This article explains how to prepare your scene for Chaos Arena.
Follow the steps below to prepare your content scene for Chaos Arena.
Scene Preparation
Make sure the scene has a correct physical scale.
Set up the tracked camera.
- Add a new Physical camera. The location of the camera in the scene doesn't matter.
- Set the Focal length and Film gate to match the actual camera used on set.
- Set a reasonable Focus distance, for example, 2 meters.
- Adjust the exposure of the camera according to the scene.
Set up the projection, depending on the desired workflow:
- Add stage position nodes if you use a Stage Geometry scene in the configuration.
- Alternatively, directly import the stage geometry into the scene and position it as desired.
Set the render resolution to match the camera's aspect ratio. A high enough resolution is also helpful for the operator instances, as Arena clamps the render resolution to the camera resolution in the scene by default.
Repath all assets to a shared network drive if needed.
Export a .vrscene file.
- Ensure the primary render camera is the tracked camera in the exported scene.
- Make sure to enable animation export if there are animations in the scene.
- Use the Archive option in the .vrscene export settings if desired. It packs the scene and all assets and makes it portable. Useful if local assets are not stored in a shared location. In this case, re-pathing the assets is unnecessary; all paths are converted to relative.
Follow the links below for detailed instructions for .vrscene export per host app.
