Floatingpagetoc
CSS Stylesheet
.relative-table {
    width: 100% !important;
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap30px
Columns1width1540px
Columns2width1290px
This page provides information about the mouse and key shortcuts in Chaos Vantage.
width60%
Vantage provides a list of mouse and key shortcuts for easier navigation and commands execution. The navigation can be set to work as in 3ds Max, SketchUp or Maya. This can be set from the Navigation Preset drop-down.
To see the full list of shortcut keys in Chaos Vantage, go to Edit > Mouse and Key Shortcuts.
To understand the shortcuts below, you should assume the following abbreviations:
AbbreviationControl
LMBLeft Mouse Button
RMBRight Mouse Button
MMBMiddle Mouse Button
[3]/[S]/[M]
Shortcut depending on navigation preset:
[3] - 3ds Max
[S] - Sketchup
[M] - Maya
width5%
width35%
width60%
Shortcuts which are not greyed out can be edited. New keys or combination of keystrokes with modifiers can be assigned by using LMB click on the shortcut or RMB click > Edit. Additional options for shortcuts are Delete, which removes the shortcut and Reset, which restores it to default value.
width5%
width35%
div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
div
General Shortcuts
CommandShortcut
Toggle InterfaceCtrl+`
Toggle Fullscreen ModeAlt+Return
Flip Up Axis Z/YY
Pause RenderingPause
Frame Selected/Scene[3] Z
[S] Z
[M] F
div
Navigation Shortcuts
CommandShortcut
Dolly Camera Sideways[3] MMB
[S] Shift+MMB
[M] Alt+MMB
Orbit Camera[3] Alt+MMB
[S] MMB
[M] Alt+LMB
Fine/Smooth Camera Zoom[3] Ctrl+Alt+MMB
[S] (error)
[M] Alt+RMB
Toggle First Person Mode`
Toggle Camera CollisionC
Camera Move Forward (when in First Person mode)W
Camera Move Backward (when in First Person mode)S
Camera Move Left (when in First Person mode)A
Camera Move Right (when in First Person mode)D
Camera Move Up (when in First Person mode)E
Camera Move Down (when in First Person mode)Q
Camera Move Faster (when in First Person mode)Shift+
Camera Ignore Collisions (when in First Person mode)Ctrl+
Camera Pan UpUp
Camera Pan DownDown
Camera Pan LeftLeft
Camera Pan RightRight
div
Camera Shortcuts
CommandShortcut
Change Focus DistanceCtrl+Alt+LMB
Change FOV[3] Alt+RMB
[S] Alt+RMB
[M] (error)
Roll CameraCtrl+MMB
Toggle Camera RecordingCtrl+Shift+R
Undo CameraAlt+Z
Redo CameraAlt+Shift+Z
Level the CameraX
Save New CameraCtrl+K
Overwrite CameraCtrl+Shift+K
Switch to Home CameraHome
Switch to Next CameraPgDown
Switch to Previous CameraPgUp
Load Camera SlotF1..F12
div
Tool Shortcuts
CommandShortcut
SelectQ
Group SelectShift+Q
TranslateW
RotateE
ScaleR
Pick FocusT
SnapS
UndoCtrl+Z
RedoCtrl+Shift+Z
Copy Viewport to ClipboardCtrl+C
High Quality Render SetupCtrl+R
Always On TopCtrl+Alt+T
div
Selection Shortcuts
CommandShortcut
Make Selection InvisibleV
Make Selection VisibleShift+V
Select ParentCtrl+Up
Save SelectionCtrl+0..9
Restore Selection0..9
div
Animation Shortcuts
CommandShortcut
Play/Pause AnimationSpace
Scroll though the timelineMouse wheel
Zoom in/out of the timelineAlt+Mouse wheel
