Enabled – When enabled, the render element appears in the V-Ray frame buffer. Deep output – Specifies whether to include this render element in deep images. Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.materialID.vrimg). Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible. Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler rollout in the VRay tab of the Render Settings. Denoise – Enables the render element's denoising, provided the Denoiser render element is present. |
