« Previous Version 2 Next »
This page lists all processes that create and destroy the different FLIP liquid particle types, including conversions between particle types.
Liquid
Simulated whenSimulator Output rollout Liquid Grid/Particles enabled
Birth:
Life:
  • At places where the liquid velocity gradient is high, creates Foam particlesRequiresFoam is simulated
  • At places where the liquid surface has sharp edges, creates Splash particlesRequiresSplash is simulated
  • At places where the liquid is in free fall, creates Splash particlesRequiresSplash is simulated + Simulator Splash rollout By Free Fly > 0
  • On contact with a Solid geometry, creates WetMap particlesRequiresWetMap is simulated + geometry has Wetting property
Death:
Foam
Simulated when: Simulator Output rollout Foam Particles enabled + Simulator Foam rollout enabled
Birth:
  • At places where the liquid velocity gradient is highRequiresLiquid is simulated
  • When Splash particles die on entering the Liquid volumeRequiresSplash is simulated + Simulator Splash rollout Foam On Hit > 0
  • From any Source (Source Particles enabled + Source Particle Type = Foam)
Death:
Splash
Simulated whenSimulator Output rollout Splash Particles enabled + Simulator Splash rollout enabled
Birth:
  • At places where the liquid surface has sharp edgesRequiresLiquid is simulated
  • At places where the liquid is in free fallRequiresLiquid is simulated + Simulator Splash rollout By Free Fly > 0
  • From any SourceRequiresSource Particles enabled + Source Particle Type = Splash
Life:
  • On free fall, splits into several smaller Splash particles RequiresSimulator Splash rollout Splash to Mist > 0
  • On movement, creates Mist particles and decreases its Particle SizeRequiresMist is simulated + Simulator Splash rollout Splash to Mist > 0
  • On death due to entering the Liquid volume, or due to contact with a geometry, creates Liquid particlesRequiresLiquid is simulated + Simulator Splash rollout Affect Liquid > 0
  • On death due to entering the Liquid volume, creates Foam particlesRequiresFoam is simulated + Simulator Splash rollout Foam On Hit > 0
Death:
Mist
Simulated whenSimulator Output rollout Mist Particles enabled + Simulator Splash rollout enabled + Simulator Splash rollout Splash to Mist > 0
Birth:
Death:
WetMap
Simulated when: Simulator Output rollout WetMap Particles enabled + Simulator Dynamics rollout Wetting enabled
Birth:
Death:
