This page provides information about the Contact Sheet feature.
These options are accessed through right-clicking on the button.
Тhe commands in this section can be used from the command line to automate creating sheets. These and more commands you can find on the Command Reference page.
Command | Description |
--set_sheet_enabled={0,1} | Disables or enables the Contact Sheet |
--sheet_options=columns,rows,resX,resY,margin,labels,label_background | Takes the arguments in this order to specify the Contact Sheet options. For example, --sheet_options=2,1,3840,1080,0,1,1 will create a sheet with 2 columns and 1 row (i.e. two layers side by side), with a 3840x1080 resolution (to display each 1920x1080 in its full resolution), without margins and with labels with background. |
