« Previous Version 10 Next »
This page provides information on the PHXTurbulence component.
This component adds turbulence that can be controlled. The turbulence can be added in two different ways:
  • as a divergence-free force (force with circular lines);
  • as pressure.
The turbulence generator is based on fractal-like noise function, similar to the noise texture in 3ds Max.
By default, the Turbulence affects all Phoenix Fire/Smoke and Liquid Simulator objects in the scene. You can exclude it from interacting with a simulator from the Exclude list in the simulator's Interaction rollout.
Create Pressureinjmode – Switches between pressure and force mode. While force mode simply adds velocity, pressure mode works in a similar way to the Source in Volume Inject mode, adding pressure to the areas displayed in red in the preview. This way the option will generally affect the appearance and behavior of the turbulent effect. Note that if Create Pressure is on, the Turbulence helper will not take into account the fluid density and will uniformly affect all voxels. However, if it's Not in Pressure mode, it will act more strongly on the dense voxels and more mildly on the ones where the channels in the Affect list have lower values.
Strength mult – General amplitude multiplier.
Size size – General scale multiplier.
Fractal Depth | depth – The number of the additional stages (the real number is this parameter + 1).
Last Stage Scale | lss – The scale of the last stage. The scale of the first stage is 1. The intermediate stages are between 1 and this parameter.
Last Stage Amp. | lsa – The amplitude of the last stage. The amplitude of the first stage is 1. The intermediate stages are between 1 and this parameter.
Random Seed | seed – Initial value for the random generator.
Rate of Change | speed – The noise change speed.
Decay decay – How the multiplier decreases with the distance.
None – No decay.
Inverse Distance – Decreases with the inverse distance.
Inverse Square – Decreases with the inverse square of the distance.
Sphere – No decay in a sphere with radius 1 (in scene units with radius equal to the size) and no action outside the sphere.
Affect affect – Lists the grid channels or particle systems the Turbulence affects, separated by commas.
  • Valid strings for Affect are: liquid, splash, splashes, foam, air, mist, wetmap, temperature, smoke, fuel, rgb, velocity, viscosity.
  • The names are not case sensitive and spaces are ignored.
  • If Create Pressure is enabled, the Affect list will be ignored as the entire simulation volume will be affected by the pressure force.
Preview
Show Streamlines partpreview – Affects the preview. When enabled, visualizes the trajectories of several particles.
