Version 1 Next »
This page provides information on the Resimulation rollout.
Page Contents
Resimulation in general is a process that uses existing cache files as a base for another simulation pass. It works differently for Fire/Smoke and Liquid simulations.
You can resimulate over the resimulated caches and so on - it's not necessarily just 2 passes at most.
Due to the difference between the compression algorithms used by Phoenix FD's Aura format and the OpenVDB format, the resimulation process may produce a different result when using exported VDB caches as opposed to Aura caches if the Storage Quality option in the Output roll-out is set to a value lower than 20 (i.e. Lossless).
Fire/Smoke Resimulation uses an already simulated cache sequence with exported velocity (base simulation) to drive a new simulation with any of these added effects:
  • Increase resolution while keeping the shape and behavior. (It's possible to add wavelet turbulence to increase detail or simply amplify the resolution)
  • Slow down or speed up the animation, as well as apply animated time scale using Phoenix's Time Bend controls. See Slowing Down a Simulation, Animating the Time-Scale, etc.
  • Keep the grid channels such as Smoke, Temperature, etc. unchanged and only change the dynamics or number of Drag particles, or vice versa.
Rendering and simulation cache paths can be set manually. For information on how to do this, see the Tips and Tricks page regarding simulation paths and resimulation paths.
When performing a fire/smoke resimulation, it is recommended that you leave the Dynamics settings unchanged between running a base simulation and resimulation unless more advanced behaviors are specifically needed.
The resimulation workflow for Fire/Smoke is as follows:
Enable Velocity in the Output rollout. If you are going to add wavelet turbulence as well, also enable the export of the Wavelet channel.
Start the original (base) simulation and let it run through.
Enable Grid Resimulation or Particle Resimulation. Adjust the resimulation options in this rollout if needed.
Start the simulation again - this time the Resimulation will take place. You can switch between preview and render of the base and resimulated caches by enabling/disabling the Resimulate checkbox.
Liquid Resimulation uses an already simulated cache sequence and allows you to add, delete or modify the Splash, Mist, Foam or Wetmap particle systems. It will preserve the Liquid and the particle systems you are happy with.
The particle resimulation will affect only the particle systems which are checked in this rollout. If a particle system is not checked, it will remain unchanged. The Liquid always remains unchanged. While the Fire/Smoke Resimulation creates new cache files during the simulation process, the Liquid Resimulation overwrites the existing cache files.
Using Resimulation to just modify a particle system is practical only in case you have a large number of secondary particles such as Foam, Splash, etc in relation to the number of Liquid particles. If you have mostly Liquid particles and very few other particles, it will be faster to just simulate again.
Select Resimulation → Affect → Particles and enable the respective particle system below (ie. Splash and Mist, Foam or Wetting).
Modify the particle system's settings - e.g. for Foam, go to the Foam roll-out and tweak the parameters there.
Hit Start to run the simulation again - repeat this process until you are happy with the result.
Make sure the particle system's simulation is Enabled, e.g. for Foam open the Foam roll-out → select the Enable Foam option.
Hit Start to run the simulation again - the particle system will be added to the cache sequence.
Make sure the particle system's simulation is Disabled, e.g. for Foam open the Foam roll-out → deselect the Enable Foam option.
Hit Start to run the simulation again - the particle system will be removed from the cache sequence.
UI Path: ||Select PhoenixFDSim|| > Attribute Editor > Resimulation rollout
Resimulate | resimulate – Enables/disables resimulation mode. When enabled, all normal parameters/actions affect the resimulation. When enabled, the preview and rendering will read from the Output Simulation Path instead of the Input Path.
Use Simulation Start Framers_start_from_sim - When enabled, the Resimulation will run from the first frame of the base simulation to the simulation End Frame or the Custom Stop Frame, depending on the options.
Custom Start Frame | rsStartFrame – Explicitly sets the Start frame of the Resimulation. This can also be a negative number.
Use Simulation Stop Framers_stop_from_sim - When enabled, the Resimulation will run from the base simulation Start Frame or the Custom Start Frame to the last frame of the base simulation.
Custom Stop Frame | rsStopFrame – Explicitly sets the End frame of the Resimulation. This can also be a negative number.
Affect | rsAffect – Specifies which part of the simulator to be affected during the resimulation.
Grid – Simulates only the grid content. If there are existing particle groups in the input cache, they will be directly copied to the new cache.
Particles – Simulates only particle groups (i.e. foam/splashes/drag particles). The grid will be directly reused from the input cache.
Both – Simulate both grid and particles.
Amplify ResolutionrsResAmplify – Magnifies the grid resolution. A value of 0 means no change, 1 means doubling the voxel amount in all axes (2*2*2=8 times the resolution), 2 means tripling (3*3*3=27 times the resolution), etc. Non-integer values can also be entered, however, they are slightly slower to calculate. The resolution can also be decreased by using a negative value.
Amplify Method | rsResAmplifyMethod – When the grid resolution is increased, this parameter specifies which method to use to sample the velocity.
Interpolate – Use interpolation. The velocity channel is stretched from the lower resolution to the increased one.
Wavelet Fast – Use wavelet turbulence to synthesize fine detail. Needs a Wavelet channel exported from the base simulation. This is a slightly faster approximation method.
Wavelet Nice – Use wavelet turbulence to synthesize fine detail. Needs a Wavelet channel exported from the base simulation.
Wavelet Strength | waveletStrength – Specifies the strength of the wavelet turbulence.
Wavelet Cutoff | waveletCutoff – Turbulence with smaller amplitude will be cut off to reduce calculation time.
No-Export Channels | rsTempChannels – Specifies the channels that are used just for resimulation, which will not be exported to the resimulation output cache. For example, for wavelet turbulence, removing the UVW/Wavelet and Velocity channels from the final simulation will reduce the cache size.
Splash and MistrsPartSplash – Specifies that the splash and mist will be recalculated.
The Affect Liquid parameter on the Splash and Mist rollout will be ignored when resimulating Splash, because the liquid is already simulated and cannot be changed without a full simulation.
FoamrsPartFoam – Specifies that the foam will be recalculated.
WettingrsPartWet – Specifies that a WetMap will be recalculated.
The Sticky Effect setting for Wetting in the Liquid rollout will be ignored when resimulating wetting. This is because the liquid is already simulated and cannot be changed without a full simulation.
Example: Resimulation with Wavelet Turbulence
The example below shows the difference between a base Fire/Smoke simulation and the Resimulation result when using Wavelet Turbulence.
Base Simulation
Resimulated with Amplify Resolution = 1
and Wavelet Nice Method
Time Bend
Phoenix has many tools for changing the animation timing of a cache sequence after it is simulated. Resimulation with enabled Time Bend Controls can produce smoother playback in cases where the Input Time Bend controls are insufficient. For more information on Resimulating with Time Bend, see the Slowing Down a Simulation, Animating the Time-Scale, etc. section on the Tips and Tricks page.
Use Time Bend ControlsrsGridTimeBend – Change the time scale of the base simulation according to the Time Bend Controls in the Input rollout. You need to re-scale the animation of all other interacting objects and sources in the scene as well.
Time Bend Method | rsGridTimeBendMethod – A method to use when scaling the time of the resimulation. Note that both methods work best when Steps per Frame on the Dynamics rollout is set to 1. Note that speeds below 0.2 may produce unsatisfactory results when using either method.
General-Purpose – Works for all play speeds including backwards playback. It resimulates more quickly, but might produce flickering or jittering in the movement of the fluid. Sources or forces do not need to be present in the scene for this method. However, this method may not produce satisfactory results with animated sources.
Slow Down – Works only for play speeds between 0 and 1. It will produce smooth playback without flicker or jitter but will add more dissipation in the long run, so it's better to combine it with Multi-Pass Advection. This method requires all used sources and forces to be present in the scene. Any animation will need to be adjusted accordingly.
Example: Time Bend Resimulation
The example below shows the difference between the Input roll-out → Frm.Blend Interpolation used to slow down without resimulating, the Resimulation → Slow Down Time Bend Method and the Resimulation → General-Purpose Time Bend Method.
Input Play Speed = 0.2, Interpolation Blend
Slow Down method + Wavelet
General-Purpose method + Wavelet
Resimulation Cache
During resimulation, Phoenix reads cache files in the Input Simulation Path, performs resimulation operations, and then saves a new cache sequence in the Output Simulation path.
For information on changing the default paths for resimulation, see the Tips and Tricks page.
Cache Waiting | rsWaitMode – When enabled, waits if the base cache file is not yet available. This can be used if another instance of Maya is simulating the base cache at the same time (on the same or other computer).
Base Cache Files Path | rsInput – Specifies the base simulation caches which will be used as base for resimulation. $(same_as_output) by default. The field below shows the resolved full path.
Output and Render Path | rsOuptut – Specifies the path for the output cache files. See the Simulation Save Path parameter in the Output Rollout for details. The bottom control shows the resolved full path.
Click the "...button to open a menu with the following options:
Browse - Opens a dialog for choosing one of several cache file types. Phoenix FD can import *.f3d and *.vdb files from other fluid simulator software products. Supported file types are Phoenix FD *.aur, Field3D *.f3d and OpenVDB *.vdb.  See How to import and render simulations from FumeFX, Houdini and Maya for more information.
Delete Cache Files - Clears the simulations files matching the provided Simulation Save Path pattern.
Reset to Default - Resets the Simulation Save Path to the default value of $(same_as_output).
Help - Opens the Help page for the Input tab of the Phoenix FD Simulator.
If the Output and Render Path coincides with the Input Simulation Path, Phoenix FD will not prevent you from overwriting your existing cache files. It's valid to do so if you need a more complicated setup or when not enough disk space is available.
 The following error message may appear when you start a re-simulation:
"Cannot start the Re-Simulation! Please make sure the simulation was run with the 'Velocity' channel checked under the 'Output' roll-out, and that the cache files in the Simulation Input path exist."
The reason may be that either the files in the Input Simulation Path do not exist at all, or they do not have Grid Velocity Channel exported when you have simulated them beforehand. Of course, you may use more complicated setups where you resimulate over an already resimulated cache file, or you may Load an existing base cache file as the initial state of the re-simulation. These are all possible; you just need to have velocity in the base cache and an existing path to it.
