« Previous Version 2 Next »
This page provides details on the V-Ray for Revit UI and how it is integrated into the Revit interface.
The V-Ray for Revit Ribbon gives you access to all of the settings and options that you will need with V-Ray.
View
This allows you to select which one of the Revit 3D views to render.
Render
Allows you to choose your Render type and open up the V-Ray Frame Buffer.
Quality
Provides a drop down menu with a specific set of presets. They provide preset settings ranging from very low quality “Low” settings to “High+” settings.
Resolution
Allows you to choose your Output and Crop Box resolution size.
Lighting
Gives you access to the options for the V-Ray Sun, V-Ray Dome Light, No V-Ray Lights and Artificial Lights.
Assets
Gives you access to the V-Ray Asset Editor and V-Ray Appearance Manger.
Camera
Gives you access to the V-Ray Camera settings.
Gives you access to the V-Ray Settings.
Opens the online V-Ray for Revit Help documents.
The following Render options are accessible through the panel:
  • Online Help - This will take to you the V-Ray for Revit home page.
  • Disable V-Ray - Releases your V-Ray license. V-Ray for Revit will be locked and won't be available for use.
  • About - Displays V-Ray version information and the End User License Agreement, as shown in the image below.
  • Feedback - redirects to the V-Ray for Revit forum where users can give us feedback.
  • License Server - Opens a webpage to your Online License server information.
V-Ray
Allows you to acquire your license and gives you access to the Online License Server.
