Extends PropertyMeta with type information only available at runtime for a specific property instance.
More...
#include <vraysdk.hpp>
| PropertyRuntimeMeta (const PropertyRuntimeMeta &propertyRuntimeMeta) |
int | getRuntimeElementsCount () const |
| | Return the current number of elements in a list property.
Type | getRuntimeType () const |
| | Get the current type of the property value. This can differ from the result of getType().
const char * | getRuntimeTypeAsString () const |
RuntimeUIGuides | getRuntimeUIGuidesObject () const |
| | Returns an object used to obtain meta and dynamic information about a plugin property uiGuides.
PropertyRuntimeMeta & | operator= (const PropertyRuntimeMeta &propertyRuntimeMeta) |
void | swap (PropertyRuntimeMeta &propertyRuntimeMeta) noexcept |
| PropertyMeta (const PropertyMeta &propertyMeta) |
StringList | getAliases () const |
| | Returns a list of alias names of this property.
| Value | getDefaultValue () const |
const char * | getDeprecation () const |
| | Returns a deprecation string for this property. May be nullptr!
std::string | getDescription () const |
| | Returns a short description of this property. May be empty.
int | getElementsCount () const |
| | Returns the number of elements for the property if it is a list and -1 otherwise.
Type | getElementType () const |
| | Returns the type of the property by definition or the type of the list elements when it's a typed list.
GPUParamSupport | getGPUSupport () const |
| | Returns to what extent the property is supported by V-Ray GPU.
const char * | getName () const |
| | Returns the primary name of this property.
| Type | getType () const |
const char * | getTypeAsString () const |
| std::string | getUIGuides () const |
UIGuides | getUIGuidesObject () const |
| | Returns an object used to obtain meta information about a plugin property uiGuides.
| operator bool () const |
| | Returns true if the PropertyMeta is valid property meta, therefore can be used for valid checks of parameters.
PropertyMeta & | operator= (const PropertyMeta &propertyMeta) |
void | swap (PropertyMeta &propertyMeta) noexcept |
| PropertyRuntimeMeta (const Plugin &plugin, const char *propertyName) |
| PropertyMeta (const VRayRenderer *pRenderer, const char *pluginClassName, const char *propertyName) |
static const char * | typeToString (const Type type) |
GPUParamSupport | gpuSupport |
const void * | pParamDef |
The documentation for this class was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
