©BBB3viz
This page provides information on the Sheen Specular Render Element.
The Sheen Specular Render Element is analogous to the Specular Render Element.
The Sheen Specular RE stores the direct specular reflection (highlight) information calculated from the VRayMtl Sheen Layer. Specular reflection is defined as the reflection of light from a surface in a single particular reflection, as opposed to a diffuse reflection which is reflected at many angles.
The brighter the area, the more highlight reflection the object exhibits in the render. Specular highlights are colored if the Reflection Color parameter of a material is colored.
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
