This page introduces the different material types in V-Ray for Houdini.
There are a number of different materials for use with V-Ray for Houdini. These materials are quite versatile and each can be used in a number of ways to achieve different looks as needed from simulating simple surface properties like plastics and metals, to simulating complex uses such as translucent objects, subsurface materials such as skin, and even light emitting objects.
Some basic information on each material can be found below, but for more details, please see the dedicated pages for each one.
Note: Standard Houdini materials are not supported by V-Ray!
UI Paths
||shop Network|| > Material > V-Ray Material node > V-Ray > Material sub-menu
 ||mat Network|| > V-Ray > Material sub-menu
V-Ray Material Builder Node
The V-Ray Material Builder (vrayMaterialBuilder) node is a container that allows you to create V-Ray materials, textures, and additional V-Ray nodes.
By default, it creates a V-Ray Material (BRDFVRayMtl) connected to a V-Ray Material Output node. For additional information, see the V-Ray Material Builder page.
List of V-Ray BRDF Materials
Blend
Bump
Car Paint
Hair
Light
Override
Hair 3
VRscans
Skin
SSS
V-Ray alSurface
V-Ray Material
Two Sided
VRmat
Wrapper
VRayToonMtl
V-Ray Toon Material
VRayMtlOSL
V-Ray OSL Material
List of Additional V-Ray Material Nodes
