This page provides information on the Splash/Mist rollout.
This rollout affects the splash and mist simulation. Because these systems are closely related and share many properties, they are controlled by a common user interface.
A splash and mist rollout, separate from the liquid simulation, is provided in order to optimize memory and CPU usage. While normal liquid simulation can produce splash, and if you increase the resolution to extreme values it will produce mist as well, such a simulation would run slowly and consume an incredible amount of resources. Besides saving on resources and rendering time, there is another strong advantage to controlling splash and mist separately from the liquid itself: different shaders can be used for splash/mist and the liquid.
Splash and mist can be simulated in two different ways: as fully separated systems (non-physical mode), or as part of the liquid simulation (physical mode, the default). In physical mode, the liquid, splash and mist systems can be seen as single system with adaptive levels of detail. Following certain rules, the liquid can be converted into splash, the splash can be converted into mist or back into liquid, and the mist can be converted into liquid.
Users of previous versions should note an important difference about splash regarding particle size. In version 2.2 the splash size was controlled directly, like the foam. While foam really needs direct size control, especially for the most popular usage of pouring a glass of beer or soda, the size and volume of a splash should be directly related to the amount of liquid being displaced rather than a user-specified value. In other words, in order to have a seamless transition between the splash and the liquid, the volume of the splash droplets must be equal to the volume of the liquid converted into splash. Phoenix 3.0 and newer simulates splashes according to this rule. Here is an image that may help visualize this process - FLIP Particles Life Cycle.
UI Path: ||Select PhoenixFDSim|| > Attribute Editor > Splash/Mist rollout
Enable | splEnbl – Enables the birth and simulation of Splash and Mist particles.
Splash Birth
Splash Amount | splBirthRate – Controls the amount of splash relative to the liquid. This value determines how many splash particles are equal to a single liquid particle in volume. This value also affects the particle size, where larger values decrease the size of splash particles. Note: This parameter is the nearest in functionality to the "birth rate" parameter in previous versions. For more information, see the Splash Amount example below.
Birth Threshold | splBirthTresh – Splashes are born when the local curvature of the liquid surface exceeds this value. The lower the threshold is, the more places on the liquid surface will produce splashes.
By Free Fly | splByFreeFly – How likely a free falling or flying liquid particle will turn into splash. At 0.0, free falling/flying liquid will not convert into splashes. The main usage of values above 0.0 is in waterfall simulations. It is not recommended that this parameter be changed to a value other than 0.0 for ocean simulations because this might create splashes over the ocean surface or even in air pockets under the water surface. For more information, see the By Free Fly example below.
Use Birth Volume | useSplashBirthVolume – When enabled, allows the splash to be born naturally by the simulation only inside a specified geometry object. The splash born inside the Birth Volume can travel outside the volume without a problem. The difference between this approach and spawning splash inside a volume manually from a Source object is that using a Birth Volume, the splash birth will follow the simulation criteria of the simulation and will look and behave more naturally.
Set Selected Object as Birth Volume - When a polygon mesh and a Phoenix Simulator are selected, the selected object will be used as the Birth Volume for the generation of Splash particles in this simulator.
Birth Volume | splashBirthVolume – Specifies a geometry object to confine splash particles. To do this, select the simulator and the confine geometry and from the Phoenix FD menu, select Set Splash Birth Volume.
By default, the birth volume geometry is not automatically converted to a non-solid and it will behave as a rigid body in your simulation. In this case, you can still use the Birth Volume Fade Dist to expand an area around the object where Foam/Splash births are possible. You can convert the geometry to a non-solid from its Phoenix FD Extra Attributes in order to allow liquid to exist inside it as well.
Also note that birth volumes will interact with the simulation even if they are hidden. If you wish, you can exclude the Birth Volume from the Scene Interaction rollout.
Birth Volume Fade Dist | splashBirthVolumeFade – Controls how far the splash particles will spawn around the specified Birth Volume geometry object, in world units.
Mist Birth
Splash to Mist | splSplitRate – Controls how fast the splash particles are converted into mist. This value determines the portion of the splash volume that is turned into mist after traveling one meter (3.3 feet). During its motion, a splash particle constantly produces mist particles, decreasing the volume of the splash. When the entire volume is exhausted, the splash particle disappears. This parameter controls how fast this happens. If the value is 0.0 the mist is not simulated at all, and if you restore a simulation containing mist, the mist will be deleted.
Mist Amount | splMistMult – Controls the amount of mist. This value determines how many mist particles are spawned by a single splash particle.
Use Birth Volume | useMistBirthVolume – When enabled, allows the mist to be born naturally by the simulation only inside a specified geometry object. The mist particle born inside the Birth Volume can travel outside the volume without a problem. The difference between this approach and spawning mist inside a volume manually from a Source object is that using a Birth Volume, the mist birth will follow the simulation criteria of the simulation and will look and behave more naturally.
Set Selected Object as Birth Volume - When a polygon mesh and a Phoenix Simulator are selected, the selected object will be used as the Birth Volume for the generation of Mist particles in this simulator.
Birth Volume | mistBirthVolume – Specifies a geometry object to confine mist particles. To do this, select the simulator and the confine geometry and from the Phoenix FD menu, select Set Mist Birth Volume.
Birth Volume Fade Dist | mistBirthVolumeFade – Controls how far the mist particles will spawn around the specified Birth Volume geometry object, in world units.
Foam On Hit
Foam on Hit Amount | splFoamOnHit – Controls how many foam bubbles are created when a single splash particle enters the liquid volume. This parameter works in terms of probability, so non-integer values can be used. For more information, see the Foam on Hit example below.
Min. Age | splFoamOnHitMinAge – Minimum age for foam production. Only splash particles with a particle age above this limit will produce foam when they hit the liquid surface.
For the Min. Age parameter to work, you need to Enable the export of the Age channel for your Splash particles from the Output menu of the Phoenix Simulator.
Depth | splFoamOnHitDepth – When a splash particle hits the liquid surface and produces foam, this parameter specifies how far in front of the splash particle the new foam particles will be born. This parameter is used mostly to create underwater foam that will be colored by the fog color of the liquid.
Properties
Splash Air Drag | splAirFriction – The air friction of the splash droplet. A value of 1 represents the air friction of an average rain droplet.
Mist Air Drag | splMistDrag – The air friction of the mist. This value determines not only how fast the speed decreases, but also the influence of the wind. The larger this value, the larger the wind's influence.
Max Outside Age (secs) | splTimeOut – If a particle exits the grid and its age exceeds this parameter, it will be killed instantly. This parameter affects both splash and mist.
For the Max Outside Age (secs) parameter to work, you need to Enable the export of the Age channel for your Splash particles from the Output menu of the Phoenix Simulator.
Initial Velocity Mult. | splVMult – When the splash particles are born, they are initialized with the velocity of the nearest liquid multiplied by this value. This parameter greatly affects the general appearance of the splash. When it is below 1, the liquid droplets fly in front of the splash and produce a clearly visible track.
Initial Velocity Rand. | splVRand – Controls the randomness of the velocity direction when splash particles are born.
Liquid-Like | splLiquidLike – Controls the ability of the splash particles to stick to each other, forming different strings and tentacles, so the splash behaves more like liquid and blends better with the behavior of the liquid mass. The higher this value, the larger the acceleration needed to break the connection. Note that larger values will increase the calculation time. For more information, see the Liquid-Like example below.
Affect Liquid | splAffectLiq – Controls the conversion of liquid to splash, and splash back into liquid. When this value is not zero, the splash birth causes some of the liquid to disappear, and then when the splash enters the liquid the splash particles are replaced by liquid. A value of 1 with splashes and mist enabled produces a physically accurate simulation where liquid, splash and mist are constantly converted into one another, and the sum of all three at any point during the simulation is the same as the original liquid.
When a Splash particle is converted into a Liquid particle, it inherits the Default RGB and Default Viscosity values set under the Liquid rollout.
Example: Splash Amount
The following video provides an example of Splash Amount parameter to show the differences between values of 0.0, 3.0, and 10.0.
Example: By Free Fly
The following video provides examples to show the differences of By Free Fly values of 0, 0.6, and 1.0.
Example: Foam on Hit
The following video provides examples to show the differences of Foam on Hit values of 0.0, 2, and 5.0.
Example: Liquid-Like
The following video provides an example of Liquid-Like parameter to show the differences between values of 0 and 3
Liquid-Like = 0
Liquid-Like = 3
