This page provides information on using the Corona Menu in Corona for Cinema 4D.
Button | Description | |
Creates a Corona Sky object. | ||
Creates a Corona Sun object. | ||
Creates a Corona Light object. | ||
Creates a Corona Proxy object. | ||
Creates a Corona Volume Grid (VDB) object. | ||
Creates a Corona Decal object. | ||
Creates a Camera with a Corona Camera tag. | ||
Creates a Corona Hair object. | ||
Creates a Corona Pattern object. | ||
Creates a Chaos Scatter object. | ||
Launches the Multi-Pass setup window. | ||
Launches the Corona VFB window. | ||
Launches the Corona Material Library window. | ||
Launches the Cosmos Browser window. | ||
Launches de Corona Node Material Editor. | ||
Launches the Corona Lister window. | ||
Launches the Corona Scene Converter window. | ||
Sub-menu for the Chaos Vantage tools. | ||
Start Vantage live link – Exports the current scene project to Chaos Vantage and launches it in live link mode. Export and open in Vantage – Exports the current scene project to be later opened in Chaos Vantage. Render animation in Vantage – Starts/stops export of animation to Vantage. The initial frame is exported to Vantage along with the timeline information. Then, you can select directly in Vantage which frames to be used as part of the animation. Once selected, Corona uploads automatically the frames. Vantage settings... – Allows defining the settings to launch Chaos Vantage (locally or remote).
Starts the Interactive Rendering process. | ||
Starts the Interactive Viewport rendering process. | ||
Launches the Corona Preferences in the Cinema 4D preferences window. | ||
Launches the Corona for Cinema 4D Helpdesk portal. | ||
Launches the About window. |
