The Chaos License Server is the bridge between the Chaos Product and the Chaos Account associated with a given license. You cannot use any Chaos product without a license. You connect to the License Server by installing the license application locally on your machine or connecting to a machine in your local network that has a shared Premium license set up. If you are hosting a Premium Chaos License Server for multiple machines, please see the Administrator Workflow. Please follow the instructions for your subscription plan: The Solo License requires the server to be installed directly on your machine. The Solo License can only be used by a single user with a user login. If you accidentally close the window, you can type 127.0.0.1:30304 / localhost:30304 in a web browser. Keep in mind that you cannot use any Chaos products without an active license! The Premium License can be shared between multiple users and devices, or it can be used locally - similar to the Solo License. If you only plan to use the license on your machine, see the Solo License section. When doing a shared setup for a Premium license, the license holder needs to install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license. If you are the license holder, i.e., the administrator, see the Administrator Workflow page. Here is how to connect to an already set-up Premium shared license: Example screenshot You can also 'borrow' a license to use offline on a machine with unstable or with no internet access. For more information, see the Borrowing Licenses for Offline Use page. If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions. Visit the License Server section of the documentation for further details on the Chaos License Server, such as how to check your license expiration and status, how to access various settings, and more advanced options.Activate the License
Borrow Licenses for Offline Use
Troubleshooting
Next Step
Go to step 3 to see how to load Anima.
