To run Corona for 3ds Max, you have to:
This page serves as a guide for installing Corona for 3ds Max. If you would like to try Corona for 3ds Max or Cinema 4D, download and run the installer.
If you are using User Account Control (UAC), a security prompt opens when launching the installer. You need to confirm that the installer can proceed.
Trial users should refer to the Trial Installation of Corona for 3ds Max article, as the process differs from the one shown here.
Running the Installer
Before running the installation, make sure your Windows account has administrative privileges.
Run the installer. Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
Welcome
Carefully read the End User License Agreement and the Global Consumer Privacy Policy. Click the I accept button if you agree to the terms.
Click the Install button. This immediately initiates the automatic installation process.
If you need to customize your Corona for 3ds Max installation, click the Advanced button.
If you need to unpack all the installer files into a specified directory, click the Unpack button. This option is useful for advanced users and debugging purposes. For instance, you might choose this option when installing the plugins manually or troubleshooting installation issues. For example, if the installer cannot detect any host application, you can unpack the files and copy them manually.
The Install option uses localhost for licensing by default and installs the software in a default directory.
Unpack Installation
This is an optional step.
Directory – Specifies an unpack root directory where the installer files are extracted.
Advanced
Here, you can specify for which version of 3ds Max to install Corona. You can also select components you wish to include in the installation - Chaos Cosmos Service and NVIDIA AI Denoiser.
Also, decide if you need to install the DR Server, Corona Standalone and the Corona Image Editor, and if so, where you want to install them.
Click Continue to proceed.
Licensing
In this step, you can specify whether the Chaos License Server runs locally or on another machine.
Local – This option installs the License Server on your machine. For a walkthrough, see the Activating Corona.
Remote – This option allows you to configure your Chaos product for floating licenses in a local network. Fill in the IP address of the Chaos License Server in your network in the Primary License Server field. Please leave the port 30304 unchanged. For more details on this setup, see the License Server Deployment page.
Chaos License Server Options
At this step, you can choose where to install the Chaos License Server.
Migrate data during installation – When enabled, it transfers all of your settings made with older versions of the License Server, such as proxy settings, etc. Disabling this option makes a clean install of License Server with any custom settings from previous installations reset to their defaults.
Add firewall exception – Allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you must manually add firewall exceptions later.
Chaos Telemetry
Corona for 3ds Max installation is successful.
Participate in the improvement decisions for future versions of Corona. No intellectual property is violated when agreeing to participate in the improvement program. Chaos does not gather scenes, assets, materials, etc. For more information, see the Chaos Telemetry page.
Anonymized Telemetry – Includes the most used product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
Personalized Telemetry – Includes the most used product functionality, parameter values, but also contains personally identifiable information tied to an individual user's license. This helps Chaos tailor and optimize the product for better personal use.
Welcome
Please take a moment to review the End User License Agreement. Once you've carefully read the License Agreement, you can click I accept the terms and conditions if you agree to the terms.
Participate in the improvement decisions for future versions of Corona by agreeing to Help improve Chaos Corona by sending Product usage data. No intellectual property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc. For more information, see the Privacy Notice.
Click Next to proceed.
Install Type
Typical – This is the fastest, fully automated installation type. It is recommended for most users. This mode installs Corona plugins for all software versions detected, plus the Corona Image Editor (GUI and Command Line versions) and the Corona Distributed Rendering server.
If you already have an older version of Corona installed on your system, this mode is renamed to Update
When installing Corona 8 or newer, you may see this option grayed out and with a short explanation instructing you to use the Custom installation mode instead. For more information, see the Basic Information on Corona and the Chaos License Server article.
Click Install to proceed.
CustomThis is an advanced installation method that allows you to choose the specific items to be installed and their locations. Useful, for example, when you have different 3ds Max versions installed, and you want to install Corona for only one of them or if you only want to install certain components (such as the DR ServerChaos LicensingCorona Standalone, or the Corona Image Editor).
Unpack filesThis unpacks all the installer files into a specified directory. Useful for advanced users and debugging. You might opt for this option, for example, when installing the plugins manually, or if there are problems during the installation, e.g., if the installer could not find any host application, then you can unpack the files and copy them manually. For more information on the manual installation of Corona, see: How to install Corona manually?
Click Unpack to proceed.
Options
Custom Install Type
If you select the Custom installation type, after selecting Next, you are presented with the customizable options. Select the version of 3ds Max you wish to have Corona installed in. You can also select the components you wish to include in the installation - Chaos Cosmos Services, Chaos License Server, NVIDIA AI Denoiser, and the Material Library. Also, decide if you need to install the DR Server, Corona Standalone, and the Corona Image Editor, and if so, where you want to install them.
By default, the Material Library is downloaded from the internet, but you can also use an offline file to install it. For more information, see the How to install the material library in offline mode article.
Summary
After a successful installation, you see the following message: Chaos Corona was successfully installed on your computer. Any errors are marked with a red font
Click Finish to enjoy Corona.
Activate Corona
Before running 3ds Max, make sure that your computer is connected to the Internet.
Command-Line Parameters
By using the Chaos installer for automatic installation with the respective options for that (-auto or -quiet=1), or otherwise installing a Chaos product, you accept the Chaos End User License Agreement and the Chaos Global Consumer Privacy Policy.
The Corona installer can be run with the following command line parameters:
Corona 12 Update 1 and newer:
ParameterDescription
-helpDisplays help.
-help=2Displays advanced help.
-unpackInstall=<directory_path>Unpacks the installation into the specified directory.
-configFileSpecifies the path to the installation configuration file.
-gui=0/1
Specifies whether to use the Graphical User Interface or the command-line one. (default: 1)
-debug=<level>
Specifies the level of debug logging used by the installer. (default: 0; assumes the value of 1 if the argument is provided with no value)
-auto
Enables automatic installation and forces -quiet.
-quiet=0/1
Specifies whether the automatic installation is quiet or not. (default: 1 when -auto is present; otherwise 0)
-backup=0/1
Specifies whether the installer should perform a backup. (default: 1)
-bin=<filename>
Specifies the path to the binary image containing compressed installation data to be used for the current installation run.
-binaryOffset=<offset>
Offset in bytes of the binary image - to be used with packed installation executables.
-fileTree=<directory_path>
Directory containing all installation files with relative paths corresponding to the ones in the installation XML to be used for the current installation run.
-log=<filename> or -uninstall=<filename>
The filename of an install log to be used for performing the uninstallation. No uninstallApp required.
-uninstallApp=<name_of_application>
The name of the application to be uninstalled by the installer.
-ignoreErrors=0/1
The installation process ignores errors during the installation and behaves as if the process completed successfully.
Note: If you perform an automatic installation and using the Software, you accept the terms of the End User License Agreement and the Global Consumer Privacy Policy, which are available to you when running the installer in GUI mode or at https://www.chaos.com/. If you do not accept these terms, do not install or use the Software.
Usage: <installation_file> {<option>} where option (case-insensitive) is one of the options listed above.
Example (Silent Installation):
  1. Open Command Prompt (CMD)
  2. Navigate to the folder containing the installer:
cd "C:\Downloads\Corona"
Run the silent installation command:
.\chaos-corona-installer.exe -auto -gui=0
 Uninstaller only:
-uninstallApp="Chaos Corona for 3ds Max"
Runs the uninstallation for the specified application.
-log="<path>"
Specifies the path for writing the uninstall log file.
-gui=0
Runs the uninstaller without a GUI (silent mode).
Example (Silent Uninstall):
  2. Navigate to the uninstaller directory:
cd "C:\Program Files\Chaos\Corona\Corona Renderer for 3ds Max\uninstall"
Run the silent uninstallation command:
.\installer.exe -uninstallApp="Chaos Corona for 3ds Max" -log="install.log" -gui=0
Corona 12 and older:
-h or --helpDisplays command-line help.
--acceptEulaAndAutoInstall
Runs the installation in console mode with no user input. It is the same as running the typical installation option in GUI, accepting the EULA, and finishing the installation process.
Important note:
Currently, there is no way to specify which items should be installed during silent installation. This means that when Corona is already installed, the installer will remember the last items selected by the user (e.g. which 3ds Max versions were selected, what additional components were selected). If you uninstall Corona and run the installer in silent mode, it will use the default behavior - it will detect which versions of 3ds Max are installed and will install all additional components.
Console mode may not work as expected when run directly from the Windows command line console. In such a case, the console will not wait for the installer to finish and will display a new prompt. It will also capture and accept user input while the installer is running and printing into the console.
Solution: The issue will not appear when using a .bat file or any other script, which is the intended use case. In this case, the script correctly waits for the installer to finish before proceeding.
Next Step
