, edgeLength = None):
  subdiv = create('GeomStaticSmoothedMesh', geom.name() + '@subdivGeometry') # Create a smoothed mesh plugin
  subdiv.set('mesh', geom) # Set the base geometry for the subdivision to be the original mesh plugin
  nodes = findByType('Node') # Get a list of all nodes
  for node in nodes:
    if node.get('geometry') == geom: # If a node references the original geometry...
      node.set('geometry', subdiv) # ...replace it with the subdivided one
  if maxSubdivs is not None: # Set the max. subdivs if specified
    subdiv.set('use_globals', False)
    subdiv.set('max_subdivs', maxSubdivs)
  if edgeLength is not None: # Set the max. edge length if specified
    subdiv.set('edge_length', edgeLength)
p = findByType('GeomStaticMesh') # Find all mesh plugins
for geom in p: # Replace each mesh plugin with a smoothed one
	smooth(geom)
Example: Instancing the First Node to Form a Helix
This example instances the first node in the scene a number of times to form a helix.
import math
geomNodes = findByType('Node') # Get all Node plugins
sp = geomNodes[0] # The first node
geom = sp.get('geometry') # The geometry of the first node
r = 12 # helix radius
n = 20 # number of objects per helix turn
m = 3 # number of helix turns
h = 0.5 # height difference between objects on the helix
for i in range(n * m):
  d = sp.duplicate('sphereNode' + str(i)) # Create a copy of the first scene node
  tr = d.get('transform') # Get the transformation matrix
  tr.offs += Vector(r * math.cos(i * 2 * 3.14159 / n), i * h, r * math.sin(i * 2 * 3.14159 / n)) # Add an offset according to the helix formula
  d.set('transform', tr) # Set the new transformation
Example: Exporting and Changing Materials
This example exports several textures and materials and changes the material of an object.
lambert = exportMaterial('lambert1') # Export lambert1 material
checker = exportTexture('checker1') # Export checker1 texture
cloth = exportTexture('cloth1') # Export cloth1 texture
brdf = lambert.get('brdf') # Get the 'lambert1@material' plugin
brdf.set('transparency_tex', checker.output('color')) # Set the transparency_tex parameter of the brdf
brdf.set('color_tex', cloth) # Set the color_tex parameter of the brdf
planeNode = Plugin('pPlaneShape1@node') # Get the plane node
planeNode.set('material', lambert) # Set the material of the plane
Example: Combining the Contents of Several Scenes
This example adds the contents of several scenes and uses some of the newly created plugins.
addSceneContent('blinn.vrscene', 'basic_') # Create all plugins in this scene file and prepend 'basic_' to the names of all plugins
addSceneContent('vraymtl.vrscene') # Create all plugins in this scene file and use the original names
blinn = Plugin('basic_blinn1@material') # Get the blinn material from the first added scene
vraymtl = Plugin('VRayMtl1@material') # Get the V-Ray material from the second added scene
nodes = findByType('Node') # Find all nodes in the scene
# Change the materials of some of the nodes
nodes[0].set('material', blinn)
nodes[1].set('material', vraymtl)
Example: Modifying the Parameters
This example demonstrates how to change the value of a more complex parameter. For instance, the ignored_lights parameter of the SettingsLightLinker plugin is a list of several sub-lists of plugins. The first plugin in each list is a light plugin and the rest of the plugins are geometry nodes. This is how the parameter can be modified:
lightLinker = findByType('SettingsLightLinker')[0] # Get the SettingsLightLinker plugin
directLight = findByType('MayaLightDirect')[0] # Get the first directional light
spotLight = findByType('LightSpot')[0] # Get the first spot light
nodes = findByType('Node') # Get all geometry nodes in the scene
param = [[directLight, nodes[0], nodes[1]], [spotLight, nodes[2]]] # Just create a list of lists
lightLinker.set("ignored_lights", param)
