Square Enix © Goodbye Kansas
« Previous Version 7 Next »
This page provides information on the Raw Lighting Render Element.
The Raw Lighting Render Element stores the effects of direct lighting on scene objects with no diffuse components or GI contribution.
This is useful for adjusting the brightness of direct lighting during compositing.
Attributes
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawLight.img).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
This render element is not supported with V-Ray GPU rendering.
Common uses
The Raw Lighting Render Element is useful for changing the appearance of direct lighting after rendering in a compositing or image editing software. Below are a couple of examples of its use. In this set of render elements, direct lighting affects the back of the alien figure the most due to a strong back-light in the scene as well as the top of the circular machine above the figure.
The Original Beauty Composite
Brightened Lighting Render Element
Brightened and tinted lighting Render Element
Brightened Lights
Raised and tinted Lights
Underlying Compositing Equation
 vrayRE_Raw_Light x vrayRE_Diffuse = vrayRE_Lighting
