© Bertrand Benoit
« Previous Version 2 Next »
This page provides information about export .vrscene file with V-Ray for Unreal.
VRayScene allows for assets to be shared between all platforms that run V-Ray.
Exporting a .vrscene
A vrscene from the an Unreal project can be exported with in two ways:
V-Ray toolbar
ІІV-Ray toolbar drop-downІІ > Export vrscene
VRScene Name – Enables the export of a .vrscene file when the V-Ray render button is clicked.
Export VRScene Path – Directory where the .vrscene file is saved. Default directory is <ProjectPath>\Content
Compress – Compresses geometric information thus making the resulting .vrscene file smaller.
(plus) NEW - When you export a .vrscene a .bat file is also created with the name specified in VRScene Name and in the directory set in Export VRScene Path. You can use the .bat file to render the exported .vrscene in standalone, outside of Unreal
V-Ray Bake Settings
Export VRScene – Enables the export of a .vrscene file when the V-Ray Bake  button is clicked.
Export VRScene Path – Directory where the .vrscene file is saved with the file name bake#.vrscene. Default directory is <Project_Path>
Supported Features
