Square Enix © Goodbye Kansas
This page provides details on the V-Ray Toon Specular Render Element.
The Toon Specular Render Element is an image that stores Toon Specular reflection (highlights) information calculated from the VRayToonMtl.
The brighter the area, the more Toon highlight reflection the object exhibits in the render. Toon Specular highlights will be colored if the Reflection Color parameter of a material is colored.
The Toon Specular RE is included in the Specular RE. It can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||Display Render Settings button|| > Render Elements tab > Toon Specular
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
Attributes
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.Toon.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color Management rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
