This page gives an overview of the Global Illumination render element and explains how it is used in compositing.
The Global Illumination Render Element is a color image that stores indirect lighting information coming from reflected diffuse light in a scene (without direct light and reflection contributions) when Global Illumination is enabled in Render Settings. This element may be used directly in Back to Beauty compositing and adjusted for brightness and color to control the final image easily.
For even more control of indirect illumination without re-rendering the scene, the Global Illumination render element may be re-assembled by multiplying the Raw Global Illumination Render Element by the Diffuse Render Element:
vrayRE_RawGlobalIllumination x vrayRE_Diffuse = vrayRE_GlobalIllumination
||Display Render Settings button|| > Render Elements tab > GI
Render (menu) > Render Settings > GI
Attributes
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.GI.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Common Uses
The Global Illumination Render Element is useful for changing the appearance of Indirect lighting after rendering, using a compositing or image editing software. Below are a couple of examples of its use.
Original Beauty Composite
Brightened GI
Tinted and Brightened GI
Compositing Formula
Raw GI x vrayRE_Diffuse = vrayRE_GI
