©BBB3viz
« Previous Version 2 Next »
This page gives information on the  Raw Lighting Render Element.
The Raw Lighting Render Element stores the effects of direct lighting on scene objects with no diffuse components. It is useful for adjusting the brightness of direct lighting during compositing.
UI Path
||Render Setup window|| > Render Elements  tab > Add button > VRayRawLighting
vrayVFB  – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
deep output – Specifies whether to include this render element in deep images.
color mapping – Applies the color mapping options specified in the  Color mapping  rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
denoise –  Specifies whether to denoise this render element.
Common Uses
The Raw Lighting Render Element is useful for changing the appearance of direct lighting after rendering in a compositing or image editing software. Below are a couple of examples of its use. In this set of render elements, direct lighting affects the floor and wall a great deal more than the ceiling.
The Original Beauty Composite
Brightened Lights
Tinted Lights
Underlying Compositing Equation
  VRayRawLighting   x VrayDiffuseFilter = VRayLighting
