The Color Mapping Property Panel allows you to adjust how the input color is decoded and how it is corrected for display.
Properties
UI Path: ||Property Panel|| > Color panel
Lookup Table – Specifies the LUT file or OCIO configuration. To use a lookup table right click on the Lookup Table chooser and pick one from the list. You can also import your own lookup tables.
Color Space – Controls the color space for the particular layer. You can choose from three different options Default, Linear and sRGB. You can cycle through them with the arrows on both sides of the value or right click and choose a color space from the context menu.
LUT
Chaos Player supports 1D and 3D lookup tables (LUTs). The supported formats are Autodesk .3dl, Nucoda .cms and Iridas .cube. 3dl tables are assumed to have 12 bits of output (range 0…4095). .3dl, .cube and .ocio are assumed to contain sRGB values by default, whereas .cms is assumed to be linear. Chaos Player comes with a set of commonly used Lookup tables that can be found in “installation folder”\LUTs.
OpenColorIO
Chaos Player supports OCIO v2 configurations.
OCIO can be set up by using the OCIO environment variable or by manually loading a configuration and choosing its settings.
Apply Default OCIO Configuration – Applies the default .ocio configuration, specified by the OCIO environment variable.
If you choose an OpenColorIO configuration to load in the Lookup Table, a separate OpenColorIO Settings window will appear. You can tweak the .ocio profile settings here.
