This page provides information on how V-Ray options are integrated into the Houdini menus.
V-Ray adds a number of commonly used V-Ray components to Houdini's main menu. From these options, you can manage Render, Object, and Displacement properties; import files; and manage VFB and V-Ray IPR.
UI Paths
||V-Ray menu|| > V-Ray components
Render menu
V-Ray Main Menu
MenuDescription
RenderCreates a V-Ray Renderer node.
Render VFB IPROpens the VFB and starts V-Ray IPR.
Render SettingsOpens the V-Ray Render Settings window.
Show VFBOpens the V-Ray Frame Buffer.
Global SettingsOpens the V-Ray Global Settings.
Object PropertiesOpens Object Properties submenu.
ImportOpens Import submenu.
Pack SceneOpens the Report Bug/RFE dialog.
Chaosgroup.com
Opens Chaos Group website.
HelpOpens the Help submenu.
About V-RayShows you information about the installed version.
V-Ray Object Properties Submenu
MenuDescription
CommonOpens the Object Properties tab.
DisplacementOpens the Displacement Properties tab.
HairOpens the Hair Properties tab.
CameraOpens the Camera Properties tab.
Physical CameraOpens the Physical Camera Properties tab.
V-Ray Import Submenu
Menu
Description
Material (.vrscene)Imports a material from a .vrscene file.
AUR Cache (.aur)Imports an .aur cache file (a Phoenix simulation cache file).
Help Submenu
MenuDescription
DocumentationOpens the V-Ray for Houdini online documentation.
TutorialsOpens the Tutorials page of the V-Ray for Houdini online documentation.
ForumOpens the V-Ray for Houdini forum.
Render Menu
MenuDescription
Create Render NodeCreates a V-Ray Renderer node as well as a V-Ray Renderer IPR node.
Edit Render NodeOpens a list of existing V-Ray Renderer and V-Ray Renderer IPR nodes. When you click on a given node, its ROP parameters are displayed for edition.
