« Previous Version 5 Next »
To run Corona for 3ds Max, you have to:
This page serves as a guide for installing Corona for 3ds Max. If you would like to try Corona for 3ds Max or Cinema 4D, download and run the installer.
If you are using User Account Control (UAC), a security prompt opens when launching the installer. You need to confirm that the installer can proceed.
Trial users should refer to the Trial Installation of Corona for 3ds Max article, as the process differs from the one shown here.
Download Corona for 3ds Max
Running the Installer
Before running the installation, make sure your Windows account has administrative privileges.
Run the installer. Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
Welcome
Carefully read the End User License Agreement and the Global Consumer Privacy Policy. Click the I accept buttons if you agree to the terms.
Proceed to click the Install button.
If you need to customize your Corona for 3ds Max installation, click the Advanced button.
If you need to unpack all the installer files into a specified directory, click the Unpack button. This option is useful for advanced users and debugging purposes. For instance, you might choose this option when installing the plugins manually or troubleshooting installation issues. For example, if the installer cannot detect any host application, you can unpack the files and copy them manually.
The Install option uses the localhost for licensing by default and installs the software in a default directory.
Unpack Installation
Directory – Specifies an unpack root directory where the installer files are extracted.
Advanced
Here, you can specify for which version of 3ds Max to install Corona. You can also select components you wish to include in the installation - Chaos Cosmos Service and NVIDIA AI Denoiser.
Also, decide if you need to install the DR Server, Corona Standalone and the Corona Image Editor, and if so, where you want to install them.
Click Continue to proceed.
Licensing
In this step, specify whether the Chaos License Server runs locally or on another machine.
If you select Remote licensing, you have to enter the IP address of your Chaos License Server in the Primary License Server field. Leave port 30304 unchanged. An Alternate License Server can be used for redundancy in case the primary one does not respond. The License Server will not install when the Remote option is selected.
When Local licensing is selected, the Chaos License Server is installed with Corona.
For information about the advanced Chaos License Server installation settings, visit the Instance a License Server in a Network page.
Chaos License Server Options
At this step, you can choose where to install the Chaos License Server.
Migrate data during installation – When enabled, it transfers all of your settings made with older versions of the License Server, such as proxy settings, etc. Disabling this option makes a clean install of License Server with any custom settings from previous installations reset to their defaults.
Add firewall exception – Allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you must manually add firewall exceptions later.
Chaos Telemetry
Corona for 3ds Max installation is successful.
Participate in the improvement decisions for future versions of Corona. No intelligence property is violated when agreeing to participate in the improvement program. Chaos does not gather scenes, assets, materials, etc. For more information, see the Chaos Telemetry page.
Anonymized Telemetry – Includes the most used product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
Personalized Telemetry – Includes the most used product functionality, parameter values, but also contains personally identifiable information tied to an individual user's license. This helps Chaos tailor and optimize the product for better personal use.
Welcome
Please take a moment to review the End User License Agreement. Once you've carefully read the License Agreement, you can click I accept the terms and conditions if you agree to the terms.
Participate in the improvement decisions for future versions of Corona by agreeing to Help improve Chaos Corona by sending Product usage data. No intellectual property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc. For more information, see the Privacy Notice.
Click Next to proceed.
Install Type
Typical – This is the fastest, fully automated installation type. It is recommended for most users. This mode installs Corona plugins for all software versions detected, plus the Corona Image Editor (GUI and Command Line versions) and the Corona Distributed Rendering server.
If you already have an older version of Corona installed on your system, this mode is renamed to Update
When installing Corona 8 or newer, you may see this option grayed out and with a short explanation instructing you to use the Custom installation mode instead. For more information, see the Basic Information on Corona and the Chaos License Server article.
Click Install to proceed.
CustomThis is an advanced installation method that allows you to choose the specific items to be installed and their locations. Useful, for example, when you have different 3ds Max versions installed, and you want to install Corona for only one of them or if you only want to install certain components (such as the DR ServerChaos LicensingCorona Standalone, or the Corona Image Editor).
Unpack filesThis unpacks all the installer files into a specified directory. Useful for advanced users and debugging. You might opt for this option, for example, when installing the plugins manually, or if there are problems during the installation, e.g., if the installer could not find any host application, then you can unpack the files and copy them manually. For more information on the manual installation of Corona, see: How to install Corona manually?
Click Unpack to proceed.
Options
Custom Install Type
If you select the Custom installation type, after selecting Next, you are presented with the customizable options. Select the version of 3ds Max you wish to have Corona installed in. You can also select the components you wish to include in the installation - Chaos Cosmos Services, Chaos License Server, NVIDIA AI Denoiser, and the Material Library. Also, decide if you need to install the DR Server, Corona Standalone, and the Corona Image Editor, and if so, where you want to install them.
By default, the Material Library is downloaded from the internet, but you can also use an offline file to install it. For more information, see the How to install the material library in offline mode article.
Summary
After a successful installation, you see the following message: Chaos Corona was successfully installed on your computer. Any errors are marked with a red font
Click Finish to enjoy Corona.
Activate Corona
Before running 3ds Max, make sure that your computer is connected to the Internet.
Silent Installation
The Corona installer can be run with the following command line parameters:
ParameterDescription
-h or --helpDisplays command-line help.
--acceptEulaAndAutoInstall
Runs the installation in console mode with no user input. It is the same as running the typical installation option in GUI, accepting the EULA, and finishing the installation process.
Important note:
Currently, there is no way to specify which items should be installed during silent installation. This means that when Corona is already installed, the installer will remember the last items selected by the user (e.g. which 3ds Max versions were selected, what additional components were selected). If you uninstall Corona and run the installer in silent mode, it will use the default behavior - it will detect which versions of 3ds Max are installed and will install all additional components.
Console mode may not work as expected when run directly from the Windows command line console. In such a case, the console will not wait for the installer to finish and will display a new prompt. It will also capture and accept user input while the installer is running and printing into the console.
Solution: The issue will not appear when using a .bat file or any other script, which is the intended use case. In this case, the script correctly waits for the installer to finish before proceeding.
Next Step
