This page gives some basic details about the Shadow Render Element and how it is used in compositing.
||Render Settings window|| > Render Elements tab > Shadow
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.shadow.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
The Shadow Render Element is useful for changing the appearance of shadowed areas in a compositing or image editing application. Below are examples of possible uses.
vrayRE_Raw_Shadow x vrayRE_Diffuse = vrayRE_Shadow
