VRay SDK for C++
Loading...
Searching...
No Matches
vrayplugins.hpp
1#ifndef _VRAY_PLUGINS_HPP_
2#define _VRAY_PLUGINS_HPP_
3
4#include "vraysdk.hpp"
5
6namespace VRay {
7namespace Plugins {
8
10class BitmapPluginCategory : public Plugin {};
11
13class BSDFPluginCategory : public Plugin {};
14
17
20
22class LightPluginCategory : public Plugin {};
23
26
29
31class ViewPluginCategory : public Plugin {};
32
35
37class TexturePluginCategory : public Plugin {};
38
41
44
47
50
53
55class UVWGenPluginCategory : public Plugin {};
56
59
61class BRDFAlHair : public Plugin {
62public:
64 static constexpr const PluginTypeId getTypeId() { return 0x7839282C; }
66 static constexpr const char* getType() { return "BRDFAlHair"; }
67
68 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
69
73 bool set_opacity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
77 bool set_opacity(float texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
81 Value get_opacity(double time = TiMe::Default()) const { return getValue("opacity", time); }
82
86 bool set_melanin(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("melanin", texturefloat, time); }
90 bool set_melanin(float texturefloat, double time = TiMe::Default()) { return setValue("melanin", texturefloat, time); }
94 Value get_melanin(double time = TiMe::Default()) const { return getValue("melanin", time); }
95
98 bool set_dye_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dye_color", texture, time); }
101 bool set_dye_color(const AColor& texture, double time = TiMe::Default()) { return setValue("dye_color", texture, time); }
104 Value get_dye_color(double time = TiMe::Default()) const { return getValue("dye_color", time); }
105
108 bool set_specular_width(float val, double time = TiMe::Default()) { return setValue("specular_width", val, time); }
111 float get_specular_width(double time = TiMe::Default()) const { return getFloat("specular_width", time); }
112
115 bool set_specular_shift(float val, double time = TiMe::Default()) { return setValue("specular_shift", val, time); }
118 float get_specular_shift(double time = TiMe::Default()) const { return getFloat("specular_shift", time); }
119
122 bool set_diffuse_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
125 bool set_diffuse_color(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
128 Value get_diffuse_color(double time = TiMe::Default()) const { return getValue("diffuse_color", time); }
129
133 bool set_diffuse_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_strength", texturefloat, time); }
137 bool set_diffuse_strength(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_strength", texturefloat, time); }
141 Value get_diffuse_strength(double time = TiMe::Default()) const { return getValue("diffuse_strength", time); }
142
146 bool set_forward_scattering(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("forward_scattering", texturefloat, time); }
150 bool set_forward_scattering(float texturefloat, double time = TiMe::Default()) { return setValue("forward_scattering", texturefloat, time); }
154 Value get_forward_scattering(double time = TiMe::Default()) const { return getValue("forward_scattering", time); }
155
159 bool set_back_scattering(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("back_scattering", texturefloat, time); }
163 bool set_back_scattering(float texturefloat, double time = TiMe::Default()) { return setValue("back_scattering", texturefloat, time); }
167 Value get_back_scattering(double time = TiMe::Default()) const { return getValue("back_scattering", time); }
168
171 bool set_specular1_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("specular1_color", texture, time); }
174 bool set_specular1_color(const AColor& texture, double time = TiMe::Default()) { return setValue("specular1_color", texture, time); }
177 Value get_specular1_color(double time = TiMe::Default()) const { return getValue("specular1_color", time); }
178
182 bool set_specular1_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular1_strength", texturefloat, time); }
186 bool set_specular1_strength(float texturefloat, double time = TiMe::Default()) { return setValue("specular1_strength", texturefloat, time); }
190 Value get_specular1_strength(double time = TiMe::Default()) const { return getValue("specular1_strength", time); }
191
194 bool set_specular1_shift(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular1_shift", texturefloat, time); }
197 bool set_specular1_shift(float texturefloat, double time = TiMe::Default()) { return setValue("specular1_shift", texturefloat, time); }
200 Value get_specular1_shift(double time = TiMe::Default()) const { return getValue("specular1_shift", time); }
201
204 bool set_specular1_width_scale(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular1_width_scale", texturefloat, time); }
207 bool set_specular1_width_scale(float texturefloat, double time = TiMe::Default()) { return setValue("specular1_width_scale", texturefloat, time); }
210 Value get_specular1_width_scale(double time = TiMe::Default()) const { return getValue("specular1_width_scale", time); }
211
214 bool set_specular2_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("specular2_color", texture, time); }
217 bool set_specular2_color(const AColor& texture, double time = TiMe::Default()) { return setValue("specular2_color", texture, time); }
220 Value get_specular2_color(double time = TiMe::Default()) const { return getValue("specular2_color", time); }
221
225 bool set_specular2_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular2_strength", texturefloat, time); }
229 bool set_specular2_strength(float texturefloat, double time = TiMe::Default()) { return setValue("specular2_strength", texturefloat, time); }
233 Value get_specular2_strength(double time = TiMe::Default()) const { return getValue("specular2_strength", time); }
234
237 bool set_specular2_shift(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular2_shift", texturefloat, time); }
240 bool set_specular2_shift(float texturefloat, double time = TiMe::Default()) { return setValue("specular2_shift", texturefloat, time); }
243 Value get_specular2_shift(double time = TiMe::Default()) const { return getValue("specular2_shift", time); }
244
247 bool set_specular2_width_scale(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular2_width_scale", texturefloat, time); }
250 bool set_specular2_width_scale(float texturefloat, double time = TiMe::Default()) { return setValue("specular2_width_scale", texturefloat, time); }
253 Value get_specular2_width_scale(double time = TiMe::Default()) const { return getValue("specular2_width_scale", time); }
254
257 bool set_glint_strength(float val, double time = TiMe::Default()) { return setValue("glint_strength", val, time); }
260 float get_glint_strength(double time = TiMe::Default()) const { return getFloat("glint_strength", time); }
261
264 bool set_transmission_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transmission_color", texture, time); }
267 bool set_transmission_color(const AColor& texture, double time = TiMe::Default()) { return setValue("transmission_color", texture, time); }
270 Value get_transmission_color(double time = TiMe::Default()) const { return getValue("transmission_color", time); }
271
275 bool set_transmission_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("transmission_strength", texturefloat, time); }
279 bool set_transmission_strength(float texturefloat, double time = TiMe::Default()) { return setValue("transmission_strength", texturefloat, time); }
283 Value get_transmission_strength(double time = TiMe::Default()) const { return getValue("transmission_strength", time); }
284
287 bool set_transmission_shift(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("transmission_shift", texturefloat, time); }
290 bool set_transmission_shift(float texturefloat, double time = TiMe::Default()) { return setValue("transmission_shift", texturefloat, time); }
293 Value get_transmission_shift(double time = TiMe::Default()) const { return getValue("transmission_shift", time); }
294
297 bool set_transmission_width_scale(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("transmission_width_scale", texturefloat, time); }
300 bool set_transmission_width_scale(float texturefloat, double time = TiMe::Default()) { return setValue("transmission_width_scale", texturefloat, time); }
303 Value get_transmission_width_scale(double time = TiMe::Default()) const { return getValue("transmission_width_scale", time); }
304
307 bool set_glint_rolloff(float val, double time = TiMe::Default()) { return setValue("glint_rolloff", val, time); }
310 float get_glint_rolloff(double time = TiMe::Default()) const { return getFloat("glint_rolloff", time); }
311
314 bool set_transmission_rolloff(float val, double time = TiMe::Default()) { return setValue("transmission_rolloff", val, time); }
317 float get_transmission_rolloff(double time = TiMe::Default()) const { return getFloat("transmission_rolloff", time); }
318
321 bool set_random_melanin(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("random_melanin", texturefloat, time); }
324 bool set_random_melanin(float texturefloat, double time = TiMe::Default()) { return setValue("random_melanin", texturefloat, time); }
327 Value get_random_melanin(double time = TiMe::Default()) const { return getValue("random_melanin", time); }
328
331 bool set_random_hue(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("random_hue", texturefloat, time); }
334 bool set_random_hue(float texturefloat, double time = TiMe::Default()) { return setValue("random_hue", texturefloat, time); }
337 Value get_random_hue(double time = TiMe::Default()) const { return getValue("random_hue", time); }
338
341 bool set_random_saturation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("random_saturation", texturefloat, time); }
344 bool set_random_saturation(float texturefloat, double time = TiMe::Default()) { return setValue("random_saturation", texturefloat, time); }
347 Value get_random_saturation(double time = TiMe::Default()) const { return getValue("random_saturation", time); }
348
351 bool set_random_tangent(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("random_tangent", texturefloat, time); }
354 bool set_random_tangent(float texturefloat, double time = TiMe::Default()) { return setValue("random_tangent", texturefloat, time); }
357 Value get_random_tangent(double time = TiMe::Default()) const { return getValue("random_tangent", time); }
358
362 bool set_diffuse_indirect_strength(float val, double time = TiMe::Default()) { return setValue("diffuse_indirect_strength", val, time); }
366 float get_diffuse_indirect_strength(double time = TiMe::Default()) const { return getFloat("diffuse_indirect_strength", time); }
367
371 bool set_glossy_indirect_strength(float val, double time = TiMe::Default()) { return setValue("glossy_indirect_strength", val, time); }
375 float get_glossy_indirect_strength(double time = TiMe::Default()) const { return getFloat("glossy_indirect_strength", time); }
376};
377
379class BRDFAlSurface : public Plugin {
380public:
382 static constexpr const PluginTypeId getTypeId() { return 0x782AFAE0; }
384 static constexpr const char* getType() { return "BRDFAlSurface"; }
385
386 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
387
391 bool set_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_map", texture, time); }
395 bool set_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_map", texture, time); }
399 Value get_bump_map(double time = TiMe::Default()) const { return getValue("bump_map", time); }
400
404 bool set_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_amount", texturefloat, time); }
408 bool set_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("bump_amount", texturefloat, time); }
412 Value get_bump_amount(double time = TiMe::Default()) const { return getValue("bump_amount", time); }
413
417 bool set_bump_type(int val, double time = TiMe::Default()) { return setValue("bump_type", val, time); }
421 int get_bump_type(double time = TiMe::Default()) const { return getInt("bump_type", time); }
422
426 bool set_opacity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
430 bool set_opacity(float texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
434 Value get_opacity(double time = TiMe::Default()) const { return getValue("opacity", time); }
435
439 bool set_diffuse(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse", texture, time); }
443 bool set_diffuse(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse", texture, time); }
447 Value get_diffuse(double time = TiMe::Default()) const { return getValue("diffuse", time); }
448
452 bool set_diffuse_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_strength", texturefloat, time); }
456 bool set_diffuse_strength(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_strength", texturefloat, time); }
460 Value get_diffuse_strength(double time = TiMe::Default()) const { return getValue("diffuse_strength", time); }
461
465 bool set_diffuse_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_bump_map", texture, time); }
469 bool set_diffuse_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_bump_map", texture, time); }
473 Value get_diffuse_bump_map(double time = TiMe::Default()) const { return getValue("diffuse_bump_map", time); }
474
478 bool set_diffuse_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_bump_amount", texturefloat, time); }
482 bool set_diffuse_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_bump_amount", texturefloat, time); }
486 Value get_diffuse_bump_amount(double time = TiMe::Default()) const { return getValue("diffuse_bump_amount", time); }
487
491 bool set_diffuse_bump_type(int val, double time = TiMe::Default()) { return setValue("diffuse_bump_type", val, time); }
495 int get_diffuse_bump_type(double time = TiMe::Default()) const { return getInt("diffuse_bump_type", time); }
496
500 bool set_reflect1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect1", texture, time); }
504 bool set_reflect1(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect1", texture, time); }
508 Value get_reflect1(double time = TiMe::Default()) const { return getValue("reflect1", time); }
509
513 bool set_reflect1_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect1_strength", texturefloat, time); }
517 bool set_reflect1_strength(float texturefloat, double time = TiMe::Default()) { return setValue("reflect1_strength", texturefloat, time); }
521 Value get_reflect1_strength(double time = TiMe::Default()) const { return getValue("reflect1_strength", time); }
522
526 bool set_reflect1_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect1_roughness", texturefloat, time); }
530 bool set_reflect1_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("reflect1_roughness", texturefloat, time); }
534 Value get_reflect1_roughness(double time = TiMe::Default()) const { return getValue("reflect1_roughness", time); }
535
539 bool set_reflect1_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect1_ior", texturefloat, time); }
543 bool set_reflect1_ior(float texturefloat, double time = TiMe::Default()) { return setValue("reflect1_ior", texturefloat, time); }
547 Value get_reflect1_ior(double time = TiMe::Default()) const { return getValue("reflect1_ior", time); }
548
552 bool set_reflect1_distribution(int val, double time = TiMe::Default()) { return setValue("reflect1_distribution", val, time); }
556 int get_reflect1_distribution(double time = TiMe::Default()) const { return getInt("reflect1_distribution", time); }
557
561 bool set_reflect1_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect1_bump_map", texture, time); }
565 bool set_reflect1_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect1_bump_map", texture, time); }
569 Value get_reflect1_bump_map(double time = TiMe::Default()) const { return getValue("reflect1_bump_map", time); }
570
574 bool set_reflect1_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect1_bump_amount", texturefloat, time); }
578 bool set_reflect1_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("reflect1_bump_amount", texturefloat, time); }
582 Value get_reflect1_bump_amount(double time = TiMe::Default()) const { return getValue("reflect1_bump_amount", time); }
583
587 bool set_reflect1_bump_type(int val, double time = TiMe::Default()) { return setValue("reflect1_bump_type", val, time); }
591 int get_reflect1_bump_type(double time = TiMe::Default()) const { return getInt("reflect1_bump_type", time); }
592
596 bool set_reflect2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect2", texture, time); }
600 bool set_reflect2(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect2", texture, time); }
604 Value get_reflect2(double time = TiMe::Default()) const { return getValue("reflect2", time); }
605
609 bool set_reflect2_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect2_strength", texturefloat, time); }
613 bool set_reflect2_strength(float texturefloat, double time = TiMe::Default()) { return setValue("reflect2_strength", texturefloat, time); }
617 Value get_reflect2_strength(double time = TiMe::Default()) const { return getValue("reflect2_strength", time); }
618
622 bool set_reflect2_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect2_roughness", texturefloat, time); }
626 bool set_reflect2_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("reflect2_roughness", texturefloat, time); }
630 Value get_reflect2_roughness(double time = TiMe::Default()) const { return getValue("reflect2_roughness", time); }
631
635 bool set_reflect2_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect2_ior", texturefloat, time); }
639 bool set_reflect2_ior(float texturefloat, double time = TiMe::Default()) { return setValue("reflect2_ior", texturefloat, time); }
643 Value get_reflect2_ior(double time = TiMe::Default()) const { return getValue("reflect2_ior", time); }
644
648 bool set_reflect2_distribution(int val, double time = TiMe::Default()) { return setValue("reflect2_distribution", val, time); }
652 int get_reflect2_distribution(double time = TiMe::Default()) const { return getInt("reflect2_distribution", time); }
653
657 bool set_reflect2_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect2_bump_map", texture, time); }
661 bool set_reflect2_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect2_bump_map", texture, time); }
665 Value get_reflect2_bump_map(double time = TiMe::Default()) const { return getValue("reflect2_bump_map", time); }
666
670 bool set_reflect2_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect2_bump_amount", texturefloat, time); }
674 bool set_reflect2_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("reflect2_bump_amount", texturefloat, time); }
678 Value get_reflect2_bump_amount(double time = TiMe::Default()) const { return getValue("reflect2_bump_amount", time); }
679
683 bool set_reflect2_bump_type(int val, double time = TiMe::Default()) { return setValue("reflect2_bump_type", val, time); }
687 int get_reflect2_bump_type(double time = TiMe::Default()) const { return getInt("reflect2_bump_type", time); }
688
692 bool set_sss_mix(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss_mix", texturefloat, time); }
696 bool set_sss_mix(float texturefloat, double time = TiMe::Default()) { return setValue("sss_mix", texturefloat, time); }
700 Value get_sss_mix(double time = TiMe::Default()) const { return getValue("sss_mix", time); }
701
705 bool set_sss_mode(int val, double time = TiMe::Default()) { return setValue("sss_mode", val, time); }
709 int get_sss_mode(double time = TiMe::Default()) const { return getInt("sss_mode", time); }
710
714 bool set_sss_density_scale(float val, double time = TiMe::Default()) { return setValue("sss_density_scale", val, time); }
718 float get_sss_density_scale(double time = TiMe::Default()) const { return getFloat("sss_density_scale", time); }
719
723 bool set_sss1_weight(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss1_weight", texturefloat, time); }
727 bool set_sss1_weight(float texturefloat, double time = TiMe::Default()) { return setValue("sss1_weight", texturefloat, time); }
731 Value get_sss1_weight(double time = TiMe::Default()) const { return getValue("sss1_weight", time); }
732
736 bool set_sss1_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sss1_color", texture, time); }
740 bool set_sss1_color(const AColor& texture, double time = TiMe::Default()) { return setValue("sss1_color", texture, time); }
744 Value get_sss1_color(double time = TiMe::Default()) const { return getValue("sss1_color", time); }
745
749 bool set_sss1_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss1_radius", texturefloat, time); }
753 bool set_sss1_radius(float texturefloat, double time = TiMe::Default()) { return setValue("sss1_radius", texturefloat, time); }
757 Value get_sss1_radius(double time = TiMe::Default()) const { return getValue("sss1_radius", time); }
758
762 bool set_sss2_weight(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss2_weight", texturefloat, time); }
766 bool set_sss2_weight(float texturefloat, double time = TiMe::Default()) { return setValue("sss2_weight", texturefloat, time); }
770 Value get_sss2_weight(double time = TiMe::Default()) const { return getValue("sss2_weight", time); }
771
775 bool set_sss2_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sss2_color", texture, time); }
779 bool set_sss2_color(const AColor& texture, double time = TiMe::Default()) { return setValue("sss2_color", texture, time); }
783 Value get_sss2_color(double time = TiMe::Default()) const { return getValue("sss2_color", time); }
784
788 bool set_sss2_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss2_radius", texturefloat, time); }
792 bool set_sss2_radius(float texturefloat, double time = TiMe::Default()) { return setValue("sss2_radius", texturefloat, time); }
796 Value get_sss2_radius(double time = TiMe::Default()) const { return getValue("sss2_radius", time); }
797
801 bool set_sss3_weight(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss3_weight", texturefloat, time); }
805 bool set_sss3_weight(float texturefloat, double time = TiMe::Default()) { return setValue("sss3_weight", texturefloat, time); }
809 Value get_sss3_weight(double time = TiMe::Default()) const { return getValue("sss3_weight", time); }
810
814 bool set_sss3_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sss3_color", texture, time); }
818 bool set_sss3_color(const AColor& texture, double time = TiMe::Default()) { return setValue("sss3_color", texture, time); }
822 Value get_sss3_color(double time = TiMe::Default()) const { return getValue("sss3_color", time); }
823
827 bool set_sss3_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sss3_radius", texturefloat, time); }
831 bool set_sss3_radius(float texturefloat, double time = TiMe::Default()) { return setValue("sss3_radius", texturefloat, time); }
835 Value get_sss3_radius(double time = TiMe::Default()) const { return getValue("sss3_radius", time); }
836
840 bool set_reflect_max_depth(int val, double time = TiMe::Default()) { return setValue("reflect_max_depth", val, time); }
844 int get_reflect_max_depth(double time = TiMe::Default()) const { return getInt("reflect_max_depth", time); }
845
849 bool set_reflect_subdivs(int val, double time = TiMe::Default()) { return setValue("reflect_subdivs", val, time); }
853 int get_reflect_subdivs(double time = TiMe::Default()) const { return getInt("reflect_subdivs", time); }
854
858 bool set_sss_subdivs(int val, double time = TiMe::Default()) { return setValue("sss_subdivs", val, time); }
862 int get_sss_subdivs(double time = TiMe::Default()) const { return getInt("sss_subdivs", time); }
863
867 bool set_consider_all_objects(bool val, double time = TiMe::Default()) { return setValue("consider_all_objects", val, time); }
871 bool get_consider_all_objects(double time = TiMe::Default()) const { return getBool("consider_all_objects", time); }
872};
873
875class BRDFBlinn : public Plugin {
876public:
878 static constexpr const PluginTypeId getTypeId() { return 0x77742B0F; }
880 static constexpr const char* getType() { return "BRDFBlinn"; }
881
882 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
883
887 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
891 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
892
895 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
898 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
901 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
902
906 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
910 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
911
915 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
919 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
920
923 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
926 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
929 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
930
934 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
938 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
939
943 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
947 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
948
952 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
956 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
957
961 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
965 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
966
970 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
974 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
975
979 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
983 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
984
988 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
992 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
996 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
997
1001 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
1005 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
1006
1010 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
1014 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
1015
1019 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
1023 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
1024
1028 bool set_hilightGlossiness(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness", val, time); }
1032 float get_hilightGlossiness(double time = TiMe::Default()) const { return getFloat("hilightGlossiness", time); }
1033
1036 bool set_hilightGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
1039 bool set_hilightGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
1042 Value get_hilightGlossiness_tex(double time = TiMe::Default()) const { return getValue("hilightGlossiness_tex", time); }
1043
1047 bool set_hilightGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex_mult", val, time); }
1051 float get_hilightGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("hilightGlossiness_tex_mult", time); }
1052
1056 bool set_reflectionGlossiness(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness", val, time); }
1060 float get_reflectionGlossiness(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness", time); }
1061
1064 bool set_reflectionGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
1067 bool set_reflectionGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
1070 Value get_reflectionGlossiness_tex(double time = TiMe::Default()) const { return getValue("reflectionGlossiness_tex", time); }
1071
1075 bool set_reflectionGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex_mult", val, time); }
1079 float get_reflectionGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness_tex_mult", time); }
1080
1084 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
1088 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
1089
1093 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
1097 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
1098
1102 bool set_soften_edge(float val, double time = TiMe::Default()) { return setValue("soften_edge", val, time); }
1106 float get_soften_edge(double time = TiMe::Default()) const { return getFloat("soften_edge", time); }
1107
1111 bool set_interpolation_on(int val, double time = TiMe::Default()) { return setValue("interpolation_on", val, time); }
1115 int get_interpolation_on(double time = TiMe::Default()) const { return getInt("interpolation_on", time); }
1116
1120 bool set_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("imap_min_rate", val, time); }
1124 int get_imap_min_rate(double time = TiMe::Default()) const { return getInt("imap_min_rate", time); }
1125
1129 bool set_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("imap_max_rate", val, time); }
1133 int get_imap_max_rate(double time = TiMe::Default()) const { return getInt("imap_max_rate", time); }
1134
1138 bool set_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("imap_color_thresh", val, time); }
1142 float get_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("imap_color_thresh", time); }
1143
1147 bool set_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("imap_norm_thresh", val, time); }
1151 float get_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("imap_norm_thresh", time); }
1152
1156 bool set_imap_samples(int val, double time = TiMe::Default()) { return setValue("imap_samples", val, time); }
1160 int get_imap_samples(double time = TiMe::Default()) const { return getInt("imap_samples", time); }
1161
1165 bool set_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
1169 bool set_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
1173 Value get_anisotropy(double time = TiMe::Default()) const { return getValue("anisotropy", time); }
1174
1177 bool set_anisotropy_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("anisotropy_uvwgen", plugin, time); }
1180 PluginRef get_anisotropy_uvwgen(double time = TiMe::Default()) const { return getPlugin("anisotropy_uvwgen", time); }
1181
1185 bool set_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
1189 bool set_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
1193 Value get_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("anisotropy_rotation", time); }
1194
1198 bool set_fix_dark_edges(bool val, double time = TiMe::Default()) { return setValue("fix_dark_edges", val, time); }
1202 bool get_fix_dark_edges(double time = TiMe::Default()) const { return getBool("fix_dark_edges", time); }
1203};
1204
1206class BRDFBump : public Plugin {
1207public:
1209 static constexpr const PluginTypeId getTypeId() { return 0x7782CBFA; }
1211 static constexpr const char* getType() { return "BRDFBump"; }
1212
1213 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
1214
1217 bool set_base_brdf(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_brdf", plugin, time); }
1220 PluginRef get_base_brdf(double time = TiMe::Default()) const { return getPlugin("base_brdf", time); }
1221
1224 bool set_bump_tex_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_tex_color", texture, time); }
1227 bool set_bump_tex_color(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_tex_color", texture, time); }
1230 Value get_bump_tex_color(double time = TiMe::Default()) const { return getValue("bump_tex_color", time); }
1231
1234 bool set_bump_tex_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_tex_float", texturefloat, time); }
1237 bool set_bump_tex_float(float texturefloat, double time = TiMe::Default()) { return setValue("bump_tex_float", texturefloat, time); }
1240 Value get_bump_tex_float(double time = TiMe::Default()) const { return getValue("bump_tex_float", time); }
1241
1245 bool set_bump_tex_mult(float val, double time = TiMe::Default()) { return setValue("bump_tex_mult", val, time); }
1249 float get_bump_tex_mult(double time = TiMe::Default()) const { return getFloat("bump_tex_mult", time); }
1250
1253 bool set_bump_tex_mult_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_tex_mult_tex", texturefloat, time); }
1256 bool set_bump_tex_mult_tex(float texturefloat, double time = TiMe::Default()) { return setValue("bump_tex_mult_tex", texturefloat, time); }
1259 Value get_bump_tex_mult_tex(double time = TiMe::Default()) const { return getValue("bump_tex_mult_tex", time); }
1260
1263 bool set_bump_tex(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("bump_tex", plugin, time); }
1266 PluginRef get_bump_tex(double time = TiMe::Default()) const { return getPlugin("bump_tex", time); }
1267
1271 bool set_bump_shadows(bool val, double time = TiMe::Default()) { return setValue("bump_shadows", val, time); }
1275 bool get_bump_shadows(double time = TiMe::Default()) const { return getBool("bump_shadows", time); }
1276
1280 bool set_map_type(int val, double time = TiMe::Default()) { return setValue("map_type", val, time); }
1284 int get_map_type(double time = TiMe::Default()) const { return getInt("map_type", time); }
1285
1288 bool set_normal_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("normal_uvwgen", plugin, time); }
1291 PluginRef get_normal_uvwgen(double time = TiMe::Default()) const { return getPlugin("normal_uvwgen", time); }
1292
1296 bool set_maya_compatible(bool val, double time = TiMe::Default()) { return setValue("maya_compatible", val, time); }
1300 bool get_maya_compatible(double time = TiMe::Default()) const { return getBool("maya_compatible", time); }
1301
1305 bool set_compute_bump_for_shadows(bool val, double time = TiMe::Default()) { return setValue("compute_bump_for_shadows", val, time); }
1309 bool get_compute_bump_for_shadows(double time = TiMe::Default()) const { return getBool("compute_bump_for_shadows", time); }
1310
1314 bool set_bump_delta_scale(float val, double time = TiMe::Default()) { return setValue("bump_delta_scale", val, time); }
1318 float get_bump_delta_scale(double time = TiMe::Default()) const { return getFloat("bump_delta_scale", time); }
1319
1323 bool set_normal_map_mult(float val, double time = TiMe::Default()) { return setValue("normal_map_mult", val, time); }
1327 float get_normal_map_mult(double time = TiMe::Default()) const { return getFloat("normal_map_mult", time); }
1328
1331 bool set_additional_bump(const PluginRef& texture, double time = TiMe::Default()) { return setValue("additional_bump", texture, time); }
1334 bool set_additional_bump(const AColor& texture, double time = TiMe::Default()) { return setValue("additional_bump", texture, time); }
1337 Value get_additional_bump(double time = TiMe::Default()) const { return getValue("additional_bump", time); }
1338
1342 bool set_bump_map_mult(float val, double time = TiMe::Default()) { return setValue("bump_map_mult", val, time); }
1346 float get_bump_map_mult(double time = TiMe::Default()) const { return getFloat("bump_map_mult", time); }
1347
1351 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
1355 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
1356
1360 bool set_blue2Z_mapping_method(int val, double time = TiMe::Default()) { return setValue("blue2Z_mapping_method", val, time); }
1364 int get_blue2Z_mapping_method(double time = TiMe::Default()) const { return getInt("blue2Z_mapping_method", time); }
1365
1368 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
1369 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
1370 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
1373 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
1374};
1375
1377class BRDFCSV : public Plugin {
1378public:
1380 static constexpr const PluginTypeId getTypeId() { return 0xA78E28BA; }
1382 static constexpr const char* getType() { return "BRDFCSV"; }
1383
1384 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
1385
1389 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
1393 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
1394
1398 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
1402 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
1406 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
1407
1411 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
1415 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
1416
1419 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
1422 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
1423
1426 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
1429 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
1430
1433 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
1436 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
1437
1440 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
1443 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
1444
1447 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
1450 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
1451
1454 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
1457 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
1460 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
1461
1464 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
1467 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
1468
1471 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
1474 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
1475
1478 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
1481 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
1482
1485 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
1488 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
1489
1492 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
1495 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
1496
1500 bool set_csv_path(const char* str, double time = TiMe::Default()) { return setValue("csv_path", str, time); }
1504 bool set_csv_path(const std::string& str, double time = TiMe::Default()) { return setValue("csv_path", str, time); }
1508 std::string get_csv_path(double time = TiMe::Default()) const { return getString("csv_path", time); }
1509
1512 bool set_csv_color_filter(const Color& color, double time = TiMe::Default()) { return setValue("csv_color_filter", color, time); }
1515 Color get_csv_color_filter(double time = TiMe::Default()) const { return getColor("csv_color_filter", time); }
1516};
1517
1519class BRDFCarPaint : public Plugin {
1520public:
1522 static constexpr const PluginTypeId getTypeId() { return 0x77CF44ED; }
1524 static constexpr const char* getType() { return "BRDFCarPaint"; }
1525
1526 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
1527
1531 bool set_base_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base_color", texture, time); }
1535 bool set_base_color(const AColor& texture, double time = TiMe::Default()) { return setValue("base_color", texture, time); }
1539 Value get_base_color(double time = TiMe::Default()) const { return getValue("base_color", time); }
1540
1544 bool set_base_reflection(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_reflection", texturefloat, time); }
1548 bool set_base_reflection(float texturefloat, double time = TiMe::Default()) { return setValue("base_reflection", texturefloat, time); }
1552 Value get_base_reflection(double time = TiMe::Default()) const { return getValue("base_reflection", time); }
1553
1557 bool set_base_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness", texturefloat, time); }
1561 bool set_base_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness", texturefloat, time); }
1565 Value get_base_glossiness(double time = TiMe::Default()) const { return getValue("base_glossiness", time); }
1566
1570 bool set_base_traceReflections(bool val, double time = TiMe::Default()) { return setValue("base_traceReflections", val, time); }
1574 bool get_base_traceReflections(double time = TiMe::Default()) const { return getBool("base_traceReflections", time); }
1575
1578 bool set_base_bump_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_bump_float", texturefloat, time); }
1581 bool set_base_bump_float(float texturefloat, double time = TiMe::Default()) { return setValue("base_bump_float", texturefloat, time); }
1584 Value get_base_bump_float(double time = TiMe::Default()) const { return getValue("base_bump_float", time); }
1585
1588 bool set_base_bump_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base_bump_color", texture, time); }
1591 bool set_base_bump_color(const AColor& texture, double time = TiMe::Default()) { return setValue("base_bump_color", texture, time); }
1594 Value get_base_bump_color(double time = TiMe::Default()) const { return getValue("base_bump_color", time); }
1595
1598 bool set_base_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_bump_amount", texturefloat, time); }
1601 bool set_base_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("base_bump_amount", texturefloat, time); }
1604 Value get_base_bump_amount(double time = TiMe::Default()) const { return getValue("base_bump_amount", time); }
1605
1609 bool set_base_bump_type(int val, double time = TiMe::Default()) { return setValue("base_bump_type", val, time); }
1613 int get_base_bump_type(double time = TiMe::Default()) const { return getInt("base_bump_type", time); }
1614
1618 bool set_flake_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
1622 bool set_flake_color(const AColor& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
1626 Value get_flake_color(double time = TiMe::Default()) const { return getValue("flake_color", time); }
1627
1631 bool set_flake_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("flake_glossiness", texturefloat, time); }
1635 bool set_flake_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("flake_glossiness", texturefloat, time); }
1639 Value get_flake_glossiness(double time = TiMe::Default()) const { return getValue("flake_glossiness", time); }
1640
1644 bool set_flake_orientation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
1648 bool set_flake_orientation(float texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
1652 Value get_flake_orientation(double time = TiMe::Default()) const { return getValue("flake_orientation", time); }
1653
1657 bool set_flake_density(float val, double time = TiMe::Default()) { return setValue("flake_density", val, time); }
1661 float get_flake_density(double time = TiMe::Default()) const { return getFloat("flake_density", time); }
1662
1666 bool set_flake_scale(float val, double time = TiMe::Default()) { return setValue("flake_scale", val, time); }
1670 float get_flake_scale(double time = TiMe::Default()) const { return getFloat("flake_scale", time); }
1671
1675 bool set_flake_size(float val, double time = TiMe::Default()) { return setValue("flake_size", val, time); }
1679 float get_flake_size(double time = TiMe::Default()) const { return getFloat("flake_size", time); }
1680
1684 bool set_flake_map_size(int val, double time = TiMe::Default()) { return setValue("flake_map_size", val, time); }
1688 int get_flake_map_size(double time = TiMe::Default()) const { return getInt("flake_map_size", time); }
1689
1693 bool set_flake_filtering_mode(int val, double time = TiMe::Default()) { return setValue("flake_filtering_mode", val, time); }
1697 int get_flake_filtering_mode(double time = TiMe::Default()) const { return getInt("flake_filtering_mode", time); }
1698
1702 bool set_flake_seed(int val, double time = TiMe::Default()) { return setValue("flake_seed", val, time); }
1706 int get_flake_seed(double time = TiMe::Default()) const { return getInt("flake_seed", time); }
1707
1710 bool set_flake_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("flake_uvwgen", plugin, time); }
1713 PluginRef get_flake_uvwgen(double time = TiMe::Default()) const { return getPlugin("flake_uvwgen", time); }
1714
1718 bool set_mapping_type(int val, double time = TiMe::Default()) { return setValue("mapping_type", val, time); }
1722 int get_mapping_type(double time = TiMe::Default()) const { return getInt("mapping_type", time); }
1723
1727 bool set_mapping_channel(int val, double time = TiMe::Default()) { return setValue("mapping_channel", val, time); }
1731 int get_mapping_channel(double time = TiMe::Default()) const { return getInt("mapping_channel", time); }
1732
1736 bool set_flake_traceReflections(bool val, double time = TiMe::Default()) { return setValue("flake_traceReflections", val, time); }
1740 bool get_flake_traceReflections(double time = TiMe::Default()) const { return getBool("flake_traceReflections", time); }
1741
1745 bool set_coat_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
1749 bool set_coat_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
1753 Value get_coat_color(double time = TiMe::Default()) const { return getValue("coat_color", time); }
1754
1758 bool set_coat_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_strength", texturefloat, time); }
1762 bool set_coat_strength(float texturefloat, double time = TiMe::Default()) { return setValue("coat_strength", texturefloat, time); }
1766 Value get_coat_strength(double time = TiMe::Default()) const { return getValue("coat_strength", time); }
1767
1771 bool set_coat_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
1775 bool set_coat_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
1779 Value get_coat_glossiness(double time = TiMe::Default()) const { return getValue("coat_glossiness", time); }
1780
1784 bool set_coat_traceReflections(bool val, double time = TiMe::Default()) { return setValue("coat_traceReflections", val, time); }
1788 bool get_coat_traceReflections(double time = TiMe::Default()) const { return getBool("coat_traceReflections", time); }
1789
1792 bool set_coat_bump_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_float", texturefloat, time); }
1795 bool set_coat_bump_float(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_float", texturefloat, time); }
1798 Value get_coat_bump_float(double time = TiMe::Default()) const { return getValue("coat_bump_float", time); }
1799
1802 bool set_coat_bump_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_bump_color", texture, time); }
1805 bool set_coat_bump_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_bump_color", texture, time); }
1808 Value get_coat_bump_color(double time = TiMe::Default()) const { return getValue("coat_bump_color", time); }
1809
1812 bool set_coat_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
1815 bool set_coat_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
1818 Value get_coat_bump_amount(double time = TiMe::Default()) const { return getValue("coat_bump_amount", time); }
1819
1823 bool set_coat_bump_type(int val, double time = TiMe::Default()) { return setValue("coat_bump_type", val, time); }
1827 int get_coat_bump_type(double time = TiMe::Default()) const { return getInt("coat_bump_type", time); }
1828
1832 bool set_traceReflections(bool val, double time = TiMe::Default()) { return setValue("traceReflections", val, time); }
1836 bool get_traceReflections(double time = TiMe::Default()) const { return getBool("traceReflections", time); }
1837
1841 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
1845 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
1846
1850 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
1854 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
1855
1859 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
1863 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
1864
1868 bool set_cutoff_threshold(float val, double time = TiMe::Default()) { return setValue("cutoff_threshold", val, time); }
1872 float get_cutoff_threshold(double time = TiMe::Default()) const { return getFloat("cutoff_threshold", time); }
1873
1877 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
1881 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
1882
1885 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
1888 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
1891 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
1892
1896 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
1900 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
1901
1905 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
1909 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
1913 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
1914};
1915
1917class BRDFCarPaint2 : public Plugin {
1918public:
1920 static constexpr const PluginTypeId getTypeId() { return 0x786713E5; }
1922 static constexpr const char* getType() { return "BRDFCarPaint2"; }
1923
1924 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
1925
1929 bool set_base_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base_color", texture, time); }
1933 bool set_base_color(const AColor& texture, double time = TiMe::Default()) { return setValue("base_color", texture, time); }
1937 Value get_base_color(double time = TiMe::Default()) const { return getValue("base_color", time); }
1938
1942 bool set_base_reflection(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_reflection", texturefloat, time); }
1946 bool set_base_reflection(float texturefloat, double time = TiMe::Default()) { return setValue("base_reflection", texturefloat, time); }
1950 Value get_base_reflection(double time = TiMe::Default()) const { return getValue("base_reflection", time); }
1951
1955 bool set_base_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness", texturefloat, time); }
1959 bool set_base_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness", texturefloat, time); }
1963 Value get_base_glossiness(double time = TiMe::Default()) const { return getValue("base_glossiness", time); }
1964
1968 bool set_base_glossiness_tail(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness_tail", texturefloat, time); }
1972 bool set_base_glossiness_tail(float texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness_tail", texturefloat, time); }
1976 Value get_base_glossiness_tail(double time = TiMe::Default()) const { return getValue("base_glossiness_tail", time); }
1977
1981 bool set_base_traceReflections(bool val, double time = TiMe::Default()) { return setValue("base_traceReflections", val, time); }
1985 bool get_base_traceReflections(double time = TiMe::Default()) const { return getBool("base_traceReflections", time); }
1986
1989 bool set_base_bump_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_bump_float", texturefloat, time); }
1992 bool set_base_bump_float(float texturefloat, double time = TiMe::Default()) { return setValue("base_bump_float", texturefloat, time); }
1995 Value get_base_bump_float(double time = TiMe::Default()) const { return getValue("base_bump_float", time); }
1996
1999 bool set_base_bump_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base_bump_color", texture, time); }
2002 bool set_base_bump_color(const AColor& texture, double time = TiMe::Default()) { return setValue("base_bump_color", texture, time); }
2005 Value get_base_bump_color(double time = TiMe::Default()) const { return getValue("base_bump_color", time); }
2006
2009 bool set_base_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_bump_amount", texturefloat, time); }
2012 bool set_base_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("base_bump_amount", texturefloat, time); }
2015 Value get_base_bump_amount(double time = TiMe::Default()) const { return getValue("base_bump_amount", time); }
2016
2020 bool set_base_bump_type(int val, double time = TiMe::Default()) { return setValue("base_bump_type", val, time); }
2024 int get_base_bump_type(double time = TiMe::Default()) const { return getInt("base_bump_type", time); }
2025
2029 bool set_flake_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
2033 bool set_flake_color(const AColor& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
2037 Value get_flake_color(double time = TiMe::Default()) const { return getValue("flake_color", time); }
2038
2042 bool set_flake_random_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("flake_random_color", texture, time); }
2046 bool set_flake_random_color(const AColor& texture, double time = TiMe::Default()) { return setValue("flake_random_color", texture, time); }
2050 Value get_flake_random_color(double time = TiMe::Default()) const { return getValue("flake_random_color", time); }
2051
2055 bool set_flake_orientation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
2059 bool set_flake_orientation(float texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
2063 Value get_flake_orientation(double time = TiMe::Default()) const { return getValue("flake_orientation", time); }
2064
2068 bool set_flake_orientation_tail(float val, double time = TiMe::Default()) { return setValue("flake_orientation_tail", val, time); }
2072 float get_flake_orientation_tail(double time = TiMe::Default()) const { return getFloat("flake_orientation_tail", time); }
2073
2077 bool set_flake_glossiness(float val, double time = TiMe::Default()) { return setValue("flake_glossiness", val, time); }
2081 float get_flake_glossiness(double time = TiMe::Default()) const { return getFloat("flake_glossiness", time); }
2082
2086 bool set_flake_density(float val, double time = TiMe::Default()) { return setValue("flake_density", val, time); }
2090 float get_flake_density(double time = TiMe::Default()) const { return getFloat("flake_density", time); }
2091
2095 bool set_flake_scale(float val, double time = TiMe::Default()) { return setValue("flake_scale", val, time); }
2099 float get_flake_scale(double time = TiMe::Default()) const { return getFloat("flake_scale", time); }
2100
2104 bool set_flake_scale_triplanar(float val, double time = TiMe::Default()) { return setValue("flake_scale_triplanar", val, time); }
2108 float get_flake_scale_triplanar(double time = TiMe::Default()) const { return getFloat("flake_scale_triplanar", time); }
2109
2113 bool set_flake_size(float val, double time = TiMe::Default()) { return setValue("flake_size", val, time); }
2117 float get_flake_size(double time = TiMe::Default()) const { return getFloat("flake_size", time); }
2118
2122 bool set_flake_map_size(int val, double time = TiMe::Default()) { return setValue("flake_map_size", val, time); }
2126 int get_flake_map_size(double time = TiMe::Default()) const { return getInt("flake_map_size", time); }
2127
2131 bool set_flake_seed(int val, double time = TiMe::Default()) { return setValue("flake_seed", val, time); }
2135 int get_flake_seed(double time = TiMe::Default()) const { return getInt("flake_seed", time); }
2136
2139 bool set_flake_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("flake_uvwgen", plugin, time); }
2142 PluginRef get_flake_uvwgen(double time = TiMe::Default()) const { return getPlugin("flake_uvwgen", time); }
2143
2147 bool set_mapping_type(int val, double time = TiMe::Default()) { return setValue("mapping_type", val, time); }
2151 int get_mapping_type(double time = TiMe::Default()) const { return getInt("mapping_type", time); }
2152
2156 bool set_mapping_channel(int val, double time = TiMe::Default()) { return setValue("mapping_channel", val, time); }
2160 int get_mapping_channel(double time = TiMe::Default()) const { return getInt("mapping_channel", time); }
2161
2165 bool set_flake_traceReflections(bool val, double time = TiMe::Default()) { return setValue("flake_traceReflections", val, time); }
2169 bool get_flake_traceReflections(double time = TiMe::Default()) const { return getBool("flake_traceReflections", time); }
2170
2174 bool set_flake_bin_subdivs(int val, double time = TiMe::Default()) { return setValue("flake_bin_subdivs", val, time); }
2178 int get_flake_bin_subdivs(double time = TiMe::Default()) const { return getInt("flake_bin_subdivs", time); }
2179
2183 bool set_coat_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
2187 bool set_coat_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
2191 Value get_coat_color(double time = TiMe::Default()) const { return getValue("coat_color", time); }
2192
2196 bool set_coat_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_amount", texturefloat, time); }
2200 bool set_coat_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_amount", texturefloat, time); }
2204 Value get_coat_amount(double time = TiMe::Default()) const { return getValue("coat_amount", time); }
2205
2209 bool set_coat_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_ior", texturefloat, time); }
2213 bool set_coat_ior(float texturefloat, double time = TiMe::Default()) { return setValue("coat_ior", texturefloat, time); }
2217 Value get_coat_ior(double time = TiMe::Default()) const { return getValue("coat_ior", time); }
2218
2222 bool set_coat_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
2226 bool set_coat_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
2230 Value get_coat_glossiness(double time = TiMe::Default()) const { return getValue("coat_glossiness", time); }
2231
2235 bool set_coat_traceReflections(bool val, double time = TiMe::Default()) { return setValue("coat_traceReflections", val, time); }
2239 bool get_coat_traceReflections(double time = TiMe::Default()) const { return getBool("coat_traceReflections", time); }
2240
2243 bool set_coat_bump_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_float", texturefloat, time); }
2246 bool set_coat_bump_float(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_float", texturefloat, time); }
2249 Value get_coat_bump_float(double time = TiMe::Default()) const { return getValue("coat_bump_float", time); }
2250
2253 bool set_coat_bump_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_bump_color", texture, time); }
2256 bool set_coat_bump_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_bump_color", texture, time); }
2259 Value get_coat_bump_color(double time = TiMe::Default()) const { return getValue("coat_bump_color", time); }
2260
2263 bool set_coat_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
2266 bool set_coat_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
2269 Value get_coat_bump_amount(double time = TiMe::Default()) const { return getValue("coat_bump_amount", time); }
2270
2274 bool set_coat_bump_type(int val, double time = TiMe::Default()) { return setValue("coat_bump_type", val, time); }
2278 int get_coat_bump_type(double time = TiMe::Default()) const { return getInt("coat_bump_type", time); }
2279
2283 bool set_traceReflections(bool val, double time = TiMe::Default()) { return setValue("traceReflections", val, time); }
2287 bool get_traceReflections(double time = TiMe::Default()) const { return getBool("traceReflections", time); }
2288
2292 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
2296 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
2297
2301 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
2305 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
2306
2310 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
2314 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
2315
2319 bool set_cutoff_threshold(float val, double time = TiMe::Default()) { return setValue("cutoff_threshold", val, time); }
2323 float get_cutoff_threshold(double time = TiMe::Default()) const { return getFloat("cutoff_threshold", time); }
2324
2328 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
2332 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
2333
2336 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
2339 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
2342 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
2343
2347 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
2351 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
2352
2356 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
2360 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
2364 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
2365};
2366
2368class BRDFCookTorrance : public Plugin {
2369public:
2371 static constexpr const PluginTypeId getTypeId() { return 0x77DF20B1; }
2373 static constexpr const char* getType() { return "BRDFCookTorrance"; }
2374
2375 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
2376
2380 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
2384 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
2385
2388 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
2391 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
2394 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
2395
2399 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
2403 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
2404
2408 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
2412 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
2413
2416 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
2419 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
2422 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
2423
2427 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
2431 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
2432
2436 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
2440 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
2441
2445 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
2449 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
2450
2454 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
2458 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
2459
2463 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
2467 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
2468
2472 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
2476 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
2477
2481 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
2485 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
2489 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
2490
2494 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
2498 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
2499
2503 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
2507 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
2508
2512 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
2516 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
2517
2521 bool set_hilightGlossiness(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness", val, time); }
2525 float get_hilightGlossiness(double time = TiMe::Default()) const { return getFloat("hilightGlossiness", time); }
2526
2529 bool set_hilightGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
2532 bool set_hilightGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
2535 Value get_hilightGlossiness_tex(double time = TiMe::Default()) const { return getValue("hilightGlossiness_tex", time); }
2536
2540 bool set_hilightGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex_mult", val, time); }
2544 float get_hilightGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("hilightGlossiness_tex_mult", time); }
2545
2549 bool set_reflectionGlossiness(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness", val, time); }
2553 float get_reflectionGlossiness(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness", time); }
2554
2557 bool set_reflectionGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
2560 bool set_reflectionGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
2563 Value get_reflectionGlossiness_tex(double time = TiMe::Default()) const { return getValue("reflectionGlossiness_tex", time); }
2564
2568 bool set_reflectionGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex_mult", val, time); }
2572 float get_reflectionGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness_tex_mult", time); }
2573
2577 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
2581 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
2582
2586 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
2590 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
2591
2595 bool set_soften_edge(float val, double time = TiMe::Default()) { return setValue("soften_edge", val, time); }
2599 float get_soften_edge(double time = TiMe::Default()) const { return getFloat("soften_edge", time); }
2600
2604 bool set_interpolation_on(int val, double time = TiMe::Default()) { return setValue("interpolation_on", val, time); }
2608 int get_interpolation_on(double time = TiMe::Default()) const { return getInt("interpolation_on", time); }
2609
2613 bool set_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("imap_min_rate", val, time); }
2617 int get_imap_min_rate(double time = TiMe::Default()) const { return getInt("imap_min_rate", time); }
2618
2622 bool set_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("imap_max_rate", val, time); }
2626 int get_imap_max_rate(double time = TiMe::Default()) const { return getInt("imap_max_rate", time); }
2627
2631 bool set_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("imap_color_thresh", val, time); }
2635 float get_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("imap_color_thresh", time); }
2636
2640 bool set_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("imap_norm_thresh", val, time); }
2644 float get_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("imap_norm_thresh", time); }
2645
2649 bool set_imap_samples(int val, double time = TiMe::Default()) { return setValue("imap_samples", val, time); }
2653 int get_imap_samples(double time = TiMe::Default()) const { return getInt("imap_samples", time); }
2654
2658 bool set_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
2662 bool set_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
2666 Value get_anisotropy(double time = TiMe::Default()) const { return getValue("anisotropy", time); }
2667
2670 bool set_anisotropy_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("anisotropy_uvwgen", plugin, time); }
2673 PluginRef get_anisotropy_uvwgen(double time = TiMe::Default()) const { return getPlugin("anisotropy_uvwgen", time); }
2674
2678 bool set_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
2682 bool set_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
2686 Value get_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("anisotropy_rotation", time); }
2687
2691 bool set_fix_dark_edges(bool val, double time = TiMe::Default()) { return setValue("fix_dark_edges", val, time); }
2695 bool get_fix_dark_edges(double time = TiMe::Default()) const { return getBool("fix_dark_edges", time); }
2696};
2697
2699class BRDFDiffuse : public Plugin {
2700public:
2702 static constexpr const PluginTypeId getTypeId() { return 0x77742B0D; }
2704 static constexpr const char* getType() { return "BRDFDiffuse"; }
2705
2706 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
2707
2711 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
2715 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
2716
2719 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
2722 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
2725 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
2726
2730 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
2734 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
2735
2739 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
2743 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
2744
2747 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
2750 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
2753 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
2754
2758 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
2762 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
2763
2767 bool set_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
2771 bool set_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
2775 Value get_roughness(double time = TiMe::Default()) const { return getValue("roughness", time); }
2776
2780 bool set_use_irradiance_map(bool val, double time = TiMe::Default()) { return setValue("use_irradiance_map", val, time); }
2784 bool get_use_irradiance_map(double time = TiMe::Default()) const { return getBool("use_irradiance_map", time); }
2785
2789 bool set_color_tex_alpha_as_transparency(bool val, double time = TiMe::Default()) { return setValue("color_tex_alpha_as_transparency", val, time); }
2793 bool get_color_tex_alpha_as_transparency(double time = TiMe::Default()) const { return getBool("color_tex_alpha_as_transparency", time); }
2794};
2795
2798public:
2800 static constexpr const PluginTypeId getTypeId() { return 0x77A08B37; }
2802 static constexpr const char* getType() { return "BRDFDiffuse_forSSS"; }
2803
2804 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
2805
2809 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
2813 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
2814
2817 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
2820 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
2823 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
2824
2828 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
2832 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
2833
2837 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
2841 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
2842
2845 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
2848 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
2851 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
2852
2856 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
2860 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
2861
2864 bool set_back_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("back_color", texture, time); }
2867 bool set_back_color(const AColor& texture, double time = TiMe::Default()) { return setValue("back_color", texture, time); }
2870 Value get_back_color(double time = TiMe::Default()) const { return getValue("back_color", time); }
2871
2875 bool set_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
2879 bool set_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
2883 Value get_roughness(double time = TiMe::Default()) const { return getValue("roughness", time); }
2884
2888 bool set_use_irradiance_map(bool val, double time = TiMe::Default()) { return setValue("use_irradiance_map", val, time); }
2892 bool get_use_irradiance_map(double time = TiMe::Default()) const { return getBool("use_irradiance_map", time); }
2893};
2894
2896class BRDFFiltering : public Plugin {
2897public:
2899 static constexpr const PluginTypeId getTypeId() { return 0x7849EF27; }
2901 static constexpr const char* getType() { return "BRDFFiltering"; }
2902
2903 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
2904
2908 bool set_hilight_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
2912 bool set_hilight_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
2916 Value get_hilight_glossiness(double time = TiMe::Default()) const { return getValue("hilight_glossiness", time); }
2917
2920 bool set_roughness(float val, double time = TiMe::Default()) { return setValue("roughness", val, time); }
2923 float get_roughness(double time = TiMe::Default()) const { return getFloat("roughness", time); }
2924
2927 bool set_alpha(float val, double time = TiMe::Default()) { return setValue("alpha", val, time); }
2930 float get_alpha(double time = TiMe::Default()) const { return getFloat("alpha", time); }
2931
2935 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
2939 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
2940
2944 bool set_reflect_filter(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_filter", texture, time); }
2948 bool set_reflect_filter(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_filter", texture, time); }
2952 Value get_reflect_filter(double time = TiMe::Default()) const { return getValue("reflect_filter", time); }
2953
2957 bool set_mapping_type(int val, double time = TiMe::Default()) { return setValue("mapping_type", val, time); }
2961 int get_mapping_type(double time = TiMe::Default()) const { return getInt("mapping_type", time); }
2962
2966 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
2970 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
2971
2975 bool set_brdf_type(int val, double time = TiMe::Default()) { return setValue("brdf_type", val, time); }
2979 int get_brdf_type(double time = TiMe::Default()) const { return getInt("brdf_type", time); }
2980
2982 bool set_normal_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("normal_map", texture, time); }
2984 bool set_normal_map(const AColor& texture, double time = TiMe::Default()) { return setValue("normal_map", texture, time); }
2986 Value get_normal_map(double time = TiMe::Default()) const { return getValue("normal_map", time); }
2987
2990 bool set_bin_subdivs(int val, double time = TiMe::Default()) { return setValue("bin_subdivs", val, time); }
2993 int get_bin_subdivs(double time = TiMe::Default()) const { return getInt("bin_subdivs", time); }
2994
2997 bool set_bump_amount(float val, double time = TiMe::Default()) { return setValue("bump_amount", val, time); }
3000 float get_bump_amount(double time = TiMe::Default()) const { return getFloat("bump_amount", time); }
3001
3004 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
3007 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
3008
3011 bool set_filtering_mode(int val, double time = TiMe::Default()) { return setValue("filtering_mode", val, time); }
3014 int get_filtering_mode(double time = TiMe::Default()) const { return getInt("filtering_mode", time); }
3015
3018 bool set_normals_transform_type(int val, double time = TiMe::Default()) { return setValue("normals_transform_type", val, time); }
3021 int get_normals_transform_type(double time = TiMe::Default()) const { return getInt("normals_transform_type", time); }
3022};
3023
3025class BRDFFlakes : public Plugin {
3026public:
3028 static constexpr const PluginTypeId getTypeId() { return 0x77DE0EDD; }
3030 static constexpr const char* getType() { return "BRDFFlakes"; }
3031
3032 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
3033
3037 bool set_flake_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
3041 bool set_flake_color(const AColor& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
3045 Value get_flake_color(double time = TiMe::Default()) const { return getValue("flake_color", time); }
3046
3050 bool set_flake_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("flake_glossiness", texturefloat, time); }
3054 bool set_flake_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("flake_glossiness", texturefloat, time); }
3058 Value get_flake_glossiness(double time = TiMe::Default()) const { return getValue("flake_glossiness", time); }
3059
3063 bool set_flake_orientation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
3067 bool set_flake_orientation(float texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
3071 Value get_flake_orientation(double time = TiMe::Default()) const { return getValue("flake_orientation", time); }
3072
3076 bool set_flake_density(float val, double time = TiMe::Default()) { return setValue("flake_density", val, time); }
3080 float get_flake_density(double time = TiMe::Default()) const { return getFloat("flake_density", time); }
3081
3085 bool set_flake_scale(float val, double time = TiMe::Default()) { return setValue("flake_scale", val, time); }
3089 float get_flake_scale(double time = TiMe::Default()) const { return getFloat("flake_scale", time); }
3090
3094 bool set_flake_size(float val, double time = TiMe::Default()) { return setValue("flake_size", val, time); }
3098 float get_flake_size(double time = TiMe::Default()) const { return getFloat("flake_size", time); }
3099
3103 bool set_flake_map_size(int val, double time = TiMe::Default()) { return setValue("flake_map_size", val, time); }
3107 int get_flake_map_size(double time = TiMe::Default()) const { return getInt("flake_map_size", time); }
3108
3112 bool set_flake_filtering_mode(int val, double time = TiMe::Default()) { return setValue("flake_filtering_mode", val, time); }
3116 int get_flake_filtering_mode(double time = TiMe::Default()) const { return getInt("flake_filtering_mode", time); }
3117
3121 bool set_flake_seed(int val, double time = TiMe::Default()) { return setValue("flake_seed", val, time); }
3125 int get_flake_seed(double time = TiMe::Default()) const { return getInt("flake_seed", time); }
3126
3129 bool set_flake_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("flake_uvwgen", plugin, time); }
3132 PluginRef get_flake_uvwgen(double time = TiMe::Default()) const { return getPlugin("flake_uvwgen", time); }
3133
3137 bool set_mapping_type(int val, double time = TiMe::Default()) { return setValue("mapping_type", val, time); }
3141 int get_mapping_type(double time = TiMe::Default()) const { return getInt("mapping_type", time); }
3142
3146 bool set_mapping_channel(int val, double time = TiMe::Default()) { return setValue("mapping_channel", val, time); }
3150 int get_mapping_channel(double time = TiMe::Default()) const { return getInt("mapping_channel", time); }
3151
3155 bool set_traceReflections(bool val, double time = TiMe::Default()) { return setValue("traceReflections", val, time); }
3159 bool get_traceReflections(double time = TiMe::Default()) const { return getBool("traceReflections", time); }
3160
3164 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
3168 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
3169
3173 bool set_doubleSided(int val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
3177 int get_doubleSided(double time = TiMe::Default()) const { return getInt("doubleSided", time); }
3178
3182 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
3186 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
3187
3191 bool set_cutoff_threshold(float val, double time = TiMe::Default()) { return setValue("cutoff_threshold", val, time); }
3195 float get_cutoff_threshold(double time = TiMe::Default()) const { return getFloat("cutoff_threshold", time); }
3196
3200 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
3204 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
3205
3208 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
3211 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
3214 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
3215
3219 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
3223 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
3224};
3225
3227class BRDFFlakes2 : public Plugin {
3228public:
3230 static constexpr const PluginTypeId getTypeId() { return 0x786713E6; }
3232 static constexpr const char* getType() { return "BRDFFlakes2"; }
3233
3234 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
3235
3239 bool set_flake_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
3243 bool set_flake_color(const AColor& texture, double time = TiMe::Default()) { return setValue("flake_color", texture, time); }
3247 Value get_flake_color(double time = TiMe::Default()) const { return getValue("flake_color", time); }
3248
3252 bool set_flake_random_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("flake_random_color", texture, time); }
3256 bool set_flake_random_color(const AColor& texture, double time = TiMe::Default()) { return setValue("flake_random_color", texture, time); }
3260 Value get_flake_random_color(double time = TiMe::Default()) const { return getValue("flake_random_color", time); }
3261
3265 bool set_flake_orientation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
3269 bool set_flake_orientation(float texturefloat, double time = TiMe::Default()) { return setValue("flake_orientation", texturefloat, time); }
3273 Value get_flake_orientation(double time = TiMe::Default()) const { return getValue("flake_orientation", time); }
3274
3278 bool set_flake_orientation_tail(float val, double time = TiMe::Default()) { return setValue("flake_orientation_tail", val, time); }
3282 float get_flake_orientation_tail(double time = TiMe::Default()) const { return getFloat("flake_orientation_tail", time); }
3283
3287 bool set_flake_glossiness(float val, double time = TiMe::Default()) { return setValue("flake_glossiness", val, time); }
3291 float get_flake_glossiness(double time = TiMe::Default()) const { return getFloat("flake_glossiness", time); }
3292
3296 bool set_flake_density(float val, double time = TiMe::Default()) { return setValue("flake_density", val, time); }
3300 float get_flake_density(double time = TiMe::Default()) const { return getFloat("flake_density", time); }
3301
3305 bool set_flake_scale(float val, double time = TiMe::Default()) { return setValue("flake_scale", val, time); }
3309 float get_flake_scale(double time = TiMe::Default()) const { return getFloat("flake_scale", time); }
3310
3314 bool set_flake_scale_triplanar(float val, double time = TiMe::Default()) { return setValue("flake_scale_triplanar", val, time); }
3318 float get_flake_scale_triplanar(double time = TiMe::Default()) const { return getFloat("flake_scale_triplanar", time); }
3319
3323 bool set_flake_size(float val, double time = TiMe::Default()) { return setValue("flake_size", val, time); }
3327 float get_flake_size(double time = TiMe::Default()) const { return getFloat("flake_size", time); }
3328
3332 bool set_flake_map_size(int val, double time = TiMe::Default()) { return setValue("flake_map_size", val, time); }
3336 int get_flake_map_size(double time = TiMe::Default()) const { return getInt("flake_map_size", time); }
3337
3341 bool set_flake_seed(int val, double time = TiMe::Default()) { return setValue("flake_seed", val, time); }
3345 int get_flake_seed(double time = TiMe::Default()) const { return getInt("flake_seed", time); }
3346
3349 bool set_flake_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("flake_uvwgen", plugin, time); }
3352 PluginRef get_flake_uvwgen(double time = TiMe::Default()) const { return getPlugin("flake_uvwgen", time); }
3353
3357 bool set_flake_bin_subdivs(int val, double time = TiMe::Default()) { return setValue("flake_bin_subdivs", val, time); }
3361 int get_flake_bin_subdivs(double time = TiMe::Default()) const { return getInt("flake_bin_subdivs", time); }
3362
3366 bool set_mapping_type(int val, double time = TiMe::Default()) { return setValue("mapping_type", val, time); }
3370 int get_mapping_type(double time = TiMe::Default()) const { return getInt("mapping_type", time); }
3371
3375 bool set_mapping_channel(int val, double time = TiMe::Default()) { return setValue("mapping_channel", val, time); }
3379 int get_mapping_channel(double time = TiMe::Default()) const { return getInt("mapping_channel", time); }
3380
3384 bool set_traceReflections(bool val, double time = TiMe::Default()) { return setValue("traceReflections", val, time); }
3388 bool get_traceReflections(double time = TiMe::Default()) const { return getBool("traceReflections", time); }
3389
3393 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
3397 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
3398
3402 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
3406 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
3407
3411 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
3415 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
3416
3420 bool set_cutoff_threshold(float val, double time = TiMe::Default()) { return setValue("cutoff_threshold", val, time); }
3424 float get_cutoff_threshold(double time = TiMe::Default()) const { return getFloat("cutoff_threshold", time); }
3425
3429 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
3433 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
3434
3437 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
3440 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
3443 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
3444
3448 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
3452 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
3453};
3454
3456class BRDFGGX : public Plugin {
3457public:
3459 static constexpr const PluginTypeId getTypeId() { return 0x780BFB81; }
3461 static constexpr const char* getType() { return "BRDFGGX"; }
3462
3463 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
3464
3468 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
3472 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
3473
3476 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
3479 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
3482 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
3483
3487 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
3491 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
3492
3496 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
3500 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
3501
3504 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
3507 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
3510 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
3511
3515 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
3519 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
3520
3524 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
3528 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
3529
3533 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
3537 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
3538
3542 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
3546 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
3547
3551 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
3555 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
3556
3560 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
3564 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
3565
3569 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
3573 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
3577 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
3578
3582 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
3586 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
3587
3591 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
3595 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
3596
3600 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
3604 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
3605
3609 bool set_hilightGlossiness(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness", val, time); }
3613 float get_hilightGlossiness(double time = TiMe::Default()) const { return getFloat("hilightGlossiness", time); }
3614
3617 bool set_hilightGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
3620 bool set_hilightGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
3623 Value get_hilightGlossiness_tex(double time = TiMe::Default()) const { return getValue("hilightGlossiness_tex", time); }
3624
3628 bool set_hilightGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex_mult", val, time); }
3632 float get_hilightGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("hilightGlossiness_tex_mult", time); }
3633
3637 bool set_reflectionGlossiness(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness", val, time); }
3641 float get_reflectionGlossiness(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness", time); }
3642
3645 bool set_reflectionGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
3648 bool set_reflectionGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
3651 Value get_reflectionGlossiness_tex(double time = TiMe::Default()) const { return getValue("reflectionGlossiness_tex", time); }
3652
3656 bool set_reflectionGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex_mult", val, time); }
3660 float get_reflectionGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness_tex_mult", time); }
3661
3665 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
3669 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
3670
3674 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
3678 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
3679
3683 bool set_soften_edge(float val, double time = TiMe::Default()) { return setValue("soften_edge", val, time); }
3687 float get_soften_edge(double time = TiMe::Default()) const { return getFloat("soften_edge", time); }
3688
3692 bool set_interpolation_on(int val, double time = TiMe::Default()) { return setValue("interpolation_on", val, time); }
3696 int get_interpolation_on(double time = TiMe::Default()) const { return getInt("interpolation_on", time); }
3697
3701 bool set_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("imap_min_rate", val, time); }
3705 int get_imap_min_rate(double time = TiMe::Default()) const { return getInt("imap_min_rate", time); }
3706
3710 bool set_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("imap_max_rate", val, time); }
3714 int get_imap_max_rate(double time = TiMe::Default()) const { return getInt("imap_max_rate", time); }
3715
3719 bool set_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("imap_color_thresh", val, time); }
3723 float get_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("imap_color_thresh", time); }
3724
3728 bool set_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("imap_norm_thresh", val, time); }
3732 float get_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("imap_norm_thresh", time); }
3733
3737 bool set_imap_samples(int val, double time = TiMe::Default()) { return setValue("imap_samples", val, time); }
3741 int get_imap_samples(double time = TiMe::Default()) const { return getInt("imap_samples", time); }
3742
3746 bool set_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
3750 bool set_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
3754 Value get_anisotropy(double time = TiMe::Default()) const { return getValue("anisotropy", time); }
3755
3758 bool set_anisotropy_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("anisotropy_uvwgen", plugin, time); }
3761 PluginRef get_anisotropy_uvwgen(double time = TiMe::Default()) const { return getPlugin("anisotropy_uvwgen", time); }
3762
3766 bool set_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
3770 bool set_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
3774 Value get_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("anisotropy_rotation", time); }
3775
3779 bool set_fix_dark_edges(bool val, double time = TiMe::Default()) { return setValue("fix_dark_edges", val, time); }
3783 bool get_fix_dark_edges(double time = TiMe::Default()) const { return getBool("fix_dark_edges", time); }
3784
3788 bool set_gtr_gamma(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gtr_gamma", texturefloat, time); }
3792 bool set_gtr_gamma(float texturefloat, double time = TiMe::Default()) { return setValue("gtr_gamma", texturefloat, time); }
3796 Value get_gtr_gamma(double time = TiMe::Default()) const { return getValue("gtr_gamma", time); }
3797
3801 bool set_new_gtr_anisotropy(bool val, double time = TiMe::Default()) { return setValue("new_gtr_anisotropy", val, time); }
3805 bool get_new_gtr_anisotropy(double time = TiMe::Default()) const { return getBool("new_gtr_anisotropy", time); }
3806};
3807
3809class BRDFGlass : public Plugin {
3810public:
3812 static constexpr const PluginTypeId getTypeId() { return 0x77744B79; }
3814 static constexpr const char* getType() { return "BRDFGlass"; }
3815
3816 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
3817
3821 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
3825 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
3826
3829 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
3832 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
3835 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
3836
3840 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
3844 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
3845
3849 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
3853 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
3854
3857 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
3860 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
3863 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
3864
3868 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
3872 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
3873
3877 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
3881 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
3882
3886 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
3890 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
3891
3895 bool set_affect_shadows(bool val, double time = TiMe::Default()) { return setValue("affect_shadows", val, time); }
3899 bool get_affect_shadows(double time = TiMe::Default()) const { return getBool("affect_shadows", time); }
3900
3904 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
3908 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
3909
3913 bool set_trace_refractions(bool val, double time = TiMe::Default()) { return setValue("trace_refractions", val, time); }
3917 bool get_trace_refractions(double time = TiMe::Default()) const { return getBool("trace_refractions", time); }
3918
3922 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
3926 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
3927
3931 bool set_exit_color_on(bool val, double time = TiMe::Default()) { return setValue("exit_color_on", val, time); }
3935 bool get_exit_color_on(double time = TiMe::Default()) const { return getBool("exit_color_on", time); }
3936
3940 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
3944 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
3948 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
3949
3953 bool set_refract_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("refract_exit_color", texture, time); }
3957 bool set_refract_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("refract_exit_color", texture, time); }
3961 Value get_refract_exit_color(double time = TiMe::Default()) const { return getValue("refract_exit_color", time); }
3962
3965 bool set_volume(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("volume", plugin, time); }
3968 PluginRef get_volume(double time = TiMe::Default()) const { return getPlugin("volume", time); }
3969
3972 bool set_ior_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("ior_tex", texturefloat, time); }
3975 bool set_ior_tex(float texturefloat, double time = TiMe::Default()) { return setValue("ior_tex", texturefloat, time); }
3978 Value get_ior_tex(double time = TiMe::Default()) const { return getValue("ior_tex", time); }
3979};
3980
3982class BRDFGlassGlossy : public Plugin {
3983public:
3985 static constexpr const PluginTypeId getTypeId() { return 0x77931DB5; }
3987 static constexpr const char* getType() { return "BRDFGlassGlossy"; }
3988
3989 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
3990
3994 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
3998 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
3999
4002 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
4005 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
4008 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
4009
4013 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
4017 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
4018
4022 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
4026 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
4027
4030 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
4033 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
4036 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
4037
4041 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
4045 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
4046
4050 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
4054 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
4055
4059 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
4063 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
4064
4068 bool set_affect_shadows(bool val, double time = TiMe::Default()) { return setValue("affect_shadows", val, time); }
4072 bool get_affect_shadows(double time = TiMe::Default()) const { return getBool("affect_shadows", time); }
4073
4077 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
4081 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
4082
4086 bool set_trace_refractions(bool val, double time = TiMe::Default()) { return setValue("trace_refractions", val, time); }
4090 bool get_trace_refractions(double time = TiMe::Default()) const { return getBool("trace_refractions", time); }
4091
4095 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
4099 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
4100
4104 bool set_exit_color_on(bool val, double time = TiMe::Default()) { return setValue("exit_color_on", val, time); }
4108 bool get_exit_color_on(double time = TiMe::Default()) const { return getBool("exit_color_on", time); }
4109
4113 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
4117 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
4121 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
4122
4126 bool set_refract_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("refract_exit_color", texture, time); }
4130 bool set_refract_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("refract_exit_color", texture, time); }
4134 Value get_refract_exit_color(double time = TiMe::Default()) const { return getValue("refract_exit_color", time); }
4135
4138 bool set_volume(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("volume", plugin, time); }
4141 PluginRef get_volume(double time = TiMe::Default()) const { return getPlugin("volume", time); }
4142
4145 bool set_ior_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("ior_tex", texturefloat, time); }
4148 bool set_ior_tex(float texturefloat, double time = TiMe::Default()) { return setValue("ior_tex", texturefloat, time); }
4151 Value get_ior_tex(double time = TiMe::Default()) const { return getValue("ior_tex", time); }
4152
4156 bool set_glossiness(float val, double time = TiMe::Default()) { return setValue("glossiness", val, time); }
4160 float get_glossiness(double time = TiMe::Default()) const { return getFloat("glossiness", time); }
4161
4164 bool set_glossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("glossiness_tex", texturefloat, time); }
4167 bool set_glossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("glossiness_tex", texturefloat, time); }
4170 Value get_glossiness_tex(double time = TiMe::Default()) const { return getValue("glossiness_tex", time); }
4171
4175 bool set_glossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("glossiness_tex_mult", val, time); }
4179 float get_glossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("glossiness_tex_mult", time); }
4180
4184 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
4188 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
4189
4193 bool set_dispersion_on(int val, double time = TiMe::Default()) { return setValue("dispersion_on", val, time); }
4197 int get_dispersion_on(double time = TiMe::Default()) const { return getInt("dispersion_on", time); }
4198
4202 bool set_dispersion(float val, double time = TiMe::Default()) { return setValue("dispersion", val, time); }
4206 float get_dispersion(double time = TiMe::Default()) const { return getFloat("dispersion", time); }
4207
4211 bool set_interpolation_on(int val, double time = TiMe::Default()) { return setValue("interpolation_on", val, time); }
4215 int get_interpolation_on(double time = TiMe::Default()) const { return getInt("interpolation_on", time); }
4216
4220 bool set_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("imap_min_rate", val, time); }
4224 int get_imap_min_rate(double time = TiMe::Default()) const { return getInt("imap_min_rate", time); }
4225
4229 bool set_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("imap_max_rate", val, time); }
4233 int get_imap_max_rate(double time = TiMe::Default()) const { return getInt("imap_max_rate", time); }
4234
4238 bool set_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("imap_color_thresh", val, time); }
4242 float get_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("imap_color_thresh", time); }
4243
4247 bool set_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("imap_norm_thresh", val, time); }
4251 float get_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("imap_norm_thresh", time); }
4252
4256 bool set_imap_samples(int val, double time = TiMe::Default()) { return setValue("imap_samples", val, time); }
4260 int get_imap_samples(double time = TiMe::Default()) const { return getInt("imap_samples", time); }
4261};
4262
4264class BRDFHOPS : public Plugin {
4265public:
4267 static constexpr const PluginTypeId getTypeId() { return 0x41CFB5D5; }
4269 static constexpr const char* getType() { return "BRDFHOPS"; }
4270
4271 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
4272
4276 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
4280 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
4281
4285 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
4289 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
4293 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
4294
4298 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
4302 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
4303
4306 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
4309 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
4310
4313 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
4316 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
4317
4320 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
4323 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
4324
4327 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
4330 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
4331
4334 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
4337 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
4338
4341 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
4344 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
4347 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
4348
4351 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
4354 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
4355
4358 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
4361 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
4362
4365 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
4368 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
4369
4372 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
4375 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
4376
4379 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
4382 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
4383
4387 bool set_csv_path(const char* str, double time = TiMe::Default()) { return setValue("csv_path", str, time); }
4391 bool set_csv_path(const std::string& str, double time = TiMe::Default()) { return setValue("csv_path", str, time); }
4395 std::string get_csv_path(double time = TiMe::Default()) const { return getString("csv_path", time); }
4396
4399 bool set_csv_color_filter(const Color& color, double time = TiMe::Default()) { return setValue("csv_color_filter", color, time); }
4402 Color get_csv_color_filter(double time = TiMe::Default()) const { return getColor("csv_color_filter", time); }
4403
4407 bool set_flakes_csv_path(const char* str, double time = TiMe::Default()) { return setValue("flakes_csv_path", str, time); }
4411 bool set_flakes_csv_path(const std::string& str, double time = TiMe::Default()) { return setValue("flakes_csv_path", str, time); }
4415 std::string get_flakes_csv_path(double time = TiMe::Default()) const { return getString("flakes_csv_path", time); }
4416
4419 bool set_coat_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
4422 bool set_coat_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
4425 Value get_coat_color(double time = TiMe::Default()) const { return getValue("coat_color", time); }
4426
4429 bool set_coat_strength(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_strength", texturefloat, time); }
4432 bool set_coat_strength(float texturefloat, double time = TiMe::Default()) { return setValue("coat_strength", texturefloat, time); }
4435 Value get_coat_strength(double time = TiMe::Default()) const { return getValue("coat_strength", time); }
4436
4439 bool set_coat_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
4442 bool set_coat_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
4445 Value get_coat_glossiness(double time = TiMe::Default()) const { return getValue("coat_glossiness", time); }
4446
4448 bool set_coat_bump_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_float", texturefloat, time); }
4450 bool set_coat_bump_float(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_float", texturefloat, time); }
4452 Value get_coat_bump_float(double time = TiMe::Default()) const { return getValue("coat_bump_float", time); }
4453
4455 bool set_coat_bump_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_bump_color", texture, time); }
4457 bool set_coat_bump_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_bump_color", texture, time); }
4459 Value get_coat_bump_color(double time = TiMe::Default()) const { return getValue("coat_bump_color", time); }
4460
4462 bool set_coat_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
4464 bool set_coat_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
4466 Value get_coat_bump_amount(double time = TiMe::Default()) const { return getValue("coat_bump_amount", time); }
4467
4470 bool set_coat_bump_type(int val, double time = TiMe::Default()) { return setValue("coat_bump_type", val, time); }
4473 int get_coat_bump_type(double time = TiMe::Default()) const { return getInt("coat_bump_type", time); }
4474
4477 bool set_coat_traceReflections(int val, double time = TiMe::Default()) { return setValue("coat_traceReflections", val, time); }
4480 int get_coat_traceReflections(double time = TiMe::Default()) const { return getInt("coat_traceReflections", time); }
4481
4484 bool set_coat_subdivs(int val, double time = TiMe::Default()) { return setValue("coat_subdivs", val, time); }
4487 int get_coat_subdivs(double time = TiMe::Default()) const { return getInt("coat_subdivs", time); }
4488
4491 bool set_enabled_layers(int val, double time = TiMe::Default()) { return setValue("enabled_layers", val, time); }
4494 int get_enabled_layers(double time = TiMe::Default()) const { return getInt("enabled_layers", time); }
4495
4498 bool set_flake_scale(float val, double time = TiMe::Default()) { return setValue("flake_scale", val, time); }
4501 float get_flake_scale(double time = TiMe::Default()) const { return getFloat("flake_scale", time); }
4502
4505 bool set_flake_size(float val, double time = TiMe::Default()) { return setValue("flake_size", val, time); }
4508 float get_flake_size(double time = TiMe::Default()) const { return getFloat("flake_size", time); }
4509
4512 bool set_flake_traceReflections(int val, double time = TiMe::Default()) { return setValue("flake_traceReflections", val, time); }
4515 int get_flake_traceReflections(double time = TiMe::Default()) const { return getInt("flake_traceReflections", time); }
4516
4519 bool set_doubleSided(int val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
4522 int get_doubleSided(double time = TiMe::Default()) const { return getInt("doubleSided", time); }
4523
4526 bool set_flake_glossiness(float val, double time = TiMe::Default()) { return setValue("flake_glossiness", val, time); }
4529 float get_flake_glossiness(double time = TiMe::Default()) const { return getFloat("flake_glossiness", time); }
4530
4532 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
4534 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
4536 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
4537
4540 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
4543 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
4544};
4545
4547class BRDFHair : public Plugin {
4548public:
4550 static constexpr const PluginTypeId getTypeId() { return 0x77CE7D51; }
4552 static constexpr const char* getType() { return "BRDFHair"; }
4553
4554 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
4555
4559 bool set_specular_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("specular_color_tex", texture, time); }
4563 bool set_specular_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("specular_color_tex", texture, time); }
4567 Value get_specular_color_tex(double time = TiMe::Default()) const { return getValue("specular_color_tex", time); }
4568
4572 bool set_specular_power(float val, double time = TiMe::Default()) { return setValue("specular_power", val, time); }
4576 float get_specular_power(double time = TiMe::Default()) const { return getFloat("specular_power", time); }
4577
4580 bool set_diffuse_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color_tex", texture, time); }
4583 bool set_diffuse_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color_tex", texture, time); }
4586 Value get_diffuse_color_tex(double time = TiMe::Default()) const { return getValue("diffuse_color_tex", time); }
4587};
4588
4590class BRDFHair2 : public Plugin {
4591public:
4593 static constexpr const PluginTypeId getTypeId() { return 0x77DE584D; }
4595 static constexpr const char* getType() { return "BRDFHair2"; }
4596
4597 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
4598
4602 bool set_diffuse_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color_tex", texture, time); }
4606 bool set_diffuse_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color_tex", texture, time); }
4610 Value get_diffuse_color_tex(double time = TiMe::Default()) const { return getValue("diffuse_color_tex", time); }
4611
4614 bool set_absorption(const PluginRef& texture, double time = TiMe::Default()) { return setValue("absorption", texture, time); }
4617 bool set_absorption(const AColor& texture, double time = TiMe::Default()) { return setValue("absorption", texture, time); }
4620 Value get_absorption(double time = TiMe::Default()) const { return getValue("absorption", time); }
4621
4625 bool set_refraction_index(float val, double time = TiMe::Default()) { return setValue("refraction_index", val, time); }
4629 float get_refraction_index(double time = TiMe::Default()) const { return getFloat("refraction_index", time); }
4630
4634 bool set_diffuse_mult(float val, double time = TiMe::Default()) { return setValue("diffuse_mult", val, time); }
4638 float get_diffuse_mult(double time = TiMe::Default()) const { return getFloat("diffuse_mult", time); }
4639
4643 bool set_r_mult(float val, double time = TiMe::Default()) { return setValue("r_mult", val, time); }
4647 float get_r_mult(double time = TiMe::Default()) const { return getFloat("r_mult", time); }
4648
4652 bool set_r_long_shift(float val, double time = TiMe::Default()) { return setValue("r_long_shift", val, time); }
4656 float get_r_long_shift(double time = TiMe::Default()) const { return getFloat("r_long_shift", time); }
4657
4661 bool set_r_long_width(float val, double time = TiMe::Default()) { return setValue("r_long_width", val, time); }
4665 float get_r_long_width(double time = TiMe::Default()) const { return getFloat("r_long_width", time); }
4666
4670 bool set_tt_mult(float val, double time = TiMe::Default()) { return setValue("tt_mult", val, time); }
4674 float get_tt_mult(double time = TiMe::Default()) const { return getFloat("tt_mult", time); }
4675
4679 bool set_tt_long_shift(float val, double time = TiMe::Default()) { return setValue("tt_long_shift", val, time); }
4683 float get_tt_long_shift(double time = TiMe::Default()) const { return getFloat("tt_long_shift", time); }
4684
4688 bool set_tt_long_width(float val, double time = TiMe::Default()) { return setValue("tt_long_width", val, time); }
4692 float get_tt_long_width(double time = TiMe::Default()) const { return getFloat("tt_long_width", time); }
4693
4697 bool set_trt_mult(float val, double time = TiMe::Default()) { return setValue("trt_mult", val, time); }
4701 float get_trt_mult(double time = TiMe::Default()) const { return getFloat("trt_mult", time); }
4702
4706 bool set_trt_long_shift(float val, double time = TiMe::Default()) { return setValue("trt_long_shift", val, time); }
4710 float get_trt_long_shift(double time = TiMe::Default()) const { return getFloat("trt_long_shift", time); }
4711
4715 bool set_trt_long_width(float val, double time = TiMe::Default()) { return setValue("trt_long_width", val, time); }
4719 float get_trt_long_width(double time = TiMe::Default()) const { return getFloat("trt_long_width", time); }
4720
4724 bool set_glint_scale(float val, double time = TiMe::Default()) { return setValue("glint_scale", val, time); }
4728 float get_glint_scale(double time = TiMe::Default()) const { return getFloat("glint_scale", time); }
4729
4732 bool set_azimuthal_width(float val, double time = TiMe::Default()) { return setValue("azimuthal_width", val, time); }
4735 float get_azimuthal_width(double time = TiMe::Default()) const { return getFloat("azimuthal_width", time); }
4736
4739 bool set_fade_range(float val, double time = TiMe::Default()) { return setValue("fade_range", val, time); }
4742 float get_fade_range(double time = TiMe::Default()) const { return getFloat("fade_range", time); }
4743
4746 bool set_caustic_limit(float val, double time = TiMe::Default()) { return setValue("caustic_limit", val, time); }
4749 float get_caustic_limit(double time = TiMe::Default()) const { return getFloat("caustic_limit", time); }
4750};
4751
4753class BRDFHair3 : public Plugin {
4754public:
4756 static constexpr const PluginTypeId getTypeId() { return 0x77DECDE1; }
4758 static constexpr const char* getType() { return "BRDFHair3"; }
4759
4760 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
4761
4765 bool set_overall_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("overall_color", texture, time); }
4769 bool set_overall_color(const AColor& texture, double time = TiMe::Default()) { return setValue("overall_color", texture, time); }
4773 Value get_overall_color(double time = TiMe::Default()) const { return getValue("overall_color", time); }
4774
4778 bool set_transparency(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency", texture, time); }
4782 bool set_transparency(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency", texture, time); }
4786 Value get_transparency(double time = TiMe::Default()) const { return getValue("transparency", time); }
4787
4790 bool set_diffuse_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
4793 bool set_diffuse_color(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
4796 Value get_diffuse_color(double time = TiMe::Default()) const { return getValue("diffuse_color", time); }
4797
4801 bool set_diffuse_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
4805 bool set_diffuse_amount(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
4809 Value get_diffuse_amount(double time = TiMe::Default()) const { return getValue("diffuse_amount", time); }
4810
4814 bool set_primary_specular(const PluginRef& texture, double time = TiMe::Default()) { return setValue("primary_specular", texture, time); }
4818 bool set_primary_specular(const AColor& texture, double time = TiMe::Default()) { return setValue("primary_specular", texture, time); }
4822 Value get_primary_specular(double time = TiMe::Default()) const { return getValue("primary_specular", time); }
4823
4827 bool set_primary_specular_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("primary_specular_amount", texturefloat, time); }
4831 bool set_primary_specular_amount(float texturefloat, double time = TiMe::Default()) { return setValue("primary_specular_amount", texturefloat, time); }
4835 Value get_primary_specular_amount(double time = TiMe::Default()) const { return getValue("primary_specular_amount", time); }
4836
4840 bool set_primary_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("primary_glossiness", texturefloat, time); }
4844 bool set_primary_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("primary_glossiness", texturefloat, time); }
4848 Value get_primary_glossiness(double time = TiMe::Default()) const { return getValue("primary_glossiness", time); }
4849
4853 bool set_secondary_lock_to_transmission(bool val, double time = TiMe::Default()) { return setValue("secondary_lock_to_transmission", val, time); }
4857 bool get_secondary_lock_to_transmission(double time = TiMe::Default()) const { return getBool("secondary_lock_to_transmission", time); }
4858
4862 bool set_secondary_specular(const PluginRef& texture, double time = TiMe::Default()) { return setValue("secondary_specular", texture, time); }
4866 bool set_secondary_specular(const AColor& texture, double time = TiMe::Default()) { return setValue("secondary_specular", texture, time); }
4870 Value get_secondary_specular(double time = TiMe::Default()) const { return getValue("secondary_specular", time); }
4871
4875 bool set_secondary_specular_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("secondary_specular_amount", texturefloat, time); }
4879 bool set_secondary_specular_amount(float texturefloat, double time = TiMe::Default()) { return setValue("secondary_specular_amount", texturefloat, time); }
4883 Value get_secondary_specular_amount(double time = TiMe::Default()) const { return getValue("secondary_specular_amount", time); }
4884
4888 bool set_secondary_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("secondary_glossiness", texturefloat, time); }
4892 bool set_secondary_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("secondary_glossiness", texturefloat, time); }
4896 Value get_secondary_glossiness(double time = TiMe::Default()) const { return getValue("secondary_glossiness", time); }
4897
4901 bool set_transmission(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transmission", texture, time); }
4905 bool set_transmission(const AColor& texture, double time = TiMe::Default()) { return setValue("transmission", texture, time); }
4909 Value get_transmission(double time = TiMe::Default()) const { return getValue("transmission", time); }
4910
4914 bool set_transmission_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("transmission_amount", texturefloat, time); }
4918 bool set_transmission_amount(float texturefloat, double time = TiMe::Default()) { return setValue("transmission_amount", texturefloat, time); }
4922 Value get_transmission_amount(double time = TiMe::Default()) const { return getValue("transmission_amount", time); }
4923
4927 bool set_transmission_glossiness_length(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("transmission_glossiness_length", texturefloat, time); }
4931 bool set_transmission_glossiness_length(float texturefloat, double time = TiMe::Default()) { return setValue("transmission_glossiness_length", texturefloat, time); }
4935 Value get_transmission_glossiness_length(double time = TiMe::Default()) const { return getValue("transmission_glossiness_length", time); }
4936
4940 bool set_transmission_glossiness_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("transmission_glossiness_width", texturefloat, time); }
4944 bool set_transmission_glossiness_width(float texturefloat, double time = TiMe::Default()) { return setValue("transmission_glossiness_width", texturefloat, time); }
4948 Value get_transmission_glossiness_width(double time = TiMe::Default()) const { return getValue("transmission_glossiness_width", time); }
4949
4953 bool set_opaque_for_shadows(bool val, double time = TiMe::Default()) { return setValue("opaque_for_shadows", val, time); }
4957 bool get_opaque_for_shadows(double time = TiMe::Default()) const { return getBool("opaque_for_shadows", time); }
4958
4962 bool set_opaque_for_gi(bool val, double time = TiMe::Default()) { return setValue("opaque_for_gi", val, time); }
4966 bool get_opaque_for_gi(double time = TiMe::Default()) const { return getBool("opaque_for_gi", time); }
4967
4971 bool set_simplify_for_gi(bool val, double time = TiMe::Default()) { return setValue("simplify_for_gi", val, time); }
4975 bool get_simplify_for_gi(double time = TiMe::Default()) const { return getBool("simplify_for_gi", time); }
4976
4980 bool set_use_cached_gi(bool val, double time = TiMe::Default()) { return setValue("use_cached_gi", val, time); }
4984 bool get_use_cached_gi(double time = TiMe::Default()) const { return getBool("use_cached_gi", time); }
4985
4989 bool set_transmission_in_specular(bool val, double time = TiMe::Default()) { return setValue("transmission_in_specular", val, time); }
4993 bool get_transmission_in_specular(double time = TiMe::Default()) const { return getBool("transmission_in_specular", time); }
4994
4998 bool set_light_multiplier(float val, double time = TiMe::Default()) { return setValue("light_multiplier", val, time); }
5002 float get_light_multiplier(double time = TiMe::Default()) const { return getFloat("light_multiplier", time); }
5003};
5004
5006class BRDFHair4 : public Plugin {
5007public:
5009 static constexpr const PluginTypeId getTypeId() { return 0x78397A61; }
5011 static constexpr const char* getType() { return "BRDFHair4"; }
5012
5013 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5014
5018 bool set_melanin(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("melanin", texturefloat, time); }
5022 bool set_melanin(float texturefloat, double time = TiMe::Default()) { return setValue("melanin", texturefloat, time); }
5026 Value get_melanin(double time = TiMe::Default()) const { return getValue("melanin", time); }
5027
5031 bool set_pheomelanin(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("pheomelanin", texturefloat, time); }
5035 bool set_pheomelanin(float texturefloat, double time = TiMe::Default()) { return setValue("pheomelanin", texturefloat, time); }
5039 Value get_pheomelanin(double time = TiMe::Default()) const { return getValue("pheomelanin", time); }
5040
5044 bool set_dye_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dye_color", texture, time); }
5048 bool set_dye_color(const AColor& texture, double time = TiMe::Default()) { return setValue("dye_color", texture, time); }
5052 Value get_dye_color(double time = TiMe::Default()) const { return getValue("dye_color", time); }
5053
5057 bool set_transparency(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency", texture, time); }
5061 bool set_transparency(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency", texture, time); }
5065 Value get_transparency(double time = TiMe::Default()) const { return getValue("transparency", time); }
5066
5070 bool set_diffuse_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
5074 bool set_diffuse_color(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
5078 Value get_diffuse_color(double time = TiMe::Default()) const { return getValue("diffuse_color", time); }
5079
5083 bool set_diffuse_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
5087 bool set_diffuse_amount(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
5091 Value get_diffuse_amount(double time = TiMe::Default()) const { return getValue("diffuse_amount", time); }
5092
5096 bool set_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("glossiness", texturefloat, time); }
5100 bool set_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("glossiness", texturefloat, time); }
5104 Value get_glossiness(double time = TiMe::Default()) const { return getValue("glossiness", time); }
5105
5109 bool set_primary_glossiness_boost(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("primary_glossiness_boost", texturefloat, time); }
5113 bool set_primary_glossiness_boost(float texturefloat, double time = TiMe::Default()) { return setValue("primary_glossiness_boost", texturefloat, time); }
5117 Value get_primary_glossiness_boost(double time = TiMe::Default()) const { return getValue("primary_glossiness_boost", time); }
5118
5122 bool set_softness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("softness", texturefloat, time); }
5126 bool set_softness(float texturefloat, double time = TiMe::Default()) { return setValue("softness", texturefloat, time); }
5130 Value get_softness(double time = TiMe::Default()) const { return getValue("softness", time); }
5131
5135 bool set_highlight_shift(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("highlight_shift", texturefloat, time); }
5139 bool set_highlight_shift(float texturefloat, double time = TiMe::Default()) { return setValue("highlight_shift", texturefloat, time); }
5143 Value get_highlight_shift(double time = TiMe::Default()) const { return getValue("highlight_shift", time); }
5144
5148 bool set_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("ior", texturefloat, time); }
5152 bool set_ior(float texturefloat, double time = TiMe::Default()) { return setValue("ior", texturefloat, time); }
5156 Value get_ior(double time = TiMe::Default()) const { return getValue("ior", time); }
5157
5161 bool set_glint_strength(float val, double time = TiMe::Default()) { return setValue("glint_strength", val, time); }
5165 float get_glint_strength(double time = TiMe::Default()) const { return getFloat("glint_strength", time); }
5166
5170 bool set_glint_variation(float val, double time = TiMe::Default()) { return setValue("glint_variation", val, time); }
5174 float get_glint_variation(double time = TiMe::Default()) const { return getFloat("glint_variation", time); }
5175
5179 bool set_glitter_strength(float val, double time = TiMe::Default()) { return setValue("glitter_strength", val, time); }
5183 float get_glitter_strength(double time = TiMe::Default()) const { return getFloat("glitter_strength", time); }
5184
5188 bool set_glitter_size(float val, double time = TiMe::Default()) { return setValue("glitter_size", val, time); }
5192 float get_glitter_size(double time = TiMe::Default()) const { return getFloat("glitter_size", time); }
5193
5197 bool set_glint_scale(float val, double time = TiMe::Default()) { return setValue("glint_scale", val, time); }
5201 float get_glint_scale(double time = TiMe::Default()) const { return getFloat("glint_scale", time); }
5202
5206 bool set_random_melanin(float val, double time = TiMe::Default()) { return setValue("random_melanin", val, time); }
5210 float get_random_melanin(double time = TiMe::Default()) const { return getFloat("random_melanin", time); }
5211
5215 bool set_random_dye_hue(float val, double time = TiMe::Default()) { return setValue("random_dye_hue", val, time); }
5219 float get_random_dye_hue(double time = TiMe::Default()) const { return getFloat("random_dye_hue", time); }
5220
5224 bool set_random_dye_saturation(float val, double time = TiMe::Default()) { return setValue("random_dye_saturation", val, time); }
5228 float get_random_dye_saturation(double time = TiMe::Default()) const { return getFloat("random_dye_saturation", time); }
5229
5233 bool set_random_dye_value(float val, double time = TiMe::Default()) { return setValue("random_dye_value", val, time); }
5237 float get_random_dye_value(double time = TiMe::Default()) const { return getFloat("random_dye_value", time); }
5238
5242 bool set_gray_hair_density(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gray_hair_density", texturefloat, time); }
5246 bool set_gray_hair_density(float texturefloat, double time = TiMe::Default()) { return setValue("gray_hair_density", texturefloat, time); }
5250 Value get_gray_hair_density(double time = TiMe::Default()) const { return getValue("gray_hair_density", time); }
5251
5255 bool set_random_glossiness(float val, double time = TiMe::Default()) { return setValue("random_glossiness", val, time); }
5259 float get_random_glossiness(double time = TiMe::Default()) const { return getFloat("random_glossiness", time); }
5260
5264 bool set_random_softness(float val, double time = TiMe::Default()) { return setValue("random_softness", val, time); }
5268 float get_random_softness(double time = TiMe::Default()) const { return getFloat("random_softness", time); }
5269
5273 bool set_random_highlight_shift(float val, double time = TiMe::Default()) { return setValue("random_highlight_shift", val, time); }
5277 float get_random_highlight_shift(double time = TiMe::Default()) const { return getFloat("random_highlight_shift", time); }
5278
5282 bool set_random_ior(float val, double time = TiMe::Default()) { return setValue("random_ior", val, time); }
5286 float get_random_ior(double time = TiMe::Default()) const { return getFloat("random_ior", time); }
5287
5291 bool set_random_tangent(float val, double time = TiMe::Default()) { return setValue("random_tangent", val, time); }
5295 float get_random_tangent(double time = TiMe::Default()) const { return getFloat("random_tangent", time); }
5296
5300 bool set_primary_tint(const PluginRef& texture, double time = TiMe::Default()) { return setValue("primary_tint", texture, time); }
5304 bool set_primary_tint(const AColor& texture, double time = TiMe::Default()) { return setValue("primary_tint", texture, time); }
5308 Value get_primary_tint(double time = TiMe::Default()) const { return getValue("primary_tint", time); }
5309
5313 bool set_secondary_tint(const PluginRef& texture, double time = TiMe::Default()) { return setValue("secondary_tint", texture, time); }
5317 bool set_secondary_tint(const AColor& texture, double time = TiMe::Default()) { return setValue("secondary_tint", texture, time); }
5321 Value get_secondary_tint(double time = TiMe::Default()) const { return getValue("secondary_tint", time); }
5322
5326 bool set_transmission_tint(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transmission_tint", texture, time); }
5330 bool set_transmission_tint(const AColor& texture, double time = TiMe::Default()) { return setValue("transmission_tint", texture, time); }
5334 Value get_transmission_tint(double time = TiMe::Default()) const { return getValue("transmission_tint", time); }
5335
5339 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
5343 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
5344
5348 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
5352 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
5353
5357 bool set_compensate_energy(bool val, double time = TiMe::Default()) { return setValue("compensate_energy", val, time); }
5361 bool get_compensate_energy(double time = TiMe::Default()) const { return getBool("compensate_energy", time); }
5362};
5363
5365class BRDFLayered : public Plugin {
5366public:
5368 static constexpr const PluginTypeId getTypeId() { return 0x7782CC5F; }
5370 static constexpr const char* getType() { return "BRDFLayered"; }
5371
5372 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5373
5376 bool set_brdfs(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("brdfs", pluginList, time); }
5377 bool set_brdfs(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("brdfs", plugins, count, time); }
5378 template<size_t count> bool set_brdfs(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("brdfs", plugins, count, time); }
5381 PluginList get_brdfs(double time = TiMe::Default()) const { return getPluginList("brdfs", time); }
5382
5385 bool set_weights(const ValueList& textureList, double time = TiMe::Default()) { return setValue("weights", textureList, time); }
5386 bool set_weights(ValueList&& textureList, double time = TiMe::Default()) { return setValue("weights", std::move(textureList), time); }
5387 bool set_weights(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("weights", textures, count, time); }
5388 template<size_t count> bool set_weights(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("weights", textures, count, time); }
5389 template<size_t count> bool set_weights(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("weights", textures, count, time); }
5392 ValueList get_weights(double time = TiMe::Default()) const { return getValueList("weights", time); }
5393
5397 bool set_opacities(const FloatList& floatList, double time = TiMe::Default()) { return setValue("opacities", floatList, time); }
5398 bool set_opacities(FloatList&& floatList, double time = TiMe::Default()) { return setValue("opacities", std::move(floatList), time); }
5399 bool set_opacities(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("opacities", floats, count, time); }
5400 template<size_t count> bool set_opacities(const float (&floats)[count], double time = TiMe::Default()) { return setArray("opacities", floats, count, time); }
5404 FloatList get_opacities(double time = TiMe::Default()) const { return getFloatList("opacities", time); }
5405
5409 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
5413 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
5414
5417 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
5420 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
5423 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
5424
5428 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
5432 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
5433
5437 bool set_additive_mode(int val, double time = TiMe::Default()) { return setValue("additive_mode", val, time); }
5441 int get_additive_mode(double time = TiMe::Default()) const { return getInt("additive_mode", time); }
5442
5445 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
5446 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
5447 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
5450 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
5451};
5452
5454class BRDFLight : public Plugin {
5455public:
5457 static constexpr const PluginTypeId getTypeId() { return 0x77836E15; }
5459 static constexpr const char* getType() { return "BRDFLight"; }
5460
5461 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5462
5466 bool set_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
5470 bool set_color(const AColor& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
5474 Value get_color(double time = TiMe::Default()) const { return getValue("color", time); }
5475
5479 bool set_colorMultiplier(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("colorMultiplier", texturefloat, time); }
5483 bool set_colorMultiplier(float texturefloat, double time = TiMe::Default()) { return setValue("colorMultiplier", texturefloat, time); }
5487 Value get_colorMultiplier(double time = TiMe::Default()) const { return getValue("colorMultiplier", time); }
5488
5492 bool set_transparency(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency", texture, time); }
5496 bool set_transparency(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency", texture, time); }
5500 Value get_transparency(double time = TiMe::Default()) const { return getValue("transparency", time); }
5501
5505 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
5509 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
5510
5514 bool set_emitOnBackSide(bool val, double time = TiMe::Default()) { return setValue("emitOnBackSide", val, time); }
5518 bool get_emitOnBackSide(double time = TiMe::Default()) const { return getBool("emitOnBackSide", time); }
5519
5522 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
5523 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
5524 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
5527 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
5528
5532 bool set_compensateExposure(bool val, double time = TiMe::Default()) { return setValue("compensateExposure", val, time); }
5536 bool get_compensateExposure(double time = TiMe::Default()) const { return getBool("compensateExposure", time); }
5537
5541 bool set_multiplyByOpacity(bool val, double time = TiMe::Default()) { return setValue("multiplyByOpacity", val, time); }
5545 bool get_multiplyByOpacity(double time = TiMe::Default()) const { return getBool("multiplyByOpacity", time); }
5546
5550 bool set_affect_gi(bool val, double time = TiMe::Default()) { return setValue("affect_gi", val, time); }
5554 bool get_affect_gi(double time = TiMe::Default()) const { return getBool("affect_gi", time); }
5555
5559 bool set_transparency_invert(bool val, double time = TiMe::Default()) { return setValue("transparency_invert", val, time); }
5563 bool get_transparency_invert(double time = TiMe::Default()) const { return getBool("transparency_invert", time); }
5564};
5565
5567class BRDFMirror : public Plugin {
5568public:
5570 static constexpr const PluginTypeId getTypeId() { return 0x77742B0E; }
5572 static constexpr const char* getType() { return "BRDFMirror"; }
5573
5574 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5575
5579 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
5583 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
5584
5587 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
5590 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
5593 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
5594
5598 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
5602 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
5603
5607 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
5611 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
5612
5615 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
5618 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
5621 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
5622
5626 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
5630 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
5631
5635 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
5639 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
5640
5644 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
5648 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
5649
5653 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
5657 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
5658
5662 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
5666 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
5667
5671 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
5675 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
5676
5680 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
5684 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
5688 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
5689
5693 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
5697 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
5698
5702 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
5706 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
5707
5711 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
5715 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
5716};
5717
5719class BRDFModoUnity : public Plugin {
5720public:
5722 static constexpr const PluginTypeId getTypeId() { return 0x782A5636; }
5724 static constexpr const char* getType() { return "BRDFModoUnity"; }
5725
5726 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5727
5730 bool set_albedo_mult(const Color& color, double time = TiMe::Default()) { return setValue("albedo_mult", color, time); }
5733 Color get_albedo_mult(double time = TiMe::Default()) const { return getColor("albedo_mult", time); }
5734
5738 bool set_albedo(const PluginRef& texture, double time = TiMe::Default()) { return setValue("albedo", texture, time); }
5742 bool set_albedo(const AColor& texture, double time = TiMe::Default()) { return setValue("albedo", texture, time); }
5746 Value get_albedo(double time = TiMe::Default()) const { return getValue("albedo", time); }
5747
5751 bool set_metallic(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("metallic", texturefloat, time); }
5755 bool set_metallic(float texturefloat, double time = TiMe::Default()) { return setValue("metallic", texturefloat, time); }
5759 Value get_metallic(double time = TiMe::Default()) const { return getValue("metallic", time); }
5760
5764 bool set_smoothness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("smoothness", texturefloat, time); }
5768 bool set_smoothness(float texturefloat, double time = TiMe::Default()) { return setValue("smoothness", texturefloat, time); }
5772 Value get_smoothness(double time = TiMe::Default()) const { return getValue("smoothness", time); }
5773
5776 bool set_emissive_mult(const Color& color, double time = TiMe::Default()) { return setValue("emissive_mult", color, time); }
5779 Color get_emissive_mult(double time = TiMe::Default()) const { return getColor("emissive_mult", time); }
5780
5784 bool set_emissive(const PluginRef& texture, double time = TiMe::Default()) { return setValue("emissive", texture, time); }
5788 bool set_emissive(const AColor& texture, double time = TiMe::Default()) { return setValue("emissive", texture, time); }
5792 Value get_emissive(double time = TiMe::Default()) const { return getValue("emissive", time); }
5793
5797 bool set_emissivelevel(float val, double time = TiMe::Default()) { return setValue("emissivelevel", val, time); }
5801 float get_emissivelevel(double time = TiMe::Default()) const { return getFloat("emissivelevel", time); }
5802
5806 bool set_fresrel0(float val, double time = TiMe::Default()) { return setValue("fresrel0", val, time); }
5810 float get_fresrel0(double time = TiMe::Default()) const { return getFloat("fresrel0", time); }
5811
5815 bool set_reflRays(int val, double time = TiMe::Default()) { return setValue("reflRays", val, time); }
5819 int get_reflRays(double time = TiMe::Default()) const { return getInt("reflRays", time); }
5820
5823 bool set_ambient_occlusion_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ambient_occlusion_map", texture, time); }
5826 bool set_ambient_occlusion_map(const AColor& texture, double time = TiMe::Default()) { return setValue("ambient_occlusion_map", texture, time); }
5829 Value get_ambient_occlusion_map(double time = TiMe::Default()) const { return getValue("ambient_occlusion_map", time); }
5830};
5831
5833class BRDFModoUnreal : public Plugin {
5834public:
5836 static constexpr const PluginTypeId getTypeId() { return 0x782A5635; }
5838 static constexpr const char* getType() { return "BRDFModoUnreal"; }
5839
5840 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5841
5845 bool set_base(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base", texture, time); }
5849 bool set_base(const AColor& texture, double time = TiMe::Default()) { return setValue("base", texture, time); }
5853 Value get_base(double time = TiMe::Default()) const { return getValue("base", time); }
5854
5858 bool set_metallic(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("metallic", texturefloat, time); }
5862 bool set_metallic(float texturefloat, double time = TiMe::Default()) { return setValue("metallic", texturefloat, time); }
5866 Value get_metallic(double time = TiMe::Default()) const { return getValue("metallic", time); }
5867
5871 bool set_specular(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular", texturefloat, time); }
5875 bool set_specular(float texturefloat, double time = TiMe::Default()) { return setValue("specular", texturefloat, time); }
5879 Value get_specular(double time = TiMe::Default()) const { return getValue("specular", time); }
5880
5884 bool set_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
5888 bool set_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
5892 Value get_roughness(double time = TiMe::Default()) const { return getValue("roughness", time); }
5893
5897 bool set_emissive(const PluginRef& texture, double time = TiMe::Default()) { return setValue("emissive", texture, time); }
5901 bool set_emissive(const AColor& texture, double time = TiMe::Default()) { return setValue("emissive", texture, time); }
5905 Value get_emissive(double time = TiMe::Default()) const { return getValue("emissive", time); }
5906
5910 bool set_opacityUE(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacityUE", texturefloat, time); }
5914 bool set_opacityUE(float texturefloat, double time = TiMe::Default()) { return setValue("opacityUE", texturefloat, time); }
5918 Value get_opacityUE(double time = TiMe::Default()) const { return getValue("opacityUE", time); }
5919
5923 bool set_reflRays(int val, double time = TiMe::Default()) { return setValue("reflRays", val, time); }
5927 int get_reflRays(double time = TiMe::Default()) const { return getInt("reflRays", time); }
5928
5931 bool set_ambient_occlusion_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ambient_occlusion_map", texture, time); }
5934 bool set_ambient_occlusion_map(const AColor& texture, double time = TiMe::Default()) { return setValue("ambient_occlusion_map", texture, time); }
5937 Value get_ambient_occlusion_map(double time = TiMe::Default()) const { return getValue("ambient_occlusion_map", time); }
5938};
5939
5941class BRDFMultiBump : public Plugin {
5942public:
5944 static constexpr const PluginTypeId getTypeId() { return 0x77FDA62E; }
5946 static constexpr const char* getType() { return "BRDFMultiBump"; }
5947
5948 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
5949
5951 bool set_base_brdf(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_brdf", plugin, time); }
5953 PluginRef get_base_brdf(double time = TiMe::Default()) const { return getPlugin("base_brdf", time); }
5954
5956 bool set_bump_tex_0(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_tex_0", texture, time); }
5958 bool set_bump_tex_0(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_tex_0", texture, time); }
5960 Value get_bump_tex_0(double time = TiMe::Default()) const { return getValue("bump_tex_0", time); }
5961
5963 bool set_bump_mult_0(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_0", texturefloat, time); }
5965 bool set_bump_mult_0(float texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_0", texturefloat, time); }
5967 Value get_bump_mult_0(double time = TiMe::Default()) const { return getValue("bump_mult_0", time); }
5968
5972 bool set_map_type_0(int val, double time = TiMe::Default()) { return setValue("map_type_0", val, time); }
5976 int get_map_type_0(double time = TiMe::Default()) const { return getInt("map_type_0", time); }
5977
5979 bool set_bump_tex_1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_tex_1", texture, time); }
5981 bool set_bump_tex_1(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_tex_1", texture, time); }
5983 Value get_bump_tex_1(double time = TiMe::Default()) const { return getValue("bump_tex_1", time); }
5984
5986 bool set_bump_mult_1(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_1", texturefloat, time); }
5988 bool set_bump_mult_1(float texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_1", texturefloat, time); }
5990 Value get_bump_mult_1(double time = TiMe::Default()) const { return getValue("bump_mult_1", time); }
5991
5995 bool set_map_type_1(int val, double time = TiMe::Default()) { return setValue("map_type_1", val, time); }
5999 int get_map_type_1(double time = TiMe::Default()) const { return getInt("map_type_1", time); }
6000
6002 bool set_bump_tex_2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_tex_2", texture, time); }
6004 bool set_bump_tex_2(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_tex_2", texture, time); }
6006 Value get_bump_tex_2(double time = TiMe::Default()) const { return getValue("bump_tex_2", time); }
6007
6009 bool set_bump_mult_2(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_2", texturefloat, time); }
6011 bool set_bump_mult_2(float texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_2", texturefloat, time); }
6013 Value get_bump_mult_2(double time = TiMe::Default()) const { return getValue("bump_mult_2", time); }
6014
6018 bool set_map_type_2(int val, double time = TiMe::Default()) { return setValue("map_type_2", val, time); }
6022 int get_map_type_2(double time = TiMe::Default()) const { return getInt("map_type_2", time); }
6023
6025 bool set_bump_tex_3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_tex_3", texture, time); }
6027 bool set_bump_tex_3(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_tex_3", texture, time); }
6029 Value get_bump_tex_3(double time = TiMe::Default()) const { return getValue("bump_tex_3", time); }
6030
6032 bool set_bump_mult_3(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_3", texturefloat, time); }
6034 bool set_bump_mult_3(float texturefloat, double time = TiMe::Default()) { return setValue("bump_mult_3", texturefloat, time); }
6036 Value get_bump_mult_3(double time = TiMe::Default()) const { return getValue("bump_mult_3", time); }
6037
6041 bool set_map_type_3(int val, double time = TiMe::Default()) { return setValue("map_type_3", val, time); }
6045 int get_map_type_3(double time = TiMe::Default()) const { return getInt("map_type_3", time); }
6046
6048 bool set_normal_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("normal_uvwgen", plugin, time); }
6050 PluginRef get_normal_uvwgen(double time = TiMe::Default()) const { return getPlugin("normal_uvwgen", time); }
6051};
6052
6054class BRDFPhong : public Plugin {
6055public:
6057 static constexpr const PluginTypeId getTypeId() { return 0x77742B2D; }
6059 static constexpr const char* getType() { return "BRDFPhong"; }
6060
6061 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
6062
6066 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
6070 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
6071
6074 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
6077 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
6080 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
6081
6085 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
6089 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
6090
6094 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
6098 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
6099
6102 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
6105 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
6108 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
6109
6113 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
6117 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
6118
6122 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
6126 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
6127
6131 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
6135 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
6136
6140 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
6144 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
6145
6149 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
6153 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
6154
6158 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
6162 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
6163
6167 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
6171 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
6175 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
6176
6180 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
6184 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
6185
6189 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
6193 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
6194
6198 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
6202 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
6203
6207 bool set_hilightGlossiness(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness", val, time); }
6211 float get_hilightGlossiness(double time = TiMe::Default()) const { return getFloat("hilightGlossiness", time); }
6212
6215 bool set_hilightGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
6218 bool set_hilightGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
6221 Value get_hilightGlossiness_tex(double time = TiMe::Default()) const { return getValue("hilightGlossiness_tex", time); }
6222
6226 bool set_hilightGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex_mult", val, time); }
6230 float get_hilightGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("hilightGlossiness_tex_mult", time); }
6231
6235 bool set_reflectionGlossiness(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness", val, time); }
6239 float get_reflectionGlossiness(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness", time); }
6240
6243 bool set_reflectionGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
6246 bool set_reflectionGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
6249 Value get_reflectionGlossiness_tex(double time = TiMe::Default()) const { return getValue("reflectionGlossiness_tex", time); }
6250
6254 bool set_reflectionGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex_mult", val, time); }
6258 float get_reflectionGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness_tex_mult", time); }
6259
6263 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
6267 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
6268
6272 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
6276 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
6277
6281 bool set_soften_edge(float val, double time = TiMe::Default()) { return setValue("soften_edge", val, time); }
6285 float get_soften_edge(double time = TiMe::Default()) const { return getFloat("soften_edge", time); }
6286
6290 bool set_interpolation_on(int val, double time = TiMe::Default()) { return setValue("interpolation_on", val, time); }
6294 int get_interpolation_on(double time = TiMe::Default()) const { return getInt("interpolation_on", time); }
6295
6299 bool set_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("imap_min_rate", val, time); }
6303 int get_imap_min_rate(double time = TiMe::Default()) const { return getInt("imap_min_rate", time); }
6304
6308 bool set_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("imap_max_rate", val, time); }
6312 int get_imap_max_rate(double time = TiMe::Default()) const { return getInt("imap_max_rate", time); }
6313
6317 bool set_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("imap_color_thresh", val, time); }
6321 float get_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("imap_color_thresh", time); }
6322
6326 bool set_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("imap_norm_thresh", val, time); }
6330 float get_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("imap_norm_thresh", time); }
6331
6335 bool set_imap_samples(int val, double time = TiMe::Default()) { return setValue("imap_samples", val, time); }
6339 int get_imap_samples(double time = TiMe::Default()) const { return getInt("imap_samples", time); }
6340};
6341
6343class BRDFSSS : public Plugin {
6344public:
6346 static constexpr const PluginTypeId getTypeId() { return 0x7791518D; }
6348 static constexpr const char* getType() { return "BRDFSSS"; }
6349
6350 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
6351
6355 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
6359 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
6360
6363 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
6366 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
6369 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
6370
6374 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
6378 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
6379
6383 bool set_translucency(const Color& color, double time = TiMe::Default()) { return setValue("translucency", color, time); }
6387 Color get_translucency(double time = TiMe::Default()) const { return getColor("translucency", time); }
6388
6391 bool set_translucency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("translucency_tex", texture, time); }
6394 bool set_translucency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("translucency_tex", texture, time); }
6397 Value get_translucency_tex(double time = TiMe::Default()) const { return getValue("translucency_tex", time); }
6398
6402 bool set_translucency_tex_mult(float val, double time = TiMe::Default()) { return setValue("translucency_tex_mult", val, time); }
6406 float get_translucency_tex_mult(double time = TiMe::Default()) const { return getFloat("translucency_tex_mult", time); }
6407
6411 bool set_glossiness(float val, double time = TiMe::Default()) { return setValue("glossiness", val, time); }
6415 float get_glossiness(double time = TiMe::Default()) const { return getFloat("glossiness", time); }
6416
6419 bool set_glossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("glossiness_tex", texturefloat, time); }
6422 bool set_glossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("glossiness_tex", texturefloat, time); }
6425 Value get_glossiness_tex(double time = TiMe::Default()) const { return getValue("glossiness_tex", time); }
6426
6430 bool set_glossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("glossiness_tex_mult", val, time); }
6434 float get_glossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("glossiness_tex_mult", time); }
6435
6439 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
6443 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
6444
6447 bool set_thickness(float val, double time = TiMe::Default()) { return setValue("thickness", val, time); }
6450 float get_thickness(double time = TiMe::Default()) const { return getFloat("thickness", time); }
6451
6454 bool set_scatter_coeff(float val, double time = TiMe::Default()) { return setValue("scatter_coeff", val, time); }
6457 float get_scatter_coeff(double time = TiMe::Default()) const { return getFloat("scatter_coeff", time); }
6458
6461 bool set_scatter_direction(float val, double time = TiMe::Default()) { return setValue("scatter_direction", val, time); }
6464 float get_scatter_direction(double time = TiMe::Default()) const { return getFloat("scatter_direction", time); }
6465};
6466
6468class BRDFSSS2 : public Plugin {
6469public:
6471 static constexpr const PluginTypeId getTypeId() { return 0x77B12D69; }
6473 static constexpr const char* getType() { return "BRDFSSS2"; }
6474
6475 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
6476
6480 bool set_prepass_rate(int val, double time = TiMe::Default()) { return setValue("prepass_rate", val, time); }
6484 int get_prepass_rate(double time = TiMe::Default()) const { return getInt("prepass_rate", time); }
6485
6489 bool set_interpolation_accuracy(float val, double time = TiMe::Default()) { return setValue("interpolation_accuracy", val, time); }
6493 float get_interpolation_accuracy(double time = TiMe::Default()) const { return getFloat("interpolation_accuracy", time); }
6494
6498 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
6502 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
6503
6507 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
6511 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
6512
6516 bool set_diffuse_reflectance(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_reflectance", texture, time); }
6520 bool set_diffuse_reflectance(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_reflectance", texture, time); }
6524 Value get_diffuse_reflectance(double time = TiMe::Default()) const { return getValue("diffuse_reflectance", time); }
6525
6529 bool set_scatter_radius(const PluginRef& texture, double time = TiMe::Default()) { return setValue("scatter_radius", texture, time); }
6533 bool set_scatter_radius(const AColor& texture, double time = TiMe::Default()) { return setValue("scatter_radius", texture, time); }
6537 Value get_scatter_radius(double time = TiMe::Default()) const { return getValue("scatter_radius", time); }
6538
6542 bool set_scatter_radius_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("scatter_radius_mult", texturefloat, time); }
6546 bool set_scatter_radius_mult(float texturefloat, double time = TiMe::Default()) { return setValue("scatter_radius_mult", texturefloat, time); }
6550 Value get_scatter_radius_mult(double time = TiMe::Default()) const { return getValue("scatter_radius_mult", time); }
6551
6555 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
6559 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
6560
6564 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
6568 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
6569
6573 bool set_single_scatter(int val, double time = TiMe::Default()) { return setValue("single_scatter", val, time); }
6577 int get_single_scatter(double time = TiMe::Default()) const { return getInt("single_scatter", time); }
6578
6582 bool set_front_scatter(bool val, double time = TiMe::Default()) { return setValue("front_scatter", val, time); }
6586 bool get_front_scatter(double time = TiMe::Default()) const { return getBool("front_scatter", time); }
6587
6591 bool set_back_scatter(bool val, double time = TiMe::Default()) { return setValue("back_scatter", val, time); }
6595 bool get_back_scatter(double time = TiMe::Default()) const { return getBool("back_scatter", time); }
6596
6600 bool set_scatter_gi(bool val, double time = TiMe::Default()) { return setValue("scatter_gi", val, time); }
6604 bool get_scatter_gi(double time = TiMe::Default()) const { return getBool("scatter_gi", time); }
6605
6609 bool set_prepass_lod_threshold(float val, double time = TiMe::Default()) { return setValue("prepass_lod_threshold", val, time); }
6613 float get_prepass_lod_threshold(double time = TiMe::Default()) const { return getFloat("prepass_lod_threshold", time); }
6614
6618 bool set_prepass_blur(float val, double time = TiMe::Default()) { return setValue("prepass_blur", val, time); }
6622 float get_prepass_blur(double time = TiMe::Default()) const { return getFloat("prepass_blur", time); }
6623
6627 bool set_prepass_id(int val, double time = TiMe::Default()) { return setValue("prepass_id", val, time); }
6631 int get_prepass_id(double time = TiMe::Default()) const { return getInt("prepass_id", time); }
6632
6636 bool set_linear_workflow(bool val, double time = TiMe::Default()) { return setValue("linear_workflow", val, time); }
6640 bool get_linear_workflow(double time = TiMe::Default()) const { return getBool("linear_workflow", time); }
6641
6645 bool set_color_mode(int val, double time = TiMe::Default()) { return setValue("color_mode", val, time); }
6649 int get_color_mode(double time = TiMe::Default()) const { return getInt("color_mode", time); }
6650
6654 bool set_geometry_based_sampling(int val, double time = TiMe::Default()) { return setValue("geometry_based_sampling", val, time); }
6658 int get_geometry_based_sampling(double time = TiMe::Default()) const { return getInt("geometry_based_sampling", time); }
6659
6663 bool set_samples_per_unit_area(float val, double time = TiMe::Default()) { return setValue("samples_per_unit_area", val, time); }
6667 float get_samples_per_unit_area(double time = TiMe::Default()) const { return getFloat("samples_per_unit_area", time); }
6668
6672 bool set_surface_offset(float val, double time = TiMe::Default()) { return setValue("surface_offset", val, time); }
6676 float get_surface_offset(double time = TiMe::Default()) const { return getFloat("surface_offset", time); }
6677
6681 bool set_preview_samples(int val, double time = TiMe::Default()) { return setValue("preview_samples", val, time); }
6685 int get_preview_samples(double time = TiMe::Default()) const { return getInt("preview_samples", time); }
6686
6690 bool set_max_distance(float val, double time = TiMe::Default()) { return setValue("max_distance", val, time); }
6694 float get_max_distance(double time = TiMe::Default()) const { return getFloat("max_distance", time); }
6695
6699 bool set_background_color(const Color& color, double time = TiMe::Default()) { return setValue("background_color", color, time); }
6703 Color get_background_color(double time = TiMe::Default()) const { return getColor("background_color", time); }
6704
6708 bool set_samples_color(const Color& color, double time = TiMe::Default()) { return setValue("samples_color", color, time); }
6712 Color get_samples_color(double time = TiMe::Default()) const { return getColor("samples_color", time); }
6713};
6714
6716class BRDFSSS2Complex : public Plugin {
6717public:
6719 static constexpr const PluginTypeId getTypeId() { return 0x77BFDA0D; }
6721 static constexpr const char* getType() { return "BRDFSSS2Complex"; }
6722
6723 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
6724
6728 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
6732 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
6733
6737 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
6741 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
6742
6746 bool set_opacity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
6750 bool set_opacity(float texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
6754 Value get_opacity(double time = TiMe::Default()) const { return getValue("opacity", time); }
6755
6759 bool set_overall_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("overall_color", texture, time); }
6763 bool set_overall_color(const AColor& texture, double time = TiMe::Default()) { return setValue("overall_color", texture, time); }
6767 Value get_overall_color(double time = TiMe::Default()) const { return getValue("overall_color", time); }
6768
6772 bool set_diffuse_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
6776 bool set_diffuse_color(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
6780 Value get_diffuse_color(double time = TiMe::Default()) const { return getValue("diffuse_color", time); }
6781
6785 bool set_diffuse_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
6789 bool set_diffuse_amount(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
6793 Value get_diffuse_amount(double time = TiMe::Default()) const { return getValue("diffuse_amount", time); }
6794
6798 bool set_sub_surface_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sub_surface_color", texture, time); }
6802 bool set_sub_surface_color(const AColor& texture, double time = TiMe::Default()) { return setValue("sub_surface_color", texture, time); }
6806 Value get_sub_surface_color(double time = TiMe::Default()) const { return getValue("sub_surface_color", time); }
6807
6811 bool set_scatter_radius(const PluginRef& texture, double time = TiMe::Default()) { return setValue("scatter_radius", texture, time); }
6815 bool set_scatter_radius(const AColor& texture, double time = TiMe::Default()) { return setValue("scatter_radius", texture, time); }
6819 Value get_scatter_radius(double time = TiMe::Default()) const { return getValue("scatter_radius", time); }
6820
6824 bool set_scatter_radius_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("scatter_radius_mult", texturefloat, time); }
6828 bool set_scatter_radius_mult(float texturefloat, double time = TiMe::Default()) { return setValue("scatter_radius_mult", texturefloat, time); }
6832 Value get_scatter_radius_mult(double time = TiMe::Default()) const { return getValue("scatter_radius_mult", time); }
6833
6837 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
6841 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
6842
6846 bool set_color_mode(int val, double time = TiMe::Default()) { return setValue("color_mode", val, time); }
6850 int get_color_mode(double time = TiMe::Default()) const { return getInt("color_mode", time); }
6851
6855 bool set_specular_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("specular_color", texture, time); }
6859 bool set_specular_color(const AColor& texture, double time = TiMe::Default()) { return setValue("specular_color", texture, time); }
6863 Value get_specular_color(double time = TiMe::Default()) const { return getValue("specular_color", time); }
6864
6868 bool set_specular_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular_amount", texturefloat, time); }
6872 bool set_specular_amount(float texturefloat, double time = TiMe::Default()) { return setValue("specular_amount", texturefloat, time); }
6876 Value get_specular_amount(double time = TiMe::Default()) const { return getValue("specular_amount", time); }
6877
6881 bool set_specular_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specular_glossiness", texturefloat, time); }
6885 bool set_specular_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("specular_glossiness", texturefloat, time); }
6889 Value get_specular_glossiness(double time = TiMe::Default()) const { return getValue("specular_glossiness", time); }
6890
6894 bool set_specular_subdivs(int val, double time = TiMe::Default()) { return setValue("specular_subdivs", val, time); }
6898 int get_specular_subdivs(double time = TiMe::Default()) const { return getInt("specular_subdivs", time); }
6899
6903 bool set_cutoff_threshold(float val, double time = TiMe::Default()) { return setValue("cutoff_threshold", val, time); }
6907 float get_cutoff_threshold(double time = TiMe::Default()) const { return getFloat("cutoff_threshold", time); }
6908
6912 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
6916 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
6917
6921 bool set_reflection_depth(int val, double time = TiMe::Default()) { return setValue("reflection_depth", val, time); }
6925 int get_reflection_depth(double time = TiMe::Default()) const { return getInt("reflection_depth", time); }
6926
6930 bool set_geometry_based_sampling(int val, double time = TiMe::Default()) { return setValue("geometry_based_sampling", val, time); }
6934 int get_geometry_based_sampling(double time = TiMe::Default()) const { return getInt("geometry_based_sampling", time); }
6935
6939 bool set_prepass_rate(int val, double time = TiMe::Default()) { return setValue("prepass_rate", val, time); }
6943 int get_prepass_rate(double time = TiMe::Default()) const { return getInt("prepass_rate", time); }
6944
6948 bool set_prepass_id(int val, double time = TiMe::Default()) { return setValue("prepass_id", val, time); }
6952 int get_prepass_id(double time = TiMe::Default()) const { return getInt("prepass_id", time); }
6953
6957 bool set_prepass_mode(int val, double time = TiMe::Default()) { return setValue("prepass_mode", val, time); }
6961 int get_prepass_mode(double time = TiMe::Default()) const { return getInt("prepass_mode", time); }
6962
6966 bool set_prepass_fileName(const char* str, double time = TiMe::Default()) { return setValue("prepass_fileName", str, time); }
6970 bool set_prepass_fileName(const std::string& str, double time = TiMe::Default()) { return setValue("prepass_fileName", str, time); }
6974 std::string get_prepass_fileName(double time = TiMe::Default()) const { return getString("prepass_fileName", time); }
6975
6979 bool set_auto_density(bool val, double time = TiMe::Default()) { return setValue("auto_density", val, time); }
6983 bool get_auto_density(double time = TiMe::Default()) const { return getBool("auto_density", time); }
6984
6988 bool set_samples_per_unit_area(float val, double time = TiMe::Default()) { return setValue("samples_per_unit_area", val, time); }
6992 float get_samples_per_unit_area(double time = TiMe::Default()) const { return getFloat("samples_per_unit_area", time); }
6993
6997 bool set_surface_offset(float val, double time = TiMe::Default()) { return setValue("surface_offset", val, time); }
7001 float get_surface_offset(double time = TiMe::Default()) const { return getFloat("surface_offset", time); }
7002
7006 bool set_preview_samples(bool val, double time = TiMe::Default()) { return setValue("preview_samples", val, time); }
7010 bool get_preview_samples(double time = TiMe::Default()) const { return getBool("preview_samples", time); }
7011
7015 bool set_max_distance(float val, double time = TiMe::Default()) { return setValue("max_distance", val, time); }
7019 float get_max_distance(double time = TiMe::Default()) const { return getFloat("max_distance", time); }
7020
7024 bool set_background_color(const Color& color, double time = TiMe::Default()) { return setValue("background_color", color, time); }
7028 Color get_background_color(double time = TiMe::Default()) const { return getColor("background_color", time); }
7029
7033 bool set_samples_color(const Color& color, double time = TiMe::Default()) { return setValue("samples_color", color, time); }
7037 Color get_samples_color(double time = TiMe::Default()) const { return getColor("samples_color", time); }
7038
7042 bool set_single_scatter(int val, double time = TiMe::Default()) { return setValue("single_scatter", val, time); }
7046 int get_single_scatter(double time = TiMe::Default()) const { return getInt("single_scatter", time); }
7047
7051 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
7055 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
7056
7060 bool set_refraction_depth(int val, double time = TiMe::Default()) { return setValue("refraction_depth", val, time); }
7064 int get_refraction_depth(double time = TiMe::Default()) const { return getInt("refraction_depth", time); }
7065
7069 bool set_front_scatter(bool val, double time = TiMe::Default()) { return setValue("front_scatter", val, time); }
7073 bool get_front_scatter(double time = TiMe::Default()) const { return getBool("front_scatter", time); }
7074
7078 bool set_back_scatter(bool val, double time = TiMe::Default()) { return setValue("back_scatter", val, time); }
7082 bool get_back_scatter(double time = TiMe::Default()) const { return getBool("back_scatter", time); }
7083
7087 bool set_scatter_gi(bool val, double time = TiMe::Default()) { return setValue("scatter_gi", val, time); }
7091 bool get_scatter_gi(double time = TiMe::Default()) const { return getBool("scatter_gi", time); }
7092
7096 bool set_interpolation_accuracy(float val, double time = TiMe::Default()) { return setValue("interpolation_accuracy", val, time); }
7100 float get_interpolation_accuracy(double time = TiMe::Default()) const { return getFloat("interpolation_accuracy", time); }
7101
7105 bool set_prepass_blur(float val, double time = TiMe::Default()) { return setValue("prepass_blur", val, time); }
7109 float get_prepass_blur(double time = TiMe::Default()) const { return getFloat("prepass_blur", time); }
7110
7114 bool set_consider_all_objects(bool val, double time = TiMe::Default()) { return setValue("consider_all_objects", val, time); }
7118 bool get_consider_all_objects(double time = TiMe::Default()) const { return getBool("consider_all_objects", time); }
7119
7122 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
7123 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
7124 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
7127 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
7128
7132 bool set_linear_workflow(bool val, double time = TiMe::Default()) { return setValue("linear_workflow", val, time); }
7136 bool get_linear_workflow(double time = TiMe::Default()) const { return getBool("linear_workflow", time); }
7137};
7138
7140class BRDFSampled : public Plugin {
7141public:
7143 static constexpr const PluginTypeId getTypeId() { return 0x77B094AD; }
7145 static constexpr const char* getType() { return "BRDFSampled"; }
7146
7147 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
7148
7152 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
7156 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
7157
7160 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
7163 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
7166 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
7167
7171 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
7175 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
7176
7180 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
7184 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
7185
7188 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
7191 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
7194 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
7195
7199 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
7203 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
7204
7207 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
7210 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
7211
7215 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
7219 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
7220
7223 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
7226 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
7227
7229 bool set_brdf_bitmap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("brdf_bitmap", plugin, time); }
7231 PluginRef get_brdf_bitmap(double time = TiMe::Default()) const { return getPlugin("brdf_bitmap", time); }
7232
7235 bool set_brdf_nsamples_d_theta(int val, double time = TiMe::Default()) { return setValue("brdf_nsamples_d_theta", val, time); }
7238 int get_brdf_nsamples_d_theta(double time = TiMe::Default()) const { return getInt("brdf_nsamples_d_theta", time); }
7239
7242 bool set_brdf_nsamples_d_phi(int val, double time = TiMe::Default()) { return setValue("brdf_nsamples_d_phi", val, time); }
7245 int get_brdf_nsamples_d_phi(double time = TiMe::Default()) const { return getInt("brdf_nsamples_d_phi", time); }
7246
7249 bool set_brdf_importance_sampling_on(bool val, double time = TiMe::Default()) { return setValue("brdf_importance_sampling_on", val, time); }
7252 bool get_brdf_importance_sampling_on(double time = TiMe::Default()) const { return getBool("brdf_importance_sampling_on", time); }
7253
7256 bool set_brdf_importance_sampling_resolution(int val, double time = TiMe::Default()) { return setValue("brdf_importance_sampling_resolution", val, time); }
7259 int get_brdf_importance_sampling_resolution(double time = TiMe::Default()) const { return getInt("brdf_importance_sampling_resolution", time); }
7260
7263 bool set_brdf_importance_sampling_view_terms(int val, double time = TiMe::Default()) { return setValue("brdf_importance_sampling_view_terms", val, time); }
7266 int get_brdf_importance_sampling_view_terms(double time = TiMe::Default()) const { return getInt("brdf_importance_sampling_view_terms", time); }
7267
7270 bool set_brdf_importance_sampling_half_terms(int val, double time = TiMe::Default()) { return setValue("brdf_importance_sampling_half_terms", val, time); }
7273 int get_brdf_importance_sampling_half_terms(double time = TiMe::Default()) const { return getInt("brdf_importance_sampling_half_terms", time); }
7274};
7275
7277class BRDFScanned : public Plugin {
7278public:
7280 static constexpr const PluginTypeId getTypeId() { return 0x77EE6247; }
7282 static constexpr const char* getType() { return "BRDFScanned"; }
7283
7284 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
7285
7289 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
7293 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
7297 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
7298
7301 bool set_paintcolor(const PluginRef& texture, double time = TiMe::Default()) { return setValue("paintcolor", texture, time); }
7304 bool set_paintcolor(const AColor& texture, double time = TiMe::Default()) { return setValue("paintcolor", texture, time); }
7307 Value get_paintcolor(double time = TiMe::Default()) const { return getValue("paintcolor", time); }
7308
7311 bool set_filtercolor(const PluginRef& texture, double time = TiMe::Default()) { return setValue("filtercolor", texture, time); }
7314 bool set_filtercolor(const AColor& texture, double time = TiMe::Default()) { return setValue("filtercolor", texture, time); }
7317 Value get_filtercolor(double time = TiMe::Default()) const { return getValue("filtercolor", time); }
7318
7321 bool set_ccmult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ccmult", texture, time); }
7324 bool set_ccmult(const AColor& texture, double time = TiMe::Default()) { return setValue("ccmult", texture, time); }
7327 Value get_ccmult(double time = TiMe::Default()) const { return getValue("ccmult", time); }
7328
7331 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
7334 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
7335
7339 bool set_tiling_factor(float val, double time = TiMe::Default()) { return setValue("tiling_factor", val, time); }
7343 float get_tiling_factor(double time = TiMe::Default()) const { return getFloat("tiling_factor", time); }
7344
7348 bool set_param_block(const IntList& intList, double time = TiMe::Default()) { return setValue("param_block", intList, time); }
7349 bool set_param_block(IntList&& intList, double time = TiMe::Default()) { return setValue("param_block", std::move(intList), time); }
7350 bool set_param_block(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("param_block", ints, count, time); }
7351 template<size_t count> bool set_param_block(const int (&ints)[count], double time = TiMe::Default()) { return setArray("param_block", ints, count, time); }
7355 IntList get_param_block(double time = TiMe::Default()) const { return getIntList("param_block", time); }
7356
7360 bool set_plain(int val, double time = TiMe::Default()) { return setValue("plain", val, time); }
7364 int get_plain(double time = TiMe::Default()) const { return getInt("plain", time); }
7365
7369 bool set_invgamma(float val, double time = TiMe::Default()) { return setValue("invgamma", val, time); }
7373 float get_invgamma(double time = TiMe::Default()) const { return getFloat("invgamma", time); }
7374
7378 bool set_saturation(float val, double time = TiMe::Default()) { return setValue("saturation", val, time); }
7382 float get_saturation(double time = TiMe::Default()) const { return getFloat("saturation", time); }
7383
7387 bool set_DepthMul(float val, double time = TiMe::Default()) { return setValue("DepthMul", val, time); }
7391 float get_DepthMul(double time = TiMe::Default()) const { return getFloat("DepthMul", time); }
7392
7396 bool set_filter(const Color& color, double time = TiMe::Default()) { return setValue("filter", color, time); }
7400 Color get_filter(double time = TiMe::Default()) const { return getColor("filter", time); }
7401
7405 bool set_uvtrans(const Transform& transform, double time = TiMe::Default()) { return setValue("uvtrans", transform, time); }
7409 Transform get_uvtrans(double time = TiMe::Default()) const { return getTransform("uvtrans", time); }
7410
7414 bool set_bumpmul(float val, double time = TiMe::Default()) { return setValue("bumpmul", val, time); }
7418 float get_bumpmul(double time = TiMe::Default()) const { return getFloat("bumpmul", time); }
7419
7423 bool set_bumpstart(float val, double time = TiMe::Default()) { return setValue("bumpstart", val, time); }
7427 float get_bumpstart(double time = TiMe::Default()) const { return getFloat("bumpstart", time); }
7428
7432 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
7436 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
7437
7441 bool set_mapChannel(int val, double time = TiMe::Default()) { return setValue("mapChannel", val, time); }
7445 int get_mapChannel(double time = TiMe::Default()) const { return getInt("mapChannel", time); }
7446
7450 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
7454 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
7455
7459 bool set_ccior(float val, double time = TiMe::Default()) { return setValue("ccior", val, time); }
7463 float get_ccior(double time = TiMe::Default()) const { return getFloat("ccior", time); }
7464
7468 bool set_cchlight(int val, double time = TiMe::Default()) { return setValue("cchlight", val, time); }
7472 int get_cchlight(double time = TiMe::Default()) const { return getInt("cchlight", time); }
7473
7477 bool set_ccbump(float val, double time = TiMe::Default()) { return setValue("ccbump", val, time); }
7481 float get_ccbump(double time = TiMe::Default()) const { return getFloat("ccbump", time); }
7482
7486 bool set_UnfRefl(int val, double time = TiMe::Default()) { return setValue("UnfRefl", val, time); }
7490 int get_UnfRefl(double time = TiMe::Default()) const { return getInt("UnfRefl", time); }
7491
7495 bool set_twoside(int val, double time = TiMe::Default()) { return setValue("twoside", val, time); }
7499 int get_twoside(double time = TiMe::Default()) const { return getInt("twoside", time); }
7500
7504 bool set_displace(int val, double time = TiMe::Default()) { return setValue("displace", val, time); }
7508 int get_displace(double time = TiMe::Default()) const { return getInt("displace", time); }
7509
7513 bool set_notransp(int val, double time = TiMe::Default()) { return setValue("notransp", val, time); }
7517 int get_notransp(double time = TiMe::Default()) const { return getInt("notransp", time); }
7518
7522 bool set_paintstrength(float val, double time = TiMe::Default()) { return setValue("paintstrength", val, time); }
7526 float get_paintstrength(double time = TiMe::Default()) const { return getFloat("paintstrength", time); }
7527
7531 bool set_fltstrength(float val, double time = TiMe::Default()) { return setValue("fltstrength", val, time); }
7535 float get_fltstrength(double time = TiMe::Default()) const { return getFloat("fltstrength", time); }
7536
7540 bool set_NoCachedGI(int val, double time = TiMe::Default()) { return setValue("NoCachedGI", val, time); }
7544 int get_NoCachedGI(double time = TiMe::Default()) const { return getInt("NoCachedGI", time); }
7545
7549 bool set_ccmetalrefl(float val, double time = TiMe::Default()) { return setValue("ccmetalrefl", val, time); }
7553 float get_ccmetalrefl(double time = TiMe::Default()) const { return getFloat("ccmetalrefl", time); }
7554
7558 bool set_ccmul(float val, double time = TiMe::Default()) { return setValue("ccmul", val, time); }
7562 float get_ccmul(double time = TiMe::Default()) const { return getFloat("ccmul", time); }
7563
7567 bool set_triplanar(int val, double time = TiMe::Default()) { return setValue("triplanar", val, time); }
7571 int get_triplanar(double time = TiMe::Default()) const { return getInt("triplanar", time); }
7572
7576 bool set_BWforGI(int val, double time = TiMe::Default()) { return setValue("BWforGI", val, time); }
7580 int get_BWforGI(double time = TiMe::Default()) const { return getInt("BWforGI", time); }
7581
7585 bool set_ccglossy(float val, double time = TiMe::Default()) { return setValue("ccglossy", val, time); }
7589 float get_ccglossy(double time = TiMe::Default()) const { return getFloat("ccglossy", time); }
7590
7594 bool set_ccglossyvar(float val, double time = TiMe::Default()) { return setValue("ccglossyvar", val, time); }
7598 float get_ccglossyvar(double time = TiMe::Default()) const { return getFloat("ccglossyvar", time); }
7599
7603 bool set_sssmul(float val, double time = TiMe::Default()) { return setValue("sssmul", val, time); }
7607 float get_sssmul(double time = TiMe::Default()) const { return getFloat("sssmul", time); }
7608
7612 bool set_uvflags(int val, double time = TiMe::Default()) { return setValue("uvflags", val, time); }
7616 int get_uvflags(double time = TiMe::Default()) const { return getInt("uvflags", time); }
7617
7621 bool set_usedmaps(int val, double time = TiMe::Default()) { return setValue("usedmaps", val, time); }
7625 int get_usedmaps(double time = TiMe::Default()) const { return getInt("usedmaps", time); }
7626};
7627
7630public:
7632 static constexpr const PluginTypeId getTypeId() { return 0x7857AF68; }
7634 static constexpr const char* getType() { return "BRDFScatterVolume"; }
7635
7636 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
7637
7641 bool set_overall_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("overall_color", texture, time); }
7645 bool set_overall_color(const AColor& texture, double time = TiMe::Default()) { return setValue("overall_color", texture, time); }
7649 Value get_overall_color(double time = TiMe::Default()) const { return getValue("overall_color", time); }
7650
7654 bool set_color_mode(int val, double time = TiMe::Default()) { return setValue("color_mode", val, time); }
7658 int get_color_mode(double time = TiMe::Default()) const { return getInt("color_mode", time); }
7659
7663 bool set_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
7667 bool set_color(const AColor& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
7671 Value get_color(double time = TiMe::Default()) const { return getValue("color", time); }
7672
7675 bool set_scatter_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("scatter_color", texture, time); }
7678 bool set_scatter_color(const AColor& texture, double time = TiMe::Default()) { return setValue("scatter_color", texture, time); }
7681 Value get_scatter_color(double time = TiMe::Default()) const { return getValue("scatter_color", time); }
7682
7686 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
7690 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
7691
7695 bool set_radius_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("radius_mult", texturefloat, time); }
7699 bool set_radius_mult(float texturefloat, double time = TiMe::Default()) { return setValue("radius_mult", texturefloat, time); }
7703 Value get_radius_mult(double time = TiMe::Default()) const { return getValue("radius_mult", time); }
7704
7708 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
7712 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
7713
7717 bool set_bounces(int val, double time = TiMe::Default()) { return setValue("bounces", val, time); }
7721 int get_bounces(double time = TiMe::Default()) const { return getInt("bounces", time); }
7722
7726 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
7730 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
7731
7735 bool set_light_multiplier(float val, double time = TiMe::Default()) { return setValue("light_multiplier", val, time); }
7739 float get_light_multiplier(double time = TiMe::Default()) const { return getFloat("light_multiplier", time); }
7740};
7741
7743class BRDFSkinComplex : public Plugin {
7744public:
7746 static constexpr const PluginTypeId getTypeId() { return 0x780B5FDC; }
7748 static constexpr const char* getType() { return "BRDFSkinComplex"; }
7749
7750 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
7751
7755 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
7759 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
7760
7764 bool set_max_sss_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("max_sss_amount", texturefloat, time); }
7768 bool set_max_sss_amount(float texturefloat, double time = TiMe::Default()) { return setValue("max_sss_amount", texturefloat, time); }
7772 Value get_max_sss_amount(double time = TiMe::Default()) const { return getValue("max_sss_amount", time); }
7773
7777 bool set_max_reflection_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("max_reflection_amount", texturefloat, time); }
7781 bool set_max_reflection_amount(float texturefloat, double time = TiMe::Default()) { return setValue("max_reflection_amount", texturefloat, time); }
7785 Value get_max_reflection_amount(double time = TiMe::Default()) const { return getValue("max_reflection_amount", time); }
7786
7789 bool set_opacity(const PluginRef& texture, double time = TiMe::Default()) { return setValue("opacity", texture, time); }
7792 bool set_opacity(const AColor& texture, double time = TiMe::Default()) { return setValue("opacity", texture, time); }
7795 Value get_opacity(double time = TiMe::Default()) const { return getValue("opacity", time); }
7796
7800 bool set_diffuse_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
7804 bool set_diffuse_color(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
7808 Value get_diffuse_color(double time = TiMe::Default()) const { return getValue("diffuse_color", time); }
7809
7813 bool set_diffuse_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
7817 bool set_diffuse_amount(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_amount", texturefloat, time); }
7821 Value get_diffuse_amount(double time = TiMe::Default()) const { return getValue("diffuse_amount", time); }
7822
7826 bool set_shallow_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shallow_color", texture, time); }
7830 bool set_shallow_color(const AColor& texture, double time = TiMe::Default()) { return setValue("shallow_color", texture, time); }
7834 Value get_shallow_color(double time = TiMe::Default()) const { return getValue("shallow_color", time); }
7835
7839 bool set_shallow_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shallow_amount", texturefloat, time); }
7843 bool set_shallow_amount(float texturefloat, double time = TiMe::Default()) { return setValue("shallow_amount", texturefloat, time); }
7847 Value get_shallow_amount(double time = TiMe::Default()) const { return getValue("shallow_amount", time); }
7848
7852 bool set_shallow_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shallow_radius", texturefloat, time); }
7856 bool set_shallow_radius(float texturefloat, double time = TiMe::Default()) { return setValue("shallow_radius", texturefloat, time); }
7860 Value get_shallow_radius(double time = TiMe::Default()) const { return getValue("shallow_radius", time); }
7861
7865 bool set_medium_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("medium_color", texture, time); }
7869 bool set_medium_color(const AColor& texture, double time = TiMe::Default()) { return setValue("medium_color", texture, time); }
7873 Value get_medium_color(double time = TiMe::Default()) const { return getValue("medium_color", time); }
7874
7878 bool set_medium_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("medium_amount", texturefloat, time); }
7882 bool set_medium_amount(float texturefloat, double time = TiMe::Default()) { return setValue("medium_amount", texturefloat, time); }
7886 Value get_medium_amount(double time = TiMe::Default()) const { return getValue("medium_amount", time); }
7887
7891 bool set_medium_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("medium_radius", texturefloat, time); }
7895 bool set_medium_radius(float texturefloat, double time = TiMe::Default()) { return setValue("medium_radius", texturefloat, time); }
7899 Value get_medium_radius(double time = TiMe::Default()) const { return getValue("medium_radius", time); }
7900
7904 bool set_deep_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("deep_color", texture, time); }
7908 bool set_deep_color(const AColor& texture, double time = TiMe::Default()) { return setValue("deep_color", texture, time); }
7912 Value get_deep_color(double time = TiMe::Default()) const { return getValue("deep_color", time); }
7913
7917 bool set_deep_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("deep_amount", texturefloat, time); }
7921 bool set_deep_amount(float texturefloat, double time = TiMe::Default()) { return setValue("deep_amount", texturefloat, time); }
7925 Value get_deep_amount(double time = TiMe::Default()) const { return getValue("deep_amount", time); }
7926
7930 bool set_deep_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("deep_radius", texturefloat, time); }
7934 bool set_deep_radius(float texturefloat, double time = TiMe::Default()) { return setValue("deep_radius", texturefloat, time); }
7938 Value get_deep_radius(double time = TiMe::Default()) const { return getValue("deep_radius", time); }
7939
7943 bool set_primary_reflecton_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("primary_reflecton_color", texture, time); }
7947 bool set_primary_reflecton_color(const AColor& texture, double time = TiMe::Default()) { return setValue("primary_reflecton_color", texture, time); }
7951 Value get_primary_reflecton_color(double time = TiMe::Default()) const { return getValue("primary_reflecton_color", time); }
7952
7956 bool set_primary_reflection_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("primary_reflection_amount", texturefloat, time); }
7960 bool set_primary_reflection_amount(float texturefloat, double time = TiMe::Default()) { return setValue("primary_reflection_amount", texturefloat, time); }
7964 Value get_primary_reflection_amount(double time = TiMe::Default()) const { return getValue("primary_reflection_amount", time); }
7965
7969 bool set_primary_reflection_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("primary_reflection_glossiness", texturefloat, time); }
7973 bool set_primary_reflection_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("primary_reflection_glossiness", texturefloat, time); }
7977 Value get_primary_reflection_glossiness(double time = TiMe::Default()) const { return getValue("primary_reflection_glossiness", time); }
7978
7982 bool set_primary_reflection_subdivs(int val, double time = TiMe::Default()) { return setValue("primary_reflection_subdivs", val, time); }
7986 int get_primary_reflection_subdivs(double time = TiMe::Default()) const { return getInt("primary_reflection_subdivs", time); }
7987
7991 bool set_primary_reflection_fresnel(bool val, double time = TiMe::Default()) { return setValue("primary_reflection_fresnel", val, time); }
7995 bool get_primary_reflection_fresnel(double time = TiMe::Default()) const { return getBool("primary_reflection_fresnel", time); }
7996
8000 bool set_primary_reflection_fresnel_ior(float val, double time = TiMe::Default()) { return setValue("primary_reflection_fresnel_ior", val, time); }
8004 float get_primary_reflection_fresnel_ior(double time = TiMe::Default()) const { return getFloat("primary_reflection_fresnel_ior", time); }
8005
8009 bool set_secondary_reflecton_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("secondary_reflecton_color", texture, time); }
8013 bool set_secondary_reflecton_color(const AColor& texture, double time = TiMe::Default()) { return setValue("secondary_reflecton_color", texture, time); }
8017 Value get_secondary_reflecton_color(double time = TiMe::Default()) const { return getValue("secondary_reflecton_color", time); }
8018
8022 bool set_secondary_reflection_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("secondary_reflection_amount", texturefloat, time); }
8026 bool set_secondary_reflection_amount(float texturefloat, double time = TiMe::Default()) { return setValue("secondary_reflection_amount", texturefloat, time); }
8030 Value get_secondary_reflection_amount(double time = TiMe::Default()) const { return getValue("secondary_reflection_amount", time); }
8031
8035 bool set_secondary_reflection_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("secondary_reflection_glossiness", texturefloat, time); }
8039 bool set_secondary_reflection_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("secondary_reflection_glossiness", texturefloat, time); }
8043 Value get_secondary_reflection_glossiness(double time = TiMe::Default()) const { return getValue("secondary_reflection_glossiness", time); }
8044
8048 bool set_secondary_reflection_subdivs(int val, double time = TiMe::Default()) { return setValue("secondary_reflection_subdivs", val, time); }
8052 int get_secondary_reflection_subdivs(double time = TiMe::Default()) const { return getInt("secondary_reflection_subdivs", time); }
8053
8057 bool set_secondary_reflection_fresnel(bool val, double time = TiMe::Default()) { return setValue("secondary_reflection_fresnel", val, time); }
8061 bool get_secondary_reflection_fresnel(double time = TiMe::Default()) const { return getBool("secondary_reflection_fresnel", time); }
8062
8066 bool set_secondary_reflection_fresnel_ior(float val, double time = TiMe::Default()) { return setValue("secondary_reflection_fresnel_ior", val, time); }
8070 float get_secondary_reflection_fresnel_ior(double time = TiMe::Default()) const { return getFloat("secondary_reflection_fresnel_ior", time); }
8071
8075 bool set_multiple_scattering(int val, double time = TiMe::Default()) { return setValue("multiple_scattering", val, time); }
8079 int get_multiple_scattering(double time = TiMe::Default()) const { return getInt("multiple_scattering", time); }
8080
8084 bool set_scatter_gi(bool val, double time = TiMe::Default()) { return setValue("scatter_gi", val, time); }
8088 bool get_scatter_gi(double time = TiMe::Default()) const { return getBool("scatter_gi", time); }
8089
8093 bool set_raytraced_scatter_textures(bool val, double time = TiMe::Default()) { return setValue("raytraced_scatter_textures", val, time); }
8097 bool get_raytraced_scatter_textures(double time = TiMe::Default()) const { return getBool("raytraced_scatter_textures", time); }
8098
8102 bool set_raytraced_subdivs(int val, double time = TiMe::Default()) { return setValue("raytraced_subdivs", val, time); }
8106 int get_raytraced_subdivs(double time = TiMe::Default()) const { return getInt("raytraced_subdivs", time); }
8107
8111 bool set_prepass_rate(int val, double time = TiMe::Default()) { return setValue("prepass_rate", val, time); }
8115 int get_prepass_rate(double time = TiMe::Default()) const { return getInt("prepass_rate", time); }
8116
8120 bool set_prepass_id(int val, double time = TiMe::Default()) { return setValue("prepass_id", val, time); }
8124 int get_prepass_id(double time = TiMe::Default()) const { return getInt("prepass_id", time); }
8125
8129 bool set_prepass_interpolation_accuracy(float val, double time = TiMe::Default()) { return setValue("prepass_interpolation_accuracy", val, time); }
8133 float get_prepass_interpolation_accuracy(double time = TiMe::Default()) const { return getFloat("prepass_interpolation_accuracy", time); }
8134
8138 bool set_geom_auto_density(bool val, double time = TiMe::Default()) { return setValue("geom_auto_density", val, time); }
8142 bool get_geom_auto_density(double time = TiMe::Default()) const { return getBool("geom_auto_density", time); }
8143
8147 bool set_geom_samples_per_unit_area(float val, double time = TiMe::Default()) { return setValue("geom_samples_per_unit_area", val, time); }
8151 float get_geom_samples_per_unit_area(double time = TiMe::Default()) const { return getFloat("geom_samples_per_unit_area", time); }
8152
8156 bool set_geom_surface_offset(float val, double time = TiMe::Default()) { return setValue("geom_surface_offset", val, time); }
8160 float get_geom_surface_offset(double time = TiMe::Default()) const { return getFloat("geom_surface_offset", time); }
8161
8165 bool set_geom_preview_samples(bool val, double time = TiMe::Default()) { return setValue("geom_preview_samples", val, time); }
8169 bool get_geom_preview_samples(double time = TiMe::Default()) const { return getBool("geom_preview_samples", time); }
8170
8174 bool set_geom_max_distance(float val, double time = TiMe::Default()) { return setValue("geom_max_distance", val, time); }
8178 float get_geom_max_distance(double time = TiMe::Default()) const { return getFloat("geom_max_distance", time); }
8179
8183 bool set_geom_background_color(const Color& color, double time = TiMe::Default()) { return setValue("geom_background_color", color, time); }
8187 Color get_geom_background_color(double time = TiMe::Default()) const { return getColor("geom_background_color", time); }
8188
8192 bool set_geom_samples_color(const Color& color, double time = TiMe::Default()) { return setValue("geom_samples_color", color, time); }
8196 Color get_geom_samples_color(double time = TiMe::Default()) const { return getColor("geom_samples_color", time); }
8197
8201 bool set_option_reflections_trace(bool val, double time = TiMe::Default()) { return setValue("option_reflections_trace", val, time); }
8205 bool get_option_reflections_trace(double time = TiMe::Default()) const { return getBool("option_reflections_trace", time); }
8206
8210 bool set_option_reflections_maxDepth(int val, double time = TiMe::Default()) { return setValue("option_reflections_maxDepth", val, time); }
8214 int get_option_reflections_maxDepth(double time = TiMe::Default()) const { return getInt("option_reflections_maxDepth", time); }
8215
8219 bool set_option_reflections_cutoff(float val, double time = TiMe::Default()) { return setValue("option_reflections_cutoff", val, time); }
8223 float get_option_reflections_cutoff(double time = TiMe::Default()) const { return getFloat("option_reflections_cutoff", time); }
8224
8226 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
8227 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
8228 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
8230 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
8231};
8232
8235public:
8237 static constexpr const PluginTypeId getTypeId() { return 0x781B3B41; }
8239 static constexpr const char* getType() { return "BRDFStochasticFlakes"; }
8240
8241 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
8242
8246 bool set_enable_flakes(bool val, double time = TiMe::Default()) { return setValue("enable_flakes", val, time); }
8250 bool get_enable_flakes(double time = TiMe::Default()) const { return getBool("enable_flakes", time); }
8251
8255 bool set_num_flakes(int val, double time = TiMe::Default()) { return setValue("num_flakes", val, time); }
8259 int get_num_flakes(double time = TiMe::Default()) const { return getInt("num_flakes", time); }
8260
8264 bool set_hilight_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
8268 bool set_hilight_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
8272 Value get_hilight_glossiness(double time = TiMe::Default()) const { return getValue("hilight_glossiness", time); }
8273
8277 bool set_blur_angle(float val, double time = TiMe::Default()) { return setValue("blur_angle", val, time); }
8281 float get_blur_angle(double time = TiMe::Default()) const { return getFloat("blur_angle", time); }
8282
8286 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
8290 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
8291
8295 bool set_reflect_filter(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_filter", texture, time); }
8299 bool set_reflect_filter(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_filter", texture, time); }
8303 Value get_reflect_filter(double time = TiMe::Default()) const { return getValue("reflect_filter", time); }
8304
8308 bool set_mapping_type(int val, double time = TiMe::Default()) { return setValue("mapping_type", val, time); }
8312 int get_mapping_type(double time = TiMe::Default()) const { return getInt("mapping_type", time); }
8313
8316 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
8319 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
8320
8324 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
8328 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
8329
8333 bool set_flake_scale(float val, double time = TiMe::Default()) { return setValue("flake_scale", val, time); }
8337 float get_flake_scale(double time = TiMe::Default()) const { return getFloat("flake_scale", time); }
8338
8342 bool set_brdf_type(int val, double time = TiMe::Default()) { return setValue("brdf_type", val, time); }
8346 int get_brdf_type(double time = TiMe::Default()) const { return getInt("brdf_type", time); }
8347
8351 bool set_seed(int val, double time = TiMe::Default()) { return setValue("seed", val, time); }
8355 int get_seed(double time = TiMe::Default()) const { return getInt("seed", time); }
8356
8360 bool set_colored_flakes_option(int val, double time = TiMe::Default()) { return setValue("colored_flakes_option", val, time); }
8364 int get_colored_flakes_option(double time = TiMe::Default()) const { return getInt("colored_flakes_option", time); }
8365
8369 bool set_saturation(float val, double time = TiMe::Default()) { return setValue("saturation", val, time); }
8373 float get_saturation(double time = TiMe::Default()) const { return getFloat("saturation", time); }
8374
8378 bool set_lightness(float val, double time = TiMe::Default()) { return setValue("lightness", val, time); }
8382 float get_lightness(double time = TiMe::Default()) const { return getFloat("lightness", time); }
8383
8386 bool set_random_color_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("random_color_map", texture, time); }
8389 bool set_random_color_map(const AColor& texture, double time = TiMe::Default()) { return setValue("random_color_map", texture, time); }
8392 Value get_random_color_map(double time = TiMe::Default()) const { return getValue("random_color_map", time); }
8393
8397 bool set_white_average(bool val, double time = TiMe::Default()) { return setValue("white_average", val, time); }
8401 bool get_white_average(double time = TiMe::Default()) const { return getBool("white_average", time); }
8402
8406 bool set_tex_subdivs(int val, double time = TiMe::Default()) { return setValue("tex_subdivs", val, time); }
8410 int get_tex_subdivs(double time = TiMe::Default()) const { return getInt("tex_subdivs", time); }
8411
8415 bool set_blend_min(float val, double time = TiMe::Default()) { return setValue("blend_min", val, time); }
8419 float get_blend_min(double time = TiMe::Default()) const { return getFloat("blend_min", time); }
8420
8424 bool set_blend_max(float val, double time = TiMe::Default()) { return setValue("blend_max", val, time); }
8428 float get_blend_max(double time = TiMe::Default()) const { return getFloat("blend_max", time); }
8429};
8430
8432class BRDFThunderLoom : public Plugin {
8433public:
8435 static constexpr const PluginTypeId getTypeId() { return 0x78399B95; }
8437 static constexpr const char* getType() { return "BRDFThunderLoom"; }
8438
8439 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
8440
8443 bool set_filepath(const char* str, double time = TiMe::Default()) { return setValue("filepath", str, time); }
8446 bool set_filepath(const std::string& str, double time = TiMe::Default()) { return setValue("filepath", str, time); }
8449 std::string get_filepath(double time = TiMe::Default()) const { return getString("filepath", time); }
8450
8453 bool set_uscale(float val, double time = TiMe::Default()) { return setValue("uscale", val, time); }
8456 float get_uscale(double time = TiMe::Default()) const { return getFloat("uscale", time); }
8457
8460 bool set_vscale(float val, double time = TiMe::Default()) { return setValue("vscale", val, time); }
8463 float get_vscale(double time = TiMe::Default()) const { return getFloat("vscale", time); }
8464
8467 bool set_uvrotation(float val, double time = TiMe::Default()) { return setValue("uvrotation", val, time); }
8470 float get_uvrotation(double time = TiMe::Default()) const { return getFloat("uvrotation", time); }
8471
8473 bool set_bend(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("bend", texturefloatList, time); }
8474 bool set_bend(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("bend", std::move(texturefloatList), time); }
8475 bool set_bend(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("bend", texturefloats, count, time); }
8476 template<size_t count> bool set_bend(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("bend", texturefloats, count, time); }
8477 template<size_t count> bool set_bend(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("bend", texturefloats, count, time); }
8479 ValueList get_bend(double time = TiMe::Default()) const { return getValueList("bend", time); }
8480
8482 bool set_yarnsize(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("yarnsize", texturefloatList, time); }
8483 bool set_yarnsize(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("yarnsize", std::move(texturefloatList), time); }
8484 bool set_yarnsize(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("yarnsize", texturefloats, count, time); }
8485 template<size_t count> bool set_yarnsize(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("yarnsize", texturefloats, count, time); }
8486 template<size_t count> bool set_yarnsize(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("yarnsize", texturefloats, count, time); }
8488 ValueList get_yarnsize(double time = TiMe::Default()) const { return getValueList("yarnsize", time); }
8489
8491 bool set_twist(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("twist", texturefloatList, time); }
8492 bool set_twist(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("twist", std::move(texturefloatList), time); }
8493 bool set_twist(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("twist", texturefloats, count, time); }
8494 template<size_t count> bool set_twist(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("twist", texturefloats, count, time); }
8495 template<size_t count> bool set_twist(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("twist", texturefloats, count, time); }
8497 ValueList get_twist(double time = TiMe::Default()) const { return getValueList("twist", time); }
8498
8500 bool set_phase_alpha(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("phase_alpha", texturefloatList, time); }
8501 bool set_phase_alpha(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("phase_alpha", std::move(texturefloatList), time); }
8502 bool set_phase_alpha(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("phase_alpha", texturefloats, count, time); }
8503 template<size_t count> bool set_phase_alpha(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("phase_alpha", texturefloats, count, time); }
8504 template<size_t count> bool set_phase_alpha(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("phase_alpha", texturefloats, count, time); }
8506 ValueList get_phase_alpha(double time = TiMe::Default()) const { return getValueList("phase_alpha", time); }
8507
8509 bool set_phase_beta(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("phase_beta", texturefloatList, time); }
8510 bool set_phase_beta(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("phase_beta", std::move(texturefloatList), time); }
8511 bool set_phase_beta(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("phase_beta", texturefloats, count, time); }
8512 template<size_t count> bool set_phase_beta(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("phase_beta", texturefloats, count, time); }
8513 template<size_t count> bool set_phase_beta(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("phase_beta", texturefloats, count, time); }
8515 ValueList get_phase_beta(double time = TiMe::Default()) const { return getValueList("phase_beta", time); }
8516
8519 bool set_specular_color(const ValueList& textureList, double time = TiMe::Default()) { return setValue("specular_color", textureList, time); }
8520 bool set_specular_color(ValueList&& textureList, double time = TiMe::Default()) { return setValue("specular_color", std::move(textureList), time); }
8521 bool set_specular_color(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("specular_color", textures, count, time); }
8522 template<size_t count> bool set_specular_color(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("specular_color", textures, count, time); }
8523 template<size_t count> bool set_specular_color(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("specular_color", textures, count, time); }
8526 ValueList get_specular_color(double time = TiMe::Default()) const { return getValueList("specular_color", time); }
8527
8529 bool set_specular_color_amount(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("specular_color_amount", texturefloatList, time); }
8530 bool set_specular_color_amount(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("specular_color_amount", std::move(texturefloatList), time); }
8531 bool set_specular_color_amount(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("specular_color_amount", texturefloats, count, time); }
8532 template<size_t count> bool set_specular_color_amount(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("specular_color_amount", texturefloats, count, time); }
8533 template<size_t count> bool set_specular_color_amount(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("specular_color_amount", texturefloats, count, time); }
8535 ValueList get_specular_color_amount(double time = TiMe::Default()) const { return getValueList("specular_color_amount", time); }
8536
8538 bool set_specular_noise(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("specular_noise", texturefloatList, time); }
8539 bool set_specular_noise(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("specular_noise", std::move(texturefloatList), time); }
8540 bool set_specular_noise(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("specular_noise", texturefloats, count, time); }
8541 template<size_t count> bool set_specular_noise(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("specular_noise", texturefloats, count, time); }
8542 template<size_t count> bool set_specular_noise(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("specular_noise", texturefloats, count, time); }
8544 ValueList get_specular_noise(double time = TiMe::Default()) const { return getValueList("specular_noise", time); }
8545
8547 bool set_highlight_width(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("highlight_width", texturefloatList, time); }
8548 bool set_highlight_width(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("highlight_width", std::move(texturefloatList), time); }
8549 bool set_highlight_width(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("highlight_width", texturefloats, count, time); }
8550 template<size_t count> bool set_highlight_width(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("highlight_width", texturefloats, count, time); }
8551 template<size_t count> bool set_highlight_width(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("highlight_width", texturefloats, count, time); }
8553 ValueList get_highlight_width(double time = TiMe::Default()) const { return getValueList("highlight_width", time); }
8554
8557 bool set_diffuse_color(const ValueList& textureList, double time = TiMe::Default()) { return setValue("diffuse_color", textureList, time); }
8558 bool set_diffuse_color(ValueList&& textureList, double time = TiMe::Default()) { return setValue("diffuse_color", std::move(textureList), time); }
8559 bool set_diffuse_color(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("diffuse_color", textures, count, time); }
8560 template<size_t count> bool set_diffuse_color(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("diffuse_color", textures, count, time); }
8561 template<size_t count> bool set_diffuse_color(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("diffuse_color", textures, count, time); }
8564 ValueList get_diffuse_color(double time = TiMe::Default()) const { return getValueList("diffuse_color", time); }
8565
8567 bool set_diffuse_color_amount(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("diffuse_color_amount", texturefloatList, time); }
8568 bool set_diffuse_color_amount(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("diffuse_color_amount", std::move(texturefloatList), time); }
8569 bool set_diffuse_color_amount(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("diffuse_color_amount", texturefloats, count, time); }
8570 template<size_t count> bool set_diffuse_color_amount(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("diffuse_color_amount", texturefloats, count, time); }
8571 template<size_t count> bool set_diffuse_color_amount(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("diffuse_color_amount", texturefloats, count, time); }
8573 ValueList get_diffuse_color_amount(double time = TiMe::Default()) const { return getValueList("diffuse_color_amount", time); }
8574
8577 bool set_bend_on(const IntList& intList, double time = TiMe::Default()) { return setValue("bend_on", intList, time); }
8578 bool set_bend_on(IntList&& intList, double time = TiMe::Default()) { return setValue("bend_on", std::move(intList), time); }
8579 bool set_bend_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("bend_on", ints, count, time); }
8580 template<size_t count> bool set_bend_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("bend_on", ints, count, time); }
8583 IntList get_bend_on(double time = TiMe::Default()) const { return getIntList("bend_on", time); }
8584
8587 bool set_yarnsize_on(const IntList& intList, double time = TiMe::Default()) { return setValue("yarnsize_on", intList, time); }
8588 bool set_yarnsize_on(IntList&& intList, double time = TiMe::Default()) { return setValue("yarnsize_on", std::move(intList), time); }
8589 bool set_yarnsize_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("yarnsize_on", ints, count, time); }
8590 template<size_t count> bool set_yarnsize_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("yarnsize_on", ints, count, time); }
8593 IntList get_yarnsize_on(double time = TiMe::Default()) const { return getIntList("yarnsize_on", time); }
8594
8597 bool set_twist_on(const IntList& intList, double time = TiMe::Default()) { return setValue("twist_on", intList, time); }
8598 bool set_twist_on(IntList&& intList, double time = TiMe::Default()) { return setValue("twist_on", std::move(intList), time); }
8599 bool set_twist_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("twist_on", ints, count, time); }
8600 template<size_t count> bool set_twist_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("twist_on", ints, count, time); }
8603 IntList get_twist_on(double time = TiMe::Default()) const { return getIntList("twist_on", time); }
8604
8607 bool set_phase_alpha_on(const IntList& intList, double time = TiMe::Default()) { return setValue("phase_alpha_on", intList, time); }
8608 bool set_phase_alpha_on(IntList&& intList, double time = TiMe::Default()) { return setValue("phase_alpha_on", std::move(intList), time); }
8609 bool set_phase_alpha_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("phase_alpha_on", ints, count, time); }
8610 template<size_t count> bool set_phase_alpha_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("phase_alpha_on", ints, count, time); }
8613 IntList get_phase_alpha_on(double time = TiMe::Default()) const { return getIntList("phase_alpha_on", time); }
8614
8617 bool set_phase_beta_on(const IntList& intList, double time = TiMe::Default()) { return setValue("phase_beta_on", intList, time); }
8618 bool set_phase_beta_on(IntList&& intList, double time = TiMe::Default()) { return setValue("phase_beta_on", std::move(intList), time); }
8619 bool set_phase_beta_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("phase_beta_on", ints, count, time); }
8620 template<size_t count> bool set_phase_beta_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("phase_beta_on", ints, count, time); }
8623 IntList get_phase_beta_on(double time = TiMe::Default()) const { return getIntList("phase_beta_on", time); }
8624
8627 bool set_specular_color_on(const IntList& intList, double time = TiMe::Default()) { return setValue("specular_color_on", intList, time); }
8628 bool set_specular_color_on(IntList&& intList, double time = TiMe::Default()) { return setValue("specular_color_on", std::move(intList), time); }
8629 bool set_specular_color_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("specular_color_on", ints, count, time); }
8630 template<size_t count> bool set_specular_color_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("specular_color_on", ints, count, time); }
8633 IntList get_specular_color_on(double time = TiMe::Default()) const { return getIntList("specular_color_on", time); }
8634
8637 bool set_specular_color_amount_on(const IntList& intList, double time = TiMe::Default()) { return setValue("specular_color_amount_on", intList, time); }
8638 bool set_specular_color_amount_on(IntList&& intList, double time = TiMe::Default()) { return setValue("specular_color_amount_on", std::move(intList), time); }
8639 bool set_specular_color_amount_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("specular_color_amount_on", ints, count, time); }
8640 template<size_t count> bool set_specular_color_amount_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("specular_color_amount_on", ints, count, time); }
8643 IntList get_specular_color_amount_on(double time = TiMe::Default()) const { return getIntList("specular_color_amount_on", time); }
8644
8647 bool set_specular_noise_on(const IntList& intList, double time = TiMe::Default()) { return setValue("specular_noise_on", intList, time); }
8648 bool set_specular_noise_on(IntList&& intList, double time = TiMe::Default()) { return setValue("specular_noise_on", std::move(intList), time); }
8649 bool set_specular_noise_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("specular_noise_on", ints, count, time); }
8650 template<size_t count> bool set_specular_noise_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("specular_noise_on", ints, count, time); }
8653 IntList get_specular_noise_on(double time = TiMe::Default()) const { return getIntList("specular_noise_on", time); }
8654
8657 bool set_highlight_width_on(const IntList& intList, double time = TiMe::Default()) { return setValue("highlight_width_on", intList, time); }
8658 bool set_highlight_width_on(IntList&& intList, double time = TiMe::Default()) { return setValue("highlight_width_on", std::move(intList), time); }
8659 bool set_highlight_width_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("highlight_width_on", ints, count, time); }
8660 template<size_t count> bool set_highlight_width_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("highlight_width_on", ints, count, time); }
8663 IntList get_highlight_width_on(double time = TiMe::Default()) const { return getIntList("highlight_width_on", time); }
8664
8667 bool set_diffuse_color_on(const IntList& intList, double time = TiMe::Default()) { return setValue("diffuse_color_on", intList, time); }
8668 bool set_diffuse_color_on(IntList&& intList, double time = TiMe::Default()) { return setValue("diffuse_color_on", std::move(intList), time); }
8669 bool set_diffuse_color_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("diffuse_color_on", ints, count, time); }
8670 template<size_t count> bool set_diffuse_color_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("diffuse_color_on", ints, count, time); }
8673 IntList get_diffuse_color_on(double time = TiMe::Default()) const { return getIntList("diffuse_color_on", time); }
8674
8677 bool set_diffuse_color_amount_on(const IntList& intList, double time = TiMe::Default()) { return setValue("diffuse_color_amount_on", intList, time); }
8678 bool set_diffuse_color_amount_on(IntList&& intList, double time = TiMe::Default()) { return setValue("diffuse_color_amount_on", std::move(intList), time); }
8679 bool set_diffuse_color_amount_on(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("diffuse_color_amount_on", ints, count, time); }
8680 template<size_t count> bool set_diffuse_color_amount_on(const int (&ints)[count], double time = TiMe::Default()) { return setArray("diffuse_color_amount_on", ints, count, time); }
8683 IntList get_diffuse_color_amount_on(double time = TiMe::Default()) const { return getIntList("diffuse_color_amount_on", time); }
8684};
8685
8687class BRDFToonMtl : public Plugin {
8688public:
8690 static constexpr const PluginTypeId getTypeId() { return 0x2EFC5912BF; }
8692 static constexpr const char* getType() { return "BRDFToonMtl"; }
8693
8694 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
8695
8699 bool set_opacity_source(int val, double time = TiMe::Default()) { return setValue("opacity_source", val, time); }
8703 int get_opacity_source(double time = TiMe::Default()) const { return getInt("opacity_source", time); }
8704
8708 bool set_opacity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
8712 bool set_opacity(float texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
8716 Value get_opacity(double time = TiMe::Default()) const { return getValue("opacity", time); }
8717
8721 bool set_opacity_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("opacity_color", texture, time); }
8725 bool set_opacity_color(const AColor& texture, double time = TiMe::Default()) { return setValue("opacity_color", texture, time); }
8729 Value get_opacity_color(double time = TiMe::Default()) const { return getValue("opacity_color", time); }
8730
8734 bool set_opacity_mode(int val, double time = TiMe::Default()) { return setValue("opacity_mode", val, time); }
8738 int get_opacity_mode(double time = TiMe::Default()) const { return getInt("opacity_mode", time); }
8739
8743 bool set_diffuse(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse", texture, time); }
8747 bool set_diffuse(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse", texture, time); }
8751 Value get_diffuse(double time = TiMe::Default()) const { return getValue("diffuse", time); }
8752
8756 bool set_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
8760 bool set_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
8764 Value get_roughness(double time = TiMe::Default()) const { return getValue("roughness", time); }
8765
8769 bool set_roughness_model(int val, double time = TiMe::Default()) { return setValue("roughness_model", val, time); }
8773 int get_roughness_model(double time = TiMe::Default()) const { return getInt("roughness_model", time); }
8774
8778 bool set_self_illumination(const PluginRef& texture, double time = TiMe::Default()) { return setValue("self_illumination", texture, time); }
8782 bool set_self_illumination(const AColor& texture, double time = TiMe::Default()) { return setValue("self_illumination", texture, time); }
8786 Value get_self_illumination(double time = TiMe::Default()) const { return getValue("self_illumination", time); }
8787
8791 bool set_self_illumination_gi(bool val, double time = TiMe::Default()) { return setValue("self_illumination_gi", val, time); }
8795 bool get_self_illumination_gi(double time = TiMe::Default()) const { return getBool("self_illumination_gi", time); }
8796
8800 bool set_compensate_camera_exposure(bool val, double time = TiMe::Default()) { return setValue("compensate_camera_exposure", val, time); }
8804 bool get_compensate_camera_exposure(double time = TiMe::Default()) const { return getBool("compensate_camera_exposure", time); }
8805
8809 bool set_brdf_type(int val, double time = TiMe::Default()) { return setValue("brdf_type", val, time); }
8813 int get_brdf_type(double time = TiMe::Default()) const { return getInt("brdf_type", time); }
8814
8818 bool set_reflect(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect", texture, time); }
8822 bool set_reflect(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect", texture, time); }
8826 Value get_reflect(double time = TiMe::Default()) const { return getValue("reflect", time); }
8827
8831 bool set_reflect_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect_glossiness", texturefloat, time); }
8835 bool set_reflect_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("reflect_glossiness", texturefloat, time); }
8839 Value get_reflect_glossiness(double time = TiMe::Default()) const { return getValue("reflect_glossiness", time); }
8840
8844 bool set_hilight_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
8848 bool set_hilight_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
8852 Value get_hilight_glossiness(double time = TiMe::Default()) const { return getValue("hilight_glossiness", time); }
8853
8857 bool set_hilight_glossiness_lock(bool val, double time = TiMe::Default()) { return setValue("hilight_glossiness_lock", val, time); }
8861 bool get_hilight_glossiness_lock(double time = TiMe::Default()) const { return getBool("hilight_glossiness_lock", time); }
8862
8866 bool set_gtr_gamma(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gtr_gamma", texturefloat, time); }
8870 bool set_gtr_gamma(float texturefloat, double time = TiMe::Default()) { return setValue("gtr_gamma", texturefloat, time); }
8874 Value get_gtr_gamma(double time = TiMe::Default()) const { return getValue("gtr_gamma", time); }
8875
8879 bool set_fresnel(bool val, double time = TiMe::Default()) { return setValue("fresnel", val, time); }
8883 bool get_fresnel(double time = TiMe::Default()) const { return getBool("fresnel", time); }
8884
8888 bool set_fresnel_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("fresnel_ior", texturefloat, time); }
8892 bool set_fresnel_ior(float texturefloat, double time = TiMe::Default()) { return setValue("fresnel_ior", texturefloat, time); }
8896 Value get_fresnel_ior(double time = TiMe::Default()) const { return getValue("fresnel_ior", time); }
8897
8901 bool set_fresnel_ior_lock(bool val, double time = TiMe::Default()) { return setValue("fresnel_ior_lock", val, time); }
8905 bool get_fresnel_ior_lock(double time = TiMe::Default()) const { return getBool("fresnel_ior_lock", time); }
8906
8910 bool set_metalness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("metalness", texturefloat, time); }
8914 bool set_metalness(float texturefloat, double time = TiMe::Default()) { return setValue("metalness", texturefloat, time); }
8918 Value get_metalness(double time = TiMe::Default()) const { return getValue("metalness", time); }
8919
8923 bool set_gtr_energy_compensation(int val, double time = TiMe::Default()) { return setValue("gtr_energy_compensation", val, time); }
8927 int get_gtr_energy_compensation(double time = TiMe::Default()) const { return getInt("gtr_energy_compensation", time); }
8928
8932 bool set_reflect_subdivs(int val, double time = TiMe::Default()) { return setValue("reflect_subdivs", val, time); }
8936 int get_reflect_subdivs(double time = TiMe::Default()) const { return getInt("reflect_subdivs", time); }
8937
8941 bool set_reflect_trace(bool val, double time = TiMe::Default()) { return setValue("reflect_trace", val, time); }
8945 bool get_reflect_trace(double time = TiMe::Default()) const { return getBool("reflect_trace", time); }
8946
8950 bool set_reflect_depth(int val, double time = TiMe::Default()) { return setValue("reflect_depth", val, time); }
8954 int get_reflect_depth(double time = TiMe::Default()) const { return getInt("reflect_depth", time); }
8955
8959 bool set_reflect_exit_color(const Color& color, double time = TiMe::Default()) { return setValue("reflect_exit_color", color, time); }
8963 Color get_reflect_exit_color(double time = TiMe::Default()) const { return getColor("reflect_exit_color", time); }
8964
8968 bool set_hilight_soften(float val, double time = TiMe::Default()) { return setValue("hilight_soften", val, time); }
8972 float get_hilight_soften(double time = TiMe::Default()) const { return getFloat("hilight_soften", time); }
8973
8977 bool set_reflect_affect_alpha(int val, double time = TiMe::Default()) { return setValue("reflect_affect_alpha", val, time); }
8981 int get_reflect_affect_alpha(double time = TiMe::Default()) const { return getInt("reflect_affect_alpha", time); }
8982
8986 bool set_reflect_weight(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect_weight", texturefloat, time); }
8990 bool set_reflect_weight(float texturefloat, double time = TiMe::Default()) { return setValue("reflect_weight", texturefloat, time); }
8994 Value get_reflect_weight(double time = TiMe::Default()) const { return getValue("reflect_weight", time); }
8995
8999 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
9003 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
9004
9008 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
9012 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
9013
9017 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
9021 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
9022
9026 bool set_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
9030 bool set_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
9034 Value get_anisotropy(double time = TiMe::Default()) const { return getValue("anisotropy", time); }
9035
9039 bool set_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
9043 bool set_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
9047 Value get_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("anisotropy_rotation", time); }
9048
9052 bool set_anisotropy_derivation(int val, double time = TiMe::Default()) { return setValue("anisotropy_derivation", val, time); }
9056 int get_anisotropy_derivation(double time = TiMe::Default()) const { return getInt("anisotropy_derivation", time); }
9057
9061 bool set_anisotropy_axis(int val, double time = TiMe::Default()) { return setValue("anisotropy_axis", val, time); }
9065 int get_anisotropy_axis(double time = TiMe::Default()) const { return getInt("anisotropy_axis", time); }
9066
9069 bool set_anisotropy_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("anisotropy_uvwgen", plugin, time); }
9072 PluginRef get_anisotropy_uvwgen(double time = TiMe::Default()) const { return getPlugin("anisotropy_uvwgen", time); }
9073
9077 bool set_new_gtr_anisotropy(bool val, double time = TiMe::Default()) { return setValue("new_gtr_anisotropy", val, time); }
9081 bool get_new_gtr_anisotropy(double time = TiMe::Default()) const { return getBool("new_gtr_anisotropy", time); }
9082
9086 bool set_thin_film_on(bool val, double time = TiMe::Default()) { return setValue("thin_film_on", val, time); }
9090 bool get_thin_film_on(double time = TiMe::Default()) const { return getBool("thin_film_on", time); }
9091
9095 bool set_thin_film_thickness_min(float val, double time = TiMe::Default()) { return setValue("thin_film_thickness_min", val, time); }
9099 float get_thin_film_thickness_min(double time = TiMe::Default()) const { return getFloat("thin_film_thickness_min", time); }
9100
9104 bool set_thin_film_thickness_max(float val, double time = TiMe::Default()) { return setValue("thin_film_thickness_max", val, time); }
9108 float get_thin_film_thickness_max(double time = TiMe::Default()) const { return getFloat("thin_film_thickness_max", time); }
9109
9113 bool set_thin_film_thickness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("thin_film_thickness", texturefloat, time); }
9117 bool set_thin_film_thickness(float texturefloat, double time = TiMe::Default()) { return setValue("thin_film_thickness", texturefloat, time); }
9121 Value get_thin_film_thickness(double time = TiMe::Default()) const { return getValue("thin_film_thickness", time); }
9122
9126 bool set_thin_film_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("thin_film_ior", texturefloat, time); }
9130 bool set_thin_film_ior(float texturefloat, double time = TiMe::Default()) { return setValue("thin_film_ior", texturefloat, time); }
9134 Value get_thin_film_ior(double time = TiMe::Default()) const { return getValue("thin_film_ior", time); }
9135
9139 bool set_refract(const PluginRef& texture, double time = TiMe::Default()) { return setValue("refract", texture, time); }
9143 bool set_refract(const AColor& texture, double time = TiMe::Default()) { return setValue("refract", texture, time); }
9147 Value get_refract(double time = TiMe::Default()) const { return getValue("refract", time); }
9148
9152 bool set_refract_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("refract_ior", texturefloat, time); }
9156 bool set_refract_ior(float texturefloat, double time = TiMe::Default()) { return setValue("refract_ior", texturefloat, time); }
9160 Value get_refract_ior(double time = TiMe::Default()) const { return getValue("refract_ior", time); }
9161
9165 bool set_refract_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("refract_glossiness", texturefloat, time); }
9169 bool set_refract_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("refract_glossiness", texturefloat, time); }
9173 Value get_refract_glossiness(double time = TiMe::Default()) const { return getValue("refract_glossiness", time); }
9174
9178 bool set_refract_subdivs(int val, double time = TiMe::Default()) { return setValue("refract_subdivs", val, time); }
9182 int get_refract_subdivs(double time = TiMe::Default()) const { return getInt("refract_subdivs", time); }
9183
9187 bool set_refract_trace(bool val, double time = TiMe::Default()) { return setValue("refract_trace", val, time); }
9191 bool get_refract_trace(double time = TiMe::Default()) const { return getBool("refract_trace", time); }
9192
9196 bool set_refract_depth(int val, double time = TiMe::Default()) { return setValue("refract_depth", val, time); }
9200 int get_refract_depth(double time = TiMe::Default()) const { return getInt("refract_depth", time); }
9201
9205 bool set_refract_exit_color_on(bool val, double time = TiMe::Default()) { return setValue("refract_exit_color_on", val, time); }
9209 bool get_refract_exit_color_on(double time = TiMe::Default()) const { return getBool("refract_exit_color_on", time); }
9210
9214 bool set_refract_exit_color(const Color& color, double time = TiMe::Default()) { return setValue("refract_exit_color", color, time); }
9218 Color get_refract_exit_color(double time = TiMe::Default()) const { return getColor("refract_exit_color", time); }
9219
9223 bool set_refract_affect_alpha(int val, double time = TiMe::Default()) { return setValue("refract_affect_alpha", val, time); }
9227 int get_refract_affect_alpha(double time = TiMe::Default()) const { return getInt("refract_affect_alpha", time); }
9228
9232 bool set_refract_affect_shadows(bool val, double time = TiMe::Default()) { return setValue("refract_affect_shadows", val, time); }
9236 bool get_refract_affect_shadows(double time = TiMe::Default()) const { return getBool("refract_affect_shadows", time); }
9237
9241 bool set_dispersion_on(bool val, double time = TiMe::Default()) { return setValue("dispersion_on", val, time); }
9245 bool get_dispersion_on(double time = TiMe::Default()) const { return getBool("dispersion_on", time); }
9246
9250 bool set_dispersion(float val, double time = TiMe::Default()) { return setValue("dispersion", val, time); }
9254 float get_dispersion(double time = TiMe::Default()) const { return getFloat("dispersion", time); }
9255
9259 bool set_refract_thin_walled(bool val, double time = TiMe::Default()) { return setValue("refract_thin_walled", val, time); }
9263 bool get_refract_thin_walled(double time = TiMe::Default()) const { return getBool("refract_thin_walled", time); }
9264
9268 bool set_fog_color(const Color& color, double time = TiMe::Default()) { return setValue("fog_color", color, time); }
9272 Color get_fog_color(double time = TiMe::Default()) const { return getColor("fog_color", time); }
9273
9276 bool set_fog_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("fog_color_tex", texture, time); }
9279 bool set_fog_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("fog_color_tex", texture, time); }
9282 Value get_fog_color_tex(double time = TiMe::Default()) const { return getValue("fog_color_tex", time); }
9283
9287 bool set_fog_mult(float val, double time = TiMe::Default()) { return setValue("fog_mult", val, time); }
9291 float get_fog_mult(double time = TiMe::Default()) const { return getFloat("fog_mult", time); }
9292
9296 bool set_fog_depth(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("fog_depth", texturefloat, time); }
9300 bool set_fog_depth(float texturefloat, double time = TiMe::Default()) { return setValue("fog_depth", texturefloat, time); }
9304 Value get_fog_depth(double time = TiMe::Default()) const { return getValue("fog_depth", time); }
9305
9309 bool set_fog_bias(float val, double time = TiMe::Default()) { return setValue("fog_bias", val, time); }
9313 float get_fog_bias(double time = TiMe::Default()) const { return getFloat("fog_bias", time); }
9314
9318 bool set_fog_unit_scale_on(bool val, double time = TiMe::Default()) { return setValue("fog_unit_scale_on", val, time); }
9322 bool get_fog_unit_scale_on(double time = TiMe::Default()) const { return getBool("fog_unit_scale_on", time); }
9323
9327 bool set_translucency(int val, double time = TiMe::Default()) { return setValue("translucency", val, time); }
9331 int get_translucency(double time = TiMe::Default()) const { return getInt("translucency", time); }
9332
9336 bool set_translucency_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("translucency_color", texture, time); }
9340 bool set_translucency_color(const AColor& texture, double time = TiMe::Default()) { return setValue("translucency_color", texture, time); }
9344 Value get_translucency_color(double time = TiMe::Default()) const { return getValue("translucency_color", time); }
9345
9349 bool set_translucency_light_mult(float val, double time = TiMe::Default()) { return setValue("translucency_light_mult", val, time); }
9353 float get_translucency_light_mult(double time = TiMe::Default()) const { return getFloat("translucency_light_mult", time); }
9354
9358 bool set_translucency_scatter_dir(float val, double time = TiMe::Default()) { return setValue("translucency_scatter_dir", val, time); }
9362 float get_translucency_scatter_dir(double time = TiMe::Default()) const { return getFloat("translucency_scatter_dir", time); }
9363
9367 bool set_translucency_scatter_coeff(float val, double time = TiMe::Default()) { return setValue("translucency_scatter_coeff", val, time); }
9371 float get_translucency_scatter_coeff(double time = TiMe::Default()) const { return getFloat("translucency_scatter_coeff", time); }
9372
9376 bool set_translucency_thickness(float val, double time = TiMe::Default()) { return setValue("translucency_thickness", val, time); }
9380 float get_translucency_thickness(double time = TiMe::Default()) const { return getFloat("translucency_thickness", time); }
9381
9385 bool set_translucency_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("translucency_amount", texturefloat, time); }
9389 bool set_translucency_amount(float texturefloat, double time = TiMe::Default()) { return setValue("translucency_amount", texturefloat, time); }
9393 Value get_translucency_amount(double time = TiMe::Default()) const { return getValue("translucency_amount", time); }
9394
9398 bool set_translucency_surfaceLighting(int val, double time = TiMe::Default()) { return setValue("translucency_surfaceLighting", val, time); }
9402 int get_translucency_surfaceLighting(double time = TiMe::Default()) const { return getInt("translucency_surfaceLighting", time); }
9403
9407 bool set_option_shading_model(int val, double time = TiMe::Default()) { return setValue("option_shading_model", val, time); }
9411 int get_option_shading_model(double time = TiMe::Default()) const { return getInt("option_shading_model", time); }
9412
9416 bool set_option_double_sided(bool val, double time = TiMe::Default()) { return setValue("option_double_sided", val, time); }
9420 bool get_option_double_sided(double time = TiMe::Default()) const { return getBool("option_double_sided", time); }
9421
9425 bool set_option_reflect_on_back(bool val, double time = TiMe::Default()) { return setValue("option_reflect_on_back", val, time); }
9429 bool get_option_reflect_on_back(double time = TiMe::Default()) const { return getBool("option_reflect_on_back", time); }
9430
9434 bool set_option_glossy_rays_as_gi(int val, double time = TiMe::Default()) { return setValue("option_glossy_rays_as_gi", val, time); }
9438 int get_option_glossy_rays_as_gi(double time = TiMe::Default()) const { return getInt("option_glossy_rays_as_gi", time); }
9439
9443 bool set_option_cutoff(float val, double time = TiMe::Default()) { return setValue("option_cutoff", val, time); }
9447 float get_option_cutoff(double time = TiMe::Default()) const { return getFloat("option_cutoff", time); }
9448
9452 bool set_option_use_irradiance_map(bool val, double time = TiMe::Default()) { return setValue("option_use_irradiance_map", val, time); }
9456 bool get_option_use_irradiance_map(double time = TiMe::Default()) const { return getBool("option_use_irradiance_map", time); }
9457
9461 bool set_option_energy_mode(int val, double time = TiMe::Default()) { return setValue("option_energy_mode", val, time); }
9465 int get_option_energy_mode(double time = TiMe::Default()) const { return getInt("option_energy_mode", time); }
9466
9470 bool set_option_fix_dark_edges(bool val, double time = TiMe::Default()) { return setValue("option_fix_dark_edges", val, time); }
9474 bool get_option_fix_dark_edges(double time = TiMe::Default()) const { return getBool("option_fix_dark_edges", time); }
9475
9479 bool set_option_glossy_fresnel(bool val, double time = TiMe::Default()) { return setValue("option_glossy_fresnel", val, time); }
9483 bool get_option_glossy_fresnel(double time = TiMe::Default()) const { return getBool("option_glossy_fresnel", time); }
9484
9488 bool set_option_use_roughness(bool val, double time = TiMe::Default()) { return setValue("option_use_roughness", val, time); }
9492 bool get_option_use_roughness(double time = TiMe::Default()) const { return getBool("option_use_roughness", time); }
9493
9497 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
9501 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
9502
9505 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
9508 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
9511 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
9512
9516 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
9520 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
9521
9525 bool set_refl_interpolation_on(bool val, double time = TiMe::Default()) { return setValue("refl_interpolation_on", val, time); }
9529 bool get_refl_interpolation_on(double time = TiMe::Default()) const { return getBool("refl_interpolation_on", time); }
9530
9534 bool set_refl_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("refl_imap_min_rate", val, time); }
9538 int get_refl_imap_min_rate(double time = TiMe::Default()) const { return getInt("refl_imap_min_rate", time); }
9539
9543 bool set_refl_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("refl_imap_max_rate", val, time); }
9547 int get_refl_imap_max_rate(double time = TiMe::Default()) const { return getInt("refl_imap_max_rate", time); }
9548
9552 bool set_refl_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("refl_imap_color_thresh", val, time); }
9556 float get_refl_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("refl_imap_color_thresh", time); }
9557
9561 bool set_refl_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("refl_imap_norm_thresh", val, time); }
9565 float get_refl_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("refl_imap_norm_thresh", time); }
9566
9570 bool set_refl_imap_samples(int val, double time = TiMe::Default()) { return setValue("refl_imap_samples", val, time); }
9574 int get_refl_imap_samples(double time = TiMe::Default()) const { return getInt("refl_imap_samples", time); }
9575
9579 bool set_refr_interpolation_on(bool val, double time = TiMe::Default()) { return setValue("refr_interpolation_on", val, time); }
9583 bool get_refr_interpolation_on(double time = TiMe::Default()) const { return getBool("refr_interpolation_on", time); }
9584
9588 bool set_refr_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("refr_imap_min_rate", val, time); }
9592 int get_refr_imap_min_rate(double time = TiMe::Default()) const { return getInt("refr_imap_min_rate", time); }
9593
9597 bool set_refr_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("refr_imap_max_rate", val, time); }
9601 int get_refr_imap_max_rate(double time = TiMe::Default()) const { return getInt("refr_imap_max_rate", time); }
9602
9606 bool set_refr_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("refr_imap_color_thresh", val, time); }
9610 float get_refr_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("refr_imap_color_thresh", time); }
9611
9615 bool set_refr_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("refr_imap_norm_thresh", val, time); }
9619 float get_refr_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("refr_imap_norm_thresh", time); }
9620
9624 bool set_refr_imap_samples(int val, double time = TiMe::Default()) { return setValue("refr_imap_samples", val, time); }
9628 int get_refr_imap_samples(double time = TiMe::Default()) const { return getInt("refr_imap_samples", time); }
9629
9632 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
9633 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
9634 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
9637 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
9638
9641 bool set_volume(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("volume", plugin, time); }
9644 PluginRef get_volume(double time = TiMe::Default()) const { return getPlugin("volume", time); }
9645
9649 bool set_sheen_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sheen_color", texture, time); }
9653 bool set_sheen_color(const AColor& texture, double time = TiMe::Default()) { return setValue("sheen_color", texture, time); }
9657 Value get_sheen_color(double time = TiMe::Default()) const { return getValue("sheen_color", time); }
9658
9662 bool set_sheen_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sheen_amount", texturefloat, time); }
9666 bool set_sheen_amount(float texturefloat, double time = TiMe::Default()) { return setValue("sheen_amount", texturefloat, time); }
9670 Value get_sheen_amount(double time = TiMe::Default()) const { return getValue("sheen_amount", time); }
9671
9675 bool set_sheen_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sheen_glossiness", texturefloat, time); }
9679 bool set_sheen_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("sheen_glossiness", texturefloat, time); }
9683 Value get_sheen_glossiness(double time = TiMe::Default()) const { return getValue("sheen_glossiness", time); }
9684
9688 bool set_coat_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
9692 bool set_coat_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
9696 Value get_coat_color(double time = TiMe::Default()) const { return getValue("coat_color", time); }
9697
9701 bool set_coat_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_amount", texturefloat, time); }
9705 bool set_coat_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_amount", texturefloat, time); }
9709 Value get_coat_amount(double time = TiMe::Default()) const { return getValue("coat_amount", time); }
9710
9714 bool set_coat_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
9718 bool set_coat_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
9722 Value get_coat_glossiness(double time = TiMe::Default()) const { return getValue("coat_glossiness", time); }
9723
9727 bool set_coat_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_ior", texturefloat, time); }
9731 bool set_coat_ior(float texturefloat, double time = TiMe::Default()) { return setValue("coat_ior", texturefloat, time); }
9735 Value get_coat_ior(double time = TiMe::Default()) const { return getValue("coat_ior", time); }
9736
9740 bool set_coat_bump_lock(bool val, double time = TiMe::Default()) { return setValue("coat_bump_lock", val, time); }
9744 bool get_coat_bump_lock(double time = TiMe::Default()) const { return getBool("coat_bump_lock", time); }
9745
9749 bool set_coat_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy", texturefloat, time); }
9753 bool set_coat_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy", texturefloat, time); }
9757 Value get_coat_anisotropy(double time = TiMe::Default()) const { return getValue("coat_anisotropy", time); }
9758
9762 bool set_coat_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy_rotation", texturefloat, time); }
9766 bool set_coat_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy_rotation", texturefloat, time); }
9770 Value get_coat_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("coat_anisotropy_rotation", time); }
9771
9775 bool set_coat_darkening(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_darkening", texturefloat, time); }
9779 bool set_coat_darkening(float texturefloat, double time = TiMe::Default()) { return setValue("coat_darkening", texturefloat, time); }
9783 Value get_coat_darkening(double time = TiMe::Default()) const { return getValue("coat_darkening", time); }
9784
9788 bool set_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_map", texture, time); }
9792 bool set_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_map", texture, time); }
9796 Value get_bump_map(double time = TiMe::Default()) const { return getValue("bump_map", time); }
9797
9801 bool set_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_amount", texturefloat, time); }
9805 bool set_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("bump_amount", texturefloat, time); }
9809 Value get_bump_amount(double time = TiMe::Default()) const { return getValue("bump_amount", time); }
9810
9814 bool set_bump_type(int val, double time = TiMe::Default()) { return setValue("bump_type", val, time); }
9818 int get_bump_type(double time = TiMe::Default()) const { return getInt("bump_type", time); }
9819
9823 bool set_coat_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_bump_map", texture, time); }
9827 bool set_coat_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_bump_map", texture, time); }
9831 Value get_coat_bump_map(double time = TiMe::Default()) const { return getValue("coat_bump_map", time); }
9832
9836 bool set_coat_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
9840 bool set_coat_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
9844 Value get_coat_bump_amount(double time = TiMe::Default()) const { return getValue("coat_bump_amount", time); }
9845
9849 bool set_coat_bump_type(int val, double time = TiMe::Default()) { return setValue("coat_bump_type", val, time); }
9853 int get_coat_bump_type(double time = TiMe::Default()) const { return getInt("coat_bump_type", time); }
9854
9858 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
9862 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
9866 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
9867
9871 bool set_diffuse_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("diffuse_positions", floatList, time); }
9872 bool set_diffuse_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("diffuse_positions", std::move(floatList), time); }
9873 bool set_diffuse_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("diffuse_positions", floats, count, time); }
9874 template<size_t count> bool set_diffuse_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("diffuse_positions", floats, count, time); }
9878 FloatList get_diffuse_positions(double time = TiMe::Default()) const { return getFloatList("diffuse_positions", time); }
9879
9883 bool set_diffuse_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("diffuse_interpolations", intList, time); }
9884 bool set_diffuse_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("diffuse_interpolations", std::move(intList), time); }
9885 bool set_diffuse_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("diffuse_interpolations", ints, count, time); }
9886 template<size_t count> bool set_diffuse_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("diffuse_interpolations", ints, count, time); }
9890 IntList get_diffuse_interpolations(double time = TiMe::Default()) const { return getIntList("diffuse_interpolations", time); }
9891
9894 bool set_diffuse_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("diffuse_colors", textureList, time); }
9895 bool set_diffuse_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("diffuse_colors", std::move(textureList), time); }
9896 bool set_diffuse_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("diffuse_colors", textures, count, time); }
9897 template<size_t count> bool set_diffuse_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("diffuse_colors", textures, count, time); }
9898 template<size_t count> bool set_diffuse_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("diffuse_colors", textures, count, time); }
9901 ValueList get_diffuse_colors(double time = TiMe::Default()) const { return getValueList("diffuse_colors", time); }
9902
9905 bool set_diffuse_gradient_external(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("diffuse_gradient_external", plugin, time); }
9908 PluginRef get_diffuse_gradient_external(double time = TiMe::Default()) const { return getPlugin("diffuse_gradient_external", time); }
9909
9913 bool set_diffuse_gradation_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_gradation_offset", texturefloat, time); }
9917 bool set_diffuse_gradation_offset(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_gradation_offset", texturefloat, time); }
9921 Value get_diffuse_gradation_offset(double time = TiMe::Default()) const { return getValue("diffuse_gradation_offset", time); }
9922
9926 bool set_diffuse_output_offset(float val, double time = TiMe::Default()) { return setValue("diffuse_output_offset", val, time); }
9930 float get_diffuse_output_offset(double time = TiMe::Default()) const { return getFloat("diffuse_output_offset", time); }
9931
9935 bool set_specular_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("specular_positions", floatList, time); }
9936 bool set_specular_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("specular_positions", std::move(floatList), time); }
9937 bool set_specular_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("specular_positions", floats, count, time); }
9938 template<size_t count> bool set_specular_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("specular_positions", floats, count, time); }
9942 FloatList get_specular_positions(double time = TiMe::Default()) const { return getFloatList("specular_positions", time); }
9943
9947 bool set_specular_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("specular_interpolations", intList, time); }
9948 bool set_specular_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("specular_interpolations", std::move(intList), time); }
9949 bool set_specular_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("specular_interpolations", ints, count, time); }
9950 template<size_t count> bool set_specular_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("specular_interpolations", ints, count, time); }
9954 IntList get_specular_interpolations(double time = TiMe::Default()) const { return getIntList("specular_interpolations", time); }
9955
9958 bool set_specular_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("specular_colors", textureList, time); }
9959 bool set_specular_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("specular_colors", std::move(textureList), time); }
9960 bool set_specular_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("specular_colors", textures, count, time); }
9961 template<size_t count> bool set_specular_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("specular_colors", textures, count, time); }
9962 template<size_t count> bool set_specular_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("specular_colors", textures, count, time); }
9965 ValueList get_specular_colors(double time = TiMe::Default()) const { return getValueList("specular_colors", time); }
9966
9969 bool set_specular_gradient_external(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("specular_gradient_external", plugin, time); }
9972 PluginRef get_specular_gradient_external(double time = TiMe::Default()) const { return getPlugin("specular_gradient_external", time); }
9973
9977 bool set_shadow_override_on(bool val, double time = TiMe::Default()) { return setValue("shadow_override_on", val, time); }
9981 bool get_shadow_override_on(double time = TiMe::Default()) const { return getBool("shadow_override_on", time); }
9982
9986 bool set_shadow_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadow_color", texture, time); }
9990 bool set_shadow_color(const AColor& texture, double time = TiMe::Default()) { return setValue("shadow_color", texture, time); }
9994 Value get_shadow_color(double time = TiMe::Default()) const { return getValue("shadow_color", time); }
9995
9999 bool set_shadow_opacity(float val, double time = TiMe::Default()) { return setValue("shadow_opacity", val, time); }
10003 float get_shadow_opacity(double time = TiMe::Default()) const { return getFloat("shadow_opacity", time); }
10004
10008 bool set_light_override_on(bool val, double time = TiMe::Default()) { return setValue("light_override_on", val, time); }
10012 bool get_light_override_on(double time = TiMe::Default()) const { return getBool("light_override_on", time); }
10013
10017 bool set_light_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("light_color", texture, time); }
10021 bool set_light_color(const AColor& texture, double time = TiMe::Default()) { return setValue("light_color", texture, time); }
10025 Value get_light_color(double time = TiMe::Default()) const { return getValue("light_color", time); }
10026
10030 bool set_light_blend_mode(int val, double time = TiMe::Default()) { return setValue("light_blend_mode", val, time); }
10034 int get_light_blend_mode(double time = TiMe::Default()) const { return getInt("light_blend_mode", time); }
10035
10039 bool set_light_blend_intensity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("light_blend_intensity", texturefloat, time); }
10043 bool set_light_blend_intensity(float texturefloat, double time = TiMe::Default()) { return setValue("light_blend_intensity", texturefloat, time); }
10047 Value get_light_blend_intensity(double time = TiMe::Default()) const { return getValue("light_blend_intensity", time); }
10048
10052 bool set_highlight_type(int val, double time = TiMe::Default()) { return setValue("highlight_type", val, time); }
10056 int get_highlight_type(double time = TiMe::Default()) const { return getInt("highlight_type", time); }
10057
10061 bool set_highlight_mask(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("highlight_mask", texturefloat, time); }
10065 bool set_highlight_mask(float texturefloat, double time = TiMe::Default()) { return setValue("highlight_mask", texturefloat, time); }
10069 Value get_highlight_mask(double time = TiMe::Default()) const { return getValue("highlight_mask", time); }
10070
10074 bool set_highlight_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("highlight_positions", floatList, time); }
10075 bool set_highlight_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("highlight_positions", std::move(floatList), time); }
10076 bool set_highlight_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("highlight_positions", floats, count, time); }
10077 template<size_t count> bool set_highlight_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("highlight_positions", floats, count, time); }
10081 FloatList get_highlight_positions(double time = TiMe::Default()) const { return getFloatList("highlight_positions", time); }
10082
10086 bool set_highlight_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("highlight_interpolations", intList, time); }
10087 bool set_highlight_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("highlight_interpolations", std::move(intList), time); }
10088 bool set_highlight_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("highlight_interpolations", ints, count, time); }
10089 template<size_t count> bool set_highlight_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("highlight_interpolations", ints, count, time); }
10093 IntList get_highlight_interpolations(double time = TiMe::Default()) const { return getIntList("highlight_interpolations", time); }
10094
10097 bool set_highlight_values(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("highlight_values", texturefloatList, time); }
10098 bool set_highlight_values(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("highlight_values", std::move(texturefloatList), time); }
10099 bool set_highlight_values(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("highlight_values", texturefloats, count, time); }
10100 template<size_t count> bool set_highlight_values(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("highlight_values", texturefloats, count, time); }
10101 template<size_t count> bool set_highlight_values(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("highlight_values", texturefloats, count, time); }
10104 ValueList get_highlight_values(double time = TiMe::Default()) const { return getValueList("highlight_values", time); }
10105
10108 bool set_highlight_shape_external(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("highlight_shape_external", plugin, time); }
10111 PluginRef get_highlight_shape_external(double time = TiMe::Default()) const { return getPlugin("highlight_shape_external", time); }
10112
10116 bool set_highlight_split_g1(float val, double time = TiMe::Default()) { return setValue("highlight_split_g1", val, time); }
10120 float get_highlight_split_g1(double time = TiMe::Default()) const { return getFloat("highlight_split_g1", time); }
10121
10125 bool set_highlight_split_g2(float val, double time = TiMe::Default()) { return setValue("highlight_split_g2", val, time); }
10129 float get_highlight_split_g2(double time = TiMe::Default()) const { return getFloat("highlight_split_g2", time); }
10130
10134 bool set_highlight_rotation(float val, double time = TiMe::Default()) { return setValue("highlight_rotation", val, time); }
10138 float get_highlight_rotation(double time = TiMe::Default()) const { return getFloat("highlight_rotation", time); }
10139
10143 bool set_transparency_source(int val, double time = TiMe::Default()) { return setValue("transparency_source", val, time); }
10147 int get_transparency_source(double time = TiMe::Default()) const { return getInt("transparency_source", time); }
10148
10152 bool set_transparency_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("transparency_ids", intList, time); }
10153 bool set_transparency_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("transparency_ids", std::move(intList), time); }
10154 bool set_transparency_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("transparency_ids", ints, count, time); }
10155 template<size_t count> bool set_transparency_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("transparency_ids", ints, count, time); }
10159 IntList get_transparency_ids(double time = TiMe::Default()) const { return getIntList("transparency_ids", time); }
10160
10163 bool set_transparency_values(const ValueList& textureList, double time = TiMe::Default()) { return setValue("transparency_values", textureList, time); }
10164 bool set_transparency_values(ValueList&& textureList, double time = TiMe::Default()) { return setValue("transparency_values", std::move(textureList), time); }
10165 bool set_transparency_values(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("transparency_values", textures, count, time); }
10166 template<size_t count> bool set_transparency_values(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("transparency_values", textures, count, time); }
10167 template<size_t count> bool set_transparency_values(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("transparency_values", textures, count, time); }
10170 ValueList get_transparency_values(double time = TiMe::Default()) const { return getValueList("transparency_values", time); }
10171
10175 bool set_toon_edge_override_on(bool val, double time = TiMe::Default()) { return setValue("toon_edge_override_on", val, time); }
10179 bool get_toon_edge_override_on(double time = TiMe::Default()) const { return getBool("toon_edge_override_on", time); }
10180
10184 bool set_toon_edge_priority(int val, double time = TiMe::Default()) { return setValue("toon_edge_priority", val, time); }
10188 int get_toon_edge_priority(double time = TiMe::Default()) const { return getInt("toon_edge_priority", time); }
10189
10192 bool set_lineColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("lineColor_tex", texture, time); }
10195 bool set_lineColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("lineColor_tex", texture, time); }
10198 Value get_lineColor_tex(double time = TiMe::Default()) const { return getValue("lineColor_tex", time); }
10199
10202 bool set_lineWidth_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("lineWidth_tex", texturefloat, time); }
10205 bool set_lineWidth_tex(float texturefloat, double time = TiMe::Default()) { return setValue("lineWidth_tex", texturefloat, time); }
10208 Value get_lineWidth_tex(double time = TiMe::Default()) const { return getValue("lineWidth_tex", time); }
10209
10213 bool set_innerLineControl(bool val, double time = TiMe::Default()) { return setValue("innerLineControl", val, time); }
10217 bool get_innerLineControl(double time = TiMe::Default()) const { return getBool("innerLineControl", time); }
10218
10221 bool set_lineColorInner_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("lineColorInner_tex", texture, time); }
10224 bool set_lineColorInner_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("lineColorInner_tex", texture, time); }
10227 Value get_lineColorInner_tex(double time = TiMe::Default()) const { return getValue("lineColorInner_tex", time); }
10228
10231 bool set_lineWidthInner_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("lineWidthInner_tex", texturefloat, time); }
10234 bool set_lineWidthInner_tex(float texturefloat, double time = TiMe::Default()) { return setValue("lineWidthInner_tex", texturefloat, time); }
10237 Value get_lineWidthInner_tex(double time = TiMe::Default()) const { return getValue("lineWidthInner_tex", time); }
10238
10242 bool set_outerOverlapThreshold_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("outerOverlapThreshold_tex", texturefloat, time); }
10246 bool set_outerOverlapThreshold_tex(float texturefloat, double time = TiMe::Default()) { return setValue("outerOverlapThreshold_tex", texturefloat, time); }
10250 Value get_outerOverlapThreshold_tex(double time = TiMe::Default()) const { return getValue("outerOverlapThreshold_tex", time); }
10251
10255 bool set_normalThreshold_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("normalThreshold_tex", texturefloat, time); }
10259 bool set_normalThreshold_tex(float texturefloat, double time = TiMe::Default()) { return setValue("normalThreshold_tex", texturefloat, time); }
10263 Value get_normalThreshold_tex(double time = TiMe::Default()) const { return getValue("normalThreshold_tex", time); }
10264
10268 bool set_overlapThreshold_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("overlapThreshold_tex", texturefloat, time); }
10272 bool set_overlapThreshold_tex(float texturefloat, double time = TiMe::Default()) { return setValue("overlapThreshold_tex", texturefloat, time); }
10276 Value get_overlapThreshold_tex(double time = TiMe::Default()) const { return getValue("overlapThreshold_tex", time); }
10277
10281 bool set_maskColorThreshold(float val, double time = TiMe::Default()) { return setValue("maskColorThreshold", val, time); }
10285 float get_maskColorThreshold(double time = TiMe::Default()) const { return getFloat("maskColorThreshold", time); }
10286
10289 bool set_maskColor(const PluginRef& texture, double time = TiMe::Default()) { return setValue("maskColor", texture, time); }
10292 bool set_maskColor(const AColor& texture, double time = TiMe::Default()) { return setValue("maskColor", texture, time); }
10295 Value get_maskColor(double time = TiMe::Default()) const { return getValue("maskColor", time); }
10296};
10297
10299class BRDFToonOverride : public Plugin {
10300public:
10302 static constexpr const PluginTypeId getTypeId() { return 0x2F0864900B; }
10304 static constexpr const char* getType() { return "BRDFToonOverride"; }
10305
10306 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
10307
10310 bool set_base_brdf(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_brdf", plugin, time); }
10313 PluginRef get_base_brdf(double time = TiMe::Default()) const { return getPlugin("base_brdf", time); }
10314
10318 bool set_lineColor(const Color& color, double time = TiMe::Default()) { return setValue("lineColor", color, time); }
10322 Color get_lineColor(double time = TiMe::Default()) const { return getColor("lineColor", time); }
10323
10326 bool set_lineColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("lineColor_tex", texture, time); }
10329 bool set_lineColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("lineColor_tex", texture, time); }
10332 Value get_lineColor_tex(double time = TiMe::Default()) const { return getValue("lineColor_tex", time); }
10333
10337 bool set_lineWidth(float val, double time = TiMe::Default()) { return setValue("lineWidth", val, time); }
10341 float get_lineWidth(double time = TiMe::Default()) const { return getFloat("lineWidth", time); }
10342
10345 bool set_lineWidth_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("lineWidth_tex", texturefloat, time); }
10348 bool set_lineWidth_tex(float texturefloat, double time = TiMe::Default()) { return setValue("lineWidth_tex", texturefloat, time); }
10351 Value get_lineWidth_tex(double time = TiMe::Default()) const { return getValue("lineWidth_tex", time); }
10352
10356 bool set_innerLineControl(bool val, double time = TiMe::Default()) { return setValue("innerLineControl", val, time); }
10360 bool get_innerLineControl(double time = TiMe::Default()) const { return getBool("innerLineControl", time); }
10361
10365 bool set_lineColorInner(const Color& color, double time = TiMe::Default()) { return setValue("lineColorInner", color, time); }
10369 Color get_lineColorInner(double time = TiMe::Default()) const { return getColor("lineColorInner", time); }
10370
10373 bool set_lineColorInner_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("lineColorInner_tex", texture, time); }
10376 bool set_lineColorInner_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("lineColorInner_tex", texture, time); }
10379 Value get_lineColorInner_tex(double time = TiMe::Default()) const { return getValue("lineColorInner_tex", time); }
10380
10384 bool set_lineWidthInner(float val, double time = TiMe::Default()) { return setValue("lineWidthInner", val, time); }
10388 float get_lineWidthInner(double time = TiMe::Default()) const { return getFloat("lineWidthInner", time); }
10389
10392 bool set_lineWidthInner_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("lineWidthInner_tex", texturefloat, time); }
10395 bool set_lineWidthInner_tex(float texturefloat, double time = TiMe::Default()) { return setValue("lineWidthInner_tex", texturefloat, time); }
10398 Value get_lineWidthInner_tex(double time = TiMe::Default()) const { return getValue("lineWidthInner_tex", time); }
10399
10403 bool set_outerOverlapThreshold(float val, double time = TiMe::Default()) { return setValue("outerOverlapThreshold", val, time); }
10407 float get_outerOverlapThreshold(double time = TiMe::Default()) const { return getFloat("outerOverlapThreshold", time); }
10408
10412 bool set_normalThreshold(float val, double time = TiMe::Default()) { return setValue("normalThreshold", val, time); }
10416 float get_normalThreshold(double time = TiMe::Default()) const { return getFloat("normalThreshold", time); }
10417
10421 bool set_overlapThreshold(float val, double time = TiMe::Default()) { return setValue("overlapThreshold", val, time); }
10425 float get_overlapThreshold(double time = TiMe::Default()) const { return getFloat("overlapThreshold", time); }
10426
10430 bool set_opacity(float val, double time = TiMe::Default()) { return setValue("opacity", val, time); }
10434 float get_opacity(double time = TiMe::Default()) const { return getFloat("opacity", time); }
10435
10438 bool set_opacity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacity_tex", texturefloat, time); }
10441 bool set_opacity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("opacity_tex", texturefloat, time); }
10444 Value get_opacity_tex(double time = TiMe::Default()) const { return getValue("opacity_tex", time); }
10445};
10446
10448class BRDFVRayMtl : public Plugin {
10449public:
10451 static constexpr const PluginTypeId getTypeId() { return 0x77BF8D7F; }
10453 static constexpr const char* getType() { return "BRDFVRayMtl"; }
10454
10455 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
10456
10460 bool set_opacity_source(int val, double time = TiMe::Default()) { return setValue("opacity_source", val, time); }
10464 int get_opacity_source(double time = TiMe::Default()) const { return getInt("opacity_source", time); }
10465
10469 bool set_opacity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
10473 bool set_opacity(float texturefloat, double time = TiMe::Default()) { return setValue("opacity", texturefloat, time); }
10477 Value get_opacity(double time = TiMe::Default()) const { return getValue("opacity", time); }
10478
10482 bool set_opacity_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("opacity_color", texture, time); }
10486 bool set_opacity_color(const AColor& texture, double time = TiMe::Default()) { return setValue("opacity_color", texture, time); }
10490 Value get_opacity_color(double time = TiMe::Default()) const { return getValue("opacity_color", time); }
10491
10495 bool set_opacity_mode(int val, double time = TiMe::Default()) { return setValue("opacity_mode", val, time); }
10499 int get_opacity_mode(double time = TiMe::Default()) const { return getInt("opacity_mode", time); }
10500
10504 bool set_diffuse(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse", texture, time); }
10508 bool set_diffuse(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse", texture, time); }
10512 Value get_diffuse(double time = TiMe::Default()) const { return getValue("diffuse", time); }
10513
10517 bool set_roughness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
10521 bool set_roughness(float texturefloat, double time = TiMe::Default()) { return setValue("roughness", texturefloat, time); }
10525 Value get_roughness(double time = TiMe::Default()) const { return getValue("roughness", time); }
10526
10530 bool set_roughness_model(int val, double time = TiMe::Default()) { return setValue("roughness_model", val, time); }
10534 int get_roughness_model(double time = TiMe::Default()) const { return getInt("roughness_model", time); }
10535
10539 bool set_self_illumination(const PluginRef& texture, double time = TiMe::Default()) { return setValue("self_illumination", texture, time); }
10543 bool set_self_illumination(const AColor& texture, double time = TiMe::Default()) { return setValue("self_illumination", texture, time); }
10547 Value get_self_illumination(double time = TiMe::Default()) const { return getValue("self_illumination", time); }
10548
10552 bool set_self_illumination_gi(bool val, double time = TiMe::Default()) { return setValue("self_illumination_gi", val, time); }
10556 bool get_self_illumination_gi(double time = TiMe::Default()) const { return getBool("self_illumination_gi", time); }
10557
10561 bool set_compensate_camera_exposure(bool val, double time = TiMe::Default()) { return setValue("compensate_camera_exposure", val, time); }
10565 bool get_compensate_camera_exposure(double time = TiMe::Default()) const { return getBool("compensate_camera_exposure", time); }
10566
10570 bool set_brdf_type(int val, double time = TiMe::Default()) { return setValue("brdf_type", val, time); }
10574 int get_brdf_type(double time = TiMe::Default()) const { return getInt("brdf_type", time); }
10575
10579 bool set_reflect(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect", texture, time); }
10583 bool set_reflect(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect", texture, time); }
10587 Value get_reflect(double time = TiMe::Default()) const { return getValue("reflect", time); }
10588
10592 bool set_reflect_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect_glossiness", texturefloat, time); }
10596 bool set_reflect_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("reflect_glossiness", texturefloat, time); }
10600 Value get_reflect_glossiness(double time = TiMe::Default()) const { return getValue("reflect_glossiness", time); }
10601
10605 bool set_hilight_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
10609 bool set_hilight_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("hilight_glossiness", texturefloat, time); }
10613 Value get_hilight_glossiness(double time = TiMe::Default()) const { return getValue("hilight_glossiness", time); }
10614
10618 bool set_hilight_glossiness_lock(bool val, double time = TiMe::Default()) { return setValue("hilight_glossiness_lock", val, time); }
10622 bool get_hilight_glossiness_lock(double time = TiMe::Default()) const { return getBool("hilight_glossiness_lock", time); }
10623
10627 bool set_gtr_gamma(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gtr_gamma", texturefloat, time); }
10631 bool set_gtr_gamma(float texturefloat, double time = TiMe::Default()) { return setValue("gtr_gamma", texturefloat, time); }
10635 Value get_gtr_gamma(double time = TiMe::Default()) const { return getValue("gtr_gamma", time); }
10636
10640 bool set_fresnel(bool val, double time = TiMe::Default()) { return setValue("fresnel", val, time); }
10644 bool get_fresnel(double time = TiMe::Default()) const { return getBool("fresnel", time); }
10645
10649 bool set_fresnel_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("fresnel_ior", texturefloat, time); }
10653 bool set_fresnel_ior(float texturefloat, double time = TiMe::Default()) { return setValue("fresnel_ior", texturefloat, time); }
10657 Value get_fresnel_ior(double time = TiMe::Default()) const { return getValue("fresnel_ior", time); }
10658
10662 bool set_fresnel_ior_lock(bool val, double time = TiMe::Default()) { return setValue("fresnel_ior_lock", val, time); }
10666 bool get_fresnel_ior_lock(double time = TiMe::Default()) const { return getBool("fresnel_ior_lock", time); }
10667
10671 bool set_metalness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("metalness", texturefloat, time); }
10675 bool set_metalness(float texturefloat, double time = TiMe::Default()) { return setValue("metalness", texturefloat, time); }
10679 Value get_metalness(double time = TiMe::Default()) const { return getValue("metalness", time); }
10680
10684 bool set_gtr_energy_compensation(int val, double time = TiMe::Default()) { return setValue("gtr_energy_compensation", val, time); }
10688 int get_gtr_energy_compensation(double time = TiMe::Default()) const { return getInt("gtr_energy_compensation", time); }
10689
10693 bool set_reflect_subdivs(int val, double time = TiMe::Default()) { return setValue("reflect_subdivs", val, time); }
10697 int get_reflect_subdivs(double time = TiMe::Default()) const { return getInt("reflect_subdivs", time); }
10698
10702 bool set_reflect_trace(bool val, double time = TiMe::Default()) { return setValue("reflect_trace", val, time); }
10706 bool get_reflect_trace(double time = TiMe::Default()) const { return getBool("reflect_trace", time); }
10707
10711 bool set_reflect_depth(int val, double time = TiMe::Default()) { return setValue("reflect_depth", val, time); }
10715 int get_reflect_depth(double time = TiMe::Default()) const { return getInt("reflect_depth", time); }
10716
10720 bool set_reflect_exit_color(const Color& color, double time = TiMe::Default()) { return setValue("reflect_exit_color", color, time); }
10724 Color get_reflect_exit_color(double time = TiMe::Default()) const { return getColor("reflect_exit_color", time); }
10725
10729 bool set_hilight_soften(float val, double time = TiMe::Default()) { return setValue("hilight_soften", val, time); }
10733 float get_hilight_soften(double time = TiMe::Default()) const { return getFloat("hilight_soften", time); }
10734
10738 bool set_reflect_affect_alpha(int val, double time = TiMe::Default()) { return setValue("reflect_affect_alpha", val, time); }
10742 int get_reflect_affect_alpha(double time = TiMe::Default()) const { return getInt("reflect_affect_alpha", time); }
10743
10747 bool set_reflect_weight(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflect_weight", texturefloat, time); }
10751 bool set_reflect_weight(float texturefloat, double time = TiMe::Default()) { return setValue("reflect_weight", texturefloat, time); }
10755 Value get_reflect_weight(double time = TiMe::Default()) const { return getValue("reflect_weight", time); }
10756
10760 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
10764 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
10765
10769 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
10773 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
10774
10778 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
10782 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
10783
10787 bool set_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
10791 bool set_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
10795 Value get_anisotropy(double time = TiMe::Default()) const { return getValue("anisotropy", time); }
10796
10800 bool set_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
10804 bool set_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
10808 Value get_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("anisotropy_rotation", time); }
10809
10813 bool set_anisotropy_derivation(int val, double time = TiMe::Default()) { return setValue("anisotropy_derivation", val, time); }
10817 int get_anisotropy_derivation(double time = TiMe::Default()) const { return getInt("anisotropy_derivation", time); }
10818
10822 bool set_anisotropy_axis(int val, double time = TiMe::Default()) { return setValue("anisotropy_axis", val, time); }
10826 int get_anisotropy_axis(double time = TiMe::Default()) const { return getInt("anisotropy_axis", time); }
10827
10830 bool set_anisotropy_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("anisotropy_uvwgen", plugin, time); }
10833 PluginRef get_anisotropy_uvwgen(double time = TiMe::Default()) const { return getPlugin("anisotropy_uvwgen", time); }
10834
10838 bool set_new_gtr_anisotropy(bool val, double time = TiMe::Default()) { return setValue("new_gtr_anisotropy", val, time); }
10842 bool get_new_gtr_anisotropy(double time = TiMe::Default()) const { return getBool("new_gtr_anisotropy", time); }
10843
10847 bool set_thin_film_on(bool val, double time = TiMe::Default()) { return setValue("thin_film_on", val, time); }
10851 bool get_thin_film_on(double time = TiMe::Default()) const { return getBool("thin_film_on", time); }
10852
10856 bool set_thin_film_thickness_min(float val, double time = TiMe::Default()) { return setValue("thin_film_thickness_min", val, time); }
10860 float get_thin_film_thickness_min(double time = TiMe::Default()) const { return getFloat("thin_film_thickness_min", time); }
10861
10865 bool set_thin_film_thickness_max(float val, double time = TiMe::Default()) { return setValue("thin_film_thickness_max", val, time); }
10869 float get_thin_film_thickness_max(double time = TiMe::Default()) const { return getFloat("thin_film_thickness_max", time); }
10870
10874 bool set_thin_film_thickness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("thin_film_thickness", texturefloat, time); }
10878 bool set_thin_film_thickness(float texturefloat, double time = TiMe::Default()) { return setValue("thin_film_thickness", texturefloat, time); }
10882 Value get_thin_film_thickness(double time = TiMe::Default()) const { return getValue("thin_film_thickness", time); }
10883
10887 bool set_thin_film_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("thin_film_ior", texturefloat, time); }
10891 bool set_thin_film_ior(float texturefloat, double time = TiMe::Default()) { return setValue("thin_film_ior", texturefloat, time); }
10895 Value get_thin_film_ior(double time = TiMe::Default()) const { return getValue("thin_film_ior", time); }
10896
10900 bool set_refract(const PluginRef& texture, double time = TiMe::Default()) { return setValue("refract", texture, time); }
10904 bool set_refract(const AColor& texture, double time = TiMe::Default()) { return setValue("refract", texture, time); }
10908 Value get_refract(double time = TiMe::Default()) const { return getValue("refract", time); }
10909
10913 bool set_refract_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("refract_ior", texturefloat, time); }
10917 bool set_refract_ior(float texturefloat, double time = TiMe::Default()) { return setValue("refract_ior", texturefloat, time); }
10921 Value get_refract_ior(double time = TiMe::Default()) const { return getValue("refract_ior", time); }
10922
10926 bool set_refract_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("refract_glossiness", texturefloat, time); }
10930 bool set_refract_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("refract_glossiness", texturefloat, time); }
10934 Value get_refract_glossiness(double time = TiMe::Default()) const { return getValue("refract_glossiness", time); }
10935
10939 bool set_refract_subdivs(int val, double time = TiMe::Default()) { return setValue("refract_subdivs", val, time); }
10943 int get_refract_subdivs(double time = TiMe::Default()) const { return getInt("refract_subdivs", time); }
10944
10948 bool set_refract_trace(bool val, double time = TiMe::Default()) { return setValue("refract_trace", val, time); }
10952 bool get_refract_trace(double time = TiMe::Default()) const { return getBool("refract_trace", time); }
10953
10957 bool set_refract_depth(int val, double time = TiMe::Default()) { return setValue("refract_depth", val, time); }
10961 int get_refract_depth(double time = TiMe::Default()) const { return getInt("refract_depth", time); }
10962
10966 bool set_refract_exit_color_on(bool val, double time = TiMe::Default()) { return setValue("refract_exit_color_on", val, time); }
10970 bool get_refract_exit_color_on(double time = TiMe::Default()) const { return getBool("refract_exit_color_on", time); }
10971
10975 bool set_refract_exit_color(const Color& color, double time = TiMe::Default()) { return setValue("refract_exit_color", color, time); }
10979 Color get_refract_exit_color(double time = TiMe::Default()) const { return getColor("refract_exit_color", time); }
10980
10984 bool set_refract_affect_alpha(int val, double time = TiMe::Default()) { return setValue("refract_affect_alpha", val, time); }
10988 int get_refract_affect_alpha(double time = TiMe::Default()) const { return getInt("refract_affect_alpha", time); }
10989
10993 bool set_refract_affect_shadows(bool val, double time = TiMe::Default()) { return setValue("refract_affect_shadows", val, time); }
10997 bool get_refract_affect_shadows(double time = TiMe::Default()) const { return getBool("refract_affect_shadows", time); }
10998
11002 bool set_dispersion_on(bool val, double time = TiMe::Default()) { return setValue("dispersion_on", val, time); }
11006 bool get_dispersion_on(double time = TiMe::Default()) const { return getBool("dispersion_on", time); }
11007
11011 bool set_dispersion(float val, double time = TiMe::Default()) { return setValue("dispersion", val, time); }
11015 float get_dispersion(double time = TiMe::Default()) const { return getFloat("dispersion", time); }
11016
11020 bool set_refract_thin_walled(bool val, double time = TiMe::Default()) { return setValue("refract_thin_walled", val, time); }
11024 bool get_refract_thin_walled(double time = TiMe::Default()) const { return getBool("refract_thin_walled", time); }
11025
11029 bool set_fog_color(const Color& color, double time = TiMe::Default()) { return setValue("fog_color", color, time); }
11033 Color get_fog_color(double time = TiMe::Default()) const { return getColor("fog_color", time); }
11034
11037 bool set_fog_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("fog_color_tex", texture, time); }
11040 bool set_fog_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("fog_color_tex", texture, time); }
11043 Value get_fog_color_tex(double time = TiMe::Default()) const { return getValue("fog_color_tex", time); }
11044
11048 bool set_fog_mult(float val, double time = TiMe::Default()) { return setValue("fog_mult", val, time); }
11052 float get_fog_mult(double time = TiMe::Default()) const { return getFloat("fog_mult", time); }
11053
11057 bool set_fog_depth(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("fog_depth", texturefloat, time); }
11061 bool set_fog_depth(float texturefloat, double time = TiMe::Default()) { return setValue("fog_depth", texturefloat, time); }
11065 Value get_fog_depth(double time = TiMe::Default()) const { return getValue("fog_depth", time); }
11066
11070 bool set_fog_bias(float val, double time = TiMe::Default()) { return setValue("fog_bias", val, time); }
11074 float get_fog_bias(double time = TiMe::Default()) const { return getFloat("fog_bias", time); }
11075
11079 bool set_fog_unit_scale_on(bool val, double time = TiMe::Default()) { return setValue("fog_unit_scale_on", val, time); }
11083 bool get_fog_unit_scale_on(double time = TiMe::Default()) const { return getBool("fog_unit_scale_on", time); }
11084
11088 bool set_translucency(int val, double time = TiMe::Default()) { return setValue("translucency", val, time); }
11092 int get_translucency(double time = TiMe::Default()) const { return getInt("translucency", time); }
11093
11097 bool set_translucency_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("translucency_color", texture, time); }
11101 bool set_translucency_color(const AColor& texture, double time = TiMe::Default()) { return setValue("translucency_color", texture, time); }
11105 Value get_translucency_color(double time = TiMe::Default()) const { return getValue("translucency_color", time); }
11106
11110 bool set_translucency_light_mult(float val, double time = TiMe::Default()) { return setValue("translucency_light_mult", val, time); }
11114 float get_translucency_light_mult(double time = TiMe::Default()) const { return getFloat("translucency_light_mult", time); }
11115
11119 bool set_translucency_scatter_dir(float val, double time = TiMe::Default()) { return setValue("translucency_scatter_dir", val, time); }
11123 float get_translucency_scatter_dir(double time = TiMe::Default()) const { return getFloat("translucency_scatter_dir", time); }
11124
11128 bool set_translucency_scatter_coeff(float val, double time = TiMe::Default()) { return setValue("translucency_scatter_coeff", val, time); }
11132 float get_translucency_scatter_coeff(double time = TiMe::Default()) const { return getFloat("translucency_scatter_coeff", time); }
11133
11137 bool set_translucency_thickness(float val, double time = TiMe::Default()) { return setValue("translucency_thickness", val, time); }
11141 float get_translucency_thickness(double time = TiMe::Default()) const { return getFloat("translucency_thickness", time); }
11142
11146 bool set_translucency_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("translucency_amount", texturefloat, time); }
11150 bool set_translucency_amount(float texturefloat, double time = TiMe::Default()) { return setValue("translucency_amount", texturefloat, time); }
11154 Value get_translucency_amount(double time = TiMe::Default()) const { return getValue("translucency_amount", time); }
11155
11159 bool set_translucency_surfaceLighting(int val, double time = TiMe::Default()) { return setValue("translucency_surfaceLighting", val, time); }
11163 int get_translucency_surfaceLighting(double time = TiMe::Default()) const { return getInt("translucency_surfaceLighting", time); }
11164
11168 bool set_option_shading_model(int val, double time = TiMe::Default()) { return setValue("option_shading_model", val, time); }
11172 int get_option_shading_model(double time = TiMe::Default()) const { return getInt("option_shading_model", time); }
11173
11177 bool set_option_double_sided(bool val, double time = TiMe::Default()) { return setValue("option_double_sided", val, time); }
11181 bool get_option_double_sided(double time = TiMe::Default()) const { return getBool("option_double_sided", time); }
11182
11186 bool set_option_reflect_on_back(bool val, double time = TiMe::Default()) { return setValue("option_reflect_on_back", val, time); }
11190 bool get_option_reflect_on_back(double time = TiMe::Default()) const { return getBool("option_reflect_on_back", time); }
11191
11195 bool set_option_glossy_rays_as_gi(int val, double time = TiMe::Default()) { return setValue("option_glossy_rays_as_gi", val, time); }
11199 int get_option_glossy_rays_as_gi(double time = TiMe::Default()) const { return getInt("option_glossy_rays_as_gi", time); }
11200
11204 bool set_option_cutoff(float val, double time = TiMe::Default()) { return setValue("option_cutoff", val, time); }
11208 float get_option_cutoff(double time = TiMe::Default()) const { return getFloat("option_cutoff", time); }
11209
11213 bool set_option_use_irradiance_map(bool val, double time = TiMe::Default()) { return setValue("option_use_irradiance_map", val, time); }
11217 bool get_option_use_irradiance_map(double time = TiMe::Default()) const { return getBool("option_use_irradiance_map", time); }
11218
11222 bool set_option_energy_mode(int val, double time = TiMe::Default()) { return setValue("option_energy_mode", val, time); }
11226 int get_option_energy_mode(double time = TiMe::Default()) const { return getInt("option_energy_mode", time); }
11227
11231 bool set_option_fix_dark_edges(bool val, double time = TiMe::Default()) { return setValue("option_fix_dark_edges", val, time); }
11235 bool get_option_fix_dark_edges(double time = TiMe::Default()) const { return getBool("option_fix_dark_edges", time); }
11236
11240 bool set_option_glossy_fresnel(bool val, double time = TiMe::Default()) { return setValue("option_glossy_fresnel", val, time); }
11244 bool get_option_glossy_fresnel(double time = TiMe::Default()) const { return getBool("option_glossy_fresnel", time); }
11245
11249 bool set_option_use_roughness(bool val, double time = TiMe::Default()) { return setValue("option_use_roughness", val, time); }
11253 bool get_option_use_roughness(double time = TiMe::Default()) const { return getBool("option_use_roughness", time); }
11254
11258 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
11262 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
11263
11266 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
11269 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
11272 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
11273
11277 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
11281 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
11282
11286 bool set_refl_interpolation_on(bool val, double time = TiMe::Default()) { return setValue("refl_interpolation_on", val, time); }
11290 bool get_refl_interpolation_on(double time = TiMe::Default()) const { return getBool("refl_interpolation_on", time); }
11291
11295 bool set_refl_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("refl_imap_min_rate", val, time); }
11299 int get_refl_imap_min_rate(double time = TiMe::Default()) const { return getInt("refl_imap_min_rate", time); }
11300
11304 bool set_refl_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("refl_imap_max_rate", val, time); }
11308 int get_refl_imap_max_rate(double time = TiMe::Default()) const { return getInt("refl_imap_max_rate", time); }
11309
11313 bool set_refl_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("refl_imap_color_thresh", val, time); }
11317 float get_refl_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("refl_imap_color_thresh", time); }
11318
11322 bool set_refl_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("refl_imap_norm_thresh", val, time); }
11326 float get_refl_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("refl_imap_norm_thresh", time); }
11327
11331 bool set_refl_imap_samples(int val, double time = TiMe::Default()) { return setValue("refl_imap_samples", val, time); }
11335 int get_refl_imap_samples(double time = TiMe::Default()) const { return getInt("refl_imap_samples", time); }
11336
11340 bool set_refr_interpolation_on(bool val, double time = TiMe::Default()) { return setValue("refr_interpolation_on", val, time); }
11344 bool get_refr_interpolation_on(double time = TiMe::Default()) const { return getBool("refr_interpolation_on", time); }
11345
11349 bool set_refr_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("refr_imap_min_rate", val, time); }
11353 int get_refr_imap_min_rate(double time = TiMe::Default()) const { return getInt("refr_imap_min_rate", time); }
11354
11358 bool set_refr_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("refr_imap_max_rate", val, time); }
11362 int get_refr_imap_max_rate(double time = TiMe::Default()) const { return getInt("refr_imap_max_rate", time); }
11363
11367 bool set_refr_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("refr_imap_color_thresh", val, time); }
11371 float get_refr_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("refr_imap_color_thresh", time); }
11372
11376 bool set_refr_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("refr_imap_norm_thresh", val, time); }
11380 float get_refr_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("refr_imap_norm_thresh", time); }
11381
11385 bool set_refr_imap_samples(int val, double time = TiMe::Default()) { return setValue("refr_imap_samples", val, time); }
11389 int get_refr_imap_samples(double time = TiMe::Default()) const { return getInt("refr_imap_samples", time); }
11390
11393 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
11394 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
11395 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
11398 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
11399
11402 bool set_volume(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("volume", plugin, time); }
11405 PluginRef get_volume(double time = TiMe::Default()) const { return getPlugin("volume", time); }
11406
11410 bool set_sheen_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sheen_color", texture, time); }
11414 bool set_sheen_color(const AColor& texture, double time = TiMe::Default()) { return setValue("sheen_color", texture, time); }
11418 Value get_sheen_color(double time = TiMe::Default()) const { return getValue("sheen_color", time); }
11419
11423 bool set_sheen_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sheen_amount", texturefloat, time); }
11427 bool set_sheen_amount(float texturefloat, double time = TiMe::Default()) { return setValue("sheen_amount", texturefloat, time); }
11431 Value get_sheen_amount(double time = TiMe::Default()) const { return getValue("sheen_amount", time); }
11432
11436 bool set_sheen_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sheen_glossiness", texturefloat, time); }
11440 bool set_sheen_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("sheen_glossiness", texturefloat, time); }
11444 Value get_sheen_glossiness(double time = TiMe::Default()) const { return getValue("sheen_glossiness", time); }
11445
11449 bool set_coat_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
11453 bool set_coat_color(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_color", texture, time); }
11457 Value get_coat_color(double time = TiMe::Default()) const { return getValue("coat_color", time); }
11458
11462 bool set_coat_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_amount", texturefloat, time); }
11466 bool set_coat_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_amount", texturefloat, time); }
11470 Value get_coat_amount(double time = TiMe::Default()) const { return getValue("coat_amount", time); }
11471
11475 bool set_coat_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
11479 bool set_coat_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("coat_glossiness", texturefloat, time); }
11483 Value get_coat_glossiness(double time = TiMe::Default()) const { return getValue("coat_glossiness", time); }
11484
11488 bool set_coat_ior(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_ior", texturefloat, time); }
11492 bool set_coat_ior(float texturefloat, double time = TiMe::Default()) { return setValue("coat_ior", texturefloat, time); }
11496 Value get_coat_ior(double time = TiMe::Default()) const { return getValue("coat_ior", time); }
11497
11501 bool set_coat_bump_lock(bool val, double time = TiMe::Default()) { return setValue("coat_bump_lock", val, time); }
11505 bool get_coat_bump_lock(double time = TiMe::Default()) const { return getBool("coat_bump_lock", time); }
11506
11510 bool set_coat_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy", texturefloat, time); }
11514 bool set_coat_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy", texturefloat, time); }
11518 Value get_coat_anisotropy(double time = TiMe::Default()) const { return getValue("coat_anisotropy", time); }
11519
11523 bool set_coat_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy_rotation", texturefloat, time); }
11527 bool set_coat_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("coat_anisotropy_rotation", texturefloat, time); }
11531 Value get_coat_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("coat_anisotropy_rotation", time); }
11532
11536 bool set_coat_darkening(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_darkening", texturefloat, time); }
11540 bool set_coat_darkening(float texturefloat, double time = TiMe::Default()) { return setValue("coat_darkening", texturefloat, time); }
11544 Value get_coat_darkening(double time = TiMe::Default()) const { return getValue("coat_darkening", time); }
11545
11549 bool set_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bump_map", texture, time); }
11553 bool set_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("bump_map", texture, time); }
11557 Value get_bump_map(double time = TiMe::Default()) const { return getValue("bump_map", time); }
11558
11562 bool set_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bump_amount", texturefloat, time); }
11566 bool set_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("bump_amount", texturefloat, time); }
11570 Value get_bump_amount(double time = TiMe::Default()) const { return getValue("bump_amount", time); }
11571
11575 bool set_bump_type(int val, double time = TiMe::Default()) { return setValue("bump_type", val, time); }
11579 int get_bump_type(double time = TiMe::Default()) const { return getInt("bump_type", time); }
11580
11584 bool set_coat_bump_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("coat_bump_map", texture, time); }
11588 bool set_coat_bump_map(const AColor& texture, double time = TiMe::Default()) { return setValue("coat_bump_map", texture, time); }
11592 Value get_coat_bump_map(double time = TiMe::Default()) const { return getValue("coat_bump_map", time); }
11593
11597 bool set_coat_bump_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
11601 bool set_coat_bump_amount(float texturefloat, double time = TiMe::Default()) { return setValue("coat_bump_amount", texturefloat, time); }
11605 Value get_coat_bump_amount(double time = TiMe::Default()) const { return getValue("coat_bump_amount", time); }
11606
11610 bool set_coat_bump_type(int val, double time = TiMe::Default()) { return setValue("coat_bump_type", val, time); }
11614 int get_coat_bump_type(double time = TiMe::Default()) const { return getInt("coat_bump_type", time); }
11615
11619 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
11623 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
11627 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
11628};
11629
11631class BRDFWard : public Plugin {
11632public:
11634 static constexpr const PluginTypeId getTypeId() { return 0x77A094F9; }
11636 static constexpr const char* getType() { return "BRDFWard"; }
11637
11638 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
11639
11643 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
11647 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
11648
11651 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
11654 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
11657 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
11658
11662 bool set_color_tex_mult(float val, double time = TiMe::Default()) { return setValue("color_tex_mult", val, time); }
11666 float get_color_tex_mult(double time = TiMe::Default()) const { return getFloat("color_tex_mult", time); }
11667
11671 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
11675 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
11676
11679 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
11682 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
11685 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
11686
11690 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
11694 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
11695
11699 bool set_cutoff(float val, double time = TiMe::Default()) { return setValue("cutoff", val, time); }
11703 float get_cutoff(double time = TiMe::Default()) const { return getFloat("cutoff", time); }
11704
11708 bool set_back_side(bool val, double time = TiMe::Default()) { return setValue("back_side", val, time); }
11712 bool get_back_side(double time = TiMe::Default()) const { return getBool("back_side", time); }
11713
11717 bool set_trace_reflections(bool val, double time = TiMe::Default()) { return setValue("trace_reflections", val, time); }
11721 bool get_trace_reflections(double time = TiMe::Default()) const { return getBool("trace_reflections", time); }
11722
11726 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
11730 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
11731
11735 bool set_affect_alpha(int val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
11739 int get_affect_alpha(double time = TiMe::Default()) const { return getInt("affect_alpha", time); }
11740
11744 bool set_reflect_exit_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
11748 bool set_reflect_exit_color(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_exit_color", texture, time); }
11752 Value get_reflect_exit_color(double time = TiMe::Default()) const { return getValue("reflect_exit_color", time); }
11753
11757 bool set_reflect_dim_distance_on(bool val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_on", val, time); }
11761 bool get_reflect_dim_distance_on(double time = TiMe::Default()) const { return getBool("reflect_dim_distance_on", time); }
11762
11766 bool set_reflect_dim_distance(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance", val, time); }
11770 float get_reflect_dim_distance(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance", time); }
11771
11775 bool set_reflect_dim_distance_falloff(float val, double time = TiMe::Default()) { return setValue("reflect_dim_distance_falloff", val, time); }
11779 float get_reflect_dim_distance_falloff(double time = TiMe::Default()) const { return getFloat("reflect_dim_distance_falloff", time); }
11780
11784 bool set_hilightGlossiness(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness", val, time); }
11788 float get_hilightGlossiness(double time = TiMe::Default()) const { return getFloat("hilightGlossiness", time); }
11789
11792 bool set_hilightGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
11795 bool set_hilightGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex", texturefloat, time); }
11798 Value get_hilightGlossiness_tex(double time = TiMe::Default()) const { return getValue("hilightGlossiness_tex", time); }
11799
11803 bool set_hilightGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("hilightGlossiness_tex_mult", val, time); }
11807 float get_hilightGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("hilightGlossiness_tex_mult", time); }
11808
11812 bool set_reflectionGlossiness(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness", val, time); }
11816 float get_reflectionGlossiness(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness", time); }
11817
11820 bool set_reflectionGlossiness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
11823 bool set_reflectionGlossiness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex", texturefloat, time); }
11826 Value get_reflectionGlossiness_tex(double time = TiMe::Default()) const { return getValue("reflectionGlossiness_tex", time); }
11827
11831 bool set_reflectionGlossiness_tex_mult(float val, double time = TiMe::Default()) { return setValue("reflectionGlossiness_tex_mult", val, time); }
11835 float get_reflectionGlossiness_tex_mult(double time = TiMe::Default()) const { return getFloat("reflectionGlossiness_tex_mult", time); }
11836
11840 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
11844 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
11845
11849 bool set_glossyAsGI(int val, double time = TiMe::Default()) { return setValue("glossyAsGI", val, time); }
11853 int get_glossyAsGI(double time = TiMe::Default()) const { return getInt("glossyAsGI", time); }
11854
11858 bool set_soften_edge(float val, double time = TiMe::Default()) { return setValue("soften_edge", val, time); }
11862 float get_soften_edge(double time = TiMe::Default()) const { return getFloat("soften_edge", time); }
11863
11867 bool set_interpolation_on(int val, double time = TiMe::Default()) { return setValue("interpolation_on", val, time); }
11871 int get_interpolation_on(double time = TiMe::Default()) const { return getInt("interpolation_on", time); }
11872
11876 bool set_imap_min_rate(int val, double time = TiMe::Default()) { return setValue("imap_min_rate", val, time); }
11880 int get_imap_min_rate(double time = TiMe::Default()) const { return getInt("imap_min_rate", time); }
11881
11885 bool set_imap_max_rate(int val, double time = TiMe::Default()) { return setValue("imap_max_rate", val, time); }
11889 int get_imap_max_rate(double time = TiMe::Default()) const { return getInt("imap_max_rate", time); }
11890
11894 bool set_imap_color_thresh(float val, double time = TiMe::Default()) { return setValue("imap_color_thresh", val, time); }
11898 float get_imap_color_thresh(double time = TiMe::Default()) const { return getFloat("imap_color_thresh", time); }
11899
11903 bool set_imap_norm_thresh(float val, double time = TiMe::Default()) { return setValue("imap_norm_thresh", val, time); }
11907 float get_imap_norm_thresh(double time = TiMe::Default()) const { return getFloat("imap_norm_thresh", time); }
11908
11912 bool set_imap_samples(int val, double time = TiMe::Default()) { return setValue("imap_samples", val, time); }
11916 int get_imap_samples(double time = TiMe::Default()) const { return getInt("imap_samples", time); }
11917
11921 bool set_anisotropy(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
11925 bool set_anisotropy(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy", texturefloat, time); }
11929 Value get_anisotropy(double time = TiMe::Default()) const { return getValue("anisotropy", time); }
11930
11933 bool set_anisotropy_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("anisotropy_uvwgen", plugin, time); }
11936 PluginRef get_anisotropy_uvwgen(double time = TiMe::Default()) const { return getPlugin("anisotropy_uvwgen", time); }
11937
11941 bool set_anisotropy_rotation(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
11945 bool set_anisotropy_rotation(float texturefloat, double time = TiMe::Default()) { return setValue("anisotropy_rotation", texturefloat, time); }
11949 Value get_anisotropy_rotation(double time = TiMe::Default()) const { return getValue("anisotropy_rotation", time); }
11950
11954 bool set_fix_dark_edges(bool val, double time = TiMe::Default()) { return setValue("fix_dark_edges", val, time); }
11958 bool get_fix_dark_edges(double time = TiMe::Default()) const { return getBool("fix_dark_edges", time); }
11959};
11960
11963public:
11965 static constexpr const PluginTypeId getTypeId() { return 0x780BD93A; }
11967 static constexpr const char* getType() { return "BSDFPointParticle"; }
11968
11969 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
11970
11973 bool set_diffuse_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
11976 bool set_diffuse_color(const AColor& texture, double time = TiMe::Default()) { return setValue("diffuse_color", texture, time); }
11979 Value get_diffuse_color(double time = TiMe::Default()) const { return getValue("diffuse_color", time); }
11980
11983 bool set_use_particle_color(bool val, double time = TiMe::Default()) { return setValue("use_particle_color", val, time); }
11986 bool get_use_particle_color(double time = TiMe::Default()) const { return getBool("use_particle_color", time); }
11987
11991 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
11995 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
11996};
11997
11999class BakeView : public Plugin {
12000public:
12002 static constexpr const PluginTypeId getTypeId() { return 0x77A17595; }
12004 static constexpr const char* getType() { return "BakeView"; }
12005
12006 operator ViewPluginCategory() { return *static_cast<ViewPluginCategory*>(static_cast<Plugin*>(this)); }
12007
12010 bool set_bake_node(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("bake_node", plugin, time); }
12013 PluginRef get_bake_node(double time = TiMe::Default()) const { return getPlugin("bake_node", time); }
12014
12017 bool set_target_nodes(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("target_nodes", pluginList, time); }
12018 bool set_target_nodes(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("target_nodes", plugins, count, time); }
12019 template<size_t count> bool set_target_nodes(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("target_nodes", plugins, count, time); }
12022 PluginList get_target_nodes(double time = TiMe::Default()) const { return getPluginList("target_nodes", time); }
12023
12026 bool set_bake_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("bake_uvwgen", plugin, time); }
12029 PluginRef get_bake_uvwgen(double time = TiMe::Default()) const { return getPlugin("bake_uvwgen", time); }
12030
12034 bool set_dilation(float val, double time = TiMe::Default()) { return setValue("dilation", val, time); }
12038 float get_dilation(double time = TiMe::Default()) const { return getFloat("dilation", time); }
12039
12043 bool set_flip_derivs(bool val, double time = TiMe::Default()) { return setValue("flip_derivs", val, time); }
12047 bool get_flip_derivs(double time = TiMe::Default()) const { return getBool("flip_derivs", time); }
12048
12052 bool set_u_min(float val, double time = TiMe::Default()) { return setValue("u_min", val, time); }
12056 float get_u_min(double time = TiMe::Default()) const { return getFloat("u_min", time); }
12057
12061 bool set_v_min(float val, double time = TiMe::Default()) { return setValue("v_min", val, time); }
12065 float get_v_min(double time = TiMe::Default()) const { return getFloat("v_min", time); }
12066
12070 bool set_u_max(float val, double time = TiMe::Default()) { return setValue("u_max", val, time); }
12074 float get_u_max(double time = TiMe::Default()) const { return getFloat("u_max", time); }
12075
12079 bool set_v_max(float val, double time = TiMe::Default()) { return setValue("v_max", val, time); }
12083 float get_v_max(double time = TiMe::Default()) const { return getFloat("v_max", time); }
12084
12088 bool set_uv_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("uv_transform", transform, time); }
12092 Transform get_uv_transform(double time = TiMe::Default()) const { return getTransform("uv_transform", time); }
12093
12097 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
12101 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
12102
12106 bool set_fov(float val, double time = TiMe::Default()) { return setValue("fov", val, time); }
12110 float get_fov(double time = TiMe::Default()) const { return getFloat("fov", time); }
12111
12115 bool set_projection_baking(int val, double time = TiMe::Default()) { return setValue("projection_baking", val, time); }
12119 int get_projection_baking(double time = TiMe::Default()) const { return getInt("projection_baking", time); }
12120
12124 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
12128 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
12129
12133 bool set_normal(int val, double time = TiMe::Default()) { return setValue("normal", val, time); }
12137 int get_normal(double time = TiMe::Default()) const { return getInt("normal", time); }
12138
12142 bool set_max_depth(float val, double time = TiMe::Default()) { return setValue("max_depth", val, time); }
12146 float get_max_depth(double time = TiMe::Default()) const { return getFloat("max_depth", time); }
12147
12151 bool set_ray_offset(float val, double time = TiMe::Default()) { return setValue("ray_offset", val, time); }
12155 float get_ray_offset(double time = TiMe::Default()) const { return getFloat("ray_offset", time); }
12156
12160 bool set_from_camera(int val, double time = TiMe::Default()) { return setValue("from_camera", val, time); }
12164 int get_from_camera(double time = TiMe::Default()) const { return getInt("from_camera", time); }
12165
12168 bool set_mapped_bake_nodes(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("mapped_bake_nodes", pluginList, time); }
12169 bool set_mapped_bake_nodes(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("mapped_bake_nodes", plugins, count, time); }
12170 template<size_t count> bool set_mapped_bake_nodes(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("mapped_bake_nodes", plugins, count, time); }
12173 PluginList get_mapped_bake_nodes(double time = TiMe::Default()) const { return getPluginList("mapped_bake_nodes", time); }
12174
12177 bool set_mapped_bake_uvwgens(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("mapped_bake_uvwgens", pluginList, time); }
12178 bool set_mapped_bake_uvwgens(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("mapped_bake_uvwgens", plugins, count, time); }
12179 template<size_t count> bool set_mapped_bake_uvwgens(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("mapped_bake_uvwgens", plugins, count, time); }
12182 PluginList get_mapped_bake_uvwgens(double time = TiMe::Default()) const { return getPluginList("mapped_bake_uvwgens", time); }
12183
12187 bool set_mapped_x0(const IntList& intList, double time = TiMe::Default()) { return setValue("mapped_x0", intList, time); }
12188 bool set_mapped_x0(IntList&& intList, double time = TiMe::Default()) { return setValue("mapped_x0", std::move(intList), time); }
12189 bool set_mapped_x0(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("mapped_x0", ints, count, time); }
12190 template<size_t count> bool set_mapped_x0(const int (&ints)[count], double time = TiMe::Default()) { return setArray("mapped_x0", ints, count, time); }
12194 IntList get_mapped_x0(double time = TiMe::Default()) const { return getIntList("mapped_x0", time); }
12195
12199 bool set_mapped_y0(const IntList& intList, double time = TiMe::Default()) { return setValue("mapped_y0", intList, time); }
12200 bool set_mapped_y0(IntList&& intList, double time = TiMe::Default()) { return setValue("mapped_y0", std::move(intList), time); }
12201 bool set_mapped_y0(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("mapped_y0", ints, count, time); }
12202 template<size_t count> bool set_mapped_y0(const int (&ints)[count], double time = TiMe::Default()) { return setArray("mapped_y0", ints, count, time); }
12206 IntList get_mapped_y0(double time = TiMe::Default()) const { return getIntList("mapped_y0", time); }
12207
12211 bool set_mapped_x1(const IntList& intList, double time = TiMe::Default()) { return setValue("mapped_x1", intList, time); }
12212 bool set_mapped_x1(IntList&& intList, double time = TiMe::Default()) { return setValue("mapped_x1", std::move(intList), time); }
12213 bool set_mapped_x1(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("mapped_x1", ints, count, time); }
12214 template<size_t count> bool set_mapped_x1(const int (&ints)[count], double time = TiMe::Default()) { return setArray("mapped_x1", ints, count, time); }
12218 IntList get_mapped_x1(double time = TiMe::Default()) const { return getIntList("mapped_x1", time); }
12219
12223 bool set_mapped_y1(const IntList& intList, double time = TiMe::Default()) { return setValue("mapped_y1", intList, time); }
12224 bool set_mapped_y1(IntList&& intList, double time = TiMe::Default()) { return setValue("mapped_y1", std::move(intList), time); }
12225 bool set_mapped_y1(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("mapped_y1", ints, count, time); }
12226 template<size_t count> bool set_mapped_y1(const int (&ints)[count], double time = TiMe::Default()) { return setArray("mapped_y1", ints, count, time); }
12230 IntList get_mapped_y1(double time = TiMe::Default()) const { return getIntList("mapped_y1", time); }
12231
12235 bool set_mapped_bake_nodes_auto(bool val, double time = TiMe::Default()) { return setValue("mapped_bake_nodes_auto", val, time); }
12239 bool get_mapped_bake_nodes_auto(double time = TiMe::Default()) const { return getBool("mapped_bake_nodes_auto", time); }
12240};
12241
12243class BitmapBuffer : public Plugin {
12244public:
12246 static constexpr const PluginTypeId getTypeId() { return 0x777473BF; }
12248 static constexpr const char* getType() { return "BitmapBuffer"; }
12249
12250 operator BitmapPluginCategory() { return *static_cast<BitmapPluginCategory*>(static_cast<Plugin*>(this)); }
12251
12255 bool set_filter_type(int val, double time = TiMe::Default()) { return setValue("filter_type", val, time); }
12259 int get_filter_type(double time = TiMe::Default()) const { return getInt("filter_type", time); }
12260
12263 bool set_filter_blur(float val, double time = TiMe::Default()) { return setValue("filter_blur", val, time); }
12266 float get_filter_blur(double time = TiMe::Default()) const { return getFloat("filter_blur", time); }
12267
12271 bool set_transfer_function(int val, double time = TiMe::Default()) { return setValue("transfer_function", val, time); }
12275 int get_transfer_function(double time = TiMe::Default()) const { return getInt("transfer_function", time); }
12276
12278 bool set_color_space(int val, double time = TiMe::Default()) { return setValue("color_space", val, time); }
12280 int get_color_space(double time = TiMe::Default()) const { return getInt("color_space", time); }
12281
12283 bool set_rgb_color_space(const char* str, double time = TiMe::Default()) { return setValue("rgb_color_space", str, time); }
12285 bool set_rgb_color_space(const std::string& str, double time = TiMe::Default()) { return setValue("rgb_color_space", str, time); }
12287 std::string get_rgb_color_space(double time = TiMe::Default()) const { return getString("rgb_color_space", time); }
12288
12291 bool set_gamma(float val, double time = TiMe::Default()) { return setValue("gamma", val, time); }
12294 float get_gamma(double time = TiMe::Default()) const { return getFloat("gamma", time); }
12295
12298 bool set_maya_compatible(bool val, double time = TiMe::Default()) { return setValue("maya_compatible", val, time); }
12301 bool get_maya_compatible(double time = TiMe::Default()) const { return getBool("maya_compatible", time); }
12302
12305 bool set_allow_negative_colors(bool val, double time = TiMe::Default()) { return setValue("allow_negative_colors", val, time); }
12308 bool get_allow_negative_colors(double time = TiMe::Default()) const { return getBool("allow_negative_colors", time); }
12309
12313 bool set_interpolation(int val, double time = TiMe::Default()) { return setValue("interpolation", val, time); }
12317 int get_interpolation(double time = TiMe::Default()) const { return getInt("interpolation", time); }
12318
12321 bool set_frame_number(int val, double time = TiMe::Default()) { return setValue("frame_number", val, time); }
12324 int get_frame_number(double time = TiMe::Default()) const { return getInt("frame_number", time); }
12325
12328 bool set_frame_offset(int val, double time = TiMe::Default()) { return setValue("frame_offset", val, time); }
12331 int get_frame_offset(double time = TiMe::Default()) const { return getInt("frame_offset", time); }
12332
12336 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
12340 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
12344 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
12345
12348 bool set_load_file(bool val, double time = TiMe::Default()) { return setValue("load_file", val, time); }
12351 bool get_load_file(double time = TiMe::Default()) const { return getBool("load_file", time); }
12352
12355 bool set_frame_sequence(bool val, double time = TiMe::Default()) { return setValue("frame_sequence", val, time); }
12358 bool get_frame_sequence(double time = TiMe::Default()) const { return getBool("frame_sequence", time); }
12359
12362 bool set_use_data_window(bool val, double time = TiMe::Default()) { return setValue("use_data_window", val, time); }
12365 bool get_use_data_window(double time = TiMe::Default()) const { return getBool("use_data_window", time); }
12366
12368 bool set_psd_group_name(const IntList& intList, double time = TiMe::Default()) { return setValue("psd_group_name", intList, time); }
12369 bool set_psd_group_name(IntList&& intList, double time = TiMe::Default()) { return setValue("psd_group_name", std::move(intList), time); }
12370 bool set_psd_group_name(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("psd_group_name", ints, count, time); }
12371 template<size_t count> bool set_psd_group_name(const int (&ints)[count], double time = TiMe::Default()) { return setArray("psd_group_name", ints, count, time); }
12373 IntList get_psd_group_name(double time = TiMe::Default()) const { return getIntList("psd_group_name", time); }
12374
12376 bool set_psd_alpha_name(const IntList& intList, double time = TiMe::Default()) { return setValue("psd_alpha_name", intList, time); }
12377 bool set_psd_alpha_name(IntList&& intList, double time = TiMe::Default()) { return setValue("psd_alpha_name", std::move(intList), time); }
12378 bool set_psd_alpha_name(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("psd_alpha_name", ints, count, time); }
12379 template<size_t count> bool set_psd_alpha_name(const int (&ints)[count], double time = TiMe::Default()) { return setArray("psd_alpha_name", ints, count, time); }
12381 IntList get_psd_alpha_name(double time = TiMe::Default()) const { return getIntList("psd_alpha_name", time); }
12382
12385 bool set_ifl_start_frame(int val, double time = TiMe::Default()) { return setValue("ifl_start_frame", val, time); }
12388 int get_ifl_start_frame(double time = TiMe::Default()) const { return getInt("ifl_start_frame", time); }
12389
12392 bool set_ifl_playback_rate(float val, double time = TiMe::Default()) { return setValue("ifl_playback_rate", val, time); }
12395 float get_ifl_playback_rate(double time = TiMe::Default()) const { return getFloat("ifl_playback_rate", time); }
12396
12400 bool set_ifl_end_condition(int val, double time = TiMe::Default()) { return setValue("ifl_end_condition", val, time); }
12404 int get_ifl_end_condition(double time = TiMe::Default()) const { return getInt("ifl_end_condition", time); }
12405};
12406
12408class CameraDefault : public Plugin {
12409public:
12411 static constexpr const PluginTypeId getTypeId() { return 0x77ED7DA5; }
12413 static constexpr const char* getType() { return "CameraDefault"; }
12414
12415 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
12416
12419 bool set_orthographic(bool val, double time = TiMe::Default()) { return setValue("orthographic", val, time); }
12422 bool get_orthographic(double time = TiMe::Default()) const { return getBool("orthographic", time); }
12423};
12424
12426class CameraDome : public Plugin {
12427public:
12429 static constexpr const PluginTypeId getTypeId() { return 0x7782F3D0; }
12431 static constexpr const char* getType() { return "CameraDome"; }
12432
12433 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
12434
12437 bool set_flip_x(bool val, double time = TiMe::Default()) { return setValue("flip_x", val, time); }
12440 bool get_flip_x(double time = TiMe::Default()) const { return getBool("flip_x", time); }
12441
12444 bool set_flip_y(bool val, double time = TiMe::Default()) { return setValue("flip_y", val, time); }
12447 bool get_flip_y(double time = TiMe::Default()) const { return getBool("flip_y", time); }
12448
12451 bool set_fov(float val, double time = TiMe::Default()) { return setValue("fov", val, time); }
12454 float get_fov(double time = TiMe::Default()) const { return getFloat("fov", time); }
12455
12459 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
12463 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
12464
12468 bool set_scene_name(const char* str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
12472 bool set_scene_name(const std::string& str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
12476 std::string get_scene_name(double time = TiMe::Default()) const { return getString("scene_name", time); }
12477};
12478
12481public:
12483 static constexpr const PluginTypeId getTypeId() { return 0x77CECF58; }
12485 static constexpr const char* getType() { return "CameraFilmTransform"; }
12486
12487 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
12488
12491 bool set_prescale(float val, double time = TiMe::Default()) { return setValue("prescale", val, time); }
12494 float get_prescale(double time = TiMe::Default()) const { return getFloat("prescale", time); }
12495
12498 bool set_postscale(float val, double time = TiMe::Default()) { return setValue("postscale", val, time); }
12501 float get_postscale(double time = TiMe::Default()) const { return getFloat("postscale", time); }
12502
12505 bool set_transx(float val, double time = TiMe::Default()) { return setValue("transx", val, time); }
12508 float get_transx(double time = TiMe::Default()) const { return getFloat("transx", time); }
12509
12512 bool set_transy(float val, double time = TiMe::Default()) { return setValue("transy", val, time); }
12515 float get_transy(double time = TiMe::Default()) const { return getFloat("transy", time); }
12516
12519 bool set_pivotx(float val, double time = TiMe::Default()) { return setValue("pivotx", val, time); }
12522 float get_pivotx(double time = TiMe::Default()) const { return getFloat("pivotx", time); }
12523
12526 bool set_pivoty(float val, double time = TiMe::Default()) { return setValue("pivoty", val, time); }
12529 float get_pivoty(double time = TiMe::Default()) const { return getFloat("pivoty", time); }
12530
12533 bool set_rotation(float val, double time = TiMe::Default()) { return setValue("rotation", val, time); }
12536 float get_rotation(double time = TiMe::Default()) const { return getFloat("rotation", time); }
12537
12540 bool set_rot_before_trans(bool val, double time = TiMe::Default()) { return setValue("rot_before_trans", val, time); }
12543 bool get_rot_before_trans(double time = TiMe::Default()) const { return getBool("rot_before_trans", time); }
12544};
12545
12547class CameraLensSystem : public Plugin {
12548public:
12550 static constexpr const PluginTypeId getTypeId() { return 0x78490C0E; }
12552 static constexpr const char* getType() { return "CameraLensSystem"; }
12553
12554 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
12555
12559 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
12563 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
12564
12568 bool set_film_width(float val, double time = TiMe::Default()) { return setValue("film_width", val, time); }
12572 float get_film_width(double time = TiMe::Default()) const { return getFloat("film_width", time); }
12573
12577 bool set_focal_length(float val, double time = TiMe::Default()) { return setValue("focal_length", val, time); }
12581 float get_focal_length(double time = TiMe::Default()) const { return getFloat("focal_length", time); }
12582
12586 bool set_zoom_factor(float val, double time = TiMe::Default()) { return setValue("zoom_factor", val, time); }
12590 float get_zoom_factor(double time = TiMe::Default()) const { return getFloat("zoom_factor", time); }
12591
12595 bool set_distortion(float val, double time = TiMe::Default()) { return setValue("distortion", val, time); }
12599 float get_distortion(double time = TiMe::Default()) const { return getFloat("distortion", time); }
12600
12604 bool set_distortion_type(int val, double time = TiMe::Default()) { return setValue("distortion_type", val, time); }
12608 int get_distortion_type(double time = TiMe::Default()) const { return getInt("distortion_type", time); }
12609
12613 bool set_f_number(float val, double time = TiMe::Default()) { return setValue("f_number", val, time); }
12617 float get_f_number(double time = TiMe::Default()) const { return getFloat("f_number", time); }
12618
12622 bool set_lens_shift(float val, double time = TiMe::Default()) { return setValue("lens_shift", val, time); }
12626 float get_lens_shift(double time = TiMe::Default()) const { return getFloat("lens_shift", time); }
12627
12631 bool set_shutter_speed(float val, double time = TiMe::Default()) { return setValue("shutter_speed", val, time); }
12635 float get_shutter_speed(double time = TiMe::Default()) const { return getFloat("shutter_speed", time); }
12636
12640 bool set_shutter_angle(float val, double time = TiMe::Default()) { return setValue("shutter_angle", val, time); }
12644 float get_shutter_angle(double time = TiMe::Default()) const { return getFloat("shutter_angle", time); }
12645
12649 bool set_shutter_offset(float val, double time = TiMe::Default()) { return setValue("shutter_offset", val, time); }
12653 float get_shutter_offset(double time = TiMe::Default()) const { return getFloat("shutter_offset", time); }
12654
12658 bool set_latency(float val, double time = TiMe::Default()) { return setValue("latency", val, time); }
12662 float get_latency(double time = TiMe::Default()) const { return getFloat("latency", time); }
12663
12667 bool set_ISO(float val, double time = TiMe::Default()) { return setValue("ISO", val, time); }
12671 float get_ISO(double time = TiMe::Default()) const { return getFloat("ISO", time); }
12672
12676 bool set_specify_focus(bool val, double time = TiMe::Default()) { return setValue("specify_focus", val, time); }
12680 bool get_specify_focus(double time = TiMe::Default()) const { return getBool("specify_focus", time); }
12681
12685 bool set_focus_distance(float val, double time = TiMe::Default()) { return setValue("focus_distance", val, time); }
12689 float get_focus_distance(double time = TiMe::Default()) const { return getFloat("focus_distance", time); }
12690
12694 bool set_targeted(bool val, double time = TiMe::Default()) { return setValue("targeted", val, time); }
12698 bool get_targeted(double time = TiMe::Default()) const { return getBool("targeted", time); }
12699
12703 bool set_target_distance(float val, double time = TiMe::Default()) { return setValue("target_distance", val, time); }
12707 float get_target_distance(double time = TiMe::Default()) const { return getFloat("target_distance", time); }
12708
12712 bool set_dof_display_threshold(float val, double time = TiMe::Default()) { return setValue("dof_display_threshold", val, time); }
12716 float get_dof_display_threshold(double time = TiMe::Default()) const { return getFloat("dof_display_threshold", time); }
12717
12721 bool set_exposure(bool val, double time = TiMe::Default()) { return setValue("exposure", val, time); }
12725 bool get_exposure(double time = TiMe::Default()) const { return getBool("exposure", time); }
12726
12730 bool set_white_balance(const Color& color, double time = TiMe::Default()) { return setValue("white_balance", color, time); }
12734 Color get_white_balance(double time = TiMe::Default()) const { return getColor("white_balance", time); }
12735
12739 bool set_vignetting(float val, double time = TiMe::Default()) { return setValue("vignetting", val, time); }
12743 float get_vignetting(double time = TiMe::Default()) const { return getFloat("vignetting", time); }
12744
12748 bool set_blades_enable(bool val, double time = TiMe::Default()) { return setValue("blades_enable", val, time); }
12752 bool get_blades_enable(double time = TiMe::Default()) const { return getBool("blades_enable", time); }
12753
12757 bool set_blades_num(int val, double time = TiMe::Default()) { return setValue("blades_num", val, time); }
12761 int get_blades_num(double time = TiMe::Default()) const { return getInt("blades_num", time); }
12762
12766 bool set_blades_rotation(float val, double time = TiMe::Default()) { return setValue("blades_rotation", val, time); }
12770 float get_blades_rotation(double time = TiMe::Default()) const { return getFloat("blades_rotation", time); }
12771
12775 bool set_center_bias(float val, double time = TiMe::Default()) { return setValue("center_bias", val, time); }
12779 float get_center_bias(double time = TiMe::Default()) const { return getFloat("center_bias", time); }
12780
12784 bool set_anisotropy(float val, double time = TiMe::Default()) { return setValue("anisotropy", val, time); }
12788 float get_anisotropy(double time = TiMe::Default()) const { return getFloat("anisotropy", time); }
12789
12793 bool set_use_dof(bool val, double time = TiMe::Default()) { return setValue("use_dof", val, time); }
12797 bool get_use_dof(double time = TiMe::Default()) const { return getBool("use_dof", time); }
12798
12802 bool set_use_moblur(bool val, double time = TiMe::Default()) { return setValue("use_moblur", val, time); }
12806 bool get_use_moblur(double time = TiMe::Default()) const { return getBool("use_moblur", time); }
12807
12811 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
12815 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
12816
12820 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
12824 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
12825
12829 bool set_lens_file(const char* str, double time = TiMe::Default()) { return setValue("lens_file", str, time); }
12833 bool set_lens_file(const std::string& str, double time = TiMe::Default()) { return setValue("lens_file", str, time); }
12837 std::string get_lens_file(double time = TiMe::Default()) const { return getString("lens_file", time); }
12838
12842 bool set_specify_fov(bool val, double time = TiMe::Default()) { return setValue("specify_fov", val, time); }
12846 bool get_specify_fov(double time = TiMe::Default()) const { return getBool("specify_fov", time); }
12847
12851 bool set_fov(float val, double time = TiMe::Default()) { return setValue("fov", val, time); }
12855 float get_fov(double time = TiMe::Default()) const { return getFloat("fov", time); }
12856
12860 bool set_horizontal_shift(float val, double time = TiMe::Default()) { return setValue("horizontal_shift", val, time); }
12864 float get_horizontal_shift(double time = TiMe::Default()) const { return getFloat("horizontal_shift", time); }
12865
12869 bool set_horizontal_offset(float val, double time = TiMe::Default()) { return setValue("horizontal_offset", val, time); }
12873 float get_horizontal_offset(double time = TiMe::Default()) const { return getFloat("horizontal_offset", time); }
12874
12878 bool set_vertical_offset(float val, double time = TiMe::Default()) { return setValue("vertical_offset", val, time); }
12882 float get_vertical_offset(double time = TiMe::Default()) const { return getFloat("vertical_offset", time); }
12883
12886 bool set_distortion_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("distortion_tex", texture, time); }
12889 bool set_distortion_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("distortion_tex", texture, time); }
12892 Value get_distortion_tex(double time = TiMe::Default()) const { return getValue("distortion_tex", time); }
12893
12897 bool set_bmpaperture_enable(bool val, double time = TiMe::Default()) { return setValue("bmpaperture_enable", val, time); }
12901 bool get_bmpaperture_enable(double time = TiMe::Default()) const { return getBool("bmpaperture_enable", time); }
12902
12906 bool set_bmpaperture_resolution(int val, double time = TiMe::Default()) { return setValue("bmpaperture_resolution", val, time); }
12910 int get_bmpaperture_resolution(double time = TiMe::Default()) const { return getInt("bmpaperture_resolution", time); }
12911
12914 bool set_bmpaperture_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bmpaperture_tex", texture, time); }
12917 bool set_bmpaperture_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("bmpaperture_tex", texture, time); }
12920 Value get_bmpaperture_tex(double time = TiMe::Default()) const { return getValue("bmpaperture_tex", time); }
12921
12925 bool set_optical_vignetting(float val, double time = TiMe::Default()) { return setValue("optical_vignetting", val, time); }
12929 float get_optical_vignetting(double time = TiMe::Default()) const { return getFloat("optical_vignetting", time); }
12930
12934 bool set_bmpaperture_affects_exposure(bool val, double time = TiMe::Default()) { return setValue("bmpaperture_affects_exposure", val, time); }
12938 bool get_bmpaperture_affects_exposure(double time = TiMe::Default()) const { return getBool("bmpaperture_affects_exposure", time); }
12939
12943 bool set_enable_thin_lens_equation(bool val, double time = TiMe::Default()) { return setValue("enable_thin_lens_equation", val, time); }
12947 bool get_enable_thin_lens_equation(double time = TiMe::Default()) const { return getBool("enable_thin_lens_equation", time); }
12948
12952 bool set_lens_system_description_file(const char* str, double time = TiMe::Default()) { return setValue("lens_system_description_file", str, time); }
12956 bool set_lens_system_description_file(const std::string& str, double time = TiMe::Default()) { return setValue("lens_system_description_file", str, time); }
12960 std::string get_lens_system_description_file(double time = TiMe::Default()) const { return getString("lens_system_description_file", time); }
12961
12965 bool set_chromatic_aberration(bool val, double time = TiMe::Default()) { return setValue("chromatic_aberration", val, time); }
12969 bool get_chromatic_aberration(double time = TiMe::Default()) const { return getBool("chromatic_aberration", time); }
12970};
12971
12973class CameraPhysical : public Plugin {
12974public:
12976 static constexpr const PluginTypeId getTypeId() { return 0x77A09431; }
12978 static constexpr const char* getType() { return "CameraPhysical"; }
12979
12980 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
12981
12985 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
12989 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
12990
12994 bool set_film_width(float val, double time = TiMe::Default()) { return setValue("film_width", val, time); }
12998 float get_film_width(double time = TiMe::Default()) const { return getFloat("film_width", time); }
12999
13003 bool set_focal_length(float val, double time = TiMe::Default()) { return setValue("focal_length", val, time); }
13007 float get_focal_length(double time = TiMe::Default()) const { return getFloat("focal_length", time); }
13008
13012 bool set_zoom_factor(float val, double time = TiMe::Default()) { return setValue("zoom_factor", val, time); }
13016 float get_zoom_factor(double time = TiMe::Default()) const { return getFloat("zoom_factor", time); }
13017
13021 bool set_distortion(float val, double time = TiMe::Default()) { return setValue("distortion", val, time); }
13025 float get_distortion(double time = TiMe::Default()) const { return getFloat("distortion", time); }
13026
13030 bool set_distortion_type(int val, double time = TiMe::Default()) { return setValue("distortion_type", val, time); }
13034 int get_distortion_type(double time = TiMe::Default()) const { return getInt("distortion_type", time); }
13035
13039 bool set_f_number(float val, double time = TiMe::Default()) { return setValue("f_number", val, time); }
13043 float get_f_number(double time = TiMe::Default()) const { return getFloat("f_number", time); }
13044
13048 bool set_lens_shift(float val, double time = TiMe::Default()) { return setValue("lens_shift", val, time); }
13052 float get_lens_shift(double time = TiMe::Default()) const { return getFloat("lens_shift", time); }
13053
13057 bool set_shutter_speed(float val, double time = TiMe::Default()) { return setValue("shutter_speed", val, time); }
13061 float get_shutter_speed(double time = TiMe::Default()) const { return getFloat("shutter_speed", time); }
13062
13066 bool set_shutter_angle(float val, double time = TiMe::Default()) { return setValue("shutter_angle", val, time); }
13070 float get_shutter_angle(double time = TiMe::Default()) const { return getFloat("shutter_angle", time); }
13071
13075 bool set_shutter_offset(float val, double time = TiMe::Default()) { return setValue("shutter_offset", val, time); }
13079 float get_shutter_offset(double time = TiMe::Default()) const { return getFloat("shutter_offset", time); }
13080
13084 bool set_latency(float val, double time = TiMe::Default()) { return setValue("latency", val, time); }
13088 float get_latency(double time = TiMe::Default()) const { return getFloat("latency", time); }
13089
13093 bool set_ISO(float val, double time = TiMe::Default()) { return setValue("ISO", val, time); }
13097 float get_ISO(double time = TiMe::Default()) const { return getFloat("ISO", time); }
13098
13102 bool set_specify_focus(bool val, double time = TiMe::Default()) { return setValue("specify_focus", val, time); }
13106 bool get_specify_focus(double time = TiMe::Default()) const { return getBool("specify_focus", time); }
13107
13111 bool set_focus_distance(float val, double time = TiMe::Default()) { return setValue("focus_distance", val, time); }
13115 float get_focus_distance(double time = TiMe::Default()) const { return getFloat("focus_distance", time); }
13116
13120 bool set_targeted(bool val, double time = TiMe::Default()) { return setValue("targeted", val, time); }
13124 bool get_targeted(double time = TiMe::Default()) const { return getBool("targeted", time); }
13125
13129 bool set_target_distance(float val, double time = TiMe::Default()) { return setValue("target_distance", val, time); }
13133 float get_target_distance(double time = TiMe::Default()) const { return getFloat("target_distance", time); }
13134
13138 bool set_dof_display_threshold(float val, double time = TiMe::Default()) { return setValue("dof_display_threshold", val, time); }
13142 float get_dof_display_threshold(double time = TiMe::Default()) const { return getFloat("dof_display_threshold", time); }
13143
13147 bool set_exposure(int val, double time = TiMe::Default()) { return setValue("exposure", val, time); }
13151 int get_exposure(double time = TiMe::Default()) const { return getInt("exposure", time); }
13152
13156 bool set_white_balance(const Color& color, double time = TiMe::Default()) { return setValue("white_balance", color, time); }
13160 Color get_white_balance(double time = TiMe::Default()) const { return getColor("white_balance", time); }
13161
13165 bool set_vignetting(float val, double time = TiMe::Default()) { return setValue("vignetting", val, time); }
13169 float get_vignetting(double time = TiMe::Default()) const { return getFloat("vignetting", time); }
13170
13174 bool set_blades_enable(bool val, double time = TiMe::Default()) { return setValue("blades_enable", val, time); }
13178 bool get_blades_enable(double time = TiMe::Default()) const { return getBool("blades_enable", time); }
13179
13183 bool set_blades_num(int val, double time = TiMe::Default()) { return setValue("blades_num", val, time); }
13187 int get_blades_num(double time = TiMe::Default()) const { return getInt("blades_num", time); }
13188
13192 bool set_blades_rotation(float val, double time = TiMe::Default()) { return setValue("blades_rotation", val, time); }
13196 float get_blades_rotation(double time = TiMe::Default()) const { return getFloat("blades_rotation", time); }
13197
13201 bool set_center_bias(float val, double time = TiMe::Default()) { return setValue("center_bias", val, time); }
13205 float get_center_bias(double time = TiMe::Default()) const { return getFloat("center_bias", time); }
13206
13210 bool set_anisotropy(float val, double time = TiMe::Default()) { return setValue("anisotropy", val, time); }
13214 float get_anisotropy(double time = TiMe::Default()) const { return getFloat("anisotropy", time); }
13215
13219 bool set_use_dof(bool val, double time = TiMe::Default()) { return setValue("use_dof", val, time); }
13223 bool get_use_dof(double time = TiMe::Default()) const { return getBool("use_dof", time); }
13224
13228 bool set_use_moblur(bool val, double time = TiMe::Default()) { return setValue("use_moblur", val, time); }
13232 bool get_use_moblur(double time = TiMe::Default()) const { return getBool("use_moblur", time); }
13233
13237 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
13241 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
13242
13246 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
13250 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
13251
13255 bool set_lens_file(const char* str, double time = TiMe::Default()) { return setValue("lens_file", str, time); }
13259 bool set_lens_file(const std::string& str, double time = TiMe::Default()) { return setValue("lens_file", str, time); }
13263 std::string get_lens_file(double time = TiMe::Default()) const { return getString("lens_file", time); }
13264
13268 bool set_specify_fov(bool val, double time = TiMe::Default()) { return setValue("specify_fov", val, time); }
13272 bool get_specify_fov(double time = TiMe::Default()) const { return getBool("specify_fov", time); }
13273
13277 bool set_fov(float val, double time = TiMe::Default()) { return setValue("fov", val, time); }
13281 float get_fov(double time = TiMe::Default()) const { return getFloat("fov", time); }
13282
13286 bool set_horizontal_shift(float val, double time = TiMe::Default()) { return setValue("horizontal_shift", val, time); }
13290 float get_horizontal_shift(double time = TiMe::Default()) const { return getFloat("horizontal_shift", time); }
13291
13295 bool set_horizontal_offset(float val, double time = TiMe::Default()) { return setValue("horizontal_offset", val, time); }
13299 float get_horizontal_offset(double time = TiMe::Default()) const { return getFloat("horizontal_offset", time); }
13300
13304 bool set_vertical_offset(float val, double time = TiMe::Default()) { return setValue("vertical_offset", val, time); }
13308 float get_vertical_offset(double time = TiMe::Default()) const { return getFloat("vertical_offset", time); }
13309
13312 bool set_distortion_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("distortion_tex", texture, time); }
13315 bool set_distortion_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("distortion_tex", texture, time); }
13318 Value get_distortion_tex(double time = TiMe::Default()) const { return getValue("distortion_tex", time); }
13319
13323 bool set_bmpaperture_enable(bool val, double time = TiMe::Default()) { return setValue("bmpaperture_enable", val, time); }
13327 bool get_bmpaperture_enable(double time = TiMe::Default()) const { return getBool("bmpaperture_enable", time); }
13328
13332 bool set_bmpaperture_resolution(int val, double time = TiMe::Default()) { return setValue("bmpaperture_resolution", val, time); }
13336 int get_bmpaperture_resolution(double time = TiMe::Default()) const { return getInt("bmpaperture_resolution", time); }
13337
13340 bool set_bmpaperture_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bmpaperture_tex", texture, time); }
13343 bool set_bmpaperture_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("bmpaperture_tex", texture, time); }
13346 Value get_bmpaperture_tex(double time = TiMe::Default()) const { return getValue("bmpaperture_tex", time); }
13347
13351 bool set_optical_vignetting(float val, double time = TiMe::Default()) { return setValue("optical_vignetting", val, time); }
13355 float get_optical_vignetting(double time = TiMe::Default()) const { return getFloat("optical_vignetting", time); }
13356
13360 bool set_bmpaperture_affects_exposure(bool val, double time = TiMe::Default()) { return setValue("bmpaperture_affects_exposure", val, time); }
13364 bool get_bmpaperture_affects_exposure(double time = TiMe::Default()) const { return getBool("bmpaperture_affects_exposure", time); }
13365
13369 bool set_enable_thin_lens_equation(bool val, double time = TiMe::Default()) { return setValue("enable_thin_lens_equation", val, time); }
13373 bool get_enable_thin_lens_equation(double time = TiMe::Default()) const { return getBool("enable_thin_lens_equation", time); }
13374
13378 bool set_rolling_shutter_mode(int val, double time = TiMe::Default()) { return setValue("rolling_shutter_mode", val, time); }
13382 int get_rolling_shutter_mode(double time = TiMe::Default()) const { return getInt("rolling_shutter_mode", time); }
13383
13387 bool set_rolling_shutter_duration(float val, double time = TiMe::Default()) { return setValue("rolling_shutter_duration", val, time); }
13391 float get_rolling_shutter_duration(double time = TiMe::Default()) const { return getFloat("rolling_shutter_duration", time); }
13392
13396 bool set_exposure_value(float val, double time = TiMe::Default()) { return setValue("exposure_value", val, time); }
13400 float get_exposure_value(double time = TiMe::Default()) const { return getFloat("exposure_value", time); }
13401
13405 bool set_scene_name(const char* str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
13409 bool set_scene_name(const std::string& str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
13413 std::string get_scene_name(double time = TiMe::Default()) const { return getString("scene_name", time); }
13414
13417 bool set_camera_shader_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("camera_shader_tex", texture, time); }
13420 bool set_camera_shader_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("camera_shader_tex", texture, time); }
13423 Value get_camera_shader_tex(double time = TiMe::Default()) const { return getValue("camera_shader_tex", time); }
13424};
13425
13427class ColorCorrect : public Plugin {
13428public:
13430 static constexpr const PluginTypeId getTypeId() { return 0xBF991F1; }
13432 static constexpr const char* getType() { return "ColorCorrect"; }
13433
13434 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
13435
13438 bool set_source_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("source_color", acolor, time); }
13441 AColor get_source_color(double time = TiMe::Default()) const { return getAColor("source_color", time); }
13442
13444 bool set_texture_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
13446 bool set_texture_map(const AColor& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
13448 Value get_texture_map(double time = TiMe::Default()) const { return getValue("texture_map", time); }
13449
13453 bool set_preprocess(bool val, double time = TiMe::Default()) { return setValue("preprocess", val, time); }
13457 bool get_preprocess(double time = TiMe::Default()) const { return getBool("preprocess", time); }
13458
13462 bool set_pre_brightness(float val, double time = TiMe::Default()) { return setValue("pre_brightness", val, time); }
13466 float get_pre_brightness(double time = TiMe::Default()) const { return getFloat("pre_brightness", time); }
13467
13471 bool set_pre_contrast(float val, double time = TiMe::Default()) { return setValue("pre_contrast", val, time); }
13475 float get_pre_contrast(double time = TiMe::Default()) const { return getFloat("pre_contrast", time); }
13476
13480 bool set_pre_gamma(float val, double time = TiMe::Default()) { return setValue("pre_gamma", val, time); }
13484 float get_pre_gamma(double time = TiMe::Default()) const { return getFloat("pre_gamma", time); }
13485
13489 bool set_pre_mono(bool val, double time = TiMe::Default()) { return setValue("pre_mono", val, time); }
13493 bool get_pre_mono(double time = TiMe::Default()) const { return getBool("pre_mono", time); }
13494
13498 bool set_pre_invert(bool val, double time = TiMe::Default()) { return setValue("pre_invert", val, time); }
13502 bool get_pre_invert(double time = TiMe::Default()) const { return getBool("pre_invert", time); }
13503
13507 bool set_pre_unmult_alpha(bool val, double time = TiMe::Default()) { return setValue("pre_unmult_alpha", val, time); }
13511 bool get_pre_unmult_alpha(double time = TiMe::Default()) const { return getBool("pre_unmult_alpha", time); }
13512
13516 bool set_pre_clamp(bool val, double time = TiMe::Default()) { return setValue("pre_clamp", val, time); }
13520 bool get_pre_clamp(double time = TiMe::Default()) const { return getBool("pre_clamp", time); }
13521
13525 bool set_pre_clamp_min(float val, double time = TiMe::Default()) { return setValue("pre_clamp_min", val, time); }
13529 float get_pre_clamp_min(double time = TiMe::Default()) const { return getFloat("pre_clamp_min", time); }
13530
13534 bool set_pre_clamp_max(float val, double time = TiMe::Default()) { return setValue("pre_clamp_max", val, time); }
13538 float get_pre_clamp_max(double time = TiMe::Default()) const { return getFloat("pre_clamp_max", time); }
13539
13543 bool set_pre_clamp_normalize(bool val, double time = TiMe::Default()) { return setValue("pre_clamp_normalize", val, time); }
13547 bool get_pre_clamp_normalize(double time = TiMe::Default()) const { return getBool("pre_clamp_normalize", time); }
13548
13552 bool set_hsl_on(bool val, double time = TiMe::Default()) { return setValue("hsl_on", val, time); }
13556 bool get_hsl_on(double time = TiMe::Default()) const { return getBool("hsl_on", time); }
13557
13561 bool set_hsl_hue_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsl_hue_offset", texturefloat, time); }
13565 bool set_hsl_hue_offset(float texturefloat, double time = TiMe::Default()) { return setValue("hsl_hue_offset", texturefloat, time); }
13569 Value get_hsl_hue_offset(double time = TiMe::Default()) const { return getValue("hsl_hue_offset", time); }
13570
13574 bool set_hsl_hue_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsl_hue_gain", texturefloat, time); }
13578 bool set_hsl_hue_gain(float texturefloat, double time = TiMe::Default()) { return setValue("hsl_hue_gain", texturefloat, time); }
13582 Value get_hsl_hue_gain(double time = TiMe::Default()) const { return getValue("hsl_hue_gain", time); }
13583
13587 bool set_hsl_saturation_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsl_saturation_offset", texturefloat, time); }
13591 bool set_hsl_saturation_offset(float texturefloat, double time = TiMe::Default()) { return setValue("hsl_saturation_offset", texturefloat, time); }
13595 Value get_hsl_saturation_offset(double time = TiMe::Default()) const { return getValue("hsl_saturation_offset", time); }
13596
13600 bool set_hsl_saturation_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsl_saturation_gain", texturefloat, time); }
13604 bool set_hsl_saturation_gain(float texturefloat, double time = TiMe::Default()) { return setValue("hsl_saturation_gain", texturefloat, time); }
13608 Value get_hsl_saturation_gain(double time = TiMe::Default()) const { return getValue("hsl_saturation_gain", time); }
13609
13613 bool set_hsl_lightness_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsl_lightness_offset", texturefloat, time); }
13617 bool set_hsl_lightness_offset(float texturefloat, double time = TiMe::Default()) { return setValue("hsl_lightness_offset", texturefloat, time); }
13621 Value get_hsl_lightness_offset(double time = TiMe::Default()) const { return getValue("hsl_lightness_offset", time); }
13622
13626 bool set_hsl_lightness_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsl_lightness_gain", texturefloat, time); }
13630 bool set_hsl_lightness_gain(float texturefloat, double time = TiMe::Default()) { return setValue("hsl_lightness_gain", texturefloat, time); }
13634 Value get_hsl_lightness_gain(double time = TiMe::Default()) const { return getValue("hsl_lightness_gain", time); }
13635
13639 bool set_hsv_on(bool val, double time = TiMe::Default()) { return setValue("hsv_on", val, time); }
13643 bool get_hsv_on(double time = TiMe::Default()) const { return getBool("hsv_on", time); }
13644
13648 bool set_hsv_hue_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsv_hue_offset", texturefloat, time); }
13652 bool set_hsv_hue_offset(float texturefloat, double time = TiMe::Default()) { return setValue("hsv_hue_offset", texturefloat, time); }
13656 Value get_hsv_hue_offset(double time = TiMe::Default()) const { return getValue("hsv_hue_offset", time); }
13657
13661 bool set_hsv_hue_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsv_hue_gain", texturefloat, time); }
13665 bool set_hsv_hue_gain(float texturefloat, double time = TiMe::Default()) { return setValue("hsv_hue_gain", texturefloat, time); }
13669 Value get_hsv_hue_gain(double time = TiMe::Default()) const { return getValue("hsv_hue_gain", time); }
13670
13674 bool set_hsv_saturation_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsv_saturation_offset", texturefloat, time); }
13678 bool set_hsv_saturation_offset(float texturefloat, double time = TiMe::Default()) { return setValue("hsv_saturation_offset", texturefloat, time); }
13682 Value get_hsv_saturation_offset(double time = TiMe::Default()) const { return getValue("hsv_saturation_offset", time); }
13683
13687 bool set_hsv_saturation_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsv_saturation_gain", texturefloat, time); }
13691 bool set_hsv_saturation_gain(float texturefloat, double time = TiMe::Default()) { return setValue("hsv_saturation_gain", texturefloat, time); }
13695 Value get_hsv_saturation_gain(double time = TiMe::Default()) const { return getValue("hsv_saturation_gain", time); }
13696
13700 bool set_hsv_value_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsv_value_offset", texturefloat, time); }
13704 bool set_hsv_value_offset(float texturefloat, double time = TiMe::Default()) { return setValue("hsv_value_offset", texturefloat, time); }
13708 Value get_hsv_value_offset(double time = TiMe::Default()) const { return getValue("hsv_value_offset", time); }
13709
13713 bool set_hsv_value_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hsv_value_gain", texturefloat, time); }
13717 bool set_hsv_value_gain(float texturefloat, double time = TiMe::Default()) { return setValue("hsv_value_gain", texturefloat, time); }
13721 Value get_hsv_value_gain(double time = TiMe::Default()) const { return getValue("hsv_value_gain", time); }
13722
13726 bool set_rgba_on(bool val, double time = TiMe::Default()) { return setValue("rgba_on", val, time); }
13730 bool get_rgba_on(double time = TiMe::Default()) const { return getBool("rgba_on", time); }
13731
13735 bool set_red_channel(int val, double time = TiMe::Default()) { return setValue("red_channel", val, time); }
13739 int get_red_channel(double time = TiMe::Default()) const { return getInt("red_channel", time); }
13740
13744 bool set_red_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("red_offset", texturefloat, time); }
13748 bool set_red_offset(float texturefloat, double time = TiMe::Default()) { return setValue("red_offset", texturefloat, time); }
13752 Value get_red_offset(double time = TiMe::Default()) const { return getValue("red_offset", time); }
13753
13757 bool set_red_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("red_gain", texturefloat, time); }
13761 bool set_red_gain(float texturefloat, double time = TiMe::Default()) { return setValue("red_gain", texturefloat, time); }
13765 Value get_red_gain(double time = TiMe::Default()) const { return getValue("red_gain", time); }
13766
13770 bool set_green_channel(int val, double time = TiMe::Default()) { return setValue("green_channel", val, time); }
13774 int get_green_channel(double time = TiMe::Default()) const { return getInt("green_channel", time); }
13775
13779 bool set_green_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("green_offset", texturefloat, time); }
13783 bool set_green_offset(float texturefloat, double time = TiMe::Default()) { return setValue("green_offset", texturefloat, time); }
13787 Value get_green_offset(double time = TiMe::Default()) const { return getValue("green_offset", time); }
13788
13792 bool set_green_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("green_gain", texturefloat, time); }
13796 bool set_green_gain(float texturefloat, double time = TiMe::Default()) { return setValue("green_gain", texturefloat, time); }
13800 Value get_green_gain(double time = TiMe::Default()) const { return getValue("green_gain", time); }
13801
13805 bool set_blue_channel(int val, double time = TiMe::Default()) { return setValue("blue_channel", val, time); }
13809 int get_blue_channel(double time = TiMe::Default()) const { return getInt("blue_channel", time); }
13810
13814 bool set_blue_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("blue_offset", texturefloat, time); }
13818 bool set_blue_offset(float texturefloat, double time = TiMe::Default()) { return setValue("blue_offset", texturefloat, time); }
13822 Value get_blue_offset(double time = TiMe::Default()) const { return getValue("blue_offset", time); }
13823
13827 bool set_blue_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("blue_gain", texturefloat, time); }
13831 bool set_blue_gain(float texturefloat, double time = TiMe::Default()) { return setValue("blue_gain", texturefloat, time); }
13835 Value get_blue_gain(double time = TiMe::Default()) const { return getValue("blue_gain", time); }
13836
13840 bool set_alpha_channel(int val, double time = TiMe::Default()) { return setValue("alpha_channel", val, time); }
13844 int get_alpha_channel(double time = TiMe::Default()) const { return getInt("alpha_channel", time); }
13845
13849 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
13853 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
13857 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
13858
13862 bool set_alpha_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_gain", texturefloat, time); }
13866 bool set_alpha_gain(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_gain", texturefloat, time); }
13870 Value get_alpha_gain(double time = TiMe::Default()) const { return getValue("alpha_gain", time); }
13871
13875 bool set_premultiply_new_alpha(bool val, double time = TiMe::Default()) { return setValue("premultiply_new_alpha", val, time); }
13879 bool get_premultiply_new_alpha(double time = TiMe::Default()) const { return getBool("premultiply_new_alpha", time); }
13880
13884 bool set_postprocess(bool val, double time = TiMe::Default()) { return setValue("postprocess", val, time); }
13888 bool get_postprocess(double time = TiMe::Default()) const { return getBool("postprocess", time); }
13889
13893 bool set_post_mono(bool val, double time = TiMe::Default()) { return setValue("post_mono", val, time); }
13897 bool get_post_mono(double time = TiMe::Default()) const { return getBool("post_mono", time); }
13898
13902 bool set_post_invert(bool val, double time = TiMe::Default()) { return setValue("post_invert", val, time); }
13906 bool get_post_invert(double time = TiMe::Default()) const { return getBool("post_invert", time); }
13907
13911 bool set_post_clamp(bool val, double time = TiMe::Default()) { return setValue("post_clamp", val, time); }
13915 bool get_post_clamp(double time = TiMe::Default()) const { return getBool("post_clamp", time); }
13916
13920 bool set_post_clamp_min(float val, double time = TiMe::Default()) { return setValue("post_clamp_min", val, time); }
13924 float get_post_clamp_min(double time = TiMe::Default()) const { return getFloat("post_clamp_min", time); }
13925
13929 bool set_post_clamp_max(float val, double time = TiMe::Default()) { return setValue("post_clamp_max", val, time); }
13933 float get_post_clamp_max(double time = TiMe::Default()) const { return getFloat("post_clamp_max", time); }
13934
13938 bool set_post_clamp_normalize(bool val, double time = TiMe::Default()) { return setValue("post_clamp_normalize", val, time); }
13942 bool get_post_clamp_normalize(double time = TiMe::Default()) const { return getBool("post_clamp_normalize", time); }
13943};
13944
13946class ColorCorrection : public Plugin {
13947public:
13949 static constexpr const PluginTypeId getTypeId() { return 0xBF8164B; }
13951 static constexpr const char* getType() { return "ColorCorrection"; }
13952
13953 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
13954
13958 bool set_source_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("source_color", acolor, time); }
13962 AColor get_source_color(double time = TiMe::Default()) const { return getAColor("source_color", time); }
13963
13966 bool set_texture_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
13969 bool set_texture_map(const AColor& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
13972 Value get_texture_map(double time = TiMe::Default()) const { return getValue("texture_map", time); }
13973
13977 bool set_rewire_red(int val, double time = TiMe::Default()) { return setValue("rewire_red", val, time); }
13981 int get_rewire_red(double time = TiMe::Default()) const { return getInt("rewire_red", time); }
13982
13986 bool set_rewire_green(int val, double time = TiMe::Default()) { return setValue("rewire_green", val, time); }
13990 int get_rewire_green(double time = TiMe::Default()) const { return getInt("rewire_green", time); }
13991
13995 bool set_rewire_blue(int val, double time = TiMe::Default()) { return setValue("rewire_blue", val, time); }
13999 int get_rewire_blue(double time = TiMe::Default()) const { return getInt("rewire_blue", time); }
14000
14004 bool set_rewire_alpha(int val, double time = TiMe::Default()) { return setValue("rewire_alpha", val, time); }
14008 int get_rewire_alpha(double time = TiMe::Default()) const { return getInt("rewire_alpha", time); }
14009
14013 bool set_hue_shift(float val, double time = TiMe::Default()) { return setValue("hue_shift", val, time); }
14017 float get_hue_shift(double time = TiMe::Default()) const { return getFloat("hue_shift", time); }
14018
14022 bool set_saturation(float val, double time = TiMe::Default()) { return setValue("saturation", val, time); }
14026 float get_saturation(double time = TiMe::Default()) const { return getFloat("saturation", time); }
14027
14030 bool set_hue_tint(const AColor& acolor, double time = TiMe::Default()) { return setValue("hue_tint", acolor, time); }
14033 AColor get_hue_tint(double time = TiMe::Default()) const { return getAColor("hue_tint", time); }
14034
14038 bool set_tint_strength(float val, double time = TiMe::Default()) { return setValue("tint_strength", val, time); }
14042 float get_tint_strength(double time = TiMe::Default()) const { return getFloat("tint_strength", time); }
14043
14047 bool set_lightness_mode(int val, double time = TiMe::Default()) { return setValue("lightness_mode", val, time); }
14051 int get_lightness_mode(double time = TiMe::Default()) const { return getInt("lightness_mode", time); }
14052
14056 bool set_brightness(float val, double time = TiMe::Default()) { return setValue("brightness", val, time); }
14060 float get_brightness(double time = TiMe::Default()) const { return getFloat("brightness", time); }
14061
14065 bool set_contrast(float val, double time = TiMe::Default()) { return setValue("contrast", val, time); }
14069 float get_contrast(double time = TiMe::Default()) const { return getFloat("contrast", time); }
14070
14074 bool set_adv_exposure_mode(int val, double time = TiMe::Default()) { return setValue("adv_exposure_mode", val, time); }
14078 int get_adv_exposure_mode(double time = TiMe::Default()) const { return getInt("adv_exposure_mode", time); }
14079
14083 bool set_adv_brightness(float val, double time = TiMe::Default()) { return setValue("adv_brightness", val, time); }
14087 float get_adv_brightness(double time = TiMe::Default()) const { return getFloat("adv_brightness", time); }
14088
14092 bool set_adv_contrast(float val, double time = TiMe::Default()) { return setValue("adv_contrast", val, time); }
14096 float get_adv_contrast(double time = TiMe::Default()) const { return getFloat("adv_contrast", time); }
14097
14101 bool set_adv_base(float val, double time = TiMe::Default()) { return setValue("adv_base", val, time); }
14105 float get_adv_base(double time = TiMe::Default()) const { return getFloat("adv_base", time); }
14106
14110 bool set_adv_offset(float val, double time = TiMe::Default()) { return setValue("adv_offset", val, time); }
14114 float get_adv_offset(double time = TiMe::Default()) const { return getFloat("adv_offset", time); }
14115
14119 bool set_adv_use_red(bool val, double time = TiMe::Default()) { return setValue("adv_use_red", val, time); }
14123 bool get_adv_use_red(double time = TiMe::Default()) const { return getBool("adv_use_red", time); }
14124
14128 bool set_adv_use_green(bool val, double time = TiMe::Default()) { return setValue("adv_use_green", val, time); }
14132 bool get_adv_use_green(double time = TiMe::Default()) const { return getBool("adv_use_green", time); }
14133
14137 bool set_adv_use_blue(bool val, double time = TiMe::Default()) { return setValue("adv_use_blue", val, time); }
14141 bool get_adv_use_blue(double time = TiMe::Default()) const { return getBool("adv_use_blue", time); }
14142
14146 bool set_adv_rgb_brightness(const Color& color, double time = TiMe::Default()) { return setValue("adv_rgb_brightness", color, time); }
14150 Color get_adv_rgb_brightness(double time = TiMe::Default()) const { return getColor("adv_rgb_brightness", time); }
14151
14155 bool set_adv_rgb_contrast(const Color& color, double time = TiMe::Default()) { return setValue("adv_rgb_contrast", color, time); }
14159 Color get_adv_rgb_contrast(double time = TiMe::Default()) const { return getColor("adv_rgb_contrast", time); }
14160
14164 bool set_adv_rgb_base(const Color& color, double time = TiMe::Default()) { return setValue("adv_rgb_base", color, time); }
14168 Color get_adv_rgb_base(double time = TiMe::Default()) const { return getColor("adv_rgb_base", time); }
14169
14173 bool set_adv_rgb_offset(const Color& color, double time = TiMe::Default()) { return setValue("adv_rgb_offset", color, time); }
14177 Color get_adv_rgb_offset(double time = TiMe::Default()) const { return getColor("adv_rgb_offset", time); }
14178
14182 bool set_adv_printer_lights_per(float val, double time = TiMe::Default()) { return setValue("adv_printer_lights_per", val, time); }
14186 float get_adv_printer_lights_per(double time = TiMe::Default()) const { return getFloat("adv_printer_lights_per", time); }
14187};
14188
14189class ColorMapperTest : public Plugin {
14190public:
14192 static constexpr const PluginTypeId getTypeId() { return 0x780CE6E0; }
14194 static constexpr const char* getType() { return "ColorMapperTest"; }
14195
14196 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14197
14200 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
14203 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
14204
14207 bool set_gamma(float val, double time = TiMe::Default()) { return setValue("gamma", val, time); }
14210 float get_gamma(double time = TiMe::Default()) const { return getFloat("gamma", time); }
14211
14214 bool set_clamp_level(float val, double time = TiMe::Default()) { return setValue("clamp_level", val, time); }
14217 float get_clamp_level(double time = TiMe::Default()) const { return getFloat("clamp_level", time); }
14218};
14219
14222public:
14224 static constexpr const PluginTypeId getTypeId() { return 0x77C004A1; }
14226 static constexpr const char* getType() { return "ColorTextureToMono"; }
14227
14228 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
14229
14232 bool set_value(float val, double time = TiMe::Default()) { return setValue("value", val, time); }
14235 float get_value(double time = TiMe::Default()) const { return getFloat("value", time); }
14236
14239 bool set_color_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_texture", texture, time); }
14242 bool set_color_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("color_texture", texture, time); }
14245 Value get_color_texture(double time = TiMe::Default()) const { return getValue("color_texture", time); }
14246};
14247
14248class CustomGlsl : public Plugin {
14249public:
14251 static constexpr const PluginTypeId getTypeId() { return 0x77EE67AE; }
14253 static constexpr const char* getType() { return "CustomGlsl"; }
14254
14255 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14256};
14257
14259class EnvFogMeshGizmo : public Plugin {
14260public:
14262 static constexpr const PluginTypeId getTypeId() { return 0x77CEA016; }
14264 static constexpr const char* getType() { return "EnvFogMeshGizmo"; }
14265
14266 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
14267
14271 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
14275 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
14276
14279 bool set_geometry(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("geometry", plugin, time); }
14282 PluginRef get_geometry(double time = TiMe::Default()) const { return getPlugin("geometry", time); }
14283
14286 bool set_lights(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("lights", pluginList, time); }
14287 bool set_lights(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("lights", plugins, count, time); }
14288 template<size_t count> bool set_lights(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("lights", plugins, count, time); }
14291 PluginList get_lights(double time = TiMe::Default()) const { return getPluginList("lights", time); }
14292
14296 bool set_fade_out_radius(float val, double time = TiMe::Default()) { return setValue("fade_out_radius", val, time); }
14300 float get_fade_out_radius(double time = TiMe::Default()) const { return getFloat("fade_out_radius", time); }
14301};
14302
14304class EnvironmentFog : public Plugin {
14305public:
14307 static constexpr const PluginTypeId getTypeId() { return 0x77CEA015; }
14309 static constexpr const char* getType() { return "EnvironmentFog"; }
14310
14311 operator VolumetricPluginCategory() { return *static_cast<VolumetricPluginCategory*>(static_cast<Plugin*>(this)); }
14312
14316 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
14320 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
14321
14324 bool set_gizmos(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("gizmos", pluginList, time); }
14325 bool set_gizmos(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("gizmos", plugins, count, time); }
14326 template<size_t count> bool set_gizmos(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("gizmos", plugins, count, time); }
14329 PluginList get_gizmos(double time = TiMe::Default()) const { return getPluginList("gizmos", time); }
14330
14334 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
14338 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
14339
14342 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
14345 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
14348 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
14349
14353 bool set_color_mult(float val, double time = TiMe::Default()) { return setValue("color_mult", val, time); }
14357 float get_color_mult(double time = TiMe::Default()) const { return getFloat("color_mult", time); }
14358
14362 bool set_emission(const Color& color, double time = TiMe::Default()) { return setValue("emission", color, time); }
14366 Color get_emission(double time = TiMe::Default()) const { return getColor("emission", time); }
14367
14370 bool set_emission_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("emission_tex", texture, time); }
14373 bool set_emission_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("emission_tex", texture, time); }
14376 Value get_emission_tex(double time = TiMe::Default()) const { return getValue("emission_tex", time); }
14377
14381 bool set_emission_mult(float val, double time = TiMe::Default()) { return setValue("emission_mult", val, time); }
14385 float get_emission_mult(double time = TiMe::Default()) const { return getFloat("emission_mult", time); }
14386
14389 bool set_emission_mult_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("emission_mult_tex", texturefloat, time); }
14392 bool set_emission_mult_tex(float texturefloat, double time = TiMe::Default()) { return setValue("emission_mult_tex", texturefloat, time); }
14395 Value get_emission_mult_tex(double time = TiMe::Default()) const { return getValue("emission_mult_tex", time); }
14396
14400 bool set_distance(float val, double time = TiMe::Default()) { return setValue("distance", val, time); }
14404 float get_distance(double time = TiMe::Default()) const { return getFloat("distance", time); }
14405
14409 bool set_density(float val, double time = TiMe::Default()) { return setValue("density", val, time); }
14413 float get_density(double time = TiMe::Default()) const { return getFloat("density", time); }
14414
14417 bool set_density_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("density_tex", texturefloat, time); }
14420 bool set_density_tex(float texturefloat, double time = TiMe::Default()) { return setValue("density_tex", texturefloat, time); }
14423 Value get_density_tex(double time = TiMe::Default()) const { return getValue("density_tex", time); }
14424
14428 bool set_opacity_mode(bool val, double time = TiMe::Default()) { return setValue("opacity_mode", val, time); }
14432 bool get_opacity_mode(double time = TiMe::Default()) const { return getBool("opacity_mode", time); }
14433
14437 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
14441 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
14442
14445 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
14448 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
14451 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
14452
14456 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
14460 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
14461
14465 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
14469 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
14470
14474 bool set_use_height(bool val, double time = TiMe::Default()) { return setValue("use_height", val, time); }
14478 bool get_use_height(double time = TiMe::Default()) const { return getBool("use_height", time); }
14479
14483 bool set_height(float val, double time = TiMe::Default()) { return setValue("height", val, time); }
14487 float get_height(double time = TiMe::Default()) const { return getFloat("height", time); }
14488
14492 bool set_yup(bool val, double time = TiMe::Default()) { return setValue("yup", val, time); }
14496 bool get_yup(double time = TiMe::Default()) const { return getBool("yup", time); }
14497
14501 bool set_solid_mode(bool val, double time = TiMe::Default()) { return setValue("solid_mode", val, time); }
14505 bool get_solid_mode(double time = TiMe::Default()) const { return getBool("solid_mode", time); }
14506
14510 bool set_solid_threshold(float val, double time = TiMe::Default()) { return setValue("solid_threshold", val, time); }
14514 float get_solid_threshold(double time = TiMe::Default()) const { return getFloat("solid_threshold", time); }
14515
14519 bool set_jitter(bool val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
14523 bool get_jitter(double time = TiMe::Default()) const { return getBool("jitter", time); }
14524
14528 bool set_shadow_opacity(float val, double time = TiMe::Default()) { return setValue("shadow_opacity", val, time); }
14532 float get_shadow_opacity(double time = TiMe::Default()) const { return getFloat("shadow_opacity", time); }
14533
14537 bool set_scale(const FloatList& floatList, double time = TiMe::Default()) { return setValue("scale", floatList, time); }
14538 bool set_scale(FloatList&& floatList, double time = TiMe::Default()) { return setValue("scale", std::move(floatList), time); }
14539 bool set_scale(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("scale", floats, count, time); }
14540 template<size_t count> bool set_scale(const float (&floats)[count], double time = TiMe::Default()) { return setArray("scale", floats, count, time); }
14544 FloatList get_scale(double time = TiMe::Default()) const { return getFloatList("scale", time); }
14545
14549 bool set_deep_output(bool val, double time = TiMe::Default()) { return setValue("deep_output", val, time); }
14553 bool get_deep_output(double time = TiMe::Default()) const { return getBool("deep_output", time); }
14554
14558 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
14562 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
14563
14567 bool set_fade_out_mode(int val, double time = TiMe::Default()) { return setValue("fade_out_mode", val, time); }
14571 int get_fade_out_mode(double time = TiMe::Default()) const { return getInt("fade_out_mode", time); }
14572
14576 bool set_fade_out_radius(float val, double time = TiMe::Default()) { return setValue("fade_out_radius", val, time); }
14580 float get_fade_out_radius(double time = TiMe::Default()) const { return getFloat("fade_out_radius", time); }
14581
14585 bool set_per_object_fade_out_radius(bool val, double time = TiMe::Default()) { return setValue("per_object_fade_out_radius", val, time); }
14589 bool get_per_object_fade_out_radius(double time = TiMe::Default()) const { return getBool("per_object_fade_out_radius", time); }
14590
14594 bool set_scatter_gi(bool val, double time = TiMe::Default()) { return setValue("scatter_gi", val, time); }
14598 bool get_scatter_gi(double time = TiMe::Default()) const { return getBool("scatter_gi", time); }
14599
14603 bool set_scatter_bounces(int val, double time = TiMe::Default()) { return setValue("scatter_bounces", val, time); }
14607 int get_scatter_bounces(double time = TiMe::Default()) const { return getInt("scatter_bounces", time); }
14608
14612 bool set_simplify_gi(bool val, double time = TiMe::Default()) { return setValue("simplify_gi", val, time); }
14616 bool get_simplify_gi(double time = TiMe::Default()) const { return getBool("simplify_gi", time); }
14617
14621 bool set_step_size(float val, double time = TiMe::Default()) { return setValue("step_size", val, time); }
14625 float get_step_size(double time = TiMe::Default()) const { return getFloat("step_size", time); }
14626
14630 bool set_max_steps(int val, double time = TiMe::Default()) { return setValue("max_steps", val, time); }
14634 int get_max_steps(double time = TiMe::Default()) const { return getInt("max_steps", time); }
14635
14639 bool set_tex_samples(int val, double time = TiMe::Default()) { return setValue("tex_samples", val, time); }
14643 int get_tex_samples(double time = TiMe::Default()) const { return getInt("tex_samples", time); }
14644
14648 bool set_cutoff_threshold(float val, double time = TiMe::Default()) { return setValue("cutoff_threshold", val, time); }
14652 float get_cutoff_threshold(double time = TiMe::Default()) const { return getFloat("cutoff_threshold", time); }
14653
14657 bool set_light_mode(int val, double time = TiMe::Default()) { return setValue("light_mode", val, time); }
14661 int get_light_mode(double time = TiMe::Default()) const { return getInt("light_mode", time); }
14662
14665 bool set_lights(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("lights", pluginList, time); }
14666 bool set_lights(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("lights", plugins, count, time); }
14667 template<size_t count> bool set_lights(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("lights", plugins, count, time); }
14670 PluginList get_lights(double time = TiMe::Default()) const { return getPluginList("lights", time); }
14671
14675 bool set_use_shade_instance(bool val, double time = TiMe::Default()) { return setValue("use_shade_instance", val, time); }
14679 bool get_use_shade_instance(double time = TiMe::Default()) const { return getBool("use_shade_instance", time); }
14680
14684 bool set_use_shade_data(bool val, double time = TiMe::Default()) { return setValue("use_shade_data", val, time); }
14688 bool get_use_shade_data(double time = TiMe::Default()) const { return getBool("use_shade_data", time); }
14689
14693 bool set_affect_background(bool val, double time = TiMe::Default()) { return setValue("affect_background", val, time); }
14697 bool get_affect_background(double time = TiMe::Default()) const { return getBool("affect_background", time); }
14698
14702 bool set_affect_reflections(bool val, double time = TiMe::Default()) { return setValue("affect_reflections", val, time); }
14706 bool get_affect_reflections(double time = TiMe::Default()) const { return getBool("affect_reflections", time); }
14707
14711 bool set_affect_refractions(bool val, double time = TiMe::Default()) { return setValue("affect_refractions", val, time); }
14715 bool get_affect_refractions(double time = TiMe::Default()) const { return getBool("affect_refractions", time); }
14716
14720 bool set_affect_shadows(bool val, double time = TiMe::Default()) { return setValue("affect_shadows", val, time); }
14724 bool get_affect_shadows(double time = TiMe::Default()) const { return getBool("affect_shadows", time); }
14725
14729 bool set_affect_gi(bool val, double time = TiMe::Default()) { return setValue("affect_gi", val, time); }
14733 bool get_affect_gi(double time = TiMe::Default()) const { return getBool("affect_gi", time); }
14734
14738 bool set_affect_camera(bool val, double time = TiMe::Default()) { return setValue("affect_camera", val, time); }
14742 bool get_affect_camera(double time = TiMe::Default()) const { return getBool("affect_camera", time); }
14743
14746 bool set_affect_alpha(bool val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
14749 bool get_affect_alpha(double time = TiMe::Default()) const { return getBool("affect_alpha", time); }
14750};
14751
14753class ExtChannel : public Plugin {
14754public:
14756 static constexpr const PluginTypeId getTypeId() { return 0x7877B2EF; }
14758 static constexpr const char* getType() { return "ExtChannel"; }
14759
14761 bool set_id(int val, double time = TiMe::Default()) { return setValue("id", val, time); }
14763 int get_id(double time = TiMe::Default()) const { return getInt("id", time); }
14764
14766 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
14768 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
14770 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
14771
14773 bool set_component_type(int val, double time = TiMe::Default()) { return setValue("component_type", val, time); }
14775 int get_component_type(double time = TiMe::Default()) const { return getInt("component_type", time); }
14776
14778 bool set_num_components(int val, double time = TiMe::Default()) { return setValue("num_components", val, time); }
14780 int get_num_components(double time = TiMe::Default()) const { return getInt("num_components", time); }
14781
14783 bool set_structure_type(const char* str, double time = TiMe::Default()) { return setValue("structure_type", str, time); }
14785 bool set_structure_type(const std::string& str, double time = TiMe::Default()) { return setValue("structure_type", str, time); }
14787 std::string get_structure_type(double time = TiMe::Default()) const { return getString("structure_type", time); }
14788
14790 bool set_flags(int val, double time = TiMe::Default()) { return setValue("flags", val, time); }
14792 int get_flags(double time = TiMe::Default()) const { return getInt("flags", time); }
14793
14795 bool set_data_raw(const IntList& intList, double time = TiMe::Default()) { return setValue("data_raw", intList, time); }
14796 bool set_data_raw(IntList&& intList, double time = TiMe::Default()) { return setValue("data_raw", std::move(intList), time); }
14797 bool set_data_raw(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("data_raw", ints, count, time); }
14798 template<size_t count> bool set_data_raw(const int (&ints)[count], double time = TiMe::Default()) { return setArray("data_raw", ints, count, time); }
14800 IntList get_data_raw(double time = TiMe::Default()) const { return getIntList("data_raw", time); }
14801
14803 bool set_data_int(const IntList& intList, double time = TiMe::Default()) { return setValue("data_int", intList, time); }
14804 bool set_data_int(IntList&& intList, double time = TiMe::Default()) { return setValue("data_int", std::move(intList), time); }
14805 bool set_data_int(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("data_int", ints, count, time); }
14806 template<size_t count> bool set_data_int(const int (&ints)[count], double time = TiMe::Default()) { return setArray("data_int", ints, count, time); }
14808 IntList get_data_int(double time = TiMe::Default()) const { return getIntList("data_int", time); }
14809
14811 bool set_data_float(const FloatList& floatList, double time = TiMe::Default()) { return setValue("data_float", floatList, time); }
14812 bool set_data_float(FloatList&& floatList, double time = TiMe::Default()) { return setValue("data_float", std::move(floatList), time); }
14813 bool set_data_float(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("data_float", floats, count, time); }
14814 template<size_t count> bool set_data_float(const float (&floats)[count], double time = TiMe::Default()) { return setArray("data_float", floats, count, time); }
14816 FloatList get_data_float(double time = TiMe::Default()) const { return getFloatList("data_float", time); }
14817
14819 bool set_data_double(const ValueList& doubleList, double time = TiMe::Default()) { return setValue("data_double", doubleList, time); }
14820 bool set_data_double(ValueList&& doubleList, double time = TiMe::Default()) { return setValue("data_double", std::move(doubleList), time); }
14821 bool set_data_double(const Value* doubles, size_t count, double time = TiMe::Default()) { return setArray("data_double", doubles, count, time); }
14822 template<size_t count> bool set_data_double(const Value (&doubles)[count], double time = TiMe::Default()) { return setArray("data_double", doubles, count, time); }
14823 template<size_t count> bool set_data_double(Value (&&doubles)[count], double time = TiMe::Default()) { return setArray("data_double", doubles, count, time); }
14825 ValueList get_data_double(double time = TiMe::Default()) const { return getValueList("data_double", time); }
14826
14828 bool set_data_vector(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("data_vector", vectorList, time); }
14829 bool set_data_vector(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("data_vector", std::move(vectorList), time); }
14830 bool set_data_vector(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("data_vector", vectors, count, time); }
14831 template<size_t count> bool set_data_vector(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("data_vector", vectors, count, time); }
14833 VectorList get_data_vector(double time = TiMe::Default()) const { return getVectorList("data_vector", time); }
14834
14836 bool set_data_color(const ColorList& colorList, double time = TiMe::Default()) { return setValue("data_color", colorList, time); }
14837 bool set_data_color(ColorList&& colorList, double time = TiMe::Default()) { return setValue("data_color", std::move(colorList), time); }
14838 bool set_data_color(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("data_color", colors, count, time); }
14839 template<size_t count> bool set_data_color(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("data_color", colors, count, time); }
14841 ColorList get_data_color(double time = TiMe::Default()) const { return getColorList("data_color", time); }
14842
14844 bool set_data_acolor(const ValueList& acolorList, double time = TiMe::Default()) { return setValue("data_acolor", acolorList, time); }
14845 bool set_data_acolor(ValueList&& acolorList, double time = TiMe::Default()) { return setValue("data_acolor", std::move(acolorList), time); }
14846 bool set_data_acolor(const Value* acolors, size_t count, double time = TiMe::Default()) { return setArray("data_acolor", acolors, count, time); }
14847 template<size_t count> bool set_data_acolor(const Value (&acolors)[count], double time = TiMe::Default()) { return setArray("data_acolor", acolors, count, time); }
14848 template<size_t count> bool set_data_acolor(Value (&&acolors)[count], double time = TiMe::Default()) { return setArray("data_acolor", acolors, count, time); }
14850 ValueList get_data_acolor(double time = TiMe::Default()) const { return getValueList("data_acolor", time); }
14851
14853 bool set_data_matrix(const ValueList& matrixList, double time = TiMe::Default()) { return setValue("data_matrix", matrixList, time); }
14854 bool set_data_matrix(ValueList&& matrixList, double time = TiMe::Default()) { return setValue("data_matrix", std::move(matrixList), time); }
14855 bool set_data_matrix(const Value* matrices, size_t count, double time = TiMe::Default()) { return setArray("data_matrix", matrices, count, time); }
14856 template<size_t count> bool set_data_matrix(const Value (&matrices)[count], double time = TiMe::Default()) { return setArray("data_matrix", matrices, count, time); }
14857 template<size_t count> bool set_data_matrix(Value (&&matrices)[count], double time = TiMe::Default()) { return setArray("data_matrix", matrices, count, time); }
14859 ValueList get_data_matrix(double time = TiMe::Default()) const { return getValueList("data_matrix", time); }
14860
14862 bool set_data_transform(const TransformList& transformList, double time = TiMe::Default()) { return setValue("data_transform", transformList, time); }
14863 bool set_data_transform(const Transform* transforms, size_t count, double time = TiMe::Default()) { return setArray("data_transform", transforms, count, time); }
14864 template<size_t count> bool set_data_transform(const Transform (&transforms)[count], double time = TiMe::Default()) { return setArray("data_transform", transforms, count, time); }
14866 TransformList get_data_transform(double time = TiMe::Default()) const { return getTransformList("data_transform", time); }
14867
14869 bool set_data_string(const StringList& stringList, double time = TiMe::Default()) { return setValue("data_string", stringList, time); }
14871 StringList get_data_string(double time = TiMe::Default()) const { return getStringList("data_string", time); }
14872};
14873
14875class ExtMapChannels : public Plugin {
14876public:
14878 static constexpr const PluginTypeId getTypeId() { return 0x783B1FEC; }
14880 static constexpr const char* getType() { return "ExtMapChannels"; }
14881
14883 bool set_map_channels(const ValueList& list, double time = TiMe::Default()) { return setValue("map_channels", list, time); }
14884 bool set_map_channels(ValueList&& list, double time = TiMe::Default()) { return setValue("map_channels", std::move(list), time); }
14885 bool set_map_channels(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
14886 template<size_t count> bool set_map_channels(const Value (&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
14887 template<size_t count> bool set_map_channels(Value (&&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
14889 ValueList get_map_channels(double time = TiMe::Default()) const { return getValueList("map_channels", time); }
14890};
14891
14893class FilterArea : public Plugin {
14894public:
14896 static constexpr const PluginTypeId getTypeId() { return 0x7782ACB9; }
14898 static constexpr const char* getType() { return "FilterArea"; }
14899
14900 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14901
14904 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
14907 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
14908};
14909
14911class FilterBox : public Plugin {
14912public:
14914 static constexpr const PluginTypeId getTypeId() { return 0x7782ACBA; }
14916 static constexpr const char* getType() { return "FilterBox"; }
14917
14918 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14919
14922 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
14925 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
14926};
14927
14929class FilterCatmullRom : public Plugin {
14930public:
14932 static constexpr const PluginTypeId getTypeId() { return 0x7782ACBD; }
14934 static constexpr const char* getType() { return "FilterCatmullRom"; }
14935
14936 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14937};
14938
14941public:
14943 static constexpr const PluginTypeId getTypeId() { return 0x77CEF21D; }
14945 static constexpr const char* getType() { return "FilterCookVariable"; }
14946
14947 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14948
14951 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
14954 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
14955};
14956
14958class FilterGaussian : public Plugin {
14959public:
14961 static constexpr const PluginTypeId getTypeId() { return 0x77A0B245; }
14963 static constexpr const char* getType() { return "FilterGaussian"; }
14964
14965 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14966
14969 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
14972 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
14973};
14974
14976class FilterLanczos : public Plugin {
14977public:
14979 static constexpr const PluginTypeId getTypeId() { return 0x7782ACBC; }
14981 static constexpr const char* getType() { return "FilterLanczos"; }
14982
14983 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
14984
14987 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
14990 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
14991};
14992
14994class FilterMitNet : public Plugin {
14995public:
14997 static constexpr const PluginTypeId getTypeId() { return 0x77CF94A3; }
14999 static constexpr const char* getType() { return "FilterMitNet"; }
15000
15001 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
15002
15005 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
15008 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
15009
15012 bool set_blur(float val, double time = TiMe::Default()) { return setValue("blur", val, time); }
15015 float get_blur(double time = TiMe::Default()) const { return getFloat("blur", time); }
15016
15019 bool set_ringing(float val, double time = TiMe::Default()) { return setValue("ringing", val, time); }
15022 float get_ringing(double time = TiMe::Default()) const { return getFloat("ringing", time); }
15023};
15024
15026class FilterPoint : public Plugin {
15027public:
15029 static constexpr const PluginTypeId getTypeId() { return 0x780C6C6B; }
15031 static constexpr const char* getType() { return "FilterPoint"; }
15032
15033 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
15034};
15035
15037class FilterSinc : public Plugin {
15038public:
15040 static constexpr const PluginTypeId getTypeId() { return 0x7782ACBE; }
15042 static constexpr const char* getType() { return "FilterSinc"; }
15043
15044 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
15045
15048 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
15051 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
15052};
15053
15055class FilterTriangle : public Plugin {
15056public:
15058 static constexpr const PluginTypeId getTypeId() { return 0x7782ACBB; }
15060 static constexpr const char* getType() { return "FilterTriangle"; }
15061
15062 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
15063
15066 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
15069 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
15070};
15071
15073class Float3ToAColor : public Plugin {
15074public:
15076 static constexpr const PluginTypeId getTypeId() { return 0x77831EDA; }
15078 static constexpr const char* getType() { return "Float3ToAColor"; }
15079
15080 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
15081
15085 bool set_float1(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float1", texturefloat, time); }
15089 bool set_float1(float texturefloat, double time = TiMe::Default()) { return setValue("float1", texturefloat, time); }
15093 Value get_float1(double time = TiMe::Default()) const { return getValue("float1", time); }
15094
15098 bool set_float2(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float2", texturefloat, time); }
15102 bool set_float2(float texturefloat, double time = TiMe::Default()) { return setValue("float2", texturefloat, time); }
15106 Value get_float2(double time = TiMe::Default()) const { return getValue("float2", time); }
15107
15111 bool set_float3(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float3", texturefloat, time); }
15115 bool set_float3(float texturefloat, double time = TiMe::Default()) { return setValue("float3", texturefloat, time); }
15119 Value get_float3(double time = TiMe::Default()) const { return getValue("float3", time); }
15120
15124 bool set_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
15128 bool set_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
15132 Value get_alpha(double time = TiMe::Default()) const { return getValue("alpha", time); }
15133
15135 PluginRef out_color() const { return PluginRef(*this, "color"); }
15136
15140 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
15144 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
15145};
15146
15148class FloatToTex : public Plugin {
15149public:
15151 static constexpr const PluginTypeId getTypeId() { return 0x77BF3A4A; }
15153 static constexpr const char* getType() { return "FloatToTex"; }
15154
15155 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
15156
15159 bool set_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
15162 bool set_input(float texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
15165 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
15166};
15167
15169class GeomBifrost : public Plugin {
15170public:
15172 static constexpr const PluginTypeId getTypeId() { return 0x781AF005; }
15174 static constexpr const char* getType() { return "GeomBifrost"; }
15175
15176 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
15177
15181 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
15185 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
15189 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
15190
15193 bool set_stream(const IntList& intList, double time = TiMe::Default()) { return setValue("stream", intList, time); }
15194 bool set_stream(IntList&& intList, double time = TiMe::Default()) { return setValue("stream", std::move(intList), time); }
15195 bool set_stream(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("stream", ints, count, time); }
15196 template<size_t count> bool set_stream(const int (&ints)[count], double time = TiMe::Default()) { return setArray("stream", ints, count, time); }
15199 IntList get_stream(double time = TiMe::Default()) const { return getIntList("stream", time); }
15200
15203 bool set_render_grid(const char* str, double time = TiMe::Default()) { return setValue("render_grid", str, time); }
15206 bool set_render_grid(const std::string& str, double time = TiMe::Default()) { return setValue("render_grid", str, time); }
15209 std::string get_render_grid(double time = TiMe::Default()) const { return getString("render_grid", time); }
15210
15213 bool set_velocity_grid(const char* str, double time = TiMe::Default()) { return setValue("velocity_grid", str, time); }
15216 bool set_velocity_grid(const std::string& str, double time = TiMe::Default()) { return setValue("velocity_grid", str, time); }
15219 std::string get_velocity_grid(double time = TiMe::Default()) const { return getString("velocity_grid", time); }
15220
15223 bool set_delay_load(bool val, double time = TiMe::Default()) { return setValue("delay_load", val, time); }
15226 bool get_delay_load(double time = TiMe::Default()) const { return getBool("delay_load", time); }
15227
15231 bool set_interpolation(int val, double time = TiMe::Default()) { return setValue("interpolation", val, time); }
15235 int get_interpolation(double time = TiMe::Default()) const { return getInt("interpolation", time); }
15236
15239 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
15242 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
15243
15246 bool set_positions(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("positions", vectorList, time); }
15247 bool set_positions(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("positions", std::move(vectorList), time); }
15248 bool set_positions(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("positions", vectors, count, time); }
15249 template<size_t count> bool set_positions(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("positions", vectors, count, time); }
15252 VectorList get_positions(double time = TiMe::Default()) const { return getVectorList("positions", time); }
15253
15256 bool set_velocities(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("velocities", vectorList, time); }
15257 bool set_velocities(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("velocities", std::move(vectorList), time); }
15258 bool set_velocities(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
15259 template<size_t count> bool set_velocities(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
15262 VectorList get_velocities(double time = TiMe::Default()) const { return getVectorList("velocities", time); }
15263
15266 bool set_userScalar1PP(const FloatList& floatList, double time = TiMe::Default()) { return setValue("userScalar1PP", floatList, time); }
15267 bool set_userScalar1PP(FloatList&& floatList, double time = TiMe::Default()) { return setValue("userScalar1PP", std::move(floatList), time); }
15268 bool set_userScalar1PP(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("userScalar1PP", floats, count, time); }
15269 template<size_t count> bool set_userScalar1PP(const float (&floats)[count], double time = TiMe::Default()) { return setArray("userScalar1PP", floats, count, time); }
15272 FloatList get_userScalar1PP(double time = TiMe::Default()) const { return getFloatList("userScalar1PP", time); }
15273
15276 bool set_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("ids", intList, time); }
15277 bool set_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("ids", std::move(intList), time); }
15278 bool set_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
15279 template<size_t count> bool set_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
15282 IntList get_ids(double time = TiMe::Default()) const { return getIntList("ids", time); }
15283
15286 bool set_age_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("age_pp", floatList, time); }
15287 bool set_age_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("age_pp", std::move(floatList), time); }
15288 bool set_age_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
15289 template<size_t count> bool set_age_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
15292 FloatList get_age_pp(double time = TiMe::Default()) const { return getFloatList("age_pp", time); }
15293
15296 bool set_acceleration_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", colorList, time); }
15297 bool set_acceleration_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", std::move(colorList), time); }
15298 bool set_acceleration_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
15299 template<size_t count> bool set_acceleration_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
15302 ColorList get_acceleration_pp(double time = TiMe::Default()) const { return getColorList("acceleration_pp", time); }
15303
15306 bool set_texture_coord_u(const FloatList& floatList, double time = TiMe::Default()) { return setValue("texture_coord_u", floatList, time); }
15307 bool set_texture_coord_u(FloatList&& floatList, double time = TiMe::Default()) { return setValue("texture_coord_u", std::move(floatList), time); }
15308 bool set_texture_coord_u(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("texture_coord_u", floats, count, time); }
15309 template<size_t count> bool set_texture_coord_u(const float (&floats)[count], double time = TiMe::Default()) { return setArray("texture_coord_u", floats, count, time); }
15312 FloatList get_texture_coord_u(double time = TiMe::Default()) const { return getFloatList("texture_coord_u", time); }
15313
15316 bool set_texture_coord_v(const FloatList& floatList, double time = TiMe::Default()) { return setValue("texture_coord_v", floatList, time); }
15317 bool set_texture_coord_v(FloatList&& floatList, double time = TiMe::Default()) { return setValue("texture_coord_v", std::move(floatList), time); }
15318 bool set_texture_coord_v(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("texture_coord_v", floats, count, time); }
15319 template<size_t count> bool set_texture_coord_v(const float (&floats)[count], double time = TiMe::Default()) { return setArray("texture_coord_v", floats, count, time); }
15322 FloatList get_texture_coord_v(double time = TiMe::Default()) const { return getFloatList("texture_coord_v", time); }
15323};
15324
15326class GeomBox : public Plugin {
15327public:
15329 static constexpr const PluginTypeId getTypeId() { return 0x77CF6BFD; }
15331 static constexpr const char* getType() { return "GeomBox"; }
15332
15333 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
15334
15337 bool set_size_x(float val, double time = TiMe::Default()) { return setValue("size_x", val, time); }
15340 float get_size_x(double time = TiMe::Default()) const { return getFloat("size_x", time); }
15341
15344 bool set_size_y(float val, double time = TiMe::Default()) { return setValue("size_y", val, time); }
15347 float get_size_y(double time = TiMe::Default()) const { return getFloat("size_y", time); }
15348
15351 bool set_size_z(float val, double time = TiMe::Default()) { return setValue("size_z", val, time); }
15354 float get_size_z(double time = TiMe::Default()) const { return getFloat("size_z", time); }
15355
15358 bool set_is_volumetric(bool val, double time = TiMe::Default()) { return setValue("is_volumetric", val, time); }
15361 bool get_is_volumetric(double time = TiMe::Default()) const { return getBool("is_volumetric", time); }
15362};
15363
15366public:
15368 static constexpr const PluginTypeId getTypeId() { return 0x7792B375; }
15370 static constexpr const char* getType() { return "GeomDisplacedMesh"; }
15371
15372 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
15373
15376 bool set_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("mesh", plugin, time); }
15379 PluginRef get_mesh(double time = TiMe::Default()) const { return getPlugin("mesh", time); }
15380
15383 bool set_displacement_tex_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displacement_tex_color", texture, time); }
15386 bool set_displacement_tex_color(const AColor& texture, double time = TiMe::Default()) { return setValue("displacement_tex_color", texture, time); }
15389 Value get_displacement_tex_color(double time = TiMe::Default()) const { return getValue("displacement_tex_color", time); }
15390
15393 bool set_displacement_tex_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("displacement_tex_float", texturefloat, time); }
15396 bool set_displacement_tex_float(float texturefloat, double time = TiMe::Default()) { return setValue("displacement_tex_float", texturefloat, time); }
15399 Value get_displacement_tex_float(double time = TiMe::Default()) const { return getValue("displacement_tex_float", time); }
15400
15404 bool set_displacement_amount(float val, double time = TiMe::Default()) { return setValue("displacement_amount", val, time); }
15408 float get_displacement_amount(double time = TiMe::Default()) const { return getFloat("displacement_amount", time); }
15409
15413 bool set_displacement_shift(float val, double time = TiMe::Default()) { return setValue("displacement_shift", val, time); }
15417 float get_displacement_shift(double time = TiMe::Default()) const { return getFloat("displacement_shift", time); }
15418
15422 bool set_use_globals(bool val, double time = TiMe::Default()) { return setValue("use_globals", val, time); }
15426 bool get_use_globals(double time = TiMe::Default()) const { return getBool("use_globals", time); }
15427
15431 bool set_view_dep(bool val, double time = TiMe::Default()) { return setValue("view_dep", val, time); }
15435 bool get_view_dep(double time = TiMe::Default()) const { return getBool("view_dep", time); }
15436
15440 bool set_edge_length(float val, double time = TiMe::Default()) { return setValue("edge_length", val, time); }
15444 float get_edge_length(double time = TiMe::Default()) const { return getFloat("edge_length", time); }
15445
15449 bool set_max_subdivs(int val, double time = TiMe::Default()) { return setValue("max_subdivs", val, time); }
15453 int get_max_subdivs(double time = TiMe::Default()) const { return getInt("max_subdivs", time); }
15454
15458 bool set_keep_continuity(bool val, double time = TiMe::Default()) { return setValue("keep_continuity", val, time); }
15462 bool get_keep_continuity(double time = TiMe::Default()) const { return getBool("keep_continuity", time); }
15463
15467 bool set_water_level(float val, double time = TiMe::Default()) { return setValue("water_level", val, time); }
15471 float get_water_level(double time = TiMe::Default()) const { return getFloat("water_level", time); }
15472
15476 bool set_vector_displacement(int val, double time = TiMe::Default()) { return setValue("vector_displacement", val, time); }
15480 int get_vector_displacement(double time = TiMe::Default()) const { return getInt("vector_displacement", time); }
15481
15485 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
15489 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
15490
15494 bool set_map_channel_name(const char* str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
15498 bool set_map_channel_name(const std::string& str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
15502 std::string get_map_channel_name(double time = TiMe::Default()) const { return getString("map_channel_name", time); }
15503
15507 bool set_static_displacement(bool val, double time = TiMe::Default()) { return setValue("static_displacement", val, time); }
15511 bool get_static_displacement(double time = TiMe::Default()) const { return getBool("static_displacement", time); }
15512
15516 bool set_image_width(int val, double time = TiMe::Default()) { return setValue("image_width", val, time); }
15520 int get_image_width(double time = TiMe::Default()) const { return getInt("image_width", time); }
15521
15525 bool set_cache_normals(bool val, double time = TiMe::Default()) { return setValue("cache_normals", val, time); }
15529 bool get_cache_normals(double time = TiMe::Default()) const { return getBool("cache_normals", time); }
15530
15534 bool set_object_space_displacement(int val, double time = TiMe::Default()) { return setValue("object_space_displacement", val, time); }
15538 int get_object_space_displacement(double time = TiMe::Default()) const { return getInt("object_space_displacement", time); }
15539
15543 bool set_use_bounds(bool val, double time = TiMe::Default()) { return setValue("use_bounds", val, time); }
15547 bool get_use_bounds(double time = TiMe::Default()) const { return getBool("use_bounds", time); }
15548
15552 bool set_min_bound(const Color& color, double time = TiMe::Default()) { return setValue("min_bound", color, time); }
15556 Color get_min_bound(double time = TiMe::Default()) const { return getColor("min_bound", time); }
15557
15561 bool set_max_bound(const Color& color, double time = TiMe::Default()) { return setValue("max_bound", color, time); }
15565 Color get_max_bound(double time = TiMe::Default()) const { return getColor("max_bound", time); }
15566
15570 bool set_displace_2d(bool val, double time = TiMe::Default()) { return setValue("displace_2d", val, time); }
15574 bool get_displace_2d(double time = TiMe::Default()) const { return getBool("displace_2d", time); }
15575
15579 bool set_displace_2d_multi_tile(bool val, double time = TiMe::Default()) { return setValue("displace_2d_multi_tile", val, time); }
15583 bool get_displace_2d_multi_tile(double time = TiMe::Default()) const { return getBool("displace_2d_multi_tile", time); }
15584
15588 bool set_displace_2d_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("displace_2d_transform", transform, time); }
15592 Transform get_displace_2d_transform(double time = TiMe::Default()) const { return getTransform("displace_2d_transform", time); }
15593
15597 bool set_resolution(int val, double time = TiMe::Default()) { return setValue("resolution", val, time); }
15601 int get_resolution(double time = TiMe::Default()) const { return getInt("resolution", time); }
15602
15606 bool set_precision(int val, double time = TiMe::Default()) { return setValue("precision", val, time); }
15610 int get_precision(double time = TiMe::Default()) const { return getInt("precision", time); }
15611
15615 bool set_tight_bounds(bool val, double time = TiMe::Default()) { return setValue("tight_bounds", val, time); }
15619 bool get_tight_bounds(double time = TiMe::Default()) const { return getBool("tight_bounds", time); }
15620
15624 bool set_filter_texture(bool val, double time = TiMe::Default()) { return setValue("filter_texture", val, time); }
15628 bool get_filter_texture(double time = TiMe::Default()) const { return getBool("filter_texture", time); }
15629
15633 bool set_filter_blur(float val, double time = TiMe::Default()) { return setValue("filter_blur", val, time); }
15637 float get_filter_blur(double time = TiMe::Default()) const { return getFloat("filter_blur", time); }
15638};
15639
15641class GeomEnmesh : public Plugin {
15642public:
15644 static constexpr const PluginTypeId getTypeId() { return 0x78684DE4; }
15646 static constexpr const char* getType() { return "GeomEnmesh"; }
15647
15648 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
15649
15651 bool set_source_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("source_mesh", plugin, time); }
15653 PluginRef get_source_mesh(double time = TiMe::Default()) const { return getPlugin("source_mesh", time); }
15654
15656 bool set_ref_nodes(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("ref_nodes", pluginList, time); }
15657 bool set_ref_nodes(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("ref_nodes", plugins, count, time); }
15658 template<size_t count> bool set_ref_nodes(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("ref_nodes", plugins, count, time); }
15660 PluginList get_ref_nodes(double time = TiMe::Default()) const { return getPluginList("ref_nodes", time); }
15661
15664 bool set_obj_scale(float val, double time = TiMe::Default()) { return setValue("obj_scale", val, time); }
15667 float get_obj_scale(double time = TiMe::Default()) const { return getFloat("obj_scale", time); }
15668
15671 bool set_rep_u(float val, double time = TiMe::Default()) { return setValue("rep_u", val, time); }
15674 float get_rep_u(double time = TiMe::Default()) const { return getFloat("rep_u", time); }
15675
15678 bool set_rep_v(float val, double time = TiMe::Default()) { return setValue("rep_v", val, time); }
15681 float get_rep_v(double time = TiMe::Default()) const { return getFloat("rep_v", time); }
15682
15685 bool set_flip_u(bool val, double time = TiMe::Default()) { return setValue("flip_u", val, time); }
15688 bool get_flip_u(double time = TiMe::Default()) const { return getBool("flip_u", time); }
15689
15692 bool set_flip_v(bool val, double time = TiMe::Default()) { return setValue("flip_v", val, time); }
15695 bool get_flip_v(double time = TiMe::Default()) const { return getBool("flip_v", time); }
15696
15699 bool set_height(float val, double time = TiMe::Default()) { return setValue("height", val, time); }
15702 float get_height(double time = TiMe::Default()) const { return getFloat("height", time); }
15703
15707 bool set_rotation(float val, double time = TiMe::Default()) { return setValue("rotation", val, time); }
15711 float get_rotation(double time = TiMe::Default()) const { return getFloat("rotation", time); }
15712
15715 bool set_offset_u(float val, double time = TiMe::Default()) { return setValue("offset_u", val, time); }
15718 float get_offset_u(double time = TiMe::Default()) const { return getFloat("offset_u", time); }
15719
15722 bool set_offset_v(float val, double time = TiMe::Default()) { return setValue("offset_v", val, time); }
15725 float get_offset_v(double time = TiMe::Default()) const { return getFloat("offset_v", time); }
15726
15729 bool set_height_offset(float val, double time = TiMe::Default()) { return setValue("height_offset", val, time); }
15732 float get_height_offset(double time = TiMe::Default()) const { return getFloat("height_offset", time); }
15733
15736 bool set_random_offset_u(float val, double time = TiMe::Default()) { return setValue("random_offset_u", val, time); }
15739 float get_random_offset_u(double time = TiMe::Default()) const { return getFloat("random_offset_u", time); }
15740
15743 bool set_random_offset_v(float val, double time = TiMe::Default()) { return setValue("random_offset_v", val, time); }
15746 float get_random_offset_v(double time = TiMe::Default()) const { return getFloat("random_offset_v", time); }
15747
15751 bool set_cropbox_x(float val, double time = TiMe::Default()) { return setValue("cropbox_x", val, time); }
15755 float get_cropbox_x(double time = TiMe::Default()) const { return getFloat("cropbox_x", time); }
15756
15760 bool set_cropbox_y(float val, double time = TiMe::Default()) { return setValue("cropbox_y", val, time); }
15764 float get_cropbox_y(double time = TiMe::Default()) const { return getFloat("cropbox_y", time); }
15765
15769 bool set_cropbox_z(float val, double time = TiMe::Default()) { return setValue("cropbox_z", val, time); }
15773 float get_cropbox_z(double time = TiMe::Default()) const { return getFloat("cropbox_z", time); }
15774
15777 bool set_gizmo_center(const Vector& vector, double time = TiMe::Default()) { return setValue("gizmo_center", vector, time); }
15780 Vector get_gizmo_center(double time = TiMe::Default()) const { return getVector("gizmo_center", time); }
15781
15784 bool set_gizmo_rotate(const Matrix& matrix, double time = TiMe::Default()) { return setValue("gizmo_rotate", matrix, time); }
15787 Matrix get_gizmo_rotate(double time = TiMe::Default()) const { return getMatrix("gizmo_rotate", time); }
15788
15791 bool set_gizmo_scale(const Matrix& matrix, double time = TiMe::Default()) { return setValue("gizmo_scale", matrix, time); }
15794 Matrix get_gizmo_scale(double time = TiMe::Default()) const { return getMatrix("gizmo_scale", time); }
15795
15798 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
15801 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
15802
15805 bool set_map_channel_name(const char* str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
15808 bool set_map_channel_name(const std::string& str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
15811 std::string get_map_channel_name(double time = TiMe::Default()) const { return getString("map_channel_name", time); }
15812
15815 bool set_use_mesh_uvw_mapping(bool val, double time = TiMe::Default()) { return setValue("use_mesh_uvw_mapping", val, time); }
15818 bool get_use_mesh_uvw_mapping(double time = TiMe::Default()) const { return getBool("use_mesh_uvw_mapping", time); }
15819
15822 bool set_use_mesh_ids(bool val, double time = TiMe::Default()) { return setValue("use_mesh_ids", val, time); }
15825 bool get_use_mesh_ids(double time = TiMe::Default()) const { return getBool("use_mesh_ids", time); }
15826
15829 bool set_use_rotation_step(bool val, double time = TiMe::Default()) { return setValue("use_rotation_step", val, time); }
15832 bool get_use_rotation_step(double time = TiMe::Default()) const { return getBool("use_rotation_step", time); }
15833
15836 bool set_random_rotation(float val, double time = TiMe::Default()) { return setValue("random_rotation", val, time); }
15839 float get_random_rotation(double time = TiMe::Default()) const { return getFloat("random_rotation", time); }
15840
15844 bool set_flip_axis(int val, double time = TiMe::Default()) { return setValue("flip_axis", val, time); }
15848 int get_flip_axis(double time = TiMe::Default()) const { return getInt("flip_axis", time); }
15849};
15850
15852class GeomGaussians : public Plugin {
15853public:
15855 static constexpr const PluginTypeId getTypeId() { return 0x78963E16; }
15857 static constexpr const char* getType() { return "GeomGaussians"; }
15858
15859 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
15860
15864 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
15868 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
15872 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
15873
15877 bool set_flip_axis(int val, double time = TiMe::Default()) { return setValue("flip_axis", val, time); }
15881 int get_flip_axis(double time = TiMe::Default()) const { return getInt("flip_axis", time); }
15882
15885 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
15888 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
15889
15892 bool set_affect_camera(bool val, double time = TiMe::Default()) { return setValue("affect_camera", val, time); }
15895 bool get_affect_camera(double time = TiMe::Default()) const { return getBool("affect_camera", time); }
15896
15899 bool set_affect_shadows(bool val, double time = TiMe::Default()) { return setValue("affect_shadows", val, time); }
15902 bool get_affect_shadows(double time = TiMe::Default()) const { return getBool("affect_shadows", time); }
15903
15906 bool set_affect_reflections(bool val, double time = TiMe::Default()) { return setValue("affect_reflections", val, time); }
15909 bool get_affect_reflections(double time = TiMe::Default()) const { return getBool("affect_reflections", time); }
15910
15913 bool set_affect_refractions(bool val, double time = TiMe::Default()) { return setValue("affect_refractions", val, time); }
15916 bool get_affect_refractions(double time = TiMe::Default()) const { return getBool("affect_refractions", time); }
15917
15920 bool set_affect_matte_surfaces(bool val, double time = TiMe::Default()) { return setValue("affect_matte_surfaces", val, time); }
15923 bool get_affect_matte_surfaces(double time = TiMe::Default()) const { return getBool("affect_matte_surfaces", time); }
15924
15928 bool set_rgb_color_space(int val, double time = TiMe::Default()) { return setValue("rgb_color_space", val, time); }
15932 int get_rgb_color_space(double time = TiMe::Default()) const { return getInt("rgb_color_space", time); }
15933
15937 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
15941 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
15942
15945 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
15948 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
15949};
15950
15952class GeomHair : public Plugin {
15953public:
15955 static constexpr const PluginTypeId getTypeId() { return 0x77CE55DD; }
15957 static constexpr const char* getType() { return "GeomHair"; }
15958
15959 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
15960
15963 bool set_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("mesh", plugin, time); }
15966 PluginRef get_mesh(double time = TiMe::Default()) const { return getPlugin("mesh", time); }
15967
15971 bool set_length_base(float val, double time = TiMe::Default()) { return setValue("length_base", val, time); }
15975 float get_length_base(double time = TiMe::Default()) const { return getFloat("length_base", time); }
15976
15980 bool set_thickness_base(float val, double time = TiMe::Default()) { return setValue("thickness_base", val, time); }
15984 float get_thickness_base(double time = TiMe::Default()) const { return getFloat("thickness_base", time); }
15985
15989 bool set_gravity_base(float val, double time = TiMe::Default()) { return setValue("gravity_base", val, time); }
15993 float get_gravity_base(double time = TiMe::Default()) const { return getFloat("gravity_base", time); }
15994
15998 bool set_gravity_vector(const Vector& vector, double time = TiMe::Default()) { return setValue("gravity_vector", vector, time); }
16002 Vector get_gravity_vector(double time = TiMe::Default()) const { return getVector("gravity_vector", time); }
16003
16007 bool set_bend(float val, double time = TiMe::Default()) { return setValue("bend", val, time); }
16011 float get_bend(double time = TiMe::Default()) const { return getFloat("bend", time); }
16012
16016 bool set_taper(float val, double time = TiMe::Default()) { return setValue("taper", val, time); }
16020 float get_taper(double time = TiMe::Default()) const { return getFloat("taper", time); }
16021
16025 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
16029 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
16030
16034 bool set_dir_var(float val, double time = TiMe::Default()) { return setValue("dir_var", val, time); }
16038 float get_dir_var(double time = TiMe::Default()) const { return getFloat("dir_var", time); }
16039
16043 bool set_length_var(float val, double time = TiMe::Default()) { return setValue("length_var", val, time); }
16047 float get_length_var(double time = TiMe::Default()) const { return getFloat("length_var", time); }
16048
16052 bool set_thickness_var(float val, double time = TiMe::Default()) { return setValue("thickness_var", val, time); }
16056 float get_thickness_var(double time = TiMe::Default()) const { return getFloat("thickness_var", time); }
16057
16061 bool set_gravity_var(float val, double time = TiMe::Default()) { return setValue("gravity_var", val, time); }
16065 float get_gravity_var(double time = TiMe::Default()) const { return getFloat("gravity_var", time); }
16066
16070 bool set_curl_radius_var(float val, double time = TiMe::Default()) { return setValue("curl_radius_var", val, time); }
16074 float get_curl_radius_var(double time = TiMe::Default()) const { return getFloat("curl_radius_var", time); }
16075
16079 bool set_curl_enabled(bool val, double time = TiMe::Default()) { return setValue("curl_enabled", val, time); }
16083 bool get_curl_enabled(double time = TiMe::Default()) const { return getBool("curl_enabled", time); }
16084
16088 bool set_curl_radius(float val, double time = TiMe::Default()) { return setValue("curl_radius", val, time); }
16092 float get_curl_radius(double time = TiMe::Default()) const { return getFloat("curl_radius", time); }
16093
16097 bool set_curl_angle(float val, double time = TiMe::Default()) { return setValue("curl_angle", val, time); }
16101 float get_curl_angle(double time = TiMe::Default()) const { return getFloat("curl_angle", time); }
16102
16106 bool set_hair_sides(int val, double time = TiMe::Default()) { return setValue("hair_sides", val, time); }
16110 int get_hair_sides(double time = TiMe::Default()) const { return getInt("hair_sides", time); }
16111
16115 bool set_hair_knots(int val, double time = TiMe::Default()) { return setValue("hair_knots", val, time); }
16119 int get_hair_knots(double time = TiMe::Default()) const { return getInt("hair_knots", time); }
16120
16124 bool set_lod_enabled(bool val, double time = TiMe::Default()) { return setValue("lod_enabled", val, time); }
16128 bool get_lod_enabled(double time = TiMe::Default()) const { return getBool("lod_enabled", time); }
16129
16133 bool set_lod_startDistance(float val, double time = TiMe::Default()) { return setValue("lod_startDistance", val, time); }
16137 float get_lod_startDistance(double time = TiMe::Default()) const { return getFloat("lod_startDistance", time); }
16138
16142 bool set_lod_rate(float val, double time = TiMe::Default()) { return setValue("lod_rate", val, time); }
16146 float get_lod_rate(double time = TiMe::Default()) const { return getFloat("lod_rate", time); }
16147
16151 bool set_tessellation_on(bool val, double time = TiMe::Default()) { return setValue("tessellation_on", val, time); }
16155 bool get_tessellation_on(double time = TiMe::Default()) const { return getBool("tessellation_on", time); }
16156
16160 bool set_tessellation_edge_length(float val, double time = TiMe::Default()) { return setValue("tessellation_edge_length", val, time); }
16164 float get_tessellation_edge_length(double time = TiMe::Default()) const { return getFloat("tessellation_edge_length", time); }
16165
16169 bool set_faceList(const IntList& intList, double time = TiMe::Default()) { return setValue("faceList", intList, time); }
16170 bool set_faceList(IntList&& intList, double time = TiMe::Default()) { return setValue("faceList", std::move(intList), time); }
16171 bool set_faceList(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("faceList", ints, count, time); }
16172 template<size_t count> bool set_faceList(const int (&ints)[count], double time = TiMe::Default()) { return setArray("faceList", ints, count, time); }
16176 IntList get_faceList(double time = TiMe::Default()) const { return getIntList("faceList", time); }
16177
16181 bool set_distribution(int val, double time = TiMe::Default()) { return setValue("distribution", val, time); }
16185 int get_distribution(double time = TiMe::Default()) const { return getInt("distribution", time); }
16186
16190 bool set_perFace(int val, double time = TiMe::Default()) { return setValue("perFace", val, time); }
16194 int get_perFace(double time = TiMe::Default()) const { return getInt("perFace", time); }
16195
16199 bool set_perArea(float val, double time = TiMe::Default()) { return setValue("perArea", val, time); }
16203 float get_perArea(double time = TiMe::Default()) const { return getFloat("perArea", time); }
16204
16208 bool set_fixed_areas(int val, double time = TiMe::Default()) { return setValue("fixed_areas", val, time); }
16212 int get_fixed_areas(double time = TiMe::Default()) const { return getInt("fixed_areas", time); }
16213
16217 bool set_areaList(const FloatList& floatList, double time = TiMe::Default()) { return setValue("areaList", floatList, time); }
16218 bool set_areaList(FloatList&& floatList, double time = TiMe::Default()) { return setValue("areaList", std::move(floatList), time); }
16219 bool set_areaList(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("areaList", floats, count, time); }
16220 template<size_t count> bool set_areaList(const float (&floats)[count], double time = TiMe::Default()) { return setArray("areaList", floats, count, time); }
16224 FloatList get_areaList(double time = TiMe::Default()) const { return getFloatList("areaList", time); }
16225
16229 bool set_flat_normals(bool val, double time = TiMe::Default()) { return setValue("flat_normals", val, time); }
16233 bool get_flat_normals(double time = TiMe::Default()) const { return getBool("flat_normals", time); }
16234
16238 bool set_override_mtlID_on(bool val, double time = TiMe::Default()) { return setValue("override_mtlID_on", val, time); }
16242 bool get_override_mtlID_on(double time = TiMe::Default()) const { return getBool("override_mtlID_on", time); }
16243
16247 bool set_override_mtlID(int val, double time = TiMe::Default()) { return setValue("override_mtlID", val, time); }
16251 int get_override_mtlID(double time = TiMe::Default()) const { return getInt("override_mtlID", time); }
16252
16256 bool set_ignore_base_mesh_displacement(bool val, double time = TiMe::Default()) { return setValue("ignore_base_mesh_displacement", val, time); }
16260 bool get_ignore_base_mesh_displacement(double time = TiMe::Default()) const { return getBool("ignore_base_mesh_displacement", time); }
16261
16265 bool set_placement(int val, double time = TiMe::Default()) { return setValue("placement", val, time); }
16269 int get_placement(double time = TiMe::Default()) const { return getInt("placement", time); }
16270
16274 bool set_mtlID(int val, double time = TiMe::Default()) { return setValue("mtlID", val, time); }
16278 int get_mtlID(double time = TiMe::Default()) const { return getInt("mtlID", time); }
16279
16283 bool set_mtlIDList(const IntList& intList, double time = TiMe::Default()) { return setValue("mtlIDList", intList, time); }
16284 bool set_mtlIDList(IntList&& intList, double time = TiMe::Default()) { return setValue("mtlIDList", std::move(intList), time); }
16285 bool set_mtlIDList(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("mtlIDList", ints, count, time); }
16286 template<size_t count> bool set_mtlIDList(const int (&ints)[count], double time = TiMe::Default()) { return setArray("mtlIDList", ints, count, time); }
16290 IntList get_mtlIDList(double time = TiMe::Default()) const { return getIntList("mtlIDList", time); }
16291
16295 bool set_generate_w_coord(bool val, double time = TiMe::Default()) { return setValue("generate_w_coord", val, time); }
16299 bool get_generate_w_coord(double time = TiMe::Default()) const { return getBool("generate_w_coord", time); }
16300
16304 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
16308 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
16309
16312 bool set_bend_direction_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bend_direction_tex", texture, time); }
16315 bool set_bend_direction_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("bend_direction_tex", texture, time); }
16318 Value get_bend_direction_tex(double time = TiMe::Default()) const { return getValue("bend_direction_tex", time); }
16319
16322 bool set_initial_direction_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("initial_direction_tex", texture, time); }
16325 bool set_initial_direction_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("initial_direction_tex", texture, time); }
16328 Value get_initial_direction_tex(double time = TiMe::Default()) const { return getValue("initial_direction_tex", time); }
16329
16332 bool set_length_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("length_tex", texturefloat, time); }
16335 bool set_length_tex(float texturefloat, double time = TiMe::Default()) { return setValue("length_tex", texturefloat, time); }
16338 Value get_length_tex(double time = TiMe::Default()) const { return getValue("length_tex", time); }
16339
16342 bool set_thickness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("thickness_tex", texturefloat, time); }
16345 bool set_thickness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("thickness_tex", texturefloat, time); }
16348 Value get_thickness_tex(double time = TiMe::Default()) const { return getValue("thickness_tex", time); }
16349
16352 bool set_gravity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gravity_tex", texturefloat, time); }
16355 bool set_gravity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("gravity_tex", texturefloat, time); }
16358 Value get_gravity_tex(double time = TiMe::Default()) const { return getValue("gravity_tex", time); }
16359
16362 bool set_bend_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bend_tex", texturefloat, time); }
16365 bool set_bend_tex(float texturefloat, double time = TiMe::Default()) { return setValue("bend_tex", texturefloat, time); }
16368 Value get_bend_tex(double time = TiMe::Default()) const { return getValue("bend_tex", time); }
16369
16372 bool set_density_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("density_tex", texturefloat, time); }
16375 bool set_density_tex(float texturefloat, double time = TiMe::Default()) { return setValue("density_tex", texturefloat, time); }
16378 Value get_density_tex(double time = TiMe::Default()) const { return getValue("density_tex", time); }
16379
16382 bool set_curl_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("curl_tex", texture, time); }
16385 bool set_curl_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("curl_tex", texture, time); }
16388 Value get_curl_tex(double time = TiMe::Default()) const { return getValue("curl_tex", time); }
16389};
16390
16392class GeomImagePlane : public Plugin {
16393public:
16395 static constexpr const PluginTypeId getTypeId() { return 0x77ED9ED9; }
16397 static constexpr const char* getType() { return "GeomImagePlane"; }
16398
16399 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
16400};
16401
16403class GeomInstancer : public Plugin {
16404public:
16406 static constexpr const PluginTypeId getTypeId() { return 0x78865E06; }
16408 static constexpr const char* getType() { return "GeomInstancer"; }
16409
16410 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
16411
16415 bool set_use_rayserver(bool val, double time = TiMe::Default()) { return setValue("use_rayserver", val, time); }
16419 bool get_use_rayserver(double time = TiMe::Default()) const { return getBool("use_rayserver", time); }
16420
16423 bool set_sources(const ValueList& list, double time = TiMe::Default()) { return setValue("sources", list, time); }
16424 bool set_sources(ValueList&& list, double time = TiMe::Default()) { return setValue("sources", std::move(list), time); }
16425 bool set_sources(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("sources", values, count, time); }
16426 template<size_t count> bool set_sources(const Value (&values)[count], double time = TiMe::Default()) { return setArray("sources", values, count, time); }
16427 template<size_t count> bool set_sources(Value (&&values)[count], double time = TiMe::Default()) { return setArray("sources", values, count, time); }
16430 ValueList get_sources(double time = TiMe::Default()) const { return getValueList("sources", time); }
16431
16433 bool set_instances_generator(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("instances_generator", plugin, time); }
16435 PluginRef get_instances_generator(double time = TiMe::Default()) const { return getPlugin("instances_generator", time); }
16436
16440 bool set_use_source_transform(int val, double time = TiMe::Default()) { return setValue("use_source_transform", val, time); }
16444 int get_use_source_transform(double time = TiMe::Default()) const { return getInt("use_source_transform", time); }
16445
16449 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
16453 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
16457 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
16458
16462 bool set_transforms_vector(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("transforms_vector", vectorList, time); }
16463 bool set_transforms_vector(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("transforms_vector", std::move(vectorList), time); }
16464 bool set_transforms_vector(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("transforms_vector", vectors, count, time); }
16465 template<size_t count> bool set_transforms_vector(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("transforms_vector", vectors, count, time); }
16469 VectorList get_transforms_vector(double time = TiMe::Default()) const { return getVectorList("transforms_vector", time); }
16470
16474 bool set_transforms(const TransformList& transformList, double time = TiMe::Default()) { return setValue("transforms", transformList, time); }
16475 bool set_transforms(const Transform* transforms, size_t count, double time = TiMe::Default()) { return setArray("transforms", transforms, count, time); }
16476 template<size_t count> bool set_transforms(const Transform (&transforms)[count], double time = TiMe::Default()) { return setArray("transforms", transforms, count, time); }
16480 TransformList get_transforms(double time = TiMe::Default()) const { return getTransformList("transforms", time); }
16481
16485 bool set_base_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("base_transform", transform, time); }
16489 Transform get_base_transform(double time = TiMe::Default()) const { return getTransform("base_transform", time); }
16490
16494 bool set_velocities(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("velocities", vectorList, time); }
16495 bool set_velocities(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("velocities", std::move(vectorList), time); }
16496 bool set_velocities(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
16497 template<size_t count> bool set_velocities(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
16501 VectorList get_velocities(double time = TiMe::Default()) const { return getVectorList("velocities", time); }
16502
16506 bool set_exclude_list(const StringList& stringList, double time = TiMe::Default()) { return setValue("exclude_list", stringList, time); }
16510 StringList get_exclude_list(double time = TiMe::Default()) const { return getStringList("exclude_list", time); }
16511
16515 bool set_exclude_list_inclusive(int val, double time = TiMe::Default()) { return setValue("exclude_list_inclusive", val, time); }
16519 int get_exclude_list_inclusive(double time = TiMe::Default()) const { return getInt("exclude_list_inclusive", time); }
16520
16524 bool set_flip_axis(int val, double time = TiMe::Default()) { return setValue("flip_axis", val, time); }
16528 int get_flip_axis(double time = TiMe::Default()) const { return getInt("flip_axis", time); }
16529
16532 bool set_shaders(const ValueList& list, double time = TiMe::Default()) { return setValue("shaders", list, time); }
16533 bool set_shaders(ValueList&& list, double time = TiMe::Default()) { return setValue("shaders", std::move(list), time); }
16534 bool set_shaders(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("shaders", values, count, time); }
16535 template<size_t count> bool set_shaders(const Value (&values)[count], double time = TiMe::Default()) { return setArray("shaders", values, count, time); }
16536 template<size_t count> bool set_shaders(Value (&&values)[count], double time = TiMe::Default()) { return setArray("shaders", values, count, time); }
16539 ValueList get_shaders(double time = TiMe::Default()) const { return getValueList("shaders", time); }
16540
16543 bool set_trimmers(const ValueList& list, double time = TiMe::Default()) { return setValue("trimmers", list, time); }
16544 bool set_trimmers(ValueList&& list, double time = TiMe::Default()) { return setValue("trimmers", std::move(list), time); }
16545 bool set_trimmers(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("trimmers", values, count, time); }
16546 template<size_t count> bool set_trimmers(const Value (&values)[count], double time = TiMe::Default()) { return setArray("trimmers", values, count, time); }
16547 template<size_t count> bool set_trimmers(Value (&&values)[count], double time = TiMe::Default()) { return setArray("trimmers", values, count, time); }
16550 ValueList get_trimmers(double time = TiMe::Default()) const { return getValueList("trimmers", time); }
16551
16554 bool set_shaders_match(const ValueList& list, double time = TiMe::Default()) { return setValue("shaders_match", list, time); }
16555 bool set_shaders_match(ValueList&& list, double time = TiMe::Default()) { return setValue("shaders_match", std::move(list), time); }
16556 bool set_shaders_match(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("shaders_match", values, count, time); }
16557 template<size_t count> bool set_shaders_match(const Value (&values)[count], double time = TiMe::Default()) { return setArray("shaders_match", values, count, time); }
16558 template<size_t count> bool set_shaders_match(Value (&&values)[count], double time = TiMe::Default()) { return setArray("shaders_match", values, count, time); }
16561 ValueList get_shaders_match(double time = TiMe::Default()) const { return getValueList("shaders_match", time); }
16562
16566 bool set_shaders_match_indexes(const IntList& intList, double time = TiMe::Default()) { return setValue("shaders_match_indexes", intList, time); }
16567 bool set_shaders_match_indexes(IntList&& intList, double time = TiMe::Default()) { return setValue("shaders_match_indexes", std::move(intList), time); }
16568 bool set_shaders_match_indexes(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("shaders_match_indexes", ints, count, time); }
16569 template<size_t count> bool set_shaders_match_indexes(const int (&ints)[count], double time = TiMe::Default()) { return setArray("shaders_match_indexes", ints, count, time); }
16573 IntList get_shaders_match_indexes(double time = TiMe::Default()) const { return getIntList("shaders_match_indexes", time); }
16574
16578 bool set_shaders_match_file(const char* str, double time = TiMe::Default()) { return setValue("shaders_match_file", str, time); }
16582 bool set_shaders_match_file(const std::string& str, double time = TiMe::Default()) { return setValue("shaders_match_file", str, time); }
16586 std::string get_shaders_match_file(double time = TiMe::Default()) const { return getString("shaders_match_file", time); }
16587
16590 bool set_map_channels(const ValueList& list, double time = TiMe::Default()) { return setValue("map_channels", list, time); }
16591 bool set_map_channels(ValueList&& list, double time = TiMe::Default()) { return setValue("map_channels", std::move(list), time); }
16592 bool set_map_channels(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
16593 template<size_t count> bool set_map_channels(const Value (&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
16594 template<size_t count> bool set_map_channels(Value (&&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
16597 ValueList get_map_channels(double time = TiMe::Default()) const { return getValueList("map_channels", time); }
16598
16601 bool set_extra_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("extra_channels", pluginList, time); }
16602 bool set_extra_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("extra_channels", plugins, count, time); }
16603 template<size_t count> bool set_extra_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("extra_channels", plugins, count, time); }
16606 PluginList get_extra_channels(double time = TiMe::Default()) const { return getPluginList("extra_channels", time); }
16607
16610 bool set_object_properties(const ValueList& list, double time = TiMe::Default()) { return setValue("object_properties", list, time); }
16611 bool set_object_properties(ValueList&& list, double time = TiMe::Default()) { return setValue("object_properties", std::move(list), time); }
16612 bool set_object_properties(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("object_properties", values, count, time); }
16613 template<size_t count> bool set_object_properties(const Value (&values)[count], double time = TiMe::Default()) { return setArray("object_properties", values, count, time); }
16614 template<size_t count> bool set_object_properties(Value (&&values)[count], double time = TiMe::Default()) { return setArray("object_properties", values, count, time); }
16617 ValueList get_object_properties(double time = TiMe::Default()) const { return getValueList("object_properties", time); }
16618
16621 bool set_user_attributes(const ValueList& list, double time = TiMe::Default()) { return setValue("user_attributes", list, time); }
16622 bool set_user_attributes(ValueList&& list, double time = TiMe::Default()) { return setValue("user_attributes", std::move(list), time); }
16623 bool set_user_attributes(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("user_attributes", values, count, time); }
16624 template<size_t count> bool set_user_attributes(const Value (&values)[count], double time = TiMe::Default()) { return setArray("user_attributes", values, count, time); }
16625 template<size_t count> bool set_user_attributes(Value (&&values)[count], double time = TiMe::Default()) { return setArray("user_attributes", values, count, time); }
16628 ValueList get_user_attributes(double time = TiMe::Default()) const { return getValueList("user_attributes", time); }
16629
16633 bool set_light_color_override(const char* str, double time = TiMe::Default()) { return setValue("light_color_override", str, time); }
16637 bool set_light_color_override(const std::string& str, double time = TiMe::Default()) { return setValue("light_color_override", str, time); }
16641 std::string get_light_color_override(double time = TiMe::Default()) const { return getString("light_color_override", time); }
16642
16646 bool set_light_intensity_override(const char* str, double time = TiMe::Default()) { return setValue("light_intensity_override", str, time); }
16650 bool set_light_intensity_override(const std::string& str, double time = TiMe::Default()) { return setValue("light_intensity_override", str, time); }
16654 std::string get_light_intensity_override(double time = TiMe::Default()) const { return getString("light_intensity_override", time); }
16655
16659 bool set_instance_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("instance_ids", intList, time); }
16660 bool set_instance_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("instance_ids", std::move(intList), time); }
16661 bool set_instance_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("instance_ids", ints, count, time); }
16662 template<size_t count> bool set_instance_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("instance_ids", ints, count, time); }
16666 IntList get_instance_ids(double time = TiMe::Default()) const { return getIntList("instance_ids", time); }
16667};
16668
16671public:
16673 static constexpr const PluginTypeId getTypeId() { return 0x780C95A0; }
16675 static constexpr const char* getType() { return "GeomLocalRayserver"; }
16676
16677 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
16678
16681 bool set_source_geometry(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("source_geometry", pluginList, time); }
16682 bool set_source_geometry(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("source_geometry", plugins, count, time); }
16683 template<size_t count> bool set_source_geometry(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("source_geometry", plugins, count, time); }
16686 PluginList get_source_geometry(double time = TiMe::Default()) const { return getPluginList("source_geometry", time); }
16687};
16688
16690class GeomMayaHair : public Plugin {
16691public:
16693 static constexpr const PluginTypeId getTypeId() { return 0x77CE7C89; }
16695 static constexpr const char* getType() { return "GeomMayaHair"; }
16696
16697 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
16698
16702 bool set_num_hair_vertices(const IntList& intList, double time = TiMe::Default()) { return setValue("num_hair_vertices", intList, time); }
16703 bool set_num_hair_vertices(IntList&& intList, double time = TiMe::Default()) { return setValue("num_hair_vertices", std::move(intList), time); }
16704 bool set_num_hair_vertices(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("num_hair_vertices", ints, count, time); }
16705 template<size_t count> bool set_num_hair_vertices(const int (&ints)[count], double time = TiMe::Default()) { return setArray("num_hair_vertices", ints, count, time); }
16709 IntList get_num_hair_vertices(double time = TiMe::Default()) const { return getIntList("num_hair_vertices", time); }
16710
16714 bool set_hair_vertices(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("hair_vertices", vectorList, time); }
16715 bool set_hair_vertices(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("hair_vertices", std::move(vectorList), time); }
16716 bool set_hair_vertices(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("hair_vertices", vectors, count, time); }
16717 template<size_t count> bool set_hair_vertices(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("hair_vertices", vectors, count, time); }
16721 VectorList get_hair_vertices(double time = TiMe::Default()) const { return getVectorList("hair_vertices", time); }
16722
16726 bool set_velocities(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("velocities", vectorList, time); }
16727 bool set_velocities(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("velocities", std::move(vectorList), time); }
16728 bool set_velocities(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
16729 template<size_t count> bool set_velocities(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
16733 VectorList get_velocities(double time = TiMe::Default()) const { return getVectorList("velocities", time); }
16734
16738 bool set_widths(const FloatList& floatList, double time = TiMe::Default()) { return setValue("widths", floatList, time); }
16739 bool set_widths(FloatList&& floatList, double time = TiMe::Default()) { return setValue("widths", std::move(floatList), time); }
16740 bool set_widths(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("widths", floats, count, time); }
16741 template<size_t count> bool set_widths(const float (&floats)[count], double time = TiMe::Default()) { return setArray("widths", floats, count, time); }
16745 FloatList get_widths(double time = TiMe::Default()) const { return getFloatList("widths", time); }
16746
16750 bool set_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("colors", colorList, time); }
16751 bool set_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("colors", std::move(colorList), time); }
16752 bool set_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
16753 template<size_t count> bool set_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
16757 ColorList get_colors(double time = TiMe::Default()) const { return getColorList("colors", time); }
16758
16762 bool set_incandescence(const ColorList& colorList, double time = TiMe::Default()) { return setValue("incandescence", colorList, time); }
16763 bool set_incandescence(ColorList&& colorList, double time = TiMe::Default()) { return setValue("incandescence", std::move(colorList), time); }
16764 bool set_incandescence(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("incandescence", colors, count, time); }
16765 template<size_t count> bool set_incandescence(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("incandescence", colors, count, time); }
16769 ColorList get_incandescence(double time = TiMe::Default()) const { return getColorList("incandescence", time); }
16770
16774 bool set_transparency(const ColorList& colorList, double time = TiMe::Default()) { return setValue("transparency", colorList, time); }
16775 bool set_transparency(ColorList&& colorList, double time = TiMe::Default()) { return setValue("transparency", std::move(colorList), time); }
16776 bool set_transparency(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("transparency", colors, count, time); }
16777 template<size_t count> bool set_transparency(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("transparency", colors, count, time); }
16781 ColorList get_transparency(double time = TiMe::Default()) const { return getColorList("transparency", time); }
16782
16786 bool set_opacity(float val, double time = TiMe::Default()) { return setValue("opacity", val, time); }
16790 float get_opacity(double time = TiMe::Default()) const { return getFloat("opacity", time); }
16791
16795 bool set_strand_uvw(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("strand_uvw", vectorList, time); }
16796 bool set_strand_uvw(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("strand_uvw", std::move(vectorList), time); }
16797 bool set_strand_uvw(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("strand_uvw", vectors, count, time); }
16798 template<size_t count> bool set_strand_uvw(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("strand_uvw", vectors, count, time); }
16802 VectorList get_strand_uvw(double time = TiMe::Default()) const { return getVectorList("strand_uvw", time); }
16803
16807 bool set_geom_splines(bool val, double time = TiMe::Default()) { return setValue("geom_splines", val, time); }
16811 bool get_geom_splines(double time = TiMe::Default()) const { return getBool("geom_splines", time); }
16812
16816 bool set_use_global_hair_tree(bool val, double time = TiMe::Default()) { return setValue("use_global_hair_tree", val, time); }
16820 bool get_use_global_hair_tree(double time = TiMe::Default()) const { return getBool("use_global_hair_tree", time); }
16821
16825 bool set_geom_tesselation_mult(float val, double time = TiMe::Default()) { return setValue("geom_tesselation_mult", val, time); }
16829 float get_geom_tesselation_mult(double time = TiMe::Default()) const { return getFloat("geom_tesselation_mult", time); }
16830
16834 bool set_max_tesselation_factor(int val, double time = TiMe::Default()) { return setValue("max_tesselation_factor", val, time); }
16838 int get_max_tesselation_factor(double time = TiMe::Default()) const { return getInt("max_tesselation_factor", time); }
16839
16843 bool set_xgen_generated(int val, double time = TiMe::Default()) { return setValue("xgen_generated", val, time); }
16847 int get_xgen_generated(double time = TiMe::Default()) const { return getInt("xgen_generated", time); }
16848
16852 bool set_widths_in_pixels(bool val, double time = TiMe::Default()) { return setValue("widths_in_pixels", val, time); }
16856 bool get_widths_in_pixels(double time = TiMe::Default()) const { return getBool("widths_in_pixels", time); }
16857
16860 bool set_map_channels(const ValueList& list, double time = TiMe::Default()) { return setValue("map_channels", list, time); }
16861 bool set_map_channels(ValueList&& list, double time = TiMe::Default()) { return setValue("map_channels", std::move(list), time); }
16862 bool set_map_channels(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
16863 template<size_t count> bool set_map_channels(const Value (&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
16864 template<size_t count> bool set_map_channels(Value (&&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
16867 ValueList get_map_channels(double time = TiMe::Default()) const { return getValueList("map_channels", time); }
16868
16872 bool set_generate_w_coord(bool val, double time = TiMe::Default()) { return setValue("generate_w_coord", val, time); }
16876 bool get_generate_w_coord(double time = TiMe::Default()) const { return getBool("generate_w_coord", time); }
16877
16881 bool set_w_coord_affect_channels_use(bool val, double time = TiMe::Default()) { return setValue("w_coord_affect_channels_use", val, time); }
16885 bool get_w_coord_affect_channels_use(double time = TiMe::Default()) const { return getBool("w_coord_affect_channels_use", time); }
16886
16890 bool set_w_coord_affect_channels(const char* str, double time = TiMe::Default()) { return setValue("w_coord_affect_channels", str, time); }
16894 bool set_w_coord_affect_channels(const std::string& str, double time = TiMe::Default()) { return setValue("w_coord_affect_channels", str, time); }
16898 std::string get_w_coord_affect_channels(double time = TiMe::Default()) const { return getString("w_coord_affect_channels", time); }
16899
16903 bool set_min_pixel_width(float val, double time = TiMe::Default()) { return setValue("min_pixel_width", val, time); }
16907 float get_min_pixel_width(double time = TiMe::Default()) const { return getFloat("min_pixel_width", time); }
16908
16912 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
16916 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
16917};
16918
16920class GeomMeshFile : public Plugin {
16921public:
16923 static constexpr const PluginTypeId getTypeId() { return 0x777476DE; }
16925 static constexpr const char* getType() { return "GeomMeshFile"; }
16926
16927 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
16928
16932 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
16936 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
16940 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
16941
16944 bool set_alembic_layers(const StringList& stringList, double time = TiMe::Default()) { return setValue("alembic_layers", stringList, time); }
16947 StringList get_alembic_layers(double time = TiMe::Default()) const { return getStringList("alembic_layers", time); }
16948
16952 bool set_anim_speed(float val, double time = TiMe::Default()) { return setValue("anim_speed", val, time); }
16956 float get_anim_speed(double time = TiMe::Default()) const { return getFloat("anim_speed", time); }
16957
16961 bool set_anim_type(int val, double time = TiMe::Default()) { return setValue("anim_type", val, time); }
16965 int get_anim_type(double time = TiMe::Default()) const { return getInt("anim_type", time); }
16966
16970 bool set_anim_offset(float val, double time = TiMe::Default()) { return setValue("anim_offset", val, time); }
16974 float get_anim_offset(double time = TiMe::Default()) const { return getFloat("anim_offset", time); }
16975
16979 bool set_anim_override(int val, double time = TiMe::Default()) { return setValue("anim_override", val, time); }
16983 int get_anim_override(double time = TiMe::Default()) const { return getInt("anim_override", time); }
16984
16988 bool set_anim_frame(float val, double time = TiMe::Default()) { return setValue("anim_frame", val, time); }
16992 float get_anim_frame(double time = TiMe::Default()) const { return getFloat("anim_frame", time); }
16993
16997 bool set_anim_abc_time(float val, double time = TiMe::Default()) { return setValue("anim_abc_time", val, time); }
17001 float get_anim_abc_time(double time = TiMe::Default()) const { return getFloat("anim_abc_time", time); }
17002
17006 bool set_anim_start(int val, double time = TiMe::Default()) { return setValue("anim_start", val, time); }
17010 int get_anim_start(double time = TiMe::Default()) const { return getInt("anim_start", time); }
17011
17015 bool set_anim_length(int val, double time = TiMe::Default()) { return setValue("anim_length", val, time); }
17019 int get_anim_length(double time = TiMe::Default()) const { return getInt("anim_length", time); }
17020
17024 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
17028 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
17029
17033 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
17037 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
17038
17042 bool set_flip_axis(int val, double time = TiMe::Default()) { return setValue("flip_axis", val, time); }
17046 int get_flip_axis(double time = TiMe::Default()) const { return getInt("flip_axis", time); }
17047
17051 bool set_smooth_uv_borders(bool val, double time = TiMe::Default()) { return setValue("smooth_uv_borders", val, time); }
17055 bool get_smooth_uv_borders(double time = TiMe::Default()) const { return getBool("smooth_uv_borders", time); }
17056
17060 bool set_smooth_uv(bool val, double time = TiMe::Default()) { return setValue("smooth_uv", val, time); }
17064 bool get_smooth_uv(double time = TiMe::Default()) const { return getBool("smooth_uv", time); }
17065
17069 bool set_compute_normals(int val, double time = TiMe::Default()) { return setValue("compute_normals", val, time); }
17073 int get_compute_normals(double time = TiMe::Default()) const { return getInt("compute_normals", time); }
17074
17078 bool set_smooth_angle(float val, double time = TiMe::Default()) { return setValue("smooth_angle", val, time); }
17082 float get_smooth_angle(double time = TiMe::Default()) const { return getFloat("smooth_angle", time); }
17083
17087 bool set_flip_normals(bool val, double time = TiMe::Default()) { return setValue("flip_normals", val, time); }
17091 bool get_flip_normals(double time = TiMe::Default()) const { return getBool("flip_normals", time); }
17092
17096 bool set_compute_bbox(bool val, double time = TiMe::Default()) { return setValue("compute_bbox", val, time); }
17100 bool get_compute_bbox(double time = TiMe::Default()) const { return getBool("compute_bbox", time); }
17101
17105 bool set_num_preview_faces(int val, double time = TiMe::Default()) { return setValue("num_preview_faces", val, time); }
17109 int get_num_preview_faces(double time = TiMe::Default()) const { return getInt("num_preview_faces", time); }
17110
17114 bool set_use_face_sets(int val, double time = TiMe::Default()) { return setValue("use_face_sets", val, time); }
17118 int get_use_face_sets(double time = TiMe::Default()) const { return getInt("use_face_sets", time); }
17119
17123 bool set_use_full_names(bool val, double time = TiMe::Default()) { return setValue("use_full_names", val, time); }
17127 bool get_use_full_names(double time = TiMe::Default()) const { return getBool("use_full_names", time); }
17128
17132 bool set_object_path(const char* str, double time = TiMe::Default()) { return setValue("object_path", str, time); }
17136 bool set_object_path(const std::string& str, double time = TiMe::Default()) { return setValue("object_path", str, time); }
17140 std::string get_object_path(double time = TiMe::Default()) const { return getString("object_path", time); }
17141
17145 bool set_hair_width_multiplier(float val, double time = TiMe::Default()) { return setValue("hair_width_multiplier", val, time); }
17149 float get_hair_width_multiplier(double time = TiMe::Default()) const { return getFloat("hair_width_multiplier", time); }
17150
17154 bool set_particle_width_multiplier(float val, double time = TiMe::Default()) { return setValue("particle_width_multiplier", val, time); }
17158 float get_particle_width_multiplier(double time = TiMe::Default()) const { return getFloat("particle_width_multiplier", time); }
17159
17163 bool set_velocity_multiplier(float val, double time = TiMe::Default()) { return setValue("velocity_multiplier", val, time); }
17167 float get_velocity_multiplier(double time = TiMe::Default()) const { return getFloat("velocity_multiplier", time); }
17168
17172 bool set_visibility_lists_type(int val, double time = TiMe::Default()) { return setValue("visibility_lists_type", val, time); }
17176 int get_visibility_lists_type(double time = TiMe::Default()) const { return getInt("visibility_lists_type", time); }
17177
17180 bool set_visibility_list_names(const StringList& stringList, double time = TiMe::Default()) { return setValue("visibility_list_names", stringList, time); }
17183 StringList get_visibility_list_names(double time = TiMe::Default()) const { return getStringList("visibility_list_names", time); }
17184
17187 bool set_visibility_list_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("visibility_list_ids", intList, time); }
17188 bool set_visibility_list_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("visibility_list_ids", std::move(intList), time); }
17189 bool set_visibility_list_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("visibility_list_ids", ints, count, time); }
17190 template<size_t count> bool set_visibility_list_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("visibility_list_ids", ints, count, time); }
17193 IntList get_visibility_list_ids(double time = TiMe::Default()) const { return getIntList("visibility_list_ids", time); }
17194
17198 bool set_hair_visibility_lists_type(int val, double time = TiMe::Default()) { return setValue("hair_visibility_lists_type", val, time); }
17202 int get_hair_visibility_lists_type(double time = TiMe::Default()) const { return getInt("hair_visibility_lists_type", time); }
17203
17206 bool set_hair_visibility_list_names(const StringList& stringList, double time = TiMe::Default()) { return setValue("hair_visibility_list_names", stringList, time); }
17209 StringList get_hair_visibility_list_names(double time = TiMe::Default()) const { return getStringList("hair_visibility_list_names", time); }
17210
17213 bool set_hair_visibility_list_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("hair_visibility_list_ids", intList, time); }
17214 bool set_hair_visibility_list_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("hair_visibility_list_ids", std::move(intList), time); }
17215 bool set_hair_visibility_list_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("hair_visibility_list_ids", ints, count, time); }
17216 template<size_t count> bool set_hair_visibility_list_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("hair_visibility_list_ids", ints, count, time); }
17219 IntList get_hair_visibility_list_ids(double time = TiMe::Default()) const { return getIntList("hair_visibility_list_ids", time); }
17220
17224 bool set_particle_visibility_lists_type(int val, double time = TiMe::Default()) { return setValue("particle_visibility_lists_type", val, time); }
17228 int get_particle_visibility_lists_type(double time = TiMe::Default()) const { return getInt("particle_visibility_lists_type", time); }
17229
17232 bool set_particle_visibility_list_names(const StringList& stringList, double time = TiMe::Default()) { return setValue("particle_visibility_list_names", stringList, time); }
17235 StringList get_particle_visibility_list_names(double time = TiMe::Default()) const { return getStringList("particle_visibility_list_names", time); }
17236
17239 bool set_particle_visibility_list_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("particle_visibility_list_ids", intList, time); }
17240 bool set_particle_visibility_list_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("particle_visibility_list_ids", std::move(intList), time); }
17241 bool set_particle_visibility_list_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("particle_visibility_list_ids", ints, count, time); }
17242 template<size_t count> bool set_particle_visibility_list_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("particle_visibility_list_ids", ints, count, time); }
17245 IntList get_particle_visibility_list_ids(double time = TiMe::Default()) const { return getIntList("particle_visibility_list_ids", time); }
17246
17249 bool set_visibility_overrides_rules(const StringList& stringList, double time = TiMe::Default()) { return setValue("visibility_overrides_rules", stringList, time); }
17252 StringList get_visibility_overrides_rules(double time = TiMe::Default()) const { return getStringList("visibility_overrides_rules", time); }
17253
17256 bool set_visibility_overrides_values(const IntList& intList, double time = TiMe::Default()) { return setValue("visibility_overrides_values", intList, time); }
17257 bool set_visibility_overrides_values(IntList&& intList, double time = TiMe::Default()) { return setValue("visibility_overrides_values", std::move(intList), time); }
17258 bool set_visibility_overrides_values(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("visibility_overrides_values", ints, count, time); }
17259 template<size_t count> bool set_visibility_overrides_values(const int (&ints)[count], double time = TiMe::Default()) { return setArray("visibility_overrides_values", ints, count, time); }
17262 IntList get_visibility_overrides_values(double time = TiMe::Default()) const { return getIntList("visibility_overrides_values", time); }
17263
17267 bool set_sort_voxels(int val, double time = TiMe::Default()) { return setValue("sort_voxels", val, time); }
17271 int get_sort_voxels(double time = TiMe::Default()) const { return getInt("sort_voxels", time); }
17272
17276 bool set_first_map_channel(int val, double time = TiMe::Default()) { return setValue("first_map_channel", val, time); }
17280 int get_first_map_channel(double time = TiMe::Default()) const { return getInt("first_map_channel", time); }
17281
17285 bool set_particle_render_mode(int val, double time = TiMe::Default()) { return setValue("particle_render_mode", val, time); }
17289 int get_particle_render_mode(double time = TiMe::Default()) const { return getInt("particle_render_mode", time); }
17290
17294 bool set_particle_use_normals(bool val, double time = TiMe::Default()) { return setValue("particle_use_normals", val, time); }
17298 bool get_particle_use_normals(double time = TiMe::Default()) const { return getBool("particle_use_normals", time); }
17299
17303 bool set_use_alembic_offset(bool val, double time = TiMe::Default()) { return setValue("use_alembic_offset", val, time); }
17307 bool get_use_alembic_offset(double time = TiMe::Default()) const { return getBool("use_alembic_offset", time); }
17308
17312 bool set_use_alembic_transform(bool val, double time = TiMe::Default()) { return setValue("use_alembic_transform", val, time); }
17316 bool get_use_alembic_transform(double time = TiMe::Default()) const { return getBool("use_alembic_transform", time); }
17317
17321 bool set_use_alembic_visibility(bool val, double time = TiMe::Default()) { return setValue("use_alembic_visibility", val, time); }
17325 bool get_use_alembic_visibility(double time = TiMe::Default()) const { return getBool("use_alembic_visibility", time); }
17326
17330 bool set_velocity_color_set(const char* str, double time = TiMe::Default()) { return setValue("velocity_color_set", str, time); }
17334 bool set_velocity_color_set(const std::string& str, double time = TiMe::Default()) { return setValue("velocity_color_set", str, time); }
17338 std::string get_velocity_color_set(double time = TiMe::Default()) const { return getString("velocity_color_set", time); }
17339
17343 bool set_instancing(int val, double time = TiMe::Default()) { return setValue("instancing", val, time); }
17347 int get_instancing(double time = TiMe::Default()) const { return getInt("instancing", time); }
17348
17352 bool set_tessellate_hair(bool val, double time = TiMe::Default()) { return setValue("tessellate_hair", val, time); }
17356 bool get_tessellate_hair(double time = TiMe::Default()) const { return getBool("tessellate_hair", time); }
17357
17361 bool set_hair_tessellation_length(float val, double time = TiMe::Default()) { return setValue("hair_tessellation_length", val, time); }
17365 float get_hair_tessellation_length(double time = TiMe::Default()) const { return getFloat("hair_tessellation_length", time); }
17366
17370 bool set_subdiv_all_meshes(bool val, double time = TiMe::Default()) { return setValue("subdiv_all_meshes", val, time); }
17374 bool get_subdiv_all_meshes(double time = TiMe::Default()) const { return getBool("subdiv_all_meshes", time); }
17375
17379 bool set_subdiv_type(int val, double time = TiMe::Default()) { return setValue("subdiv_type", val, time); }
17383 int get_subdiv_type(double time = TiMe::Default()) const { return getInt("subdiv_type", time); }
17384
17388 bool set_subdiv_level(int val, double time = TiMe::Default()) { return setValue("subdiv_level", val, time); }
17392 int get_subdiv_level(double time = TiMe::Default()) const { return getInt("subdiv_level", time); }
17393
17397 bool set_subdiv_uvs(bool val, double time = TiMe::Default()) { return setValue("subdiv_uvs", val, time); }
17401 bool get_subdiv_uvs(double time = TiMe::Default()) const { return getBool("subdiv_uvs", time); }
17402
17406 bool set_subdiv_preserve_geom_borders(bool val, double time = TiMe::Default()) { return setValue("subdiv_preserve_geom_borders", val, time); }
17410 bool get_subdiv_preserve_geom_borders(double time = TiMe::Default()) const { return getBool("subdiv_preserve_geom_borders", time); }
17411
17415 bool set_subdiv_preserve_map_borders(int val, double time = TiMe::Default()) { return setValue("subdiv_preserve_map_borders", val, time); }
17419 int get_subdiv_preserve_map_borders(double time = TiMe::Default()) const { return getInt("subdiv_preserve_map_borders", time); }
17420
17424 bool set_use_point_cloud(bool val, double time = TiMe::Default()) { return setValue("use_point_cloud", val, time); }
17428 bool get_use_point_cloud(double time = TiMe::Default()) const { return getBool("use_point_cloud", time); }
17429
17433 bool set_point_cloud_mult(float val, double time = TiMe::Default()) { return setValue("point_cloud_mult", val, time); }
17437 float get_point_cloud_mult(double time = TiMe::Default()) const { return getFloat("point_cloud_mult", time); }
17438
17442 bool set_pixel_scale(float val, double time = TiMe::Default()) { return setValue("pixel_scale", val, time); }
17446 float get_pixel_scale(double time = TiMe::Default()) const { return getFloat("pixel_scale", time); }
17447
17451 bool set_material_assignments_file(const char* str, double time = TiMe::Default()) { return setValue("material_assignments_file", str, time); }
17455 bool set_material_assignments_file(const std::string& str, double time = TiMe::Default()) { return setValue("material_assignments_file", str, time); }
17459 std::string get_material_assignments_file(double time = TiMe::Default()) const { return getString("material_assignments_file", time); }
17460
17464 bool set_alembic_mode(int val, double time = TiMe::Default()) { return setValue("alembic_mode", val, time); }
17468 int get_alembic_mode(double time = TiMe::Default()) const { return getInt("alembic_mode", time); }
17469
17473 bool set_load_mesh(int val, double time = TiMe::Default()) { return setValue("load_mesh", val, time); }
17477 int get_load_mesh(double time = TiMe::Default()) const { return getInt("load_mesh", time); }
17478
17482 bool set_load_hair(int val, double time = TiMe::Default()) { return setValue("load_hair", val, time); }
17486 int get_load_hair(double time = TiMe::Default()) const { return getInt("load_hair", time); }
17487
17491 bool set_load_particles(int val, double time = TiMe::Default()) { return setValue("load_particles", val, time); }
17495 int get_load_particles(double time = TiMe::Default()) const { return getInt("load_particles", time); }
17496
17500 bool set_use_velocity(int val, double time = TiMe::Default()) { return setValue("use_velocity", val, time); }
17504 int get_use_velocity(double time = TiMe::Default()) const { return getInt("use_velocity", time); }
17505
17507 bool set_reference_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("reference_mesh", plugin, time); }
17509 PluginRef get_reference_mesh(double time = TiMe::Default()) const { return getPlugin("reference_mesh", time); }
17510
17513 bool set_reference_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("reference_transform", transform, time); }
17516 Transform get_reference_transform(double time = TiMe::Default()) const { return getTransform("reference_transform", time); }
17517
17521 bool set_reference_vertex_channel(const char* str, double time = TiMe::Default()) { return setValue("reference_vertex_channel", str, time); }
17525 bool set_reference_vertex_channel(const std::string& str, double time = TiMe::Default()) { return setValue("reference_vertex_channel", str, time); }
17529 std::string get_reference_vertex_channel(double time = TiMe::Default()) const { return getString("reference_vertex_channel", time); }
17530
17534 bool set_reference_normal_channel(const char* str, double time = TiMe::Default()) { return setValue("reference_normal_channel", str, time); }
17538 bool set_reference_normal_channel(const std::string& str, double time = TiMe::Default()) { return setValue("reference_normal_channel", str, time); }
17542 std::string get_reference_normal_channel(double time = TiMe::Default()) const { return getString("reference_normal_channel", time); }
17543
17547 bool set_merge_equal_vertices(bool val, double time = TiMe::Default()) { return setValue("merge_equal_vertices", val, time); }
17551 bool get_merge_equal_vertices(double time = TiMe::Default()) const { return getBool("merge_equal_vertices", time); }
17552
17556 bool set_reorder_channels_by_name_indices(bool val, double time = TiMe::Default()) { return setValue("reorder_channels_by_name_indices", val, time); }
17560 bool get_reorder_channels_by_name_indices(double time = TiMe::Default()) const { return getBool("reorder_channels_by_name_indices", time); }
17561
17565 bool set_custom_reorder_mesh_set_names(const StringList& stringList, double time = TiMe::Default()) { return setValue("custom_reorder_mesh_set_names", stringList, time); }
17569 StringList get_custom_reorder_mesh_set_names(double time = TiMe::Default()) const { return getStringList("custom_reorder_mesh_set_names", time); }
17570
17574 bool set_custom_reorder_mesh_set_types(const IntList& intList, double time = TiMe::Default()) { return setValue("custom_reorder_mesh_set_types", intList, time); }
17575 bool set_custom_reorder_mesh_set_types(IntList&& intList, double time = TiMe::Default()) { return setValue("custom_reorder_mesh_set_types", std::move(intList), time); }
17576 bool set_custom_reorder_mesh_set_types(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("custom_reorder_mesh_set_types", ints, count, time); }
17577 template<size_t count> bool set_custom_reorder_mesh_set_types(const int (&ints)[count], double time = TiMe::Default()) { return setArray("custom_reorder_mesh_set_types", ints, count, time); }
17581 IntList get_custom_reorder_mesh_set_types(double time = TiMe::Default()) const { return getIntList("custom_reorder_mesh_set_types", time); }
17582
17586 bool set_custom_reorder_mesh_set_indices(const IntList& intList, double time = TiMe::Default()) { return setValue("custom_reorder_mesh_set_indices", intList, time); }
17587 bool set_custom_reorder_mesh_set_indices(IntList&& intList, double time = TiMe::Default()) { return setValue("custom_reorder_mesh_set_indices", std::move(intList), time); }
17588 bool set_custom_reorder_mesh_set_indices(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("custom_reorder_mesh_set_indices", ints, count, time); }
17589 template<size_t count> bool set_custom_reorder_mesh_set_indices(const int (&ints)[count], double time = TiMe::Default()) { return setArray("custom_reorder_mesh_set_indices", ints, count, time); }
17593 IntList get_custom_reorder_mesh_set_indices(double time = TiMe::Default()) const { return getIntList("custom_reorder_mesh_set_indices", time); }
17594};
17595
17596class GeomMeshLoader : public Plugin {
17597public:
17599 static constexpr const PluginTypeId getTypeId() { return 0x77C04BB8; }
17601 static constexpr const char* getType() { return "GeomMeshLoader"; }
17602
17603 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
17604
17607 bool set_sphere_size(float val, double time = TiMe::Default()) { return setValue("sphere_size", val, time); }
17610 float get_sphere_size(double time = TiMe::Default()) const { return getFloat("sphere_size", time); }
17611
17614 bool set_sphere_segments(int val, double time = TiMe::Default()) { return setValue("sphere_segments", val, time); }
17617 int get_sphere_segments(double time = TiMe::Default()) const { return getInt("sphere_segments", time); }
17618
17621 bool set_num_spheres(int val, double time = TiMe::Default()) { return setValue("num_spheres", val, time); }
17624 int get_num_spheres(double time = TiMe::Default()) const { return getInt("num_spheres", time); }
17625
17628 bool set_bbox_size(float val, double time = TiMe::Default()) { return setValue("bbox_size", val, time); }
17631 float get_bbox_size(double time = TiMe::Default()) const { return getFloat("bbox_size", time); }
17632};
17633
17634class GeomMeshLoader1 : public Plugin {
17635public:
17637 static constexpr const PluginTypeId getTypeId() { return 0x77CF8AD8; }
17639 static constexpr const char* getType() { return "GeomMeshLoader1"; }
17640
17641 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
17642
17645 bool set_sphere_size(float val, double time = TiMe::Default()) { return setValue("sphere_size", val, time); }
17648 float get_sphere_size(double time = TiMe::Default()) const { return getFloat("sphere_size", time); }
17649
17652 bool set_sphere_segments(int val, double time = TiMe::Default()) { return setValue("sphere_segments", val, time); }
17655 int get_sphere_segments(double time = TiMe::Default()) const { return getInt("sphere_segments", time); }
17656
17659 bool set_num_spheres(int val, double time = TiMe::Default()) { return setValue("num_spheres", val, time); }
17662 int get_num_spheres(double time = TiMe::Default()) const { return getInt("num_spheres", time); }
17663
17666 bool set_bbox_size(float val, double time = TiMe::Default()) { return setValue("bbox_size", val, time); }
17669 float get_bbox_size(double time = TiMe::Default()) const { return getFloat("bbox_size", time); }
17670
17673 bool set_use_displacement(bool val, double time = TiMe::Default()) { return setValue("use_displacement", val, time); }
17676 bool get_use_displacement(double time = TiMe::Default()) const { return getBool("use_displacement", time); }
17677};
17678
17679class GeomMeshTest : public Plugin {
17680public:
17682 static constexpr const PluginTypeId getTypeId() { return 0x77BF36C4; }
17684 static constexpr const char* getType() { return "GeomMeshTest"; }
17685
17686 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
17687
17690 bool set_sphere_size(float val, double time = TiMe::Default()) { return setValue("sphere_size", val, time); }
17693 float get_sphere_size(double time = TiMe::Default()) const { return getFloat("sphere_size", time); }
17694
17697 bool set_sphere_segments(int val, double time = TiMe::Default()) { return setValue("sphere_segments", val, time); }
17700 int get_sphere_segments(double time = TiMe::Default()) const { return getInt("sphere_segments", time); }
17701
17704 bool set_num_spheres(int val, double time = TiMe::Default()) { return setValue("num_spheres", val, time); }
17707 int get_num_spheres(double time = TiMe::Default()) const { return getInt("num_spheres", time); }
17708
17711 bool set_bbox_size(float val, double time = TiMe::Default()) { return setValue("bbox_size", val, time); }
17714 float get_bbox_size(double time = TiMe::Default()) const { return getFloat("bbox_size", time); }
17715};
17716
17719public:
17721 static constexpr const PluginTypeId getTypeId() { return 0x77DE39D6; }
17723 static constexpr const char* getType() { return "GeomMetaballSystem"; }
17724
17725 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
17726
17730 bool set_useParticleSize(int val, double time = TiMe::Default()) { return setValue("useParticleSize", val, time); }
17734 int get_useParticleSize(double time = TiMe::Default()) const { return getInt("useParticleSize", time); }
17735
17738 bool set_particleRadius(float val, double time = TiMe::Default()) { return setValue("particleRadius", val, time); }
17741 float get_particleRadius(double time = TiMe::Default()) const { return getFloat("particleRadius", time); }
17742
17745 bool set_threshold(float val, double time = TiMe::Default()) { return setValue("threshold", val, time); }
17748 float get_threshold(double time = TiMe::Default()) const { return getFloat("threshold", time); }
17749
17752 bool set_stepLength(float val, double time = TiMe::Default()) { return setValue("stepLength", val, time); }
17755 float get_stepLength(double time = TiMe::Default()) const { return getFloat("stepLength", time); }
17756
17759 bool set_mbSamples(int val, double time = TiMe::Default()) { return setValue("mbSamples", val, time); }
17762 int get_mbSamples(double time = TiMe::Default()) const { return getInt("mbSamples", time); }
17763
17767 bool set_distanceFunction(int val, double time = TiMe::Default()) { return setValue("distanceFunction", val, time); }
17771 int get_distanceFunction(double time = TiMe::Default()) const { return getInt("distanceFunction", time); }
17772
17775 bool set_smoothingBumps(int val, double time = TiMe::Default()) { return setValue("smoothingBumps", val, time); }
17778 int get_smoothingBumps(double time = TiMe::Default()) const { return getInt("smoothingBumps", time); }
17779
17782 bool set_smoothRadius(float val, double time = TiMe::Default()) { return setValue("smoothRadius", val, time); }
17785 float get_smoothRadius(double time = TiMe::Default()) const { return getFloat("smoothRadius", time); }
17786
17789 bool set_smoothExpansion(float val, double time = TiMe::Default()) { return setValue("smoothExpansion", val, time); }
17792 float get_smoothExpansion(double time = TiMe::Default()) const { return getFloat("smoothExpansion", time); }
17793
17795 bool set_positiveParticles(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("positiveParticles", pluginList, time); }
17796 bool set_positiveParticles(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("positiveParticles", plugins, count, time); }
17797 template<size_t count> bool set_positiveParticles(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("positiveParticles", plugins, count, time); }
17799 PluginList get_positiveParticles(double time = TiMe::Default()) const { return getPluginList("positiveParticles", time); }
17800
17802 bool set_negativeParticles(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("negativeParticles", pluginList, time); }
17803 bool set_negativeParticles(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("negativeParticles", plugins, count, time); }
17804 template<size_t count> bool set_negativeParticles(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("negativeParticles", plugins, count, time); }
17806 PluginList get_negativeParticles(double time = TiMe::Default()) const { return getPluginList("negativeParticles", time); }
17807
17810 bool set_useTexture(int val, double time = TiMe::Default()) { return setValue("useTexture", val, time); }
17813 int get_useTexture(double time = TiMe::Default()) const { return getInt("useTexture", time); }
17814
17817 bool set_fieldTexture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("fieldTexture", texture, time); }
17820 bool set_fieldTexture(const AColor& texture, double time = TiMe::Default()) { return setValue("fieldTexture", texture, time); }
17823 Value get_fieldTexture(double time = TiMe::Default()) const { return getValue("fieldTexture", time); }
17824
17828 bool set_textureFunction(int val, double time = TiMe::Default()) { return setValue("textureFunction", val, time); }
17832 int get_textureFunction(double time = TiMe::Default()) const { return getInt("textureFunction", time); }
17833
17836 bool set_textureMultiplier(float val, double time = TiMe::Default()) { return setValue("textureMultiplier", val, time); }
17839 float get_textureMultiplier(double time = TiMe::Default()) const { return getFloat("textureMultiplier", time); }
17840
17843 bool set_clampField(int val, double time = TiMe::Default()) { return setValue("clampField", val, time); }
17846 int get_clampField(double time = TiMe::Default()) const { return getInt("clampField", time); }
17847
17850 bool set_clampThreshold(float val, double time = TiMe::Default()) { return setValue("clampThreshold", val, time); }
17853 float get_clampThreshold(double time = TiMe::Default()) const { return getFloat("clampThreshold", time); }
17854
17857 bool set_useCache(int val, double time = TiMe::Default()) { return setValue("useCache", val, time); }
17860 int get_useCache(double time = TiMe::Default()) const { return getInt("useCache", time); }
17861
17864 bool set_cacheRecursiveBuild(int val, double time = TiMe::Default()) { return setValue("cacheRecursiveBuild", val, time); }
17867 int get_cacheRecursiveBuild(double time = TiMe::Default()) const { return getInt("cacheRecursiveBuild", time); }
17868
17871 bool set_cacheSize(int val, double time = TiMe::Default()) { return setValue("cacheSize", val, time); }
17874 int get_cacheSize(double time = TiMe::Default()) const { return getInt("cacheSize", time); }
17875
17878 bool set_cacheBlockSize(int val, double time = TiMe::Default()) { return setValue("cacheBlockSize", val, time); }
17881 int get_cacheBlockSize(double time = TiMe::Default()) const { return getInt("cacheBlockSize", time); }
17882
17885 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
17888 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
17889};
17890
17893public:
17895 static constexpr const PluginTypeId getTypeId() { return 0x77A218DD; }
17897 static constexpr const char* getType() { return "GeomParticleSystem"; }
17898
17899 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
17900
17904 bool set_acceleration_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", colorList, time); }
17905 bool set_acceleration_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", std::move(colorList), time); }
17906 bool set_acceleration_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
17907 template<size_t count> bool set_acceleration_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
17911 ColorList get_acceleration_pp(double time = TiMe::Default()) const { return getColorList("acceleration_pp", time); }
17912
17916 bool set_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("colors", colorList, time); }
17917 bool set_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("colors", std::move(colorList), time); }
17918 bool set_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
17919 template<size_t count> bool set_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
17923 ColorList get_colors(double time = TiMe::Default()) const { return getColorList("colors", time); }
17924
17928 bool set_emission_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("emission_pp", colorList, time); }
17929 bool set_emission_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("emission_pp", std::move(colorList), time); }
17930 bool set_emission_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("emission_pp", colors, count, time); }
17931 template<size_t count> bool set_emission_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("emission_pp", colors, count, time); }
17935 ColorList get_emission_pp(double time = TiMe::Default()) const { return getColorList("emission_pp", time); }
17936
17940 bool set_user_color_pp_1(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_1", colorList, time); }
17941 bool set_user_color_pp_1(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_1", std::move(colorList), time); }
17942 bool set_user_color_pp_1(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_1", colors, count, time); }
17943 template<size_t count> bool set_user_color_pp_1(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_1", colors, count, time); }
17947 ColorList get_user_color_pp_1(double time = TiMe::Default()) const { return getColorList("user_color_pp_1", time); }
17948
17952 bool set_user_color_pp_2(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_2", colorList, time); }
17953 bool set_user_color_pp_2(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_2", std::move(colorList), time); }
17954 bool set_user_color_pp_2(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_2", colors, count, time); }
17955 template<size_t count> bool set_user_color_pp_2(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_2", colors, count, time); }
17959 ColorList get_user_color_pp_2(double time = TiMe::Default()) const { return getColorList("user_color_pp_2", time); }
17960
17964 bool set_user_color_pp_3(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_3", colorList, time); }
17965 bool set_user_color_pp_3(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_3", std::move(colorList), time); }
17966 bool set_user_color_pp_3(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_3", colors, count, time); }
17967 template<size_t count> bool set_user_color_pp_3(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_3", colors, count, time); }
17971 ColorList get_user_color_pp_3(double time = TiMe::Default()) const { return getColorList("user_color_pp_3", time); }
17972
17976 bool set_user_color_pp_4(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_4", colorList, time); }
17977 bool set_user_color_pp_4(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_4", std::move(colorList), time); }
17978 bool set_user_color_pp_4(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_4", colors, count, time); }
17979 template<size_t count> bool set_user_color_pp_4(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_4", colors, count, time); }
17983 ColorList get_user_color_pp_4(double time = TiMe::Default()) const { return getColorList("user_color_pp_4", time); }
17984
17988 bool set_user_color_pp_5(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_5", colorList, time); }
17989 bool set_user_color_pp_5(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_5", std::move(colorList), time); }
17990 bool set_user_color_pp_5(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_5", colors, count, time); }
17991 template<size_t count> bool set_user_color_pp_5(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_5", colors, count, time); }
17995 ColorList get_user_color_pp_5(double time = TiMe::Default()) const { return getColorList("user_color_pp_5", time); }
17996
18000 bool set_age_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("age_pp", floatList, time); }
18001 bool set_age_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("age_pp", std::move(floatList), time); }
18002 bool set_age_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
18003 template<size_t count> bool set_age_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
18007 FloatList get_age_pp(double time = TiMe::Default()) const { return getFloatList("age_pp", time); }
18008
18012 bool set_lifespan_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("lifespan_pp", floatList, time); }
18013 bool set_lifespan_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("lifespan_pp", std::move(floatList), time); }
18014 bool set_lifespan_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("lifespan_pp", floats, count, time); }
18015 template<size_t count> bool set_lifespan_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("lifespan_pp", floats, count, time); }
18019 FloatList get_lifespan_pp(double time = TiMe::Default()) const { return getFloatList("lifespan_pp", time); }
18020
18024 bool set_opacity_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("opacity_pp", floatList, time); }
18025 bool set_opacity_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("opacity_pp", std::move(floatList), time); }
18026 bool set_opacity_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("opacity_pp", floats, count, time); }
18027 template<size_t count> bool set_opacity_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("opacity_pp", floats, count, time); }
18031 FloatList get_opacity_pp(double time = TiMe::Default()) const { return getFloatList("opacity_pp", time); }
18032
18036 bool set_user_float_pp_1(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_1", floatList, time); }
18037 bool set_user_float_pp_1(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_1", std::move(floatList), time); }
18038 bool set_user_float_pp_1(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_1", floats, count, time); }
18039 template<size_t count> bool set_user_float_pp_1(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_1", floats, count, time); }
18043 FloatList get_user_float_pp_1(double time = TiMe::Default()) const { return getFloatList("user_float_pp_1", time); }
18044
18048 bool set_user_float_pp_2(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_2", floatList, time); }
18049 bool set_user_float_pp_2(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_2", std::move(floatList), time); }
18050 bool set_user_float_pp_2(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_2", floats, count, time); }
18051 template<size_t count> bool set_user_float_pp_2(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_2", floats, count, time); }
18055 FloatList get_user_float_pp_2(double time = TiMe::Default()) const { return getFloatList("user_float_pp_2", time); }
18056
18060 bool set_user_float_pp_3(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_3", floatList, time); }
18061 bool set_user_float_pp_3(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_3", std::move(floatList), time); }
18062 bool set_user_float_pp_3(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_3", floats, count, time); }
18063 template<size_t count> bool set_user_float_pp_3(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_3", floats, count, time); }
18067 FloatList get_user_float_pp_3(double time = TiMe::Default()) const { return getFloatList("user_float_pp_3", time); }
18068
18072 bool set_user_float_pp_4(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_4", floatList, time); }
18073 bool set_user_float_pp_4(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_4", std::move(floatList), time); }
18074 bool set_user_float_pp_4(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_4", floats, count, time); }
18075 template<size_t count> bool set_user_float_pp_4(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_4", floats, count, time); }
18079 FloatList get_user_float_pp_4(double time = TiMe::Default()) const { return getFloatList("user_float_pp_4", time); }
18080
18084 bool set_user_float_pp_5(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_5", floatList, time); }
18085 bool set_user_float_pp_5(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_5", std::move(floatList), time); }
18086 bool set_user_float_pp_5(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_5", floats, count, time); }
18087 template<size_t count> bool set_user_float_pp_5(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_5", floats, count, time); }
18091 FloatList get_user_float_pp_5(double time = TiMe::Default()) const { return getFloatList("user_float_pp_5", time); }
18092
18095 bool set_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("mesh", plugin, time); }
18098 PluginRef get_mesh(double time = TiMe::Default()) const { return getPlugin("mesh", time); }
18099
18103 bool set_render_type(int val, double time = TiMe::Default()) { return setValue("render_type", val, time); }
18107 int get_render_type(double time = TiMe::Default()) const { return getInt("render_type", time); }
18108
18112 bool set_positions(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("positions", vectorList, time); }
18113 bool set_positions(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("positions", std::move(vectorList), time); }
18114 bool set_positions(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("positions", vectors, count, time); }
18115 template<size_t count> bool set_positions(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("positions", vectors, count, time); }
18119 VectorList get_positions(double time = TiMe::Default()) const { return getVectorList("positions", time); }
18120
18124 bool set_velocities(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("velocities", vectorList, time); }
18125 bool set_velocities(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("velocities", std::move(vectorList), time); }
18126 bool set_velocities(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
18127 template<size_t count> bool set_velocities(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
18131 VectorList get_velocities(double time = TiMe::Default()) const { return getVectorList("velocities", time); }
18132
18136 bool set_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("ids", intList, time); }
18137 bool set_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("ids", std::move(intList), time); }
18138 bool set_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
18139 template<size_t count> bool set_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
18143 IntList get_ids(double time = TiMe::Default()) const { return getIntList("ids", time); }
18144
18148 bool set_radii(const FloatList& floatList, double time = TiMe::Default()) { return setValue("radii", floatList, time); }
18149 bool set_radii(FloatList&& floatList, double time = TiMe::Default()) { return setValue("radii", std::move(floatList), time); }
18150 bool set_radii(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("radii", floats, count, time); }
18151 template<size_t count> bool set_radii(const float (&floats)[count], double time = TiMe::Default()) { return setArray("radii", floats, count, time); }
18155 FloatList get_radii(double time = TiMe::Default()) const { return getFloatList("radii", time); }
18156
18160 bool set_sprite_num_pp(const IntList& intList, double time = TiMe::Default()) { return setValue("sprite_num_pp", intList, time); }
18161 bool set_sprite_num_pp(IntList&& intList, double time = TiMe::Default()) { return setValue("sprite_num_pp", std::move(intList), time); }
18162 bool set_sprite_num_pp(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("sprite_num_pp", ints, count, time); }
18163 template<size_t count> bool set_sprite_num_pp(const int (&ints)[count], double time = TiMe::Default()) { return setArray("sprite_num_pp", ints, count, time); }
18167 IntList get_sprite_num_pp(double time = TiMe::Default()) const { return getIntList("sprite_num_pp", time); }
18168
18172 bool set_normals(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("normals", vectorList, time); }
18173 bool set_normals(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("normals", std::move(vectorList), time); }
18174 bool set_normals(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("normals", vectors, count, time); }
18175 template<size_t count> bool set_normals(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("normals", vectors, count, time); }
18179 VectorList get_normals(double time = TiMe::Default()) const { return getVectorList("normals", time); }
18180
18184 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
18188 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
18189
18193 bool set_sprite_size_x(float val, double time = TiMe::Default()) { return setValue("sprite_size_x", val, time); }
18197 float get_sprite_size_x(double time = TiMe::Default()) const { return getFloat("sprite_size_x", time); }
18198
18202 bool set_sprite_size_y(float val, double time = TiMe::Default()) { return setValue("sprite_size_y", val, time); }
18206 float get_sprite_size_y(double time = TiMe::Default()) const { return getFloat("sprite_size_y", time); }
18207
18211 bool set_sprite_twist(float val, double time = TiMe::Default()) { return setValue("sprite_twist", val, time); }
18215 float get_sprite_twist(double time = TiMe::Default()) const { return getFloat("sprite_twist", time); }
18216
18220 bool set_sprite_scale_x(const FloatList& floatList, double time = TiMe::Default()) { return setValue("sprite_scale_x", floatList, time); }
18221 bool set_sprite_scale_x(FloatList&& floatList, double time = TiMe::Default()) { return setValue("sprite_scale_x", std::move(floatList), time); }
18222 bool set_sprite_scale_x(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("sprite_scale_x", floats, count, time); }
18223 template<size_t count> bool set_sprite_scale_x(const float (&floats)[count], double time = TiMe::Default()) { return setArray("sprite_scale_x", floats, count, time); }
18227 FloatList get_sprite_scale_x(double time = TiMe::Default()) const { return getFloatList("sprite_scale_x", time); }
18228
18232 bool set_sprite_scale_y(const FloatList& floatList, double time = TiMe::Default()) { return setValue("sprite_scale_y", floatList, time); }
18233 bool set_sprite_scale_y(FloatList&& floatList, double time = TiMe::Default()) { return setValue("sprite_scale_y", std::move(floatList), time); }
18234 bool set_sprite_scale_y(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("sprite_scale_y", floats, count, time); }
18235 template<size_t count> bool set_sprite_scale_y(const float (&floats)[count], double time = TiMe::Default()) { return setArray("sprite_scale_y", floats, count, time); }
18239 FloatList get_sprite_scale_y(double time = TiMe::Default()) const { return getFloatList("sprite_scale_y", time); }
18240
18244 bool set_sprite_rotate(const FloatList& floatList, double time = TiMe::Default()) { return setValue("sprite_rotate", floatList, time); }
18245 bool set_sprite_rotate(FloatList&& floatList, double time = TiMe::Default()) { return setValue("sprite_rotate", std::move(floatList), time); }
18246 bool set_sprite_rotate(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("sprite_rotate", floats, count, time); }
18247 template<size_t count> bool set_sprite_rotate(const float (&floats)[count], double time = TiMe::Default()) { return setArray("sprite_rotate", floats, count, time); }
18251 FloatList get_sprite_rotate(double time = TiMe::Default()) const { return getFloatList("sprite_rotate", time); }
18252
18256 bool set_sprite_orientation(int val, double time = TiMe::Default()) { return setValue("sprite_orientation", val, time); }
18260 int get_sprite_orientation(double time = TiMe::Default()) const { return getInt("sprite_orientation", time); }
18261
18265 bool set_point_size(float val, double time = TiMe::Default()) { return setValue("point_size", val, time); }
18269 float get_point_size(double time = TiMe::Default()) const { return getFloat("point_size", time); }
18270
18274 bool set_point_radii(bool val, double time = TiMe::Default()) { return setValue("point_radii", val, time); }
18278 bool get_point_radii(double time = TiMe::Default()) const { return getBool("point_radii", time); }
18279
18283 bool set_point_world_size(bool val, double time = TiMe::Default()) { return setValue("point_world_size", val, time); }
18287 bool get_point_world_size(double time = TiMe::Default()) const { return getBool("point_world_size", time); }
18288
18292 bool set_point_size_from_ortho_width(bool val, double time = TiMe::Default()) { return setValue("point_size_from_ortho_width", val, time); }
18296 bool get_point_size_from_ortho_width(double time = TiMe::Default()) const { return getBool("point_size_from_ortho_width", time); }
18297
18301 bool set_multi_count(int val, double time = TiMe::Default()) { return setValue("multi_count", val, time); }
18305 int get_multi_count(double time = TiMe::Default()) const { return getInt("multi_count", time); }
18306
18310 bool set_multi_radius(float val, double time = TiMe::Default()) { return setValue("multi_radius", val, time); }
18314 float get_multi_radius(double time = TiMe::Default()) const { return getFloat("multi_radius", time); }
18315
18319 bool set_line_width(float val, double time = TiMe::Default()) { return setValue("line_width", val, time); }
18323 float get_line_width(double time = TiMe::Default()) const { return getFloat("line_width", time); }
18324
18328 bool set_tail_length(float val, double time = TiMe::Default()) { return setValue("tail_length", val, time); }
18332 float get_tail_length(double time = TiMe::Default()) const { return getFloat("tail_length", time); }
18333
18337 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
18341 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
18342
18345 bool set_data_source(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("data_source", plugin, time); }
18348 PluginRef get_data_source(double time = TiMe::Default()) const { return getPlugin("data_source", time); }
18349};
18350
18352class GeomPartio : public Plugin {
18353public:
18355 static constexpr const PluginTypeId getTypeId() { return 0x7829E425; }
18357 static constexpr const char* getType() { return "GeomPartio"; }
18358
18359 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
18360
18364 bool set_directory(const char* str, double time = TiMe::Default()) { return setValue("directory", str, time); }
18368 bool set_directory(const std::string& str, double time = TiMe::Default()) { return setValue("directory", str, time); }
18372 std::string get_directory(double time = TiMe::Default()) const { return getString("directory", time); }
18373
18377 bool set_prefix(const char* str, double time = TiMe::Default()) { return setValue("prefix", str, time); }
18381 bool set_prefix(const std::string& str, double time = TiMe::Default()) { return setValue("prefix", str, time); }
18385 std::string get_prefix(double time = TiMe::Default()) const { return getString("prefix", time); }
18386
18390 bool set_format(const char* str, double time = TiMe::Default()) { return setValue("format", str, time); }
18394 bool set_format(const std::string& str, double time = TiMe::Default()) { return setValue("format", str, time); }
18398 std::string get_format(double time = TiMe::Default()) const { return getString("format", time); }
18399
18403 bool set_default_color(const Color& color, double time = TiMe::Default()) { return setValue("default_color", color, time); }
18407 Color get_default_color(double time = TiMe::Default()) const { return getColor("default_color", time); }
18408
18412 bool set_cache_offset(int val, double time = TiMe::Default()) { return setValue("cache_offset", val, time); }
18416 int get_cache_offset(double time = TiMe::Default()) const { return getInt("cache_offset", time); }
18417
18421 bool set_by_frame(int val, double time = TiMe::Default()) { return setValue("by_frame", val, time); }
18425 int get_by_frame(double time = TiMe::Default()) const { return getInt("by_frame", time); }
18426
18430 bool set_static(bool val, double time = TiMe::Default()) { return setValue("static", val, time); }
18434 bool get_static(double time = TiMe::Default()) const { return getBool("static", time); }
18435};
18436
18439public:
18441 static constexpr const PluginTypeId getTypeId() { return 0x7885C5A1; }
18443 static constexpr const char* getType() { return "GeomPerfectSphere"; }
18444
18445 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
18446
18450 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
18454 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
18455
18459 bool set_flip_normals(bool val, double time = TiMe::Default()) { return setValue("flip_normals", val, time); }
18463 bool get_flip_normals(double time = TiMe::Default()) const { return getBool("flip_normals", time); }
18464};
18465
18467class GeomPlane : public Plugin {
18468public:
18470 static constexpr const PluginTypeId getTypeId() { return 0x77BF64E3; }
18472 static constexpr const char* getType() { return "GeomPlane"; }
18473
18474 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
18475
18479 bool set_real_world_scale(int val, double time = TiMe::Default()) { return setValue("real_world_scale", val, time); }
18483 int get_real_world_scale(double time = TiMe::Default()) const { return getInt("real_world_scale", time); }
18484};
18485
18488public:
18490 static constexpr const PluginTypeId getTypeId() { return 0x785842EA; }
18492 static constexpr const char* getType() { return "GeomRayserverInstancer"; }
18493
18494 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
18495
18498 bool set_source_geometry(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("source_geometry", pluginList, time); }
18499 bool set_source_geometry(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("source_geometry", plugins, count, time); }
18500 template<size_t count> bool set_source_geometry(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("source_geometry", plugins, count, time); }
18503 PluginList get_source_geometry(double time = TiMe::Default()) const { return getPluginList("source_geometry", time); }
18504
18508 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
18512 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
18516 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
18517
18521 bool set_transforms_vector(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("transforms_vector", vectorList, time); }
18522 bool set_transforms_vector(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("transforms_vector", std::move(vectorList), time); }
18523 bool set_transforms_vector(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("transforms_vector", vectors, count, time); }
18524 template<size_t count> bool set_transforms_vector(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("transforms_vector", vectors, count, time); }
18528 VectorList get_transforms_vector(double time = TiMe::Default()) const { return getVectorList("transforms_vector", time); }
18529
18533 bool set_transforms(const TransformList& transformList, double time = TiMe::Default()) { return setValue("transforms", transformList, time); }
18534 bool set_transforms(const Transform* transforms, size_t count, double time = TiMe::Default()) { return setArray("transforms", transforms, count, time); }
18535 template<size_t count> bool set_transforms(const Transform (&transforms)[count], double time = TiMe::Default()) { return setArray("transforms", transforms, count, time); }
18539 TransformList get_transforms(double time = TiMe::Default()) const { return getTransformList("transforms", time); }
18540
18544 bool set_base_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("base_transform", transform, time); }
18548 Transform get_base_transform(double time = TiMe::Default()) const { return getTransform("base_transform", time); }
18549
18553 bool set_velocities(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("velocities", vectorList, time); }
18554 bool set_velocities(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("velocities", std::move(vectorList), time); }
18555 bool set_velocities(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
18556 template<size_t count> bool set_velocities(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
18560 VectorList get_velocities(double time = TiMe::Default()) const { return getVectorList("velocities", time); }
18561
18565 bool set_exclude_list(const StringList& stringList, double time = TiMe::Default()) { return setValue("exclude_list", stringList, time); }
18569 StringList get_exclude_list(double time = TiMe::Default()) const { return getStringList("exclude_list", time); }
18570
18574 bool set_exclude_list_inclusive(int val, double time = TiMe::Default()) { return setValue("exclude_list_inclusive", val, time); }
18578 int get_exclude_list_inclusive(double time = TiMe::Default()) const { return getInt("exclude_list_inclusive", time); }
18579
18583 bool set_flip_axis(int val, double time = TiMe::Default()) { return setValue("flip_axis", val, time); }
18587 int get_flip_axis(double time = TiMe::Default()) const { return getInt("flip_axis", time); }
18588
18591 bool set_shaders(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("shaders", pluginList, time); }
18592 bool set_shaders(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("shaders", plugins, count, time); }
18593 template<size_t count> bool set_shaders(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("shaders", plugins, count, time); }
18596 PluginList get_shaders(double time = TiMe::Default()) const { return getPluginList("shaders", time); }
18597
18601 bool set_shader_indexes(const IntList& intList, double time = TiMe::Default()) { return setValue("shader_indexes", intList, time); }
18602 bool set_shader_indexes(IntList&& intList, double time = TiMe::Default()) { return setValue("shader_indexes", std::move(intList), time); }
18603 bool set_shader_indexes(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("shader_indexes", ints, count, time); }
18604 template<size_t count> bool set_shader_indexes(const int (&ints)[count], double time = TiMe::Default()) { return setArray("shader_indexes", ints, count, time); }
18608 IntList get_shader_indexes(double time = TiMe::Default()) const { return getIntList("shader_indexes", time); }
18609
18612 bool set_shaders_match(const ValueList& list, double time = TiMe::Default()) { return setValue("shaders_match", list, time); }
18613 bool set_shaders_match(ValueList&& list, double time = TiMe::Default()) { return setValue("shaders_match", std::move(list), time); }
18614 bool set_shaders_match(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("shaders_match", values, count, time); }
18615 template<size_t count> bool set_shaders_match(const Value (&values)[count], double time = TiMe::Default()) { return setArray("shaders_match", values, count, time); }
18616 template<size_t count> bool set_shaders_match(Value (&&values)[count], double time = TiMe::Default()) { return setArray("shaders_match", values, count, time); }
18619 ValueList get_shaders_match(double time = TiMe::Default()) const { return getValueList("shaders_match", time); }
18620
18624 bool set_shaders_match_indexes(const IntList& intList, double time = TiMe::Default()) { return setValue("shaders_match_indexes", intList, time); }
18625 bool set_shaders_match_indexes(IntList&& intList, double time = TiMe::Default()) { return setValue("shaders_match_indexes", std::move(intList), time); }
18626 bool set_shaders_match_indexes(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("shaders_match_indexes", ints, count, time); }
18627 template<size_t count> bool set_shaders_match_indexes(const int (&ints)[count], double time = TiMe::Default()) { return setArray("shaders_match_indexes", ints, count, time); }
18631 IntList get_shaders_match_indexes(double time = TiMe::Default()) const { return getIntList("shaders_match_indexes", time); }
18632
18636 bool set_shaders_match_file(const char* str, double time = TiMe::Default()) { return setValue("shaders_match_file", str, time); }
18640 bool set_shaders_match_file(const std::string& str, double time = TiMe::Default()) { return setValue("shaders_match_file", str, time); }
18644 std::string get_shaders_match_file(double time = TiMe::Default()) const { return getString("shaders_match_file", time); }
18645
18648 bool set_map_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("map_channels", pluginList, time); }
18649 bool set_map_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("map_channels", plugins, count, time); }
18650 template<size_t count> bool set_map_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("map_channels", plugins, count, time); }
18653 PluginList get_map_channels(double time = TiMe::Default()) const { return getPluginList("map_channels", time); }
18654
18658 bool set_map_channel_indexes(const IntList& intList, double time = TiMe::Default()) { return setValue("map_channel_indexes", intList, time); }
18659 bool set_map_channel_indexes(IntList&& intList, double time = TiMe::Default()) { return setValue("map_channel_indexes", std::move(intList), time); }
18660 bool set_map_channel_indexes(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("map_channel_indexes", ints, count, time); }
18661 template<size_t count> bool set_map_channel_indexes(const int (&ints)[count], double time = TiMe::Default()) { return setArray("map_channel_indexes", ints, count, time); }
18665 IntList get_map_channel_indexes(double time = TiMe::Default()) const { return getIntList("map_channel_indexes", time); }
18666
18669 bool set_object_properties(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("object_properties", plugin, time); }
18672 PluginRef get_object_properties(double time = TiMe::Default()) const { return getPlugin("object_properties", time); }
18673
18677 bool set_user_attributes_bin(const IntList& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", intList, time); }
18678 bool set_user_attributes_bin(IntList&& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", std::move(intList), time); }
18679 bool set_user_attributes_bin(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
18680 template<size_t count> bool set_user_attributes_bin(const int (&ints)[count], double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
18684 IntList get_user_attributes_bin(double time = TiMe::Default()) const { return getIntList("user_attributes_bin", time); }
18685};
18686
18688class GeomScatter : public Plugin {
18689public:
18691 static constexpr const PluginTypeId getTypeId() { return 0x7894DB1E; }
18693 static constexpr const char* getType() { return "GeomScatter"; }
18694
18695 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
18696
18698 bool set_targets(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("targets", pluginList, time); }
18699 bool set_targets(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("targets", plugins, count, time); }
18700 template<size_t count> bool set_targets(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("targets", plugins, count, time); }
18702 PluginList get_targets(double time = TiMe::Default()) const { return getPluginList("targets", time); }
18703
18707 bool set_target_factors(const FloatList& floatList, double time = TiMe::Default()) { return setValue("target_factors", floatList, time); }
18708 bool set_target_factors(FloatList&& floatList, double time = TiMe::Default()) { return setValue("target_factors", std::move(floatList), time); }
18709 bool set_target_factors(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("target_factors", floats, count, time); }
18710 template<size_t count> bool set_target_factors(const float (&floats)[count], double time = TiMe::Default()) { return setArray("target_factors", floats, count, time); }
18714 FloatList get_target_factors(double time = TiMe::Default()) const { return getFloatList("target_factors", time); }
18715
18719 bool set_targets_tangent_mode(int val, double time = TiMe::Default()) { return setValue("targets_tangent_mode", val, time); }
18723 int get_targets_tangent_mode(double time = TiMe::Default()) const { return getInt("targets_tangent_mode", time); }
18724
18726 bool set_models(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("models", pluginList, time); }
18727 bool set_models(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("models", plugins, count, time); }
18728 template<size_t count> bool set_models(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("models", plugins, count, time); }
18730 PluginList get_models(double time = TiMe::Default()) const { return getPluginList("models", time); }
18731
18735 bool set_model_frequencies(const FloatList& floatList, double time = TiMe::Default()) { return setValue("model_frequencies", floatList, time); }
18736 bool set_model_frequencies(FloatList&& floatList, double time = TiMe::Default()) { return setValue("model_frequencies", std::move(floatList), time); }
18737 bool set_model_frequencies(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("model_frequencies", floats, count, time); }
18738 template<size_t count> bool set_model_frequencies(const float (&floats)[count], double time = TiMe::Default()) { return setArray("model_frequencies", floats, count, time); }
18742 FloatList get_model_frequencies(double time = TiMe::Default()) const { return getFloatList("model_frequencies", time); }
18743
18746 bool set_model_parents(const IntList& intList, double time = TiMe::Default()) { return setValue("model_parents", intList, time); }
18747 bool set_model_parents(IntList&& intList, double time = TiMe::Default()) { return setValue("model_parents", std::move(intList), time); }
18748 bool set_model_parents(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("model_parents", ints, count, time); }
18749 template<size_t count> bool set_model_parents(const int (&ints)[count], double time = TiMe::Default()) { return setArray("model_parents", ints, count, time); }
18752 IntList get_model_parents(double time = TiMe::Default()) const { return getIntList("model_parents", time); }
18753
18757 bool set_scatter_type(int val, double time = TiMe::Default()) { return setValue("scatter_type", val, time); }
18761 int get_scatter_type(double time = TiMe::Default()) const { return getInt("scatter_type", time); }
18762
18766 bool set_instance_count_limit(int val, double time = TiMe::Default()) { return setValue("instance_count_limit", val, time); }
18770 int get_instance_count_limit(double time = TiMe::Default()) const { return getInt("instance_count_limit", time); }
18771
18775 bool set_seed(int val, double time = TiMe::Default()) { return setValue("seed", val, time); }
18779 int get_seed(double time = TiMe::Default()) const { return getInt("seed", time); }
18780
18783 bool set_rest_pose_enabled(bool val, double time = TiMe::Default()) { return setValue("rest_pose_enabled", val, time); }
18786 bool get_rest_pose_enabled(double time = TiMe::Default()) const { return getBool("rest_pose_enabled", time); }
18787
18790 bool set_rest_pose_frame(double val, double time = TiMe::Default()) { return setValue("rest_pose_frame", val, time); }
18793 double get_rest_pose_frame(double time = TiMe::Default()) const { return getDouble("rest_pose_frame", time); }
18794
18797 bool set_avoid_collisions(bool val, double time = TiMe::Default()) { return setValue("avoid_collisions", val, time); }
18800 bool get_avoid_collisions(double time = TiMe::Default()) const { return getBool("avoid_collisions", time); }
18801
18805 bool set_avoid_collisions_spacing(float val, double time = TiMe::Default()) { return setValue("avoid_collisions_spacing", val, time); }
18809 float get_avoid_collisions_spacing(double time = TiMe::Default()) const { return getFloat("avoid_collisions_spacing", time); }
18810
18814 bool set_surface_scatter_mode(int val, double time = TiMe::Default()) { return setValue("surface_scatter_mode", val, time); }
18818 int get_surface_scatter_mode(double time = TiMe::Default()) const { return getInt("surface_scatter_mode", time); }
18819
18823 bool set_surface_random_count(int val, double time = TiMe::Default()) { return setValue("surface_random_count", val, time); }
18827 int get_surface_random_count(double time = TiMe::Default()) const { return getInt("surface_random_count", time); }
18828
18831 bool set_surface_random_use_density(bool val, double time = TiMe::Default()) { return setValue("surface_random_use_density", val, time); }
18834 bool get_surface_random_use_density(double time = TiMe::Default()) const { return getBool("surface_random_use_density", time); }
18835
18839 bool set_surface_random_edge_size(float val, double time = TiMe::Default()) { return setValue("surface_random_edge_size", val, time); }
18843 float get_surface_random_edge_size(double time = TiMe::Default()) const { return getFloat("surface_random_edge_size", time); }
18844
18847 bool set_surface_random_density_map(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("surface_random_density_map", texturefloat, time); }
18850 bool set_surface_random_density_map(float texturefloat, double time = TiMe::Default()) { return setValue("surface_random_density_map", texturefloat, time); }
18853 Value get_surface_random_density_map(double time = TiMe::Default()) const { return getValue("surface_random_density_map", time); }
18854
18858 bool set_surface_random_density_map_pattern(int val, double time = TiMe::Default()) { return setValue("surface_random_density_map_pattern", val, time); }
18862 int get_surface_random_density_map_pattern(double time = TiMe::Default()) const { return getInt("surface_random_density_map_pattern", time); }
18863
18867 bool set_surface_map_pattern(int val, double time = TiMe::Default()) { return setValue("surface_map_pattern", val, time); }
18871 int get_surface_map_pattern(double time = TiMe::Default()) const { return getInt("surface_map_pattern", time); }
18872
18875 bool set_surface_map_planar(bool val, double time = TiMe::Default()) { return setValue("surface_map_planar", val, time); }
18878 bool get_surface_map_planar(double time = TiMe::Default()) const { return getBool("surface_map_planar", time); }
18879
18883 bool set_surface_map_planar_axis(int val, double time = TiMe::Default()) { return setValue("surface_map_planar_axis", val, time); }
18887 int get_surface_map_planar_axis(double time = TiMe::Default()) const { return getInt("surface_map_planar_axis", time); }
18888
18891 bool set_surface_map_lock_v(bool val, double time = TiMe::Default()) { return setValue("surface_map_lock_v", val, time); }
18894 bool get_surface_map_lock_v(double time = TiMe::Default()) const { return getBool("surface_map_lock_v", time); }
18895
18899 bool set_surface_map_spacing_u(float val, double time = TiMe::Default()) { return setValue("surface_map_spacing_u", val, time); }
18903 float get_surface_map_spacing_u(double time = TiMe::Default()) const { return getFloat("surface_map_spacing_u", time); }
18904
18908 bool set_surface_map_spacing_v(float val, double time = TiMe::Default()) { return setValue("surface_map_spacing_v", val, time); }
18912 float get_surface_map_spacing_v(double time = TiMe::Default()) const { return getFloat("surface_map_spacing_v", time); }
18913
18917 bool set_surface_map_jitter_u(float val, double time = TiMe::Default()) { return setValue("surface_map_jitter_u", val, time); }
18921 float get_surface_map_jitter_u(double time = TiMe::Default()) const { return getFloat("surface_map_jitter_u", time); }
18922
18926 bool set_surface_map_jitter_v(float val, double time = TiMe::Default()) { return setValue("surface_map_jitter_v", val, time); }
18930 float get_surface_map_jitter_v(double time = TiMe::Default()) const { return getFloat("surface_map_jitter_v", time); }
18931
18934 bool set_surface_map_offset_u(float val, double time = TiMe::Default()) { return setValue("surface_map_offset_u", val, time); }
18937 float get_surface_map_offset_u(double time = TiMe::Default()) const { return getFloat("surface_map_offset_u", time); }
18938
18941 bool set_surface_map_offset_v(float val, double time = TiMe::Default()) { return setValue("surface_map_offset_v", val, time); }
18944 float get_surface_map_offset_v(double time = TiMe::Default()) const { return getFloat("surface_map_offset_v", time); }
18945
18949 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
18953 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
18954
18957 bool set_map_channel_name(const char* str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
18960 bool set_map_channel_name(const std::string& str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
18963 std::string get_map_channel_name(double time = TiMe::Default()) const { return getString("map_channel_name", time); }
18964
18967 bool set_surface_slope_limit_enabled(bool val, double time = TiMe::Default()) { return setValue("surface_slope_limit_enabled", val, time); }
18970 bool get_surface_slope_limit_enabled(double time = TiMe::Default()) const { return getBool("surface_slope_limit_enabled", time); }
18971
18975 bool set_surface_slope_limit_mode(int val, double time = TiMe::Default()) { return setValue("surface_slope_limit_mode", val, time); }
18979 int get_surface_slope_limit_mode(double time = TiMe::Default()) const { return getInt("surface_slope_limit_mode", time); }
18980
18984 bool set_surface_slope_limit_min(float val, double time = TiMe::Default()) { return setValue("surface_slope_limit_min", val, time); }
18988 float get_surface_slope_limit_min(double time = TiMe::Default()) const { return getFloat("surface_slope_limit_min", time); }
18989
18993 bool set_surface_slope_limit_max(float val, double time = TiMe::Default()) { return setValue("surface_slope_limit_max", val, time); }
18997 float get_surface_slope_limit_max(double time = TiMe::Default()) const { return getFloat("surface_slope_limit_max", time); }
18998
19001 bool set_surface_altitude_limit_enabled(bool val, double time = TiMe::Default()) { return setValue("surface_altitude_limit_enabled", val, time); }
19004 bool get_surface_altitude_limit_enabled(double time = TiMe::Default()) const { return getBool("surface_altitude_limit_enabled", time); }
19005
19009 bool set_surface_altitude_limit_mode(int val, double time = TiMe::Default()) { return setValue("surface_altitude_limit_mode", val, time); }
19013 int get_surface_altitude_limit_mode(double time = TiMe::Default()) const { return getInt("surface_altitude_limit_mode", time); }
19014
19018 bool set_surface_altitude_limit_min(float val, double time = TiMe::Default()) { return setValue("surface_altitude_limit_min", val, time); }
19022 float get_surface_altitude_limit_min(double time = TiMe::Default()) const { return getFloat("surface_altitude_limit_min", time); }
19023
19027 bool set_surface_altitude_limit_max(float val, double time = TiMe::Default()) { return setValue("surface_altitude_limit_max", val, time); }
19031 float get_surface_altitude_limit_max(double time = TiMe::Default()) const { return getFloat("surface_altitude_limit_max", time); }
19032
19035 bool set_surface_altitude_limit_falloff_curve(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("surface_altitude_limit_falloff_curve", vectorList, time); }
19036 bool set_surface_altitude_limit_falloff_curve(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("surface_altitude_limit_falloff_curve", std::move(vectorList), time); }
19037 bool set_surface_altitude_limit_falloff_curve(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("surface_altitude_limit_falloff_curve", vectors, count, time); }
19038 template<size_t count> bool set_surface_altitude_limit_falloff_curve(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("surface_altitude_limit_falloff_curve", vectors, count, time); }
19041 VectorList get_surface_altitude_limit_falloff_curve(double time = TiMe::Default()) const { return getVectorList("surface_altitude_limit_falloff_curve", time); }
19042
19046 bool set_surface_altitude_limit_falloff_curve_interp(int val, double time = TiMe::Default()) { return setValue("surface_altitude_limit_falloff_curve_interp", val, time); }
19050 int get_surface_altitude_limit_falloff_curve_interp(double time = TiMe::Default()) const { return getInt("surface_altitude_limit_falloff_curve_interp", time); }
19051
19054 bool set_spline_vertices(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("spline_vertices", vectorList, time); }
19055 bool set_spline_vertices(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("spline_vertices", std::move(vectorList), time); }
19056 bool set_spline_vertices(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("spline_vertices", vectors, count, time); }
19057 template<size_t count> bool set_spline_vertices(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("spline_vertices", vectors, count, time); }
19060 VectorList get_spline_vertices(double time = TiMe::Default()) const { return getVectorList("spline_vertices", time); }
19061
19064 bool set_spline_vertex_counts(const IntList& intList, double time = TiMe::Default()) { return setValue("spline_vertex_counts", intList, time); }
19065 bool set_spline_vertex_counts(IntList&& intList, double time = TiMe::Default()) { return setValue("spline_vertex_counts", std::move(intList), time); }
19066 bool set_spline_vertex_counts(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("spline_vertex_counts", ints, count, time); }
19067 template<size_t count> bool set_spline_vertex_counts(const int (&ints)[count], double time = TiMe::Default()) { return setArray("spline_vertex_counts", ints, count, time); }
19070 IntList get_spline_vertex_counts(double time = TiMe::Default()) const { return getIntList("spline_vertex_counts", time); }
19071
19074 bool set_spline_transforms(const TransformList& transformList, double time = TiMe::Default()) { return setValue("spline_transforms", transformList, time); }
19075 bool set_spline_transforms(const Transform* transforms, size_t count, double time = TiMe::Default()) { return setArray("spline_transforms", transforms, count, time); }
19076 template<size_t count> bool set_spline_transforms(const Transform (&transforms)[count], double time = TiMe::Default()) { return setArray("spline_transforms", transforms, count, time); }
19079 TransformList get_spline_transforms(double time = TiMe::Default()) const { return getTransformList("spline_transforms", time); }
19080
19084 bool set_spline_spacing(float val, double time = TiMe::Default()) { return setValue("spline_spacing", val, time); }
19088 float get_spline_spacing(double time = TiMe::Default()) const { return getFloat("spline_spacing", time); }
19089
19093 bool set_spline_jitter(float val, double time = TiMe::Default()) { return setValue("spline_jitter", val, time); }
19097 float get_spline_jitter(double time = TiMe::Default()) const { return getFloat("spline_jitter", time); }
19098
19102 bool set_spline_offset(float val, double time = TiMe::Default()) { return setValue("spline_offset", val, time); }
19106 float get_spline_offset(double time = TiMe::Default()) const { return getFloat("spline_offset", time); }
19107
19111 bool set_spline_follow_amount(float val, double time = TiMe::Default()) { return setValue("spline_follow_amount", val, time); }
19115 float get_spline_follow_amount(double time = TiMe::Default()) const { return getFloat("spline_follow_amount", time); }
19116
19120 bool set_volume_random_count(int val, double time = TiMe::Default()) { return setValue("volume_random_count", val, time); }
19124 int get_volume_random_count(double time = TiMe::Default()) const { return getInt("volume_random_count", time); }
19125
19128 bool set_volume_random_use_density(bool val, double time = TiMe::Default()) { return setValue("volume_random_use_density", val, time); }
19131 bool get_volume_random_use_density(double time = TiMe::Default()) const { return getBool("volume_random_use_density", time); }
19132
19136 bool set_volume_random_edge_size(float val, double time = TiMe::Default()) { return setValue("volume_random_edge_size", val, time); }
19140 float get_volume_random_edge_size(double time = TiMe::Default()) const { return getFloat("volume_random_edge_size", time); }
19141
19145 bool set_transforms_translation_from(const Vector& vector, double time = TiMe::Default()) { return setValue("transforms_translation_from", vector, time); }
19149 Vector get_transforms_translation_from(double time = TiMe::Default()) const { return getVector("transforms_translation_from", time); }
19150
19154 bool set_transforms_translation_to(const Vector& vector, double time = TiMe::Default()) { return setValue("transforms_translation_to", vector, time); }
19158 Vector get_transforms_translation_to(double time = TiMe::Default()) const { return getVector("transforms_translation_to", time); }
19159
19163 bool set_transforms_translation_step(float val, double time = TiMe::Default()) { return setValue("transforms_translation_step", val, time); }
19167 float get_transforms_translation_step(double time = TiMe::Default()) const { return getFloat("transforms_translation_step", time); }
19168
19171 bool set_transforms_translation_step_x(bool val, double time = TiMe::Default()) { return setValue("transforms_translation_step_x", val, time); }
19174 bool get_transforms_translation_step_x(double time = TiMe::Default()) const { return getBool("transforms_translation_step_x", time); }
19175
19178 bool set_transforms_translation_step_y(bool val, double time = TiMe::Default()) { return setValue("transforms_translation_step_y", val, time); }
19181 bool get_transforms_translation_step_y(double time = TiMe::Default()) const { return getBool("transforms_translation_step_y", time); }
19182
19185 bool set_transforms_translation_step_z(bool val, double time = TiMe::Default()) { return setValue("transforms_translation_step_z", val, time); }
19188 bool get_transforms_translation_step_z(double time = TiMe::Default()) const { return getBool("transforms_translation_step_z", time); }
19189
19192 bool set_transforms_translation_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transforms_translation_map", texture, time); }
19195 bool set_transforms_translation_map(const AColor& texture, double time = TiMe::Default()) { return setValue("transforms_translation_map", texture, time); }
19198 Value get_transforms_translation_map(double time = TiMe::Default()) const { return getValue("transforms_translation_map", time); }
19199
19203 bool set_transforms_translation_map_mode(int val, double time = TiMe::Default()) { return setValue("transforms_translation_map_mode", val, time); }
19207 int get_transforms_translation_map_mode(double time = TiMe::Default()) const { return getInt("transforms_translation_map_mode", time); }
19208
19211 bool set_transforms_translation_map_x(bool val, double time = TiMe::Default()) { return setValue("transforms_translation_map_x", val, time); }
19214 bool get_transforms_translation_map_x(double time = TiMe::Default()) const { return getBool("transforms_translation_map_x", time); }
19215
19218 bool set_transforms_translation_map_y(bool val, double time = TiMe::Default()) { return setValue("transforms_translation_map_y", val, time); }
19221 bool get_transforms_translation_map_y(double time = TiMe::Default()) const { return getBool("transforms_translation_map_y", time); }
19222
19225 bool set_transforms_translation_map_z(bool val, double time = TiMe::Default()) { return setValue("transforms_translation_map_z", val, time); }
19228 bool get_transforms_translation_map_z(double time = TiMe::Default()) const { return getBool("transforms_translation_map_z", time); }
19229
19233 bool set_transforms_rotation_from(const Vector& vector, double time = TiMe::Default()) { return setValue("transforms_rotation_from", vector, time); }
19237 Vector get_transforms_rotation_from(double time = TiMe::Default()) const { return getVector("transforms_rotation_from", time); }
19238
19242 bool set_transforms_rotation_to(const Vector& vector, double time = TiMe::Default()) { return setValue("transforms_rotation_to", vector, time); }
19246 Vector get_transforms_rotation_to(double time = TiMe::Default()) const { return getVector("transforms_rotation_to", time); }
19247
19251 bool set_transforms_rotation_step(float val, double time = TiMe::Default()) { return setValue("transforms_rotation_step", val, time); }
19255 float get_transforms_rotation_step(double time = TiMe::Default()) const { return getFloat("transforms_rotation_step", time); }
19256
19259 bool set_transforms_rotation_step_x(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_step_x", val, time); }
19262 bool get_transforms_rotation_step_x(double time = TiMe::Default()) const { return getBool("transforms_rotation_step_x", time); }
19263
19266 bool set_transforms_rotation_step_y(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_step_y", val, time); }
19269 bool get_transforms_rotation_step_y(double time = TiMe::Default()) const { return getBool("transforms_rotation_step_y", time); }
19270
19273 bool set_transforms_rotation_step_z(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_step_z", val, time); }
19276 bool get_transforms_rotation_step_z(double time = TiMe::Default()) const { return getBool("transforms_rotation_step_z", time); }
19277
19281 bool set_transforms_rotation_normal_alignment(float val, double time = TiMe::Default()) { return setValue("transforms_rotation_normal_alignment", val, time); }
19285 float get_transforms_rotation_normal_alignment(double time = TiMe::Default()) const { return getFloat("transforms_rotation_normal_alignment", time); }
19286
19289 bool set_transforms_rotation_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transforms_rotation_map", texture, time); }
19292 bool set_transforms_rotation_map(const AColor& texture, double time = TiMe::Default()) { return setValue("transforms_rotation_map", texture, time); }
19295 Value get_transforms_rotation_map(double time = TiMe::Default()) const { return getValue("transforms_rotation_map", time); }
19296
19300 bool set_transforms_rotation_map_mode(int val, double time = TiMe::Default()) { return setValue("transforms_rotation_map_mode", val, time); }
19304 int get_transforms_rotation_map_mode(double time = TiMe::Default()) const { return getInt("transforms_rotation_map_mode", time); }
19305
19308 bool set_transforms_rotation_map_x(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_map_x", val, time); }
19311 bool get_transforms_rotation_map_x(double time = TiMe::Default()) const { return getBool("transforms_rotation_map_x", time); }
19312
19315 bool set_transforms_rotation_map_y(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_map_y", val, time); }
19318 bool get_transforms_rotation_map_y(double time = TiMe::Default()) const { return getBool("transforms_rotation_map_y", time); }
19319
19322 bool set_transforms_rotation_map_z(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_map_z", val, time); }
19325 bool get_transforms_rotation_map_z(double time = TiMe::Default()) const { return getBool("transforms_rotation_map_z", time); }
19326
19329 bool set_transforms_rotation_preserve(bool val, double time = TiMe::Default()) { return setValue("transforms_rotation_preserve", val, time); }
19332 bool get_transforms_rotation_preserve(double time = TiMe::Default()) const { return getBool("transforms_rotation_preserve", time); }
19333
19336 bool set_look_at_enabled(bool val, double time = TiMe::Default()) { return setValue("look_at_enabled", val, time); }
19339 bool get_look_at_enabled(double time = TiMe::Default()) const { return getBool("look_at_enabled", time); }
19340
19342 bool set_look_at_target(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("look_at_target", plugin, time); }
19344 PluginRef get_look_at_target(double time = TiMe::Default()) const { return getPlugin("look_at_target", time); }
19345
19349 bool set_look_at_falloff_distance(float val, double time = TiMe::Default()) { return setValue("look_at_falloff_distance", val, time); }
19353 float get_look_at_falloff_distance(double time = TiMe::Default()) const { return getFloat("look_at_falloff_distance", time); }
19354
19357 bool set_look_at_falloff_curve(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("look_at_falloff_curve", vectorList, time); }
19358 bool set_look_at_falloff_curve(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("look_at_falloff_curve", std::move(vectorList), time); }
19359 bool set_look_at_falloff_curve(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("look_at_falloff_curve", vectors, count, time); }
19360 template<size_t count> bool set_look_at_falloff_curve(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("look_at_falloff_curve", vectors, count, time); }
19363 VectorList get_look_at_falloff_curve(double time = TiMe::Default()) const { return getVectorList("look_at_falloff_curve", time); }
19364
19368 bool set_look_at_falloff_curve_interp(int val, double time = TiMe::Default()) { return setValue("look_at_falloff_curve_interp", val, time); }
19372 int get_look_at_falloff_curve_interp(double time = TiMe::Default()) const { return getInt("look_at_falloff_curve_interp", time); }
19373
19377 bool set_look_at_models_orientation_axis(int val, double time = TiMe::Default()) { return setValue("look_at_models_orientation_axis", val, time); }
19381 int get_look_at_models_orientation_axis(double time = TiMe::Default()) const { return getInt("look_at_models_orientation_axis", time); }
19382
19385 bool set_look_at_models_orientation_axis_invert(bool val, double time = TiMe::Default()) { return setValue("look_at_models_orientation_axis_invert", val, time); }
19388 bool get_look_at_models_orientation_axis_invert(double time = TiMe::Default()) const { return getBool("look_at_models_orientation_axis_invert", time); }
19389
19392 bool set_look_at_horizontal(bool val, double time = TiMe::Default()) { return setValue("look_at_horizontal", val, time); }
19395 bool get_look_at_horizontal(double time = TiMe::Default()) const { return getBool("look_at_horizontal", time); }
19396
19399 bool set_transforms_scale_from(const Vector& vector, double time = TiMe::Default()) { return setValue("transforms_scale_from", vector, time); }
19402 Vector get_transforms_scale_from(double time = TiMe::Default()) const { return getVector("transforms_scale_from", time); }
19403
19406 bool set_transforms_scale_to(const Vector& vector, double time = TiMe::Default()) { return setValue("transforms_scale_to", vector, time); }
19409 Vector get_transforms_scale_to(double time = TiMe::Default()) const { return getVector("transforms_scale_to", time); }
19410
19414 bool set_transforms_scale_step(float val, double time = TiMe::Default()) { return setValue("transforms_scale_step", val, time); }
19418 float get_transforms_scale_step(double time = TiMe::Default()) const { return getFloat("transforms_scale_step", time); }
19419
19422 bool set_transforms_scale_step_x(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_step_x", val, time); }
19425 bool get_transforms_scale_step_x(double time = TiMe::Default()) const { return getBool("transforms_scale_step_x", time); }
19426
19429 bool set_transforms_scale_step_y(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_step_y", val, time); }
19432 bool get_transforms_scale_step_y(double time = TiMe::Default()) const { return getBool("transforms_scale_step_y", time); }
19433
19436 bool set_transforms_scale_step_z(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_step_z", val, time); }
19439 bool get_transforms_scale_step_z(double time = TiMe::Default()) const { return getBool("transforms_scale_step_z", time); }
19440
19443 bool set_transforms_scale_uniform(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_uniform", val, time); }
19446 bool get_transforms_scale_uniform(double time = TiMe::Default()) const { return getBool("transforms_scale_uniform", time); }
19447
19450 bool set_transforms_scale_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transforms_scale_map", texture, time); }
19453 bool set_transforms_scale_map(const AColor& texture, double time = TiMe::Default()) { return setValue("transforms_scale_map", texture, time); }
19456 Value get_transforms_scale_map(double time = TiMe::Default()) const { return getValue("transforms_scale_map", time); }
19457
19461 bool set_transforms_scale_map_mode(int val, double time = TiMe::Default()) { return setValue("transforms_scale_map_mode", val, time); }
19465 int get_transforms_scale_map_mode(double time = TiMe::Default()) const { return getInt("transforms_scale_map_mode", time); }
19466
19469 bool set_transforms_scale_map_x(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_map_x", val, time); }
19472 bool get_transforms_scale_map_x(double time = TiMe::Default()) const { return getBool("transforms_scale_map_x", time); }
19473
19476 bool set_transforms_scale_map_y(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_map_y", val, time); }
19479 bool get_transforms_scale_map_y(double time = TiMe::Default()) const { return getBool("transforms_scale_map_y", time); }
19480
19483 bool set_transforms_scale_map_z(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_map_z", val, time); }
19486 bool get_transforms_scale_map_z(double time = TiMe::Default()) const { return getBool("transforms_scale_map_z", time); }
19487
19490 bool set_transforms_scale_preserve(bool val, double time = TiMe::Default()) { return setValue("transforms_scale_preserve", val, time); }
19493 bool get_transforms_scale_preserve(double time = TiMe::Default()) const { return getBool("transforms_scale_preserve", time); }
19494
19497 bool set_area_modifiers_vertices(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("area_modifiers_vertices", vectorList, time); }
19498 bool set_area_modifiers_vertices(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("area_modifiers_vertices", std::move(vectorList), time); }
19499 bool set_area_modifiers_vertices(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_vertices", vectors, count, time); }
19500 template<size_t count> bool set_area_modifiers_vertices(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("area_modifiers_vertices", vectors, count, time); }
19503 VectorList get_area_modifiers_vertices(double time = TiMe::Default()) const { return getVectorList("area_modifiers_vertices", time); }
19504
19507 bool set_area_modifiers_vertex_counts(const IntList& intList, double time = TiMe::Default()) { return setValue("area_modifiers_vertex_counts", intList, time); }
19508 bool set_area_modifiers_vertex_counts(IntList&& intList, double time = TiMe::Default()) { return setValue("area_modifiers_vertex_counts", std::move(intList), time); }
19509 bool set_area_modifiers_vertex_counts(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_vertex_counts", ints, count, time); }
19510 template<size_t count> bool set_area_modifiers_vertex_counts(const int (&ints)[count], double time = TiMe::Default()) { return setArray("area_modifiers_vertex_counts", ints, count, time); }
19513 IntList get_area_modifiers_vertex_counts(double time = TiMe::Default()) const { return getIntList("area_modifiers_vertex_counts", time); }
19514
19516 bool set_area_modifiers(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("area_modifiers", pluginList, time); }
19517 bool set_area_modifiers(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers", plugins, count, time); }
19518 template<size_t count> bool set_area_modifiers(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("area_modifiers", plugins, count, time); }
19520 PluginList get_area_modifiers(double time = TiMe::Default()) const { return getPluginList("area_modifiers", time); }
19521
19525 bool set_area_modifiers_operation(const IntList& intList, double time = TiMe::Default()) { return setValue("area_modifiers_operation", intList, time); }
19526 bool set_area_modifiers_operation(IntList&& intList, double time = TiMe::Default()) { return setValue("area_modifiers_operation", std::move(intList), time); }
19527 bool set_area_modifiers_operation(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_operation", ints, count, time); }
19528 template<size_t count> bool set_area_modifiers_operation(const int (&ints)[count], double time = TiMe::Default()) { return setArray("area_modifiers_operation", ints, count, time); }
19532 IntList get_area_modifiers_operation(double time = TiMe::Default()) const { return getIntList("area_modifiers_operation", time); }
19533
19537 bool set_area_modifiers_falloff_near(const FloatList& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_falloff_near", floatList, time); }
19538 bool set_area_modifiers_falloff_near(FloatList&& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_falloff_near", std::move(floatList), time); }
19539 bool set_area_modifiers_falloff_near(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_falloff_near", floats, count, time); }
19540 template<size_t count> bool set_area_modifiers_falloff_near(const float (&floats)[count], double time = TiMe::Default()) { return setArray("area_modifiers_falloff_near", floats, count, time); }
19544 FloatList get_area_modifiers_falloff_near(double time = TiMe::Default()) const { return getFloatList("area_modifiers_falloff_near", time); }
19545
19549 bool set_area_modifiers_falloff_far(const FloatList& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_falloff_far", floatList, time); }
19550 bool set_area_modifiers_falloff_far(FloatList&& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_falloff_far", std::move(floatList), time); }
19551 bool set_area_modifiers_falloff_far(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_falloff_far", floats, count, time); }
19552 template<size_t count> bool set_area_modifiers_falloff_far(const float (&floats)[count], double time = TiMe::Default()) { return setArray("area_modifiers_falloff_far", floats, count, time); }
19556 FloatList get_area_modifiers_falloff_far(double time = TiMe::Default()) const { return getFloatList("area_modifiers_falloff_far", time); }
19557
19561 bool set_area_modifiers_scale(const FloatList& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_scale", floatList, time); }
19562 bool set_area_modifiers_scale(FloatList&& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_scale", std::move(floatList), time); }
19563 bool set_area_modifiers_scale(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_scale", floats, count, time); }
19564 template<size_t count> bool set_area_modifiers_scale(const float (&floats)[count], double time = TiMe::Default()) { return setArray("area_modifiers_scale", floats, count, time); }
19568 FloatList get_area_modifiers_scale(double time = TiMe::Default()) const { return getFloatList("area_modifiers_scale", time); }
19569
19573 bool set_area_modifiers_density(const FloatList& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_density", floatList, time); }
19574 bool set_area_modifiers_density(FloatList&& floatList, double time = TiMe::Default()) { return setValue("area_modifiers_density", std::move(floatList), time); }
19575 bool set_area_modifiers_density(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_density", floats, count, time); }
19576 template<size_t count> bool set_area_modifiers_density(const float (&floats)[count], double time = TiMe::Default()) { return setArray("area_modifiers_density", floats, count, time); }
19580 FloatList get_area_modifiers_density(double time = TiMe::Default()) const { return getFloatList("area_modifiers_density", time); }
19581
19585 bool set_area_modifiers_axis(const IntList& intList, double time = TiMe::Default()) { return setValue("area_modifiers_axis", intList, time); }
19586 bool set_area_modifiers_axis(IntList&& intList, double time = TiMe::Default()) { return setValue("area_modifiers_axis", std::move(intList), time); }
19587 bool set_area_modifiers_axis(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("area_modifiers_axis", ints, count, time); }
19588 template<size_t count> bool set_area_modifiers_axis(const int (&ints)[count], double time = TiMe::Default()) { return setArray("area_modifiers_axis", ints, count, time); }
19592 IntList get_area_modifiers_axis(double time = TiMe::Default()) const { return getIntList("area_modifiers_axis", time); }
19593
19597 bool set_flip_axis(int val, double time = TiMe::Default()) { return setValue("flip_axis", val, time); }
19601 int get_flip_axis(double time = TiMe::Default()) const { return getInt("flip_axis", time); }
19602
19606 bool set_edge_trimming_enabled(int val, double time = TiMe::Default()) { return setValue("edge_trimming_enabled", val, time); }
19610 int get_edge_trimming_enabled(double time = TiMe::Default()) const { return getInt("edge_trimming_enabled", time); }
19611
19615 bool set_camera_clipping_enabled(bool val, double time = TiMe::Default()) { return setValue("camera_clipping_enabled", val, time); }
19619 bool get_camera_clipping_enabled(double time = TiMe::Default()) const { return getBool("camera_clipping_enabled", time); }
19620
19624 bool set_camera_clipping_mode(int val, double time = TiMe::Default()) { return setValue("camera_clipping_mode", val, time); }
19628 int get_camera_clipping_mode(double time = TiMe::Default()) const { return getInt("camera_clipping_mode", time); }
19629
19631 bool set_camera_clipping_selected_cam(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("camera_clipping_selected_cam", plugin, time); }
19633 PluginRef get_camera_clipping_selected_cam(double time = TiMe::Default()) const { return getPlugin("camera_clipping_selected_cam", time); }
19634
19638 bool set_camera_clipping_extend_view(float val, double time = TiMe::Default()) { return setValue("camera_clipping_extend_view", val, time); }
19642 float get_camera_clipping_extend_view(double time = TiMe::Default()) const { return getFloat("camera_clipping_extend_view", time); }
19643
19647 bool set_camera_clipping_near_far_enabled(bool val, double time = TiMe::Default()) { return setValue("camera_clipping_near_far_enabled", val, time); }
19651 bool get_camera_clipping_near_far_enabled(double time = TiMe::Default()) const { return getBool("camera_clipping_near_far_enabled", time); }
19652
19656 bool set_camera_clipping_near_distance(float val, double time = TiMe::Default()) { return setValue("camera_clipping_near_distance", val, time); }
19660 float get_camera_clipping_near_distance(double time = TiMe::Default()) const { return getFloat("camera_clipping_near_distance", time); }
19661
19665 bool set_camera_clipping_far_distance(float val, double time = TiMe::Default()) { return setValue("camera_clipping_far_distance", val, time); }
19669 float get_camera_clipping_far_distance(double time = TiMe::Default()) const { return getFloat("camera_clipping_far_distance", time); }
19670
19673 bool set_instance_override_info_packs(const IntList& intList, double time = TiMe::Default()) { return setValue("instance_override_info_packs", intList, time); }
19674 bool set_instance_override_info_packs(IntList&& intList, double time = TiMe::Default()) { return setValue("instance_override_info_packs", std::move(intList), time); }
19675 bool set_instance_override_info_packs(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("instance_override_info_packs", ints, count, time); }
19676 template<size_t count> bool set_instance_override_info_packs(const int (&ints)[count], double time = TiMe::Default()) { return setArray("instance_override_info_packs", ints, count, time); }
19679 IntList get_instance_override_info_packs(double time = TiMe::Default()) const { return getIntList("instance_override_info_packs", time); }
19680
19683 bool set_instance_override_transforms(const TransformList& transformList, double time = TiMe::Default()) { return setValue("instance_override_transforms", transformList, time); }
19684 bool set_instance_override_transforms(const Transform* transforms, size_t count, double time = TiMe::Default()) { return setArray("instance_override_transforms", transforms, count, time); }
19685 template<size_t count> bool set_instance_override_transforms(const Transform (&transforms)[count], double time = TiMe::Default()) { return setArray("instance_override_transforms", transforms, count, time); }
19688 TransformList get_instance_override_transforms(double time = TiMe::Default()) const { return getTransformList("instance_override_transforms", time); }
19689
19692 bool set_instance_override_placements(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("instance_override_placements", vectorList, time); }
19693 bool set_instance_override_placements(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("instance_override_placements", std::move(vectorList), time); }
19694 bool set_instance_override_placements(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("instance_override_placements", vectors, count, time); }
19695 template<size_t count> bool set_instance_override_placements(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("instance_override_placements", vectors, count, time); }
19698 VectorList get_instance_override_placements(double time = TiMe::Default()) const { return getVectorList("instance_override_placements", time); }
19699
19703 bool set_presample_surface_color_map(bool val, double time = TiMe::Default()) { return setValue("presample_surface_color_map", val, time); }
19707 bool get_presample_surface_color_map(double time = TiMe::Default()) const { return getBool("presample_surface_color_map", time); }
19708
19711 bool set_instances_cryptomatte_override(bool val, double time = TiMe::Default()) { return setValue("instances_cryptomatte_override", val, time); }
19714 bool get_instances_cryptomatte_override(double time = TiMe::Default()) const { return getBool("instances_cryptomatte_override", time); }
19715
19719 bool set_compatibility_skip_transformations_rebase(bool val, double time = TiMe::Default()) { return setValue("compatibility_skip_transformations_rebase", val, time); }
19723 bool get_compatibility_skip_transformations_rebase(double time = TiMe::Default()) const { return getBool("compatibility_skip_transformations_rebase", time); }
19724
19728 bool set_compatibility_skip_original_rotation(bool val, double time = TiMe::Default()) { return setValue("compatibility_skip_original_rotation", val, time); }
19732 bool get_compatibility_skip_original_rotation(double time = TiMe::Default()) const { return getBool("compatibility_skip_original_rotation", time); }
19733
19737 bool set_compatibility_sample_model_tm_at_rest_pose(bool val, double time = TiMe::Default()) { return setValue("compatibility_sample_model_tm_at_rest_pose", val, time); }
19741 bool get_compatibility_sample_model_tm_at_rest_pose(double time = TiMe::Default()) const { return getBool("compatibility_sample_model_tm_at_rest_pose", time); }
19742
19746 bool set_compatibility_spline_scatter_normals_refdir(bool val, double time = TiMe::Default()) { return setValue("compatibility_spline_scatter_normals_refdir", val, time); }
19750 bool get_compatibility_spline_scatter_normals_refdir(double time = TiMe::Default()) const { return getBool("compatibility_spline_scatter_normals_refdir", time); }
19751
19755 bool set_compatibility_planar_map_no_scale_swap(bool val, double time = TiMe::Default()) { return setValue("compatibility_planar_map_no_scale_swap", val, time); }
19759 bool get_compatibility_planar_map_no_scale_swap(double time = TiMe::Default()) const { return getBool("compatibility_planar_map_no_scale_swap", time); }
19760
19764 bool set_compatibility_light_bounding_box_mode(int val, double time = TiMe::Default()) { return setValue("compatibility_light_bounding_box_mode", val, time); }
19768 int get_compatibility_light_bounding_box_mode(double time = TiMe::Default()) const { return getInt("compatibility_light_bounding_box_mode", time); }
19769
19773 bool set_compatibility_single_channel_limitation(bool val, double time = TiMe::Default()) { return setValue("compatibility_single_channel_limitation", val, time); }
19777 bool get_compatibility_single_channel_limitation(double time = TiMe::Default()) const { return getBool("compatibility_single_channel_limitation", time); }
19778
19782 bool set_compatibility_edited_instances_avoidance_legacy(bool val, double time = TiMe::Default()) { return setValue("compatibility_edited_instances_avoidance_legacy", val, time); }
19786 bool get_compatibility_edited_instances_avoidance_legacy(double time = TiMe::Default()) const { return getBool("compatibility_edited_instances_avoidance_legacy", time); }
19787
19791 bool set_compatibility_omit_rest_pose_transformations(bool val, double time = TiMe::Default()) { return setValue("compatibility_omit_rest_pose_transformations", val, time); }
19795 bool get_compatibility_omit_rest_pose_transformations(double time = TiMe::Default()) const { return getBool("compatibility_omit_rest_pose_transformations", time); }
19796
19800 bool set_compatibility_tiny_triangles_scattering(bool val, double time = TiMe::Default()) { return setValue("compatibility_tiny_triangles_scattering", val, time); }
19804 bool get_compatibility_tiny_triangles_scattering(double time = TiMe::Default()) const { return getBool("compatibility_tiny_triangles_scattering", time); }
19805
19809 bool set_compatibility_altitude_falloff_unstable_randomization(bool val, double time = TiMe::Default()) { return setValue("compatibility_altitude_falloff_unstable_randomization", val, time); }
19813 bool get_compatibility_altitude_falloff_unstable_randomization(double time = TiMe::Default()) const { return getBool("compatibility_altitude_falloff_unstable_randomization", time); }
19814
19818 bool set_compatibility_altitude_falloff_inconsistency(bool val, double time = TiMe::Default()) { return setValue("compatibility_altitude_falloff_inconsistency", val, time); }
19822 bool get_compatibility_altitude_falloff_inconsistency(double time = TiMe::Default()) const { return getBool("compatibility_altitude_falloff_inconsistency", time); }
19823
19827 bool set_compatibility_transforms_inconsistency(bool val, double time = TiMe::Default()) { return setValue("compatibility_transforms_inconsistency", val, time); }
19831 bool get_compatibility_transforms_inconsistency(double time = TiMe::Default()) const { return getBool("compatibility_transforms_inconsistency", time); }
19832
19836 bool set_compatibility_use_volatile_edited_instance_ids(bool val, double time = TiMe::Default()) { return setValue("compatibility_use_volatile_edited_instance_ids", val, time); }
19840 bool get_compatibility_use_volatile_edited_instance_ids(double time = TiMe::Default()) const { return getBool("compatibility_use_volatile_edited_instance_ids", time); }
19841
19845 bool set_compatibility_cyclic_map_channel_selection(bool val, double time = TiMe::Default()) { return setValue("compatibility_cyclic_map_channel_selection", val, time); }
19849 bool get_compatibility_cyclic_map_channel_selection(double time = TiMe::Default()) const { return getBool("compatibility_cyclic_map_channel_selection", time); }
19850};
19851
19854public:
19856 static constexpr const PluginTypeId getTypeId() { return 0x7895C966; }
19858 static constexpr const char* getType() { return "GeomScatterSpline"; }
19859
19862 bool set_vertices(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("vertices", vectorList, time); }
19863 bool set_vertices(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("vertices", std::move(vectorList), time); }
19864 bool set_vertices(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("vertices", vectors, count, time); }
19865 template<size_t count> bool set_vertices(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("vertices", vectors, count, time); }
19868 VectorList get_vertices(double time = TiMe::Default()) const { return getVectorList("vertices", time); }
19869
19872 bool set_triangulate(int val, double time = TiMe::Default()) { return setValue("triangulate", val, time); }
19875 int get_triangulate(double time = TiMe::Default()) const { return getInt("triangulate", time); }
19876};
19877
19879class GeomStaticMesh : public Plugin {
19880public:
19882 static constexpr const PluginTypeId getTypeId() { return 0x77742AB4; }
19884 static constexpr const char* getType() { return "GeomStaticMesh"; }
19885
19886 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
19887
19889 bool set_vertices(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("vertices", vectorList, time); }
19890 bool set_vertices(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("vertices", std::move(vectorList), time); }
19891 bool set_vertices(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("vertices", vectors, count, time); }
19892 template<size_t count> bool set_vertices(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("vertices", vectors, count, time); }
19894 VectorList get_vertices(double time = TiMe::Default()) const { return getVectorList("vertices", time); }
19895
19897 bool set_faces(const IntList& intList, double time = TiMe::Default()) { return setValue("faces", intList, time); }
19898 bool set_faces(IntList&& intList, double time = TiMe::Default()) { return setValue("faces", std::move(intList), time); }
19899 bool set_faces(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("faces", ints, count, time); }
19900 template<size_t count> bool set_faces(const int (&ints)[count], double time = TiMe::Default()) { return setArray("faces", ints, count, time); }
19902 IntList get_faces(double time = TiMe::Default()) const { return getIntList("faces", time); }
19903
19905 bool set_normals(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("normals", vectorList, time); }
19906 bool set_normals(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("normals", std::move(vectorList), time); }
19907 bool set_normals(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("normals", vectors, count, time); }
19908 template<size_t count> bool set_normals(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("normals", vectors, count, time); }
19910 VectorList get_normals(double time = TiMe::Default()) const { return getVectorList("normals", time); }
19911
19913 bool set_faceNormals(const IntList& intList, double time = TiMe::Default()) { return setValue("faceNormals", intList, time); }
19914 bool set_faceNormals(IntList&& intList, double time = TiMe::Default()) { return setValue("faceNormals", std::move(intList), time); }
19915 bool set_faceNormals(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("faceNormals", ints, count, time); }
19916 template<size_t count> bool set_faceNormals(const int (&ints)[count], double time = TiMe::Default()) { return setArray("faceNormals", ints, count, time); }
19918 IntList get_faceNormals(double time = TiMe::Default()) const { return getIntList("faceNormals", time); }
19919
19921 bool set_map_channels(const ValueList& list, double time = TiMe::Default()) { return setValue("map_channels", list, time); }
19922 bool set_map_channels(ValueList&& list, double time = TiMe::Default()) { return setValue("map_channels", std::move(list), time); }
19923 bool set_map_channels(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
19924 template<size_t count> bool set_map_channels(const Value (&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
19925 template<size_t count> bool set_map_channels(Value (&&values)[count], double time = TiMe::Default()) { return setArray("map_channels", values, count, time); }
19927 ValueList get_map_channels(double time = TiMe::Default()) const { return getValueList("map_channels", time); }
19928
19930 bool set_map_channels_names(const StringList& stringList, double time = TiMe::Default()) { return setValue("map_channels_names", stringList, time); }
19932 StringList get_map_channels_names(double time = TiMe::Default()) const { return getStringList("map_channels_names", time); }
19933
19935 bool set_edge_visibility(const IntList& intList, double time = TiMe::Default()) { return setValue("edge_visibility", intList, time); }
19936 bool set_edge_visibility(IntList&& intList, double time = TiMe::Default()) { return setValue("edge_visibility", std::move(intList), time); }
19937 bool set_edge_visibility(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("edge_visibility", ints, count, time); }
19938 template<size_t count> bool set_edge_visibility(const int (&ints)[count], double time = TiMe::Default()) { return setArray("edge_visibility", ints, count, time); }
19940 IntList get_edge_visibility(double time = TiMe::Default()) const { return getIntList("edge_visibility", time); }
19941
19943 bool set_face_mtlIDs(const IntList& intList, double time = TiMe::Default()) { return setValue("face_mtlIDs", intList, time); }
19944 bool set_face_mtlIDs(IntList&& intList, double time = TiMe::Default()) { return setValue("face_mtlIDs", std::move(intList), time); }
19945 bool set_face_mtlIDs(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("face_mtlIDs", ints, count, time); }
19946 template<size_t count> bool set_face_mtlIDs(const int (&ints)[count], double time = TiMe::Default()) { return setArray("face_mtlIDs", ints, count, time); }
19948 IntList get_face_mtlIDs(double time = TiMe::Default()) const { return getIntList("face_mtlIDs", time); }
19949
19951 bool set_shaders_names(const ValueList& list, double time = TiMe::Default()) { return setValue("shaders_names", list, time); }
19952 bool set_shaders_names(ValueList&& list, double time = TiMe::Default()) { return setValue("shaders_names", std::move(list), time); }
19953 bool set_shaders_names(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("shaders_names", values, count, time); }
19954 template<size_t count> bool set_shaders_names(const Value (&values)[count], double time = TiMe::Default()) { return setArray("shaders_names", values, count, time); }
19955 template<size_t count> bool set_shaders_names(Value (&&values)[count], double time = TiMe::Default()) { return setArray("shaders_names", values, count, time); }
19957 ValueList get_shaders_names(double time = TiMe::Default()) const { return getValueList("shaders_names", time); }
19958
19960 bool set_smooth_derivs(const ValueList& list, double time = TiMe::Default()) { return setValue("smooth_derivs", list, time); }
19961 bool set_smooth_derivs(ValueList&& list, double time = TiMe::Default()) { return setValue("smooth_derivs", std::move(list), time); }
19962 bool set_smooth_derivs(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("smooth_derivs", values, count, time); }
19963 template<size_t count> bool set_smooth_derivs(const Value (&values)[count], double time = TiMe::Default()) { return setArray("smooth_derivs", values, count, time); }
19964 template<size_t count> bool set_smooth_derivs(Value (&&values)[count], double time = TiMe::Default()) { return setArray("smooth_derivs", values, count, time); }
19966 ValueList get_smooth_derivs(double time = TiMe::Default()) const { return getValueList("smooth_derivs", time); }
19967
19970 bool set_weld_threshold(float val, double time = TiMe::Default()) { return setValue("weld_threshold", val, time); }
19973 float get_weld_threshold(double time = TiMe::Default()) const { return getFloat("weld_threshold", time); }
19974
19976 bool set_reference_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("reference_mesh", plugin, time); }
19978 PluginRef get_reference_mesh(double time = TiMe::Default()) const { return getPlugin("reference_mesh", time); }
19979
19982 bool set_reference_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("reference_transform", transform, time); }
19985 Transform get_reference_transform(double time = TiMe::Default()) const { return getTransform("reference_transform", time); }
19986
19989 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
19992 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
19993
19997 bool set_dynamic_geometry(int val, double time = TiMe::Default()) { return setValue("dynamic_geometry", val, time); }
20001 int get_dynamic_geometry(double time = TiMe::Default()) const { return getInt("dynamic_geometry", time); }
20002
20005 bool set_smooth_uv_borders(bool val, double time = TiMe::Default()) { return setValue("smooth_uv_borders", val, time); }
20008 bool get_smooth_uv_borders(double time = TiMe::Default()) const { return getBool("smooth_uv_borders", time); }
20009
20013 bool set_smooth_uv(bool val, double time = TiMe::Default()) { return setValue("smooth_uv", val, time); }
20017 bool get_smooth_uv(double time = TiMe::Default()) const { return getBool("smooth_uv", time); }
20018
20021 bool set_velocities(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("velocities", vectorList, time); }
20022 bool set_velocities(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("velocities", std::move(vectorList), time); }
20023 bool set_velocities(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
20024 template<size_t count> bool set_velocities(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("velocities", vectors, count, time); }
20027 VectorList get_velocities(double time = TiMe::Default()) const { return getVectorList("velocities", time); }
20028
20030 bool set_first_poly_vertices(const IntList& intList, double time = TiMe::Default()) { return setValue("first_poly_vertices", intList, time); }
20031 bool set_first_poly_vertices(IntList&& intList, double time = TiMe::Default()) { return setValue("first_poly_vertices", std::move(intList), time); }
20032 bool set_first_poly_vertices(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("first_poly_vertices", ints, count, time); }
20033 template<size_t count> bool set_first_poly_vertices(const int (&ints)[count], double time = TiMe::Default()) { return setArray("first_poly_vertices", ints, count, time); }
20035 IntList get_first_poly_vertices(double time = TiMe::Default()) const { return getIntList("first_poly_vertices", time); }
20036
20040 bool set_osd_subdiv_enable(bool val, double time = TiMe::Default()) { return setValue("osd_subdiv_enable", val, time); }
20044 bool get_osd_subdiv_enable(double time = TiMe::Default()) const { return getBool("osd_subdiv_enable", time); }
20045
20049 bool set_osd_subdiv_level(int val, double time = TiMe::Default()) { return setValue("osd_subdiv_level", val, time); }
20053 int get_osd_subdiv_level(double time = TiMe::Default()) const { return getInt("osd_subdiv_level", time); }
20054
20058 bool set_osd_subdiv_type(int val, double time = TiMe::Default()) { return setValue("osd_subdiv_type", val, time); }
20062 int get_osd_subdiv_type(double time = TiMe::Default()) const { return getInt("osd_subdiv_type", time); }
20063
20067 bool set_osd_subdiv_uvs(bool val, double time = TiMe::Default()) { return setValue("osd_subdiv_uvs", val, time); }
20071 bool get_osd_subdiv_uvs(double time = TiMe::Default()) const { return getBool("osd_subdiv_uvs", time); }
20072
20076 bool set_osd_preserve_map_borders(int val, double time = TiMe::Default()) { return setValue("osd_preserve_map_borders", val, time); }
20080 int get_osd_preserve_map_borders(double time = TiMe::Default()) const { return getInt("osd_preserve_map_borders", time); }
20081
20085 bool set_osd_preserve_geometry_borders(bool val, double time = TiMe::Default()) { return setValue("osd_preserve_geometry_borders", val, time); }
20089 bool get_osd_preserve_geometry_borders(double time = TiMe::Default()) const { return getBool("osd_preserve_geometry_borders", time); }
20090
20093 bool set_edge_creases_vertices(const IntList& intList, double time = TiMe::Default()) { return setValue("edge_creases_vertices", intList, time); }
20094 bool set_edge_creases_vertices(IntList&& intList, double time = TiMe::Default()) { return setValue("edge_creases_vertices", std::move(intList), time); }
20095 bool set_edge_creases_vertices(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("edge_creases_vertices", ints, count, time); }
20096 template<size_t count> bool set_edge_creases_vertices(const int (&ints)[count], double time = TiMe::Default()) { return setArray("edge_creases_vertices", ints, count, time); }
20099 IntList get_edge_creases_vertices(double time = TiMe::Default()) const { return getIntList("edge_creases_vertices", time); }
20100
20103 bool set_edge_creases_sharpness(const FloatList& floatList, double time = TiMe::Default()) { return setValue("edge_creases_sharpness", floatList, time); }
20104 bool set_edge_creases_sharpness(FloatList&& floatList, double time = TiMe::Default()) { return setValue("edge_creases_sharpness", std::move(floatList), time); }
20105 bool set_edge_creases_sharpness(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("edge_creases_sharpness", floats, count, time); }
20106 template<size_t count> bool set_edge_creases_sharpness(const float (&floats)[count], double time = TiMe::Default()) { return setArray("edge_creases_sharpness", floats, count, time); }
20109 FloatList get_edge_creases_sharpness(double time = TiMe::Default()) const { return getFloatList("edge_creases_sharpness", time); }
20110
20113 bool set_vertex_creases_vertices(const IntList& intList, double time = TiMe::Default()) { return setValue("vertex_creases_vertices", intList, time); }
20114 bool set_vertex_creases_vertices(IntList&& intList, double time = TiMe::Default()) { return setValue("vertex_creases_vertices", std::move(intList), time); }
20115 bool set_vertex_creases_vertices(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("vertex_creases_vertices", ints, count, time); }
20116 template<size_t count> bool set_vertex_creases_vertices(const int (&ints)[count], double time = TiMe::Default()) { return setArray("vertex_creases_vertices", ints, count, time); }
20119 IntList get_vertex_creases_vertices(double time = TiMe::Default()) const { return getIntList("vertex_creases_vertices", time); }
20120
20123 bool set_vertex_creases_sharpness(const FloatList& floatList, double time = TiMe::Default()) { return setValue("vertex_creases_sharpness", floatList, time); }
20124 bool set_vertex_creases_sharpness(FloatList&& floatList, double time = TiMe::Default()) { return setValue("vertex_creases_sharpness", std::move(floatList), time); }
20125 bool set_vertex_creases_sharpness(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("vertex_creases_sharpness", floats, count, time); }
20126 template<size_t count> bool set_vertex_creases_sharpness(const float (&floats)[count], double time = TiMe::Default()) { return setArray("vertex_creases_sharpness", floats, count, time); }
20129 FloatList get_vertex_creases_sharpness(double time = TiMe::Default()) const { return getFloatList("vertex_creases_sharpness", time); }
20130
20134 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
20138 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
20139};
20140
20142class GeomStaticNURBS : public Plugin {
20143public:
20145 static constexpr const PluginTypeId getTypeId() { return 0x77822DC5; }
20147 static constexpr const char* getType() { return "GeomStaticNURBS"; }
20148
20149 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
20150
20152 bool set_cvs(const ValueList& list, double time = TiMe::Default()) { return setValue("cvs", list, time); }
20153 bool set_cvs(ValueList&& list, double time = TiMe::Default()) { return setValue("cvs", std::move(list), time); }
20154 bool set_cvs(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("cvs", values, count, time); }
20155 template<size_t count> bool set_cvs(const Value (&values)[count], double time = TiMe::Default()) { return setArray("cvs", values, count, time); }
20156 template<size_t count> bool set_cvs(Value (&&values)[count], double time = TiMe::Default()) { return setArray("cvs", values, count, time); }
20158 ValueList get_cvs(double time = TiMe::Default()) const { return getValueList("cvs", time); }
20159
20161 bool set_weights(const ValueList& list, double time = TiMe::Default()) { return setValue("weights", list, time); }
20162 bool set_weights(ValueList&& list, double time = TiMe::Default()) { return setValue("weights", std::move(list), time); }
20163 bool set_weights(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("weights", values, count, time); }
20164 template<size_t count> bool set_weights(const Value (&values)[count], double time = TiMe::Default()) { return setArray("weights", values, count, time); }
20165 template<size_t count> bool set_weights(Value (&&values)[count], double time = TiMe::Default()) { return setArray("weights", values, count, time); }
20167 ValueList get_weights(double time = TiMe::Default()) const { return getValueList("weights", time); }
20168
20170 bool set_trims(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("trims", pluginList, time); }
20171 bool set_trims(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("trims", plugins, count, time); }
20172 template<size_t count> bool set_trims(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("trims", plugins, count, time); }
20174 PluginList get_trims(double time = TiMe::Default()) const { return getPluginList("trims", time); }
20175
20177 bool set_listTrimCurves(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("listTrimCurves", pluginList, time); }
20178 bool set_listTrimCurves(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("listTrimCurves", plugins, count, time); }
20179 template<size_t count> bool set_listTrimCurves(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("listTrimCurves", plugins, count, time); }
20181 PluginList get_listTrimCurves(double time = TiMe::Default()) const { return getPluginList("listTrimCurves", time); }
20182
20184 bool set_trimsComplex(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("trimsComplex", plugin, time); }
20186 PluginRef get_trimsComplex(double time = TiMe::Default()) const { return getPlugin("trimsComplex", time); }
20187
20190 bool set_uKnots(const FloatList& floatList, double time = TiMe::Default()) { return setValue("uKnots", floatList, time); }
20191 bool set_uKnots(FloatList&& floatList, double time = TiMe::Default()) { return setValue("uKnots", std::move(floatList), time); }
20192 bool set_uKnots(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("uKnots", floats, count, time); }
20193 template<size_t count> bool set_uKnots(const float (&floats)[count], double time = TiMe::Default()) { return setArray("uKnots", floats, count, time); }
20196 FloatList get_uKnots(double time = TiMe::Default()) const { return getFloatList("uKnots", time); }
20197
20200 bool set_vKnots(const FloatList& floatList, double time = TiMe::Default()) { return setValue("vKnots", floatList, time); }
20201 bool set_vKnots(FloatList&& floatList, double time = TiMe::Default()) { return setValue("vKnots", std::move(floatList), time); }
20202 bool set_vKnots(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("vKnots", floats, count, time); }
20203 template<size_t count> bool set_vKnots(const float (&floats)[count], double time = TiMe::Default()) { return setArray("vKnots", floats, count, time); }
20206 FloatList get_vKnots(double time = TiMe::Default()) const { return getFloatList("vKnots", time); }
20207
20210 bool set_maxSubdivDepth(int val, double time = TiMe::Default()) { return setValue("maxSubdivDepth", val, time); }
20213 int get_maxSubdivDepth(double time = TiMe::Default()) const { return getInt("maxSubdivDepth", time); }
20214
20217 bool set_flatnessCoef(float val, double time = TiMe::Default()) { return setValue("flatnessCoef", val, time); }
20220 float get_flatnessCoef(double time = TiMe::Default()) const { return getFloat("flatnessCoef", time); }
20221
20224 bool set_regularSubdiv(bool val, double time = TiMe::Default()) { return setValue("regularSubdiv", val, time); }
20227 bool get_regularSubdiv(double time = TiMe::Default()) const { return getBool("regularSubdiv", time); }
20228
20231 bool set_regularUSteps(int val, double time = TiMe::Default()) { return setValue("regularUSteps", val, time); }
20234 int get_regularUSteps(double time = TiMe::Default()) const { return getInt("regularUSteps", time); }
20235
20238 bool set_regularVSteps(int val, double time = TiMe::Default()) { return setValue("regularVSteps", val, time); }
20241 int get_regularVSteps(double time = TiMe::Default()) const { return getInt("regularVSteps", time); }
20242
20245 bool set_uDirectionType(int val, double time = TiMe::Default()) { return setValue("uDirectionType", val, time); }
20248 int get_uDirectionType(double time = TiMe::Default()) const { return getInt("uDirectionType", time); }
20249
20252 bool set_vDirectionType(int val, double time = TiMe::Default()) { return setValue("vDirectionType", val, time); }
20255 int get_vDirectionType(double time = TiMe::Default()) const { return getInt("vDirectionType", time); }
20256
20259 bool set_uDegree(int val, double time = TiMe::Default()) { return setValue("uDegree", val, time); }
20262 int get_uDegree(double time = TiMe::Default()) const { return getInt("uDegree", time); }
20263
20266 bool set_vDegree(int val, double time = TiMe::Default()) { return setValue("vDegree", val, time); }
20269 int get_vDegree(double time = TiMe::Default()) const { return getInt("vDegree", time); }
20270
20273 bool set_flipNormals(bool val, double time = TiMe::Default()) { return setValue("flipNormals", val, time); }
20276 bool get_flipNormals(double time = TiMe::Default()) const { return getBool("flipNormals", time); }
20277
20280 bool set_generateStatic(bool val, double time = TiMe::Default()) { return setValue("generateStatic", val, time); }
20283 bool get_generateStatic(double time = TiMe::Default()) const { return getBool("generateStatic", time); }
20284
20287 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
20290 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
20291
20293 bool set_reference_nurbs(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("reference_nurbs", plugin, time); }
20295 PluginRef get_reference_nurbs(double time = TiMe::Default()) const { return getPlugin("reference_nurbs", time); }
20296
20299 bool set_reference_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("reference_transform", transform, time); }
20302 Transform get_reference_transform(double time = TiMe::Default()) const { return getTransform("reference_transform", time); }
20303};
20304
20307public:
20309 static constexpr const PluginTypeId getTypeId() { return 0x7782FA11; }
20311 static constexpr const char* getType() { return "GeomStaticSmoothedMesh"; }
20312
20313 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
20314
20316 bool set_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("mesh", plugin, time); }
20318 PluginRef get_mesh(double time = TiMe::Default()) const { return getPlugin("mesh", time); }
20319
20321 bool set_displacement_tex_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displacement_tex_color", texture, time); }
20323 bool set_displacement_tex_color(const AColor& texture, double time = TiMe::Default()) { return setValue("displacement_tex_color", texture, time); }
20325 Value get_displacement_tex_color(double time = TiMe::Default()) const { return getValue("displacement_tex_color", time); }
20326
20328 bool set_displacement_tex_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("displacement_tex_float", texturefloat, time); }
20330 bool set_displacement_tex_float(float texturefloat, double time = TiMe::Default()) { return setValue("displacement_tex_float", texturefloat, time); }
20332 Value get_displacement_tex_float(double time = TiMe::Default()) const { return getValue("displacement_tex_float", time); }
20333
20336 bool set_displacement_amount(float val, double time = TiMe::Default()) { return setValue("displacement_amount", val, time); }
20339 float get_displacement_amount(double time = TiMe::Default()) const { return getFloat("displacement_amount", time); }
20340
20343 bool set_displacement_shift(float val, double time = TiMe::Default()) { return setValue("displacement_shift", val, time); }
20346 float get_displacement_shift(double time = TiMe::Default()) const { return getFloat("displacement_shift", time); }
20347
20350 bool set_keep_continuity(bool val, double time = TiMe::Default()) { return setValue("keep_continuity", val, time); }
20353 bool get_keep_continuity(double time = TiMe::Default()) const { return getBool("keep_continuity", time); }
20354
20357 bool set_water_level(float val, double time = TiMe::Default()) { return setValue("water_level", val, time); }
20360 float get_water_level(double time = TiMe::Default()) const { return getFloat("water_level", time); }
20361
20364 bool set_vector_displacement(int val, double time = TiMe::Default()) { return setValue("vector_displacement", val, time); }
20367 int get_vector_displacement(double time = TiMe::Default()) const { return getInt("vector_displacement", time); }
20368
20371 bool set_map_channel(int val, double time = TiMe::Default()) { return setValue("map_channel", val, time); }
20374 int get_map_channel(double time = TiMe::Default()) const { return getInt("map_channel", time); }
20375
20379 bool set_map_channel_name(const char* str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
20383 bool set_map_channel_name(const std::string& str, double time = TiMe::Default()) { return setValue("map_channel_name", str, time); }
20387 std::string get_map_channel_name(double time = TiMe::Default()) const { return getString("map_channel_name", time); }
20388
20391 bool set_image_width(int val, double time = TiMe::Default()) { return setValue("image_width", val, time); }
20394 int get_image_width(double time = TiMe::Default()) const { return getInt("image_width", time); }
20395
20398 bool set_cache_normals(bool val, double time = TiMe::Default()) { return setValue("cache_normals", val, time); }
20401 bool get_cache_normals(double time = TiMe::Default()) const { return getBool("cache_normals", time); }
20402
20405 bool set_object_space_displacement(bool val, double time = TiMe::Default()) { return setValue("object_space_displacement", val, time); }
20408 bool get_object_space_displacement(double time = TiMe::Default()) const { return getBool("object_space_displacement", time); }
20409
20413 bool set_static_subdiv(bool val, double time = TiMe::Default()) { return setValue("static_subdiv", val, time); }
20417 bool get_static_subdiv(double time = TiMe::Default()) const { return getBool("static_subdiv", time); }
20418
20422 bool set_use_globals(bool val, double time = TiMe::Default()) { return setValue("use_globals", val, time); }
20426 bool get_use_globals(double time = TiMe::Default()) const { return getBool("use_globals", time); }
20427
20431 bool set_view_dep(bool val, double time = TiMe::Default()) { return setValue("view_dep", val, time); }
20435 bool get_view_dep(double time = TiMe::Default()) const { return getBool("view_dep", time); }
20436
20440 bool set_edge_length(float val, double time = TiMe::Default()) { return setValue("edge_length", val, time); }
20444 float get_edge_length(double time = TiMe::Default()) const { return getFloat("edge_length", time); }
20445
20449 bool set_max_subdivs(int val, double time = TiMe::Default()) { return setValue("max_subdivs", val, time); }
20453 int get_max_subdivs(double time = TiMe::Default()) const { return getInt("max_subdivs", time); }
20454
20457 bool set_use_bounds(bool val, double time = TiMe::Default()) { return setValue("use_bounds", val, time); }
20460 bool get_use_bounds(double time = TiMe::Default()) const { return getBool("use_bounds", time); }
20461
20464 bool set_min_bound(const Color& color, double time = TiMe::Default()) { return setValue("min_bound", color, time); }
20467 Color get_min_bound(double time = TiMe::Default()) const { return getColor("min_bound", time); }
20468
20471 bool set_max_bound(const Color& color, double time = TiMe::Default()) { return setValue("max_bound", color, time); }
20474 Color get_max_bound(double time = TiMe::Default()) const { return getColor("max_bound", time); }
20475
20479 bool set_preserve_map_borders(int val, double time = TiMe::Default()) { return setValue("preserve_map_borders", val, time); }
20483 int get_preserve_map_borders(double time = TiMe::Default()) const { return getInt("preserve_map_borders", time); }
20484
20488 bool set_preserve_geometry_borders(bool val, double time = TiMe::Default()) { return setValue("preserve_geometry_borders", val, time); }
20492 bool get_preserve_geometry_borders(double time = TiMe::Default()) const { return getBool("preserve_geometry_borders", time); }
20493
20497 bool set_classic_catmark(bool val, double time = TiMe::Default()) { return setValue("classic_catmark", val, time); }
20501 bool get_classic_catmark(double time = TiMe::Default()) const { return getBool("classic_catmark", time); }
20502};
20503
20505class InfoRenderEngine : public Plugin {
20506public:
20508 static constexpr const PluginTypeId getTypeId() { return 0x7857A8F2; }
20510 static constexpr const char* getType() { return "InfoRenderEngine"; }
20511
20512 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
20513
20516 bool set_engine_type(const char* str, double time = TiMe::Default()) { return setValue("engine_type", str, time); }
20519 bool set_engine_type(const std::string& str, double time = TiMe::Default()) { return setValue("engine_type", str, time); }
20522 std::string get_engine_type(double time = TiMe::Default()) const { return getString("engine_type", time); }
20523
20526 bool set_version(const char* str, double time = TiMe::Default()) { return setValue("version", str, time); }
20529 bool set_version(const std::string& str, double time = TiMe::Default()) { return setValue("version", str, time); }
20532 std::string get_version(double time = TiMe::Default()) const { return getString("version", time); }
20533
20536 bool set_build(const char* str, double time = TiMe::Default()) { return setValue("build", str, time); }
20539 bool set_build(const std::string& str, double time = TiMe::Default()) { return setValue("build", str, time); }
20542 std::string get_build(double time = TiMe::Default()) const { return getString("build", time); }
20543
20546 bool set_build_number(const char* str, double time = TiMe::Default()) { return setValue("build_number", str, time); }
20549 bool set_build_number(const std::string& str, double time = TiMe::Default()) { return setValue("build_number", str, time); }
20552 std::string get_build_number(double time = TiMe::Default()) const { return getString("build_number", time); }
20553
20556 bool set_build_date(const char* str, double time = TiMe::Default()) { return setValue("build_date", str, time); }
20559 bool set_build_date(const std::string& str, double time = TiMe::Default()) { return setValue("build_date", str, time); }
20562 std::string get_build_date(double time = TiMe::Default()) const { return getString("build_date", time); }
20563
20566 bool set_exporter_version(const char* str, double time = TiMe::Default()) { return setValue("exporter_version", str, time); }
20569 bool set_exporter_version(const std::string& str, double time = TiMe::Default()) { return setValue("exporter_version", str, time); }
20572 std::string get_exporter_version(double time = TiMe::Default()) const { return getString("exporter_version", time); }
20573
20576 bool set_build_mod(const char* str, double time = TiMe::Default()) { return setValue("build_mod", str, time); }
20579 bool set_build_mod(const std::string& str, double time = TiMe::Default()) { return setValue("build_mod", str, time); }
20582 std::string get_build_mod(double time = TiMe::Default()) const { return getString("build_mod", time); }
20583
20586 bool set_host(const char* str, double time = TiMe::Default()) { return setValue("host", str, time); }
20589 bool set_host(const std::string& str, double time = TiMe::Default()) { return setValue("host", str, time); }
20592 std::string get_host(double time = TiMe::Default()) const { return getString("host", time); }
20593
20596 bool set_host_version(const char* str, double time = TiMe::Default()) { return setValue("host_version", str, time); }
20599 bool set_host_version(const std::string& str, double time = TiMe::Default()) { return setValue("host_version", str, time); }
20602 std::string get_host_version(double time = TiMe::Default()) const { return getString("host_version", time); }
20603};
20604
20606class Instancer : public Plugin {
20607public:
20609 static constexpr const PluginTypeId getTypeId() { return 0x77B0BDB2; }
20611 static constexpr const char* getType() { return "Instancer"; }
20612
20613 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
20614
20618 bool set_acceleration_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", colorList, time); }
20619 bool set_acceleration_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", std::move(colorList), time); }
20620 bool set_acceleration_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
20621 template<size_t count> bool set_acceleration_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
20625 ColorList get_acceleration_pp(double time = TiMe::Default()) const { return getColorList("acceleration_pp", time); }
20626
20630 bool set_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("colors", colorList, time); }
20631 bool set_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("colors", std::move(colorList), time); }
20632 bool set_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
20633 template<size_t count> bool set_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
20637 ColorList get_colors(double time = TiMe::Default()) const { return getColorList("colors", time); }
20638
20642 bool set_emission_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("emission_pp", colorList, time); }
20643 bool set_emission_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("emission_pp", std::move(colorList), time); }
20644 bool set_emission_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("emission_pp", colors, count, time); }
20645 template<size_t count> bool set_emission_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("emission_pp", colors, count, time); }
20649 ColorList get_emission_pp(double time = TiMe::Default()) const { return getColorList("emission_pp", time); }
20650
20654 bool set_user_color_pp_1(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_1", colorList, time); }
20655 bool set_user_color_pp_1(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_1", std::move(colorList), time); }
20656 bool set_user_color_pp_1(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_1", colors, count, time); }
20657 template<size_t count> bool set_user_color_pp_1(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_1", colors, count, time); }
20661 ColorList get_user_color_pp_1(double time = TiMe::Default()) const { return getColorList("user_color_pp_1", time); }
20662
20666 bool set_user_color_pp_2(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_2", colorList, time); }
20667 bool set_user_color_pp_2(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_2", std::move(colorList), time); }
20668 bool set_user_color_pp_2(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_2", colors, count, time); }
20669 template<size_t count> bool set_user_color_pp_2(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_2", colors, count, time); }
20673 ColorList get_user_color_pp_2(double time = TiMe::Default()) const { return getColorList("user_color_pp_2", time); }
20674
20678 bool set_user_color_pp_3(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_3", colorList, time); }
20679 bool set_user_color_pp_3(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_3", std::move(colorList), time); }
20680 bool set_user_color_pp_3(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_3", colors, count, time); }
20681 template<size_t count> bool set_user_color_pp_3(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_3", colors, count, time); }
20685 ColorList get_user_color_pp_3(double time = TiMe::Default()) const { return getColorList("user_color_pp_3", time); }
20686
20690 bool set_user_color_pp_4(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_4", colorList, time); }
20691 bool set_user_color_pp_4(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_4", std::move(colorList), time); }
20692 bool set_user_color_pp_4(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_4", colors, count, time); }
20693 template<size_t count> bool set_user_color_pp_4(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_4", colors, count, time); }
20697 ColorList get_user_color_pp_4(double time = TiMe::Default()) const { return getColorList("user_color_pp_4", time); }
20698
20702 bool set_user_color_pp_5(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_5", colorList, time); }
20703 bool set_user_color_pp_5(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_5", std::move(colorList), time); }
20704 bool set_user_color_pp_5(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_5", colors, count, time); }
20705 template<size_t count> bool set_user_color_pp_5(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_5", colors, count, time); }
20709 ColorList get_user_color_pp_5(double time = TiMe::Default()) const { return getColorList("user_color_pp_5", time); }
20710
20714 bool set_age_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("age_pp", floatList, time); }
20715 bool set_age_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("age_pp", std::move(floatList), time); }
20716 bool set_age_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
20717 template<size_t count> bool set_age_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
20721 FloatList get_age_pp(double time = TiMe::Default()) const { return getFloatList("age_pp", time); }
20722
20726 bool set_lifespan_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("lifespan_pp", floatList, time); }
20727 bool set_lifespan_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("lifespan_pp", std::move(floatList), time); }
20728 bool set_lifespan_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("lifespan_pp", floats, count, time); }
20729 template<size_t count> bool set_lifespan_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("lifespan_pp", floats, count, time); }
20733 FloatList get_lifespan_pp(double time = TiMe::Default()) const { return getFloatList("lifespan_pp", time); }
20734
20738 bool set_opacity_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("opacity_pp", floatList, time); }
20739 bool set_opacity_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("opacity_pp", std::move(floatList), time); }
20740 bool set_opacity_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("opacity_pp", floats, count, time); }
20741 template<size_t count> bool set_opacity_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("opacity_pp", floats, count, time); }
20745 FloatList get_opacity_pp(double time = TiMe::Default()) const { return getFloatList("opacity_pp", time); }
20746
20750 bool set_user_float_pp_1(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_1", floatList, time); }
20751 bool set_user_float_pp_1(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_1", std::move(floatList), time); }
20752 bool set_user_float_pp_1(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_1", floats, count, time); }
20753 template<size_t count> bool set_user_float_pp_1(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_1", floats, count, time); }
20757 FloatList get_user_float_pp_1(double time = TiMe::Default()) const { return getFloatList("user_float_pp_1", time); }
20758
20762 bool set_user_float_pp_2(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_2", floatList, time); }
20763 bool set_user_float_pp_2(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_2", std::move(floatList), time); }
20764 bool set_user_float_pp_2(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_2", floats, count, time); }
20765 template<size_t count> bool set_user_float_pp_2(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_2", floats, count, time); }
20769 FloatList get_user_float_pp_2(double time = TiMe::Default()) const { return getFloatList("user_float_pp_2", time); }
20770
20774 bool set_user_float_pp_3(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_3", floatList, time); }
20775 bool set_user_float_pp_3(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_3", std::move(floatList), time); }
20776 bool set_user_float_pp_3(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_3", floats, count, time); }
20777 template<size_t count> bool set_user_float_pp_3(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_3", floats, count, time); }
20781 FloatList get_user_float_pp_3(double time = TiMe::Default()) const { return getFloatList("user_float_pp_3", time); }
20782
20786 bool set_user_float_pp_4(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_4", floatList, time); }
20787 bool set_user_float_pp_4(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_4", std::move(floatList), time); }
20788 bool set_user_float_pp_4(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_4", floats, count, time); }
20789 template<size_t count> bool set_user_float_pp_4(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_4", floats, count, time); }
20793 FloatList get_user_float_pp_4(double time = TiMe::Default()) const { return getFloatList("user_float_pp_4", time); }
20794
20798 bool set_user_float_pp_5(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_5", floatList, time); }
20799 bool set_user_float_pp_5(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_5", std::move(floatList), time); }
20800 bool set_user_float_pp_5(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_5", floats, count, time); }
20801 template<size_t count> bool set_user_float_pp_5(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_5", floats, count, time); }
20805 FloatList get_user_float_pp_5(double time = TiMe::Default()) const { return getFloatList("user_float_pp_5", time); }
20806
20809 bool set_instances(const ValueList& list, double time = TiMe::Default()) { return setValue("instances", list, time); }
20810 bool set_instances(ValueList&& list, double time = TiMe::Default()) { return setValue("instances", std::move(list), time); }
20811 bool set_instances(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("instances", values, count, time); }
20812 template<size_t count> bool set_instances(const Value (&values)[count], double time = TiMe::Default()) { return setArray("instances", values, count, time); }
20813 template<size_t count> bool set_instances(Value (&&values)[count], double time = TiMe::Default()) { return setArray("instances", values, count, time); }
20816 ValueList get_instances(double time = TiMe::Default()) const { return getValueList("instances", time); }
20817
20819 bool set_instances_material_override(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("instances_material_override", plugin, time); }
20821 PluginRef get_instances_material_override(double time = TiMe::Default()) const { return getPlugin("instances_material_override", time); }
20822
20826 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
20830 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
20831
20835 bool set_visible(bool val, double time = TiMe::Default()) { return setValue("visible", val, time); }
20839 bool get_visible(double time = TiMe::Default()) const { return getBool("visible", time); }
20840
20844 bool set_shading_needs_ids(bool val, double time = TiMe::Default()) { return setValue("shading_needs_ids", val, time); }
20848 bool get_shading_needs_ids(double time = TiMe::Default()) const { return getBool("shading_needs_ids", time); }
20849
20853 bool set_use_additional_params(bool val, double time = TiMe::Default()) { return setValue("use_additional_params", val, time); }
20857 bool get_use_additional_params(double time = TiMe::Default()) const { return getBool("use_additional_params", time); }
20858
20862 bool set_use_visibility(bool val, double time = TiMe::Default()) { return setValue("use_visibility", val, time); }
20866 bool get_use_visibility(double time = TiMe::Default()) const { return getBool("use_visibility", time); }
20867
20871 bool set_use_direct_velocity(bool val, double time = TiMe::Default()) { return setValue("use_direct_velocity", val, time); }
20875 bool get_use_direct_velocity(double time = TiMe::Default()) const { return getBool("use_direct_velocity", time); }
20876
20880 bool set_render_ids_gen_mode(int val, double time = TiMe::Default()) { return setValue("render_ids_gen_mode", val, time); }
20884 int get_render_ids_gen_mode(double time = TiMe::Default()) const { return getInt("render_ids_gen_mode", time); }
20885
20888 bool set_extra_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("extra_channels", pluginList, time); }
20889 bool set_extra_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("extra_channels", plugins, count, time); }
20890 template<size_t count> bool set_extra_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("extra_channels", plugins, count, time); }
20893 PluginList get_extra_channels(double time = TiMe::Default()) const { return getPluginList("extra_channels", time); }
20894
20898 bool set_use_time_instancing(int val, double time = TiMe::Default()) { return setValue("use_time_instancing", val, time); }
20902 int get_use_time_instancing(double time = TiMe::Default()) const { return getInt("use_time_instancing", time); }
20903};
20904
20906class Instancer2 : public Plugin {
20907public:
20909 static constexpr const PluginTypeId getTypeId() { return 0x77EEFB79; }
20911 static constexpr const char* getType() { return "Instancer2"; }
20912
20913 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
20914
20918 bool set_acceleration_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", colorList, time); }
20919 bool set_acceleration_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("acceleration_pp", std::move(colorList), time); }
20920 bool set_acceleration_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
20921 template<size_t count> bool set_acceleration_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("acceleration_pp", colors, count, time); }
20925 ColorList get_acceleration_pp(double time = TiMe::Default()) const { return getColorList("acceleration_pp", time); }
20926
20930 bool set_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("colors", colorList, time); }
20931 bool set_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("colors", std::move(colorList), time); }
20932 bool set_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
20933 template<size_t count> bool set_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
20937 ColorList get_colors(double time = TiMe::Default()) const { return getColorList("colors", time); }
20938
20942 bool set_emission_pp(const ColorList& colorList, double time = TiMe::Default()) { return setValue("emission_pp", colorList, time); }
20943 bool set_emission_pp(ColorList&& colorList, double time = TiMe::Default()) { return setValue("emission_pp", std::move(colorList), time); }
20944 bool set_emission_pp(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("emission_pp", colors, count, time); }
20945 template<size_t count> bool set_emission_pp(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("emission_pp", colors, count, time); }
20949 ColorList get_emission_pp(double time = TiMe::Default()) const { return getColorList("emission_pp", time); }
20950
20954 bool set_user_color_pp_1(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_1", colorList, time); }
20955 bool set_user_color_pp_1(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_1", std::move(colorList), time); }
20956 bool set_user_color_pp_1(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_1", colors, count, time); }
20957 template<size_t count> bool set_user_color_pp_1(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_1", colors, count, time); }
20961 ColorList get_user_color_pp_1(double time = TiMe::Default()) const { return getColorList("user_color_pp_1", time); }
20962
20966 bool set_user_color_pp_2(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_2", colorList, time); }
20967 bool set_user_color_pp_2(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_2", std::move(colorList), time); }
20968 bool set_user_color_pp_2(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_2", colors, count, time); }
20969 template<size_t count> bool set_user_color_pp_2(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_2", colors, count, time); }
20973 ColorList get_user_color_pp_2(double time = TiMe::Default()) const { return getColorList("user_color_pp_2", time); }
20974
20978 bool set_user_color_pp_3(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_3", colorList, time); }
20979 bool set_user_color_pp_3(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_3", std::move(colorList), time); }
20980 bool set_user_color_pp_3(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_3", colors, count, time); }
20981 template<size_t count> bool set_user_color_pp_3(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_3", colors, count, time); }
20985 ColorList get_user_color_pp_3(double time = TiMe::Default()) const { return getColorList("user_color_pp_3", time); }
20986
20990 bool set_user_color_pp_4(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_4", colorList, time); }
20991 bool set_user_color_pp_4(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_4", std::move(colorList), time); }
20992 bool set_user_color_pp_4(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_4", colors, count, time); }
20993 template<size_t count> bool set_user_color_pp_4(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_4", colors, count, time); }
20997 ColorList get_user_color_pp_4(double time = TiMe::Default()) const { return getColorList("user_color_pp_4", time); }
20998
21002 bool set_user_color_pp_5(const ColorList& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_5", colorList, time); }
21003 bool set_user_color_pp_5(ColorList&& colorList, double time = TiMe::Default()) { return setValue("user_color_pp_5", std::move(colorList), time); }
21004 bool set_user_color_pp_5(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("user_color_pp_5", colors, count, time); }
21005 template<size_t count> bool set_user_color_pp_5(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("user_color_pp_5", colors, count, time); }
21009 ColorList get_user_color_pp_5(double time = TiMe::Default()) const { return getColorList("user_color_pp_5", time); }
21010
21014 bool set_age_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("age_pp", floatList, time); }
21015 bool set_age_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("age_pp", std::move(floatList), time); }
21016 bool set_age_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
21017 template<size_t count> bool set_age_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("age_pp", floats, count, time); }
21021 FloatList get_age_pp(double time = TiMe::Default()) const { return getFloatList("age_pp", time); }
21022
21026 bool set_lifespan_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("lifespan_pp", floatList, time); }
21027 bool set_lifespan_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("lifespan_pp", std::move(floatList), time); }
21028 bool set_lifespan_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("lifespan_pp", floats, count, time); }
21029 template<size_t count> bool set_lifespan_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("lifespan_pp", floats, count, time); }
21033 FloatList get_lifespan_pp(double time = TiMe::Default()) const { return getFloatList("lifespan_pp", time); }
21034
21038 bool set_opacity_pp(const FloatList& floatList, double time = TiMe::Default()) { return setValue("opacity_pp", floatList, time); }
21039 bool set_opacity_pp(FloatList&& floatList, double time = TiMe::Default()) { return setValue("opacity_pp", std::move(floatList), time); }
21040 bool set_opacity_pp(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("opacity_pp", floats, count, time); }
21041 template<size_t count> bool set_opacity_pp(const float (&floats)[count], double time = TiMe::Default()) { return setArray("opacity_pp", floats, count, time); }
21045 FloatList get_opacity_pp(double time = TiMe::Default()) const { return getFloatList("opacity_pp", time); }
21046
21050 bool set_user_float_pp_1(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_1", floatList, time); }
21051 bool set_user_float_pp_1(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_1", std::move(floatList), time); }
21052 bool set_user_float_pp_1(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_1", floats, count, time); }
21053 template<size_t count> bool set_user_float_pp_1(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_1", floats, count, time); }
21057 FloatList get_user_float_pp_1(double time = TiMe::Default()) const { return getFloatList("user_float_pp_1", time); }
21058
21062 bool set_user_float_pp_2(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_2", floatList, time); }
21063 bool set_user_float_pp_2(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_2", std::move(floatList), time); }
21064 bool set_user_float_pp_2(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_2", floats, count, time); }
21065 template<size_t count> bool set_user_float_pp_2(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_2", floats, count, time); }
21069 FloatList get_user_float_pp_2(double time = TiMe::Default()) const { return getFloatList("user_float_pp_2", time); }
21070
21074 bool set_user_float_pp_3(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_3", floatList, time); }
21075 bool set_user_float_pp_3(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_3", std::move(floatList), time); }
21076 bool set_user_float_pp_3(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_3", floats, count, time); }
21077 template<size_t count> bool set_user_float_pp_3(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_3", floats, count, time); }
21081 FloatList get_user_float_pp_3(double time = TiMe::Default()) const { return getFloatList("user_float_pp_3", time); }
21082
21086 bool set_user_float_pp_4(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_4", floatList, time); }
21087 bool set_user_float_pp_4(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_4", std::move(floatList), time); }
21088 bool set_user_float_pp_4(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_4", floats, count, time); }
21089 template<size_t count> bool set_user_float_pp_4(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_4", floats, count, time); }
21093 FloatList get_user_float_pp_4(double time = TiMe::Default()) const { return getFloatList("user_float_pp_4", time); }
21094
21098 bool set_user_float_pp_5(const FloatList& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_5", floatList, time); }
21099 bool set_user_float_pp_5(FloatList&& floatList, double time = TiMe::Default()) { return setValue("user_float_pp_5", std::move(floatList), time); }
21100 bool set_user_float_pp_5(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("user_float_pp_5", floats, count, time); }
21101 template<size_t count> bool set_user_float_pp_5(const float (&floats)[count], double time = TiMe::Default()) { return setArray("user_float_pp_5", floats, count, time); }
21105 FloatList get_user_float_pp_5(double time = TiMe::Default()) const { return getFloatList("user_float_pp_5", time); }
21106
21109 bool set_instances(const ValueList& list, double time = TiMe::Default()) { return setValue("instances", list, time); }
21110 bool set_instances(ValueList&& list, double time = TiMe::Default()) { return setValue("instances", std::move(list), time); }
21111 bool set_instances(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("instances", values, count, time); }
21112 template<size_t count> bool set_instances(const Value (&values)[count], double time = TiMe::Default()) { return setArray("instances", values, count, time); }
21113 template<size_t count> bool set_instances(Value (&&values)[count], double time = TiMe::Default()) { return setArray("instances", values, count, time); }
21116 ValueList get_instances(double time = TiMe::Default()) const { return getValueList("instances", time); }
21117
21119 bool set_instances_material_override(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("instances_material_override", plugin, time); }
21121 PluginRef get_instances_material_override(double time = TiMe::Default()) const { return getPlugin("instances_material_override", time); }
21122
21126 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
21130 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
21131
21135 bool set_visible(bool val, double time = TiMe::Default()) { return setValue("visible", val, time); }
21139 bool get_visible(double time = TiMe::Default()) const { return getBool("visible", time); }
21140
21144 bool set_shading_needs_ids(bool val, double time = TiMe::Default()) { return setValue("shading_needs_ids", val, time); }
21148 bool get_shading_needs_ids(double time = TiMe::Default()) const { return getBool("shading_needs_ids", time); }
21149
21153 bool set_use_additional_params(bool val, double time = TiMe::Default()) { return setValue("use_additional_params", val, time); }
21157 bool get_use_additional_params(double time = TiMe::Default()) const { return getBool("use_additional_params", time); }
21158
21162 bool set_use_visibility(bool val, double time = TiMe::Default()) { return setValue("use_visibility", val, time); }
21166 bool get_use_visibility(double time = TiMe::Default()) const { return getBool("use_visibility", time); }
21167
21171 bool set_use_direct_velocity(bool val, double time = TiMe::Default()) { return setValue("use_direct_velocity", val, time); }
21175 bool get_use_direct_velocity(double time = TiMe::Default()) const { return getBool("use_direct_velocity", time); }
21176
21180 bool set_render_ids_gen_mode(int val, double time = TiMe::Default()) { return setValue("render_ids_gen_mode", val, time); }
21184 int get_render_ids_gen_mode(double time = TiMe::Default()) const { return getInt("render_ids_gen_mode", time); }
21185
21188 bool set_extra_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("extra_channels", pluginList, time); }
21189 bool set_extra_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("extra_channels", plugins, count, time); }
21190 template<size_t count> bool set_extra_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("extra_channels", plugins, count, time); }
21193 PluginList get_extra_channels(double time = TiMe::Default()) const { return getPluginList("extra_channels", time); }
21194
21198 bool set_use_time_instancing(int val, double time = TiMe::Default()) { return setValue("use_time_instancing", val, time); }
21202 int get_use_time_instancing(double time = TiMe::Default()) const { return getInt("use_time_instancing", time); }
21203};
21204
21206class LightAmbient : public Plugin {
21207public:
21209 static constexpr const PluginTypeId getTypeId() { return 0x77827D84; }
21211 static constexpr const char* getType() { return "LightAmbient"; }
21212
21213 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
21214
21218 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
21222 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
21223
21227 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
21231 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
21232
21235 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
21238 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
21239
21243 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
21247 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
21248
21251 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
21254 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
21257 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
21258
21262 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
21266 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
21267
21271 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
21275 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
21276
21280 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
21284 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
21285
21289 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
21293 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
21294
21298 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
21302 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
21303
21307 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
21311 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
21312
21316 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
21320 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
21321
21325 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
21329 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
21330
21334 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
21338 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
21339
21343 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
21347 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
21348
21352 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
21356 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
21357
21361 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
21365 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
21366
21369 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
21372 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
21375 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
21376
21380 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
21384 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
21385
21389 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
21393 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
21394
21398 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
21402 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
21403
21407 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
21411 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
21412
21416 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
21420 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
21421
21425 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
21429 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
21430
21434 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
21438 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
21439
21442 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
21443 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
21444 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
21447 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
21448
21451 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
21452 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
21453 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
21456 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
21457
21460 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
21461 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
21462 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
21465 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
21466
21469 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
21470 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
21471 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
21474 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
21475
21478 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
21479 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
21480 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
21483 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
21484
21488 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
21492 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
21496 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
21497
21501 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
21505 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
21506
21510 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
21514 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
21515
21519 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
21523 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
21524
21528 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
21532 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
21533
21537 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
21541 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
21542
21546 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
21550 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
21551
21555 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
21559 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
21560
21564 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
21568 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
21569
21572 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
21575 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
21578 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
21579
21583 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
21587 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
21588
21592 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
21596 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
21597
21600 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
21603 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
21606 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
21607
21611 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
21615 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
21616
21620 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
21624 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
21625
21629 bool set_decay(float val, double time = TiMe::Default()) { return setValue("decay", val, time); }
21633 float get_decay(double time = TiMe::Default()) const { return getFloat("decay", time); }
21634
21638 bool set_ambient_shade(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("ambient_shade", texturefloat, time); }
21642 bool set_ambient_shade(float texturefloat, double time = TiMe::Default()) { return setValue("ambient_shade", texturefloat, time); }
21646 Value get_ambient_shade(double time = TiMe::Default()) const { return getValue("ambient_shade", time); }
21647};
21648
21650class LightAmbientMax : public Plugin {
21651public:
21653 static constexpr const PluginTypeId getTypeId() { return 0x77CEF0F1; }
21655 static constexpr const char* getType() { return "LightAmbientMax"; }
21656
21657 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
21658
21661 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
21664 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
21665
21669 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
21673 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
21674
21677 bool set_gi_min_distance(float val, double time = TiMe::Default()) { return setValue("gi_min_distance", val, time); }
21680 float get_gi_min_distance(double time = TiMe::Default()) const { return getFloat("gi_min_distance", time); }
21681
21684 bool set_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
21687 bool set_color(const AColor& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
21690 Value get_color(double time = TiMe::Default()) const { return getValue("color", time); }
21691
21694 bool set_compensate_exposure(bool val, double time = TiMe::Default()) { return setValue("compensate_exposure", val, time); }
21697 bool get_compensate_exposure(double time = TiMe::Default()) const { return getBool("compensate_exposure", time); }
21698
21701 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
21702 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
21703 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
21706 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
21707
21710 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
21711 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
21712 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
21715 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
21716
21719 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
21720 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
21721 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
21724 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
21725
21728 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
21729 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
21730 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
21733 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
21734
21737 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
21738 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
21739 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
21742 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
21743};
21744
21746class LightDirect : public Plugin {
21747public:
21749 static constexpr const PluginTypeId getTypeId() { return 0x77742BD4; }
21751 static constexpr const char* getType() { return "LightDirect"; }
21752
21753 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
21754
21758 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
21762 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
21763
21767 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
21771 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
21772
21775 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
21778 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
21779
21783 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
21787 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
21788
21791 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
21794 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
21797 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
21798
21802 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
21806 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
21807
21811 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
21815 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
21816
21820 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
21824 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
21825
21829 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
21833 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
21834
21838 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
21842 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
21843
21847 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
21851 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
21852
21856 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
21860 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
21861
21865 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
21869 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
21870
21874 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
21878 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
21879
21883 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
21887 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
21888
21892 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
21896 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
21897
21901 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
21905 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
21906
21909 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
21912 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
21915 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
21916
21920 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
21924 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
21925
21929 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
21933 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
21934
21938 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
21942 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
21943
21947 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
21951 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
21952
21956 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
21960 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
21961
21965 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
21969 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
21970
21974 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
21978 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
21979
21982 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
21983 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
21984 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
21987 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
21988
21991 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
21992 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
21993 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
21996 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
21997
22000 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
22001 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
22002 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
22005 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
22006
22009 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
22010 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
22011 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
22014 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
22015
22018 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
22019 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
22020 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
22023 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
22024
22028 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
22032 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
22036 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
22037
22041 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
22045 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
22046
22050 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
22054 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
22055
22058 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
22061 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
22064 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
22065
22069 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
22073 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
22074
22078 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
22082 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
22083
22087 bool set_beamRadius(float val, double time = TiMe::Default()) { return setValue("beamRadius", val, time); }
22091 float get_beamRadius(double time = TiMe::Default()) const { return getFloat("beamRadius", time); }
22092
22096 bool set_spreadAngle(float val, double time = TiMe::Default()) { return setValue("spreadAngle", val, time); }
22100 float get_spreadAngle(double time = TiMe::Default()) const { return getFloat("spreadAngle", time); }
22101};
22102
22104class LightDirectMax : public Plugin {
22105public:
22107 static constexpr const PluginTypeId getTypeId() { return 0x77BF65A7; }
22109 static constexpr const char* getType() { return "LightDirectMax"; }
22110
22111 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
22112
22113 operator UVWGenPluginCategory() { return *static_cast<UVWGenPluginCategory*>(static_cast<Plugin*>(this)); }
22114
22118 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
22122 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
22123
22127 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
22131 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
22132
22135 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
22138 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
22139
22143 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
22147 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
22148
22151 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
22154 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
22157 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
22158
22162 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
22166 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
22167
22171 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
22175 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
22176
22180 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
22184 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
22185
22189 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
22193 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
22194
22198 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
22202 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
22203
22207 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
22211 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
22212
22216 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
22220 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
22221
22225 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
22229 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
22230
22234 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
22238 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
22239
22243 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
22247 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
22248
22252 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
22256 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
22257
22261 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
22265 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
22266
22269 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
22272 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
22275 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
22276
22280 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
22284 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
22285
22289 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
22293 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
22294
22298 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
22302 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
22303
22307 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
22311 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
22312
22316 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
22320 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
22321
22325 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
22329 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
22330
22334 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
22338 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
22339
22342 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
22343 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
22344 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
22347 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
22348
22351 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
22352 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
22353 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
22356 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
22357
22360 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
22361 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
22362 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
22365 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
22366
22369 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
22370 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
22371 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
22374 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
22375
22378 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
22379 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
22380 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
22383 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
22384
22388 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
22392 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
22396 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
22397
22401 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
22405 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
22406
22410 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
22414 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
22415
22418 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
22421 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
22424 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
22425
22429 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
22433 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
22434
22438 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
22442 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
22443
22446 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
22449 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
22452 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
22453
22457 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
22461 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
22462
22466 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
22470 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
22471
22474 bool set_projector_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("projector_map", texture, time); }
22477 bool set_projector_map(const AColor& texture, double time = TiMe::Default()) { return setValue("projector_map", texture, time); }
22480 Value get_projector_map(double time = TiMe::Default()) const { return getValue("projector_map", time); }
22481
22485 bool set_decay_type(int val, double time = TiMe::Default()) { return setValue("decay_type", val, time); }
22489 int get_decay_type(double time = TiMe::Default()) const { return getInt("decay_type", time); }
22490
22494 bool set_decay_start(float val, double time = TiMe::Default()) { return setValue("decay_start", val, time); }
22498 float get_decay_start(double time = TiMe::Default()) const { return getFloat("decay_start", time); }
22499
22503 bool set_near_attenuation(bool val, double time = TiMe::Default()) { return setValue("near_attenuation", val, time); }
22507 bool get_near_attenuation(double time = TiMe::Default()) const { return getBool("near_attenuation", time); }
22508
22512 bool set_near_attenuation_start(float val, double time = TiMe::Default()) { return setValue("near_attenuation_start", val, time); }
22516 float get_near_attenuation_start(double time = TiMe::Default()) const { return getFloat("near_attenuation_start", time); }
22517
22521 bool set_near_attenuation_end(float val, double time = TiMe::Default()) { return setValue("near_attenuation_end", val, time); }
22525 float get_near_attenuation_end(double time = TiMe::Default()) const { return getFloat("near_attenuation_end", time); }
22526
22530 bool set_far_attenuation(bool val, double time = TiMe::Default()) { return setValue("far_attenuation", val, time); }
22534 bool get_far_attenuation(double time = TiMe::Default()) const { return getBool("far_attenuation", time); }
22535
22539 bool set_far_attenuation_start(float val, double time = TiMe::Default()) { return setValue("far_attenuation_start", val, time); }
22543 float get_far_attenuation_start(double time = TiMe::Default()) const { return getFloat("far_attenuation_start", time); }
22544
22548 bool set_far_attenuation_end(float val, double time = TiMe::Default()) { return setValue("far_attenuation_end", val, time); }
22552 float get_far_attenuation_end(double time = TiMe::Default()) const { return getFloat("far_attenuation_end", time); }
22553
22557 bool set_shadowShape(int val, double time = TiMe::Default()) { return setValue("shadowShape", val, time); }
22561 int get_shadowShape(double time = TiMe::Default()) const { return getInt("shadowShape", time); }
22562
22566 bool set_shadowRadius1(float val, double time = TiMe::Default()) { return setValue("shadowRadius1", val, time); }
22570 float get_shadowRadius1(double time = TiMe::Default()) const { return getFloat("shadowRadius1", time); }
22571
22575 bool set_shadowRadius2(float val, double time = TiMe::Default()) { return setValue("shadowRadius2", val, time); }
22579 float get_shadowRadius2(double time = TiMe::Default()) const { return getFloat("shadowRadius2", time); }
22580
22584 bool set_overshoot(bool val, double time = TiMe::Default()) { return setValue("overshoot", val, time); }
22588 bool get_overshoot(double time = TiMe::Default()) const { return getBool("overshoot", time); }
22589
22593 bool set_hotspot(float val, double time = TiMe::Default()) { return setValue("hotspot", val, time); }
22597 float get_hotspot(double time = TiMe::Default()) const { return getFloat("hotspot", time); }
22598
22602 bool set_fallsize(float val, double time = TiMe::Default()) { return setValue("fallsize", val, time); }
22606 float get_fallsize(double time = TiMe::Default()) const { return getFloat("fallsize", time); }
22607
22611 bool set_shape_type(int val, double time = TiMe::Default()) { return setValue("shape_type", val, time); }
22615 int get_shape_type(double time = TiMe::Default()) const { return getInt("shape_type", time); }
22616
22620 bool set_rect_aspect(float val, double time = TiMe::Default()) { return setValue("rect_aspect", val, time); }
22624 float get_rect_aspect(double time = TiMe::Default()) const { return getFloat("rect_aspect", time); }
22625};
22626
22628class LightDirectModo : public Plugin {
22629public:
22631 static constexpr const PluginTypeId getTypeId() { return 0x77FDA8B4; }
22633 static constexpr const char* getType() { return "LightDirectModo"; }
22634
22635 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
22636
22640 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
22644 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
22645
22649 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
22653 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
22654
22657 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
22660 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
22661
22665 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
22669 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
22670
22673 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
22676 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
22679 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
22680
22684 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
22688 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
22689
22693 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
22697 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
22698
22702 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
22706 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
22707
22711 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
22715 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
22716
22720 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
22724 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
22725
22729 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
22733 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
22734
22738 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
22742 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
22743
22747 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
22751 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
22752
22756 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
22760 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
22761
22765 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
22769 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
22770
22774 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
22778 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
22779
22783 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
22787 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
22788
22791 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
22794 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
22797 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
22798
22802 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
22806 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
22807
22811 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
22815 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
22816
22820 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
22824 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
22825
22829 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
22833 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
22834
22838 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
22842 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
22843
22847 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
22851 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
22852
22856 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
22860 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
22861
22864 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
22865 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
22866 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
22869 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
22870
22873 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
22874 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
22875 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
22878 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
22879
22882 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
22883 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
22884 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
22887 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
22888
22891 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
22892 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
22893 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
22896 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
22897
22900 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
22901 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
22902 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
22905 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
22906
22910 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
22914 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
22918 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
22919
22923 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
22927 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
22928
22932 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
22936 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
22937
22940 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
22943 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
22946 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
22947
22951 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
22955 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
22956
22960 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
22964 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
22965
22969 bool set_beamRadius(float val, double time = TiMe::Default()) { return setValue("beamRadius", val, time); }
22973 float get_beamRadius(double time = TiMe::Default()) const { return getFloat("beamRadius", time); }
22974
22978 bool set_spreadAngle(float val, double time = TiMe::Default()) { return setValue("spreadAngle", val, time); }
22982 float get_spreadAngle(double time = TiMe::Default()) const { return getFloat("spreadAngle", time); }
22983};
22984
22986class LightDome : public Plugin {
22987public:
22989 static constexpr const PluginTypeId getTypeId() { return 0x77928C00; }
22991 static constexpr const char* getType() { return "LightDome"; }
22992
22993 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
22994
22995 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
22996
23000 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
23004 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
23005
23009 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
23013 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
23014
23017 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
23020 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
23021
23025 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
23029 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
23030
23033 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
23036 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
23039 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
23040
23044 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
23048 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
23049
23053 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
23057 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
23058
23062 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
23066 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
23067
23071 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
23075 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
23076
23080 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
23084 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
23085
23089 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
23093 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
23094
23098 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
23102 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
23103
23107 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
23111 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
23112
23116 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
23120 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
23121
23125 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
23129 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
23130
23134 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
23138 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
23139
23143 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
23147 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
23148
23151 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
23154 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
23157 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
23158
23162 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
23166 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
23167
23171 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
23175 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
23176
23180 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
23184 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
23185
23189 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
23193 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
23194
23198 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
23202 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
23203
23207 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
23211 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
23212
23216 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
23220 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
23221
23224 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
23225 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
23226 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
23229 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
23230
23233 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
23234 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
23235 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
23238 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
23239
23242 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
23243 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
23244 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
23247 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
23248
23251 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
23252 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
23253 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
23256 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
23257
23260 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
23261 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
23262 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
23265 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
23266
23270 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
23274 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
23278 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
23279
23283 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
23287 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
23288
23292 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
23296 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
23297
23300 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
23303 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
23306 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
23307
23311 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
23315 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
23316
23320 bool set_invisible(bool val, double time = TiMe::Default()) { return setValue("invisible", val, time); }
23324 bool get_invisible(double time = TiMe::Default()) const { return getBool("invisible", time); }
23325
23329 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
23333 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
23334
23338 bool set_affectReflections(bool val, double time = TiMe::Default()) { return setValue("affectReflections", val, time); }
23342 bool get_affectReflections(double time = TiMe::Default()) const { return getBool("affectReflections", time); }
23343
23347 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
23351 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
23352
23356 bool set_useMIS(bool val, double time = TiMe::Default()) { return setValue("useMIS", val, time); }
23360 bool get_useMIS(double time = TiMe::Default()) const { return getBool("useMIS", time); }
23361
23365 bool set_dome_spherical(bool val, double time = TiMe::Default()) { return setValue("dome_spherical", val, time); }
23369 bool get_dome_spherical(double time = TiMe::Default()) const { return getBool("dome_spherical", time); }
23370
23374 bool set_use_dome_tex(bool val, double time = TiMe::Default()) { return setValue("use_dome_tex", val, time); }
23378 bool get_use_dome_tex(double time = TiMe::Default()) const { return getBool("use_dome_tex", time); }
23379
23382 bool set_dome_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dome_tex", texture, time); }
23385 bool set_dome_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("dome_tex", texture, time); }
23388 Value get_dome_tex(double time = TiMe::Default()) const { return getValue("dome_tex", time); }
23389
23393 bool set_tex_resolution(int val, double time = TiMe::Default()) { return setValue("tex_resolution", val, time); }
23397 int get_tex_resolution(double time = TiMe::Default()) const { return getInt("tex_resolution", time); }
23398
23402 bool set_tex_adaptive(float val, double time = TiMe::Default()) { return setValue("tex_adaptive", val, time); }
23406 float get_tex_adaptive(double time = TiMe::Default()) const { return getFloat("tex_adaptive", time); }
23407
23411 bool set_dome_targetRadius(float val, double time = TiMe::Default()) { return setValue("dome_targetRadius", val, time); }
23415 float get_dome_targetRadius(double time = TiMe::Default()) const { return getFloat("dome_targetRadius", time); }
23416
23420 bool set_dome_emitRadius(float val, double time = TiMe::Default()) { return setValue("dome_emitRadius", val, time); }
23424 float get_dome_emitRadius(double time = TiMe::Default()) const { return getFloat("dome_emitRadius", time); }
23425
23429 bool set_affect_alpha(bool val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
23433 bool get_affect_alpha(double time = TiMe::Default()) const { return getBool("affect_alpha", time); }
23434
23438 bool set_dome_rayDistanceMode(int val, double time = TiMe::Default()) { return setValue("dome_rayDistanceMode", val, time); }
23442 int get_dome_rayDistanceMode(double time = TiMe::Default()) const { return getInt("dome_rayDistanceMode", time); }
23443
23447 bool set_dome_rayDistance(float val, double time = TiMe::Default()) { return setValue("dome_rayDistance", val, time); }
23451 float get_dome_rayDistance(double time = TiMe::Default()) const { return getFloat("dome_rayDistance", time); }
23452
23456 bool set_dome_adaptive(bool val, double time = TiMe::Default()) { return setValue("dome_adaptive", val, time); }
23460 bool get_dome_adaptive(double time = TiMe::Default()) const { return getBool("dome_adaptive", time); }
23461
23465 bool set_dome_grid_res(int val, double time = TiMe::Default()) { return setValue("dome_grid_res", val, time); }
23469 int get_dome_grid_res(double time = TiMe::Default()) const { return getInt("dome_grid_res", time); }
23470
23474 bool set_dome_u_tiles(int val, double time = TiMe::Default()) { return setValue("dome_u_tiles", val, time); }
23478 int get_dome_u_tiles(double time = TiMe::Default()) const { return getInt("dome_u_tiles", time); }
23479
23483 bool set_dome_finite_on(int val, double time = TiMe::Default()) { return setValue("dome_finite_on", val, time); }
23487 int get_dome_finite_on(double time = TiMe::Default()) const { return getInt("dome_finite_on", time); }
23488
23492 bool set_finite_radius(float val, double time = TiMe::Default()) { return setValue("finite_radius", val, time); }
23496 float get_finite_radius(double time = TiMe::Default()) const { return getFloat("finite_radius", time); }
23497
23501 bool set_finite_cameraHeight(float val, double time = TiMe::Default()) { return setValue("finite_cameraHeight", val, time); }
23505 float get_finite_cameraHeight(double time = TiMe::Default()) const { return getFloat("finite_cameraHeight", time); }
23506
23510 bool set_finite_groundBlend(float val, double time = TiMe::Default()) { return setValue("finite_groundBlend", val, time); }
23514 float get_finite_groundBlend(double time = TiMe::Default()) const { return getFloat("finite_groundBlend", time); }
23515};
23516
23518class LightIES : public Plugin {
23519public:
23521 static constexpr const PluginTypeId getTypeId() { return 0x77A101F5; }
23523 static constexpr const char* getType() { return "LightIES"; }
23524
23525 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
23526
23530 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
23534 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
23535
23539 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
23543 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
23544
23547 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
23550 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
23551
23555 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
23559 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
23560
23563 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
23566 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
23569 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
23570
23574 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
23578 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
23579
23583 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
23587 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
23588
23592 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
23596 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
23597
23601 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
23605 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
23606
23610 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
23614 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
23615
23619 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
23623 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
23624
23628 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
23632 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
23633
23637 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
23641 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
23642
23646 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
23650 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
23651
23655 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
23659 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
23660
23664 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
23668 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
23669
23673 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
23677 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
23678
23681 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
23684 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
23687 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
23688
23692 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
23696 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
23697
23701 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
23705 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
23706
23710 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
23714 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
23715
23719 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
23723 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
23724
23728 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
23732 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
23733
23737 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
23741 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
23742
23746 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
23750 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
23751
23754 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
23755 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
23756 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
23759 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
23760
23763 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
23764 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
23765 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
23768 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
23769
23772 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
23773 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
23774 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
23777 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
23778
23781 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
23782 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
23783 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
23786 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
23787
23790 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
23791 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
23792 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
23795 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
23796
23800 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
23804 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
23808 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
23809
23813 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
23817 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
23818
23822 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
23826 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
23827
23831 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
23835 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
23836
23840 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
23844 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
23845
23849 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
23853 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
23854
23858 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
23862 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
23863
23867 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
23871 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
23872
23876 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
23880 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
23881
23885 bool set_ies_file(const char* str, double time = TiMe::Default()) { return setValue("ies_file", str, time); }
23889 bool set_ies_file(const std::string& str, double time = TiMe::Default()) { return setValue("ies_file", str, time); }
23893 std::string get_ies_file(double time = TiMe::Default()) const { return getString("ies_file", time); }
23894
23898 bool set_filter_color(const Color& color, double time = TiMe::Default()) { return setValue("filter_color", color, time); }
23902 Color get_filter_color(double time = TiMe::Default()) const { return getColor("filter_color", time); }
23903
23907 bool set_power(float val, double time = TiMe::Default()) { return setValue("power", val, time); }
23911 float get_power(double time = TiMe::Default()) const { return getFloat("power", time); }
23912
23916 bool set_override_prescribed_power(bool val, double time = TiMe::Default()) { return setValue("override_prescribed_power", val, time); }
23920 bool get_override_prescribed_power(double time = TiMe::Default()) const { return getBool("override_prescribed_power", time); }
23921
23925 bool set_area_speculars(bool val, double time = TiMe::Default()) { return setValue("area_speculars", val, time); }
23929 bool get_area_speculars(double time = TiMe::Default()) const { return getBool("area_speculars", time); }
23930
23934 bool set_soft_shadows(int val, double time = TiMe::Default()) { return setValue("soft_shadows", val, time); }
23938 int get_soft_shadows(double time = TiMe::Default()) const { return getInt("soft_shadows", time); }
23939
23943 bool set_ies_light_shape(int val, double time = TiMe::Default()) { return setValue("ies_light_shape", val, time); }
23947 int get_ies_light_shape(double time = TiMe::Default()) const { return getInt("ies_light_shape", time); }
23948
23952 bool set_ies_light_width(float val, double time = TiMe::Default()) { return setValue("ies_light_width", val, time); }
23956 float get_ies_light_width(double time = TiMe::Default()) const { return getFloat("ies_light_width", time); }
23957
23961 bool set_ies_light_length(float val, double time = TiMe::Default()) { return setValue("ies_light_length", val, time); }
23965 float get_ies_light_length(double time = TiMe::Default()) const { return getFloat("ies_light_length", time); }
23966
23970 bool set_ies_light_height(float val, double time = TiMe::Default()) { return setValue("ies_light_height", val, time); }
23974 float get_ies_light_height(double time = TiMe::Default()) const { return getFloat("ies_light_height", time); }
23975
23979 bool set_ies_light_diameter(float val, double time = TiMe::Default()) { return setValue("ies_light_diameter", val, time); }
23983 float get_ies_light_diameter(double time = TiMe::Default()) const { return getFloat("ies_light_diameter", time); }
23984
23988 bool set_rescale_max_intensty(bool val, double time = TiMe::Default()) { return setValue("rescale_max_intensty", val, time); }
23992 bool get_rescale_max_intensty(double time = TiMe::Default()) const { return getBool("rescale_max_intensty", time); }
23993
23997 bool set_new_max_intensity(float val, double time = TiMe::Default()) { return setValue("new_max_intensity", val, time); }
24001 float get_new_max_intensity(double time = TiMe::Default()) const { return getFloat("new_max_intensity", time); }
24002};
24003
24006class LightIESMax : public Plugin {
24007public:
24009 static constexpr const PluginTypeId getTypeId() { return 0x77BFB429; }
24011 static constexpr const char* getType() { return "LightIESMax"; }
24012
24013 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
24014
24018 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
24022 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
24023
24027 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
24031 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
24032
24035 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
24038 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
24039
24043 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
24047 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
24048
24051 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
24054 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
24057 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
24058
24062 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
24066 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
24067
24071 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
24075 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
24076
24080 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
24084 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
24085
24089 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
24093 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
24094
24098 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
24102 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
24103
24107 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
24111 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
24112
24116 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
24120 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
24121
24125 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
24129 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
24130
24134 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
24138 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
24139
24143 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
24147 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
24148
24152 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
24156 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
24157
24161 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
24165 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
24166
24169 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
24172 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
24175 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
24176
24180 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
24184 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
24185
24189 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
24193 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
24194
24198 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
24202 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
24203
24207 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
24211 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
24212
24216 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
24220 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
24221
24225 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
24229 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
24230
24234 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
24238 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
24239
24242 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
24243 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
24244 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
24247 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
24248
24251 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
24252 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
24253 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
24256 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
24257
24260 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
24261 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
24262 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
24265 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
24266
24269 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
24270 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
24271 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
24274 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
24275
24278 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
24279 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
24280 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
24283 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
24284
24288 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
24292 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
24296 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
24297
24301 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
24305 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
24306
24310 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
24314 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
24315
24319 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
24323 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
24324
24328 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
24332 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
24333
24337 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
24341 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
24342
24346 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
24350 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
24351
24355 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
24359 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
24360
24364 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
24368 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
24369
24373 bool set_ies_file(const char* str, double time = TiMe::Default()) { return setValue("ies_file", str, time); }
24377 bool set_ies_file(const std::string& str, double time = TiMe::Default()) { return setValue("ies_file", str, time); }
24381 std::string get_ies_file(double time = TiMe::Default()) const { return getString("ies_file", time); }
24382
24386 bool set_filter_color(const Color& color, double time = TiMe::Default()) { return setValue("filter_color", color, time); }
24390 Color get_filter_color(double time = TiMe::Default()) const { return getColor("filter_color", time); }
24391
24395 bool set_power(float val, double time = TiMe::Default()) { return setValue("power", val, time); }
24399 float get_power(double time = TiMe::Default()) const { return getFloat("power", time); }
24400
24404 bool set_override_prescribed_power(bool val, double time = TiMe::Default()) { return setValue("override_prescribed_power", val, time); }
24408 bool get_override_prescribed_power(double time = TiMe::Default()) const { return getBool("override_prescribed_power", time); }
24409
24413 bool set_area_speculars(bool val, double time = TiMe::Default()) { return setValue("area_speculars", val, time); }
24417 bool get_area_speculars(double time = TiMe::Default()) const { return getBool("area_speculars", time); }
24418
24422 bool set_soft_shadows(int val, double time = TiMe::Default()) { return setValue("soft_shadows", val, time); }
24426 int get_soft_shadows(double time = TiMe::Default()) const { return getInt("soft_shadows", time); }
24427
24431 bool set_ies_light_shape(int val, double time = TiMe::Default()) { return setValue("ies_light_shape", val, time); }
24435 int get_ies_light_shape(double time = TiMe::Default()) const { return getInt("ies_light_shape", time); }
24436
24440 bool set_ies_light_width(float val, double time = TiMe::Default()) { return setValue("ies_light_width", val, time); }
24444 float get_ies_light_width(double time = TiMe::Default()) const { return getFloat("ies_light_width", time); }
24445
24449 bool set_ies_light_length(float val, double time = TiMe::Default()) { return setValue("ies_light_length", val, time); }
24453 float get_ies_light_length(double time = TiMe::Default()) const { return getFloat("ies_light_length", time); }
24454
24458 bool set_ies_light_height(float val, double time = TiMe::Default()) { return setValue("ies_light_height", val, time); }
24462 float get_ies_light_height(double time = TiMe::Default()) const { return getFloat("ies_light_height", time); }
24463
24467 bool set_ies_light_diameter(float val, double time = TiMe::Default()) { return setValue("ies_light_diameter", val, time); }
24471 float get_ies_light_diameter(double time = TiMe::Default()) const { return getFloat("ies_light_diameter", time); }
24472
24476 bool set_rescale_max_intensty(bool val, double time = TiMe::Default()) { return setValue("rescale_max_intensty", val, time); }
24480 bool get_rescale_max_intensty(double time = TiMe::Default()) const { return getBool("rescale_max_intensty", time); }
24481
24485 bool set_new_max_intensity(float val, double time = TiMe::Default()) { return setValue("new_max_intensity", val, time); }
24489 float get_new_max_intensity(double time = TiMe::Default()) const { return getFloat("new_max_intensity", time); }
24490};
24491
24493class LightInstancer : public Plugin {
24494public:
24496 static constexpr const PluginTypeId getTypeId() { return 0x7867AC9A; }
24498 static constexpr const char* getType() { return "LightInstancer"; }
24499
24500 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
24501
24505 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
24509 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
24510
24513 bool set_source_light(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("source_light", plugin, time); }
24516 PluginRef get_source_light(double time = TiMe::Default()) const { return getPlugin("source_light", time); }
24517
24521 bool set_transforms_vector(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("transforms_vector", vectorList, time); }
24522 bool set_transforms_vector(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("transforms_vector", std::move(vectorList), time); }
24523 bool set_transforms_vector(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("transforms_vector", vectors, count, time); }
24524 template<size_t count> bool set_transforms_vector(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("transforms_vector", vectors, count, time); }
24528 VectorList get_transforms_vector(double time = TiMe::Default()) const { return getVectorList("transforms_vector", time); }
24529
24533 bool set_transforms(const TransformList& transformList, double time = TiMe::Default()) { return setValue("transforms", transformList, time); }
24534 bool set_transforms(const Transform* transforms, size_t count, double time = TiMe::Default()) { return setArray("transforms", transforms, count, time); }
24535 template<size_t count> bool set_transforms(const Transform (&transforms)[count], double time = TiMe::Default()) { return setArray("transforms", transforms, count, time); }
24539 TransformList get_transforms(double time = TiMe::Default()) const { return getTransformList("transforms", time); }
24540
24544 bool set_use_source_light_transform(bool val, double time = TiMe::Default()) { return setValue("use_source_light_transform", val, time); }
24548 bool get_use_source_light_transform(double time = TiMe::Default()) const { return getBool("use_source_light_transform", time); }
24549
24553 bool set_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("colors", colorList, time); }
24554 bool set_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("colors", std::move(colorList), time); }
24555 bool set_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
24556 template<size_t count> bool set_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("colors", colors, count, time); }
24560 ColorList get_colors(double time = TiMe::Default()) const { return getColorList("colors", time); }
24561
24565 bool set_intensities(const FloatList& floatList, double time = TiMe::Default()) { return setValue("intensities", floatList, time); }
24566 bool set_intensities(FloatList&& floatList, double time = TiMe::Default()) { return setValue("intensities", std::move(floatList), time); }
24567 bool set_intensities(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("intensities", floats, count, time); }
24568 template<size_t count> bool set_intensities(const float (&floats)[count], double time = TiMe::Default()) { return setArray("intensities", floats, count, time); }
24572 FloatList get_intensities(double time = TiMe::Default()) const { return getFloatList("intensities", time); }
24573};
24574
24576class LightLuminaire : public Plugin {
24577public:
24579 static constexpr const PluginTypeId getTypeId() { return 0x7886D14B; }
24581 static constexpr const char* getType() { return "LightLuminaire"; }
24582
24583 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
24584
24585 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
24586
24590 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
24594 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
24595
24599 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
24603 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
24604
24607 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
24610 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
24611
24615 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
24619 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
24620
24623 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
24626 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
24629 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
24630
24634 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
24638 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
24639
24643 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
24647 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
24648
24652 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
24656 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
24657
24661 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
24665 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
24666
24670 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
24674 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
24675
24679 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
24683 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
24684
24688 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
24692 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
24693
24697 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
24701 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
24702
24706 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
24710 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
24711
24715 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
24719 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
24720
24724 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
24728 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
24729
24733 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
24737 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
24738
24741 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
24744 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
24747 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
24748
24752 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
24756 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
24757
24761 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
24765 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
24766
24770 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
24774 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
24775
24779 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
24783 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
24784
24788 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
24792 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
24793
24797 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
24801 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
24802
24806 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
24810 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
24811
24814 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
24815 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
24816 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
24819 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
24820
24823 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
24824 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
24825 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
24828 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
24829
24832 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
24833 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
24834 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
24837 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
24838
24841 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
24842 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
24843 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
24846 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
24847
24850 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
24851 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
24852 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
24855 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
24856
24860 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
24864 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
24868 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
24869
24873 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
24877 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
24878
24882 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
24886 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
24887
24891 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
24895 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
24896
24900 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
24904 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
24905
24909 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
24913 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
24914
24918 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
24922 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
24923
24927 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
24931 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
24932
24936 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
24940 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
24941
24944 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
24947 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
24950 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
24951
24955 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
24959 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
24960
24964 bool set_invisible(bool val, double time = TiMe::Default()) { return setValue("invisible", val, time); }
24968 bool get_invisible(double time = TiMe::Default()) const { return getBool("invisible", time); }
24969
24973 bool set_occludeLights(bool val, double time = TiMe::Default()) { return setValue("occludeLights", val, time); }
24977 bool get_occludeLights(double time = TiMe::Default()) const { return getBool("occludeLights", time); }
24978
24982 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
24986 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
24987
24991 bool set_affectReflections(bool val, double time = TiMe::Default()) { return setValue("affectReflections", val, time); }
24995 bool get_affectReflections(double time = TiMe::Default()) const { return getBool("affectReflections", time); }
24996
25000 bool set_noDecay(bool val, double time = TiMe::Default()) { return setValue("noDecay", val, time); }
25004 bool get_noDecay(double time = TiMe::Default()) const { return getBool("noDecay", time); }
25005
25009 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
25013 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
25014
25018 bool set_useMIS(bool val, double time = TiMe::Default()) { return setValue("useMIS", val, time); }
25022 bool get_useMIS(double time = TiMe::Default()) const { return getBool("useMIS", time); }
25023
25027 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
25031 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
25035 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
25036
25040 bool set_lod_on(bool val, double time = TiMe::Default()) { return setValue("lod_on", val, time); }
25044 bool get_lod_on(double time = TiMe::Default()) const { return getBool("lod_on", time); }
25045
25048 bool set_sampling_mode(int val, double time = TiMe::Default()) { return setValue("sampling_mode", val, time); }
25051 int get_sampling_mode(double time = TiMe::Default()) const { return getInt("sampling_mode", time); }
25052
25056 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
25060 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
25061
25065 bool set_filter_strength(float val, double time = TiMe::Default()) { return setValue("filter_strength", val, time); }
25069 float get_filter_strength(double time = TiMe::Default()) const { return getFloat("filter_strength", time); }
25070
25074 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
25078 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
25079};
25080
25082class LightMesh : public Plugin {
25083public:
25085 static constexpr const PluginTypeId getTypeId() { return 0x77BF86D9; }
25087 static constexpr const char* getType() { return "LightMesh"; }
25088
25089 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
25090
25091 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
25092
25096 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
25100 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
25101
25105 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
25109 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
25110
25113 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
25116 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
25117
25121 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
25125 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
25126
25129 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
25132 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
25135 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
25136
25140 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
25144 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
25145
25149 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
25153 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
25154
25158 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
25162 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
25163
25167 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
25171 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
25172
25176 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
25180 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
25181
25185 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
25189 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
25190
25194 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
25198 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
25199
25203 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
25207 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
25208
25212 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
25216 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
25217
25221 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
25225 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
25226
25230 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
25234 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
25235
25239 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
25243 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
25244
25247 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
25250 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
25253 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
25254
25258 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
25262 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
25263
25267 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
25271 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
25272
25276 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
25280 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
25281
25285 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
25289 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
25290
25294 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
25298 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
25299
25303 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
25307 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
25308
25312 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
25316 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
25317
25320 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
25321 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
25322 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
25325 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
25326
25329 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
25330 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
25331 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
25334 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
25335
25338 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
25339 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
25340 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
25343 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
25344
25347 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
25348 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
25349 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
25352 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
25353
25356 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
25357 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
25358 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
25361 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
25362
25366 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
25370 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
25374 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
25375
25379 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
25383 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
25384
25388 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
25392 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
25393
25397 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
25401 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
25402
25406 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
25410 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
25411
25415 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
25419 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
25420
25424 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
25428 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
25429
25433 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
25437 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
25438
25442 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
25446 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
25447
25450 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
25453 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
25456 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
25457
25461 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
25465 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
25466
25470 bool set_invisible(bool val, double time = TiMe::Default()) { return setValue("invisible", val, time); }
25474 bool get_invisible(double time = TiMe::Default()) const { return getBool("invisible", time); }
25475
25479 bool set_occludeLights(bool val, double time = TiMe::Default()) { return setValue("occludeLights", val, time); }
25483 bool get_occludeLights(double time = TiMe::Default()) const { return getBool("occludeLights", time); }
25484
25488 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
25492 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
25493
25497 bool set_affectReflections(bool val, double time = TiMe::Default()) { return setValue("affectReflections", val, time); }
25501 bool get_affectReflections(double time = TiMe::Default()) const { return getBool("affectReflections", time); }
25502
25506 bool set_noDecay(bool val, double time = TiMe::Default()) { return setValue("noDecay", val, time); }
25510 bool get_noDecay(double time = TiMe::Default()) const { return getBool("noDecay", time); }
25511
25515 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
25519 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
25520
25524 bool set_lightPortal(int val, double time = TiMe::Default()) { return setValue("lightPortal", val, time); }
25528 int get_lightPortal(double time = TiMe::Default()) const { return getInt("lightPortal", time); }
25529
25533 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
25537 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
25538
25542 bool set_useMIS(bool val, double time = TiMe::Default()) { return setValue("useMIS", val, time); }
25546 bool get_useMIS(double time = TiMe::Default()) const { return getBool("useMIS", time); }
25547
25550 bool set_geometry(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("geometry", plugin, time); }
25553 PluginRef get_geometry(double time = TiMe::Default()) const { return getPlugin("geometry", time); }
25554
25558 bool set_ignoreLightNormals(bool val, double time = TiMe::Default()) { return setValue("ignoreLightNormals", val, time); }
25562 bool get_ignoreLightNormals(double time = TiMe::Default()) const { return getBool("ignoreLightNormals", time); }
25563
25567 bool set_use_tex(bool val, double time = TiMe::Default()) { return setValue("use_tex", val, time); }
25571 bool get_use_tex(double time = TiMe::Default()) const { return getBool("use_tex", time); }
25572
25575 bool set_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex", texture, time); }
25578 bool set_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("tex", texture, time); }
25581 Value get_tex(double time = TiMe::Default()) const { return getValue("tex", time); }
25582
25586 bool set_tex_resolution(int val, double time = TiMe::Default()) { return setValue("tex_resolution", val, time); }
25590 int get_tex_resolution(double time = TiMe::Default()) const { return getInt("tex_resolution", time); }
25591
25595 bool set_cache_tex(bool val, double time = TiMe::Default()) { return setValue("cache_tex", val, time); }
25599 bool get_cache_tex(double time = TiMe::Default()) const { return getBool("cache_tex", time); }
25600
25604 bool set_user_attributes(const char* str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
25608 bool set_user_attributes(const std::string& str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
25612 std::string get_user_attributes(double time = TiMe::Default()) const { return getString("user_attributes", time); }
25613
25616 bool set_user_attributes_bin(const IntList& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", intList, time); }
25617 bool set_user_attributes_bin(IntList&& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", std::move(intList), time); }
25618 bool set_user_attributes_bin(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
25619 template<size_t count> bool set_user_attributes_bin(const int (&ints)[count], double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
25622 IntList get_user_attributes_bin(double time = TiMe::Default()) const { return getIntList("user_attributes_bin", time); }
25623
25625 bool set_map_channels(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("map_channels", plugin, time); }
25627 PluginRef get_map_channels(double time = TiMe::Default()) const { return getPlugin("map_channels", time); }
25628};
25629
25631class LightOmni : public Plugin {
25632public:
25634 static constexpr const PluginTypeId getTypeId() { return 0x77742C06; }
25636 static constexpr const char* getType() { return "LightOmni"; }
25637
25638 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
25639
25643 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
25647 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
25648
25652 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
25656 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
25657
25660 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
25663 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
25664
25668 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
25672 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
25673
25676 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
25679 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
25682 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
25683
25687 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
25691 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
25692
25696 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
25700 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
25701
25705 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
25709 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
25710
25714 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
25718 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
25719
25723 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
25727 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
25728
25732 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
25736 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
25737
25741 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
25745 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
25746
25750 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
25754 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
25755
25759 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
25763 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
25764
25768 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
25772 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
25773
25777 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
25781 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
25782
25786 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
25790 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
25791
25794 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
25797 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
25800 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
25801
25805 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
25809 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
25810
25814 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
25818 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
25819
25823 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
25827 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
25828
25832 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
25836 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
25837
25841 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
25845 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
25846
25850 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
25854 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
25855
25859 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
25863 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
25864
25867 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
25868 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
25869 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
25872 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
25873
25876 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
25877 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
25878 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
25881 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
25882
25885 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
25886 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
25887 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
25890 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
25891
25894 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
25895 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
25896 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
25899 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
25900
25903 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
25904 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
25905 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
25908 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
25909
25913 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
25917 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
25921 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
25922
25926 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
25930 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
25931
25935 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
25939 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
25940
25944 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
25948 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
25949
25953 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
25957 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
25958
25962 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
25966 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
25967
25971 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
25975 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
25976
25980 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
25984 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
25985
25989 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
25993 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
25994
25997 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
26000 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
26003 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
26004
26008 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
26012 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
26013
26017 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
26021 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
26022
26025 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
26028 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
26031 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
26032
26036 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
26040 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
26041
26045 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
26049 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
26050
26054 bool set_decay(float val, double time = TiMe::Default()) { return setValue("decay", val, time); }
26058 float get_decay(double time = TiMe::Default()) const { return getFloat("decay", time); }
26059};
26060
26062class LightOmniMax : public Plugin {
26063public:
26065 static constexpr const PluginTypeId getTypeId() { return 0x77BF65A5; }
26067 static constexpr const char* getType() { return "LightOmniMax"; }
26068
26069 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
26070
26071 operator UVWGenPluginCategory() { return *static_cast<UVWGenPluginCategory*>(static_cast<Plugin*>(this)); }
26072
26076 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
26080 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
26081
26085 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
26089 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
26090
26093 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
26096 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
26097
26101 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
26105 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
26106
26109 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
26112 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
26115 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
26116
26120 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
26124 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
26125
26129 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
26133 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
26134
26138 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
26142 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
26143
26147 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
26151 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
26152
26156 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
26160 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
26161
26165 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
26169 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
26170
26174 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
26178 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
26179
26183 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
26187 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
26188
26192 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
26196 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
26197
26201 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
26205 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
26206
26210 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
26214 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
26215
26219 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
26223 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
26224
26227 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
26230 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
26233 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
26234
26238 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
26242 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
26243
26247 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
26251 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
26252
26256 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
26260 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
26261
26265 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
26269 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
26270
26274 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
26278 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
26279
26283 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
26287 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
26288
26292 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
26296 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
26297
26300 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
26301 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
26302 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
26305 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
26306
26309 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
26310 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
26311 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
26314 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
26315
26318 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
26319 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
26320 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
26323 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
26324
26327 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
26328 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
26329 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
26332 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
26333
26336 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
26337 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
26338 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
26341 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
26342
26346 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
26350 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
26354 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
26355
26359 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
26363 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
26364
26368 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
26372 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
26373
26376 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
26379 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
26382 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
26383
26387 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
26391 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
26392
26396 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
26400 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
26401
26404 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
26407 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
26410 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
26411
26415 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
26419 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
26420
26424 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
26428 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
26429
26432 bool set_projector_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("projector_map", texture, time); }
26435 bool set_projector_map(const AColor& texture, double time = TiMe::Default()) { return setValue("projector_map", texture, time); }
26438 Value get_projector_map(double time = TiMe::Default()) const { return getValue("projector_map", time); }
26439
26443 bool set_decay_type(int val, double time = TiMe::Default()) { return setValue("decay_type", val, time); }
26447 int get_decay_type(double time = TiMe::Default()) const { return getInt("decay_type", time); }
26448
26452 bool set_decay_start(float val, double time = TiMe::Default()) { return setValue("decay_start", val, time); }
26456 float get_decay_start(double time = TiMe::Default()) const { return getFloat("decay_start", time); }
26457
26461 bool set_near_attenuation(bool val, double time = TiMe::Default()) { return setValue("near_attenuation", val, time); }
26465 bool get_near_attenuation(double time = TiMe::Default()) const { return getBool("near_attenuation", time); }
26466
26470 bool set_near_attenuation_start(float val, double time = TiMe::Default()) { return setValue("near_attenuation_start", val, time); }
26474 float get_near_attenuation_start(double time = TiMe::Default()) const { return getFloat("near_attenuation_start", time); }
26475
26479 bool set_near_attenuation_end(float val, double time = TiMe::Default()) { return setValue("near_attenuation_end", val, time); }
26483 float get_near_attenuation_end(double time = TiMe::Default()) const { return getFloat("near_attenuation_end", time); }
26484
26488 bool set_far_attenuation(bool val, double time = TiMe::Default()) { return setValue("far_attenuation", val, time); }
26492 bool get_far_attenuation(double time = TiMe::Default()) const { return getBool("far_attenuation", time); }
26493
26497 bool set_far_attenuation_start(float val, double time = TiMe::Default()) { return setValue("far_attenuation_start", val, time); }
26501 float get_far_attenuation_start(double time = TiMe::Default()) const { return getFloat("far_attenuation_start", time); }
26502
26506 bool set_far_attenuation_end(float val, double time = TiMe::Default()) { return setValue("far_attenuation_end", val, time); }
26510 float get_far_attenuation_end(double time = TiMe::Default()) const { return getFloat("far_attenuation_end", time); }
26511
26515 bool set_shadowShape(int val, double time = TiMe::Default()) { return setValue("shadowShape", val, time); }
26519 int get_shadowShape(double time = TiMe::Default()) const { return getInt("shadowShape", time); }
26520
26524 bool set_shadowRadius1(float val, double time = TiMe::Default()) { return setValue("shadowRadius1", val, time); }
26528 float get_shadowRadius1(double time = TiMe::Default()) const { return getFloat("shadowRadius1", time); }
26529
26533 bool set_shadowRadius2(float val, double time = TiMe::Default()) { return setValue("shadowRadius2", val, time); }
26537 float get_shadowRadius2(double time = TiMe::Default()) const { return getFloat("shadowRadius2", time); }
26538};
26539
26541class LightRectangle : public Plugin {
26542public:
26544 static constexpr const PluginTypeId getTypeId() { return 0x77838E80; }
26546 static constexpr const char* getType() { return "LightRectangle"; }
26547
26548 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
26549
26550 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
26551
26555 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
26559 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
26560
26564 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
26568 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
26569
26572 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
26575 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
26576
26580 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
26584 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
26585
26588 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
26591 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
26594 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
26595
26599 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
26603 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
26604
26608 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
26612 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
26613
26617 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
26621 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
26622
26626 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
26630 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
26631
26635 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
26639 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
26640
26644 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
26648 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
26649
26653 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
26657 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
26658
26662 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
26666 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
26667
26671 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
26675 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
26676
26680 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
26684 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
26685
26689 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
26693 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
26694
26698 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
26702 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
26703
26706 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
26709 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
26712 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
26713
26717 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
26721 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
26722
26726 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
26730 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
26731
26735 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
26739 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
26740
26744 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
26748 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
26749
26753 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
26757 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
26758
26762 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
26766 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
26767
26771 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
26775 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
26776
26779 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
26780 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
26781 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
26784 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
26785
26788 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
26789 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
26790 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
26793 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
26794
26797 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
26798 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
26799 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
26802 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
26803
26806 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
26807 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
26808 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
26811 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
26812
26815 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
26816 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
26817 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
26820 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
26821
26825 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
26829 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
26833 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
26834
26838 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
26842 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
26843
26847 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
26851 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
26852
26856 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
26860 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
26861
26865 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
26869 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
26870
26874 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
26878 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
26879
26883 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
26887 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
26888
26892 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
26896 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
26897
26901 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
26905 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
26906
26909 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
26912 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
26915 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
26916
26920 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
26924 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
26925
26929 bool set_invisible(bool val, double time = TiMe::Default()) { return setValue("invisible", val, time); }
26933 bool get_invisible(double time = TiMe::Default()) const { return getBool("invisible", time); }
26934
26938 bool set_occludeLights(bool val, double time = TiMe::Default()) { return setValue("occludeLights", val, time); }
26942 bool get_occludeLights(double time = TiMe::Default()) const { return getBool("occludeLights", time); }
26943
26947 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
26951 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
26952
26956 bool set_affectReflections(bool val, double time = TiMe::Default()) { return setValue("affectReflections", val, time); }
26960 bool get_affectReflections(double time = TiMe::Default()) const { return getBool("affectReflections", time); }
26961
26965 bool set_noDecay(bool val, double time = TiMe::Default()) { return setValue("noDecay", val, time); }
26969 bool get_noDecay(double time = TiMe::Default()) const { return getBool("noDecay", time); }
26970
26974 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
26978 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
26979
26983 bool set_lightPortal(int val, double time = TiMe::Default()) { return setValue("lightPortal", val, time); }
26987 int get_lightPortal(double time = TiMe::Default()) const { return getInt("lightPortal", time); }
26988
26992 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
26996 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
26997
27001 bool set_useMIS(bool val, double time = TiMe::Default()) { return setValue("useMIS", val, time); }
27005 bool get_useMIS(double time = TiMe::Default()) const { return getBool("useMIS", time); }
27006
27010 bool set_is_disc(bool val, double time = TiMe::Default()) { return setValue("is_disc", val, time); }
27014 bool get_is_disc(double time = TiMe::Default()) const { return getBool("is_disc", time); }
27015
27019 bool set_u_size(float val, double time = TiMe::Default()) { return setValue("u_size", val, time); }
27023 float get_u_size(double time = TiMe::Default()) const { return getFloat("u_size", time); }
27024
27028 bool set_v_size(float val, double time = TiMe::Default()) { return setValue("v_size", val, time); }
27032 float get_v_size(double time = TiMe::Default()) const { return getFloat("v_size", time); }
27033
27037 bool set_directional(float val, double time = TiMe::Default()) { return setValue("directional", val, time); }
27041 float get_directional(double time = TiMe::Default()) const { return getFloat("directional", time); }
27042
27046 bool set_directional_strength(float val, double time = TiMe::Default()) { return setValue("directional_strength", val, time); }
27050 float get_directional_strength(double time = TiMe::Default()) const { return getFloat("directional_strength", time); }
27051
27055 bool set_ignoreLightNormals(bool val, double time = TiMe::Default()) { return setValue("ignoreLightNormals", val, time); }
27059 bool get_ignoreLightNormals(double time = TiMe::Default()) const { return getBool("ignoreLightNormals", time); }
27060
27064 bool set_use_rect_tex(bool val, double time = TiMe::Default()) { return setValue("use_rect_tex", val, time); }
27068 bool get_use_rect_tex(double time = TiMe::Default()) const { return getBool("use_rect_tex", time); }
27069
27072 bool set_rect_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("rect_tex", texture, time); }
27075 bool set_rect_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("rect_tex", texture, time); }
27078 Value get_rect_tex(double time = TiMe::Default()) const { return getValue("rect_tex", time); }
27079
27083 bool set_tex_resolution(int val, double time = TiMe::Default()) { return setValue("tex_resolution", val, time); }
27087 int get_tex_resolution(double time = TiMe::Default()) const { return getInt("tex_resolution", time); }
27088
27092 bool set_tex_adaptive(float val, double time = TiMe::Default()) { return setValue("tex_adaptive", val, time); }
27096 float get_tex_adaptive(double time = TiMe::Default()) const { return getFloat("tex_adaptive", time); }
27097};
27098
27100class LightSphere : public Plugin {
27101public:
27103 static constexpr const PluginTypeId getTypeId() { return 0x77928B9C; }
27105 static constexpr const char* getType() { return "LightSphere"; }
27106
27107 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
27108
27109 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
27110
27114 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
27118 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
27119
27123 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
27127 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
27128
27131 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
27134 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
27135
27139 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
27143 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
27144
27147 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
27150 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
27153 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
27154
27158 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
27162 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
27163
27167 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
27171 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
27172
27176 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
27180 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
27181
27185 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
27189 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
27190
27194 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
27198 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
27199
27203 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
27207 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
27208
27212 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
27216 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
27217
27221 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
27225 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
27226
27230 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
27234 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
27235
27239 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
27243 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
27244
27248 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
27252 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
27253
27257 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
27261 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
27262
27265 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
27268 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
27271 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
27272
27276 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
27280 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
27281
27285 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
27289 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
27290
27294 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
27298 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
27299
27303 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
27307 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
27308
27312 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
27316 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
27317
27321 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
27325 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
27326
27330 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
27334 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
27335
27338 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
27339 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
27340 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
27343 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
27344
27347 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
27348 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
27349 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
27352 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
27353
27356 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
27357 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
27358 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
27361 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
27362
27365 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
27366 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
27367 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
27370 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
27371
27374 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
27375 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
27376 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
27379 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
27380
27384 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
27388 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
27392 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
27393
27397 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
27401 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
27402
27406 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
27410 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
27411
27415 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
27419 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
27420
27424 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
27428 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
27429
27433 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
27437 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
27438
27442 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
27446 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
27447
27451 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
27455 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
27456
27460 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
27464 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
27465
27468 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
27471 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
27474 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
27475
27479 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
27483 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
27484
27488 bool set_invisible(bool val, double time = TiMe::Default()) { return setValue("invisible", val, time); }
27492 bool get_invisible(double time = TiMe::Default()) const { return getBool("invisible", time); }
27493
27497 bool set_occludeLights(bool val, double time = TiMe::Default()) { return setValue("occludeLights", val, time); }
27501 bool get_occludeLights(double time = TiMe::Default()) const { return getBool("occludeLights", time); }
27502
27506 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
27510 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
27511
27515 bool set_affectReflections(bool val, double time = TiMe::Default()) { return setValue("affectReflections", val, time); }
27519 bool get_affectReflections(double time = TiMe::Default()) const { return getBool("affectReflections", time); }
27520
27524 bool set_noDecay(bool val, double time = TiMe::Default()) { return setValue("noDecay", val, time); }
27528 bool get_noDecay(double time = TiMe::Default()) const { return getBool("noDecay", time); }
27529
27533 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
27537 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
27538
27542 bool set_useMIS(bool val, double time = TiMe::Default()) { return setValue("useMIS", val, time); }
27546 bool get_useMIS(double time = TiMe::Default()) const { return getBool("useMIS", time); }
27547
27551 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
27555 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
27556
27560 bool set_sphere_segments(int val, double time = TiMe::Default()) { return setValue("sphere_segments", val, time); }
27564 int get_sphere_segments(double time = TiMe::Default()) const { return getInt("sphere_segments", time); }
27565};
27566
27568class LightSpot : public Plugin {
27569public:
27571 static constexpr const PluginTypeId getTypeId() { return 0x77827D1B; }
27573 static constexpr const char* getType() { return "LightSpot"; }
27574
27575 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
27576
27580 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
27584 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
27585
27589 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
27593 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
27594
27597 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
27600 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
27601
27605 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
27609 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
27610
27613 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
27616 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
27619 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
27620
27624 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
27628 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
27629
27633 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
27637 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
27638
27642 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
27646 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
27647
27651 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
27655 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
27656
27660 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
27664 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
27665
27669 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
27673 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
27674
27678 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
27682 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
27683
27687 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
27691 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
27692
27696 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
27700 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
27701
27705 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
27709 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
27710
27714 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
27718 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
27719
27723 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
27727 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
27728
27731 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
27734 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
27737 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
27738
27742 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
27746 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
27747
27751 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
27755 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
27756
27760 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
27764 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
27765
27769 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
27773 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
27774
27778 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
27782 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
27783
27787 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
27791 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
27792
27796 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
27800 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
27801
27804 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
27805 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
27806 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
27809 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
27810
27813 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
27814 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
27815 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
27818 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
27819
27822 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
27823 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
27824 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
27827 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
27828
27831 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
27832 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
27833 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
27836 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
27837
27840 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
27841 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
27842 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
27845 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
27846
27850 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
27854 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
27858 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
27859
27863 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
27867 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
27868
27872 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
27876 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
27877
27881 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
27885 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
27886
27890 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
27894 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
27895
27899 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
27903 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
27904
27908 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
27912 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
27913
27917 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
27921 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
27922
27926 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
27930 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
27931
27934 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
27937 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
27940 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
27941
27945 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
27949 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
27950
27954 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
27958 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
27959
27962 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
27965 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
27968 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
27969
27973 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
27977 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
27978
27982 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
27986 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
27987
27991 bool set_falloffType(int val, double time = TiMe::Default()) { return setValue("falloffType", val, time); }
27995 int get_falloffType(double time = TiMe::Default()) const { return getInt("falloffType", time); }
27996
28000 bool set_decay(float val, double time = TiMe::Default()) { return setValue("decay", val, time); }
28004 float get_decay(double time = TiMe::Default()) const { return getFloat("decay", time); }
28005
28009 bool set_coneAngle(float val, double time = TiMe::Default()) { return setValue("coneAngle", val, time); }
28013 float get_coneAngle(double time = TiMe::Default()) const { return getFloat("coneAngle", time); }
28014
28018 bool set_penumbraAngle(float val, double time = TiMe::Default()) { return setValue("penumbraAngle", val, time); }
28022 float get_penumbraAngle(double time = TiMe::Default()) const { return getFloat("penumbraAngle", time); }
28023
28027 bool set_dropOff(float val, double time = TiMe::Default()) { return setValue("dropOff", val, time); }
28031 float get_dropOff(double time = TiMe::Default()) const { return getFloat("dropOff", time); }
28032
28036 bool set_barnDoor(bool val, double time = TiMe::Default()) { return setValue("barnDoor", val, time); }
28040 bool get_barnDoor(double time = TiMe::Default()) const { return getBool("barnDoor", time); }
28041
28045 bool set_barnDoorLeft(float val, double time = TiMe::Default()) { return setValue("barnDoorLeft", val, time); }
28049 float get_barnDoorLeft(double time = TiMe::Default()) const { return getFloat("barnDoorLeft", time); }
28050
28054 bool set_barnDoorRight(float val, double time = TiMe::Default()) { return setValue("barnDoorRight", val, time); }
28058 float get_barnDoorRight(double time = TiMe::Default()) const { return getFloat("barnDoorRight", time); }
28059
28063 bool set_barnDoorTop(float val, double time = TiMe::Default()) { return setValue("barnDoorTop", val, time); }
28067 float get_barnDoorTop(double time = TiMe::Default()) const { return getFloat("barnDoorTop", time); }
28068
28072 bool set_barnDoorBottom(float val, double time = TiMe::Default()) { return setValue("barnDoorBottom", val, time); }
28076 float get_barnDoorBottom(double time = TiMe::Default()) const { return getFloat("barnDoorBottom", time); }
28077
28081 bool set_useDecayRegions(bool val, double time = TiMe::Default()) { return setValue("useDecayRegions", val, time); }
28085 bool get_useDecayRegions(double time = TiMe::Default()) const { return getBool("useDecayRegions", time); }
28086
28090 bool set_startDistance1(float val, double time = TiMe::Default()) { return setValue("startDistance1", val, time); }
28094 float get_startDistance1(double time = TiMe::Default()) const { return getFloat("startDistance1", time); }
28095
28099 bool set_endDistance1(float val, double time = TiMe::Default()) { return setValue("endDistance1", val, time); }
28103 float get_endDistance1(double time = TiMe::Default()) const { return getFloat("endDistance1", time); }
28104
28108 bool set_startDistance2(float val, double time = TiMe::Default()) { return setValue("startDistance2", val, time); }
28112 float get_startDistance2(double time = TiMe::Default()) const { return getFloat("startDistance2", time); }
28113
28117 bool set_endDistance2(float val, double time = TiMe::Default()) { return setValue("endDistance2", val, time); }
28121 float get_endDistance2(double time = TiMe::Default()) const { return getFloat("endDistance2", time); }
28122
28126 bool set_startDistance3(float val, double time = TiMe::Default()) { return setValue("startDistance3", val, time); }
28130 float get_startDistance3(double time = TiMe::Default()) const { return getFloat("startDistance3", time); }
28131
28135 bool set_endDistance3(float val, double time = TiMe::Default()) { return setValue("endDistance3", val, time); }
28139 float get_endDistance3(double time = TiMe::Default()) const { return getFloat("endDistance3", time); }
28140};
28141
28143class LightSpotMax : public Plugin {
28144public:
28146 static constexpr const PluginTypeId getTypeId() { return 0x77BF65A6; }
28148 static constexpr const char* getType() { return "LightSpotMax"; }
28149
28150 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
28151
28152 operator UVWGenPluginCategory() { return *static_cast<UVWGenPluginCategory*>(static_cast<Plugin*>(this)); }
28153
28157 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
28161 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
28162
28166 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
28170 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
28171
28174 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
28177 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
28178
28182 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
28186 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
28187
28190 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
28193 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
28196 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
28197
28201 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
28205 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
28206
28210 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
28214 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
28215
28219 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
28223 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
28224
28228 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
28232 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
28233
28237 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
28241 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
28242
28246 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
28250 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
28251
28255 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
28259 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
28260
28264 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
28268 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
28269
28273 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
28277 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
28278
28282 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
28286 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
28287
28291 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
28295 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
28296
28300 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
28304 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
28305
28308 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
28311 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
28314 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
28315
28319 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
28323 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
28324
28328 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
28332 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
28333
28337 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
28341 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
28342
28346 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
28350 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
28351
28355 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
28359 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
28360
28364 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
28368 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
28369
28373 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
28377 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
28378
28381 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
28382 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
28383 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
28386 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
28387
28390 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
28391 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
28392 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
28395 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
28396
28399 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
28400 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
28401 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
28404 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
28405
28408 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
28409 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
28410 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
28413 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
28414
28417 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
28418 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
28419 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
28422 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
28423
28427 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
28431 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
28435 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
28436
28440 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
28444 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
28445
28449 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
28453 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
28454
28457 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
28460 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
28463 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
28464
28468 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
28472 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
28473
28477 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
28481 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
28482
28485 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
28488 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
28491 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
28492
28496 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
28500 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
28501
28505 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
28509 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
28510
28513 bool set_projector_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("projector_map", texture, time); }
28516 bool set_projector_map(const AColor& texture, double time = TiMe::Default()) { return setValue("projector_map", texture, time); }
28519 Value get_projector_map(double time = TiMe::Default()) const { return getValue("projector_map", time); }
28520
28524 bool set_decay_type(int val, double time = TiMe::Default()) { return setValue("decay_type", val, time); }
28528 int get_decay_type(double time = TiMe::Default()) const { return getInt("decay_type", time); }
28529
28533 bool set_decay_start(float val, double time = TiMe::Default()) { return setValue("decay_start", val, time); }
28537 float get_decay_start(double time = TiMe::Default()) const { return getFloat("decay_start", time); }
28538
28542 bool set_near_attenuation(bool val, double time = TiMe::Default()) { return setValue("near_attenuation", val, time); }
28546 bool get_near_attenuation(double time = TiMe::Default()) const { return getBool("near_attenuation", time); }
28547
28551 bool set_near_attenuation_start(float val, double time = TiMe::Default()) { return setValue("near_attenuation_start", val, time); }
28555 float get_near_attenuation_start(double time = TiMe::Default()) const { return getFloat("near_attenuation_start", time); }
28556
28560 bool set_near_attenuation_end(float val, double time = TiMe::Default()) { return setValue("near_attenuation_end", val, time); }
28564 float get_near_attenuation_end(double time = TiMe::Default()) const { return getFloat("near_attenuation_end", time); }
28565
28569 bool set_far_attenuation(bool val, double time = TiMe::Default()) { return setValue("far_attenuation", val, time); }
28573 bool get_far_attenuation(double time = TiMe::Default()) const { return getBool("far_attenuation", time); }
28574
28578 bool set_far_attenuation_start(float val, double time = TiMe::Default()) { return setValue("far_attenuation_start", val, time); }
28582 float get_far_attenuation_start(double time = TiMe::Default()) const { return getFloat("far_attenuation_start", time); }
28583
28587 bool set_far_attenuation_end(float val, double time = TiMe::Default()) { return setValue("far_attenuation_end", val, time); }
28591 float get_far_attenuation_end(double time = TiMe::Default()) const { return getFloat("far_attenuation_end", time); }
28592
28596 bool set_shadowShape(int val, double time = TiMe::Default()) { return setValue("shadowShape", val, time); }
28600 int get_shadowShape(double time = TiMe::Default()) const { return getInt("shadowShape", time); }
28601
28605 bool set_shadowRadius1(float val, double time = TiMe::Default()) { return setValue("shadowRadius1", val, time); }
28609 float get_shadowRadius1(double time = TiMe::Default()) const { return getFloat("shadowRadius1", time); }
28610
28614 bool set_shadowRadius2(float val, double time = TiMe::Default()) { return setValue("shadowRadius2", val, time); }
28618 float get_shadowRadius2(double time = TiMe::Default()) const { return getFloat("shadowRadius2", time); }
28619
28623 bool set_overshoot(bool val, double time = TiMe::Default()) { return setValue("overshoot", val, time); }
28627 bool get_overshoot(double time = TiMe::Default()) const { return getBool("overshoot", time); }
28628
28632 bool set_hotspot(float val, double time = TiMe::Default()) { return setValue("hotspot", val, time); }
28636 float get_hotspot(double time = TiMe::Default()) const { return getFloat("hotspot", time); }
28637
28641 bool set_fallsize(float val, double time = TiMe::Default()) { return setValue("fallsize", val, time); }
28645 float get_fallsize(double time = TiMe::Default()) const { return getFloat("fallsize", time); }
28646
28650 bool set_shape_type(int val, double time = TiMe::Default()) { return setValue("shape_type", val, time); }
28654 int get_shape_type(double time = TiMe::Default()) const { return getInt("shape_type", time); }
28655
28659 bool set_rect_aspect(float val, double time = TiMe::Default()) { return setValue("rect_aspect", val, time); }
28663 float get_rect_aspect(double time = TiMe::Default()) const { return getFloat("rect_aspect", time); }
28664};
28665
28667class LuminaireBaker : public Plugin {
28668public:
28670 static constexpr const PluginTypeId getTypeId() { return 0x7886CE4E; }
28672 static constexpr const char* getType() { return "LuminaireBaker"; }
28673
28674 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
28675
28676 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
28677
28681 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
28685 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
28686
28690 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
28694 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
28695
28699 bool set_filter_strength(float val, double time = TiMe::Default()) { return setValue("filter_strength", val, time); }
28703 float get_filter_strength(double time = TiMe::Default()) const { return getFloat("filter_strength", time); }
28704
28708 bool set_texel_radius(float val, double time = TiMe::Default()) { return setValue("texel_radius", val, time); }
28712 float get_texel_radius(double time = TiMe::Default()) const { return getFloat("texel_radius", time); }
28713
28717 bool set_bin_spread(float val, double time = TiMe::Default()) { return setValue("bin_spread", val, time); }
28721 float get_bin_spread(double time = TiMe::Default()) const { return getFloat("bin_spread", time); }
28722
28726 bool set_resolution(int val, double time = TiMe::Default()) { return setValue("resolution", val, time); }
28730 int get_resolution(double time = TiMe::Default()) const { return getInt("resolution", time); }
28731
28734 bool set_node(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("node", plugin, time); }
28737 PluginRef get_node(double time = TiMe::Default()) const { return getPlugin("node", time); }
28738
28742 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
28746 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
28750 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
28751
28755 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
28759 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
28760
28764 bool set_texel_sh_degree(int val, double time = TiMe::Default()) { return setValue("texel_sh_degree", val, time); }
28768 int get_texel_sh_degree(double time = TiMe::Default()) const { return getInt("texel_sh_degree", time); }
28769
28773 bool set_bin_subdivs(int val, double time = TiMe::Default()) { return setValue("bin_subdivs", val, time); }
28777 int get_bin_subdivs(double time = TiMe::Default()) const { return getInt("bin_subdivs", time); }
28778
28782 bool set_compression_ratio(float val, double time = TiMe::Default()) { return setValue("compression_ratio", val, time); }
28786 float get_compression_ratio(double time = TiMe::Default()) const { return getFloat("compression_ratio", time); }
28787
28790 bool set_dump_dir(const char* str, double time = TiMe::Default()) { return setValue("dump_dir", str, time); }
28793 bool set_dump_dir(const std::string& str, double time = TiMe::Default()) { return setValue("dump_dir", str, time); }
28796 std::string get_dump_dir(double time = TiMe::Default()) const { return getString("dump_dir", time); }
28797
28800 bool set_include_mtl_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("include_mtl_ids", intList, time); }
28801 bool set_include_mtl_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("include_mtl_ids", std::move(intList), time); }
28802 bool set_include_mtl_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("include_mtl_ids", ints, count, time); }
28803 template<size_t count> bool set_include_mtl_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("include_mtl_ids", ints, count, time); }
28806 IntList get_include_mtl_ids(double time = TiMe::Default()) const { return getIntList("include_mtl_ids", time); }
28807
28810 bool set_exclude_mtl_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("exclude_mtl_ids", intList, time); }
28811 bool set_exclude_mtl_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("exclude_mtl_ids", std::move(intList), time); }
28812 bool set_exclude_mtl_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("exclude_mtl_ids", ints, count, time); }
28813 template<size_t count> bool set_exclude_mtl_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("exclude_mtl_ids", ints, count, time); }
28816 IntList get_exclude_mtl_ids(double time = TiMe::Default()) const { return getIntList("exclude_mtl_ids", time); }
28817
28820 bool set_reduce_box_min(const Vector& vector, double time = TiMe::Default()) { return setValue("reduce_box_min", vector, time); }
28823 Vector get_reduce_box_min(double time = TiMe::Default()) const { return getVector("reduce_box_min", time); }
28824
28827 bool set_reduce_box_max(const Vector& vector, double time = TiMe::Default()) { return setValue("reduce_box_max", vector, time); }
28830 Vector get_reduce_box_max(double time = TiMe::Default()) const { return getVector("reduce_box_max", time); }
28831
28834 bool set_photon_subdivs(int val, double time = TiMe::Default()) { return setValue("photon_subdivs", val, time); }
28837 int get_photon_subdivs(double time = TiMe::Default()) const { return getInt("photon_subdivs", time); }
28838
28841 bool set_use_convex_hull(bool val, double time = TiMe::Default()) { return setValue("use_convex_hull", val, time); }
28844 bool get_use_convex_hull(double time = TiMe::Default()) const { return getBool("use_convex_hull", time); }
28845
28848 bool set_intensity_threshold(float val, double time = TiMe::Default()) { return setValue("intensity_threshold", val, time); }
28851 float get_intensity_threshold(double time = TiMe::Default()) const { return getFloat("intensity_threshold", time); }
28852
28855 bool set_minimize_box(bool val, double time = TiMe::Default()) { return setValue("minimize_box", val, time); }
28858 bool get_minimize_box(double time = TiMe::Default()) const { return getBool("minimize_box", time); }
28859
28862 bool set_minimize_box_threshold(float val, double time = TiMe::Default()) { return setValue("minimize_box_threshold", val, time); }
28865 float get_minimize_box_threshold(double time = TiMe::Default()) const { return getFloat("minimize_box_threshold", time); }
28866
28869 bool set_max_unoccluded_photons(float val, double time = TiMe::Default()) { return setValue("max_unoccluded_photons", val, time); }
28872 float get_max_unoccluded_photons(double time = TiMe::Default()) const { return getFloat("max_unoccluded_photons", time); }
28873
28876 bool set_viewpoint_supersamples(int val, double time = TiMe::Default()) { return setValue("viewpoint_supersamples", val, time); }
28879 int get_viewpoint_supersamples(double time = TiMe::Default()) const { return getInt("viewpoint_supersamples", time); }
28880};
28881
28884public:
28886 static constexpr const PluginTypeId getTypeId() { return 0x2EF6EB9B2B; }
28888 static constexpr const char* getType() { return "MaterialOverrider"; }
28889
28890 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
28891
28895 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
28899 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
28900
28903 bool set_inclusion_nodes(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("inclusion_nodes", pluginList, time); }
28904 bool set_inclusion_nodes(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("inclusion_nodes", plugins, count, time); }
28905 template<size_t count> bool set_inclusion_nodes(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("inclusion_nodes", plugins, count, time); }
28908 PluginList get_inclusion_nodes(double time = TiMe::Default()) const { return getPluginList("inclusion_nodes", time); }
28909
28912 bool set_inclusion_materials(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("inclusion_materials", pluginList, time); }
28913 bool set_inclusion_materials(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("inclusion_materials", plugins, count, time); }
28914 template<size_t count> bool set_inclusion_materials(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("inclusion_materials", plugins, count, time); }
28917 PluginList get_inclusion_materials(double time = TiMe::Default()) const { return getPluginList("inclusion_materials", time); }
28918
28922 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
28926 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
28927
28930 bool set_global_material(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("global_material", plugin, time); }
28933 PluginRef get_global_material(double time = TiMe::Default()) const { return getPlugin("global_material", time); }
28934
28937 bool set_excluded_nodes_material(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("excluded_nodes_material", plugin, time); }
28940 PluginRef get_excluded_nodes_material(double time = TiMe::Default()) const { return getPlugin("excluded_nodes_material", time); }
28941
28945 bool set_override_lights_visibility(bool val, double time = TiMe::Default()) { return setValue("override_lights_visibility", val, time); }
28949 bool get_override_lights_visibility(double time = TiMe::Default()) const { return getBool("override_lights_visibility", time); }
28950
28953 bool set_visible_lights(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("visible_lights", pluginList, time); }
28954 bool set_visible_lights(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("visible_lights", plugins, count, time); }
28955 template<size_t count> bool set_visible_lights(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("visible_lights", plugins, count, time); }
28958 PluginList get_visible_lights(double time = TiMe::Default()) const { return getPluginList("visible_lights", time); }
28959
28963 bool set_first_hit_only(bool val, double time = TiMe::Default()) { return setValue("first_hit_only", val, time); }
28967 bool get_first_hit_only(double time = TiMe::Default()) const { return getBool("first_hit_only", time); }
28968
28971 bool set_patterns(const StringList& stringList, double time = TiMe::Default()) { return setValue("patterns", stringList, time); }
28974 StringList get_patterns(double time = TiMe::Default()) const { return getStringList("patterns", time); }
28975};
28976
28978class MayaGamma : public Plugin {
28979public:
28981 static constexpr const PluginTypeId getTypeId() { return 0x77923E47; }
28983 static constexpr const char* getType() { return "MayaGamma"; }
28984
28985 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
28986
28989 bool set_input(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
28992 bool set_input(const AColor& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
28995 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
28996
28999 bool set_gamma(const PluginRef& texture, double time = TiMe::Default()) { return setValue("gamma", texture, time); }
29002 bool set_gamma(const AColor& texture, double time = TiMe::Default()) { return setValue("gamma", texture, time); }
29005 Value get_gamma(double time = TiMe::Default()) const { return getValue("gamma", time); }
29006
29008 PluginRef out_color() const { return PluginRef(*this, "color"); }
29009};
29010
29012class MayaLightDirect : public Plugin {
29013public:
29015 static constexpr const PluginTypeId getTypeId() { return 0x778257A0; }
29017 static constexpr const char* getType() { return "MayaLightDirect"; }
29018
29019 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
29020
29024 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
29028 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
29029
29033 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
29037 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
29038
29041 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
29044 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
29045
29049 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
29053 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
29054
29057 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
29060 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
29063 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
29064
29068 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
29072 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
29073
29077 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
29081 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
29082
29086 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
29090 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
29091
29095 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
29099 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
29100
29104 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
29108 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
29109
29113 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
29117 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
29118
29122 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
29126 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
29127
29131 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
29135 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
29136
29140 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
29144 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
29145
29149 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
29153 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
29154
29158 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
29162 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
29163
29167 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
29171 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
29172
29175 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
29178 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
29181 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
29182
29186 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
29190 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
29191
29195 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
29199 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
29200
29204 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
29208 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
29209
29213 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
29217 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
29218
29222 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
29226 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
29227
29231 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
29235 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
29236
29240 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
29244 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
29245
29248 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
29249 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
29250 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
29253 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
29254
29257 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
29258 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
29259 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
29262 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
29263
29266 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
29267 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
29268 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
29271 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
29272
29275 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
29276 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
29277 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
29280 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
29281
29284 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
29285 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
29286 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
29289 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
29290
29294 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
29298 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
29302 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
29303
29307 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
29311 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
29312
29316 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
29320 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
29321
29324 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
29327 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
29330 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
29331
29335 bool set_areaSpeculars(bool val, double time = TiMe::Default()) { return setValue("areaSpeculars", val, time); }
29339 bool get_areaSpeculars(double time = TiMe::Default()) const { return getBool("areaSpeculars", time); }
29340
29344 bool set_shadowRadius(float val, double time = TiMe::Default()) { return setValue("shadowRadius", val, time); }
29348 float get_shadowRadius(double time = TiMe::Default()) const { return getFloat("shadowRadius", time); }
29349
29352 bool set_shadowRadius_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
29355 bool set_shadowRadius_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadowRadius_tex", texturefloat, time); }
29358 Value get_shadowRadius_tex(double time = TiMe::Default()) const { return getValue("shadowRadius_tex", time); }
29359
29363 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
29367 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
29368
29372 bool set_shadowSubdivs(int val, double time = TiMe::Default()) { return setValue("shadowSubdivs", val, time); }
29376 int get_shadowSubdivs(double time = TiMe::Default()) const { return getInt("shadowSubdivs", time); }
29377
29381 bool set_shadowRadiusMode(int val, double time = TiMe::Default()) { return setValue("shadowRadiusMode", val, time); }
29385 int get_shadowRadiusMode(double time = TiMe::Default()) const { return getInt("shadowRadiusMode", time); }
29386
29390 bool set_beamRadius(float val, double time = TiMe::Default()) { return setValue("beamRadius", val, time); }
29394 float get_beamRadius(double time = TiMe::Default()) const { return getFloat("beamRadius", time); }
29395};
29396
29398class MayaMtlMatte : public Plugin {
29399public:
29401 static constexpr const PluginTypeId getTypeId() { return 0x7792DAE9; }
29403 static constexpr const char* getType() { return "MayaMtlMatte"; }
29404
29405 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
29406
29407 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
29408
29412 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
29416 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
29417
29419 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
29421 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
29422
29424 bool set_matte_opacity(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("matte_opacity", texturefloat, time); }
29426 bool set_matte_opacity(float texturefloat, double time = TiMe::Default()) { return setValue("matte_opacity", texturefloat, time); }
29428 Value get_matte_opacity(double time = TiMe::Default()) const { return getValue("matte_opacity", time); }
29429
29431 bool set_alpha_transparency(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_transparency", texturefloat, time); }
29433 bool set_alpha_transparency(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_transparency", texturefloat, time); }
29435 Value get_alpha_transparency(double time = TiMe::Default()) const { return getValue("alpha_transparency", time); }
29436};
29437
29440public:
29442 static constexpr const PluginTypeId getTypeId() { return 0x77923E46; }
29444 static constexpr const char* getType() { return "MayaMultiplyDivide"; }
29445
29446 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
29447
29450 bool set_color1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
29453 bool set_color1(const AColor& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
29456 Value get_color1(double time = TiMe::Default()) const { return getValue("color1", time); }
29457
29460 bool set_color2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
29463 bool set_color2(const AColor& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
29466 Value get_color2(double time = TiMe::Default()) const { return getValue("color2", time); }
29467
29471 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
29475 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
29476
29478 PluginRef out_color() const { return PluginRef(*this, "color"); }
29479};
29480
29482public:
29484 static constexpr const PluginTypeId getTypeId() { return 0x77B07185; }
29486 static constexpr const char* getType() { return "MayaProjectionTex"; }
29487
29488 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
29489
29493 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
29497 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
29498
29502 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
29506 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
29507
29511 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
29515 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
29516
29520 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
29524 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
29525
29529 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
29533 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
29537 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
29538
29542 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
29546 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
29550 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
29551
29555 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
29559 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
29563 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
29564
29568 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
29572 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
29576 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
29577
29581 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
29585 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
29589 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
29590
29592 PluginRef out_color() const { return PluginRef(*this, "color"); }
29593
29595 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
29596
29598 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
29599
29601 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
29602
29605 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
29608 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
29609
29613 bool set_wrap(bool val, double time = TiMe::Default()) { return setValue("wrap", val, time); }
29617 bool get_wrap(double time = TiMe::Default()) const { return getBool("wrap", time); }
29618
29622 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
29626 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
29627
29631 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
29635 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
29636
29640 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
29644 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
29645
29649 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
29653 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
29654
29658 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
29662 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
29663
29667 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
29671 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
29672
29676 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
29680 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
29681
29685 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
29689 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
29690
29694 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
29698 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
29699
29703 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
29707 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
29708
29712 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
29716 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
29717
29721 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
29725 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
29726
29730 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
29734 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
29735
29739 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
29743 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
29744
29747 bool set_base_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base_texture", texture, time); }
29750 bool set_base_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("base_texture", texture, time); }
29753 Value get_base_texture(double time = TiMe::Default()) const { return getValue("base_texture", time); }
29754
29757 bool set_nouvw_transparency(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_transparency", texture, time); }
29760 bool set_nouvw_transparency(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_transparency", texture, time); }
29763 Value get_nouvw_transparency(double time = TiMe::Default()) const { return getValue("nouvw_transparency", time); }
29764
29767 bool set_transparency_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_mult", texture, time); }
29770 bool set_transparency_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_mult", texture, time); }
29773 Value get_transparency_mult(double time = TiMe::Default()) const { return getValue("transparency_mult", time); }
29774
29777 bool set_transparency_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_offset", texture, time); }
29780 bool set_transparency_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_offset", texture, time); }
29783 Value get_transparency_offset(double time = TiMe::Default()) const { return getValue("transparency_offset", time); }
29784};
29785
29787class MeshGeometryTrim : public Plugin {
29788public:
29790 static constexpr const PluginTypeId getTypeId() { return 0xC0EEEA7; }
29792 static constexpr const char* getType() { return "MeshGeometryTrim"; }
29793
29796 bool set_visibility_list(const IntList& intList, double time = TiMe::Default()) { return setValue("visibility_list", intList, time); }
29797 bool set_visibility_list(IntList&& intList, double time = TiMe::Default()) { return setValue("visibility_list", std::move(intList), time); }
29798 bool set_visibility_list(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("visibility_list", ints, count, time); }
29799 template<size_t count> bool set_visibility_list(const int (&ints)[count], double time = TiMe::Default()) { return setArray("visibility_list", ints, count, time); }
29802 IntList get_visibility_list(double time = TiMe::Default()) const { return getIntList("visibility_list", time); }
29803
29806 bool set_voxels_face_basis(const IntList& intList, double time = TiMe::Default()) { return setValue("voxels_face_basis", intList, time); }
29807 bool set_voxels_face_basis(IntList&& intList, double time = TiMe::Default()) { return setValue("voxels_face_basis", std::move(intList), time); }
29808 bool set_voxels_face_basis(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("voxels_face_basis", ints, count, time); }
29809 template<size_t count> bool set_voxels_face_basis(const int (&ints)[count], double time = TiMe::Default()) { return setArray("voxels_face_basis", ints, count, time); }
29812 IntList get_voxels_face_basis(double time = TiMe::Default()) const { return getIntList("voxels_face_basis", time); }
29813};
29814
29816class Mtl2Sided : public Plugin {
29817public:
29819 static constexpr const PluginTypeId getTypeId() { return 0x779347CD; }
29821 static constexpr const char* getType() { return "Mtl2Sided"; }
29822
29823 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
29824
29825 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
29826
29829 bool set_front(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("front", plugin, time); }
29832 PluginRef get_front(double time = TiMe::Default()) const { return getPlugin("front", time); }
29833
29836 bool set_back(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("back", plugin, time); }
29839 PluginRef get_back(double time = TiMe::Default()) const { return getPlugin("back", time); }
29840
29844 bool set_translucency(const Color& color, double time = TiMe::Default()) { return setValue("translucency", color, time); }
29848 Color get_translucency(double time = TiMe::Default()) const { return getColor("translucency", time); }
29849
29852 bool set_translucency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("translucency_tex", texture, time); }
29855 bool set_translucency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("translucency_tex", texture, time); }
29858 Value get_translucency_tex(double time = TiMe::Default()) const { return getValue("translucency_tex", time); }
29859
29863 bool set_translucency_tex_mult(float val, double time = TiMe::Default()) { return setValue("translucency_tex_mult", val, time); }
29867 float get_translucency_tex_mult(double time = TiMe::Default()) const { return getFloat("translucency_tex_mult", time); }
29868
29872 bool set_force_1sided(bool val, double time = TiMe::Default()) { return setValue("force_1sided", val, time); }
29876 bool get_force_1sided(double time = TiMe::Default()) const { return getBool("force_1sided", time); }
29877
29881 bool set_mult_by_front_diffuse(bool val, double time = TiMe::Default()) { return setValue("mult_by_front_diffuse", val, time); }
29885 bool get_mult_by_front_diffuse(double time = TiMe::Default()) const { return getBool("mult_by_front_diffuse", time); }
29886
29889 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
29890 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
29891 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
29894 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
29895};
29896
29898class MtlDoubleSided : public Plugin {
29899public:
29901 static constexpr const PluginTypeId getTypeId() { return 0x7782FC69; }
29903 static constexpr const char* getType() { return "MtlDoubleSided"; }
29904
29905 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
29906
29907 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
29908
29910 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
29912 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
29913};
29914
29916class MtlGLSL : public Plugin {
29917public:
29919 static constexpr const PluginTypeId getTypeId() { return 0x77CE7EBE; }
29921 static constexpr const char* getType() { return "MtlGLSL"; }
29922
29923 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
29924
29925 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
29926
29927 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
29928
29932 bool set_shader_file(const char* str, double time = TiMe::Default()) { return setValue("shader_file", str, time); }
29936 bool set_shader_file(const std::string& str, double time = TiMe::Default()) { return setValue("shader_file", str, time); }
29940 std::string get_shader_file(double time = TiMe::Default()) const { return getString("shader_file", time); }
29941
29943 bool set_uvw_generators(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("uvw_generators", pluginList, time); }
29944 bool set_uvw_generators(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("uvw_generators", plugins, count, time); }
29945 template<size_t count> bool set_uvw_generators(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("uvw_generators", plugins, count, time); }
29947 PluginList get_uvw_generators(double time = TiMe::Default()) const { return getPluginList("uvw_generators", time); }
29948
29952 bool set_transparency(const Color& color, double time = TiMe::Default()) { return setValue("transparency", color, time); }
29956 Color get_transparency(double time = TiMe::Default()) const { return getColor("transparency", time); }
29957
29960 bool set_transparency_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
29963 bool set_transparency_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("transparency_tex", texture, time); }
29966 Value get_transparency_tex(double time = TiMe::Default()) const { return getValue("transparency_tex", time); }
29967
29971 bool set_transparency_tex_mult(float val, double time = TiMe::Default()) { return setValue("transparency_tex_mult", val, time); }
29975 float get_transparency_tex_mult(double time = TiMe::Default()) const { return getFloat("transparency_tex_mult", time); }
29976
29979 bool set_use_shader_alpha(bool val, double time = TiMe::Default()) { return setValue("use_shader_alpha", val, time); }
29982 bool get_use_shader_alpha(double time = TiMe::Default()) const { return getBool("use_shader_alpha", time); }
29983
29985 bool set_uniforms(const ValueList& list, double time = TiMe::Default()) { return setValue("uniforms", list, time); }
29986 bool set_uniforms(ValueList&& list, double time = TiMe::Default()) { return setValue("uniforms", std::move(list), time); }
29987 bool set_uniforms(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("uniforms", values, count, time); }
29988 template<size_t count> bool set_uniforms(const Value (&values)[count], double time = TiMe::Default()) { return setArray("uniforms", values, count, time); }
29989 template<size_t count> bool set_uniforms(Value (&&values)[count], double time = TiMe::Default()) { return setArray("uniforms", values, count, time); }
29991 ValueList get_uniforms(double time = TiMe::Default()) const { return getValueList("uniforms", time); }
29992
29995 bool set_max_ray_depth(int val, double time = TiMe::Default()) { return setValue("max_ray_depth", val, time); }
29998 int get_max_ray_depth(double time = TiMe::Default()) const { return getInt("max_ray_depth", time); }
29999
30002 bool set_clamp_result(bool val, double time = TiMe::Default()) { return setValue("clamp_result", val, time); }
30005 bool get_clamp_result(double time = TiMe::Default()) const { return getBool("clamp_result", time); }
30006
30009 bool set_clamp_value(float val, double time = TiMe::Default()) { return setValue("clamp_value", val, time); }
30012 float get_clamp_value(double time = TiMe::Default()) const { return getFloat("clamp_value", time); }
30013
30016 bool set_use_inline_shader(bool val, double time = TiMe::Default()) { return setValue("use_inline_shader", val, time); }
30019 bool get_use_inline_shader(double time = TiMe::Default()) const { return getBool("use_inline_shader", time); }
30020
30024 bool set_inline_shader(const char* str, double time = TiMe::Default()) { return setValue("inline_shader", str, time); }
30028 bool set_inline_shader(const std::string& str, double time = TiMe::Default()) { return setValue("inline_shader", str, time); }
30032 std::string get_inline_shader(double time = TiMe::Default()) const { return getString("inline_shader", time); }
30033
30035 bool set_vertex_channels(const ValueList& list, double time = TiMe::Default()) { return setValue("vertex_channels", list, time); }
30036 bool set_vertex_channels(ValueList&& list, double time = TiMe::Default()) { return setValue("vertex_channels", std::move(list), time); }
30037 bool set_vertex_channels(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("vertex_channels", values, count, time); }
30038 template<size_t count> bool set_vertex_channels(const Value (&values)[count], double time = TiMe::Default()) { return setArray("vertex_channels", values, count, time); }
30039 template<size_t count> bool set_vertex_channels(Value (&&values)[count], double time = TiMe::Default()) { return setArray("vertex_channels", values, count, time); }
30041 ValueList get_vertex_channels(double time = TiMe::Default()) const { return getValueList("vertex_channels", time); }
30042
30045 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
30046 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30047 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30050 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
30051
30054 bool set_bump_replaces_normal(bool val, double time = TiMe::Default()) { return setValue("bump_replaces_normal", val, time); }
30057 bool get_bump_replaces_normal(double time = TiMe::Default()) const { return getBool("bump_replaces_normal", time); }
30058};
30059
30061class MtlMDL : public Plugin {
30062public:
30064 static constexpr const PluginTypeId getTypeId() { return 0x781C2AF0; }
30066 static constexpr const char* getType() { return "MtlMDL"; }
30067
30068 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30069
30070 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30071
30074 bool set_mdl_module(const char* str, double time = TiMe::Default()) { return setValue("mdl_module", str, time); }
30077 bool set_mdl_module(const std::string& str, double time = TiMe::Default()) { return setValue("mdl_module", str, time); }
30080 std::string get_mdl_module(double time = TiMe::Default()) const { return getString("mdl_module", time); }
30081
30084 bool set_mdl_material(const char* str, double time = TiMe::Default()) { return setValue("mdl_material", str, time); }
30087 bool set_mdl_material(const std::string& str, double time = TiMe::Default()) { return setValue("mdl_material", str, time); }
30090 std::string get_mdl_material(double time = TiMe::Default()) const { return getString("mdl_material", time); }
30091
30094 bool set_mdl_material_signature(const char* str, double time = TiMe::Default()) { return setValue("mdl_material_signature", str, time); }
30097 bool set_mdl_material_signature(const std::string& str, double time = TiMe::Default()) { return setValue("mdl_material_signature", str, time); }
30100 std::string get_mdl_material_signature(double time = TiMe::Default()) const { return getString("mdl_material_signature", time); }
30101
30103 bool set_input_parameters(const ValueList& list, double time = TiMe::Default()) { return setValue("input_parameters", list, time); }
30104 bool set_input_parameters(ValueList&& list, double time = TiMe::Default()) { return setValue("input_parameters", std::move(list), time); }
30105 bool set_input_parameters(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("input_parameters", values, count, time); }
30106 template<size_t count> bool set_input_parameters(const Value (&values)[count], double time = TiMe::Default()) { return setArray("input_parameters", values, count, time); }
30107 template<size_t count> bool set_input_parameters(Value (&&values)[count], double time = TiMe::Default()) { return setArray("input_parameters", values, count, time); }
30109 ValueList get_input_parameters(double time = TiMe::Default()) const { return getValueList("input_parameters", time); }
30110
30112 bool set_uvw_generators(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("uvw_generators", pluginList, time); }
30113 bool set_uvw_generators(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("uvw_generators", plugins, count, time); }
30114 template<size_t count> bool set_uvw_generators(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("uvw_generators", plugins, count, time); }
30116 PluginList get_uvw_generators(double time = TiMe::Default()) const { return getPluginList("uvw_generators", time); }
30117
30120 bool set_max_ray_depth(int val, double time = TiMe::Default()) { return setValue("max_ray_depth", val, time); }
30123 int get_max_ray_depth(double time = TiMe::Default()) const { return getInt("max_ray_depth", time); }
30124
30127 bool set_mdl_path_list(const char* str, double time = TiMe::Default()) { return setValue("mdl_path_list", str, time); }
30130 bool set_mdl_path_list(const std::string& str, double time = TiMe::Default()) { return setValue("mdl_path_list", str, time); }
30133 std::string get_mdl_path_list(double time = TiMe::Default()) const { return getString("mdl_path_list", time); }
30134
30136 bool set_imports_list(const ValueList& list, double time = TiMe::Default()) { return setValue("imports_list", list, time); }
30137 bool set_imports_list(ValueList&& list, double time = TiMe::Default()) { return setValue("imports_list", std::move(list), time); }
30138 bool set_imports_list(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("imports_list", values, count, time); }
30139 template<size_t count> bool set_imports_list(const Value (&values)[count], double time = TiMe::Default()) { return setArray("imports_list", values, count, time); }
30140 template<size_t count> bool set_imports_list(Value (&&values)[count], double time = TiMe::Default()) { return setArray("imports_list", values, count, time); }
30142 ValueList get_imports_list(double time = TiMe::Default()) const { return getValueList("imports_list", time); }
30143
30146 bool set_remap_roughness(int val, double time = TiMe::Default()) { return setValue("remap_roughness", val, time); }
30149 int get_remap_roughness(double time = TiMe::Default()) const { return getInt("remap_roughness", time); }
30150
30154 bool set_try_to_use_vraymtl(int val, double time = TiMe::Default()) { return setValue("try_to_use_vraymtl", val, time); }
30158 int get_try_to_use_vraymtl(double time = TiMe::Default()) const { return getInt("try_to_use_vraymtl", time); }
30159
30161 PluginRef out_displacement_tex() const { return PluginRef(*this, "displacement_tex"); }
30162
30165 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
30166 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30167 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30170 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
30171};
30172
30174class MtlMaterialID : public Plugin {
30175public:
30177 static constexpr const PluginTypeId getTypeId() { return 0x77B41398; }
30179 static constexpr const char* getType() { return "MtlMaterialID"; }
30180
30181 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30182
30183 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30184
30187 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
30190 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
30191
30194 bool set_material_id_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("material_id_color", texture, time); }
30197 bool set_material_id_color(const AColor& texture, double time = TiMe::Default()) { return setValue("material_id_color", texture, time); }
30200 Value get_material_id_color(double time = TiMe::Default()) const { return getValue("material_id_color", time); }
30201
30205 bool set_material_id_number(int val, double time = TiMe::Default()) { return setValue("material_id_number", val, time); }
30209 int get_material_id_number(double time = TiMe::Default()) const { return getInt("material_id_number", time); }
30210
30214 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
30218 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
30222 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
30223};
30224
30226class MtlMayaRamp : public Plugin {
30227public:
30229 static constexpr const PluginTypeId getTypeId() { return 0x77C09D5D; }
30231 static constexpr const char* getType() { return "MtlMayaRamp"; }
30232
30233 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30234
30235 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30236
30238 bool set_color_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("color_positions", list, time); }
30239 bool set_color_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("color_positions", std::move(list), time); }
30240 bool set_color_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("color_positions", values, count, time); }
30241 template<size_t count> bool set_color_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("color_positions", values, count, time); }
30242 template<size_t count> bool set_color_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("color_positions", values, count, time); }
30244 ValueList get_color_positions(double time = TiMe::Default()) const { return getValueList("color_positions", time); }
30245
30247 bool set_color_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("color_colors", textureList, time); }
30248 bool set_color_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("color_colors", std::move(textureList), time); }
30249 bool set_color_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("color_colors", textures, count, time); }
30250 template<size_t count> bool set_color_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("color_colors", textures, count, time); }
30251 template<size_t count> bool set_color_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("color_colors", textures, count, time); }
30253 ValueList get_color_colors(double time = TiMe::Default()) const { return getValueList("color_colors", time); }
30254
30257 bool set_color_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("color_interpolations", intList, time); }
30258 bool set_color_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("color_interpolations", std::move(intList), time); }
30259 bool set_color_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("color_interpolations", ints, count, time); }
30260 template<size_t count> bool set_color_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("color_interpolations", ints, count, time); }
30263 IntList get_color_interpolations(double time = TiMe::Default()) const { return getIntList("color_interpolations", time); }
30264
30267 bool set_color_input(int val, double time = TiMe::Default()) { return setValue("color_input", val, time); }
30270 int get_color_input(double time = TiMe::Default()) const { return getInt("color_input", time); }
30271
30273 bool set_transp_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("transp_positions", list, time); }
30274 bool set_transp_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("transp_positions", std::move(list), time); }
30275 bool set_transp_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("transp_positions", values, count, time); }
30276 template<size_t count> bool set_transp_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("transp_positions", values, count, time); }
30277 template<size_t count> bool set_transp_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("transp_positions", values, count, time); }
30279 ValueList get_transp_positions(double time = TiMe::Default()) const { return getValueList("transp_positions", time); }
30280
30282 bool set_transp_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("transp_colors", textureList, time); }
30283 bool set_transp_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("transp_colors", std::move(textureList), time); }
30284 bool set_transp_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("transp_colors", textures, count, time); }
30285 template<size_t count> bool set_transp_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("transp_colors", textures, count, time); }
30286 template<size_t count> bool set_transp_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("transp_colors", textures, count, time); }
30288 ValueList get_transp_colors(double time = TiMe::Default()) const { return getValueList("transp_colors", time); }
30289
30292 bool set_transp_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("transp_interpolations", intList, time); }
30293 bool set_transp_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("transp_interpolations", std::move(intList), time); }
30294 bool set_transp_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("transp_interpolations", ints, count, time); }
30295 template<size_t count> bool set_transp_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("transp_interpolations", ints, count, time); }
30298 IntList get_transp_interpolations(double time = TiMe::Default()) const { return getIntList("transp_interpolations", time); }
30299
30301 bool set_incan_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("incan_positions", list, time); }
30302 bool set_incan_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("incan_positions", std::move(list), time); }
30303 bool set_incan_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("incan_positions", values, count, time); }
30304 template<size_t count> bool set_incan_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("incan_positions", values, count, time); }
30305 template<size_t count> bool set_incan_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("incan_positions", values, count, time); }
30307 ValueList get_incan_positions(double time = TiMe::Default()) const { return getValueList("incan_positions", time); }
30308
30310 bool set_incan_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("incan_colors", textureList, time); }
30311 bool set_incan_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("incan_colors", std::move(textureList), time); }
30312 bool set_incan_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("incan_colors", textures, count, time); }
30313 template<size_t count> bool set_incan_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("incan_colors", textures, count, time); }
30314 template<size_t count> bool set_incan_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("incan_colors", textures, count, time); }
30316 ValueList get_incan_colors(double time = TiMe::Default()) const { return getValueList("incan_colors", time); }
30317
30320 bool set_incan_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("incan_interpolations", intList, time); }
30321 bool set_incan_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("incan_interpolations", std::move(intList), time); }
30322 bool set_incan_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("incan_interpolations", ints, count, time); }
30323 template<size_t count> bool set_incan_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("incan_interpolations", ints, count, time); }
30326 IntList get_incan_interpolations(double time = TiMe::Default()) const { return getIntList("incan_interpolations", time); }
30327
30329 bool set_specular_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("specular_positions", list, time); }
30330 bool set_specular_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("specular_positions", std::move(list), time); }
30331 bool set_specular_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("specular_positions", values, count, time); }
30332 template<size_t count> bool set_specular_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("specular_positions", values, count, time); }
30333 template<size_t count> bool set_specular_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("specular_positions", values, count, time); }
30335 ValueList get_specular_positions(double time = TiMe::Default()) const { return getValueList("specular_positions", time); }
30336
30338 bool set_specular_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("specular_colors", textureList, time); }
30339 bool set_specular_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("specular_colors", std::move(textureList), time); }
30340 bool set_specular_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("specular_colors", textures, count, time); }
30341 template<size_t count> bool set_specular_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("specular_colors", textures, count, time); }
30342 template<size_t count> bool set_specular_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("specular_colors", textures, count, time); }
30344 ValueList get_specular_colors(double time = TiMe::Default()) const { return getValueList("specular_colors", time); }
30345
30348 bool set_specular_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("specular_interpolations", intList, time); }
30349 bool set_specular_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("specular_interpolations", std::move(intList), time); }
30350 bool set_specular_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("specular_interpolations", ints, count, time); }
30351 template<size_t count> bool set_specular_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("specular_interpolations", ints, count, time); }
30354 IntList get_specular_interpolations(double time = TiMe::Default()) const { return getIntList("specular_interpolations", time); }
30355
30357 bool set_environm_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("environm_positions", list, time); }
30358 bool set_environm_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("environm_positions", std::move(list), time); }
30359 bool set_environm_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("environm_positions", values, count, time); }
30360 template<size_t count> bool set_environm_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("environm_positions", values, count, time); }
30361 template<size_t count> bool set_environm_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("environm_positions", values, count, time); }
30363 ValueList get_environm_positions(double time = TiMe::Default()) const { return getValueList("environm_positions", time); }
30364
30366 bool set_environm_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("environm_colors", textureList, time); }
30367 bool set_environm_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("environm_colors", std::move(textureList), time); }
30368 bool set_environm_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("environm_colors", textures, count, time); }
30369 template<size_t count> bool set_environm_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("environm_colors", textures, count, time); }
30370 template<size_t count> bool set_environm_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("environm_colors", textures, count, time); }
30372 ValueList get_environm_colors(double time = TiMe::Default()) const { return getValueList("environm_colors", time); }
30373
30376 bool set_environm_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("environm_interpolations", intList, time); }
30377 bool set_environm_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("environm_interpolations", std::move(intList), time); }
30378 bool set_environm_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("environm_interpolations", ints, count, time); }
30379 template<size_t count> bool set_environm_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("environm_interpolations", ints, count, time); }
30382 IntList get_environm_interpolations(double time = TiMe::Default()) const { return getIntList("environm_interpolations", time); }
30383
30385 bool set_specularRollOff_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("specularRollOff_positions", list, time); }
30386 bool set_specularRollOff_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("specularRollOff_positions", std::move(list), time); }
30387 bool set_specularRollOff_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("specularRollOff_positions", values, count, time); }
30388 template<size_t count> bool set_specularRollOff_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("specularRollOff_positions", values, count, time); }
30389 template<size_t count> bool set_specularRollOff_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("specularRollOff_positions", values, count, time); }
30391 ValueList get_specularRollOff_positions(double time = TiMe::Default()) const { return getValueList("specularRollOff_positions", time); }
30392
30394 bool set_specularRollOff_values(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("specularRollOff_values", texturefloatList, time); }
30395 bool set_specularRollOff_values(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("specularRollOff_values", std::move(texturefloatList), time); }
30396 bool set_specularRollOff_values(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("specularRollOff_values", texturefloats, count, time); }
30397 template<size_t count> bool set_specularRollOff_values(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("specularRollOff_values", texturefloats, count, time); }
30398 template<size_t count> bool set_specularRollOff_values(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("specularRollOff_values", texturefloats, count, time); }
30400 ValueList get_specularRollOff_values(double time = TiMe::Default()) const { return getValueList("specularRollOff_values", time); }
30401
30404 bool set_specularRollOff_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("specularRollOff_interpolations", intList, time); }
30405 bool set_specularRollOff_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("specularRollOff_interpolations", std::move(intList), time); }
30406 bool set_specularRollOff_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("specularRollOff_interpolations", ints, count, time); }
30407 template<size_t count> bool set_specularRollOff_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("specularRollOff_interpolations", ints, count, time); }
30410 IntList get_specularRollOff_interpolations(double time = TiMe::Default()) const { return getIntList("specularRollOff_interpolations", time); }
30411
30413 bool set_reflectivity_positions(const ValueList& list, double time = TiMe::Default()) { return setValue("reflectivity_positions", list, time); }
30414 bool set_reflectivity_positions(ValueList&& list, double time = TiMe::Default()) { return setValue("reflectivity_positions", std::move(list), time); }
30415 bool set_reflectivity_positions(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("reflectivity_positions", values, count, time); }
30416 template<size_t count> bool set_reflectivity_positions(const Value (&values)[count], double time = TiMe::Default()) { return setArray("reflectivity_positions", values, count, time); }
30417 template<size_t count> bool set_reflectivity_positions(Value (&&values)[count], double time = TiMe::Default()) { return setArray("reflectivity_positions", values, count, time); }
30419 ValueList get_reflectivity_positions(double time = TiMe::Default()) const { return getValueList("reflectivity_positions", time); }
30420
30422 bool set_reflectivity_values(const ValueList& texturefloatList, double time = TiMe::Default()) { return setValue("reflectivity_values", texturefloatList, time); }
30423 bool set_reflectivity_values(ValueList&& texturefloatList, double time = TiMe::Default()) { return setValue("reflectivity_values", std::move(texturefloatList), time); }
30424 bool set_reflectivity_values(const Value* texturefloats, size_t count, double time = TiMe::Default()) { return setArray("reflectivity_values", texturefloats, count, time); }
30425 template<size_t count> bool set_reflectivity_values(const Value (&texturefloats)[count], double time = TiMe::Default()) { return setArray("reflectivity_values", texturefloats, count, time); }
30426 template<size_t count> bool set_reflectivity_values(Value (&&texturefloats)[count], double time = TiMe::Default()) { return setArray("reflectivity_values", texturefloats, count, time); }
30428 ValueList get_reflectivity_values(double time = TiMe::Default()) const { return getValueList("reflectivity_values", time); }
30429
30432 bool set_reflectivity_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("reflectivity_interpolations", intList, time); }
30433 bool set_reflectivity_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("reflectivity_interpolations", std::move(intList), time); }
30434 bool set_reflectivity_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("reflectivity_interpolations", ints, count, time); }
30435 template<size_t count> bool set_reflectivity_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("reflectivity_interpolations", ints, count, time); }
30438 IntList get_reflectivity_interpolations(double time = TiMe::Default()) const { return getIntList("reflectivity_interpolations", time); }
30439
30442 bool set_ambient_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ambient_tex", texture, time); }
30445 bool set_ambient_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("ambient_tex", texture, time); }
30448 Value get_ambient_tex(double time = TiMe::Default()) const { return getValue("ambient_tex", time); }
30449
30452 bool set_eccentricity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("eccentricity_tex", texturefloat, time); }
30455 bool set_eccentricity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("eccentricity_tex", texturefloat, time); }
30458 Value get_eccentricity_tex(double time = TiMe::Default()) const { return getValue("eccentricity_tex", time); }
30459
30462 bool set_specularity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("specularity_tex", texturefloat, time); }
30465 bool set_specularity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("specularity_tex", texturefloat, time); }
30468 Value get_specularity_tex(double time = TiMe::Default()) const { return getValue("specularity_tex", time); }
30469
30472 bool set_diffuse_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("diffuse_tex", texturefloat, time); }
30475 bool set_diffuse_tex(float texturefloat, double time = TiMe::Default()) { return setValue("diffuse_tex", texturefloat, time); }
30478 Value get_diffuse_tex(double time = TiMe::Default()) const { return getValue("diffuse_tex", time); }
30479
30482 bool set_fscatter_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("fscatter_tex", texturefloat, time); }
30485 bool set_fscatter_tex(float texturefloat, double time = TiMe::Default()) { return setValue("fscatter_tex", texturefloat, time); }
30488 Value get_fscatter_tex(double time = TiMe::Default()) const { return getValue("fscatter_tex", time); }
30489
30492 bool set_reflection_limit(int val, double time = TiMe::Default()) { return setValue("reflection_limit", val, time); }
30495 int get_reflection_limit(double time = TiMe::Default()) const { return getInt("reflection_limit", time); }
30496
30499 bool set_refractions(bool val, double time = TiMe::Default()) { return setValue("refractions", val, time); }
30502 bool get_refractions(double time = TiMe::Default()) const { return getBool("refractions", time); }
30503
30506 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
30509 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
30510
30513 bool set_refraction_limit(int val, double time = TiMe::Default()) { return setValue("refraction_limit", val, time); }
30516 int get_refraction_limit(double time = TiMe::Default()) const { return getInt("refraction_limit", time); }
30517
30519 bool set_volume(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("volume", plugin, time); }
30521 PluginRef get_volume(double time = TiMe::Default()) const { return getPlugin("volume", time); }
30522
30524 bool set_bump_brdf(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("bump_brdf", plugin, time); }
30526 PluginRef get_bump_brdf(double time = TiMe::Default()) const { return getPlugin("bump_brdf", time); }
30527
30529 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
30530 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30531 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30533 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
30534};
30535
30537class MtlMulti : public Plugin {
30538public:
30540 static constexpr const PluginTypeId getTypeId() { return 0x7782AD1D; }
30542 static constexpr const char* getType() { return "MtlMulti"; }
30543
30544 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30545
30546 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30547
30548 operator VolumetricPluginCategory() { return *static_cast<VolumetricPluginCategory*>(static_cast<Plugin*>(this)); }
30549
30552 bool set_mtls(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("mtls", pluginList, time); }
30553 bool set_mtls(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("mtls", plugins, count, time); }
30554 template<size_t count> bool set_mtls(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("mtls", plugins, count, time); }
30557 PluginList get_mtls(double time = TiMe::Default()) const { return getPluginList("mtls", time); }
30558
30561 bool set_mtls_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("mtls_list", pluginList, time); }
30562 bool set_mtls_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("mtls_list", plugins, count, time); }
30563 template<size_t count> bool set_mtls_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("mtls_list", plugins, count, time); }
30566 PluginList get_mtls_list(double time = TiMe::Default()) const { return getPluginList("mtls_list", time); }
30567
30570 bool set_volumes_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("volumes_list", pluginList, time); }
30571 bool set_volumes_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("volumes_list", plugins, count, time); }
30572 template<size_t count> bool set_volumes_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("volumes_list", plugins, count, time); }
30575 PluginList get_volumes_list(double time = TiMe::Default()) const { return getPluginList("volumes_list", time); }
30576
30580 bool set_ids_list(const IntList& intList, double time = TiMe::Default()) { return setValue("ids_list", intList, time); }
30581 bool set_ids_list(IntList&& intList, double time = TiMe::Default()) { return setValue("ids_list", std::move(intList), time); }
30582 bool set_ids_list(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ids_list", ints, count, time); }
30583 template<size_t count> bool set_ids_list(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ids_list", ints, count, time); }
30587 IntList get_ids_list(double time = TiMe::Default()) const { return getIntList("ids_list", time); }
30588
30591 bool set_shader_sets_list(const StringList& stringList, double time = TiMe::Default()) { return setValue("shader_sets_list", stringList, time); }
30594 StringList get_shader_sets_list(double time = TiMe::Default()) const { return getStringList("shader_sets_list", time); }
30595
30599 bool set_use_shader_set_patterns(bool val, double time = TiMe::Default()) { return setValue("use_shader_set_patterns", val, time); }
30603 bool get_use_shader_set_patterns(double time = TiMe::Default()) const { return getBool("use_shader_set_patterns", time); }
30604
30607 bool set_mtlid_gen(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("mtlid_gen", textureint, time); }
30610 bool set_mtlid_gen(int textureint, double time = TiMe::Default()) { return setValue("mtlid_gen", textureint, time); }
30613 Value get_mtlid_gen(double time = TiMe::Default()) const { return getValue("mtlid_gen", time); }
30614
30617 bool set_mtlid_gen_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mtlid_gen_float", texturefloat, time); }
30620 bool set_mtlid_gen_float(float texturefloat, double time = TiMe::Default()) { return setValue("mtlid_gen_float", texturefloat, time); }
30623 Value get_mtlid_gen_float(double time = TiMe::Default()) const { return getValue("mtlid_gen_float", time); }
30624
30628 bool set_mtlid_gen_float_round_mode(int val, double time = TiMe::Default()) { return setValue("mtlid_gen_float_round_mode", val, time); }
30632 int get_mtlid_gen_float_round_mode(double time = TiMe::Default()) const { return getInt("mtlid_gen_float_round_mode", time); }
30633
30637 bool set_wrap_id(bool val, double time = TiMe::Default()) { return setValue("wrap_id", val, time); }
30641 bool get_wrap_id(double time = TiMe::Default()) const { return getBool("wrap_id", time); }
30642
30646 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
30650 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
30651
30654 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
30655 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30656 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30659 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
30660};
30661
30663class MtlOSL : public Plugin {
30664public:
30666 static constexpr const PluginTypeId getTypeId() { return 0x77ED26B8; }
30668 static constexpr const char* getType() { return "MtlOSL"; }
30669
30670 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30671
30672 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30673
30677 bool set_shader_file(const char* str, double time = TiMe::Default()) { return setValue("shader_file", str, time); }
30681 bool set_shader_file(const std::string& str, double time = TiMe::Default()) { return setValue("shader_file", str, time); }
30685 std::string get_shader_file(double time = TiMe::Default()) const { return getString("shader_file", time); }
30686
30688 bool set_input_parameters(const ValueList& list, double time = TiMe::Default()) { return setValue("input_parameters", list, time); }
30689 bool set_input_parameters(ValueList&& list, double time = TiMe::Default()) { return setValue("input_parameters", std::move(list), time); }
30690 bool set_input_parameters(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("input_parameters", values, count, time); }
30691 template<size_t count> bool set_input_parameters(const Value (&values)[count], double time = TiMe::Default()) { return setArray("input_parameters", values, count, time); }
30692 template<size_t count> bool set_input_parameters(Value (&&values)[count], double time = TiMe::Default()) { return setArray("input_parameters", values, count, time); }
30694 ValueList get_input_parameters(double time = TiMe::Default()) const { return getValueList("input_parameters", time); }
30695
30698 bool set_output_closure(const char* str, double time = TiMe::Default()) { return setValue("output_closure", str, time); }
30701 bool set_output_closure(const std::string& str, double time = TiMe::Default()) { return setValue("output_closure", str, time); }
30704 std::string get_output_closure(double time = TiMe::Default()) const { return getString("output_closure", time); }
30705
30707 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
30709 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
30710
30714 bool set_max_ray_depth(int val, double time = TiMe::Default()) { return setValue("max_ray_depth", val, time); }
30718 int get_max_ray_depth(double time = TiMe::Default()) const { return getInt("max_ray_depth", time); }
30719
30722 bool set_include_path(const char* str, double time = TiMe::Default()) { return setValue("include_path", str, time); }
30725 bool set_include_path(const std::string& str, double time = TiMe::Default()) { return setValue("include_path", str, time); }
30728 std::string get_include_path(double time = TiMe::Default()) const { return getString("include_path", time); }
30729
30732 bool set_shader_type(int val, double time = TiMe::Default()) { return setValue("shader_type", val, time); }
30735 int get_shader_type(double time = TiMe::Default()) const { return getInt("shader_type", time); }
30736
30739 bool set_inline_shader(const char* str, double time = TiMe::Default()) { return setValue("inline_shader", str, time); }
30742 bool set_inline_shader(const std::string& str, double time = TiMe::Default()) { return setValue("inline_shader", str, time); }
30745 std::string get_inline_shader(double time = TiMe::Default()) const { return getString("inline_shader", time); }
30746
30749 bool set_graph_owner(int val, double time = TiMe::Default()) { return setValue("graph_owner", val, time); }
30752 int get_graph_owner(double time = TiMe::Default()) const { return getInt("graph_owner", time); }
30753
30756 bool set_flip_textures(int val, double time = TiMe::Default()) { return setValue("flip_textures", val, time); }
30759 int get_flip_textures(double time = TiMe::Default()) const { return getInt("flip_textures", time); }
30760
30763 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
30764 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30765 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
30768 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
30769};
30770
30772class MtlObjBBox : public Plugin {
30773public:
30775 static constexpr const PluginTypeId getTypeId() { return 0x77A2129D; }
30777 static constexpr const char* getType() { return "MtlObjBBox"; }
30778
30779 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30780
30781 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30782
30784 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
30786 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
30787
30790 bool set_bbox_min(const Vector& vector, double time = TiMe::Default()) { return setValue("bbox_min", vector, time); }
30793 Vector get_bbox_min(double time = TiMe::Default()) const { return getVector("bbox_min", time); }
30794
30797 bool set_bbox_max(const Vector& vector, double time = TiMe::Default()) { return setValue("bbox_max", vector, time); }
30800 Vector get_bbox_max(double time = TiMe::Default()) const { return getVector("bbox_max", time); }
30801};
30802
30804class MtlOverride : public Plugin {
30805public:
30807 static constexpr const PluginTypeId getTypeId() { return 0x77A0B2A7; }
30809 static constexpr const char* getType() { return "MtlOverride"; }
30810
30811 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30812
30813 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30814
30817 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
30820 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
30821
30825 bool set_enable_gi_mtl(bool val, double time = TiMe::Default()) { return setValue("enable_gi_mtl", val, time); }
30829 bool get_enable_gi_mtl(double time = TiMe::Default()) const { return getBool("enable_gi_mtl", time); }
30830
30833 bool set_gi_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("gi_mtl", plugin, time); }
30836 PluginRef get_gi_mtl(double time = TiMe::Default()) const { return getPlugin("gi_mtl", time); }
30837
30841 bool set_enable_reflect_mtl(bool val, double time = TiMe::Default()) { return setValue("enable_reflect_mtl", val, time); }
30845 bool get_enable_reflect_mtl(double time = TiMe::Default()) const { return getBool("enable_reflect_mtl", time); }
30846
30849 bool set_reflect_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("reflect_mtl", plugin, time); }
30852 PluginRef get_reflect_mtl(double time = TiMe::Default()) const { return getPlugin("reflect_mtl", time); }
30853
30857 bool set_enable_refract_mtl(bool val, double time = TiMe::Default()) { return setValue("enable_refract_mtl", val, time); }
30861 bool get_enable_refract_mtl(double time = TiMe::Default()) const { return getBool("enable_refract_mtl", time); }
30862
30865 bool set_refract_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("refract_mtl", plugin, time); }
30868 PluginRef get_refract_mtl(double time = TiMe::Default()) const { return getPlugin("refract_mtl", time); }
30869
30873 bool set_enable_shadow_mtl(bool val, double time = TiMe::Default()) { return setValue("enable_shadow_mtl", val, time); }
30877 bool get_enable_shadow_mtl(double time = TiMe::Default()) const { return getBool("enable_shadow_mtl", time); }
30878
30881 bool set_shadow_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("shadow_mtl", plugin, time); }
30884 PluginRef get_shadow_mtl(double time = TiMe::Default()) const { return getPlugin("shadow_mtl", time); }
30885
30889 bool set_use_environment_override(bool val, double time = TiMe::Default()) { return setValue("use_environment_override", val, time); }
30893 bool get_use_environment_override(double time = TiMe::Default()) const { return getBool("use_environment_override", time); }
30894
30897 bool set_environment_override(const PluginRef& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
30900 bool set_environment_override(const AColor& texture, double time = TiMe::Default()) { return setValue("environment_override", texture, time); }
30903 Value get_environment_override(double time = TiMe::Default()) const { return getValue("environment_override", time); }
30904
30908 bool set_environment_priority(int val, double time = TiMe::Default()) { return setValue("environment_priority", val, time); }
30912 int get_environment_priority(double time = TiMe::Default()) const { return getInt("environment_priority", time); }
30913};
30914
30916class MtlRenderStats : public Plugin {
30917public:
30919 static constexpr const PluginTypeId getTypeId() { return 0x77A0B885; }
30921 static constexpr const char* getType() { return "MtlRenderStats"; }
30922
30923 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
30924
30925 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
30926
30929 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
30932 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
30933
30937 bool set_camera_visibility(bool val, double time = TiMe::Default()) { return setValue("camera_visibility", val, time); }
30941 bool get_camera_visibility(double time = TiMe::Default()) const { return getBool("camera_visibility", time); }
30942
30946 bool set_reflections_visibility(bool val, double time = TiMe::Default()) { return setValue("reflections_visibility", val, time); }
30950 bool get_reflections_visibility(double time = TiMe::Default()) const { return getBool("reflections_visibility", time); }
30951
30955 bool set_refractions_visibility(bool val, double time = TiMe::Default()) { return setValue("refractions_visibility", val, time); }
30959 bool get_refractions_visibility(double time = TiMe::Default()) const { return getBool("refractions_visibility", time); }
30960
30964 bool set_gi_visibility(bool val, double time = TiMe::Default()) { return setValue("gi_visibility", val, time); }
30968 bool get_gi_visibility(double time = TiMe::Default()) const { return getBool("gi_visibility", time); }
30969
30973 bool set_shadows_visibility(bool val, double time = TiMe::Default()) { return setValue("shadows_visibility", val, time); }
30977 bool get_shadows_visibility(double time = TiMe::Default()) const { return getBool("shadows_visibility", time); }
30978
30982 bool set_shadows_receive(bool val, double time = TiMe::Default()) { return setValue("shadows_receive", val, time); }
30986 bool get_shadows_receive(double time = TiMe::Default()) const { return getBool("shadows_receive", time); }
30987
30991 bool set_visibility(float val, double time = TiMe::Default()) { return setValue("visibility", val, time); }
30995 float get_visibility(double time = TiMe::Default()) const { return getFloat("visibility", time); }
30996
30999 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
31000 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31001 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31004 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
31005};
31006
31008class MtlRoundEdges : public Plugin {
31009public:
31011 static constexpr const PluginTypeId getTypeId() { return 0x77A104BA; }
31013 static constexpr const char* getType() { return "MtlRoundEdges"; }
31014
31015 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31016
31017 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31018
31021 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
31024 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
31025
31029 bool set_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("radius", texturefloat, time); }
31033 bool set_radius(float texturefloat, double time = TiMe::Default()) { return setValue("radius", texturefloat, time); }
31037 Value get_radius(double time = TiMe::Default()) const { return getValue("radius", time); }
31038
31042 bool set_radius_mode(int val, double time = TiMe::Default()) { return setValue("radius_mode", val, time); }
31046 int get_radius_mode(double time = TiMe::Default()) const { return getInt("radius_mode", time); }
31047
31051 bool set_raytraced(bool val, double time = TiMe::Default()) { return setValue("raytraced", val, time); }
31055 bool get_raytraced(double time = TiMe::Default()) const { return getBool("raytraced", time); }
31056
31060 bool set_raytraced_consider_same_object_only(bool val, double time = TiMe::Default()) { return setValue("raytraced_consider_same_object_only", val, time); }
31064 bool get_raytraced_consider_same_object_only(double time = TiMe::Default()) const { return getBool("raytraced_consider_same_object_only", time); }
31065
31069 bool set_raytraced_mode(int val, double time = TiMe::Default()) { return setValue("raytraced_mode", val, time); }
31073 int get_raytraced_mode(double time = TiMe::Default()) const { return getInt("raytraced_mode", time); }
31074};
31075
31077class MtlSelectRE : public Plugin {
31078public:
31080 static constexpr const PluginTypeId getTypeId() { return 0x781B65FC; }
31082 static constexpr const char* getType() { return "MtlSelectRE"; }
31083
31084 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31085
31086 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31087
31089 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
31091 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
31092
31094 bool set_alpha_elements(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("alpha_elements", pluginList, time); }
31095 bool set_alpha_elements(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("alpha_elements", plugins, count, time); }
31096 template<size_t count> bool set_alpha_elements(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("alpha_elements", plugins, count, time); }
31098 PluginList get_alpha_elements(double time = TiMe::Default()) const { return getPluginList("alpha_elements", time); }
31099};
31100
31102class MtlSingleBRDF : public Plugin {
31103public:
31105 static constexpr const PluginTypeId getTypeId() { return 0x77742AB2; }
31107 static constexpr const char* getType() { return "MtlSingleBRDF"; }
31108
31109 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31110
31111 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31112
31116 bool set_filter(const Color& color, double time = TiMe::Default()) { return setValue("filter", color, time); }
31120 Color get_filter(double time = TiMe::Default()) const { return getColor("filter", time); }
31121
31124 bool set_brdf(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("brdf", plugin, time); }
31127 PluginRef get_brdf(double time = TiMe::Default()) const { return getPlugin("brdf", time); }
31128
31132 bool set_double_sided(int val, double time = TiMe::Default()) { return setValue("double_sided", val, time); }
31136 int get_double_sided(double time = TiMe::Default()) const { return getInt("double_sided", time); }
31137
31141 bool set_allow_negative_colors(bool val, double time = TiMe::Default()) { return setValue("allow_negative_colors", val, time); }
31145 bool get_allow_negative_colors(double time = TiMe::Default()) const { return getBool("allow_negative_colors", time); }
31146
31150 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
31154 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
31155
31158 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
31159 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31160 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31163 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
31164};
31165
31167class MtlStreakFade : public Plugin {
31168public:
31170 static constexpr const PluginTypeId getTypeId() { return 0x77CEF5A1; }
31172 static constexpr const char* getType() { return "MtlStreakFade"; }
31173
31174 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31175
31176 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31177
31179 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
31181 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
31182
31185 bool set_fade(float val, double time = TiMe::Default()) { return setValue("fade", val, time); }
31188 float get_fade(double time = TiMe::Default()) const { return getFloat("fade", time); }
31189};
31190
31192class MtlUVWScaler : public Plugin {
31193public:
31195 static constexpr const PluginTypeId getTypeId() { return 0x7867FBAC; }
31197 static constexpr const char* getType() { return "MtlUVWScaler"; }
31198
31199 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31200
31201 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31202
31204 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
31206 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
31207
31211 bool set_uvw_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("uvw_transform", transform, time); }
31215 Transform get_uvw_transform(double time = TiMe::Default()) const { return getTransform("uvw_transform", time); }
31216
31220 bool set_uvw_mode(int val, double time = TiMe::Default()) { return setValue("uvw_mode", val, time); }
31224 int get_uvw_mode(double time = TiMe::Default()) const { return getInt("uvw_mode", time); }
31225};
31226
31228class MtlUVWSelect : public Plugin {
31229public:
31231 static constexpr const PluginTypeId getTypeId() { return 0x785891EA; }
31233 static constexpr const char* getType() { return "MtlUVWSelect"; }
31234
31235 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31236
31237 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31238
31240 bool set_base_mtl(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_mtl", plugin, time); }
31242 PluginRef get_base_mtl(double time = TiMe::Default()) const { return getPlugin("base_mtl", time); }
31243
31246 bool set_uvwgen_ids(const StringList& stringList, double time = TiMe::Default()) { return setValue("uvwgen_ids", stringList, time); }
31249 StringList get_uvwgen_ids(double time = TiMe::Default()) const { return getStringList("uvwgen_ids", time); }
31250
31252 bool set_uvwgens(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("uvwgens", pluginList, time); }
31253 bool set_uvwgens(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("uvwgens", plugins, count, time); }
31254 template<size_t count> bool set_uvwgens(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("uvwgens", plugins, count, time); }
31256 PluginList get_uvwgens(double time = TiMe::Default()) const { return getPluginList("uvwgens", time); }
31257
31260 bool set_face_material_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("face_material_ids", intList, time); }
31261 bool set_face_material_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("face_material_ids", std::move(intList), time); }
31262 bool set_face_material_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("face_material_ids", ints, count, time); }
31263 template<size_t count> bool set_face_material_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("face_material_ids", ints, count, time); }
31266 IntList get_face_material_ids(double time = TiMe::Default()) const { return getIntList("face_material_ids", time); }
31267};
31268
31270class MtlVRmat : public Plugin {
31271public:
31273 static constexpr const PluginTypeId getTypeId() { return 0x2ED8D0B1F8; }
31275 static constexpr const char* getType() { return "MtlVRmat"; }
31276
31277 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31278
31279 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31280
31284 bool set_filename(const char* str, double time = TiMe::Default()) { return setValue("filename", str, time); }
31288 bool set_filename(const std::string& str, double time = TiMe::Default()) { return setValue("filename", str, time); }
31292 std::string get_filename(double time = TiMe::Default()) const { return getString("filename", time); }
31293
31297 bool set_mtlx_document(const char* str, double time = TiMe::Default()) { return setValue("mtlx_document", str, time); }
31301 bool set_mtlx_document(const std::string& str, double time = TiMe::Default()) { return setValue("mtlx_document", str, time); }
31305 std::string get_mtlx_document(double time = TiMe::Default()) const { return getString("mtlx_document", time); }
31306
31310 bool set_mtlname(const char* str, double time = TiMe::Default()) { return setValue("mtlname", str, time); }
31314 bool set_mtlname(const std::string& str, double time = TiMe::Default()) { return setValue("mtlname", str, time); }
31318 std::string get_mtlname(double time = TiMe::Default()) const { return getString("mtlname", time); }
31319
31323 bool set_mtlindex(int val, double time = TiMe::Default()) { return setValue("mtlindex", val, time); }
31327 int get_mtlindex(double time = TiMe::Default()) const { return getInt("mtlindex", time); }
31328
31333 bool set_param_override(const char* str, double time = TiMe::Default()) { return setValue("param_override", str, time); }
31338 bool set_param_override(const std::string& str, double time = TiMe::Default()) { return setValue("param_override", str, time); }
31343 std::string get_param_override(double time = TiMe::Default()) const { return getString("param_override", time); }
31344
31349 bool set_param_override_all(const char* str, double time = TiMe::Default()) { return setValue("param_override_all", str, time); }
31354 bool set_param_override_all(const std::string& str, double time = TiMe::Default()) { return setValue("param_override_all", str, time); }
31359 std::string get_param_override_all(double time = TiMe::Default()) const { return getString("param_override_all", time); }
31360};
31361
31363class MtlWrapper : public Plugin {
31364public:
31366 static constexpr const PluginTypeId getTypeId() { return 0x77B266B0; }
31368 static constexpr const char* getType() { return "MtlWrapper"; }
31369
31370 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31371
31372 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31373
31376 bool set_base_material(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_material", plugin, time); }
31379 PluginRef get_base_material(double time = TiMe::Default()) const { return getPlugin("base_material", time); }
31380
31384 bool set_use_irrad_map(bool val, double time = TiMe::Default()) { return setValue("use_irrad_map", val, time); }
31388 bool get_use_irrad_map(double time = TiMe::Default()) const { return getBool("use_irrad_map", time); }
31389
31393 bool set_generate_gi(float val, double time = TiMe::Default()) { return setValue("generate_gi", val, time); }
31397 float get_generate_gi(double time = TiMe::Default()) const { return getFloat("generate_gi", time); }
31398
31402 bool set_receive_gi(float val, double time = TiMe::Default()) { return setValue("receive_gi", val, time); }
31406 float get_receive_gi(double time = TiMe::Default()) const { return getFloat("receive_gi", time); }
31407
31411 bool set_generate_caustics(float val, double time = TiMe::Default()) { return setValue("generate_caustics", val, time); }
31415 float get_generate_caustics(double time = TiMe::Default()) const { return getFloat("generate_caustics", time); }
31416
31420 bool set_receive_caustics(float val, double time = TiMe::Default()) { return setValue("receive_caustics", val, time); }
31424 float get_receive_caustics(double time = TiMe::Default()) const { return getFloat("receive_caustics", time); }
31425
31429 bool set_alpha_contribution(float val, double time = TiMe::Default()) { return setValue("alpha_contribution", val, time); }
31433 float get_alpha_contribution(double time = TiMe::Default()) const { return getFloat("alpha_contribution", time); }
31434
31438 bool set_matte_surface(bool val, double time = TiMe::Default()) { return setValue("matte_surface", val, time); }
31442 bool get_matte_surface(double time = TiMe::Default()) const { return getBool("matte_surface", time); }
31443
31447 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
31451 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
31452
31456 bool set_affect_alpha(bool val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
31460 bool get_affect_alpha(double time = TiMe::Default()) const { return getBool("affect_alpha", time); }
31461
31465 bool set_shadow_tint_color(const Color& color, double time = TiMe::Default()) { return setValue("shadow_tint_color", color, time); }
31469 Color get_shadow_tint_color(double time = TiMe::Default()) const { return getColor("shadow_tint_color", time); }
31470
31474 bool set_shadow_brightness(float val, double time = TiMe::Default()) { return setValue("shadow_brightness", val, time); }
31478 float get_shadow_brightness(double time = TiMe::Default()) const { return getFloat("shadow_brightness", time); }
31479
31483 bool set_reflection_amount(float val, double time = TiMe::Default()) { return setValue("reflection_amount", val, time); }
31487 float get_reflection_amount(double time = TiMe::Default()) const { return getFloat("reflection_amount", time); }
31488
31492 bool set_refraction_amount(float val, double time = TiMe::Default()) { return setValue("refraction_amount", val, time); }
31496 float get_refraction_amount(double time = TiMe::Default()) const { return getFloat("refraction_amount", time); }
31497
31501 bool set_gi_amount(float val, double time = TiMe::Default()) { return setValue("gi_amount", val, time); }
31505 float get_gi_amount(double time = TiMe::Default()) const { return getFloat("gi_amount", time); }
31506
31510 bool set_no_gi_on_other_mattes(bool val, double time = TiMe::Default()) { return setValue("no_gi_on_other_mattes", val, time); }
31514 bool get_no_gi_on_other_mattes(double time = TiMe::Default()) const { return getBool("no_gi_on_other_mattes", time); }
31515
31519 bool set_matte_for_secondary_rays(int val, double time = TiMe::Default()) { return setValue("matte_for_secondary_rays", val, time); }
31523 int get_matte_for_secondary_rays(double time = TiMe::Default()) const { return getInt("matte_for_secondary_rays", time); }
31524
31528 bool set_gi_surface_id(int val, double time = TiMe::Default()) { return setValue("gi_surface_id", val, time); }
31532 int get_gi_surface_id(double time = TiMe::Default()) const { return getInt("gi_surface_id", time); }
31533
31537 bool set_gi_quality_multiplier(float val, double time = TiMe::Default()) { return setValue("gi_quality_multiplier", val, time); }
31541 float get_gi_quality_multiplier(double time = TiMe::Default()) const { return getFloat("gi_quality_multiplier", time); }
31542
31546 bool set_maya_background_shader_compatibility(bool val, double time = TiMe::Default()) { return setValue("maya_background_shader_compatibility", val, time); }
31550 bool get_maya_background_shader_compatibility(double time = TiMe::Default()) const { return getBool("maya_background_shader_compatibility", time); }
31551
31554 bool set_alpha_contribution_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_contribution_tex", texturefloat, time); }
31557 bool set_alpha_contribution_tex(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_contribution_tex", texturefloat, time); }
31560 Value get_alpha_contribution_tex(double time = TiMe::Default()) const { return getValue("alpha_contribution_tex", time); }
31561
31564 bool set_shadow_brightness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadow_brightness_tex", texturefloat, time); }
31567 bool set_shadow_brightness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadow_brightness_tex", texturefloat, time); }
31570 Value get_shadow_brightness_tex(double time = TiMe::Default()) const { return getValue("shadow_brightness_tex", time); }
31571
31574 bool set_reflection_filter_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflection_filter_tex", texture, time); }
31577 bool set_reflection_filter_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("reflection_filter_tex", texture, time); }
31580 Value get_reflection_filter_tex(double time = TiMe::Default()) const { return getValue("reflection_filter_tex", time); }
31581
31585 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
31589 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
31590
31593 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
31594 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31595 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31598 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
31599
31603 bool set_generate_render_elements(bool val, double time = TiMe::Default()) { return setValue("generate_render_elements", val, time); }
31607 bool get_generate_render_elements(double time = TiMe::Default()) const { return getBool("generate_render_elements", time); }
31608
31611 bool set_reflection_exclude(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("reflection_exclude", pluginList, time); }
31612 bool set_reflection_exclude(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("reflection_exclude", plugins, count, time); }
31613 template<size_t count> bool set_reflection_exclude(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("reflection_exclude", plugins, count, time); }
31616 PluginList get_reflection_exclude(double time = TiMe::Default()) const { return getPluginList("reflection_exclude", time); }
31617
31621 bool set_reflection_list_is_inclusive(bool val, double time = TiMe::Default()) { return setValue("reflection_list_is_inclusive", val, time); }
31625 bool get_reflection_list_is_inclusive(double time = TiMe::Default()) const { return getBool("reflection_list_is_inclusive", time); }
31626
31629 bool set_refraction_exclude(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("refraction_exclude", pluginList, time); }
31630 bool set_refraction_exclude(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("refraction_exclude", plugins, count, time); }
31631 template<size_t count> bool set_refraction_exclude(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("refraction_exclude", plugins, count, time); }
31634 PluginList get_refraction_exclude(double time = TiMe::Default()) const { return getPluginList("refraction_exclude", time); }
31635
31639 bool set_refraction_list_is_inclusive(bool val, double time = TiMe::Default()) { return setValue("refraction_list_is_inclusive", val, time); }
31643 bool get_refraction_list_is_inclusive(double time = TiMe::Default()) const { return getBool("refraction_list_is_inclusive", time); }
31644};
31645
31647class MtlWrapperMaya : public Plugin {
31648public:
31650 static constexpr const PluginTypeId getTypeId() { return 0x77C24530; }
31652 static constexpr const char* getType() { return "MtlWrapperMaya"; }
31653
31654 operator BSDFPluginCategory() { return *static_cast<BSDFPluginCategory*>(static_cast<Plugin*>(this)); }
31655
31656 operator MaterialPluginCategory() { return *static_cast<MaterialPluginCategory*>(static_cast<Plugin*>(this)); }
31657
31660 bool set_base_material(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("base_material", plugin, time); }
31663 PluginRef get_base_material(double time = TiMe::Default()) const { return getPlugin("base_material", time); }
31664
31668 bool set_use_irrad_map(bool val, double time = TiMe::Default()) { return setValue("use_irrad_map", val, time); }
31672 bool get_use_irrad_map(double time = TiMe::Default()) const { return getBool("use_irrad_map", time); }
31673
31677 bool set_generate_gi(float val, double time = TiMe::Default()) { return setValue("generate_gi", val, time); }
31681 float get_generate_gi(double time = TiMe::Default()) const { return getFloat("generate_gi", time); }
31682
31686 bool set_receive_gi(float val, double time = TiMe::Default()) { return setValue("receive_gi", val, time); }
31690 float get_receive_gi(double time = TiMe::Default()) const { return getFloat("receive_gi", time); }
31691
31695 bool set_generate_caustics(float val, double time = TiMe::Default()) { return setValue("generate_caustics", val, time); }
31699 float get_generate_caustics(double time = TiMe::Default()) const { return getFloat("generate_caustics", time); }
31700
31704 bool set_receive_caustics(float val, double time = TiMe::Default()) { return setValue("receive_caustics", val, time); }
31708 float get_receive_caustics(double time = TiMe::Default()) const { return getFloat("receive_caustics", time); }
31709
31713 bool set_alpha_contribution(float val, double time = TiMe::Default()) { return setValue("alpha_contribution", val, time); }
31717 float get_alpha_contribution(double time = TiMe::Default()) const { return getFloat("alpha_contribution", time); }
31718
31722 bool set_matte_surface(bool val, double time = TiMe::Default()) { return setValue("matte_surface", val, time); }
31726 bool get_matte_surface(double time = TiMe::Default()) const { return getBool("matte_surface", time); }
31727
31731 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
31735 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
31736
31740 bool set_affect_alpha(bool val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
31744 bool get_affect_alpha(double time = TiMe::Default()) const { return getBool("affect_alpha", time); }
31745
31749 bool set_shadow_tint_color(const Color& color, double time = TiMe::Default()) { return setValue("shadow_tint_color", color, time); }
31753 Color get_shadow_tint_color(double time = TiMe::Default()) const { return getColor("shadow_tint_color", time); }
31754
31758 bool set_shadow_brightness(float val, double time = TiMe::Default()) { return setValue("shadow_brightness", val, time); }
31762 float get_shadow_brightness(double time = TiMe::Default()) const { return getFloat("shadow_brightness", time); }
31763
31767 bool set_reflection_amount(float val, double time = TiMe::Default()) { return setValue("reflection_amount", val, time); }
31771 float get_reflection_amount(double time = TiMe::Default()) const { return getFloat("reflection_amount", time); }
31772
31776 bool set_refraction_amount(float val, double time = TiMe::Default()) { return setValue("refraction_amount", val, time); }
31780 float get_refraction_amount(double time = TiMe::Default()) const { return getFloat("refraction_amount", time); }
31781
31785 bool set_gi_amount(float val, double time = TiMe::Default()) { return setValue("gi_amount", val, time); }
31789 float get_gi_amount(double time = TiMe::Default()) const { return getFloat("gi_amount", time); }
31790
31794 bool set_no_gi_on_other_mattes(bool val, double time = TiMe::Default()) { return setValue("no_gi_on_other_mattes", val, time); }
31798 bool get_no_gi_on_other_mattes(double time = TiMe::Default()) const { return getBool("no_gi_on_other_mattes", time); }
31799
31803 bool set_matte_for_secondary_rays(int val, double time = TiMe::Default()) { return setValue("matte_for_secondary_rays", val, time); }
31807 int get_matte_for_secondary_rays(double time = TiMe::Default()) const { return getInt("matte_for_secondary_rays", time); }
31808
31812 bool set_gi_surface_id(int val, double time = TiMe::Default()) { return setValue("gi_surface_id", val, time); }
31816 int get_gi_surface_id(double time = TiMe::Default()) const { return getInt("gi_surface_id", time); }
31817
31821 bool set_gi_quality_multiplier(float val, double time = TiMe::Default()) { return setValue("gi_quality_multiplier", val, time); }
31825 float get_gi_quality_multiplier(double time = TiMe::Default()) const { return getFloat("gi_quality_multiplier", time); }
31826
31830 bool set_maya_background_shader_compatibility(bool val, double time = TiMe::Default()) { return setValue("maya_background_shader_compatibility", val, time); }
31834 bool get_maya_background_shader_compatibility(double time = TiMe::Default()) const { return getBool("maya_background_shader_compatibility", time); }
31835
31838 bool set_alpha_contribution_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_contribution_tex", texturefloat, time); }
31841 bool set_alpha_contribution_tex(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_contribution_tex", texturefloat, time); }
31844 Value get_alpha_contribution_tex(double time = TiMe::Default()) const { return getValue("alpha_contribution_tex", time); }
31845
31848 bool set_shadow_brightness_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("shadow_brightness_tex", texturefloat, time); }
31851 bool set_shadow_brightness_tex(float texturefloat, double time = TiMe::Default()) { return setValue("shadow_brightness_tex", texturefloat, time); }
31854 Value get_shadow_brightness_tex(double time = TiMe::Default()) const { return getValue("shadow_brightness_tex", time); }
31855
31858 bool set_reflection_filter_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflection_filter_tex", texture, time); }
31861 bool set_reflection_filter_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("reflection_filter_tex", texture, time); }
31864 Value get_reflection_filter_tex(double time = TiMe::Default()) const { return getValue("reflection_filter_tex", time); }
31865
31869 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
31873 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
31874
31877 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
31878 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31879 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
31882 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
31883
31887 bool set_generate_render_elements(bool val, double time = TiMe::Default()) { return setValue("generate_render_elements", val, time); }
31891 bool get_generate_render_elements(double time = TiMe::Default()) const { return getBool("generate_render_elements", time); }
31892
31895 bool set_reflection_exclude(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("reflection_exclude", pluginList, time); }
31896 bool set_reflection_exclude(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("reflection_exclude", plugins, count, time); }
31897 template<size_t count> bool set_reflection_exclude(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("reflection_exclude", plugins, count, time); }
31900 PluginList get_reflection_exclude(double time = TiMe::Default()) const { return getPluginList("reflection_exclude", time); }
31901
31905 bool set_reflection_list_is_inclusive(bool val, double time = TiMe::Default()) { return setValue("reflection_list_is_inclusive", val, time); }
31909 bool get_reflection_list_is_inclusive(double time = TiMe::Default()) const { return getBool("reflection_list_is_inclusive", time); }
31910
31913 bool set_refraction_exclude(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("refraction_exclude", pluginList, time); }
31914 bool set_refraction_exclude(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("refraction_exclude", plugins, count, time); }
31915 template<size_t count> bool set_refraction_exclude(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("refraction_exclude", plugins, count, time); }
31918 PluginList get_refraction_exclude(double time = TiMe::Default()) const { return getPluginList("refraction_exclude", time); }
31919
31923 bool set_refraction_list_is_inclusive(bool val, double time = TiMe::Default()) { return setValue("refraction_list_is_inclusive", val, time); }
31927 bool get_refraction_list_is_inclusive(double time = TiMe::Default()) const { return getBool("refraction_list_is_inclusive", time); }
31928};
31929
31931class NURBSCurve : public Plugin {
31932public:
31934 static constexpr const PluginTypeId getTypeId() { return 0x77823595; }
31936 static constexpr const char* getType() { return "NURBSCurve"; }
31937
31938 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
31939
31942 bool set_degree(int val, double time = TiMe::Default()) { return setValue("degree", val, time); }
31945 int get_degree(double time = TiMe::Default()) const { return getInt("degree", time); }
31946
31949 bool set_cvs(const VectorList& vectorList, double time = TiMe::Default()) { return setValue("cvs", vectorList, time); }
31950 bool set_cvs(VectorList&& vectorList, double time = TiMe::Default()) { return setValue("cvs", std::move(vectorList), time); }
31951 bool set_cvs(const Vector* vectors, size_t count, double time = TiMe::Default()) { return setArray("cvs", vectors, count, time); }
31952 template<size_t count> bool set_cvs(const Vector (&vectors)[count], double time = TiMe::Default()) { return setArray("cvs", vectors, count, time); }
31955 VectorList get_cvs(double time = TiMe::Default()) const { return getVectorList("cvs", time); }
31956
31959 bool set_knotVector(const FloatList& floatList, double time = TiMe::Default()) { return setValue("knotVector", floatList, time); }
31960 bool set_knotVector(FloatList&& floatList, double time = TiMe::Default()) { return setValue("knotVector", std::move(floatList), time); }
31961 bool set_knotVector(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("knotVector", floats, count, time); }
31962 template<size_t count> bool set_knotVector(const float (&floats)[count], double time = TiMe::Default()) { return setArray("knotVector", floats, count, time); }
31965 FloatList get_knotVector(double time = TiMe::Default()) const { return getFloatList("knotVector", time); }
31966
31969 bool set_boundary(const IntList& intList, double time = TiMe::Default()) { return setValue("boundary", intList, time); }
31970 bool set_boundary(IntList&& intList, double time = TiMe::Default()) { return setValue("boundary", std::move(intList), time); }
31971 bool set_boundary(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("boundary", ints, count, time); }
31972 template<size_t count> bool set_boundary(const int (&ints)[count], double time = TiMe::Default()) { return setArray("boundary", ints, count, time); }
31975 IntList get_boundary(double time = TiMe::Default()) const { return getIntList("boundary", time); }
31976};
31977
31979class Node : public Plugin {
31980public:
31982 static constexpr const PluginTypeId getTypeId() { return 0x77742AB3; }
31984 static constexpr const char* getType() { return "Node"; }
31985
31986 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
31987
31990 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
31993 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
31994
31997 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
32000 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
32001
32003 bool set_geometry(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("geometry", plugin, time); }
32005 PluginRef get_geometry(double time = TiMe::Default()) const { return getPlugin("geometry", time); }
32006
32008 bool set_material(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("material", plugin, time); }
32010 PluginRef get_material(double time = TiMe::Default()) const { return getPlugin("material", time); }
32011
32013 bool set_volume(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("volume", plugin, time); }
32015 PluginRef get_volume(double time = TiMe::Default()) const { return getPlugin("volume", time); }
32016
32019 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
32022 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
32023
32025 bool set_lights(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("lights", pluginList, time); }
32026 bool set_lights(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("lights", plugins, count, time); }
32027 template<size_t count> bool set_lights(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("lights", plugins, count, time); }
32029 PluginList get_lights(double time = TiMe::Default()) const { return getPluginList("lights", time); }
32030
32033 bool set_visible(bool val, double time = TiMe::Default()) { return setValue("visible", val, time); }
32036 bool get_visible(double time = TiMe::Default()) const { return getBool("visible", time); }
32037
32040 bool set_user_attributes(const char* str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
32043 bool set_user_attributes(const std::string& str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
32046 std::string get_user_attributes(double time = TiMe::Default()) const { return getString("user_attributes", time); }
32047
32050 bool set_user_attributes_bin(const IntList& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", intList, time); }
32051 bool set_user_attributes_bin(IntList&& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", std::move(intList), time); }
32052 bool set_user_attributes_bin(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
32053 template<size_t count> bool set_user_attributes_bin(const int (&ints)[count], double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
32056 IntList get_user_attributes_bin(double time = TiMe::Default()) const { return getIntList("user_attributes_bin", time); }
32057
32060 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
32063 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
32064
32067 bool set_primary_visibility(bool val, double time = TiMe::Default()) { return setValue("primary_visibility", val, time); }
32070 bool get_primary_visibility(double time = TiMe::Default()) const { return getBool("primary_visibility", time); }
32071
32074 bool set_time_for_geometry(float val, double time = TiMe::Default()) { return setValue("time_for_geometry", val, time); }
32077 float get_time_for_geometry(double time = TiMe::Default()) const { return getFloat("time_for_geometry", time); }
32078
32081 bool set_use_time_for_geometry(bool val, double time = TiMe::Default()) { return setValue("use_time_for_geometry", val, time); }
32084 bool get_use_time_for_geometry(double time = TiMe::Default()) const { return getBool("use_time_for_geometry", time); }
32085
32087 bool set_map_channels(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("map_channels", plugin, time); }
32089 PluginRef get_map_channels(double time = TiMe::Default()) const { return getPlugin("map_channels", time); }
32090
32093 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
32096 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
32097
32100 bool set_bake_subdiv_filepath(const char* str, double time = TiMe::Default()) { return setValue("bake_subdiv_filepath", str, time); }
32103 bool set_bake_subdiv_filepath(const std::string& str, double time = TiMe::Default()) { return setValue("bake_subdiv_filepath", str, time); }
32106 std::string get_bake_subdiv_filepath(double time = TiMe::Default()) const { return getString("bake_subdiv_filepath", time); }
32107
32111 bool set_object_space_displacement(int val, double time = TiMe::Default()) { return setValue("object_space_displacement", val, time); }
32115 int get_object_space_displacement(double time = TiMe::Default()) const { return getInt("object_space_displacement", time); }
32116
32120 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
32124 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
32125
32128 bool set_object_properties(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("object_properties", plugin, time); }
32131 PluginRef get_object_properties(double time = TiMe::Default()) const { return getPlugin("object_properties", time); }
32132};
32133
32135class OutputDeepWriter : public Plugin {
32136public:
32138 static constexpr const PluginTypeId getTypeId() { return 0x77ED0811; }
32140 static constexpr const char* getType() { return "OutputDeepWriter"; }
32141
32142 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
32143
32147 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
32151 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
32155 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
32156
32159 bool set_float_colors_mode(bool val, double time = TiMe::Default()) { return setValue("float_colors_mode", val, time); }
32162 bool get_float_colors_mode(double time = TiMe::Default()) const { return getBool("float_colors_mode", time); }
32163
32167 bool set_vrst_compression(int val, double time = TiMe::Default()) { return setValue("vrst_compression", val, time); }
32171 int get_vrst_compression(double time = TiMe::Default()) const { return getInt("vrst_compression", time); }
32172
32176 bool set_exr_compression(int val, double time = TiMe::Default()) { return setValue("exr_compression", val, time); }
32180 int get_exr_compression(double time = TiMe::Default()) const { return getInt("exr_compression", time); }
32181};
32182
32183class OutputTest : public Plugin {
32184public:
32186 static constexpr const PluginTypeId getTypeId() { return 0x77C05195; }
32188 static constexpr const char* getType() { return "OutputTest"; }
32189
32190 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
32191};
32192
32194class ParticleTex : public Plugin {
32195public:
32197 static constexpr const PluginTypeId getTypeId() { return 0x77DEACAD; }
32199 static constexpr const char* getType() { return "ParticleTex"; }
32200
32201 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
32202
32206 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
32210 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
32211
32215 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
32219 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
32220
32224 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
32228 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
32229
32233 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
32237 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
32238
32242 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
32246 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
32250 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
32251
32255 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
32259 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
32263 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
32264
32268 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
32272 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
32276 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
32277
32281 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
32285 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
32289 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
32290
32294 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
32298 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
32302 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
32303
32305 PluginRef out_color() const { return PluginRef(*this, "color"); }
32306
32308 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
32309
32311 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
32312
32314 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
32315
32318 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
32321 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
32322
32326 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
32330 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
32331
32335 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
32339 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
32340
32344 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
32348 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
32349
32353 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
32357 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
32358
32362 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
32366 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
32367
32371 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
32375 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
32376
32380 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
32384 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
32385
32389 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
32393 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
32394
32398 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
32402 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
32403
32407 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
32411 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
32412
32416 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
32420 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
32421
32425 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
32429 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
32430
32434 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
32438 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
32439
32443 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
32447 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
32448
32451 bool set_blend_alpha(bool val, double time = TiMe::Default()) { return setValue("blend_alpha", val, time); }
32454 bool get_blend_alpha(double time = TiMe::Default()) const { return getBool("blend_alpha", time); }
32455
32459 bool set_blend_method(int val, double time = TiMe::Default()) { return setValue("blend_method", val, time); }
32463 int get_blend_method(double time = TiMe::Default()) const { return getInt("blend_method", time); }
32464
32467 bool set_color_mode(int val, double time = TiMe::Default()) { return setValue("color_mode", val, time); }
32470 int get_color_mode(double time = TiMe::Default()) const { return getInt("color_mode", time); }
32471
32474 bool set_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("map", texture, time); }
32477 bool set_map(const AColor& texture, double time = TiMe::Default()) { return setValue("map", texture, time); }
32480 Value get_map(double time = TiMe::Default()) const { return getValue("map", time); }
32481
32484 bool set_radius_mode(int val, double time = TiMe::Default()) { return setValue("radius_mode", val, time); }
32487 int get_radius_mode(double time = TiMe::Default()) const { return getInt("radius_mode", time); }
32488
32491 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
32494 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
32495
32498 bool set_amplitude(float val, double time = TiMe::Default()) { return setValue("amplitude", val, time); }
32501 float get_amplitude(double time = TiMe::Default()) const { return getFloat("amplitude", time); }
32502
32505 bool set_shift_mode(bool val, double time = TiMe::Default()) { return setValue("shift_mode", val, time); }
32508 bool get_shift_mode(double time = TiMe::Default()) const { return getBool("shift_mode", time); }
32509
32512 bool set_shift(float val, double time = TiMe::Default()) { return setValue("shift", val, time); }
32515 float get_shift(double time = TiMe::Default()) const { return getFloat("shift", time); }
32516
32519 bool set_radius_scale(bool val, double time = TiMe::Default()) { return setValue("radius_scale", val, time); }
32522 bool get_radius_scale(double time = TiMe::Default()) const { return getBool("radius_scale", time); }
32523
32526 bool set_pa_color(bool val, double time = TiMe::Default()) { return setValue("pa_color", val, time); }
32529 bool get_pa_color(double time = TiMe::Default()) const { return getBool("pa_color", time); }
32530
32533 bool set_pa_radius(bool val, double time = TiMe::Default()) { return setValue("pa_radius", val, time); }
32536 bool get_pa_radius(double time = TiMe::Default()) const { return getBool("pa_radius", time); }
32537
32540 bool set_pa_amplitude(bool val, double time = TiMe::Default()) { return setValue("pa_amplitude", val, time); }
32543 bool get_pa_amplitude(double time = TiMe::Default()) const { return getBool("pa_amplitude", time); }
32544
32547 bool set_pa_shift(bool val, double time = TiMe::Default()) { return setValue("pa_shift", val, time); }
32550 bool get_pa_shift(double time = TiMe::Default()) const { return getBool("pa_shift", time); }
32551
32553 bool set_particle_systems(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("particle_systems", pluginList, time); }
32554 bool set_particle_systems(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("particle_systems", plugins, count, time); }
32555 template<size_t count> bool set_particle_systems(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("particle_systems", plugins, count, time); }
32557 PluginList get_particle_systems(double time = TiMe::Default()) const { return getPluginList("particle_systems", time); }
32558
32561 bool set_source_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("source_transform", transform, time); }
32564 Transform get_source_transform(double time = TiMe::Default()) const { return getTransform("source_transform", time); }
32565};
32566
32568class PhxShaderCache : public Plugin {
32569public:
32571 static constexpr const PluginTypeId getTypeId() { return 0x4AEA9A6CB; }
32573 static constexpr const char* getType() { return "PhxShaderCache"; }
32574
32578 bool set_cache_path(const char* str, double time = TiMe::Default()) { return setValue("cache_path", str, time); }
32582 bool set_cache_path(const std::string& str, double time = TiMe::Default()) { return setValue("cache_path", str, time); }
32586 std::string get_cache_path(double time = TiMe::Default()) const { return getString("cache_path", time); }
32587
32591 bool set_cache_load(bool val, double time = TiMe::Default()) { return setValue("cache_load", val, time); }
32595 bool get_cache_load(double time = TiMe::Default()) const { return getBool("cache_load", time); }
32596
32600 bool set_velocities_from_uvw(bool val, double time = TiMe::Default()) { return setValue("velocities_from_uvw", val, time); }
32604 bool get_velocities_from_uvw(double time = TiMe::Default()) const { return getBool("velocities_from_uvw", time); }
32605
32609 bool set_isMayaFluid(bool val, double time = TiMe::Default()) { return setValue("isMayaFluid", val, time); }
32613 bool get_isMayaFluid(double time = TiMe::Default()) const { return getBool("isMayaFluid", time); }
32614
32618 bool set_empty_grid_up_axis(int val, double time = TiMe::Default()) { return setValue("empty_grid_up_axis", val, time); }
32622 int get_empty_grid_up_axis(double time = TiMe::Default()) const { return getInt("empty_grid_up_axis", time); }
32623
32627 bool set_grid_size_x(float val, double time = TiMe::Default()) { return setValue("grid_size_x", val, time); }
32631 float get_grid_size_x(double time = TiMe::Default()) const { return getFloat("grid_size_x", time); }
32632
32636 bool set_grid_size_y(float val, double time = TiMe::Default()) { return setValue("grid_size_y", val, time); }
32640 float get_grid_size_y(double time = TiMe::Default()) const { return getFloat("grid_size_y", time); }
32641
32645 bool set_grid_size_z(float val, double time = TiMe::Default()) { return setValue("grid_size_z", val, time); }
32649 float get_grid_size_z(double time = TiMe::Default()) const { return getFloat("grid_size_z", time); }
32650
32653 bool set_cell_size(float val, double time = TiMe::Default()) { return setValue("cell_size", val, time); }
32656 float get_cell_size(double time = TiMe::Default()) const { return getFloat("cell_size", time); }
32657
32661 bool set_dynamic_offset_x(float val, double time = TiMe::Default()) { return setValue("dynamic_offset_x", val, time); }
32665 float get_dynamic_offset_x(double time = TiMe::Default()) const { return getFloat("dynamic_offset_x", time); }
32666
32670 bool set_dynamic_offset_y(float val, double time = TiMe::Default()) { return setValue("dynamic_offset_y", val, time); }
32674 float get_dynamic_offset_y(double time = TiMe::Default()) const { return getFloat("dynamic_offset_y", time); }
32675
32679 bool set_dynamic_offset_z(float val, double time = TiMe::Default()) { return setValue("dynamic_offset_z", val, time); }
32683 float get_dynamic_offset_z(double time = TiMe::Default()) const { return getFloat("dynamic_offset_z", time); }
32684
32688 bool set_anim_mode(int val, double time = TiMe::Default()) { return setValue("anim_mode", val, time); }
32692 int get_anim_mode(double time = TiMe::Default()) const { return getInt("anim_mode", time); }
32693
32697 bool set_t2f(float val, double time = TiMe::Default()) { return setValue("t2f", val, time); }
32701 float get_t2f(double time = TiMe::Default()) const { return getFloat("t2f", time); }
32702
32706 bool set_play_at(int val, double time = TiMe::Default()) { return setValue("play_at", val, time); }
32710 int get_play_at(double time = TiMe::Default()) const { return getInt("play_at", time); }
32711
32715 bool set_read_offset(int val, double time = TiMe::Default()) { return setValue("read_offset", val, time); }
32719 int get_read_offset(double time = TiMe::Default()) const { return getInt("read_offset", time); }
32720
32724 bool set_play_speed(float val, double time = TiMe::Default()) { return setValue("play_speed", val, time); }
32728 float get_play_speed(double time = TiMe::Default()) const { return getFloat("play_speed", time); }
32729
32733 bool set_max_length(int val, double time = TiMe::Default()) { return setValue("max_length", val, time); }
32737 int get_max_length(double time = TiMe::Default()) const { return getInt("max_length", time); }
32738
32742 bool set_loop_overlap(int val, double time = TiMe::Default()) { return setValue("loop_overlap", val, time); }
32746 int get_loop_overlap(double time = TiMe::Default()) const { return getInt("loop_overlap", time); }
32747
32751 bool set_blend_method(int val, double time = TiMe::Default()) { return setValue("blend_method", val, time); }
32755 int get_blend_method(double time = TiMe::Default()) const { return getInt("blend_method", time); }
32756
32760 bool set_load_nearest(bool val, double time = TiMe::Default()) { return setValue("load_nearest", val, time); }
32764 bool get_load_nearest(double time = TiMe::Default()) const { return getBool("load_nearest", time); }
32765
32769 bool set_flip_yz(bool val, double time = TiMe::Default()) { return setValue("flip_yz", val, time); }
32773 bool get_flip_yz(double time = TiMe::Default()) const { return getBool("flip_yz", time); }
32774
32778 bool set_mirror_z(bool val, double time = TiMe::Default()) { return setValue("mirror_z", val, time); }
32782 bool get_mirror_z(double time = TiMe::Default()) const { return getBool("mirror_z", time); }
32783
32787 bool set_TPF(int val, double time = TiMe::Default()) { return setValue("TPF", val, time); }
32791 int get_TPF(double time = TiMe::Default()) const { return getInt("TPF", time); }
32792
32796 bool set_load_flags(int val, double time = TiMe::Default()) { return setValue("load_flags", val, time); }
32800 int get_load_flags(double time = TiMe::Default()) const { return getInt("load_flags", time); }
32801
32805 bool set_time_tform(bool val, double time = TiMe::Default()) { return setValue("time_tform", val, time); }
32809 bool get_time_tform(double time = TiMe::Default()) const { return getBool("time_tform", time); }
32810
32814 bool set_smooth_mask(int val, double time = TiMe::Default()) { return setValue("smooth_mask", val, time); }
32818 int get_smooth_mask(double time = TiMe::Default()) const { return getInt("smooth_mask", time); }
32819
32823 bool set_smooth_threshold(const FloatList& floatList, double time = TiMe::Default()) { return setValue("smooth_threshold", floatList, time); }
32824 bool set_smooth_threshold(FloatList&& floatList, double time = TiMe::Default()) { return setValue("smooth_threshold", std::move(floatList), time); }
32825 bool set_smooth_threshold(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("smooth_threshold", floats, count, time); }
32826 template<size_t count> bool set_smooth_threshold(const float (&floats)[count], double time = TiMe::Default()) { return setArray("smooth_threshold", floats, count, time); }
32830 FloatList get_smooth_threshold(double time = TiMe::Default()) const { return getFloatList("smooth_threshold", time); }
32831
32835 bool set_smooth_similarity(const FloatList& floatList, double time = TiMe::Default()) { return setValue("smooth_similarity", floatList, time); }
32836 bool set_smooth_similarity(FloatList&& floatList, double time = TiMe::Default()) { return setValue("smooth_similarity", std::move(floatList), time); }
32837 bool set_smooth_similarity(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("smooth_similarity", floats, count, time); }
32838 template<size_t count> bool set_smooth_similarity(const float (&floats)[count], double time = TiMe::Default()) { return setArray("smooth_similarity", floats, count, time); }
32842 FloatList get_smooth_similarity(double time = TiMe::Default()) const { return getFloatList("smooth_similarity", time); }
32843
32847 bool set_smooth_randomize(const FloatList& floatList, double time = TiMe::Default()) { return setValue("smooth_randomize", floatList, time); }
32848 bool set_smooth_randomize(FloatList&& floatList, double time = TiMe::Default()) { return setValue("smooth_randomize", std::move(floatList), time); }
32849 bool set_smooth_randomize(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("smooth_randomize", floats, count, time); }
32850 template<size_t count> bool set_smooth_randomize(const float (&floats)[count], double time = TiMe::Default()) { return setArray("smooth_randomize", floats, count, time); }
32854 FloatList get_smooth_randomize(double time = TiMe::Default()) const { return getFloatList("smooth_randomize", time); }
32855
32859 bool set_free_mem_detect(int val, double time = TiMe::Default()) { return setValue("free_mem_detect", val, time); }
32863 int get_free_mem_detect(double time = TiMe::Default()) const { return getInt("free_mem_detect", time); }
32864
32868 bool set_usrchmap(const char* str, double time = TiMe::Default()) { return setValue("usrchmap", str, time); }
32872 bool set_usrchmap(const std::string& str, double time = TiMe::Default()) { return setValue("usrchmap", str, time); }
32876 std::string get_usrchmap(double time = TiMe::Default()) const { return getString("usrchmap", time); }
32877
32880 bool set_raw_vdb_stream(const ValueList& list, double time = TiMe::Default()) { return setValue("raw_vdb_stream", list, time); }
32881 bool set_raw_vdb_stream(ValueList&& list, double time = TiMe::Default()) { return setValue("raw_vdb_stream", std::move(list), time); }
32882 bool set_raw_vdb_stream(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("raw_vdb_stream", values, count, time); }
32883 template<size_t count> bool set_raw_vdb_stream(const Value (&values)[count], double time = TiMe::Default()) { return setArray("raw_vdb_stream", values, count, time); }
32884 template<size_t count> bool set_raw_vdb_stream(Value (&&values)[count], double time = TiMe::Default()) { return setArray("raw_vdb_stream", values, count, time); }
32887 ValueList get_raw_vdb_stream(double time = TiMe::Default()) const { return getValueList("raw_vdb_stream", time); }
32888};
32889
32891class PhxShaderFoam : public Plugin {
32892public:
32894 static constexpr const PluginTypeId getTypeId() { return 0x4AEB4705B; }
32896 static constexpr const char* getType() { return "PhxShaderFoam"; }
32897
32898 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
32899
32900 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
32901
32905 bool set_renderAsVolumetric(bool val, double time = TiMe::Default()) { return setValue("renderAsVolumetric", val, time); }
32909 bool get_renderAsVolumetric(double time = TiMe::Default()) const { return getBool("renderAsVolumetric", time); }
32910
32914 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
32918 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
32919
32923 bool set_geommode(int val, double time = TiMe::Default()) { return setValue("geommode", val, time); }
32927 int get_geommode(double time = TiMe::Default()) const { return getInt("geommode", time); }
32928
32931 bool set_particle_source(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("particle_source", pluginList, time); }
32932 bool set_particle_source(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("particle_source", plugins, count, time); }
32933 template<size_t count> bool set_particle_source(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("particle_source", plugins, count, time); }
32936 PluginList get_particle_source(double time = TiMe::Default()) const { return getPluginList("particle_source", time); }
32937
32940 bool set_particle_tm(const ValueList& list, double time = TiMe::Default()) { return setValue("particle_tm", list, time); }
32941 bool set_particle_tm(ValueList&& list, double time = TiMe::Default()) { return setValue("particle_tm", std::move(list), time); }
32942 bool set_particle_tm(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("particle_tm", values, count, time); }
32943 template<size_t count> bool set_particle_tm(const Value (&values)[count], double time = TiMe::Default()) { return setArray("particle_tm", values, count, time); }
32944 template<size_t count> bool set_particle_tm(Value (&&values)[count], double time = TiMe::Default()) { return setArray("particle_tm", values, count, time); }
32947 ValueList get_particle_tm(double time = TiMe::Default()) const { return getValueList("particle_tm", time); }
32948
32951 bool set_gpuMaterial(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("gpuMaterial", plugin, time); }
32954 PluginRef get_gpuMaterial(double time = TiMe::Default()) const { return getPlugin("gpuMaterial", time); }
32955
32959 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
32963 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
32964
32968 bool set_colfrompartchan(bool val, double time = TiMe::Default()) { return setValue("colfrompartchan", val, time); }
32972 bool get_colfrompartchan(double time = TiMe::Default()) const { return getBool("colfrompartchan", time); }
32973
32977 bool set_usecolormap(bool val, double time = TiMe::Default()) { return setValue("usecolormap", val, time); }
32981 bool get_usecolormap(double time = TiMe::Default()) const { return getBool("usecolormap", time); }
32982
32985 bool set_colormap(const PluginRef& texture, double time = TiMe::Default()) { return setValue("colormap", texture, time); }
32988 bool set_colormap(const AColor& texture, double time = TiMe::Default()) { return setValue("colormap", texture, time); }
32991 Value get_colormap(double time = TiMe::Default()) const { return getValue("colormap", time); }
32992
32996 bool set_bounces(int val, double time = TiMe::Default()) { return setValue("bounces", val, time); }
33000 int get_bounces(double time = TiMe::Default()) const { return getInt("bounces", time); }
33001
33005 bool set_minw(float val, double time = TiMe::Default()) { return setValue("minw", val, time); }
33009 float get_minw(double time = TiMe::Default()) const { return getFloat("minw", time); }
33010
33014 bool set_ri(float val, double time = TiMe::Default()) { return setValue("ri", val, time); }
33018 float get_ri(double time = TiMe::Default()) const { return getFloat("ri", time); }
33019
33023 bool set_difmul(float val, double time = TiMe::Default()) { return setValue("difmul", val, time); }
33027 float get_difmul(double time = TiMe::Default()) const { return getFloat("difmul", time); }
33028
33032 bool set_hlwidth(float val, double time = TiMe::Default()) { return setValue("hlwidth", val, time); }
33036 float get_hlwidth(double time = TiMe::Default()) const { return getFloat("hlwidth", time); }
33037
33041 bool set_hlmult(float val, double time = TiMe::Default()) { return setValue("hlmult", val, time); }
33045 float get_hlmult(double time = TiMe::Default()) const { return getFloat("hlmult", time); }
33046
33050 bool set_reduction(float val, double time = TiMe::Default()) { return setValue("reduction", val, time); }
33054 float get_reduction(double time = TiMe::Default()) const { return getFloat("reduction", time); }
33055
33059 bool set_cntmul_inc_meth(int val, double time = TiMe::Default()) { return setValue("cntmul_inc_meth", val, time); }
33063 int get_cntmul_inc_meth(double time = TiMe::Default()) const { return getInt("cntmul_inc_meth", time); }
33064
33068 bool set_cntmul_inc_nbrs(int val, double time = TiMe::Default()) { return setValue("cntmul_inc_nbrs", val, time); }
33072 int get_cntmul_inc_nbrs(double time = TiMe::Default()) const { return getInt("cntmul_inc_nbrs", time); }
33073
33077 bool set_displ_fade_from_liq(bool val, double time = TiMe::Default()) { return setValue("displ_fade_from_liq", val, time); }
33081 bool get_displ_fade_from_liq(double time = TiMe::Default()) const { return getBool("displ_fade_from_liq", time); }
33082
33086 bool set_displ_fade_from_liq_dist(float val, double time = TiMe::Default()) { return setValue("displ_fade_from_liq_dist", val, time); }
33090 float get_displ_fade_from_liq_dist(double time = TiMe::Default()) const { return getFloat("displ_fade_from_liq_dist", time); }
33091
33095 bool set_pvar(float val, double time = TiMe::Default()) { return setValue("pvar", val, time); }
33099 float get_pvar(double time = TiMe::Default()) const { return getFloat("pvar", time); }
33100
33104 bool set_szmul(float val, double time = TiMe::Default()) { return setValue("szmul", val, time); }
33108 float get_szmul(double time = TiMe::Default()) const { return getFloat("szmul", time); }
33109
33113 bool set_szmul_pa(bool val, double time = TiMe::Default()) { return setValue("szmul_pa", val, time); }
33117 bool get_szmul_pa(double time = TiMe::Default()) const { return getBool("szmul_pa", time); }
33118
33121 bool set_szmul_anim(const ValueList& list, double time = TiMe::Default()) { return setValue("szmul_anim", list, time); }
33122 bool set_szmul_anim(ValueList&& list, double time = TiMe::Default()) { return setValue("szmul_anim", std::move(list), time); }
33123 bool set_szmul_anim(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("szmul_anim", values, count, time); }
33124 template<size_t count> bool set_szmul_anim(const Value (&values)[count], double time = TiMe::Default()) { return setArray("szmul_anim", values, count, time); }
33125 template<size_t count> bool set_szmul_anim(Value (&&values)[count], double time = TiMe::Default()) { return setArray("szmul_anim", values, count, time); }
33128 ValueList get_szmul_anim(double time = TiMe::Default()) const { return getValueList("szmul_anim", time); }
33129
33133 bool set_szadd(float val, double time = TiMe::Default()) { return setValue("szadd", val, time); }
33137 float get_szadd(double time = TiMe::Default()) const { return getFloat("szadd", time); }
33138
33142 bool set_szvar(float val, double time = TiMe::Default()) { return setValue("szvar", val, time); }
33146 float get_szvar(double time = TiMe::Default()) const { return getFloat("szvar", time); }
33147
33151 bool set_szdist(float val, double time = TiMe::Default()) { return setValue("szdist", val, time); }
33155 float get_szdist(double time = TiMe::Default()) const { return getFloat("szdist", time); }
33156
33160 bool set_scattering(int val, double time = TiMe::Default()) { return setValue("scattering", val, time); }
33164 int get_scattering(double time = TiMe::Default()) const { return getInt("scattering", time); }
33165
33169 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
33173 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
33174
33178 bool set_optimize(bool val, double time = TiMe::Default()) { return setValue("optimize", val, time); }
33182 bool get_optimize(double time = TiMe::Default()) const { return getBool("optimize", time); }
33183
33187 bool set_moblur(int val, double time = TiMe::Default()) { return setValue("moblur", val, time); }
33191 int get_moblur(double time = TiMe::Default()) const { return getInt("moblur", time); }
33192
33196 bool set_mbstep(float val, double time = TiMe::Default()) { return setValue("mbstep", val, time); }
33200 float get_mbstep(double time = TiMe::Default()) const { return getFloat("mbstep", time); }
33201
33205 bool set_mblimit(int val, double time = TiMe::Default()) { return setValue("mblimit", val, time); }
33209 int get_mblimit(double time = TiMe::Default()) const { return getInt("mblimit", time); }
33210
33214 bool set_ptAlpha(float val, double time = TiMe::Default()) { return setValue("ptAlpha", val, time); }
33218 float get_ptAlpha(double time = TiMe::Default()) const { return getFloat("ptAlpha", time); }
33219
33223 bool set_ptSize(float val, double time = TiMe::Default()) { return setValue("ptSize", val, time); }
33227 float get_ptSize(double time = TiMe::Default()) const { return getFloat("ptSize", time); }
33228
33232 bool set_ptShadStren(float val, double time = TiMe::Default()) { return setValue("ptShadStren", val, time); }
33236 float get_ptShadStren(double time = TiMe::Default()) const { return getFloat("ptShadStren", time); }
33237
33241 bool set_ptSizeExtra(float val, double time = TiMe::Default()) { return setValue("ptSizeExtra", val, time); }
33245 float get_ptSizeExtra(double time = TiMe::Default()) const { return getFloat("ptSizeExtra", time); }
33246
33250 bool set_velmult(float val, double time = TiMe::Default()) { return setValue("velmult", val, time); }
33254 float get_velmult(double time = TiMe::Default()) const { return getFloat("velmult", time); }
33255
33259 bool set_subgroup(int val, double time = TiMe::Default()) { return setValue("subgroup", val, time); }
33263 int get_subgroup(double time = TiMe::Default()) const { return getInt("subgroup", time); }
33264
33268 bool set_nolqshadows(bool val, double time = TiMe::Default()) { return setValue("nolqshadows", val, time); }
33272 bool get_nolqshadows(double time = TiMe::Default()) const { return getBool("nolqshadows", time); }
33273
33277 bool set_flatatoceanbord(bool val, double time = TiMe::Default()) { return setValue("flatatoceanbord", val, time); }
33281 bool get_flatatoceanbord(double time = TiMe::Default()) const { return getBool("flatatoceanbord", time); }
33282
33286 bool set_ignoresize(bool val, double time = TiMe::Default()) { return setValue("ignoresize", val, time); }
33290 bool get_ignoresize(double time = TiMe::Default()) const { return getBool("ignoresize", time); }
33291
33295 bool set_szlimit(float val, double time = TiMe::Default()) { return setValue("szlimit", val, time); }
33299 float get_szlimit(double time = TiMe::Default()) const { return getFloat("szlimit", time); }
33300
33304 bool set_vertoffs(float val, double time = TiMe::Default()) { return setValue("vertoffs", val, time); }
33308 float get_vertoffs(double time = TiMe::Default()) const { return getFloat("vertoffs", time); }
33309
33313 bool set_fogres(float val, double time = TiMe::Default()) { return setValue("fogres", val, time); }
33317 float get_fogres(double time = TiMe::Default()) const { return getFloat("fogres", time); }
33318
33322 bool set_fogmult(float val, double time = TiMe::Default()) { return setValue("fogmult", val, time); }
33326 float get_fogmult(double time = TiMe::Default()) const { return getFloat("fogmult", time); }
33327
33331 bool set_fogmult_legacy(float val, double time = TiMe::Default()) { return setValue("fogmult_legacy", val, time); }
33335 float get_fogmult_legacy(double time = TiMe::Default()) const { return getFloat("fogmult_legacy", time); }
33336
33340 bool set_rendstep(int val, double time = TiMe::Default()) { return setValue("rendstep", val, time); }
33344 int get_rendstep(double time = TiMe::Default()) const { return getInt("rendstep", time); }
33345
33349 bool set_rendshadstep(int val, double time = TiMe::Default()) { return setValue("rendshadstep", val, time); }
33353 int get_rendshadstep(double time = TiMe::Default()) const { return getInt("rendshadstep", time); }
33354
33358 bool set_absorption_color(const Color& color, double time = TiMe::Default()) { return setValue("absorption_color", color, time); }
33362 Color get_absorption_color(double time = TiMe::Default()) const { return getColor("absorption_color", time); }
33363
33367 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
33371 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
33372
33376 bool set_usereflmap(bool val, double time = TiMe::Default()) { return setValue("usereflmap", val, time); }
33380 bool get_usereflmap(double time = TiMe::Default()) const { return getBool("usereflmap", time); }
33381
33385 bool set_useenvmap(bool val, double time = TiMe::Default()) { return setValue("useenvmap", val, time); }
33389 bool get_useenvmap(double time = TiMe::Default()) const { return getBool("useenvmap", time); }
33390
33393 bool set_reflmap(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflmap", texture, time); }
33396 bool set_reflmap(const AColor& texture, double time = TiMe::Default()) { return setValue("reflmap", texture, time); }
33399 Value get_reflmap(double time = TiMe::Default()) const { return getValue("reflmap", time); }
33400
33403 bool set_envmap(const PluginRef& texture, double time = TiMe::Default()) { return setValue("envmap", texture, time); }
33406 bool set_envmap(const AColor& texture, double time = TiMe::Default()) { return setValue("envmap", texture, time); }
33409 Value get_envmap(double time = TiMe::Default()) const { return getValue("envmap", time); }
33410
33414 bool set_usegizmo(int val, double time = TiMe::Default()) { return setValue("usegizmo", val, time); }
33418 int get_usegizmo(double time = TiMe::Default()) const { return getInt("usegizmo", time); }
33419
33423 bool set_invgizmo(int val, double time = TiMe::Default()) { return setValue("invgizmo", val, time); }
33427 int get_invgizmo(double time = TiMe::Default()) const { return getInt("invgizmo", time); }
33428
33431 bool set_gizmo(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("gizmo", plugin, time); }
33434 PluginRef get_gizmo(double time = TiMe::Default()) const { return getPlugin("gizmo", time); }
33435
33439 bool set_gizmo_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("gizmo_transform", transform, time); }
33443 Transform get_gizmo_transform(double time = TiMe::Default()) const { return getTransform("gizmo_transform", time); }
33444
33448 bool set_useliquid(int val, double time = TiMe::Default()) { return setValue("useliquid", val, time); }
33452 int get_useliquid(double time = TiMe::Default()) const { return getInt("useliquid", time); }
33453
33456 bool set_liquid_sim(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("liquid_sim", plugin, time); }
33459 PluginRef get_liquid_sim(double time = TiMe::Default()) const { return getPlugin("liquid_sim", time); }
33460
33464 bool set_useglass(int val, double time = TiMe::Default()) { return setValue("useglass", val, time); }
33468 int get_useglass(double time = TiMe::Default()) const { return getInt("useglass", time); }
33469
33472 bool set_glass(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("glass", plugin, time); }
33475 PluginRef get_glass(double time = TiMe::Default()) const { return getPlugin("glass", time); }
33476
33480 bool set_glass_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("glass_transform", transform, time); }
33484 Transform get_glass_transform(double time = TiMe::Default()) const { return getTransform("glass_transform", time); }
33485
33488 bool set_lightlinks(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("lightlinks", pluginList, time); }
33489 bool set_lightlinks(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("lightlinks", plugins, count, time); }
33490 template<size_t count> bool set_lightlinks(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("lightlinks", plugins, count, time); }
33493 PluginList get_lightlinks(double time = TiMe::Default()) const { return getPluginList("lightlinks", time); }
33494
33498 bool set_lightcache(int val, double time = TiMe::Default()) { return setValue("lightcache", val, time); }
33502 int get_lightcache(double time = TiMe::Default()) const { return getInt("lightcache", time); }
33503
33507 bool set_lightcachesr(float val, double time = TiMe::Default()) { return setValue("lightcachesr", val, time); }
33511 float get_lightcachesr(double time = TiMe::Default()) const { return getFloat("lightcachesr", time); }
33512
33516 bool set_pmprimary(bool val, double time = TiMe::Default()) { return setValue("pmprimary", val, time); }
33520 bool get_pmprimary(double time = TiMe::Default()) const { return getBool("pmprimary", time); }
33521
33524 bool set_oceanlevel(float val, double time = TiMe::Default()) { return setValue("oceanlevel", val, time); }
33527 float get_oceanlevel(double time = TiMe::Default()) const { return getFloat("oceanlevel", time); }
33528
33532 bool set_generate_gi(int val, double time = TiMe::Default()) { return setValue("generate_gi", val, time); }
33536 int get_generate_gi(double time = TiMe::Default()) const { return getInt("generate_gi", time); }
33537
33541 bool set_receive_gi(int val, double time = TiMe::Default()) { return setValue("receive_gi", val, time); }
33545 int get_receive_gi(double time = TiMe::Default()) const { return getInt("receive_gi", time); }
33546
33550 bool set_gen_gi_mult(float val, double time = TiMe::Default()) { return setValue("gen_gi_mult", val, time); }
33554 float get_gen_gi_mult(double time = TiMe::Default()) const { return getFloat("gen_gi_mult", time); }
33555
33559 bool set_rec_gi_mult(float val, double time = TiMe::Default()) { return setValue("rec_gi_mult", val, time); }
33563 float get_rec_gi_mult(double time = TiMe::Default()) const { return getFloat("rec_gi_mult", time); }
33564
33568 bool set_generate_caust(int val, double time = TiMe::Default()) { return setValue("generate_caust", val, time); }
33572 int get_generate_caust(double time = TiMe::Default()) const { return getInt("generate_caust", time); }
33573
33577 bool set_receive_caust(int val, double time = TiMe::Default()) { return setValue("receive_caust", val, time); }
33581 int get_receive_caust(double time = TiMe::Default()) const { return getInt("receive_caust", time); }
33582
33586 bool set_caust_mult(float val, double time = TiMe::Default()) { return setValue("caust_mult", val, time); }
33590 float get_caust_mult(double time = TiMe::Default()) const { return getFloat("caust_mult", time); }
33591
33595 bool set_camera_visibility(bool val, double time = TiMe::Default()) { return setValue("camera_visibility", val, time); }
33599 bool get_camera_visibility(double time = TiMe::Default()) const { return getBool("camera_visibility", time); }
33600
33604 bool set_reflections_visibility(bool val, double time = TiMe::Default()) { return setValue("reflections_visibility", val, time); }
33608 bool get_reflections_visibility(double time = TiMe::Default()) const { return getBool("reflections_visibility", time); }
33609
33613 bool set_refractions_visibility(bool val, double time = TiMe::Default()) { return setValue("refractions_visibility", val, time); }
33617 bool get_refractions_visibility(double time = TiMe::Default()) const { return getBool("refractions_visibility", time); }
33618
33622 bool set_gi_visibility(bool val, double time = TiMe::Default()) { return setValue("gi_visibility", val, time); }
33626 bool get_gi_visibility(double time = TiMe::Default()) const { return getBool("gi_visibility", time); }
33627
33631 bool set_shadows_visibility(bool val, double time = TiMe::Default()) { return setValue("shadows_visibility", val, time); }
33635 bool get_shadows_visibility(double time = TiMe::Default()) const { return getBool("shadows_visibility", time); }
33636
33640 bool set_probabilistic(int val, double time = TiMe::Default()) { return setValue("probabilistic", val, time); }
33644 int get_probabilistic(double time = TiMe::Default()) const { return getInt("probabilistic", time); }
33645
33649 bool set_material_id(const Color& color, double time = TiMe::Default()) { return setValue("material_id", color, time); }
33653 Color get_material_id(double time = TiMe::Default()) const { return getColor("material_id", time); }
33654
33658 bool set_volzdepth(int val, double time = TiMe::Default()) { return setValue("volzdepth", val, time); }
33662 int get_volzdepth(double time = TiMe::Default()) const { return getInt("volzdepth", time); }
33663
33667 bool set_part_age(int val, double time = TiMe::Default()) { return setValue("part_age", val, time); }
33671 int get_part_age(double time = TiMe::Default()) const { return getInt("part_age", time); }
33672
33676 bool set_volumetric_mode_geometry_RE(bool val, double time = TiMe::Default()) { return setValue("volumetric_mode_geometry_RE", val, time); }
33680 bool get_volumetric_mode_geometry_RE(double time = TiMe::Default()) const { return getBool("volumetric_mode_geometry_RE", time); }
33681
33684 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
33687 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
33688
33691 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
33694 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
33695
33698 bool set_user_attributes(const char* str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
33701 bool set_user_attributes(const std::string& str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
33704 std::string get_user_attributes(double time = TiMe::Default()) const { return getString("user_attributes", time); }
33705
33708 bool set_user_attributes_bin(const IntList& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", intList, time); }
33709 bool set_user_attributes_bin(IntList&& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", std::move(intList), time); }
33710 bool set_user_attributes_bin(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
33711 template<size_t count> bool set_user_attributes_bin(const int (&ints)[count], double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
33714 IntList get_user_attributes_bin(double time = TiMe::Default()) const { return getIntList("user_attributes_bin", time); }
33715};
33716
33718class PhxShaderFoamTex : public Plugin {
33719public:
33721 static constexpr const PluginTypeId getTypeId() { return 0x4B37A5123; }
33723 static constexpr const char* getType() { return "PhxShaderFoamTex"; }
33724
33725 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
33726
33730 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
33734 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
33735
33739 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
33743 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
33744
33747 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
33750 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
33751
33755 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
33759 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
33760
33763 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
33766 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
33769 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
33770
33773 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
33776 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
33779 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
33780
33783 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
33786 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
33789 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
33790
33793 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
33796 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
33799 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
33800
33804 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
33808 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
33812 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
33813
33815 PluginRef out_color() const { return PluginRef(*this, "color"); }
33816
33818 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
33819
33821 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
33822
33824 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
33825
33828 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
33831 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
33832
33836 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
33840 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
33841
33845 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
33849 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
33850
33854 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
33858 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
33859
33863 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
33867 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
33868
33872 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
33876 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
33877
33881 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
33885 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
33886
33890 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
33894 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
33895
33899 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
33903 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
33904
33908 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
33912 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
33913
33917 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
33921 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
33922
33926 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
33930 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
33931
33935 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
33939 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
33940
33944 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
33948 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
33949
33953 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
33957 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
33958
33961 bool set_ocean(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ocean", texture, time); }
33964 bool set_ocean(const AColor& texture, double time = TiMe::Default()) { return setValue("ocean", texture, time); }
33967 Value get_ocean(double time = TiMe::Default()) const { return getValue("ocean", time); }
33968
33971 bool set_life(float val, double time = TiMe::Default()) { return setValue("life", val, time); }
33974 float get_life(double time = TiMe::Default()) const { return getFloat("life", time); }
33975
33978 bool set_thr(float val, double time = TiMe::Default()) { return setValue("thr", val, time); }
33981 float get_thr(double time = TiMe::Default()) const { return getFloat("thr", time); }
33982
33985 bool set_ptrn(float val, double time = TiMe::Default()) { return setValue("ptrn", val, time); }
33988 float get_ptrn(double time = TiMe::Default()) const { return getFloat("ptrn", time); }
33989
33992 bool set_ptrnszx(float val, double time = TiMe::Default()) { return setValue("ptrnszx", val, time); }
33995 float get_ptrnszx(double time = TiMe::Default()) const { return getFloat("ptrnszx", time); }
33996
33999 bool set_ptrnszy(float val, double time = TiMe::Default()) { return setValue("ptrnszy", val, time); }
34002 float get_ptrnszy(double time = TiMe::Default()) const { return getFloat("ptrnszy", time); }
34003
34006 bool set_uwfoam(float val, double time = TiMe::Default()) { return setValue("uwfoam", val, time); }
34009 float get_uwfoam(double time = TiMe::Default()) const { return getFloat("uwfoam", time); }
34010
34013 bool set_tint(const Color& color, double time = TiMe::Default()) { return setValue("tint", color, time); }
34016 Color get_tint(double time = TiMe::Default()) const { return getColor("tint", time); }
34017
34020 bool set_foamcolor(const Color& color, double time = TiMe::Default()) { return setValue("foamcolor", color, time); }
34023 Color get_foamcolor(double time = TiMe::Default()) const { return getColor("foamcolor", time); }
34024
34027 bool set_useuvw(bool val, double time = TiMe::Default()) { return setValue("useuvw", val, time); }
34030 bool get_useuvw(double time = TiMe::Default()) const { return getBool("useuvw", time); }
34031};
34032
34035public:
34037 static constexpr const PluginTypeId getTypeId() { return 0x4AFE0C71D; }
34039 static constexpr const char* getType() { return "PhxShaderOceanTex"; }
34040
34041 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
34042
34046 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
34050 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
34051
34055 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
34059 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
34060
34063 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
34066 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
34067
34071 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
34075 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
34076
34079 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
34082 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
34085 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
34086
34089 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
34092 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
34095 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
34096
34099 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
34102 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
34105 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
34106
34109 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
34112 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
34115 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
34116
34120 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
34124 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
34128 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
34129
34131 PluginRef out_color() const { return PluginRef(*this, "color"); }
34132
34134 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
34135
34137 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
34138
34140 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
34141
34144 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
34147 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
34148
34152 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
34156 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
34157
34161 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
34165 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
34166
34170 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
34174 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
34175
34179 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
34183 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
34184
34188 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
34192 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
34193
34197 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
34201 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
34202
34206 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
34210 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
34211
34215 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
34219 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
34220
34224 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
34228 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
34229
34233 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
34237 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
34238
34242 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
34246 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
34247
34251 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
34255 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
34256
34260 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
34264 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
34265
34269 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
34273 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
34274
34278 bool set_vector(bool val, double time = TiMe::Default()) { return setValue("vector", val, time); }
34282 bool get_vector(double time = TiMe::Default()) const { return getBool("vector", time); }
34283
34287 bool set_usewind(bool val, double time = TiMe::Default()) { return setValue("usewind", val, time); }
34291 bool get_usewind(double time = TiMe::Default()) const { return getBool("usewind", time); }
34292
34296 bool set_wind(float val, double time = TiMe::Default()) { return setValue("wind", val, time); }
34300 float get_wind(double time = TiMe::Default()) const { return getFloat("wind", time); }
34301
34305 bool set_lod(int val, double time = TiMe::Default()) { return setValue("lod", val, time); }
34309 int get_lod(double time = TiMe::Default()) const { return getInt("lod", time); }
34310
34314 bool set_sharpness(float val, double time = TiMe::Default()) { return setValue("sharpness", val, time); }
34318 float get_sharpness(double time = TiMe::Default()) const { return getFloat("sharpness", time); }
34319
34323 bool set_velmult(float val, double time = TiMe::Default()) { return setValue("velmult", val, time); }
34327 float get_velmult(double time = TiMe::Default()) const { return getFloat("velmult", time); }
34328
34332 bool set_velcoh(float val, double time = TiMe::Default()) { return setValue("velcoh", val, time); }
34336 float get_velcoh(double time = TiMe::Default()) const { return getFloat("velcoh", time); }
34337
34341 bool set_rgbmult(float val, double time = TiMe::Default()) { return setValue("rgbmult", val, time); }
34345 float get_rgbmult(double time = TiMe::Default()) const { return getFloat("rgbmult", time); }
34346
34350 bool set_rgboffset(float val, double time = TiMe::Default()) { return setValue("rgboffset", val, time); }
34354 float get_rgboffset(double time = TiMe::Default()) const { return getFloat("rgboffset", time); }
34355
34359 bool set_meter_scale(float val, double time = TiMe::Default()) { return setValue("meter_scale", val, time); }
34363 float get_meter_scale(double time = TiMe::Default()) const { return getFloat("meter_scale", time); }
34364
34368 bool set_up_vector(int val, double time = TiMe::Default()) { return setValue("up_vector", val, time); }
34372 int get_up_vector(double time = TiMe::Default()) const { return getInt("up_vector", time); }
34373
34377 bool set_seed(int val, double time = TiMe::Default()) { return setValue("seed", val, time); }
34381 int get_seed(double time = TiMe::Default()) const { return getInt("seed", time); }
34382
34386 bool set_bell(float val, double time = TiMe::Default()) { return setValue("bell", val, time); }
34390 float get_bell(double time = TiMe::Default()) const { return getFloat("bell", time); }
34391
34395 bool set_animmode(int val, double time = TiMe::Default()) { return setValue("animmode", val, time); }
34399 int get_animmode(double time = TiMe::Default()) const { return getInt("animmode", time); }
34400
34404 bool set_loopLength(float val, double time = TiMe::Default()) { return setValue("loopLength", val, time); }
34408 float get_loopLength(double time = TiMe::Default()) const { return getFloat("loopLength", time); }
34409
34413 bool set_directTime(float val, double time = TiMe::Default()) { return setValue("directTime", val, time); }
34417 float get_directTime(double time = TiMe::Default()) const { return getFloat("directTime", time); }
34418
34422 bool set_scaletex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("scaletex", texture, time); }
34426 bool set_scaletex(const AColor& texture, double time = TiMe::Default()) { return setValue("scaletex", texture, time); }
34430 Value get_scaletex(double time = TiMe::Default()) const { return getValue("scaletex", time); }
34431};
34432
34434class PhxShaderPGroup : public Plugin {
34435public:
34437 static constexpr const PluginTypeId getTypeId() { return 0x4AEB47065; }
34439 static constexpr const char* getType() { return "PhxShaderPGroup"; }
34440
34443 bool set_phoenix_sim(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("phoenix_sim", plugin, time); }
34446 PluginRef get_phoenix_sim(double time = TiMe::Default()) const { return getPlugin("phoenix_sim", time); }
34447
34451 bool set_pgroup(const char* str, double time = TiMe::Default()) { return setValue("pgroup", str, time); }
34455 bool set_pgroup(const std::string& str, double time = TiMe::Default()) { return setValue("pgroup", str, time); }
34459 std::string get_pgroup(double time = TiMe::Default()) const { return getString("pgroup", time); }
34460
34464 bool set_lifespan_mode(int val, double time = TiMe::Default()) { return setValue("lifespan_mode", val, time); }
34468 int get_lifespan_mode(double time = TiMe::Default()) const { return getInt("lifespan_mode", time); }
34469
34473 bool set_lifespan_seed(int val, double time = TiMe::Default()) { return setValue("lifespan_seed", val, time); }
34477 int get_lifespan_seed(double time = TiMe::Default()) const { return getInt("lifespan_seed", time); }
34478
34482 bool set_lifespan(float val, double time = TiMe::Default()) { return setValue("lifespan", val, time); }
34486 float get_lifespan(double time = TiMe::Default()) const { return getFloat("lifespan", time); }
34487
34491 bool set_lifespan_random(float val, double time = TiMe::Default()) { return setValue("lifespan_random", val, time); }
34495 float get_lifespan_random(double time = TiMe::Default()) const { return getFloat("lifespan_random", time); }
34496};
34497
34500public:
34502 static constexpr const PluginTypeId getTypeId() { return 0x4B1AD9003; }
34504 static constexpr const char* getType() { return "PhxShaderParticleTex"; }
34505
34506 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
34507
34511 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
34515 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
34516
34520 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
34524 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
34525
34528 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
34531 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
34532
34536 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
34540 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
34541
34544 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
34547 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
34550 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
34551
34554 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
34557 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
34560 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
34561
34564 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
34567 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
34570 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
34571
34574 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
34577 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
34580 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
34581
34585 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
34589 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
34593 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
34594
34596 PluginRef out_color() const { return PluginRef(*this, "color"); }
34597
34599 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
34600
34602 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
34603
34605 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
34606
34609 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
34612 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
34613
34617 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
34621 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
34622
34626 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
34630 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
34631
34635 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
34639 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
34640
34644 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
34648 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
34649
34653 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
34657 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
34658
34662 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
34666 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
34667
34671 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
34675 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
34676
34680 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
34684 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
34685
34689 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
34693 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
34694
34698 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
34702 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
34703
34707 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
34711 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
34712
34716 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
34720 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
34721
34725 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
34729 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
34730
34734 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
34738 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
34739
34741 bool set_system(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("system", pluginList, time); }
34742 bool set_system(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("system", plugins, count, time); }
34743 template<size_t count> bool set_system(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("system", plugins, count, time); }
34745 PluginList get_system(double time = TiMe::Default()) const { return getPluginList("system", time); }
34746
34748 bool set_system_tm(const ValueList& list, double time = TiMe::Default()) { return setValue("system_tm", list, time); }
34749 bool set_system_tm(ValueList&& list, double time = TiMe::Default()) { return setValue("system_tm", std::move(list), time); }
34750 bool set_system_tm(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("system_tm", values, count, time); }
34751 template<size_t count> bool set_system_tm(const Value (&values)[count], double time = TiMe::Default()) { return setArray("system_tm", values, count, time); }
34752 template<size_t count> bool set_system_tm(Value (&&values)[count], double time = TiMe::Default()) { return setArray("system_tm", values, count, time); }
34754 ValueList get_system_tm(double time = TiMe::Default()) const { return getValueList("system_tm", time); }
34755
34758 bool set_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("map", texture, time); }
34761 bool set_map(const AColor& texture, double time = TiMe::Default()) { return setValue("map", texture, time); }
34764 Value get_map(double time = TiMe::Default()) const { return getValue("map", time); }
34765
34768 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
34771 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
34772
34774 bool set_radius_anim(const ValueList& list, double time = TiMe::Default()) { return setValue("radius_anim", list, time); }
34775 bool set_radius_anim(ValueList&& list, double time = TiMe::Default()) { return setValue("radius_anim", std::move(list), time); }
34776 bool set_radius_anim(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("radius_anim", values, count, time); }
34777 template<size_t count> bool set_radius_anim(const Value (&values)[count], double time = TiMe::Default()) { return setArray("radius_anim", values, count, time); }
34778 template<size_t count> bool set_radius_anim(Value (&&values)[count], double time = TiMe::Default()) { return setArray("radius_anim", values, count, time); }
34780 ValueList get_radius_anim(double time = TiMe::Default()) const { return getValueList("radius_anim", time); }
34781
34784 bool set_radius_time(bool val, double time = TiMe::Default()) { return setValue("radius_time", val, time); }
34787 bool get_radius_time(double time = TiMe::Default()) const { return getBool("radius_time", time); }
34788
34791 bool set_mulbysz(bool val, double time = TiMe::Default()) { return setValue("mulbysz", val, time); }
34794 bool get_mulbysz(double time = TiMe::Default()) const { return getBool("mulbysz", time); }
34795
34798 bool set_amplitude(float val, double time = TiMe::Default()) { return setValue("amplitude", val, time); }
34801 float get_amplitude(double time = TiMe::Default()) const { return getFloat("amplitude", time); }
34802
34804 bool set_amplitude_anim(const ValueList& list, double time = TiMe::Default()) { return setValue("amplitude_anim", list, time); }
34805 bool set_amplitude_anim(ValueList&& list, double time = TiMe::Default()) { return setValue("amplitude_anim", std::move(list), time); }
34806 bool set_amplitude_anim(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("amplitude_anim", values, count, time); }
34807 template<size_t count> bool set_amplitude_anim(const Value (&values)[count], double time = TiMe::Default()) { return setArray("amplitude_anim", values, count, time); }
34808 template<size_t count> bool set_amplitude_anim(Value (&&values)[count], double time = TiMe::Default()) { return setArray("amplitude_anim", values, count, time); }
34810 ValueList get_amplitude_anim(double time = TiMe::Default()) const { return getValueList("amplitude_anim", time); }
34811
34814 bool set_amplitude_time(bool val, double time = TiMe::Default()) { return setValue("amplitude_time", val, time); }
34817 bool get_amplitude_time(double time = TiMe::Default()) const { return getBool("amplitude_time", time); }
34818
34821 bool set_shift_mode(bool val, double time = TiMe::Default()) { return setValue("shift_mode", val, time); }
34824 bool get_shift_mode(double time = TiMe::Default()) const { return getBool("shift_mode", time); }
34825
34828 bool set_shift(float val, double time = TiMe::Default()) { return setValue("shift", val, time); }
34831 float get_shift(double time = TiMe::Default()) const { return getFloat("shift", time); }
34832
34834 bool set_shift_anim(const ValueList& list, double time = TiMe::Default()) { return setValue("shift_anim", list, time); }
34835 bool set_shift_anim(ValueList&& list, double time = TiMe::Default()) { return setValue("shift_anim", std::move(list), time); }
34836 bool set_shift_anim(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("shift_anim", values, count, time); }
34837 template<size_t count> bool set_shift_anim(const Value (&values)[count], double time = TiMe::Default()) { return setArray("shift_anim", values, count, time); }
34838 template<size_t count> bool set_shift_anim(Value (&&values)[count], double time = TiMe::Default()) { return setArray("shift_anim", values, count, time); }
34840 ValueList get_shift_anim(double time = TiMe::Default()) const { return getValueList("shift_anim", time); }
34841
34844 bool set_shift_time(bool val, double time = TiMe::Default()) { return setValue("shift_time", val, time); }
34847 bool get_shift_time(double time = TiMe::Default()) const { return getBool("shift_time", time); }
34848
34851 bool set_blending(int val, double time = TiMe::Default()) { return setValue("blending", val, time); }
34854 int get_blending(double time = TiMe::Default()) const { return getInt("blending", time); }
34855
34858 bool set_blend_alpha(bool val, double time = TiMe::Default()) { return setValue("blend_alpha", val, time); }
34861 bool get_blend_alpha(double time = TiMe::Default()) const { return getBool("blend_alpha", time); }
34862
34865 bool set_local_space_particles(bool val, double time = TiMe::Default()) { return setValue("local_space_particles", val, time); }
34868 bool get_local_space_particles(double time = TiMe::Default()) const { return getBool("local_space_particles", time); }
34869
34872 bool set_colfrompartchan(bool val, double time = TiMe::Default()) { return setValue("colfrompartchan", val, time); }
34875 bool get_colfrompartchan(double time = TiMe::Default()) const { return getBool("colfrompartchan", time); }
34876
34879 bool set_colpartchan(const char* str, double time = TiMe::Default()) { return setValue("colpartchan", str, time); }
34882 bool set_colpartchan(const std::string& str, double time = TiMe::Default()) { return setValue("colpartchan", str, time); }
34885 std::string get_colpartchan(double time = TiMe::Default()) const { return getString("colpartchan", time); }
34886
34889 bool set_partcolmin(float val, double time = TiMe::Default()) { return setValue("partcolmin", val, time); }
34892 float get_partcolmin(double time = TiMe::Default()) const { return getFloat("partcolmin", time); }
34893
34896 bool set_partcolmax(float val, double time = TiMe::Default()) { return setValue("partcolmax", val, time); }
34899 float get_partcolmax(double time = TiMe::Default()) const { return getFloat("partcolmax", time); }
34900
34903 bool set_partcolremap(bool val, double time = TiMe::Default()) { return setValue("partcolremap", val, time); }
34906 bool get_partcolremap(double time = TiMe::Default()) const { return getBool("partcolremap", time); }
34907
34910 bool set_remapcolcomp(int val, double time = TiMe::Default()) { return setValue("remapcolcomp", val, time); }
34913 int get_remapcolcomp(double time = TiMe::Default()) const { return getInt("remapcolcomp", time); }
34914
34917 bool set_partcolor_p(const FloatList& floatList, double time = TiMe::Default()) { return setValue("partcolor_p", floatList, time); }
34918 bool set_partcolor_p(FloatList&& floatList, double time = TiMe::Default()) { return setValue("partcolor_p", std::move(floatList), time); }
34919 bool set_partcolor_p(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("partcolor_p", floats, count, time); }
34920 template<size_t count> bool set_partcolor_p(const float (&floats)[count], double time = TiMe::Default()) { return setArray("partcolor_p", floats, count, time); }
34923 FloatList get_partcolor_p(double time = TiMe::Default()) const { return getFloatList("partcolor_p", time); }
34924
34927 bool set_partcolor_c(const ColorList& colorList, double time = TiMe::Default()) { return setValue("partcolor_c", colorList, time); }
34928 bool set_partcolor_c(ColorList&& colorList, double time = TiMe::Default()) { return setValue("partcolor_c", std::move(colorList), time); }
34929 bool set_partcolor_c(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("partcolor_c", colors, count, time); }
34930 template<size_t count> bool set_partcolor_c(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("partcolor_c", colors, count, time); }
34933 ColorList get_partcolor_c(double time = TiMe::Default()) const { return getColorList("partcolor_c", time); }
34934
34937 bool set_partcolor_i(const IntList& intList, double time = TiMe::Default()) { return setValue("partcolor_i", intList, time); }
34938 bool set_partcolor_i(IntList&& intList, double time = TiMe::Default()) { return setValue("partcolor_i", std::move(intList), time); }
34939 bool set_partcolor_i(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("partcolor_i", ints, count, time); }
34940 template<size_t count> bool set_partcolor_i(const int (&ints)[count], double time = TiMe::Default()) { return setArray("partcolor_i", ints, count, time); }
34943 IntList get_partcolor_i(double time = TiMe::Default()) const { return getIntList("partcolor_i", time); }
34944};
34945
34948public:
34950 static constexpr const PluginTypeId getTypeId() { return 0x4B111EC43; }
34952 static constexpr const char* getType() { return "PhxShaderPrtLoader"; }
34953
34957 bool set_filesrc(const char* str, double time = TiMe::Default()) { return setValue("filesrc", str, time); }
34961 bool set_filesrc(const std::string& str, double time = TiMe::Default()) { return setValue("filesrc", str, time); }
34965 std::string get_filesrc(double time = TiMe::Default()) const { return getString("filesrc", time); }
34966
34970 bool set_usetm(bool val, double time = TiMe::Default()) { return setValue("usetm", val, time); }
34974 bool get_usetm(double time = TiMe::Default()) const { return getBool("usetm", time); }
34975
34979 bool set_velmult(float val, double time = TiMe::Default()) { return setValue("velmult", val, time); }
34983 float get_velmult(double time = TiMe::Default()) const { return getFloat("velmult", time); }
34984};
34985
34987class PhxShaderSim : public Plugin {
34988public:
34990 static constexpr const PluginTypeId getTypeId() { return 0x4AEA9A6B7; }
34992 static constexpr const char* getType() { return "PhxShaderSim"; }
34993
34994 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
34995
34996 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
34997
34998 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
34999
35003 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
35007 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
35008
35011 bool set_cache(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("cache", plugin, time); }
35014 PluginRef get_cache(double time = TiMe::Default()) const { return getPlugin("cache", time); }
35015
35019 bool set_contentTime(int val, double time = TiMe::Default()) { return setValue("contentTime", val, time); }
35023 int get_contentTime(double time = TiMe::Default()) const { return getInt("contentTime", time); }
35024
35028 bool set_frame_duration(float val, double time = TiMe::Default()) { return setValue("frame_duration", val, time); }
35032 float get_frame_duration(double time = TiMe::Default()) const { return getFloat("frame_duration", time); }
35033
35037 bool set_play_speed(float val, double time = TiMe::Default()) { return setValue("play_speed", val, time); }
35041 float get_play_speed(double time = TiMe::Default()) const { return getFloat("play_speed", time); }
35042
35046 bool set_wind_from_movement(bool val, double time = TiMe::Default()) { return setValue("wind_from_movement", val, time); }
35050 bool get_wind_from_movement(double time = TiMe::Default()) const { return getBool("wind_from_movement", time); }
35051
35055 bool set_unit_scale(float val, double time = TiMe::Default()) { return setValue("unit_scale", val, time); }
35059 float get_unit_scale(double time = TiMe::Default()) const { return getFloat("unit_scale", time); }
35060
35064 bool set_node_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("node_transform", transform, time); }
35068 Transform get_node_transform(double time = TiMe::Default()) const { return getTransform("node_transform", time); }
35069
35073 bool set_use_node_transform_for_instancing(bool val, double time = TiMe::Default()) { return setValue("use_node_transform_for_instancing", val, time); }
35077 bool get_use_node_transform_for_instancing(double time = TiMe::Default()) const { return getBool("use_node_transform_for_instancing", time); }
35078
35082 bool set_renderAsVolumetric(bool val, double time = TiMe::Default()) { return setValue("renderAsVolumetric", val, time); }
35086 bool get_renderAsVolumetric(double time = TiMe::Default()) const { return getBool("renderAsVolumetric", time); }
35087
35091 bool set_render(bool val, double time = TiMe::Default()) { return setValue("render", val, time); }
35095 bool get_render(double time = TiMe::Default()) const { return getBool("render", time); }
35096
35100 bool set_rendMode(int val, double time = TiMe::Default()) { return setValue("rendMode", val, time); }
35104 int get_rendMode(double time = TiMe::Default()) const { return getInt("rendMode", time); }
35105
35109 bool set_rendstep(int val, double time = TiMe::Default()) { return setValue("rendstep", val, time); }
35113 int get_rendstep(double time = TiMe::Default()) const { return getInt("rendstep", time); }
35114
35118 bool set_rendshadstep(int val, double time = TiMe::Default()) { return setValue("rendshadstep", val, time); }
35122 int get_rendshadstep(double time = TiMe::Default()) const { return getInt("rendshadstep", time); }
35123
35127 bool set_jitter(bool val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
35131 bool get_jitter(double time = TiMe::Default()) const { return getBool("jitter", time); }
35132
35136 bool set_borderFade(float val, double time = TiMe::Default()) { return setValue("borderFade", val, time); }
35140 float get_borderFade(double time = TiMe::Default()) const { return getFloat("borderFade", time); }
35141
35145 bool set_sampler(int val, double time = TiMe::Default()) { return setValue("sampler", val, time); }
35149 int get_sampler(double time = TiMe::Default()) const { return getInt("sampler", time); }
35150
35154 bool set_velocity_mult(float val, double time = TiMe::Default()) { return setValue("velocity_mult", val, time); }
35158 float get_velocity_mult(double time = TiMe::Default()) const { return getFloat("velocity_mult", time); }
35159
35163 bool set_varg(int val, double time = TiMe::Default()) { return setValue("varg", val, time); }
35167 int get_varg(double time = TiMe::Default()) const { return getInt("varg", time); }
35168
35171 bool set_vtex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("vtex", texture, time); }
35174 bool set_vtex(const AColor& texture, double time = TiMe::Default()) { return setValue("vtex", texture, time); }
35177 Value get_vtex(double time = TiMe::Default()) const { return getValue("vtex", time); }
35178
35182 bool set_mod_v(int val, double time = TiMe::Default()) { return setValue("mod_v", val, time); }
35186 int get_mod_v(double time = TiMe::Default()) const { return getInt("mod_v", time); }
35187
35191 bool set_velocities(const ColorList& colorList, double time = TiMe::Default()) { return setValue("velocities", colorList, time); }
35192 bool set_velocities(ColorList&& colorList, double time = TiMe::Default()) { return setValue("velocities", std::move(colorList), time); }
35193 bool set_velocities(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("velocities", colors, count, time); }
35194 template<size_t count> bool set_velocities(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("velocities", colors, count, time); }
35198 ColorList get_velocities(double time = TiMe::Default()) const { return getColorList("velocities", time); }
35199
35203 bool set_sarg(int val, double time = TiMe::Default()) { return setValue("sarg", val, time); }
35207 int get_sarg(double time = TiMe::Default()) const { return getInt("sarg", time); }
35208
35212 bool set_surface_chan(const char* str, double time = TiMe::Default()) { return setValue("surface_chan", str, time); }
35216 bool set_surface_chan(const std::string& str, double time = TiMe::Default()) { return setValue("surface_chan", str, time); }
35220 std::string get_surface_chan(double time = TiMe::Default()) const { return getString("surface_chan", time); }
35221
35224 bool set_stex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("stex", texture, time); }
35227 bool set_stex(const AColor& texture, double time = TiMe::Default()) { return setValue("stex", texture, time); }
35230 Value get_stex(double time = TiMe::Default()) const { return getValue("stex", time); }
35231
35235 bool set_surflevel(float val, double time = TiMe::Default()) { return setValue("surflevel", val, time); }
35239 float get_surflevel(double time = TiMe::Default()) const { return getFloat("surflevel", time); }
35240
35244 bool set_solidbelow(bool val, double time = TiMe::Default()) { return setValue("solidbelow", val, time); }
35248 bool get_solidbelow(double time = TiMe::Default()) const { return getBool("solidbelow", time); }
35249
35253 bool set_usegizmo(int val, double time = TiMe::Default()) { return setValue("usegizmo", val, time); }
35257 int get_usegizmo(double time = TiMe::Default()) const { return getInt("usegizmo", time); }
35258
35261 bool set_gizmo(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("gizmo", plugin, time); }
35264 PluginRef get_gizmo(double time = TiMe::Default()) const { return getPlugin("gizmo", time); }
35265
35269 bool set_gizmo_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("gizmo_transform", transform, time); }
35273 Transform get_gizmo_transform(double time = TiMe::Default()) const { return getTransform("gizmo_transform", time); }
35274
35278 bool set_invgizmo(int val, double time = TiMe::Default()) { return setValue("invgizmo", val, time); }
35282 int get_invgizmo(double time = TiMe::Default()) const { return getInt("invgizmo", time); }
35283
35287 bool set_oceanlevel(float val, double time = TiMe::Default()) { return setValue("oceanlevel", val, time); }
35291 float get_oceanlevel(double time = TiMe::Default()) const { return getFloat("oceanlevel", time); }
35292
35296 bool set_oceantransitionzone(float val, double time = TiMe::Default()) { return setValue("oceantransitionzone", val, time); }
35300 float get_oceantransitionzone(double time = TiMe::Default()) const { return getFloat("oceantransitionzone", time); }
35301
35305 bool set_meshsubdiv(float val, double time = TiMe::Default()) { return setValue("meshsubdiv", val, time); }
35309 float get_meshsubdiv(double time = TiMe::Default()) const { return getFloat("meshsubdiv", time); }
35310
35314 bool set_oceanhorizrough(float val, double time = TiMe::Default()) { return setValue("oceanhorizrough", val, time); }
35318 float get_oceanhorizrough(double time = TiMe::Default()) const { return getFloat("oceanhorizrough", time); }
35319
35323 bool set_oceanextramargin(float val, double time = TiMe::Default()) { return setValue("oceanextramargin", val, time); }
35327 float get_oceanextramargin(double time = TiMe::Default()) const { return getFloat("oceanextramargin", time); }
35328
35332 bool set_pureocean(bool val, double time = TiMe::Default()) { return setValue("pureocean", val, time); }
35336 bool get_pureocean(double time = TiMe::Default()) const { return getBool("pureocean", time); }
35337
35341 bool set_uwglasses(bool val, double time = TiMe::Default()) { return setValue("uwglasses", val, time); }
35345 bool get_uwglasses(double time = TiMe::Default()) const { return getBool("uwglasses", time); }
35346
35350 bool set_mbself(bool val, double time = TiMe::Default()) { return setValue("mbself", val, time); }
35354 bool get_mbself(double time = TiMe::Default()) const { return getBool("mbself", time); }
35355
35359 bool set_smoothmesh(int val, double time = TiMe::Default()) { return setValue("smoothmesh", val, time); }
35363 int get_smoothmesh(double time = TiMe::Default()) const { return getInt("smoothmesh", time); }
35364
35368 bool set_smooth_normals(int val, double time = TiMe::Default()) { return setValue("smooth_normals", val, time); }
35372 int get_smooth_normals(double time = TiMe::Default()) const { return getInt("smooth_normals", time); }
35373
35377 bool set_useprt(bool val, double time = TiMe::Default()) { return setValue("useprt", val, time); }
35381 bool get_useprt(double time = TiMe::Default()) const { return getBool("useprt", time); }
35382
35386 bool set_prtsz(float val, double time = TiMe::Default()) { return setValue("prtsz", val, time); }
35390 float get_prtsz(double time = TiMe::Default()) const { return getFloat("prtsz", time); }
35391
35395 bool set_cachestretchzone(float val, double time = TiMe::Default()) { return setValue("cachestretchzone", val, time); }
35399 float get_cachestretchzone(double time = TiMe::Default()) const { return getFloat("cachestretchzone", time); }
35400
35404 bool set_displacement(bool val, double time = TiMe::Default()) { return setValue("displacement", val, time); }
35408 bool get_displacement(double time = TiMe::Default()) const { return getBool("displacement", time); }
35409
35413 bool set_displmul(float val, double time = TiMe::Default()) { return setValue("displmul", val, time); }
35417 float get_displmul(double time = TiMe::Default()) const { return getFloat("displmul", time); }
35418
35421 bool set_displ0(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displ0", texture, time); }
35424 bool set_displ0(const AColor& texture, double time = TiMe::Default()) { return setValue("displ0", texture, time); }
35427 Value get_displ0(double time = TiMe::Default()) const { return getValue("displ0", time); }
35428
35431 bool set_displ1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displ1", texture, time); }
35434 bool set_displ1(const AColor& texture, double time = TiMe::Default()) { return setValue("displ1", texture, time); }
35437 Value get_displ1(double time = TiMe::Default()) const { return getValue("displ1", time); }
35438
35441 bool set_displ2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displ2", texture, time); }
35444 bool set_displ2(const AColor& texture, double time = TiMe::Default()) { return setValue("displ2", texture, time); }
35447 Value get_displ2(double time = TiMe::Default()) const { return getValue("displ2", time); }
35448
35452 bool set_displ2d(int val, double time = TiMe::Default()) { return setValue("displ2d", val, time); }
35456 int get_displ2d(double time = TiMe::Default()) const { return getInt("displ2d", time); }
35457
35461 bool set_fadebylevel(bool val, double time = TiMe::Default()) { return setValue("fadebylevel", val, time); }
35465 bool get_fadebylevel(double time = TiMe::Default()) const { return getBool("fadebylevel", time); }
35466
35470 bool set_displfade(float val, double time = TiMe::Default()) { return setValue("displfade", val, time); }
35474 float get_displfade(double time = TiMe::Default()) const { return getFloat("displfade", time); }
35475
35479 bool set_fadebyvel(bool val, double time = TiMe::Default()) { return setValue("fadebyvel", val, time); }
35483 bool get_fadebyvel(double time = TiMe::Default()) const { return getBool("fadebyvel", time); }
35484
35488 bool set_displvelfade(float val, double time = TiMe::Default()) { return setValue("displvelfade", val, time); }
35492 float get_displvelfade(double time = TiMe::Default()) const { return getFloat("displvelfade", time); }
35493
35497 bool set_usefadeobj(int val, double time = TiMe::Default()) { return setValue("usefadeobj", val, time); }
35501 int get_usefadeobj(double time = TiMe::Default()) const { return getInt("usefadeobj", time); }
35502
35506 bool set_displgeomfade(float val, double time = TiMe::Default()) { return setValue("displgeomfade", val, time); }
35510 float get_displgeomfade(double time = TiMe::Default()) const { return getFloat("displgeomfade", time); }
35511
35514 bool set_fadeobj(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("fadeobj", plugin, time); }
35517 PluginRef get_fadeobj(double time = TiMe::Default()) const { return getPlugin("fadeobj", time); }
35518
35522 bool set_fadeobj_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("fadeobj_transform", transform, time); }
35526 Transform get_fadeobj_transform(double time = TiMe::Default()) const { return getTransform("fadeobj_transform", time); }
35527
35531 bool set_hhfactor(float val, double time = TiMe::Default()) { return setValue("hhfactor", val, time); }
35535 float get_hhfactor(double time = TiMe::Default()) const { return getFloat("hhfactor", time); }
35536
35540 bool set_material_id(const Color& color, double time = TiMe::Default()) { return setValue("material_id", color, time); }
35544 Color get_material_id(double time = TiMe::Default()) const { return getColor("material_id", time); }
35545
35549 bool set_volzdepth(int val, double time = TiMe::Default()) { return setValue("volzdepth", val, time); }
35553 int get_volzdepth(double time = TiMe::Default()) const { return getInt("volzdepth", time); }
35554
35558 bool set_volnorm(int val, double time = TiMe::Default()) { return setValue("volnorm", val, time); }
35562 int get_volnorm(double time = TiMe::Default()) const { return getInt("volnorm", time); }
35563
35567 bool set_volumetric_mode_geometry_RE(bool val, double time = TiMe::Default()) { return setValue("volumetric_mode_geometry_RE", val, time); }
35571 bool get_volumetric_mode_geometry_RE(double time = TiMe::Default()) const { return getBool("volumetric_mode_geometry_RE", time); }
35572
35576 bool set_earg(int val, double time = TiMe::Default()) { return setValue("earg", val, time); }
35580 int get_earg(double time = TiMe::Default()) const { return getInt("earg", time); }
35581
35585 bool set_fire_color_chan(const char* str, double time = TiMe::Default()) { return setValue("fire_color_chan", str, time); }
35589 bool set_fire_color_chan(const std::string& str, double time = TiMe::Default()) { return setValue("fire_color_chan", str, time); }
35593 std::string get_fire_color_chan(double time = TiMe::Default()) const { return getString("fire_color_chan", time); }
35594
35597 bool set_etex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("etex", texture, time); }
35600 bool set_etex(const AColor& texture, double time = TiMe::Default()) { return setValue("etex", texture, time); }
35603 Value get_etex(double time = TiMe::Default()) const { return getValue("etex", time); }
35604
35608 bool set_mod_e(bool val, double time = TiMe::Default()) { return setValue("mod_e", val, time); }
35612 bool get_mod_e(double time = TiMe::Default()) const { return getBool("mod_e", time); }
35613
35619 bool set_fire_opacity_mode(int val, double time = TiMe::Default()) { return setValue("fire_opacity_mode", val, time); }
35625 int get_fire_opacity_mode(double time = TiMe::Default()) const { return getInt("fire_opacity_mode", time); }
35626
35630 bool set_blackbody(float val, double time = TiMe::Default()) { return setValue("blackbody", val, time); }
35634 float get_blackbody(double time = TiMe::Default()) const { return getFloat("blackbody", time); }
35635
35639 bool set_mod_et(int val, double time = TiMe::Default()) { return setValue("mod_et", val, time); }
35643 int get_mod_et(double time = TiMe::Default()) const { return getInt("mod_et", time); }
35644
35647 bool set_ettex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ettex", texture, time); }
35650 bool set_ettex(const AColor& texture, double time = TiMe::Default()) { return setValue("ettex", texture, time); }
35653 Value get_ettex(double time = TiMe::Default()) const { return getValue("ettex", time); }
35654
35658 bool set_emult(float val, double time = TiMe::Default()) { return setValue("emult", val, time); }
35662 float get_emult(double time = TiMe::Default()) const { return getFloat("emult", time); }
35663
35667 bool set_etmult(float val, double time = TiMe::Default()) { return setValue("etmult", val, time); }
35671 float get_etmult(double time = TiMe::Default()) const { return getFloat("etmult", time); }
35672
35676 bool set_ecolor(const Color& color, double time = TiMe::Default()) { return setValue("ecolor", color, time); }
35680 Color get_ecolor(double time = TiMe::Default()) const { return getColor("ecolor", time); }
35681
35685 bool set_ecolor_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("ecolor_positions", floatList, time); }
35686 bool set_ecolor_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("ecolor_positions", std::move(floatList), time); }
35687 bool set_ecolor_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("ecolor_positions", floats, count, time); }
35688 template<size_t count> bool set_ecolor_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("ecolor_positions", floats, count, time); }
35692 FloatList get_ecolor_positions(double time = TiMe::Default()) const { return getFloatList("ecolor_positions", time); }
35693
35697 bool set_ecolor_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("ecolor_colors", colorList, time); }
35698 bool set_ecolor_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("ecolor_colors", std::move(colorList), time); }
35699 bool set_ecolor_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("ecolor_colors", colors, count, time); }
35700 template<size_t count> bool set_ecolor_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("ecolor_colors", colors, count, time); }
35704 ColorList get_ecolor_colors(double time = TiMe::Default()) const { return getColorList("ecolor_colors", time); }
35705
35709 bool set_ecolor_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("ecolor_interpolations", intList, time); }
35710 bool set_ecolor_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("ecolor_interpolations", std::move(intList), time); }
35711 bool set_ecolor_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ecolor_interpolations", ints, count, time); }
35712 template<size_t count> bool set_ecolor_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ecolor_interpolations", ints, count, time); }
35716 IntList get_ecolor_interpolations(double time = TiMe::Default()) const { return getIntList("ecolor_interpolations", time); }
35717
35720 bool set_ecolor_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("ecolor_remap", plugin, time); }
35723 PluginRef get_ecolor_remap(double time = TiMe::Default()) const { return getPlugin("ecolor_remap", time); }
35724
35728 bool set_elum_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("elum_positions", floatList, time); }
35729 bool set_elum_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("elum_positions", std::move(floatList), time); }
35730 bool set_elum_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("elum_positions", floats, count, time); }
35731 template<size_t count> bool set_elum_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("elum_positions", floats, count, time); }
35735 FloatList get_elum_positions(double time = TiMe::Default()) const { return getFloatList("elum_positions", time); }
35736
35740 bool set_elum_values(const FloatList& floatList, double time = TiMe::Default()) { return setValue("elum_values", floatList, time); }
35741 bool set_elum_values(FloatList&& floatList, double time = TiMe::Default()) { return setValue("elum_values", std::move(floatList), time); }
35742 bool set_elum_values(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("elum_values", floats, count, time); }
35743 template<size_t count> bool set_elum_values(const float (&floats)[count], double time = TiMe::Default()) { return setArray("elum_values", floats, count, time); }
35747 FloatList get_elum_values(double time = TiMe::Default()) const { return getFloatList("elum_values", time); }
35748
35752 bool set_elum_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("elum_interpolations", intList, time); }
35753 bool set_elum_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("elum_interpolations", std::move(intList), time); }
35754 bool set_elum_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("elum_interpolations", ints, count, time); }
35755 template<size_t count> bool set_elum_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("elum_interpolations", ints, count, time); }
35759 IntList get_elum_interpolations(double time = TiMe::Default()) const { return getIntList("elum_interpolations", time); }
35760
35763 bool set_elum_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("elum_remap", plugin, time); }
35766 PluginRef get_elum_remap(double time = TiMe::Default()) const { return getPlugin("elum_remap", time); }
35767
35771 bool set_ecolor_offset(float val, double time = TiMe::Default()) { return setValue("ecolor_offset", val, time); }
35775 float get_ecolor_offset(double time = TiMe::Default()) const { return getFloat("ecolor_offset", time); }
35776
35780 bool set_ecolor_scale(float val, double time = TiMe::Default()) { return setValue("ecolor_scale", val, time); }
35784 float get_ecolor_scale(double time = TiMe::Default()) const { return getFloat("ecolor_scale", time); }
35785
35789 bool set_al_enable(bool val, double time = TiMe::Default()) { return setValue("al_enable", val, time); }
35793 bool get_al_enable(double time = TiMe::Default()) const { return getBool("al_enable", time); }
35794
35798 bool set_lights(int val, double time = TiMe::Default()) { return setValue("lights", val, time); }
35802 int get_lights(double time = TiMe::Default()) const { return getInt("lights", time); }
35803
35807 bool set_al_placing(int val, double time = TiMe::Default()) { return setValue("al_placing", val, time); }
35811 int get_al_placing(double time = TiMe::Default()) const { return getInt("al_placing", time); }
35812
35816 bool set_al_sampling(int val, double time = TiMe::Default()) { return setValue("al_sampling", val, time); }
35820 int get_al_sampling(double time = TiMe::Default()) const { return getInt("al_sampling", time); }
35821
35825 bool set_lightsmultself(float val, double time = TiMe::Default()) { return setValue("lightsmultself", val, time); }
35829 float get_lightsmultself(double time = TiMe::Default()) const { return getFloat("lightsmultself", time); }
35830
35834 bool set_lightsmult(float val, double time = TiMe::Default()) { return setValue("lightsmult", val, time); }
35838 float get_lightsmult(double time = TiMe::Default()) const { return getFloat("lightsmult", time); }
35839
35843 bool set_selfshadow(int val, double time = TiMe::Default()) { return setValue("selfshadow", val, time); }
35847 int get_selfshadow(double time = TiMe::Default()) const { return getInt("selfshadow", time); }
35848
35852 bool set_gridreduct(float val, double time = TiMe::Default()) { return setValue("gridreduct", val, time); }
35856 float get_gridreduct(double time = TiMe::Default()) const { return getFloat("gridreduct", time); }
35857
35861 bool set_lightscut(float val, double time = TiMe::Default()) { return setValue("lightscut", val, time); }
35865 float get_lightscut(double time = TiMe::Default()) const { return getFloat("lightscut", time); }
35866
35870 bool set_al_decay(int val, double time = TiMe::Default()) { return setValue("al_decay", val, time); }
35874 int get_al_decay(double time = TiMe::Default()) const { return getInt("al_decay", time); }
35875
35879 bool set_al_subdivs(int val, double time = TiMe::Default()) { return setValue("al_subdivs", val, time); }
35883 int get_al_subdivs(double time = TiMe::Default()) const { return getInt("al_subdivs", time); }
35884
35888 bool set_al_csubdivs(int val, double time = TiMe::Default()) { return setValue("al_csubdivs", val, time); }
35892 int get_al_csubdivs(double time = TiMe::Default()) const { return getInt("al_csubdivs", time); }
35893
35897 bool set_al_cmult(float val, double time = TiMe::Default()) { return setValue("al_cmult", val, time); }
35901 float get_al_cmult(double time = TiMe::Default()) const { return getFloat("al_cmult", time); }
35902
35906 bool set_firelightsspec(bool val, double time = TiMe::Default()) { return setValue("firelightsspec", val, time); }
35910 bool get_firelightsspec(double time = TiMe::Default()) const { return getBool("firelightsspec", time); }
35911
35915 bool set_persistlights(bool val, double time = TiMe::Default()) { return setValue("persistlights", val, time); }
35919 bool get_persistlights(double time = TiMe::Default()) const { return getBool("persistlights", time); }
35920
35923 bool set_instancedlights(bool val, double time = TiMe::Default()) { return setValue("instancedlights", val, time); }
35926 bool get_instancedlights(double time = TiMe::Default()) const { return getBool("instancedlights", time); }
35927
35931 bool set_radmult(float val, double time = TiMe::Default()) { return setValue("radmult", val, time); }
35935 float get_radmult(double time = TiMe::Default()) const { return getFloat("radmult", time); }
35936
35940 bool set_self_illum_map_min_pow(float val, double time = TiMe::Default()) { return setValue("self_illum_map_min_pow", val, time); }
35944 float get_self_illum_map_min_pow(double time = TiMe::Default()) const { return getFloat("self_illum_map_min_pow", time); }
35945
35949 bool set_darg(int val, double time = TiMe::Default()) { return setValue("darg", val, time); }
35953 int get_darg(double time = TiMe::Default()) const { return getInt("darg", time); }
35954
35958 bool set_smoke_color_chan(const char* str, double time = TiMe::Default()) { return setValue("smoke_color_chan", str, time); }
35962 bool set_smoke_color_chan(const std::string& str, double time = TiMe::Default()) { return setValue("smoke_color_chan", str, time); }
35966 std::string get_smoke_color_chan(double time = TiMe::Default()) const { return getString("smoke_color_chan", time); }
35967
35970 bool set_dtex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dtex", texture, time); }
35973 bool set_dtex(const AColor& texture, double time = TiMe::Default()) { return setValue("dtex", texture, time); }
35976 Value get_dtex(double time = TiMe::Default()) const { return getValue("dtex", time); }
35977
35981 bool set_mod_d(bool val, double time = TiMe::Default()) { return setValue("mod_d", val, time); }
35985 bool get_mod_d(double time = TiMe::Default()) const { return getBool("mod_d", time); }
35986
35990 bool set_simple_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("simple_color", acolor, time); }
35994 AColor get_simple_color(double time = TiMe::Default()) const { return getAColor("simple_color", time); }
35995
35999 bool set_noscatter(int val, double time = TiMe::Default()) { return setValue("noscatter", val, time); }
36003 int get_noscatter(double time = TiMe::Default()) const { return getInt("noscatter", time); }
36004
36008 bool set_bounces(int val, double time = TiMe::Default()) { return setValue("bounces", val, time); }
36012 int get_bounces(double time = TiMe::Default()) const { return getInt("bounces", time); }
36013
36017 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
36021 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
36022
36026 bool set_anisotropic_scattering_optimization(int val, double time = TiMe::Default()) { return setValue("anisotropic_scattering_optimization", val, time); }
36030 int get_anisotropic_scattering_optimization(double time = TiMe::Default()) const { return getInt("anisotropic_scattering_optimization", time); }
36031
36035 bool set_lightcache(bool val, double time = TiMe::Default()) { return setValue("lightcache", val, time); }
36039 bool get_lightcache(double time = TiMe::Default()) const { return getBool("lightcache", time); }
36040
36044 bool set_lightcachesr(float val, double time = TiMe::Default()) { return setValue("lightcachesr", val, time); }
36048 float get_lightcachesr(double time = TiMe::Default()) const { return getFloat("lightcachesr", time); }
36049
36053 bool set_transfown(float val, double time = TiMe::Default()) { return setValue("transfown", val, time); }
36057 float get_transfown(double time = TiMe::Default()) const { return getFloat("transfown", time); }
36058
36062 bool set_transfext(float val, double time = TiMe::Default()) { return setValue("transfext", val, time); }
36066 float get_transfext(double time = TiMe::Default()) const { return getFloat("transfext", time); }
36067
36071 bool set_difmul(float val, double time = TiMe::Default()) { return setValue("difmul", val, time); }
36075 float get_difmul(double time = TiMe::Default()) const { return getFloat("difmul", time); }
36076
36080 bool set_shad_strength(float val, double time = TiMe::Default()) { return setValue("shad_strength", val, time); }
36084 float get_shad_strength(double time = TiMe::Default()) const { return getFloat("shad_strength", time); }
36085
36089 bool set_dcolor(const Color& color, double time = TiMe::Default()) { return setValue("dcolor", color, time); }
36093 Color get_dcolor(double time = TiMe::Default()) const { return getColor("dcolor", time); }
36094
36098 bool set_dcolor_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("dcolor_positions", floatList, time); }
36099 bool set_dcolor_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("dcolor_positions", std::move(floatList), time); }
36100 bool set_dcolor_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("dcolor_positions", floats, count, time); }
36101 template<size_t count> bool set_dcolor_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("dcolor_positions", floats, count, time); }
36105 FloatList get_dcolor_positions(double time = TiMe::Default()) const { return getFloatList("dcolor_positions", time); }
36106
36110 bool set_dcolor_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("dcolor_colors", colorList, time); }
36111 bool set_dcolor_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("dcolor_colors", std::move(colorList), time); }
36112 bool set_dcolor_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("dcolor_colors", colors, count, time); }
36113 template<size_t count> bool set_dcolor_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("dcolor_colors", colors, count, time); }
36117 ColorList get_dcolor_colors(double time = TiMe::Default()) const { return getColorList("dcolor_colors", time); }
36118
36122 bool set_dcolor_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("dcolor_interpolations", intList, time); }
36123 bool set_dcolor_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("dcolor_interpolations", std::move(intList), time); }
36124 bool set_dcolor_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("dcolor_interpolations", ints, count, time); }
36125 template<size_t count> bool set_dcolor_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("dcolor_interpolations", ints, count, time); }
36129 IntList get_dcolor_interpolations(double time = TiMe::Default()) const { return getIntList("dcolor_interpolations", time); }
36130
36133 bool set_dcolor_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("dcolor_remap", plugin, time); }
36136 PluginRef get_dcolor_remap(double time = TiMe::Default()) const { return getPlugin("dcolor_remap", time); }
36137
36141 bool set_dcolor_offset(float val, double time = TiMe::Default()) { return setValue("dcolor_offset", val, time); }
36145 float get_dcolor_offset(double time = TiMe::Default()) const { return getFloat("dcolor_offset", time); }
36146
36150 bool set_dcolor_scale(float val, double time = TiMe::Default()) { return setValue("dcolor_scale", val, time); }
36154 float get_dcolor_scale(double time = TiMe::Default()) const { return getFloat("dcolor_scale", time); }
36155
36159 bool set_targ(int val, double time = TiMe::Default()) { return setValue("targ", val, time); }
36163 int get_targ(double time = TiMe::Default()) const { return getInt("targ", time); }
36164
36168 bool set_smoke_opacity_chan(const char* str, double time = TiMe::Default()) { return setValue("smoke_opacity_chan", str, time); }
36172 bool set_smoke_opacity_chan(const std::string& str, double time = TiMe::Default()) { return setValue("smoke_opacity_chan", str, time); }
36176 std::string get_smoke_opacity_chan(double time = TiMe::Default()) const { return getString("smoke_opacity_chan", time); }
36177
36180 bool set_ttex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ttex", texture, time); }
36183 bool set_ttex(const AColor& texture, double time = TiMe::Default()) { return setValue("ttex", texture, time); }
36186 Value get_ttex(double time = TiMe::Default()) const { return getValue("ttex", time); }
36187
36191 bool set_mod_t(bool val, double time = TiMe::Default()) { return setValue("mod_t", val, time); }
36195 bool get_mod_t(double time = TiMe::Default()) const { return getBool("mod_t", time); }
36196
36200 bool set_transpmode(int val, double time = TiMe::Default()) { return setValue("transpmode", val, time); }
36204 int get_transpmode(double time = TiMe::Default()) const { return getInt("transpmode", time); }
36205
36209 bool set_smoketransp(float val, double time = TiMe::Default()) { return setValue("smoketransp", val, time); }
36213 float get_smoketransp(double time = TiMe::Default()) const { return getFloat("smoketransp", time); }
36214
36218 bool set_stoptransp(float val, double time = TiMe::Default()) { return setValue("stoptransp", val, time); }
36222 float get_stoptransp(double time = TiMe::Default()) const { return getFloat("stoptransp", time); }
36223
36227 bool set_skiptransp(float val, double time = TiMe::Default()) { return setValue("skiptransp", val, time); }
36231 float get_skiptransp(double time = TiMe::Default()) const { return getFloat("skiptransp", time); }
36232
36236 bool set_alphaunitscale(bool val, double time = TiMe::Default()) { return setValue("alphaunitscale", val, time); }
36240 bool get_alphaunitscale(double time = TiMe::Default()) const { return getBool("alphaunitscale", time); }
36241
36245 bool set_basedensityscale(float val, double time = TiMe::Default()) { return setValue("basedensityscale", val, time); }
36249 float get_basedensityscale(double time = TiMe::Default()) const { return getFloat("basedensityscale", time); }
36250
36254 bool set_optvolpass(bool val, double time = TiMe::Default()) { return setValue("optvolpass", val, time); }
36258 bool get_optvolpass(double time = TiMe::Default()) const { return getBool("optvolpass", time); }
36259
36263 bool set_absorption_arg(int val, double time = TiMe::Default()) { return setValue("absorption_arg", val, time); }
36267 int get_absorption_arg(double time = TiMe::Default()) const { return getInt("absorption_arg", time); }
36268
36272 bool set_absorption_color(const Color& color, double time = TiMe::Default()) { return setValue("absorption_color", color, time); }
36276 Color get_absorption_color(double time = TiMe::Default()) const { return getColor("absorption_color", time); }
36277
36280 bool set_absorption_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("absorption_tex", texture, time); }
36283 bool set_absorption_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("absorption_tex", texture, time); }
36286 Value get_absorption_tex(double time = TiMe::Default()) const { return getValue("absorption_tex", time); }
36287
36291 bool set_transp(float val, double time = TiMe::Default()) { return setValue("transp", val, time); }
36295 float get_transp(double time = TiMe::Default()) const { return getFloat("transp", time); }
36296
36300 bool set_transp_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("transp_positions", floatList, time); }
36301 bool set_transp_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("transp_positions", std::move(floatList), time); }
36302 bool set_transp_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("transp_positions", floats, count, time); }
36303 template<size_t count> bool set_transp_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("transp_positions", floats, count, time); }
36307 FloatList get_transp_positions(double time = TiMe::Default()) const { return getFloatList("transp_positions", time); }
36308
36312 bool set_transp_values(const FloatList& floatList, double time = TiMe::Default()) { return setValue("transp_values", floatList, time); }
36313 bool set_transp_values(FloatList&& floatList, double time = TiMe::Default()) { return setValue("transp_values", std::move(floatList), time); }
36314 bool set_transp_values(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("transp_values", floats, count, time); }
36315 template<size_t count> bool set_transp_values(const float (&floats)[count], double time = TiMe::Default()) { return setArray("transp_values", floats, count, time); }
36319 FloatList get_transp_values(double time = TiMe::Default()) const { return getFloatList("transp_values", time); }
36320
36324 bool set_transp_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("transp_interpolations", intList, time); }
36325 bool set_transp_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("transp_interpolations", std::move(intList), time); }
36326 bool set_transp_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("transp_interpolations", ints, count, time); }
36327 template<size_t count> bool set_transp_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("transp_interpolations", ints, count, time); }
36331 IntList get_transp_interpolations(double time = TiMe::Default()) const { return getIntList("transp_interpolations", time); }
36332
36335 bool set_transp_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("transp_remap", plugin, time); }
36338 PluginRef get_transp_remap(double time = TiMe::Default()) const { return getPlugin("transp_remap", time); }
36339
36343 bool set_transp_offset(float val, double time = TiMe::Default()) { return setValue("transp_offset", val, time); }
36347 float get_transp_offset(double time = TiMe::Default()) const { return getFloat("transp_offset", time); }
36348
36352 bool set_transp_scale(float val, double time = TiMe::Default()) { return setValue("transp_scale", val, time); }
36356 float get_transp_scale(double time = TiMe::Default()) const { return getFloat("transp_scale", time); }
36357
36361 bool set_tmult(float val, double time = TiMe::Default()) { return setValue("tmult", val, time); }
36365 float get_tmult(double time = TiMe::Default()) const { return getFloat("tmult", time); }
36366
36369 bool set_transp_power(float val, double time = TiMe::Default()) { return setValue("transp_power", val, time); }
36372 float get_transp_power(double time = TiMe::Default()) const { return getFloat("transp_power", time); }
36373
36377 bool set_shadow_opacity(float val, double time = TiMe::Default()) { return setValue("shadow_opacity", val, time); }
36381 float get_shadow_opacity(double time = TiMe::Default()) const { return getFloat("shadow_opacity", time); }
36382
36386 bool set_cell_aspect(const FloatList& floatList, double time = TiMe::Default()) { return setValue("cell_aspect", floatList, time); }
36387 bool set_cell_aspect(FloatList&& floatList, double time = TiMe::Default()) { return setValue("cell_aspect", std::move(floatList), time); }
36388 bool set_cell_aspect(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("cell_aspect", floats, count, time); }
36389 template<size_t count> bool set_cell_aspect(const float (&floats)[count], double time = TiMe::Default()) { return setArray("cell_aspect", floats, count, time); }
36393 FloatList get_cell_aspect(double time = TiMe::Default()) const { return getFloatList("cell_aspect", time); }
36394
36398 bool set_pmprimary(int val, double time = TiMe::Default()) { return setValue("pmprimary", val, time); }
36402 int get_pmprimary(double time = TiMe::Default()) const { return getInt("pmprimary", time); }
36403
36407 bool set_pmbounces(int val, double time = TiMe::Default()) { return setValue("pmbounces", val, time); }
36411 int get_pmbounces(double time = TiMe::Default()) const { return getInt("pmbounces", time); }
36412
36415 bool set_left_handed_coord(bool val, double time = TiMe::Default()) { return setValue("left_handed_coord", val, time); }
36418 bool get_left_handed_coord(double time = TiMe::Default()) const { return getBool("left_handed_coord", time); }
36419
36423 bool set_brdfscatter(float val, double time = TiMe::Default()) { return setValue("brdfscatter", val, time); }
36427 float get_brdfscatter(double time = TiMe::Default()) const { return getFloat("brdfscatter", time); }
36428
36432 bool set_brdfscatternogi(float val, double time = TiMe::Default()) { return setValue("brdfscatternogi", val, time); }
36436 float get_brdfscatternogi(double time = TiMe::Default()) const { return getFloat("brdfscatternogi", time); }
36437
36441 bool set_bias(float val, double time = TiMe::Default()) { return setValue("bias", val, time); }
36445 float get_bias(double time = TiMe::Default()) const { return getFloat("bias", time); }
36446
36450 bool set_usebias(int val, double time = TiMe::Default()) { return setValue("usebias", val, time); }
36454 int get_usebias(double time = TiMe::Default()) const { return getInt("usebias", time); }
36455
36459 bool set_wrapx(bool val, double time = TiMe::Default()) { return setValue("wrapx", val, time); }
36463 bool get_wrapx(double time = TiMe::Default()) const { return getBool("wrapx", time); }
36464
36468 bool set_wrapy(bool val, double time = TiMe::Default()) { return setValue("wrapy", val, time); }
36472 bool get_wrapy(double time = TiMe::Default()) const { return getBool("wrapy", time); }
36473
36477 bool set_wrapz(bool val, double time = TiMe::Default()) { return setValue("wrapz", val, time); }
36481 bool get_wrapz(double time = TiMe::Default()) const { return getBool("wrapz", time); }
36482
36486 bool set_useLegacyLightLinkingForVRayStd(bool val, double time = TiMe::Default()) { return setValue("useLegacyLightLinkingForVRayStd", val, time); }
36490 bool get_useLegacyLightLinkingForVRayStd(double time = TiMe::Default()) const { return getBool("useLegacyLightLinkingForVRayStd", time); }
36491
36494 bool set_lightlinks(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("lightlinks", pluginList, time); }
36495 bool set_lightlinks(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("lightlinks", plugins, count, time); }
36496 template<size_t count> bool set_lightlinks(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("lightlinks", plugins, count, time); }
36499 PluginList get_lightlinks(double time = TiMe::Default()) const { return getPluginList("lightlinks", time); }
36500
36503 bool set_shadowBreakings(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("shadowBreakings", pluginList, time); }
36504 bool set_shadowBreakings(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("shadowBreakings", plugins, count, time); }
36505 template<size_t count> bool set_shadowBreakings(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("shadowBreakings", plugins, count, time); }
36508 PluginList get_shadowBreakings(double time = TiMe::Default()) const { return getPluginList("shadowBreakings", time); }
36509
36513 bool set_velocities_from_uvw(bool val, double time = TiMe::Default()) { return setValue("velocities_from_uvw", val, time); }
36517 bool get_velocities_from_uvw(double time = TiMe::Default()) const { return getBool("velocities_from_uvw", time); }
36518
36522 bool set_coord_method(int val, double time = TiMe::Default()) { return setValue("coord_method", val, time); }
36526 int get_coord_method(double time = TiMe::Default()) const { return getInt("coord_method", time); }
36527
36531 bool set_gamma_mult(float val, double time = TiMe::Default()) { return setValue("gamma_mult", val, time); }
36535 float get_gamma_mult(double time = TiMe::Default()) const { return getFloat("gamma_mult", time); }
36536
36540 bool set_mbgrid(bool val, double time = TiMe::Default()) { return setValue("mbgrid", val, time); }
36544 bool get_mbgrid(double time = TiMe::Default()) const { return getBool("mbgrid", time); }
36545
36549 bool set_vol_moblur_method(int val, double time = TiMe::Default()) { return setValue("vol_moblur_method", val, time); }
36553 int get_vol_moblur_method(double time = TiMe::Default()) const { return getInt("vol_moblur_method", time); }
36554
36558 bool set_mbsmooth(int val, double time = TiMe::Default()) { return setValue("mbsmooth", val, time); }
36562 int get_mbsmooth(double time = TiMe::Default()) const { return getInt("mbsmooth", time); }
36563
36567 bool set_normalized_positions(int val, double time = TiMe::Default()) { return setValue("normalized_positions", val, time); }
36571 int get_normalized_positions(double time = TiMe::Default()) const { return getInt("normalized_positions", time); }
36572
36576 bool set_generate_gi(bool val, double time = TiMe::Default()) { return setValue("generate_gi", val, time); }
36580 bool get_generate_gi(double time = TiMe::Default()) const { return getBool("generate_gi", time); }
36581
36585 bool set_receive_gi(bool val, double time = TiMe::Default()) { return setValue("receive_gi", val, time); }
36589 bool get_receive_gi(double time = TiMe::Default()) const { return getBool("receive_gi", time); }
36590
36594 bool set_gen_gi_mult(float val, double time = TiMe::Default()) { return setValue("gen_gi_mult", val, time); }
36598 float get_gen_gi_mult(double time = TiMe::Default()) const { return getFloat("gen_gi_mult", time); }
36599
36603 bool set_rec_gi_mult(float val, double time = TiMe::Default()) { return setValue("rec_gi_mult", val, time); }
36607 float get_rec_gi_mult(double time = TiMe::Default()) const { return getFloat("rec_gi_mult", time); }
36608
36612 bool set_generate_caust(bool val, double time = TiMe::Default()) { return setValue("generate_caust", val, time); }
36616 bool get_generate_caust(double time = TiMe::Default()) const { return getBool("generate_caust", time); }
36617
36621 bool set_receive_caust(bool val, double time = TiMe::Default()) { return setValue("receive_caust", val, time); }
36625 bool get_receive_caust(double time = TiMe::Default()) const { return getBool("receive_caust", time); }
36626
36630 bool set_caust_mult(float val, double time = TiMe::Default()) { return setValue("caust_mult", val, time); }
36634 float get_caust_mult(double time = TiMe::Default()) const { return getFloat("caust_mult", time); }
36635
36639 bool set_camera_visibility(bool val, double time = TiMe::Default()) { return setValue("camera_visibility", val, time); }
36643 bool get_camera_visibility(double time = TiMe::Default()) const { return getBool("camera_visibility", time); }
36644
36648 bool set_reflections_visibility(bool val, double time = TiMe::Default()) { return setValue("reflections_visibility", val, time); }
36652 bool get_reflections_visibility(double time = TiMe::Default()) const { return getBool("reflections_visibility", time); }
36653
36657 bool set_refractions_visibility(bool val, double time = TiMe::Default()) { return setValue("refractions_visibility", val, time); }
36661 bool get_refractions_visibility(double time = TiMe::Default()) const { return getBool("refractions_visibility", time); }
36662
36666 bool set_gi_visibility(bool val, double time = TiMe::Default()) { return setValue("gi_visibility", val, time); }
36670 bool get_gi_visibility(double time = TiMe::Default()) const { return getBool("gi_visibility", time); }
36671
36675 bool set_shadows_visibility(bool val, double time = TiMe::Default()) { return setValue("shadows_visibility", val, time); }
36679 bool get_shadows_visibility(double time = TiMe::Default()) const { return getBool("shadows_visibility", time); }
36680
36683 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
36684 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
36685 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
36688 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
36689
36692 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
36693 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
36694 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
36697 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
36698
36701 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
36702 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
36703 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
36706 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
36707
36710 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
36711 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
36712 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
36715 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
36716
36719 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
36722 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
36723
36726 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
36729 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
36730
36733 bool set_user_attributes(const char* str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
36736 bool set_user_attributes(const std::string& str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
36739 std::string get_user_attributes(double time = TiMe::Default()) const { return getString("user_attributes", time); }
36740
36743 bool set_user_attributes_bin(const IntList& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", intList, time); }
36744 bool set_user_attributes_bin(IntList&& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", std::move(intList), time); }
36745 bool set_user_attributes_bin(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
36746 template<size_t count> bool set_user_attributes_bin(const int (&ints)[count], double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
36749 IntList get_user_attributes_bin(double time = TiMe::Default()) const { return getIntList("user_attributes_bin", time); }
36750};
36751
36753class PhxShaderSimGeom : public Plugin {
36754public:
36756 static constexpr const PluginTypeId getTypeId() { return 0x4AEA9A6A3; }
36758 static constexpr const char* getType() { return "PhxShaderSimGeom"; }
36759
36760 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
36761
36762 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
36763
36766 bool set_phoenix_sim(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("phoenix_sim", plugin, time); }
36769 PluginRef get_phoenix_sim(double time = TiMe::Default()) const { return getPlugin("phoenix_sim", time); }
36770
36774 bool set_gpu_di_mode(int val, double time = TiMe::Default()) { return setValue("gpu_di_mode", val, time); }
36778 int get_gpu_di_mode(double time = TiMe::Default()) const { return getInt("gpu_di_mode", time); }
36779
36783 bool set_gpu_gi_mode(int val, double time = TiMe::Default()) { return setValue("gpu_gi_mode", val, time); }
36787 int get_gpu_gi_mode(double time = TiMe::Default()) const { return getInt("gpu_gi_mode", time); }
36788
36792 bool set_gpu_samples_count(int val, double time = TiMe::Default()) { return setValue("gpu_samples_count", val, time); }
36796 int get_gpu_samples_count(double time = TiMe::Default()) const { return getInt("gpu_samples_count", time); }
36797};
36798
36800class PhxShaderSimMesh : public Plugin {
36801public:
36803 static constexpr const PluginTypeId getTypeId() { return 0x4AFDD8AF3; }
36805 static constexpr const char* getType() { return "PhxShaderSimMesh"; }
36806
36807 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
36808
36811 bool set_phoenix_sim(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("phoenix_sim", plugin, time); }
36814 PluginRef get_phoenix_sim(double time = TiMe::Default()) const { return getPlugin("phoenix_sim", time); }
36815
36818 bool set_static_mesh(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("static_mesh", plugin, time); }
36821 PluginRef get_static_mesh(double time = TiMe::Default()) const { return getPlugin("static_mesh", time); }
36822};
36823
36825class PhxShaderSimVol : public Plugin {
36826public:
36828 static constexpr const PluginTypeId getTypeId() { return 0x4AEA9A6C1; }
36830 static constexpr const char* getType() { return "PhxShaderSimVol"; }
36831
36832 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
36833
36834 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
36835
36836 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
36837
36838 operator VolumetricPluginCategory() { return *static_cast<VolumetricPluginCategory*>(static_cast<Plugin*>(this)); }
36839
36842 bool set_force_prob_samples(int val, double time = TiMe::Default()) { return setValue("force_prob_samples", val, time); }
36845 int get_force_prob_samples(double time = TiMe::Default()) const { return getInt("force_prob_samples", time); }
36846
36849 bool set_force_prob_samples_gi(int val, double time = TiMe::Default()) { return setValue("force_prob_samples_gi", val, time); }
36852 int get_force_prob_samples_gi(double time = TiMe::Default()) const { return getInt("force_prob_samples_gi", time); }
36853};
36854
36856class PhxShaderTex : public Plugin {
36857public:
36859 static constexpr const PluginTypeId getTypeId() { return 0x4AEA9A6AD; }
36861 static constexpr const char* getType() { return "PhxShaderTex"; }
36862
36863 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
36864
36868 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
36872 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
36873
36877 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
36881 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
36882
36885 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
36888 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
36889
36893 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
36897 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
36898
36901 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
36904 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
36907 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
36908
36911 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
36914 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
36917 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
36918
36921 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
36924 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
36927 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
36928
36931 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
36934 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
36937 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
36938
36942 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
36946 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
36950 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
36951
36953 PluginRef out_color() const { return PluginRef(*this, "color"); }
36954
36956 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
36957
36959 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
36960
36962 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
36963
36966 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
36969 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
36970
36974 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
36978 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
36979
36983 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
36987 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
36988
36992 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
36996 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
36997
37001 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
37005 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
37006
37010 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
37014 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
37015
37019 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
37023 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
37024
37028 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
37032 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
37033
37037 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
37041 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
37042
37046 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
37050 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
37051
37055 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
37059 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
37060
37064 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
37068 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
37069
37073 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
37077 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
37078
37082 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
37086 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
37087
37091 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
37095 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
37096
37098 bool set_phoenix_sim(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("phoenix_sim", plugin, time); }
37100 PluginRef get_phoenix_sim(double time = TiMe::Default()) const { return getPlugin("phoenix_sim", time); }
37101
37104 bool set_channel(int val, double time = TiMe::Default()) { return setValue("channel", val, time); }
37107 int get_channel(double time = TiMe::Default()) const { return getInt("channel", time); }
37108
37111 bool set_tiling(int val, double time = TiMe::Default()) { return setValue("tiling", val, time); }
37114 int get_tiling(double time = TiMe::Default()) const { return getInt("tiling", time); }
37115
37118 bool set_sampler_type(int val, double time = TiMe::Default()) { return setValue("sampler_type", val, time); }
37121 int get_sampler_type(double time = TiMe::Default()) const { return getInt("sampler_type", time); }
37122
37125 bool set_skip_fine_displ(bool val, double time = TiMe::Default()) { return setValue("skip_fine_displ", val, time); }
37128 bool get_skip_fine_displ(double time = TiMe::Default()) const { return getBool("skip_fine_displ", time); }
37129
37132 bool set_alpha_intensity(bool val, double time = TiMe::Default()) { return setValue("alpha_intensity", val, time); }
37135 bool get_alpha_intensity(double time = TiMe::Default()) const { return getBool("alpha_intensity", time); }
37136
37139 bool set_output_scale(float val, double time = TiMe::Default()) { return setValue("output_scale", val, time); }
37142 float get_output_scale(double time = TiMe::Default()) const { return getFloat("output_scale", time); }
37143
37146 bool set_output_offset(float val, double time = TiMe::Default()) { return setValue("output_offset", val, time); }
37149 float get_output_offset(double time = TiMe::Default()) const { return getFloat("output_offset", time); }
37150
37153 bool set_up_vector(int val, double time = TiMe::Default()) { return setValue("up_vector", val, time); }
37156 int get_up_vector(double time = TiMe::Default()) const { return getInt("up_vector", time); }
37157
37160 bool set_texture2d(bool val, double time = TiMe::Default()) { return setValue("texture2d", val, time); }
37163 bool get_texture2d(double time = TiMe::Default()) const { return getBool("texture2d", time); }
37164
37167 bool set_auto_map(bool val, double time = TiMe::Default()) { return setValue("auto_map", val, time); }
37170 bool get_auto_map(double time = TiMe::Default()) const { return getBool("auto_map", time); }
37171};
37172
37175public:
37177 static constexpr const PluginTypeId getTypeId() { return 0x4AEB76635; }
37179 static constexpr const char* getType() { return "PhxShaderTexAlpha"; }
37180
37181 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
37182
37184 bool set_ttex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("ttex", texturefloat, time); }
37186 bool set_ttex(float texturefloat, double time = TiMe::Default()) { return setValue("ttex", texturefloat, time); }
37188 Value get_ttex(double time = TiMe::Default()) const { return getValue("ttex", time); }
37189
37192 bool set_transparency(const AColor& acolor, double time = TiMe::Default()) { return setValue("transparency", acolor, time); }
37195 AColor get_transparency(double time = TiMe::Default()) const { return getAColor("transparency", time); }
37196
37198 PluginRef out_out_color() const { return PluginRef(*this, "out_color"); }
37199};
37200
37203public:
37205 static constexpr const PluginTypeId getTypeId() { return 0x4B53C8715; }
37207 static constexpr const char* getType() { return "PhxShaderVoxelShader"; }
37208
37209 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
37210
37211 operator GeometrySourcePluginCategory() { return *static_cast<GeometrySourcePluginCategory*>(static_cast<Plugin*>(this)); }
37212
37213 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
37214
37218 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
37222 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
37223
37226 bool set_cache(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("cache", plugin, time); }
37229 PluginRef get_cache(double time = TiMe::Default()) const { return getPlugin("cache", time); }
37230
37234 bool set_contentTime(int val, double time = TiMe::Default()) { return setValue("contentTime", val, time); }
37238 int get_contentTime(double time = TiMe::Default()) const { return getInt("contentTime", time); }
37239
37243 bool set_frame_duration(float val, double time = TiMe::Default()) { return setValue("frame_duration", val, time); }
37247 float get_frame_duration(double time = TiMe::Default()) const { return getFloat("frame_duration", time); }
37248
37252 bool set_play_speed(float val, double time = TiMe::Default()) { return setValue("play_speed", val, time); }
37256 float get_play_speed(double time = TiMe::Default()) const { return getFloat("play_speed", time); }
37257
37261 bool set_wind_from_movement(bool val, double time = TiMe::Default()) { return setValue("wind_from_movement", val, time); }
37265 bool get_wind_from_movement(double time = TiMe::Default()) const { return getBool("wind_from_movement", time); }
37266
37270 bool set_unit_scale(float val, double time = TiMe::Default()) { return setValue("unit_scale", val, time); }
37274 float get_unit_scale(double time = TiMe::Default()) const { return getFloat("unit_scale", time); }
37275
37279 bool set_node_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("node_transform", transform, time); }
37283 Transform get_node_transform(double time = TiMe::Default()) const { return getTransform("node_transform", time); }
37284
37288 bool set_use_node_transform_for_instancing(bool val, double time = TiMe::Default()) { return setValue("use_node_transform_for_instancing", val, time); }
37292 bool get_use_node_transform_for_instancing(double time = TiMe::Default()) const { return getBool("use_node_transform_for_instancing", time); }
37293
37297 bool set_renderAsVolumetric(bool val, double time = TiMe::Default()) { return setValue("renderAsVolumetric", val, time); }
37301 bool get_renderAsVolumetric(double time = TiMe::Default()) const { return getBool("renderAsVolumetric", time); }
37302
37306 bool set_render(bool val, double time = TiMe::Default()) { return setValue("render", val, time); }
37310 bool get_render(double time = TiMe::Default()) const { return getBool("render", time); }
37311
37315 bool set_rendMode(int val, double time = TiMe::Default()) { return setValue("rendMode", val, time); }
37319 int get_rendMode(double time = TiMe::Default()) const { return getInt("rendMode", time); }
37320
37324 bool set_rendstep(int val, double time = TiMe::Default()) { return setValue("rendstep", val, time); }
37328 int get_rendstep(double time = TiMe::Default()) const { return getInt("rendstep", time); }
37329
37333 bool set_rendshadstep(int val, double time = TiMe::Default()) { return setValue("rendshadstep", val, time); }
37337 int get_rendshadstep(double time = TiMe::Default()) const { return getInt("rendshadstep", time); }
37338
37342 bool set_jitter(bool val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
37346 bool get_jitter(double time = TiMe::Default()) const { return getBool("jitter", time); }
37347
37351 bool set_borderFade(float val, double time = TiMe::Default()) { return setValue("borderFade", val, time); }
37355 float get_borderFade(double time = TiMe::Default()) const { return getFloat("borderFade", time); }
37356
37360 bool set_sampler(int val, double time = TiMe::Default()) { return setValue("sampler", val, time); }
37364 int get_sampler(double time = TiMe::Default()) const { return getInt("sampler", time); }
37365
37369 bool set_velocity_mult(float val, double time = TiMe::Default()) { return setValue("velocity_mult", val, time); }
37373 float get_velocity_mult(double time = TiMe::Default()) const { return getFloat("velocity_mult", time); }
37374
37378 bool set_varg(int val, double time = TiMe::Default()) { return setValue("varg", val, time); }
37382 int get_varg(double time = TiMe::Default()) const { return getInt("varg", time); }
37383
37386 bool set_vtex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("vtex", texture, time); }
37389 bool set_vtex(const AColor& texture, double time = TiMe::Default()) { return setValue("vtex", texture, time); }
37392 Value get_vtex(double time = TiMe::Default()) const { return getValue("vtex", time); }
37393
37397 bool set_mod_v(int val, double time = TiMe::Default()) { return setValue("mod_v", val, time); }
37401 int get_mod_v(double time = TiMe::Default()) const { return getInt("mod_v", time); }
37402
37406 bool set_velocities(const ColorList& colorList, double time = TiMe::Default()) { return setValue("velocities", colorList, time); }
37407 bool set_velocities(ColorList&& colorList, double time = TiMe::Default()) { return setValue("velocities", std::move(colorList), time); }
37408 bool set_velocities(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("velocities", colors, count, time); }
37409 template<size_t count> bool set_velocities(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("velocities", colors, count, time); }
37413 ColorList get_velocities(double time = TiMe::Default()) const { return getColorList("velocities", time); }
37414
37418 bool set_sarg(int val, double time = TiMe::Default()) { return setValue("sarg", val, time); }
37422 int get_sarg(double time = TiMe::Default()) const { return getInt("sarg", time); }
37423
37427 bool set_surface_chan(const char* str, double time = TiMe::Default()) { return setValue("surface_chan", str, time); }
37431 bool set_surface_chan(const std::string& str, double time = TiMe::Default()) { return setValue("surface_chan", str, time); }
37435 std::string get_surface_chan(double time = TiMe::Default()) const { return getString("surface_chan", time); }
37436
37439 bool set_stex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("stex", texture, time); }
37442 bool set_stex(const AColor& texture, double time = TiMe::Default()) { return setValue("stex", texture, time); }
37445 Value get_stex(double time = TiMe::Default()) const { return getValue("stex", time); }
37446
37450 bool set_surflevel(float val, double time = TiMe::Default()) { return setValue("surflevel", val, time); }
37454 float get_surflevel(double time = TiMe::Default()) const { return getFloat("surflevel", time); }
37455
37459 bool set_solidbelow(bool val, double time = TiMe::Default()) { return setValue("solidbelow", val, time); }
37463 bool get_solidbelow(double time = TiMe::Default()) const { return getBool("solidbelow", time); }
37464
37468 bool set_usegizmo(int val, double time = TiMe::Default()) { return setValue("usegizmo", val, time); }
37472 int get_usegizmo(double time = TiMe::Default()) const { return getInt("usegizmo", time); }
37473
37476 bool set_gizmo(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("gizmo", plugin, time); }
37479 PluginRef get_gizmo(double time = TiMe::Default()) const { return getPlugin("gizmo", time); }
37480
37484 bool set_gizmo_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("gizmo_transform", transform, time); }
37488 Transform get_gizmo_transform(double time = TiMe::Default()) const { return getTransform("gizmo_transform", time); }
37489
37493 bool set_invgizmo(int val, double time = TiMe::Default()) { return setValue("invgizmo", val, time); }
37497 int get_invgizmo(double time = TiMe::Default()) const { return getInt("invgizmo", time); }
37498
37502 bool set_oceanlevel(float val, double time = TiMe::Default()) { return setValue("oceanlevel", val, time); }
37506 float get_oceanlevel(double time = TiMe::Default()) const { return getFloat("oceanlevel", time); }
37507
37511 bool set_oceantransitionzone(float val, double time = TiMe::Default()) { return setValue("oceantransitionzone", val, time); }
37515 float get_oceantransitionzone(double time = TiMe::Default()) const { return getFloat("oceantransitionzone", time); }
37516
37520 bool set_meshsubdiv(float val, double time = TiMe::Default()) { return setValue("meshsubdiv", val, time); }
37524 float get_meshsubdiv(double time = TiMe::Default()) const { return getFloat("meshsubdiv", time); }
37525
37529 bool set_oceanhorizrough(float val, double time = TiMe::Default()) { return setValue("oceanhorizrough", val, time); }
37533 float get_oceanhorizrough(double time = TiMe::Default()) const { return getFloat("oceanhorizrough", time); }
37534
37538 bool set_oceanextramargin(float val, double time = TiMe::Default()) { return setValue("oceanextramargin", val, time); }
37542 float get_oceanextramargin(double time = TiMe::Default()) const { return getFloat("oceanextramargin", time); }
37543
37547 bool set_pureocean(bool val, double time = TiMe::Default()) { return setValue("pureocean", val, time); }
37551 bool get_pureocean(double time = TiMe::Default()) const { return getBool("pureocean", time); }
37552
37556 bool set_uwglasses(bool val, double time = TiMe::Default()) { return setValue("uwglasses", val, time); }
37560 bool get_uwglasses(double time = TiMe::Default()) const { return getBool("uwglasses", time); }
37561
37565 bool set_mbself(bool val, double time = TiMe::Default()) { return setValue("mbself", val, time); }
37569 bool get_mbself(double time = TiMe::Default()) const { return getBool("mbself", time); }
37570
37574 bool set_smoothmesh(int val, double time = TiMe::Default()) { return setValue("smoothmesh", val, time); }
37578 int get_smoothmesh(double time = TiMe::Default()) const { return getInt("smoothmesh", time); }
37579
37583 bool set_smooth_normals(int val, double time = TiMe::Default()) { return setValue("smooth_normals", val, time); }
37587 int get_smooth_normals(double time = TiMe::Default()) const { return getInt("smooth_normals", time); }
37588
37592 bool set_useprt(bool val, double time = TiMe::Default()) { return setValue("useprt", val, time); }
37596 bool get_useprt(double time = TiMe::Default()) const { return getBool("useprt", time); }
37597
37601 bool set_prtsz(float val, double time = TiMe::Default()) { return setValue("prtsz", val, time); }
37605 float get_prtsz(double time = TiMe::Default()) const { return getFloat("prtsz", time); }
37606
37610 bool set_cachestretchzone(float val, double time = TiMe::Default()) { return setValue("cachestretchzone", val, time); }
37614 float get_cachestretchzone(double time = TiMe::Default()) const { return getFloat("cachestretchzone", time); }
37615
37619 bool set_displacement(bool val, double time = TiMe::Default()) { return setValue("displacement", val, time); }
37623 bool get_displacement(double time = TiMe::Default()) const { return getBool("displacement", time); }
37624
37628 bool set_displmul(float val, double time = TiMe::Default()) { return setValue("displmul", val, time); }
37632 float get_displmul(double time = TiMe::Default()) const { return getFloat("displmul", time); }
37633
37636 bool set_displ0(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displ0", texture, time); }
37639 bool set_displ0(const AColor& texture, double time = TiMe::Default()) { return setValue("displ0", texture, time); }
37642 Value get_displ0(double time = TiMe::Default()) const { return getValue("displ0", time); }
37643
37646 bool set_displ1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displ1", texture, time); }
37649 bool set_displ1(const AColor& texture, double time = TiMe::Default()) { return setValue("displ1", texture, time); }
37652 Value get_displ1(double time = TiMe::Default()) const { return getValue("displ1", time); }
37653
37656 bool set_displ2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("displ2", texture, time); }
37659 bool set_displ2(const AColor& texture, double time = TiMe::Default()) { return setValue("displ2", texture, time); }
37662 Value get_displ2(double time = TiMe::Default()) const { return getValue("displ2", time); }
37663
37667 bool set_displ2d(int val, double time = TiMe::Default()) { return setValue("displ2d", val, time); }
37671 int get_displ2d(double time = TiMe::Default()) const { return getInt("displ2d", time); }
37672
37676 bool set_fadebylevel(bool val, double time = TiMe::Default()) { return setValue("fadebylevel", val, time); }
37680 bool get_fadebylevel(double time = TiMe::Default()) const { return getBool("fadebylevel", time); }
37681
37685 bool set_displfade(float val, double time = TiMe::Default()) { return setValue("displfade", val, time); }
37689 float get_displfade(double time = TiMe::Default()) const { return getFloat("displfade", time); }
37690
37694 bool set_fadebyvel(bool val, double time = TiMe::Default()) { return setValue("fadebyvel", val, time); }
37698 bool get_fadebyvel(double time = TiMe::Default()) const { return getBool("fadebyvel", time); }
37699
37703 bool set_displvelfade(float val, double time = TiMe::Default()) { return setValue("displvelfade", val, time); }
37707 float get_displvelfade(double time = TiMe::Default()) const { return getFloat("displvelfade", time); }
37708
37712 bool set_usefadeobj(int val, double time = TiMe::Default()) { return setValue("usefadeobj", val, time); }
37716 int get_usefadeobj(double time = TiMe::Default()) const { return getInt("usefadeobj", time); }
37717
37721 bool set_displgeomfade(float val, double time = TiMe::Default()) { return setValue("displgeomfade", val, time); }
37725 float get_displgeomfade(double time = TiMe::Default()) const { return getFloat("displgeomfade", time); }
37726
37729 bool set_fadeobj(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("fadeobj", plugin, time); }
37732 PluginRef get_fadeobj(double time = TiMe::Default()) const { return getPlugin("fadeobj", time); }
37733
37737 bool set_fadeobj_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("fadeobj_transform", transform, time); }
37741 Transform get_fadeobj_transform(double time = TiMe::Default()) const { return getTransform("fadeobj_transform", time); }
37742
37746 bool set_hhfactor(float val, double time = TiMe::Default()) { return setValue("hhfactor", val, time); }
37750 float get_hhfactor(double time = TiMe::Default()) const { return getFloat("hhfactor", time); }
37751
37755 bool set_material_id(const Color& color, double time = TiMe::Default()) { return setValue("material_id", color, time); }
37759 Color get_material_id(double time = TiMe::Default()) const { return getColor("material_id", time); }
37760
37764 bool set_volzdepth(int val, double time = TiMe::Default()) { return setValue("volzdepth", val, time); }
37768 int get_volzdepth(double time = TiMe::Default()) const { return getInt("volzdepth", time); }
37769
37773 bool set_volnorm(int val, double time = TiMe::Default()) { return setValue("volnorm", val, time); }
37777 int get_volnorm(double time = TiMe::Default()) const { return getInt("volnorm", time); }
37778
37782 bool set_volumetric_mode_geometry_RE(bool val, double time = TiMe::Default()) { return setValue("volumetric_mode_geometry_RE", val, time); }
37786 bool get_volumetric_mode_geometry_RE(double time = TiMe::Default()) const { return getBool("volumetric_mode_geometry_RE", time); }
37787
37791 bool set_earg(int val, double time = TiMe::Default()) { return setValue("earg", val, time); }
37795 int get_earg(double time = TiMe::Default()) const { return getInt("earg", time); }
37796
37800 bool set_fire_color_chan(const char* str, double time = TiMe::Default()) { return setValue("fire_color_chan", str, time); }
37804 bool set_fire_color_chan(const std::string& str, double time = TiMe::Default()) { return setValue("fire_color_chan", str, time); }
37808 std::string get_fire_color_chan(double time = TiMe::Default()) const { return getString("fire_color_chan", time); }
37809
37812 bool set_etex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("etex", texture, time); }
37815 bool set_etex(const AColor& texture, double time = TiMe::Default()) { return setValue("etex", texture, time); }
37818 Value get_etex(double time = TiMe::Default()) const { return getValue("etex", time); }
37819
37823 bool set_mod_e(bool val, double time = TiMe::Default()) { return setValue("mod_e", val, time); }
37827 bool get_mod_e(double time = TiMe::Default()) const { return getBool("mod_e", time); }
37828
37834 bool set_fire_opacity_mode(int val, double time = TiMe::Default()) { return setValue("fire_opacity_mode", val, time); }
37840 int get_fire_opacity_mode(double time = TiMe::Default()) const { return getInt("fire_opacity_mode", time); }
37841
37845 bool set_blackbody(float val, double time = TiMe::Default()) { return setValue("blackbody", val, time); }
37849 float get_blackbody(double time = TiMe::Default()) const { return getFloat("blackbody", time); }
37850
37854 bool set_mod_et(int val, double time = TiMe::Default()) { return setValue("mod_et", val, time); }
37858 int get_mod_et(double time = TiMe::Default()) const { return getInt("mod_et", time); }
37859
37862 bool set_ettex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ettex", texture, time); }
37865 bool set_ettex(const AColor& texture, double time = TiMe::Default()) { return setValue("ettex", texture, time); }
37868 Value get_ettex(double time = TiMe::Default()) const { return getValue("ettex", time); }
37869
37873 bool set_emult(float val, double time = TiMe::Default()) { return setValue("emult", val, time); }
37877 float get_emult(double time = TiMe::Default()) const { return getFloat("emult", time); }
37878
37882 bool set_etmult(float val, double time = TiMe::Default()) { return setValue("etmult", val, time); }
37886 float get_etmult(double time = TiMe::Default()) const { return getFloat("etmult", time); }
37887
37891 bool set_ecolor(const Color& color, double time = TiMe::Default()) { return setValue("ecolor", color, time); }
37895 Color get_ecolor(double time = TiMe::Default()) const { return getColor("ecolor", time); }
37896
37900 bool set_ecolor_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("ecolor_positions", floatList, time); }
37901 bool set_ecolor_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("ecolor_positions", std::move(floatList), time); }
37902 bool set_ecolor_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("ecolor_positions", floats, count, time); }
37903 template<size_t count> bool set_ecolor_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("ecolor_positions", floats, count, time); }
37907 FloatList get_ecolor_positions(double time = TiMe::Default()) const { return getFloatList("ecolor_positions", time); }
37908
37912 bool set_ecolor_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("ecolor_colors", colorList, time); }
37913 bool set_ecolor_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("ecolor_colors", std::move(colorList), time); }
37914 bool set_ecolor_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("ecolor_colors", colors, count, time); }
37915 template<size_t count> bool set_ecolor_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("ecolor_colors", colors, count, time); }
37919 ColorList get_ecolor_colors(double time = TiMe::Default()) const { return getColorList("ecolor_colors", time); }
37920
37924 bool set_ecolor_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("ecolor_interpolations", intList, time); }
37925 bool set_ecolor_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("ecolor_interpolations", std::move(intList), time); }
37926 bool set_ecolor_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ecolor_interpolations", ints, count, time); }
37927 template<size_t count> bool set_ecolor_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ecolor_interpolations", ints, count, time); }
37931 IntList get_ecolor_interpolations(double time = TiMe::Default()) const { return getIntList("ecolor_interpolations", time); }
37932
37935 bool set_ecolor_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("ecolor_remap", plugin, time); }
37938 PluginRef get_ecolor_remap(double time = TiMe::Default()) const { return getPlugin("ecolor_remap", time); }
37939
37943 bool set_elum_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("elum_positions", floatList, time); }
37944 bool set_elum_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("elum_positions", std::move(floatList), time); }
37945 bool set_elum_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("elum_positions", floats, count, time); }
37946 template<size_t count> bool set_elum_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("elum_positions", floats, count, time); }
37950 FloatList get_elum_positions(double time = TiMe::Default()) const { return getFloatList("elum_positions", time); }
37951
37955 bool set_elum_values(const FloatList& floatList, double time = TiMe::Default()) { return setValue("elum_values", floatList, time); }
37956 bool set_elum_values(FloatList&& floatList, double time = TiMe::Default()) { return setValue("elum_values", std::move(floatList), time); }
37957 bool set_elum_values(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("elum_values", floats, count, time); }
37958 template<size_t count> bool set_elum_values(const float (&floats)[count], double time = TiMe::Default()) { return setArray("elum_values", floats, count, time); }
37962 FloatList get_elum_values(double time = TiMe::Default()) const { return getFloatList("elum_values", time); }
37963
37967 bool set_elum_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("elum_interpolations", intList, time); }
37968 bool set_elum_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("elum_interpolations", std::move(intList), time); }
37969 bool set_elum_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("elum_interpolations", ints, count, time); }
37970 template<size_t count> bool set_elum_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("elum_interpolations", ints, count, time); }
37974 IntList get_elum_interpolations(double time = TiMe::Default()) const { return getIntList("elum_interpolations", time); }
37975
37978 bool set_elum_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("elum_remap", plugin, time); }
37981 PluginRef get_elum_remap(double time = TiMe::Default()) const { return getPlugin("elum_remap", time); }
37982
37986 bool set_ecolor_offset(float val, double time = TiMe::Default()) { return setValue("ecolor_offset", val, time); }
37990 float get_ecolor_offset(double time = TiMe::Default()) const { return getFloat("ecolor_offset", time); }
37991
37995 bool set_ecolor_scale(float val, double time = TiMe::Default()) { return setValue("ecolor_scale", val, time); }
37999 float get_ecolor_scale(double time = TiMe::Default()) const { return getFloat("ecolor_scale", time); }
38000
38004 bool set_al_enable(bool val, double time = TiMe::Default()) { return setValue("al_enable", val, time); }
38008 bool get_al_enable(double time = TiMe::Default()) const { return getBool("al_enable", time); }
38009
38013 bool set_lights(int val, double time = TiMe::Default()) { return setValue("lights", val, time); }
38017 int get_lights(double time = TiMe::Default()) const { return getInt("lights", time); }
38018
38022 bool set_al_placing(int val, double time = TiMe::Default()) { return setValue("al_placing", val, time); }
38026 int get_al_placing(double time = TiMe::Default()) const { return getInt("al_placing", time); }
38027
38031 bool set_al_sampling(int val, double time = TiMe::Default()) { return setValue("al_sampling", val, time); }
38035 int get_al_sampling(double time = TiMe::Default()) const { return getInt("al_sampling", time); }
38036
38040 bool set_lightsmultself(float val, double time = TiMe::Default()) { return setValue("lightsmultself", val, time); }
38044 float get_lightsmultself(double time = TiMe::Default()) const { return getFloat("lightsmultself", time); }
38045
38049 bool set_lightsmult(float val, double time = TiMe::Default()) { return setValue("lightsmult", val, time); }
38053 float get_lightsmult(double time = TiMe::Default()) const { return getFloat("lightsmult", time); }
38054
38058 bool set_selfshadow(int val, double time = TiMe::Default()) { return setValue("selfshadow", val, time); }
38062 int get_selfshadow(double time = TiMe::Default()) const { return getInt("selfshadow", time); }
38063
38067 bool set_gridreduct(float val, double time = TiMe::Default()) { return setValue("gridreduct", val, time); }
38071 float get_gridreduct(double time = TiMe::Default()) const { return getFloat("gridreduct", time); }
38072
38076 bool set_lightscut(float val, double time = TiMe::Default()) { return setValue("lightscut", val, time); }
38080 float get_lightscut(double time = TiMe::Default()) const { return getFloat("lightscut", time); }
38081
38085 bool set_al_decay(int val, double time = TiMe::Default()) { return setValue("al_decay", val, time); }
38089 int get_al_decay(double time = TiMe::Default()) const { return getInt("al_decay", time); }
38090
38094 bool set_al_subdivs(int val, double time = TiMe::Default()) { return setValue("al_subdivs", val, time); }
38098 int get_al_subdivs(double time = TiMe::Default()) const { return getInt("al_subdivs", time); }
38099
38103 bool set_al_csubdivs(int val, double time = TiMe::Default()) { return setValue("al_csubdivs", val, time); }
38107 int get_al_csubdivs(double time = TiMe::Default()) const { return getInt("al_csubdivs", time); }
38108
38112 bool set_al_cmult(float val, double time = TiMe::Default()) { return setValue("al_cmult", val, time); }
38116 float get_al_cmult(double time = TiMe::Default()) const { return getFloat("al_cmult", time); }
38117
38121 bool set_firelightsspec(bool val, double time = TiMe::Default()) { return setValue("firelightsspec", val, time); }
38125 bool get_firelightsspec(double time = TiMe::Default()) const { return getBool("firelightsspec", time); }
38126
38130 bool set_persistlights(bool val, double time = TiMe::Default()) { return setValue("persistlights", val, time); }
38134 bool get_persistlights(double time = TiMe::Default()) const { return getBool("persistlights", time); }
38135
38138 bool set_instancedlights(bool val, double time = TiMe::Default()) { return setValue("instancedlights", val, time); }
38141 bool get_instancedlights(double time = TiMe::Default()) const { return getBool("instancedlights", time); }
38142
38146 bool set_radmult(float val, double time = TiMe::Default()) { return setValue("radmult", val, time); }
38150 float get_radmult(double time = TiMe::Default()) const { return getFloat("radmult", time); }
38151
38155 bool set_self_illum_map_min_pow(float val, double time = TiMe::Default()) { return setValue("self_illum_map_min_pow", val, time); }
38159 float get_self_illum_map_min_pow(double time = TiMe::Default()) const { return getFloat("self_illum_map_min_pow", time); }
38160
38164 bool set_darg(int val, double time = TiMe::Default()) { return setValue("darg", val, time); }
38168 int get_darg(double time = TiMe::Default()) const { return getInt("darg", time); }
38169
38173 bool set_smoke_color_chan(const char* str, double time = TiMe::Default()) { return setValue("smoke_color_chan", str, time); }
38177 bool set_smoke_color_chan(const std::string& str, double time = TiMe::Default()) { return setValue("smoke_color_chan", str, time); }
38181 std::string get_smoke_color_chan(double time = TiMe::Default()) const { return getString("smoke_color_chan", time); }
38182
38185 bool set_dtex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dtex", texture, time); }
38188 bool set_dtex(const AColor& texture, double time = TiMe::Default()) { return setValue("dtex", texture, time); }
38191 Value get_dtex(double time = TiMe::Default()) const { return getValue("dtex", time); }
38192
38196 bool set_mod_d(bool val, double time = TiMe::Default()) { return setValue("mod_d", val, time); }
38200 bool get_mod_d(double time = TiMe::Default()) const { return getBool("mod_d", time); }
38201
38205 bool set_simple_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("simple_color", acolor, time); }
38209 AColor get_simple_color(double time = TiMe::Default()) const { return getAColor("simple_color", time); }
38210
38214 bool set_noscatter(int val, double time = TiMe::Default()) { return setValue("noscatter", val, time); }
38218 int get_noscatter(double time = TiMe::Default()) const { return getInt("noscatter", time); }
38219
38223 bool set_bounces(int val, double time = TiMe::Default()) { return setValue("bounces", val, time); }
38227 int get_bounces(double time = TiMe::Default()) const { return getInt("bounces", time); }
38228
38232 bool set_phase_function(float val, double time = TiMe::Default()) { return setValue("phase_function", val, time); }
38236 float get_phase_function(double time = TiMe::Default()) const { return getFloat("phase_function", time); }
38237
38241 bool set_anisotropic_scattering_optimization(int val, double time = TiMe::Default()) { return setValue("anisotropic_scattering_optimization", val, time); }
38245 int get_anisotropic_scattering_optimization(double time = TiMe::Default()) const { return getInt("anisotropic_scattering_optimization", time); }
38246
38250 bool set_lightcache(bool val, double time = TiMe::Default()) { return setValue("lightcache", val, time); }
38254 bool get_lightcache(double time = TiMe::Default()) const { return getBool("lightcache", time); }
38255
38259 bool set_lightcachesr(float val, double time = TiMe::Default()) { return setValue("lightcachesr", val, time); }
38263 float get_lightcachesr(double time = TiMe::Default()) const { return getFloat("lightcachesr", time); }
38264
38268 bool set_transfown(float val, double time = TiMe::Default()) { return setValue("transfown", val, time); }
38272 float get_transfown(double time = TiMe::Default()) const { return getFloat("transfown", time); }
38273
38277 bool set_transfext(float val, double time = TiMe::Default()) { return setValue("transfext", val, time); }
38281 float get_transfext(double time = TiMe::Default()) const { return getFloat("transfext", time); }
38282
38286 bool set_difmul(float val, double time = TiMe::Default()) { return setValue("difmul", val, time); }
38290 float get_difmul(double time = TiMe::Default()) const { return getFloat("difmul", time); }
38291
38295 bool set_shad_strength(float val, double time = TiMe::Default()) { return setValue("shad_strength", val, time); }
38299 float get_shad_strength(double time = TiMe::Default()) const { return getFloat("shad_strength", time); }
38300
38304 bool set_dcolor(const Color& color, double time = TiMe::Default()) { return setValue("dcolor", color, time); }
38308 Color get_dcolor(double time = TiMe::Default()) const { return getColor("dcolor", time); }
38309
38313 bool set_dcolor_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("dcolor_positions", floatList, time); }
38314 bool set_dcolor_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("dcolor_positions", std::move(floatList), time); }
38315 bool set_dcolor_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("dcolor_positions", floats, count, time); }
38316 template<size_t count> bool set_dcolor_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("dcolor_positions", floats, count, time); }
38320 FloatList get_dcolor_positions(double time = TiMe::Default()) const { return getFloatList("dcolor_positions", time); }
38321
38325 bool set_dcolor_colors(const ColorList& colorList, double time = TiMe::Default()) { return setValue("dcolor_colors", colorList, time); }
38326 bool set_dcolor_colors(ColorList&& colorList, double time = TiMe::Default()) { return setValue("dcolor_colors", std::move(colorList), time); }
38327 bool set_dcolor_colors(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("dcolor_colors", colors, count, time); }
38328 template<size_t count> bool set_dcolor_colors(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("dcolor_colors", colors, count, time); }
38332 ColorList get_dcolor_colors(double time = TiMe::Default()) const { return getColorList("dcolor_colors", time); }
38333
38337 bool set_dcolor_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("dcolor_interpolations", intList, time); }
38338 bool set_dcolor_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("dcolor_interpolations", std::move(intList), time); }
38339 bool set_dcolor_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("dcolor_interpolations", ints, count, time); }
38340 template<size_t count> bool set_dcolor_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("dcolor_interpolations", ints, count, time); }
38344 IntList get_dcolor_interpolations(double time = TiMe::Default()) const { return getIntList("dcolor_interpolations", time); }
38345
38348 bool set_dcolor_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("dcolor_remap", plugin, time); }
38351 PluginRef get_dcolor_remap(double time = TiMe::Default()) const { return getPlugin("dcolor_remap", time); }
38352
38356 bool set_dcolor_offset(float val, double time = TiMe::Default()) { return setValue("dcolor_offset", val, time); }
38360 float get_dcolor_offset(double time = TiMe::Default()) const { return getFloat("dcolor_offset", time); }
38361
38365 bool set_dcolor_scale(float val, double time = TiMe::Default()) { return setValue("dcolor_scale", val, time); }
38369 float get_dcolor_scale(double time = TiMe::Default()) const { return getFloat("dcolor_scale", time); }
38370
38374 bool set_targ(int val, double time = TiMe::Default()) { return setValue("targ", val, time); }
38378 int get_targ(double time = TiMe::Default()) const { return getInt("targ", time); }
38379
38383 bool set_smoke_opacity_chan(const char* str, double time = TiMe::Default()) { return setValue("smoke_opacity_chan", str, time); }
38387 bool set_smoke_opacity_chan(const std::string& str, double time = TiMe::Default()) { return setValue("smoke_opacity_chan", str, time); }
38391 std::string get_smoke_opacity_chan(double time = TiMe::Default()) const { return getString("smoke_opacity_chan", time); }
38392
38395 bool set_ttex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("ttex", texture, time); }
38398 bool set_ttex(const AColor& texture, double time = TiMe::Default()) { return setValue("ttex", texture, time); }
38401 Value get_ttex(double time = TiMe::Default()) const { return getValue("ttex", time); }
38402
38406 bool set_mod_t(bool val, double time = TiMe::Default()) { return setValue("mod_t", val, time); }
38410 bool get_mod_t(double time = TiMe::Default()) const { return getBool("mod_t", time); }
38411
38415 bool set_transpmode(int val, double time = TiMe::Default()) { return setValue("transpmode", val, time); }
38419 int get_transpmode(double time = TiMe::Default()) const { return getInt("transpmode", time); }
38420
38424 bool set_smoketransp(float val, double time = TiMe::Default()) { return setValue("smoketransp", val, time); }
38428 float get_smoketransp(double time = TiMe::Default()) const { return getFloat("smoketransp", time); }
38429
38433 bool set_stoptransp(float val, double time = TiMe::Default()) { return setValue("stoptransp", val, time); }
38437 float get_stoptransp(double time = TiMe::Default()) const { return getFloat("stoptransp", time); }
38438
38442 bool set_skiptransp(float val, double time = TiMe::Default()) { return setValue("skiptransp", val, time); }
38446 float get_skiptransp(double time = TiMe::Default()) const { return getFloat("skiptransp", time); }
38447
38451 bool set_alphaunitscale(bool val, double time = TiMe::Default()) { return setValue("alphaunitscale", val, time); }
38455 bool get_alphaunitscale(double time = TiMe::Default()) const { return getBool("alphaunitscale", time); }
38456
38460 bool set_basedensityscale(float val, double time = TiMe::Default()) { return setValue("basedensityscale", val, time); }
38464 float get_basedensityscale(double time = TiMe::Default()) const { return getFloat("basedensityscale", time); }
38465
38469 bool set_optvolpass(bool val, double time = TiMe::Default()) { return setValue("optvolpass", val, time); }
38473 bool get_optvolpass(double time = TiMe::Default()) const { return getBool("optvolpass", time); }
38474
38478 bool set_absorption_arg(int val, double time = TiMe::Default()) { return setValue("absorption_arg", val, time); }
38482 int get_absorption_arg(double time = TiMe::Default()) const { return getInt("absorption_arg", time); }
38483
38487 bool set_absorption_color(const Color& color, double time = TiMe::Default()) { return setValue("absorption_color", color, time); }
38491 Color get_absorption_color(double time = TiMe::Default()) const { return getColor("absorption_color", time); }
38492
38495 bool set_absorption_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("absorption_tex", texture, time); }
38498 bool set_absorption_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("absorption_tex", texture, time); }
38501 Value get_absorption_tex(double time = TiMe::Default()) const { return getValue("absorption_tex", time); }
38502
38506 bool set_transp(float val, double time = TiMe::Default()) { return setValue("transp", val, time); }
38510 float get_transp(double time = TiMe::Default()) const { return getFloat("transp", time); }
38511
38515 bool set_transp_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("transp_positions", floatList, time); }
38516 bool set_transp_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("transp_positions", std::move(floatList), time); }
38517 bool set_transp_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("transp_positions", floats, count, time); }
38518 template<size_t count> bool set_transp_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("transp_positions", floats, count, time); }
38522 FloatList get_transp_positions(double time = TiMe::Default()) const { return getFloatList("transp_positions", time); }
38523
38527 bool set_transp_values(const FloatList& floatList, double time = TiMe::Default()) { return setValue("transp_values", floatList, time); }
38528 bool set_transp_values(FloatList&& floatList, double time = TiMe::Default()) { return setValue("transp_values", std::move(floatList), time); }
38529 bool set_transp_values(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("transp_values", floats, count, time); }
38530 template<size_t count> bool set_transp_values(const float (&floats)[count], double time = TiMe::Default()) { return setArray("transp_values", floats, count, time); }
38534 FloatList get_transp_values(double time = TiMe::Default()) const { return getFloatList("transp_values", time); }
38535
38539 bool set_transp_interpolations(const IntList& intList, double time = TiMe::Default()) { return setValue("transp_interpolations", intList, time); }
38540 bool set_transp_interpolations(IntList&& intList, double time = TiMe::Default()) { return setValue("transp_interpolations", std::move(intList), time); }
38541 bool set_transp_interpolations(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("transp_interpolations", ints, count, time); }
38542 template<size_t count> bool set_transp_interpolations(const int (&ints)[count], double time = TiMe::Default()) { return setArray("transp_interpolations", ints, count, time); }
38546 IntList get_transp_interpolations(double time = TiMe::Default()) const { return getIntList("transp_interpolations", time); }
38547
38550 bool set_transp_remap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("transp_remap", plugin, time); }
38553 PluginRef get_transp_remap(double time = TiMe::Default()) const { return getPlugin("transp_remap", time); }
38554
38558 bool set_transp_offset(float val, double time = TiMe::Default()) { return setValue("transp_offset", val, time); }
38562 float get_transp_offset(double time = TiMe::Default()) const { return getFloat("transp_offset", time); }
38563
38567 bool set_transp_scale(float val, double time = TiMe::Default()) { return setValue("transp_scale", val, time); }
38571 float get_transp_scale(double time = TiMe::Default()) const { return getFloat("transp_scale", time); }
38572
38576 bool set_tmult(float val, double time = TiMe::Default()) { return setValue("tmult", val, time); }
38580 float get_tmult(double time = TiMe::Default()) const { return getFloat("tmult", time); }
38581
38584 bool set_transp_power(float val, double time = TiMe::Default()) { return setValue("transp_power", val, time); }
38587 float get_transp_power(double time = TiMe::Default()) const { return getFloat("transp_power", time); }
38588
38592 bool set_shadow_opacity(float val, double time = TiMe::Default()) { return setValue("shadow_opacity", val, time); }
38596 float get_shadow_opacity(double time = TiMe::Default()) const { return getFloat("shadow_opacity", time); }
38597
38601 bool set_cell_aspect(const FloatList& floatList, double time = TiMe::Default()) { return setValue("cell_aspect", floatList, time); }
38602 bool set_cell_aspect(FloatList&& floatList, double time = TiMe::Default()) { return setValue("cell_aspect", std::move(floatList), time); }
38603 bool set_cell_aspect(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("cell_aspect", floats, count, time); }
38604 template<size_t count> bool set_cell_aspect(const float (&floats)[count], double time = TiMe::Default()) { return setArray("cell_aspect", floats, count, time); }
38608 FloatList get_cell_aspect(double time = TiMe::Default()) const { return getFloatList("cell_aspect", time); }
38609
38613 bool set_pmprimary(int val, double time = TiMe::Default()) { return setValue("pmprimary", val, time); }
38617 int get_pmprimary(double time = TiMe::Default()) const { return getInt("pmprimary", time); }
38618
38622 bool set_pmbounces(int val, double time = TiMe::Default()) { return setValue("pmbounces", val, time); }
38626 int get_pmbounces(double time = TiMe::Default()) const { return getInt("pmbounces", time); }
38627
38630 bool set_left_handed_coord(bool val, double time = TiMe::Default()) { return setValue("left_handed_coord", val, time); }
38633 bool get_left_handed_coord(double time = TiMe::Default()) const { return getBool("left_handed_coord", time); }
38634
38638 bool set_brdfscatter(float val, double time = TiMe::Default()) { return setValue("brdfscatter", val, time); }
38642 float get_brdfscatter(double time = TiMe::Default()) const { return getFloat("brdfscatter", time); }
38643
38647 bool set_brdfscatternogi(float val, double time = TiMe::Default()) { return setValue("brdfscatternogi", val, time); }
38651 float get_brdfscatternogi(double time = TiMe::Default()) const { return getFloat("brdfscatternogi", time); }
38652
38656 bool set_bias(float val, double time = TiMe::Default()) { return setValue("bias", val, time); }
38660 float get_bias(double time = TiMe::Default()) const { return getFloat("bias", time); }
38661
38665 bool set_usebias(int val, double time = TiMe::Default()) { return setValue("usebias", val, time); }
38669 int get_usebias(double time = TiMe::Default()) const { return getInt("usebias", time); }
38670
38674 bool set_wrapx(bool val, double time = TiMe::Default()) { return setValue("wrapx", val, time); }
38678 bool get_wrapx(double time = TiMe::Default()) const { return getBool("wrapx", time); }
38679
38683 bool set_wrapy(bool val, double time = TiMe::Default()) { return setValue("wrapy", val, time); }
38687 bool get_wrapy(double time = TiMe::Default()) const { return getBool("wrapy", time); }
38688
38692 bool set_wrapz(bool val, double time = TiMe::Default()) { return setValue("wrapz", val, time); }
38696 bool get_wrapz(double time = TiMe::Default()) const { return getBool("wrapz", time); }
38697
38701 bool set_useLegacyLightLinkingForVRayStd(bool val, double time = TiMe::Default()) { return setValue("useLegacyLightLinkingForVRayStd", val, time); }
38705 bool get_useLegacyLightLinkingForVRayStd(double time = TiMe::Default()) const { return getBool("useLegacyLightLinkingForVRayStd", time); }
38706
38709 bool set_lightlinks(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("lightlinks", pluginList, time); }
38710 bool set_lightlinks(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("lightlinks", plugins, count, time); }
38711 template<size_t count> bool set_lightlinks(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("lightlinks", plugins, count, time); }
38714 PluginList get_lightlinks(double time = TiMe::Default()) const { return getPluginList("lightlinks", time); }
38715
38718 bool set_shadowBreakings(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("shadowBreakings", pluginList, time); }
38719 bool set_shadowBreakings(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("shadowBreakings", plugins, count, time); }
38720 template<size_t count> bool set_shadowBreakings(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("shadowBreakings", plugins, count, time); }
38723 PluginList get_shadowBreakings(double time = TiMe::Default()) const { return getPluginList("shadowBreakings", time); }
38724
38728 bool set_velocities_from_uvw(bool val, double time = TiMe::Default()) { return setValue("velocities_from_uvw", val, time); }
38732 bool get_velocities_from_uvw(double time = TiMe::Default()) const { return getBool("velocities_from_uvw", time); }
38733
38737 bool set_coord_method(int val, double time = TiMe::Default()) { return setValue("coord_method", val, time); }
38741 int get_coord_method(double time = TiMe::Default()) const { return getInt("coord_method", time); }
38742
38746 bool set_gamma_mult(float val, double time = TiMe::Default()) { return setValue("gamma_mult", val, time); }
38750 float get_gamma_mult(double time = TiMe::Default()) const { return getFloat("gamma_mult", time); }
38751
38755 bool set_mbgrid(bool val, double time = TiMe::Default()) { return setValue("mbgrid", val, time); }
38759 bool get_mbgrid(double time = TiMe::Default()) const { return getBool("mbgrid", time); }
38760
38764 bool set_vol_moblur_method(int val, double time = TiMe::Default()) { return setValue("vol_moblur_method", val, time); }
38768 int get_vol_moblur_method(double time = TiMe::Default()) const { return getInt("vol_moblur_method", time); }
38769
38773 bool set_mbsmooth(int val, double time = TiMe::Default()) { return setValue("mbsmooth", val, time); }
38777 int get_mbsmooth(double time = TiMe::Default()) const { return getInt("mbsmooth", time); }
38778
38782 bool set_normalized_positions(int val, double time = TiMe::Default()) { return setValue("normalized_positions", val, time); }
38786 int get_normalized_positions(double time = TiMe::Default()) const { return getInt("normalized_positions", time); }
38787
38791 bool set_generate_gi(bool val, double time = TiMe::Default()) { return setValue("generate_gi", val, time); }
38795 bool get_generate_gi(double time = TiMe::Default()) const { return getBool("generate_gi", time); }
38796
38800 bool set_receive_gi(bool val, double time = TiMe::Default()) { return setValue("receive_gi", val, time); }
38804 bool get_receive_gi(double time = TiMe::Default()) const { return getBool("receive_gi", time); }
38805
38809 bool set_gen_gi_mult(float val, double time = TiMe::Default()) { return setValue("gen_gi_mult", val, time); }
38813 float get_gen_gi_mult(double time = TiMe::Default()) const { return getFloat("gen_gi_mult", time); }
38814
38818 bool set_rec_gi_mult(float val, double time = TiMe::Default()) { return setValue("rec_gi_mult", val, time); }
38822 float get_rec_gi_mult(double time = TiMe::Default()) const { return getFloat("rec_gi_mult", time); }
38823
38827 bool set_generate_caust(bool val, double time = TiMe::Default()) { return setValue("generate_caust", val, time); }
38831 bool get_generate_caust(double time = TiMe::Default()) const { return getBool("generate_caust", time); }
38832
38836 bool set_receive_caust(bool val, double time = TiMe::Default()) { return setValue("receive_caust", val, time); }
38840 bool get_receive_caust(double time = TiMe::Default()) const { return getBool("receive_caust", time); }
38841
38845 bool set_caust_mult(float val, double time = TiMe::Default()) { return setValue("caust_mult", val, time); }
38849 float get_caust_mult(double time = TiMe::Default()) const { return getFloat("caust_mult", time); }
38850
38854 bool set_camera_visibility(bool val, double time = TiMe::Default()) { return setValue("camera_visibility", val, time); }
38858 bool get_camera_visibility(double time = TiMe::Default()) const { return getBool("camera_visibility", time); }
38859
38863 bool set_reflections_visibility(bool val, double time = TiMe::Default()) { return setValue("reflections_visibility", val, time); }
38867 bool get_reflections_visibility(double time = TiMe::Default()) const { return getBool("reflections_visibility", time); }
38868
38872 bool set_refractions_visibility(bool val, double time = TiMe::Default()) { return setValue("refractions_visibility", val, time); }
38876 bool get_refractions_visibility(double time = TiMe::Default()) const { return getBool("refractions_visibility", time); }
38877
38881 bool set_gi_visibility(bool val, double time = TiMe::Default()) { return setValue("gi_visibility", val, time); }
38885 bool get_gi_visibility(double time = TiMe::Default()) const { return getBool("gi_visibility", time); }
38886
38890 bool set_shadows_visibility(bool val, double time = TiMe::Default()) { return setValue("shadows_visibility", val, time); }
38894 bool get_shadows_visibility(double time = TiMe::Default()) const { return getBool("shadows_visibility", time); }
38895
38898 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
38899 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
38900 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
38903 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
38904
38907 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
38908 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
38909 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
38912 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
38913
38916 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
38917 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
38918 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
38921 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
38922
38925 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
38926 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
38927 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
38930 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
38931
38934 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
38937 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
38938
38941 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
38944 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
38945
38948 bool set_user_attributes(const char* str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
38951 bool set_user_attributes(const std::string& str, double time = TiMe::Default()) { return setValue("user_attributes", str, time); }
38954 std::string get_user_attributes(double time = TiMe::Default()) const { return getString("user_attributes", time); }
38955
38958 bool set_user_attributes_bin(const IntList& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", intList, time); }
38959 bool set_user_attributes_bin(IntList&& intList, double time = TiMe::Default()) { return setValue("user_attributes_bin", std::move(intList), time); }
38960 bool set_user_attributes_bin(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
38961 template<size_t count> bool set_user_attributes_bin(const int (&ints)[count], double time = TiMe::Default()) { return setArray("user_attributes_bin", ints, count, time); }
38964 IntList get_user_attributes_bin(double time = TiMe::Default()) const { return getIntList("user_attributes_bin", time); }
38965};
38966
38968class PluginAtTime : public Plugin {
38969public:
38971 static constexpr const PluginTypeId getTypeId() { return 0x7889DA9E; }
38973 static constexpr const char* getType() { return "PluginAtTime"; }
38974
38975 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
38976
38979 bool set_plugin(const ValueList& list, double time = TiMe::Default()) { return setValue("plugin", list, time); }
38980 bool set_plugin(ValueList&& list, double time = TiMe::Default()) { return setValue("plugin", std::move(list), time); }
38981 bool set_plugin(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("plugin", values, count, time); }
38982 template<size_t count> bool set_plugin(const Value (&values)[count], double time = TiMe::Default()) { return setArray("plugin", values, count, time); }
38983 template<size_t count> bool set_plugin(Value (&&values)[count], double time = TiMe::Default()) { return setArray("plugin", values, count, time); }
38986 ValueList get_plugin(double time = TiMe::Default()) const { return getValueList("plugin", time); }
38987};
38988
38991public:
38993 static constexpr const PluginTypeId getTypeId() { return 0x133C8FA; }
38995 static constexpr const char* getType() { return "PluginParameterStore"; }
38996
38999 bool set_param_name(const char* str, double time = TiMe::Default()) { return setValue("param_name", str, time); }
39002 bool set_param_name(const std::string& str, double time = TiMe::Default()) { return setValue("param_name", str, time); }
39005 std::string get_param_name(double time = TiMe::Default()) const { return getString("param_name", time); }
39006
39009 bool set_bool(bool val, double time = TiMe::Default()) { return setValue("bool", val, time); }
39012 bool get_bool(double time = TiMe::Default()) const { return getBool("bool", time); }
39013
39016 bool set_int(int val, double time = TiMe::Default()) { return setValue("int", val, time); }
39019 int get_int(double time = TiMe::Default()) const { return getInt("int", time); }
39020
39023 bool set_float(float val, double time = TiMe::Default()) { return setValue("float", val, time); }
39026 float get_float(double time = TiMe::Default()) const { return getFloat("float", time); }
39027
39030 bool set_double(double val, double time = TiMe::Default()) { return setValue("double", val, time); }
39033 double get_double(double time = TiMe::Default()) const { return getDouble("double", time); }
39034
39037 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
39040 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
39041
39044 bool set_acolor(const AColor& acolor, double time = TiMe::Default()) { return setValue("acolor", acolor, time); }
39047 AColor get_acolor(double time = TiMe::Default()) const { return getAColor("acolor", time); }
39048
39050 bool set_object(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("object", plugin, time); }
39052 PluginRef get_object(double time = TiMe::Default()) const { return getPlugin("object", time); }
39053};
39054
39056class RTEngine : public Plugin {
39057public:
39059 static constexpr const PluginTypeId getTypeId() { return 0x77A0E0C1; }
39061 static constexpr const char* getType() { return "RTEngine"; }
39062
39063 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
39064
39067 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
39070 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
39071
39074 bool set_use_opencl(bool val, double time = TiMe::Default()) { return setValue("use_opencl", val, time); }
39077 bool get_use_opencl(double time = TiMe::Default()) const { return getBool("use_opencl", time); }
39078
39081 bool set_separate_window(bool val, double time = TiMe::Default()) { return setValue("separate_window", val, time); }
39084 bool get_separate_window(double time = TiMe::Default()) const { return getBool("separate_window", time); }
39085
39088 bool set_full_recalc_aa_mask(bool val, double time = TiMe::Default()) { return setValue("full_recalc_aa_mask", val, time); }
39091 bool get_full_recalc_aa_mask(double time = TiMe::Default()) const { return getBool("full_recalc_aa_mask", time); }
39092};
39093
39095class RawBitmapBuffer : public Plugin {
39096public:
39098 static constexpr const PluginTypeId getTypeId() { return 0x77CFB829; }
39100 static constexpr const char* getType() { return "RawBitmapBuffer"; }
39101
39102 operator BitmapPluginCategory() { return *static_cast<BitmapPluginCategory*>(static_cast<Plugin*>(this)); }
39103
39107 bool set_filter_type(int val, double time = TiMe::Default()) { return setValue("filter_type", val, time); }
39111 int get_filter_type(double time = TiMe::Default()) const { return getInt("filter_type", time); }
39112
39115 bool set_filter_blur(float val, double time = TiMe::Default()) { return setValue("filter_blur", val, time); }
39118 float get_filter_blur(double time = TiMe::Default()) const { return getFloat("filter_blur", time); }
39119
39123 bool set_transfer_function(int val, double time = TiMe::Default()) { return setValue("transfer_function", val, time); }
39127 int get_transfer_function(double time = TiMe::Default()) const { return getInt("transfer_function", time); }
39128
39130 bool set_color_space(int val, double time = TiMe::Default()) { return setValue("color_space", val, time); }
39132 int get_color_space(double time = TiMe::Default()) const { return getInt("color_space", time); }
39133
39135 bool set_rgb_color_space(const char* str, double time = TiMe::Default()) { return setValue("rgb_color_space", str, time); }
39137 bool set_rgb_color_space(const std::string& str, double time = TiMe::Default()) { return setValue("rgb_color_space", str, time); }
39139 std::string get_rgb_color_space(double time = TiMe::Default()) const { return getString("rgb_color_space", time); }
39140
39143 bool set_gamma(float val, double time = TiMe::Default()) { return setValue("gamma", val, time); }
39146 float get_gamma(double time = TiMe::Default()) const { return getFloat("gamma", time); }
39147
39150 bool set_maya_compatible(bool val, double time = TiMe::Default()) { return setValue("maya_compatible", val, time); }
39153 bool get_maya_compatible(double time = TiMe::Default()) const { return getBool("maya_compatible", time); }
39154
39157 bool set_allow_negative_colors(bool val, double time = TiMe::Default()) { return setValue("allow_negative_colors", val, time); }
39160 bool get_allow_negative_colors(double time = TiMe::Default()) const { return getBool("allow_negative_colors", time); }
39161
39165 bool set_interpolation(int val, double time = TiMe::Default()) { return setValue("interpolation", val, time); }
39169 int get_interpolation(double time = TiMe::Default()) const { return getInt("interpolation", time); }
39170
39173 bool set_frame_number(int val, double time = TiMe::Default()) { return setValue("frame_number", val, time); }
39176 int get_frame_number(double time = TiMe::Default()) const { return getInt("frame_number", time); }
39177
39180 bool set_frame_offset(int val, double time = TiMe::Default()) { return setValue("frame_offset", val, time); }
39183 int get_frame_offset(double time = TiMe::Default()) const { return getInt("frame_offset", time); }
39184
39187 bool set_pixels(const IntList& intList, double time = TiMe::Default()) { return setValue("pixels", intList, time); }
39188 bool set_pixels(IntList&& intList, double time = TiMe::Default()) { return setValue("pixels", std::move(intList), time); }
39189 bool set_pixels(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("pixels", ints, count, time); }
39190 template<size_t count> bool set_pixels(const int (&ints)[count], double time = TiMe::Default()) { return setArray("pixels", ints, count, time); }
39193 IntList get_pixels(double time = TiMe::Default()) const { return getIntList("pixels", time); }
39194
39197 bool set_alpha_pixels(const IntList& intList, double time = TiMe::Default()) { return setValue("alpha_pixels", intList, time); }
39198 bool set_alpha_pixels(IntList&& intList, double time = TiMe::Default()) { return setValue("alpha_pixels", std::move(intList), time); }
39199 bool set_alpha_pixels(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("alpha_pixels", ints, count, time); }
39200 template<size_t count> bool set_alpha_pixels(const int (&ints)[count], double time = TiMe::Default()) { return setArray("alpha_pixels", ints, count, time); }
39203 IntList get_alpha_pixels(double time = TiMe::Default()) const { return getIntList("alpha_pixels", time); }
39204
39208 bool set_pixels_type(int val, double time = TiMe::Default()) { return setValue("pixels_type", val, time); }
39212 int get_pixels_type(double time = TiMe::Default()) const { return getInt("pixels_type", time); }
39213
39216 bool set_width(int val, double time = TiMe::Default()) { return setValue("width", val, time); }
39219 int get_width(double time = TiMe::Default()) const { return getInt("width", time); }
39220
39223 bool set_height(int val, double time = TiMe::Default()) { return setValue("height", val, time); }
39226 int get_height(double time = TiMe::Default()) const { return getInt("height", time); }
39227};
39228
39231public:
39233 static constexpr const PluginTypeId getTypeId() { return 0x78684CB5; }
39235 static constexpr const char* getType() { return "RenderChannelAmbientOcclusion"; }
39236
39237 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39238
39242 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39246 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39247
39250 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39253 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39256 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39257
39260 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
39263 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
39264
39267 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
39270 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
39271
39275 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
39279 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
39280
39283 bool set_affect_matte_objects(bool val, double time = TiMe::Default()) { return setValue("affect_matte_objects", val, time); }
39286 bool get_affect_matte_objects(double time = TiMe::Default()) const { return getBool("affect_matte_objects", time); }
39287
39291 bool set_work_with_transparency(bool val, double time = TiMe::Default()) { return setValue("work_with_transparency", val, time); }
39295 bool get_work_with_transparency(double time = TiMe::Default()) const { return getBool("work_with_transparency", time); }
39296
39299 bool set_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("radius", texturefloat, time); }
39302 bool set_radius(float texturefloat, double time = TiMe::Default()) { return setValue("radius", texturefloat, time); }
39305 Value get_radius(double time = TiMe::Default()) const { return getValue("radius", time); }
39306
39309 bool set_distribution(float val, double time = TiMe::Default()) { return setValue("distribution", val, time); }
39312 float get_distribution(double time = TiMe::Default()) const { return getFloat("distribution", time); }
39313
39316 bool set_falloff(float val, double time = TiMe::Default()) { return setValue("falloff", val, time); }
39319 float get_falloff(double time = TiMe::Default()) const { return getFloat("falloff", time); }
39320
39323 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
39326 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
39327
39329 bool set_exclude_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list", pluginList, time); }
39330 bool set_exclude_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
39331 template<size_t count> bool set_exclude_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
39333 PluginList get_exclude_list(double time = TiMe::Default()) const { return getPluginList("exclude_list", time); }
39334
39337 bool set_exclude_list_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_as_inclusive_set", val, time); }
39340 bool get_exclude_list_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_as_inclusive_set", time); }
39341
39343 bool set_affect_by_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("affect_by_list", pluginList, time); }
39344 bool set_affect_by_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("affect_by_list", plugins, count, time); }
39345 template<size_t count> bool set_affect_by_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("affect_by_list", plugins, count, time); }
39347 PluginList get_affect_by_list(double time = TiMe::Default()) const { return getPluginList("affect_by_list", time); }
39348
39351 bool set_affect_by_list_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("affect_by_list_as_inclusive_set", val, time); }
39354 bool get_affect_by_list_as_inclusive_set(double time = TiMe::Default()) const { return getBool("affect_by_list_as_inclusive_set", time); }
39355};
39356
39359public:
39361 static constexpr const PluginTypeId getTypeId() { return 0x7867B167; }
39363 static constexpr const char* getType() { return "RenderChannelBackToBeauty"; }
39364
39365 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39366};
39367
39370public:
39372 static constexpr const PluginTypeId getTypeId() { return 0x77DD9EC1; }
39374 static constexpr const char* getType() { return "RenderChannelBumpNormals"; }
39375
39376 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39377
39381 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39385 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39386
39389 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39392 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39395 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39396
39399 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
39402 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
39403};
39404
39407public:
39409 static constexpr const PluginTypeId getTypeId() { return 0x78675E11; }
39411 static constexpr const char* getType() { return "RenderChannelCoat"; }
39412
39413 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39414
39418 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39422 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39423
39426 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39429 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39432 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39433
39436 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
39439 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
39440
39443 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
39446 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
39447
39451 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
39455 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
39456
39459 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
39462 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
39463
39466 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
39469 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
39470
39473 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
39476 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
39477
39480 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
39483 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
39484
39488 bool set_light_select_mode(int val, double time = TiMe::Default()) { return setValue("light_select_mode", val, time); }
39492 int get_light_select_mode(double time = TiMe::Default()) const { return getInt("light_select_mode", time); }
39493
39497 bool set_light_path_expression(const char* str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
39501 bool set_light_path_expression(const std::string& str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
39505 std::string get_light_path_expression(double time = TiMe::Default()) const { return getString("light_path_expression", time); }
39506
39510 bool set_light_select_matte(bool val, double time = TiMe::Default()) { return setValue("light_select_matte", val, time); }
39514 bool get_light_select_matte(double time = TiMe::Default()) const { return getBool("light_select_matte", time); }
39515
39519 bool set_light_select_in_lightmix(bool val, double time = TiMe::Default()) { return setValue("light_select_in_lightmix", val, time); }
39523 bool get_light_select_in_lightmix(double time = TiMe::Default()) const { return getBool("light_select_in_lightmix", time); }
39524};
39525
39528public:
39530 static constexpr const PluginTypeId getTypeId() { return 0x78675E12; }
39532 static constexpr const char* getType() { return "RenderChannelCoatReflection"; }
39533
39534 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39535
39539 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39543 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39544
39547 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39550 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39553 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39554
39557 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
39560 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
39561
39564 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
39567 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
39568
39572 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
39576 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
39577
39580 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
39583 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
39584
39587 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
39590 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
39591
39594 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
39597 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
39598
39601 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
39604 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
39605
39609 bool set_light_select_mode(int val, double time = TiMe::Default()) { return setValue("light_select_mode", val, time); }
39613 int get_light_select_mode(double time = TiMe::Default()) const { return getInt("light_select_mode", time); }
39614
39618 bool set_light_path_expression(const char* str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
39622 bool set_light_path_expression(const std::string& str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
39626 std::string get_light_path_expression(double time = TiMe::Default()) const { return getString("light_path_expression", time); }
39627
39631 bool set_light_select_matte(bool val, double time = TiMe::Default()) { return setValue("light_select_matte", val, time); }
39635 bool get_light_select_matte(double time = TiMe::Default()) const { return getBool("light_select_matte", time); }
39636
39640 bool set_light_select_in_lightmix(bool val, double time = TiMe::Default()) { return setValue("light_select_in_lightmix", val, time); }
39644 bool get_light_select_in_lightmix(double time = TiMe::Default()) const { return getBool("light_select_in_lightmix", time); }
39645};
39646
39649public:
39651 static constexpr const PluginTypeId getTypeId() { return 0x7784060A; }
39653 static constexpr const char* getType() { return "RenderChannelColor"; }
39654
39655 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39656
39660 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39664 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39665
39668 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39671 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39674 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39675
39678 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
39681 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
39682
39685 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
39688 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
39689
39693 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
39697 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
39698
39701 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
39704 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
39705
39708 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
39711 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
39712
39715 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
39718 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
39719
39722 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
39725 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
39726};
39727
39730public:
39732 static constexpr const PluginTypeId getTypeId() { return 0x781B6729; }
39734 static constexpr const char* getType() { return "RenderChannelColorModo"; }
39735
39736 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39737
39741 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39745 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39746
39749 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39752 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39755 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39756
39759 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
39762 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
39763
39766 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
39769 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
39770
39774 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
39778 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
39779
39782 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
39785 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
39786
39789 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
39792 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
39793
39796 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
39799 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
39800
39803 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
39806 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
39807
39810 bool set_aa_override_foreground_intensity(bool val, double time = TiMe::Default()) { return setValue("aa_override_foreground_intensity", val, time); }
39813 bool get_aa_override_foreground_intensity(double time = TiMe::Default()) const { return getBool("aa_override_foreground_intensity", time); }
39814
39817 bool set_aa_foreground_intensity(float val, double time = TiMe::Default()) { return setValue("aa_foreground_intensity", val, time); }
39820 float get_aa_foreground_intensity(double time = TiMe::Default()) const { return getFloat("aa_foreground_intensity", time); }
39821};
39822
39825public:
39827 static constexpr const PluginTypeId getTypeId() { return 0x77CF66E9; }
39829 static constexpr const char* getType() { return "RenderChannelCoverage"; }
39830
39831 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39832
39836 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39840 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39841
39844 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39847 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39850 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39851};
39852
39855public:
39857 static constexpr const PluginTypeId getTypeId() { return 0x7839ED9D; }
39859 static constexpr const char* getType() { return "RenderChannelCryptomatte"; }
39860
39861 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39862
39865 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39868 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39871 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39872
39875 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
39878 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
39879
39882 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39885 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39886
39890 bool set_id_type(int val, double time = TiMe::Default()) { return setValue("id_type", val, time); }
39894 int get_id_type(double time = TiMe::Default()) const { return getInt("id_type", time); }
39895
39899 bool set_user_attribute(const char* str, double time = TiMe::Default()) { return setValue("user_attribute", str, time); }
39903 bool set_user_attribute(const std::string& str, double time = TiMe::Default()) { return setValue("user_attribute", str, time); }
39907 std::string get_user_attribute(double time = TiMe::Default()) const { return getString("user_attribute", time); }
39908
39912 bool set_add_root_object_name(int val, double time = TiMe::Default()) { return setValue("add_root_object_name", val, time); }
39916 int get_add_root_object_name(double time = TiMe::Default()) const { return getInt("add_root_object_name", time); }
39917
39921 bool set_num_level(int val, double time = TiMe::Default()) { return setValue("num_level", val, time); }
39925 int get_num_level(double time = TiMe::Default()) const { return getInt("num_level", time); }
39926
39929 bool set_id_type_prefix(const char* str, double time = TiMe::Default()) { return setValue("id_type_prefix", str, time); }
39932 bool set_id_type_prefix(const std::string& str, double time = TiMe::Default()) { return setValue("id_type_prefix", str, time); }
39935 std::string get_id_type_prefix(double time = TiMe::Default()) const { return getString("id_type_prefix", time); }
39936
39940 bool set_write_metadata(int val, double time = TiMe::Default()) { return setValue("write_metadata", val, time); }
39944 int get_write_metadata(double time = TiMe::Default()) const { return getInt("write_metadata", time); }
39945
39948 bool set_object_path_start_slash(bool val, double time = TiMe::Default()) { return setValue("object_path_start_slash", val, time); }
39951 bool get_object_path_start_slash(double time = TiMe::Default()) const { return getBool("object_path_start_slash", time); }
39952};
39953
39956public:
39958 static constexpr const PluginTypeId getTypeId() { return 0x77DEF4F1; }
39960 static constexpr const char* getType() { return "RenderChannelDRBucket"; }
39961
39962 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
39963
39967 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
39971 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
39972
39975 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
39978 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
39981 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
39982
39986 bool set_text_alignment(int val, double time = TiMe::Default()) { return setValue("text_alignment", val, time); }
39990 int get_text_alignment(double time = TiMe::Default()) const { return getInt("text_alignment", time); }
39991};
39992
39995public:
39997 static constexpr const PluginTypeId getTypeId() { return 0x782A321F; }
39999 static constexpr const char* getType() { return "RenderChannelDenoiser"; }
40000
40001 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40002
40006 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40010 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40011
40015 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
40019 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
40020
40024 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40028 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40032 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40033
40037 bool set_engine(int val, double time = TiMe::Default()) { return setValue("engine", val, time); }
40041 int get_engine(double time = TiMe::Default()) const { return getInt("engine", time); }
40042
40046 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
40050 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
40051
40055 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
40059 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
40060
40064 bool set_preset(int val, double time = TiMe::Default()) { return setValue("preset", val, time); }
40068 int get_preset(double time = TiMe::Default()) const { return getInt("preset", time); }
40069
40073 bool set_strength(float val, double time = TiMe::Default()) { return setValue("strength", val, time); }
40077 float get_strength(double time = TiMe::Default()) const { return getFloat("strength", time); }
40078
40082 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
40086 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
40087
40091 bool set_use_gpu(bool val, double time = TiMe::Default()) { return setValue("use_gpu", val, time); }
40095 bool get_use_gpu(double time = TiMe::Default()) const { return getBool("use_gpu", time); }
40096
40099 bool set_progressive_update(int val, double time = TiMe::Default()) { return setValue("progressive_update", val, time); }
40102 int get_progressive_update(double time = TiMe::Default()) const { return getInt("progressive_update", time); }
40103
40107 bool set_generate_render_elements(int val, double time = TiMe::Default()) { return setValue("generate_render_elements", val, time); }
40111 int get_generate_render_elements(double time = TiMe::Default()) const { return getInt("generate_render_elements", time); }
40112
40116 bool set_silence_optix_init_error(bool val, double time = TiMe::Default()) { return setValue("silence_optix_init_error", val, time); }
40120 bool get_silence_optix_init_error(double time = TiMe::Default()) const { return getBool("silence_optix_init_error", time); }
40121
40125 bool set_wrap_around_borders(bool val, double time = TiMe::Default()) { return setValue("wrap_around_borders", val, time); }
40129 bool get_wrap_around_borders(double time = TiMe::Default()) const { return getBool("wrap_around_borders", time); }
40130
40134 bool set_temporal_mode(bool val, double time = TiMe::Default()) { return setValue("temporal_mode", val, time); }
40138 bool get_temporal_mode(double time = TiMe::Default()) const { return getBool("temporal_mode", time); }
40139
40143 bool set_denoise_alpha(bool val, double time = TiMe::Default()) { return setValue("denoise_alpha", val, time); }
40147 bool get_denoise_alpha(double time = TiMe::Default()) const { return getBool("denoise_alpha", time); }
40148
40152 bool set_optix_use_upscale(bool val, double time = TiMe::Default()) { return setValue("optix_use_upscale", val, time); }
40156 bool get_optix_use_upscale(double time = TiMe::Default()) const { return getBool("optix_use_upscale", time); }
40157
40161 bool set_oidn_prefilter(bool val, double time = TiMe::Default()) { return setValue("oidn_prefilter", val, time); }
40165 bool get_oidn_prefilter(double time = TiMe::Default()) const { return getBool("oidn_prefilter", time); }
40166};
40167
40170public:
40172 static constexpr const PluginTypeId getTypeId() { return 0x77C1CF9D; }
40174 static constexpr const char* getType() { return "RenderChannelExtraTex"; }
40175
40176 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40177
40181 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40185 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40186
40189 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40192 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40195 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40196
40200 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
40204 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
40205
40208 bool set_affect_matte_objects(bool val, double time = TiMe::Default()) { return setValue("affect_matte_objects", val, time); }
40211 bool get_affect_matte_objects(double time = TiMe::Default()) const { return getBool("affect_matte_objects", time); }
40212
40215 bool set_texmap(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texmap", texture, time); }
40218 bool set_texmap(const AColor& texture, double time = TiMe::Default()) { return setValue("texmap", texture, time); }
40221 Value get_texmap(double time = TiMe::Default()) const { return getValue("texmap", time); }
40222
40225 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
40228 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
40229
40231 bool set_exclude_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list", pluginList, time); }
40232 bool set_exclude_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
40233 template<size_t count> bool set_exclude_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
40235 PluginList get_exclude_list(double time = TiMe::Default()) const { return getPluginList("exclude_list", time); }
40236
40239 bool set_exclude_list_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_as_inclusive_set", val, time); }
40242 bool get_exclude_list_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_as_inclusive_set", time); }
40243
40246 bool set_force_32_bit_output(bool val, double time = TiMe::Default()) { return setValue("force_32_bit_output", val, time); }
40249 bool get_force_32_bit_output(double time = TiMe::Default()) const { return getBool("force_32_bit_output", time); }
40250
40253 bool set_force_lossless_compression(bool val, double time = TiMe::Default()) { return setValue("force_lossless_compression", val, time); }
40256 bool get_force_lossless_compression(double time = TiMe::Default()) const { return getBool("force_lossless_compression", time); }
40257
40260 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
40263 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
40264
40267 bool set_background(const PluginRef& texture, double time = TiMe::Default()) { return setValue("background", texture, time); }
40270 bool set_background(const AColor& texture, double time = TiMe::Default()) { return setValue("background", texture, time); }
40273 Value get_background(double time = TiMe::Default()) const { return getValue("background", time); }
40274};
40275
40278public:
40280 static constexpr const PluginTypeId getTypeId() { return 0x782A5B49; }
40282 static constexpr const char* getType() { return "RenderChannelExtraTexFloat"; }
40283
40284 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40285
40289 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40293 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40294
40297 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40300 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40303 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40304
40307 bool set_texmap(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("texmap", texturefloat, time); }
40310 bool set_texmap(float texturefloat, double time = TiMe::Default()) { return setValue("texmap", texturefloat, time); }
40313 Value get_texmap(double time = TiMe::Default()) const { return getValue("texmap", time); }
40314
40317 bool set_affect_matte_objects(bool val, double time = TiMe::Default()) { return setValue("affect_matte_objects", val, time); }
40320 bool get_affect_matte_objects(double time = TiMe::Default()) const { return getBool("affect_matte_objects", time); }
40321
40323 bool set_exclude_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list", pluginList, time); }
40324 bool set_exclude_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
40325 template<size_t count> bool set_exclude_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
40327 PluginList get_exclude_list(double time = TiMe::Default()) const { return getPluginList("exclude_list", time); }
40328
40331 bool set_exclude_list_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_as_inclusive_set", val, time); }
40334 bool get_exclude_list_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_as_inclusive_set", time); }
40335
40338 bool set_force_32_bit_output(bool val, double time = TiMe::Default()) { return setValue("force_32_bit_output", val, time); }
40341 bool get_force_32_bit_output(double time = TiMe::Default()) const { return getBool("force_32_bit_output", time); }
40342
40345 bool set_force_lossless_compression(bool val, double time = TiMe::Default()) { return setValue("force_lossless_compression", val, time); }
40348 bool get_force_lossless_compression(double time = TiMe::Default()) const { return getBool("force_lossless_compression", time); }
40349
40353 bool set_default_value(float val, double time = TiMe::Default()) { return setValue("default_value", val, time); }
40357 float get_default_value(double time = TiMe::Default()) const { return getFloat("default_value", time); }
40358};
40359
40362public:
40364 static constexpr const PluginTypeId getTypeId() { return 0x782A5B4A; }
40366 static constexpr const char* getType() { return "RenderChannelExtraTexInt"; }
40367
40368 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40369
40373 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40377 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40378
40381 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40384 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40387 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40388
40391 bool set_texmap(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("texmap", textureint, time); }
40394 bool set_texmap(int textureint, double time = TiMe::Default()) { return setValue("texmap", textureint, time); }
40397 Value get_texmap(double time = TiMe::Default()) const { return getValue("texmap", time); }
40398
40401 bool set_affect_matte_objects(bool val, double time = TiMe::Default()) { return setValue("affect_matte_objects", val, time); }
40404 bool get_affect_matte_objects(double time = TiMe::Default()) const { return getBool("affect_matte_objects", time); }
40405
40407 bool set_exclude_list(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list", pluginList, time); }
40408 bool set_exclude_list(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
40409 template<size_t count> bool set_exclude_list(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list", plugins, count, time); }
40411 PluginList get_exclude_list(double time = TiMe::Default()) const { return getPluginList("exclude_list", time); }
40412
40415 bool set_exclude_list_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_as_inclusive_set", val, time); }
40418 bool get_exclude_list_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_as_inclusive_set", time); }
40419};
40420
40423public:
40425 static constexpr const PluginTypeId getTypeId() { return 0x77FDA274; }
40427 static constexpr const char* getType() { return "RenderChannelGlossiness"; }
40428
40429 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40430
40434 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40438 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40439
40442 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40445 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40448 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40449
40452 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
40455 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
40456
40459 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
40462 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
40463};
40464
40467public:
40469 static constexpr const PluginTypeId getTypeId() { return 0x78581DF7; }
40471 static constexpr const char* getType() { return "RenderChannelInteger"; }
40472
40473 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40474
40478 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40482 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40483
40486 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40489 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40492 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40493
40496 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
40499 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
40500};
40501
40504public:
40506 static constexpr const PluginTypeId getTypeId() { return 0x782B1D79; }
40508 static constexpr const char* getType() { return "RenderChannelInvertedFloat"; }
40509
40510 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40511
40515 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40519 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40520
40523 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40526 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40529 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40530
40533 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
40536 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
40537
40540 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
40543 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
40544};
40545
40548public:
40550 static constexpr const PluginTypeId getTypeId() { return 0x78678A2D; }
40552 static constexpr const char* getType() { return "RenderChannelLightMix"; }
40553
40554 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40555
40558 bool set_create_rest_channel(bool val, double time = TiMe::Default()) { return setValue("create_rest_channel", val, time); }
40561 bool get_create_rest_channel(double time = TiMe::Default()) const { return getBool("create_rest_channel", time); }
40562
40565 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
40568 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
40569
40572 bool set_tag_lightmix(bool val, double time = TiMe::Default()) { return setValue("tag_lightmix", val, time); }
40575 bool get_tag_lightmix(double time = TiMe::Default()) const { return getBool("tag_lightmix", time); }
40576};
40577
40580public:
40582 static constexpr const PluginTypeId getTypeId() { return 0x7857AF39; }
40584 static constexpr const char* getType() { return "RenderChannelLightSelect"; }
40585
40586 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40587
40591 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40595 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40596
40599 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40602 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40605 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40606
40609 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
40612 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
40613
40616 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
40619 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
40620
40624 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
40628 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
40629
40632 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
40635 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
40636
40639 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
40642 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
40643
40646 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
40649 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
40650
40653 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
40656 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
40657
40661 bool set_light_select_mode(int val, double time = TiMe::Default()) { return setValue("light_select_mode", val, time); }
40665 int get_light_select_mode(double time = TiMe::Default()) const { return getInt("light_select_mode", time); }
40666
40670 bool set_light_path_expression(const char* str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
40674 bool set_light_path_expression(const std::string& str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
40678 std::string get_light_path_expression(double time = TiMe::Default()) const { return getString("light_path_expression", time); }
40679
40683 bool set_light_select_matte(bool val, double time = TiMe::Default()) { return setValue("light_select_matte", val, time); }
40687 bool get_light_select_matte(double time = TiMe::Default()) const { return getBool("light_select_matte", time); }
40688
40692 bool set_light_select_in_lightmix(bool val, double time = TiMe::Default()) { return setValue("light_select_in_lightmix", val, time); }
40696 bool get_light_select_in_lightmix(double time = TiMe::Default()) const { return getBool("light_select_in_lightmix", time); }
40697};
40698
40701public:
40703 static constexpr const PluginTypeId getTypeId() { return 0x78499EEB; }
40705 static constexpr const char* getType() { return "RenderChannelLightingAnalysis"; }
40706
40707 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40708
40712 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40716 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40720 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40721
40725 bool set_quantity(int val, double time = TiMe::Default()) { return setValue("quantity", val, time); }
40729 int get_quantity(double time = TiMe::Default()) const { return getInt("quantity", time); }
40730
40734 bool set_min_value(float val, double time = TiMe::Default()) { return setValue("min_value", val, time); }
40738 float get_min_value(double time = TiMe::Default()) const { return getFloat("min_value", time); }
40739
40743 bool set_max_value(float val, double time = TiMe::Default()) { return setValue("max_value", val, time); }
40747 float get_max_value(double time = TiMe::Default()) const { return getFloat("max_value", time); }
40748
40752 bool set_scale(int val, double time = TiMe::Default()) { return setValue("scale", val, time); }
40756 int get_scale(double time = TiMe::Default()) const { return getInt("scale", time); }
40757
40761 bool set_display(int val, double time = TiMe::Default()) { return setValue("display", val, time); }
40765 int get_display(double time = TiMe::Default()) const { return getInt("display", time); }
40766
40770 bool set_grid_horizontal_spacing(int val, double time = TiMe::Default()) { return setValue("grid_horizontal_spacing", val, time); }
40774 int get_grid_horizontal_spacing(double time = TiMe::Default()) const { return getInt("grid_horizontal_spacing", time); }
40775
40779 bool set_grid_vertical_spacing(int val, double time = TiMe::Default()) { return setValue("grid_vertical_spacing", val, time); }
40783 int get_grid_vertical_spacing(double time = TiMe::Default()) const { return getInt("grid_vertical_spacing", time); }
40784
40788 bool set_fade_background_image(bool val, double time = TiMe::Default()) { return setValue("fade_background_image", val, time); }
40792 bool get_fade_background_image(double time = TiMe::Default()) const { return getBool("fade_background_image", time); }
40793
40797 bool set_draw_legend(bool val, double time = TiMe::Default()) { return setValue("draw_legend", val, time); }
40801 bool get_draw_legend(double time = TiMe::Default()) const { return getBool("draw_legend", time); }
40802};
40803
40806public:
40808 static constexpr const PluginTypeId getTypeId() { return 0x7829E44F; }
40810 static constexpr const char* getType() { return "RenderChannelMtlID"; }
40811
40812 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40813
40817 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40821 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40822
40825 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40828 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40831 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40832};
40833
40836public:
40838 static constexpr const PluginTypeId getTypeId() { return 0x77B17F0D; }
40840 static constexpr const char* getType() { return "RenderChannelMultiMatte"; }
40841
40842 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40843
40847 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40851 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40852
40856 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40860 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
40864 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
40865
40869 bool set_red_id(int val, double time = TiMe::Default()) { return setValue("red_id", val, time); }
40873 int get_red_id(double time = TiMe::Default()) const { return getInt("red_id", time); }
40874
40878 bool set_green_id(int val, double time = TiMe::Default()) { return setValue("green_id", val, time); }
40882 int get_green_id(double time = TiMe::Default()) const { return getInt("green_id", time); }
40883
40887 bool set_blue_id(int val, double time = TiMe::Default()) { return setValue("blue_id", val, time); }
40891 int get_blue_id(double time = TiMe::Default()) const { return getInt("blue_id", time); }
40892
40896 bool set_use_mtl_id(bool val, double time = TiMe::Default()) { return setValue("use_mtl_id", val, time); }
40900 bool get_use_mtl_id(double time = TiMe::Default()) const { return getBool("use_mtl_id", time); }
40901
40905 bool set_affect_matte_objects(bool val, double time = TiMe::Default()) { return setValue("affect_matte_objects", val, time); }
40909 bool get_affect_matte_objects(double time = TiMe::Default()) const { return getBool("affect_matte_objects", time); }
40910
40914 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
40918 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
40919
40922 bool set_exclude_list_red(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list_red", pluginList, time); }
40923 bool set_exclude_list_red(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list_red", plugins, count, time); }
40924 template<size_t count> bool set_exclude_list_red(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list_red", plugins, count, time); }
40927 PluginList get_exclude_list_red(double time = TiMe::Default()) const { return getPluginList("exclude_list_red", time); }
40928
40932 bool set_exclude_list_red_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_red_as_inclusive_set", val, time); }
40936 bool get_exclude_list_red_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_red_as_inclusive_set", time); }
40937
40940 bool set_exclude_list_green(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list_green", pluginList, time); }
40941 bool set_exclude_list_green(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list_green", plugins, count, time); }
40942 template<size_t count> bool set_exclude_list_green(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list_green", plugins, count, time); }
40945 PluginList get_exclude_list_green(double time = TiMe::Default()) const { return getPluginList("exclude_list_green", time); }
40946
40950 bool set_exclude_list_green_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_green_as_inclusive_set", val, time); }
40954 bool get_exclude_list_green_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_green_as_inclusive_set", time); }
40955
40958 bool set_exclude_list_blue(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("exclude_list_blue", pluginList, time); }
40959 bool set_exclude_list_blue(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("exclude_list_blue", plugins, count, time); }
40960 template<size_t count> bool set_exclude_list_blue(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("exclude_list_blue", plugins, count, time); }
40963 PluginList get_exclude_list_blue(double time = TiMe::Default()) const { return getPluginList("exclude_list_blue", time); }
40964
40968 bool set_exclude_list_blue_as_inclusive_set(bool val, double time = TiMe::Default()) { return setValue("exclude_list_blue_as_inclusive_set", val, time); }
40972 bool get_exclude_list_blue_as_inclusive_set(double time = TiMe::Default()) const { return getBool("exclude_list_blue_as_inclusive_set", time); }
40973};
40974
40977public:
40979 static constexpr const PluginTypeId getTypeId() { return 0x77D15F35; }
40981 static constexpr const char* getType() { return "RenderChannelNodeID"; }
40982
40983 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
40984
40988 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
40992 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
40993
40996 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
40999 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41002 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41003};
41004
41007public:
41009 static constexpr const PluginTypeId getTypeId() { return 0x7784060B; }
41011 static constexpr const char* getType() { return "RenderChannelNormals"; }
41012
41013 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41014
41018 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41022 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41023
41026 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41029 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41032 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41033
41036 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
41039 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
41040};
41041
41044public:
41046 static constexpr const PluginTypeId getTypeId() { return 0x77CECB71; }
41048 static constexpr const char* getType() { return "RenderChannelObjectSelect"; }
41049
41050 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41051
41054 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41057 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41058
41061 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41064 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41067 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41068
41071 bool set_id(int val, double time = TiMe::Default()) { return setValue("id", val, time); }
41074 int get_id(double time = TiMe::Default()) const { return getInt("id", time); }
41075
41078 bool set_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("ids", intList, time); }
41079 bool set_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("ids", std::move(intList), time); }
41080 bool set_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
41081 template<size_t count> bool set_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
41084 IntList get_ids(double time = TiMe::Default()) const { return getIntList("ids", time); }
41085
41088 bool set_use_mtl_id(bool val, double time = TiMe::Default()) { return setValue("use_mtl_id", val, time); }
41091 bool get_use_mtl_id(double time = TiMe::Default()) const { return getBool("use_mtl_id", time); }
41092
41095 bool set_affect_matte_objects(bool val, double time = TiMe::Default()) { return setValue("affect_matte_objects", val, time); }
41098 bool get_affect_matte_objects(double time = TiMe::Default()) const { return getBool("affect_matte_objects", time); }
41099
41102 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
41105 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
41106
41109 bool set_invert_selection(bool val, double time = TiMe::Default()) { return setValue("invert_selection", val, time); }
41112 bool get_invert_selection(double time = TiMe::Default()) const { return getBool("invert_selection", time); }
41113
41116 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
41119 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
41120
41123 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
41126 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
41127};
41128
41131public:
41133 static constexpr const PluginTypeId getTypeId() { return 0x7784060D; }
41135 static constexpr const char* getType() { return "RenderChannelRenderID"; }
41136
41137 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41138
41142 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41146 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41147
41150 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41153 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41156 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41157};
41158
41161public:
41163 static constexpr const PluginTypeId getTypeId() { return 0x7866F17E; }
41165 static constexpr const char* getType() { return "RenderChannelSheen"; }
41166
41167 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41168
41172 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41176 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41177
41180 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41183 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41186 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41187
41190 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
41193 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
41194
41197 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
41200 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
41201
41205 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
41209 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
41210
41213 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
41216 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
41217
41220 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
41223 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
41224
41227 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
41230 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
41231
41234 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
41237 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
41238
41242 bool set_light_select_mode(int val, double time = TiMe::Default()) { return setValue("light_select_mode", val, time); }
41246 int get_light_select_mode(double time = TiMe::Default()) const { return getInt("light_select_mode", time); }
41247
41251 bool set_light_path_expression(const char* str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
41255 bool set_light_path_expression(const std::string& str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
41259 std::string get_light_path_expression(double time = TiMe::Default()) const { return getString("light_path_expression", time); }
41260
41264 bool set_light_select_matte(bool val, double time = TiMe::Default()) { return setValue("light_select_matte", val, time); }
41268 bool get_light_select_matte(double time = TiMe::Default()) const { return getBool("light_select_matte", time); }
41269
41273 bool set_light_select_in_lightmix(bool val, double time = TiMe::Default()) { return setValue("light_select_in_lightmix", val, time); }
41277 bool get_light_select_in_lightmix(double time = TiMe::Default()) const { return getBool("light_select_in_lightmix", time); }
41278};
41279
41282public:
41284 static constexpr const PluginTypeId getTypeId() { return 0x7866F17F; }
41286 static constexpr const char* getType() { return "RenderChannelSheenReflection"; }
41287
41288 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41289
41293 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41297 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41298
41301 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41304 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41307 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41308
41311 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
41314 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
41315
41318 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
41321 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
41322
41326 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
41330 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
41331
41334 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
41337 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
41338
41341 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
41344 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
41345
41348 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
41351 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
41352
41355 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
41358 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
41359
41363 bool set_light_select_mode(int val, double time = TiMe::Default()) { return setValue("light_select_mode", val, time); }
41367 int get_light_select_mode(double time = TiMe::Default()) const { return getInt("light_select_mode", time); }
41368
41372 bool set_light_path_expression(const char* str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
41376 bool set_light_path_expression(const std::string& str, double time = TiMe::Default()) { return setValue("light_path_expression", str, time); }
41380 std::string get_light_path_expression(double time = TiMe::Default()) const { return getString("light_path_expression", time); }
41381
41385 bool set_light_select_matte(bool val, double time = TiMe::Default()) { return setValue("light_select_matte", val, time); }
41389 bool get_light_select_matte(double time = TiMe::Default()) const { return getBool("light_select_matte", time); }
41390
41394 bool set_light_select_in_lightmix(bool val, double time = TiMe::Default()) { return setValue("light_select_in_lightmix", val, time); }
41398 bool get_light_select_in_lightmix(double time = TiMe::Default()) const { return getBool("light_select_in_lightmix", time); }
41399};
41400
41403public:
41405 static constexpr const PluginTypeId getTypeId() { return 0x783974E9; }
41407 static constexpr const char* getType() { return "RenderChannelToon"; }
41408
41409 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41410
41414 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41418 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41419
41422 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41425 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41428 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41429
41432 bool set_alias(int val, double time = TiMe::Default()) { return setValue("alias", val, time); }
41435 int get_alias(double time = TiMe::Default()) const { return getInt("alias", time); }
41436
41439 bool set_color_mapping(bool val, double time = TiMe::Default()) { return setValue("color_mapping", val, time); }
41442 bool get_color_mapping(double time = TiMe::Default()) const { return getBool("color_mapping", time); }
41443
41447 bool set_consider_for_aa(bool val, double time = TiMe::Default()) { return setValue("consider_for_aa", val, time); }
41451 bool get_consider_for_aa(double time = TiMe::Default()) const { return getBool("consider_for_aa", time); }
41452
41455 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
41458 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
41459
41462 bool set_derive_raw_channels(bool val, double time = TiMe::Default()) { return setValue("derive_raw_channels", val, time); }
41465 bool get_derive_raw_channels(double time = TiMe::Default()) const { return getBool("derive_raw_channels", time); }
41466
41469 bool set_vfb_color_corrections(bool val, double time = TiMe::Default()) { return setValue("vfb_color_corrections", val, time); }
41472 bool get_vfb_color_corrections(double time = TiMe::Default()) const { return getBool("vfb_color_corrections", time); }
41473
41476 bool set_denoise(bool val, double time = TiMe::Default()) { return setValue("denoise", val, time); }
41479 bool get_denoise(double time = TiMe::Default()) const { return getBool("denoise", time); }
41480
41483 bool set_invert_color(bool val, double time = TiMe::Default()) { return setValue("invert_color", val, time); }
41486 bool get_invert_color(double time = TiMe::Default()) const { return getBool("invert_color", time); }
41487};
41488
41491public:
41493 static constexpr const PluginTypeId getTypeId() { return 0x77B37759; }
41495 static constexpr const char* getType() { return "RenderChannelVelocity"; }
41496
41497 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41498
41502 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41506 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41507
41511 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41515 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41519 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41520
41524 bool set_clamp_velocity(bool val, double time = TiMe::Default()) { return setValue("clamp_velocity", val, time); }
41528 bool get_clamp_velocity(double time = TiMe::Default()) const { return getBool("clamp_velocity", time); }
41529
41533 bool set_max_velocity(float val, double time = TiMe::Default()) { return setValue("max_velocity", val, time); }
41537 float get_max_velocity(double time = TiMe::Default()) const { return getFloat("max_velocity", time); }
41538
41542 bool set_max_velocity_last_frame(float val, double time = TiMe::Default()) { return setValue("max_velocity_last_frame", val, time); }
41546 float get_max_velocity_last_frame(double time = TiMe::Default()) const { return getFloat("max_velocity_last_frame", time); }
41547
41551 bool set_ignore_z(bool val, double time = TiMe::Default()) { return setValue("ignore_z", val, time); }
41555 bool get_ignore_z(double time = TiMe::Default()) const { return getBool("ignore_z", time); }
41556
41560 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
41564 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
41565};
41566
41569public:
41571 static constexpr const PluginTypeId getTypeId() { return 0x7784060C; }
41573 static constexpr const char* getType() { return "RenderChannelZDepth"; }
41574
41575 operator RenderChannelPluginCategory() { return *static_cast<RenderChannelPluginCategory*>(static_cast<Plugin*>(this)); }
41576
41580 bool set_enableDeepOutput(bool val, double time = TiMe::Default()) { return setValue("enableDeepOutput", val, time); }
41584 bool get_enableDeepOutput(double time = TiMe::Default()) const { return getBool("enableDeepOutput", time); }
41585
41588 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41591 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41594 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41595
41598 bool set_depth_from_camera(bool val, double time = TiMe::Default()) { return setValue("depth_from_camera", val, time); }
41601 bool get_depth_from_camera(double time = TiMe::Default()) const { return getBool("depth_from_camera", time); }
41602
41605 bool set_depth_raw(bool val, double time = TiMe::Default()) { return setValue("depth_raw", val, time); }
41608 bool get_depth_raw(double time = TiMe::Default()) const { return getBool("depth_raw", time); }
41609
41612 bool set_depth_black(float val, double time = TiMe::Default()) { return setValue("depth_black", val, time); }
41615 float get_depth_black(double time = TiMe::Default()) const { return getFloat("depth_black", time); }
41616
41619 bool set_depth_white(float val, double time = TiMe::Default()) { return setValue("depth_white", val, time); }
41622 float get_depth_white(double time = TiMe::Default()) const { return getFloat("depth_white", time); }
41623
41626 bool set_depth_clamp(bool val, double time = TiMe::Default()) { return setValue("depth_clamp", val, time); }
41629 bool get_depth_clamp(double time = TiMe::Default()) const { return getBool("depth_clamp", time); }
41630
41633 bool set_filtering(bool val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
41636 bool get_filtering(double time = TiMe::Default()) const { return getBool("filtering", time); }
41637
41640 bool set_depth_invert(bool val, double time = TiMe::Default()) { return setValue("depth_invert", val, time); }
41643 bool get_depth_invert(double time = TiMe::Default()) const { return getBool("depth_invert", time); }
41644
41647 bool set_force_infinity_black(bool val, double time = TiMe::Default()) { return setValue("force_infinity_black", val, time); }
41650 bool get_force_infinity_black(double time = TiMe::Default()) const { return getBool("force_infinity_black", time); }
41651
41654 bool set_dont_filter_env(bool val, double time = TiMe::Default()) { return setValue("dont_filter_env", val, time); }
41657 bool get_dont_filter_env(double time = TiMe::Default()) const { return getBool("dont_filter_env", time); }
41658};
41659
41661class RenderView : public Plugin {
41662public:
41664 static constexpr const PluginTypeId getTypeId() { return 0x7773FCF5; }
41666 static constexpr const char* getType() { return "RenderView"; }
41667
41668 operator ViewPluginCategory() { return *static_cast<ViewPluginCategory*>(static_cast<Plugin*>(this)); }
41669
41673 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
41677 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
41678
41682 bool set_fov(float val, double time = TiMe::Default()) { return setValue("fov", val, time); }
41686 float get_fov(double time = TiMe::Default()) const { return getFloat("fov", time); }
41687
41691 bool set_focalDistance(float val, double time = TiMe::Default()) { return setValue("focalDistance", val, time); }
41695 float get_focalDistance(double time = TiMe::Default()) const { return getFloat("focalDistance", time); }
41696
41700 bool set_aperture(float val, double time = TiMe::Default()) { return setValue("aperture", val, time); }
41704 float get_aperture(double time = TiMe::Default()) const { return getFloat("aperture", time); }
41705
41709 bool set_lens_rotation(float val, double time = TiMe::Default()) { return setValue("lens_rotation", val, time); }
41713 float get_lens_rotation(double time = TiMe::Default()) const { return getFloat("lens_rotation", time); }
41714
41718 bool set_frame_samples(int val, double time = TiMe::Default()) { return setValue("frame_samples", val, time); }
41722 int get_frame_samples(double time = TiMe::Default()) const { return getInt("frame_samples", time); }
41723
41727 bool set_clipping(bool val, double time = TiMe::Default()) { return setValue("clipping", val, time); }
41731 bool get_clipping(double time = TiMe::Default()) const { return getBool("clipping", time); }
41732
41736 bool set_clipping_near(float val, double time = TiMe::Default()) { return setValue("clipping_near", val, time); }
41740 float get_clipping_near(double time = TiMe::Default()) const { return getFloat("clipping_near", time); }
41741
41745 bool set_clipping_far(float val, double time = TiMe::Default()) { return setValue("clipping_far", val, time); }
41749 float get_clipping_far(double time = TiMe::Default()) const { return getFloat("clipping_far", time); }
41750
41754 bool set_zoom(float val, double time = TiMe::Default()) { return setValue("zoom", val, time); }
41758 float get_zoom(double time = TiMe::Default()) const { return getFloat("zoom", time); }
41759
41763 bool set_orthographic(bool val, double time = TiMe::Default()) { return setValue("orthographic", val, time); }
41767 bool get_orthographic(double time = TiMe::Default()) const { return getBool("orthographic", time); }
41768
41772 bool set_orthographicWidth(float val, double time = TiMe::Default()) { return setValue("orthographicWidth", val, time); }
41776 float get_orthographicWidth(double time = TiMe::Default()) const { return getFloat("orthographicWidth", time); }
41777
41781 bool set_ortho_adjust_to_scene(bool val, double time = TiMe::Default()) { return setValue("ortho_adjust_to_scene", val, time); }
41785 bool get_ortho_adjust_to_scene(double time = TiMe::Default()) const { return getBool("ortho_adjust_to_scene", time); }
41786
41790 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
41794 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
41795
41799 bool set_use_scene_offset(bool val, double time = TiMe::Default()) { return setValue("use_scene_offset", val, time); }
41803 bool get_use_scene_offset(double time = TiMe::Default()) const { return getBool("use_scene_offset", time); }
41804
41808 bool set_mayaFocalLength(float val, double time = TiMe::Default()) { return setValue("mayaFocalLength", val, time); }
41812 float get_mayaFocalLength(double time = TiMe::Default()) const { return getFloat("mayaFocalLength", time); }
41813
41817 bool set_mayaApperture(float val, double time = TiMe::Default()) { return setValue("mayaApperture", val, time); }
41821 float get_mayaApperture(double time = TiMe::Default()) const { return getFloat("mayaApperture", time); }
41822
41826 bool set_stereo_on(int val, double time = TiMe::Default()) { return setValue("stereo_on", val, time); }
41830 int get_stereo_on(double time = TiMe::Default()) const { return getInt("stereo_on", time); }
41831
41835 bool set_stereo_eye_distance(float val, double time = TiMe::Default()) { return setValue("stereo_eye_distance", val, time); }
41839 float get_stereo_eye_distance(double time = TiMe::Default()) const { return getFloat("stereo_eye_distance", time); }
41840
41844 bool set_stereo_interocular_method(int val, double time = TiMe::Default()) { return setValue("stereo_interocular_method", val, time); }
41848 int get_stereo_interocular_method(double time = TiMe::Default()) const { return getInt("stereo_interocular_method", time); }
41849
41853 bool set_stereo_specify_focus(bool val, double time = TiMe::Default()) { return setValue("stereo_specify_focus", val, time); }
41857 bool get_stereo_specify_focus(double time = TiMe::Default()) const { return getBool("stereo_specify_focus", time); }
41858
41862 bool set_stereo_focus_distance(float val, double time = TiMe::Default()) { return setValue("stereo_focus_distance", val, time); }
41866 float get_stereo_focus_distance(double time = TiMe::Default()) const { return getFloat("stereo_focus_distance", time); }
41867
41871 bool set_stereo_focus_method(int val, double time = TiMe::Default()) { return setValue("stereo_focus_method", val, time); }
41875 int get_stereo_focus_method(double time = TiMe::Default()) const { return getInt("stereo_focus_method", time); }
41876
41880 bool set_stereo_view(int val, double time = TiMe::Default()) { return setValue("stereo_view", val, time); }
41884 int get_stereo_view(double time = TiMe::Default()) const { return getInt("stereo_view", time); }
41885
41889 bool set_stereo_top_merge_angle(float val, double time = TiMe::Default()) { return setValue("stereo_top_merge_angle", val, time); }
41893 float get_stereo_top_merge_angle(double time = TiMe::Default()) const { return getFloat("stereo_top_merge_angle", time); }
41894
41898 bool set_stereo_bottom_merge_angle(float val, double time = TiMe::Default()) { return setValue("stereo_bottom_merge_angle", val, time); }
41902 float get_stereo_bottom_merge_angle(double time = TiMe::Default()) const { return getFloat("stereo_bottom_merge_angle", time); }
41903
41907 bool set_stereo_pole_merge_method(int val, double time = TiMe::Default()) { return setValue("stereo_pole_merge_method", val, time); }
41911 int get_stereo_pole_merge_method(double time = TiMe::Default()) const { return getInt("stereo_pole_merge_method", time); }
41912
41916 bool set_scene_name(const char* str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
41920 bool set_scene_name(const std::string& str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
41924 std::string get_scene_name(double time = TiMe::Default()) const { return getString("scene_name", time); }
41925};
41926
41928class SceneMetadata : public Plugin {
41929public:
41931 static constexpr const PluginTypeId getTypeId() { return 0x78678CBC; }
41933 static constexpr const char* getType() { return "SceneMetadata"; }
41934
41935 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
41936
41938 bool set_name(const char* str, double time = TiMe::Default()) { return setValue("name", str, time); }
41940 bool set_name(const std::string& str, double time = TiMe::Default()) { return setValue("name", str, time); }
41942 std::string get_name(double time = TiMe::Default()) const { return getString("name", time); }
41943
41945 bool set_description(const char* str, double time = TiMe::Default()) { return setValue("description", str, time); }
41947 bool set_description(const std::string& str, double time = TiMe::Default()) { return setValue("description", str, time); }
41949 std::string get_description(double time = TiMe::Default()) const { return getString("description", time); }
41950
41952 bool set_scene_contents(const char* str, double time = TiMe::Default()) { return setValue("scene_contents", str, time); }
41954 bool set_scene_contents(const std::string& str, double time = TiMe::Default()) { return setValue("scene_contents", str, time); }
41956 std::string get_scene_contents(double time = TiMe::Default()) const { return getString("scene_contents", time); }
41957
41959 bool set_category(const StringList& stringList, double time = TiMe::Default()) { return setValue("category", stringList, time); }
41961 StringList get_category(double time = TiMe::Default()) const { return getStringList("category", time); }
41962
41964 bool set_tags(const StringList& stringList, double time = TiMe::Default()) { return setValue("tags", stringList, time); }
41966 StringList get_tags(double time = TiMe::Default()) const { return getStringList("tags", time); }
41967
41969 bool set_preview_images(const StringList& stringList, double time = TiMe::Default()) { return setValue("preview_images", stringList, time); }
41971 StringList get_preview_images(double time = TiMe::Default()) const { return getStringList("preview_images", time); }
41972
41974 bool set_user_attributes(const StringList& stringList, double time = TiMe::Default()) { return setValue("user_attributes", stringList, time); }
41976 StringList get_user_attributes(double time = TiMe::Default()) const { return getStringList("user_attributes", time); }
41977};
41978
41980public:
41982 static constexpr const PluginTypeId getTypeId() { return 0x780CE938; }
41984 static constexpr const char* getType() { return "SceneModifierTest"; }
41985
41989 bool set_particle_scene(const char* str, double time = TiMe::Default()) { return setValue("particle_scene", str, time); }
41993 bool set_particle_scene(const std::string& str, double time = TiMe::Default()) { return setValue("particle_scene", str, time); }
41997 std::string get_particle_scene(double time = TiMe::Default()) const { return getString("particle_scene", time); }
41998
42002 bool set_proxy_scene(const char* str, double time = TiMe::Default()) { return setValue("proxy_scene", str, time); }
42006 bool set_proxy_scene(const std::string& str, double time = TiMe::Default()) { return setValue("proxy_scene", str, time); }
42010 std::string get_proxy_scene(double time = TiMe::Default()) const { return getString("proxy_scene", time); }
42011
42015 bool set_material_scene(const char* str, double time = TiMe::Default()) { return setValue("material_scene", str, time); }
42019 bool set_material_scene(const std::string& str, double time = TiMe::Default()) { return setValue("material_scene", str, time); }
42023 std::string get_material_scene(double time = TiMe::Default()) const { return getString("material_scene", time); }
42024};
42025
42027class SettingsCamera : public Plugin {
42028public:
42030 static constexpr const PluginTypeId getTypeId() { return 0x77834705; }
42032 static constexpr const char* getType() { return "SettingsCamera"; }
42033
42034 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42035
42039 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
42043 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
42044
42048 bool set_height(float val, double time = TiMe::Default()) { return setValue("height", val, time); }
42052 float get_height(double time = TiMe::Default()) const { return getFloat("height", time); }
42053
42057 bool set_dist(float val, double time = TiMe::Default()) { return setValue("dist", val, time); }
42061 float get_dist(double time = TiMe::Default()) const { return getFloat("dist", time); }
42062
42066 bool set_fov(float val, double time = TiMe::Default()) { return setValue("fov", val, time); }
42070 float get_fov(double time = TiMe::Default()) const { return getFloat("fov", time); }
42071
42075 bool set_auto_fit(bool val, double time = TiMe::Default()) { return setValue("auto_fit", val, time); }
42079 bool get_auto_fit(double time = TiMe::Default()) const { return getBool("auto_fit", time); }
42080
42084 bool set_curve(float val, double time = TiMe::Default()) { return setValue("curve", val, time); }
42088 float get_curve(double time = TiMe::Default()) const { return getFloat("curve", time); }
42089
42093 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
42097 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
42098
42101 bool set_image_planes(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("image_planes", plugin, time); }
42104 PluginRef get_image_planes(double time = TiMe::Default()) const { return getPlugin("image_planes", time); }
42105
42109 bool set_auto_corrections_mode(int val, double time = TiMe::Default()) { return setValue("auto_corrections_mode", val, time); }
42113 int get_auto_corrections_mode(double time = TiMe::Default()) const { return getInt("auto_corrections_mode", time); }
42114
42118 bool set_auto_exposure(int val, double time = TiMe::Default()) { return setValue("auto_exposure", val, time); }
42122 int get_auto_exposure(double time = TiMe::Default()) const { return getInt("auto_exposure", time); }
42123
42127 bool set_auto_white_balance(int val, double time = TiMe::Default()) { return setValue("auto_white_balance", val, time); }
42131 int get_auto_white_balance(double time = TiMe::Default()) const { return getInt("auto_white_balance", time); }
42132
42136 bool set_auto_exposure_compensation(float val, double time = TiMe::Default()) { return setValue("auto_exposure_compensation", val, time); }
42140 float get_auto_exposure_compensation(double time = TiMe::Default()) const { return getFloat("auto_exposure_compensation", time); }
42141
42145 bool set_auto_white_balance_sample_accumulation_mode(int val, double time = TiMe::Default()) { return setValue("auto_white_balance_sample_accumulation_mode", val, time); }
42149 int get_auto_white_balance_sample_accumulation_mode(double time = TiMe::Default()) const { return getInt("auto_white_balance_sample_accumulation_mode", time); }
42150
42154 bool set_scene_name(const char* str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
42158 bool set_scene_name(const std::string& str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
42162 std::string get_scene_name(double time = TiMe::Default()) const { return getString("scene_name", time); }
42163
42167 bool set_override_resolution(bool val, double time = TiMe::Default()) { return setValue("override_resolution", val, time); }
42171 bool get_override_resolution(double time = TiMe::Default()) const { return getBool("override_resolution", time); }
42172
42175 bool set_override_width(int val, double time = TiMe::Default()) { return setValue("override_width", val, time); }
42178 int get_override_width(double time = TiMe::Default()) const { return getInt("override_width", time); }
42179
42182 bool set_override_height(int val, double time = TiMe::Default()) { return setValue("override_height", val, time); }
42185 int get_override_height(double time = TiMe::Default()) const { return getInt("override_height", time); }
42186};
42187
42190public:
42192 static constexpr const PluginTypeId getTypeId() { return 0x77834715; }
42194 static constexpr const char* getType() { return "SettingsCameraDof"; }
42195
42196 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42197
42201 bool set_on(bool val, double time = TiMe::Default()) { return setValue("on", val, time); }
42205 bool get_on(double time = TiMe::Default()) const { return getBool("on", time); }
42206
42210 bool set_aperture(float val, double time = TiMe::Default()) { return setValue("aperture", val, time); }
42214 float get_aperture(double time = TiMe::Default()) const { return getFloat("aperture", time); }
42215
42219 bool set_center_bias(float val, double time = TiMe::Default()) { return setValue("center_bias", val, time); }
42223 float get_center_bias(double time = TiMe::Default()) const { return getFloat("center_bias", time); }
42224
42228 bool set_focal_dist(float val, double time = TiMe::Default()) { return setValue("focal_dist", val, time); }
42232 float get_focal_dist(double time = TiMe::Default()) const { return getFloat("focal_dist", time); }
42233
42237 bool set_sides_on(bool val, double time = TiMe::Default()) { return setValue("sides_on", val, time); }
42241 bool get_sides_on(double time = TiMe::Default()) const { return getBool("sides_on", time); }
42242
42246 bool set_sides_num(int val, double time = TiMe::Default()) { return setValue("sides_num", val, time); }
42250 int get_sides_num(double time = TiMe::Default()) const { return getInt("sides_num", time); }
42251
42255 bool set_rotation(float val, double time = TiMe::Default()) { return setValue("rotation", val, time); }
42259 float get_rotation(double time = TiMe::Default()) const { return getFloat("rotation", time); }
42260
42264 bool set_anisotropy(float val, double time = TiMe::Default()) { return setValue("anisotropy", val, time); }
42268 float get_anisotropy(double time = TiMe::Default()) const { return getFloat("anisotropy", time); }
42269
42273 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
42277 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
42278
42282 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
42286 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
42287
42291 bool set_scene_name(const char* str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
42295 bool set_scene_name(const std::string& str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
42299 std::string get_scene_name(double time = TiMe::Default()) const { return getString("scene_name", time); }
42300};
42301
42303class SettingsCaustics : public Plugin {
42304public:
42306 static constexpr const PluginTypeId getTypeId() { return 0x7782D044; }
42308 static constexpr const char* getType() { return "SettingsCaustics"; }
42309
42310 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42311
42315 bool set_on(bool val, double time = TiMe::Default()) { return setValue("on", val, time); }
42319 bool get_on(double time = TiMe::Default()) const { return getBool("on", time); }
42320
42324 bool set_max_photons(int val, double time = TiMe::Default()) { return setValue("max_photons", val, time); }
42328 int get_max_photons(double time = TiMe::Default()) const { return getInt("max_photons", time); }
42329
42333 bool set_search_distance_units(int val, double time = TiMe::Default()) { return setValue("search_distance_units", val, time); }
42337 int get_search_distance_units(double time = TiMe::Default()) const { return getInt("search_distance_units", time); }
42338
42342 bool set_search_distance(float val, double time = TiMe::Default()) { return setValue("search_distance", val, time); }
42346 float get_search_distance(double time = TiMe::Default()) const { return getFloat("search_distance", time); }
42347
42351 bool set_search_distance_pixels(float val, double time = TiMe::Default()) { return setValue("search_distance_pixels", val, time); }
42355 float get_search_distance_pixels(double time = TiMe::Default()) const { return getFloat("search_distance_pixels", time); }
42356
42360 bool set_max_density(float val, double time = TiMe::Default()) { return setValue("max_density", val, time); }
42364 float get_max_density(double time = TiMe::Default()) const { return getFloat("max_density", time); }
42365
42369 bool set_multiplier(float val, double time = TiMe::Default()) { return setValue("multiplier", val, time); }
42373 float get_multiplier(double time = TiMe::Default()) const { return getFloat("multiplier", time); }
42374
42378 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
42382 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
42383
42387 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
42391 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
42395 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
42396
42400 bool set_dont_delete(bool val, double time = TiMe::Default()) { return setValue("dont_delete", val, time); }
42404 bool get_dont_delete(double time = TiMe::Default()) const { return getBool("dont_delete", time); }
42405
42409 bool set_auto_save(bool val, double time = TiMe::Default()) { return setValue("auto_save", val, time); }
42413 bool get_auto_save(double time = TiMe::Default()) const { return getBool("auto_save", time); }
42414
42418 bool set_auto_save_file(const char* str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
42422 bool set_auto_save_file(const std::string& str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
42426 std::string get_auto_save_file(double time = TiMe::Default()) const { return getString("auto_save_file", time); }
42427
42431 bool set_show_calc_phase(bool val, double time = TiMe::Default()) { return setValue("show_calc_phase", val, time); }
42435 bool get_show_calc_phase(double time = TiMe::Default()) const { return getBool("show_calc_phase", time); }
42436};
42437
42440public:
42442 static constexpr const PluginTypeId getTypeId() { return 0x77919BC4; }
42444 static constexpr const char* getType() { return "SettingsColorMapping"; }
42445
42446 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42447
42451 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
42455 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
42456
42460 bool set_affect_background(bool val, double time = TiMe::Default()) { return setValue("affect_background", val, time); }
42464 bool get_affect_background(double time = TiMe::Default()) const { return getBool("affect_background", time); }
42465
42469 bool set_dark_mult(float val, double time = TiMe::Default()) { return setValue("dark_mult", val, time); }
42473 float get_dark_mult(double time = TiMe::Default()) const { return getFloat("dark_mult", time); }
42474
42478 bool set_bright_mult(float val, double time = TiMe::Default()) { return setValue("bright_mult", val, time); }
42482 float get_bright_mult(double time = TiMe::Default()) const { return getFloat("bright_mult", time); }
42483
42487 bool set_gamma(float val, double time = TiMe::Default()) { return setValue("gamma", val, time); }
42491 float get_gamma(double time = TiMe::Default()) const { return getFloat("gamma", time); }
42492
42496 bool set_subpixel_mapping(bool val, double time = TiMe::Default()) { return setValue("subpixel_mapping", val, time); }
42500 bool get_subpixel_mapping(double time = TiMe::Default()) const { return getBool("subpixel_mapping", time); }
42501
42505 bool set_clamp_output(bool val, double time = TiMe::Default()) { return setValue("clamp_output", val, time); }
42509 bool get_clamp_output(double time = TiMe::Default()) const { return getBool("clamp_output", time); }
42510
42514 bool set_clamp_level(float val, double time = TiMe::Default()) { return setValue("clamp_level", val, time); }
42518 float get_clamp_level(double time = TiMe::Default()) const { return getFloat("clamp_level", time); }
42519
42523 bool set_adaptation_only(int val, double time = TiMe::Default()) { return setValue("adaptation_only", val, time); }
42527 int get_adaptation_only(double time = TiMe::Default()) const { return getInt("adaptation_only", time); }
42528
42532 bool set_linearWorkflow(bool val, double time = TiMe::Default()) { return setValue("linearWorkflow", val, time); }
42536 bool get_linearWorkflow(double time = TiMe::Default()) const { return getBool("linearWorkflow", time); }
42537
42541 bool set_exposure(const Color& color, double time = TiMe::Default()) { return setValue("exposure", color, time); }
42545 Color get_exposure(double time = TiMe::Default()) const { return getColor("exposure", time); }
42546};
42547
42550public:
42552 static constexpr const PluginTypeId getTypeId() { return 0x780C2808; }
42554 static constexpr const char* getType() { return "SettingsColorMappingModo"; }
42555
42556 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42557
42561 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
42565 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
42566
42570 bool set_affect_background(bool val, double time = TiMe::Default()) { return setValue("affect_background", val, time); }
42574 bool get_affect_background(double time = TiMe::Default()) const { return getBool("affect_background", time); }
42575
42579 bool set_dark_mult(float val, double time = TiMe::Default()) { return setValue("dark_mult", val, time); }
42583 float get_dark_mult(double time = TiMe::Default()) const { return getFloat("dark_mult", time); }
42584
42588 bool set_bright_mult(float val, double time = TiMe::Default()) { return setValue("bright_mult", val, time); }
42592 float get_bright_mult(double time = TiMe::Default()) const { return getFloat("bright_mult", time); }
42593
42597 bool set_gamma(float val, double time = TiMe::Default()) { return setValue("gamma", val, time); }
42601 float get_gamma(double time = TiMe::Default()) const { return getFloat("gamma", time); }
42602
42606 bool set_subpixel_mapping(bool val, double time = TiMe::Default()) { return setValue("subpixel_mapping", val, time); }
42610 bool get_subpixel_mapping(double time = TiMe::Default()) const { return getBool("subpixel_mapping", time); }
42611
42615 bool set_clamp_output(bool val, double time = TiMe::Default()) { return setValue("clamp_output", val, time); }
42619 bool get_clamp_output(double time = TiMe::Default()) const { return getBool("clamp_output", time); }
42620
42624 bool set_clamp_level(float val, double time = TiMe::Default()) { return setValue("clamp_level", val, time); }
42628 float get_clamp_level(double time = TiMe::Default()) const { return getFloat("clamp_level", time); }
42629
42633 bool set_adaptation_only(int val, double time = TiMe::Default()) { return setValue("adaptation_only", val, time); }
42637 int get_adaptation_only(double time = TiMe::Default()) const { return getInt("adaptation_only", time); }
42638
42642 bool set_linearWorkflow(bool val, double time = TiMe::Default()) { return setValue("linearWorkflow", val, time); }
42646 bool get_linearWorkflow(double time = TiMe::Default()) const { return getBool("linearWorkflow", time); }
42647
42651 bool set_exposure(const Color& color, double time = TiMe::Default()) { return setValue("exposure", color, time); }
42655 Color get_exposure(double time = TiMe::Default()) const { return getColor("exposure", time); }
42656
42660 bool set_multiplier(float val, double time = TiMe::Default()) { return setValue("multiplier", val, time); }
42664 float get_multiplier(double time = TiMe::Default()) const { return getFloat("multiplier", time); }
42665
42669 bool set_inverse_gamma(float val, double time = TiMe::Default()) { return setValue("inverse_gamma", val, time); }
42673 float get_inverse_gamma(double time = TiMe::Default()) const { return getFloat("inverse_gamma", time); }
42674
42678 bool set_reinhard_burn_value(float val, double time = TiMe::Default()) { return setValue("reinhard_burn_value", val, time); }
42682 float get_reinhard_burn_value(double time = TiMe::Default()) const { return getFloat("reinhard_burn_value", time); }
42683};
42684
42687public:
42689 static constexpr const PluginTypeId getTypeId() { return 0x77ED03C5; }
42691 static constexpr const char* getType() { return "SettingsCurrentFrame"; }
42692
42693 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42694
42697 bool set_current_frame(int val, double time = TiMe::Default()) { return setValue("current_frame", val, time); }
42700 int get_current_frame(double time = TiMe::Default()) const { return getInt("current_frame", time); }
42701};
42702
42704class SettingsDMCGI : public Plugin {
42705public:
42707 static constexpr const PluginTypeId getTypeId() { return 0x777476D6; }
42709 static constexpr const char* getType() { return "SettingsDMCGI"; }
42710
42711 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42712
42716 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
42720 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
42721
42725 bool set_depth(int val, double time = TiMe::Default()) { return setValue("depth", val, time); }
42729 int get_depth(double time = TiMe::Default()) const { return getInt("depth", time); }
42730
42734 bool set_adaptivity_prepass(bool val, double time = TiMe::Default()) { return setValue("adaptivity_prepass", val, time); }
42738 bool get_adaptivity_prepass(double time = TiMe::Default()) const { return getBool("adaptivity_prepass", time); }
42739};
42740
42743public:
42745 static constexpr const PluginTypeId getTypeId() { return 0x77828031; }
42747 static constexpr const char* getType() { return "SettingsDMCSampler"; }
42748
42749 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42750
42754 bool set_time_dependent(bool val, double time = TiMe::Default()) { return setValue("time_dependent", val, time); }
42758 bool get_time_dependent(double time = TiMe::Default()) const { return getBool("time_dependent", time); }
42759
42763 bool set_adaptive_amount(float val, double time = TiMe::Default()) { return setValue("adaptive_amount", val, time); }
42767 float get_adaptive_amount(double time = TiMe::Default()) const { return getFloat("adaptive_amount", time); }
42768
42772 bool set_adaptive_threshold(float val, double time = TiMe::Default()) { return setValue("adaptive_threshold", val, time); }
42776 float get_adaptive_threshold(double time = TiMe::Default()) const { return getFloat("adaptive_threshold", time); }
42777
42781 bool set_adaptive_min_samples(int val, double time = TiMe::Default()) { return setValue("adaptive_min_samples", val, time); }
42785 int get_adaptive_min_samples(double time = TiMe::Default()) const { return getInt("adaptive_min_samples", time); }
42786
42790 bool set_subdivs_mult(float val, double time = TiMe::Default()) { return setValue("subdivs_mult", val, time); }
42794 float get_subdivs_mult(double time = TiMe::Default()) const { return getFloat("subdivs_mult", time); }
42795
42799 bool set_random_seed(int val, double time = TiMe::Default()) { return setValue("random_seed", val, time); }
42803 int get_random_seed(double time = TiMe::Default()) const { return getInt("random_seed", time); }
42804
42808 bool set_use_local_subdivs(bool val, double time = TiMe::Default()) { return setValue("use_local_subdivs", val, time); }
42812 bool get_use_local_subdivs(double time = TiMe::Default()) const { return getBool("use_local_subdivs", time); }
42813
42816 bool set_use_blue_noise_optimization(bool val, double time = TiMe::Default()) { return setValue("use_blue_noise_optimization", val, time); }
42819 bool get_use_blue_noise_optimization(double time = TiMe::Default()) const { return getBool("use_blue_noise_optimization", time); }
42820};
42821
42823class SettingsDecal : public Plugin {
42824public:
42826 static constexpr const PluginTypeId getTypeId() { return 0x8DB78CC; }
42828 static constexpr const char* getType() { return "SettingsDecal"; }
42829
42830 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42831
42835 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
42839 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
42840};
42841
42844public:
42846 static constexpr const PluginTypeId getTypeId() { return 0x7791E982; }
42848 static constexpr const char* getType() { return "SettingsDefaultDisplacement"; }
42849
42850 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42851
42855 bool set_override_on(bool val, double time = TiMe::Default()) { return setValue("override_on", val, time); }
42859 bool get_override_on(double time = TiMe::Default()) const { return getBool("override_on", time); }
42860
42864 bool set_edgeLength(float val, double time = TiMe::Default()) { return setValue("edgeLength", val, time); }
42868 float get_edgeLength(double time = TiMe::Default()) const { return getFloat("edgeLength", time); }
42869
42873 bool set_viewDependent(bool val, double time = TiMe::Default()) { return setValue("viewDependent", val, time); }
42877 bool get_viewDependent(double time = TiMe::Default()) const { return getBool("viewDependent", time); }
42878
42882 bool set_maxSubdivs(int val, double time = TiMe::Default()) { return setValue("maxSubdivs", val, time); }
42886 int get_maxSubdivs(double time = TiMe::Default()) const { return getInt("maxSubdivs", time); }
42887
42891 bool set_tightBounds(bool val, double time = TiMe::Default()) { return setValue("tightBounds", val, time); }
42895 bool get_tightBounds(double time = TiMe::Default()) const { return getBool("tightBounds", time); }
42896
42900 bool set_amount(float val, double time = TiMe::Default()) { return setValue("amount", val, time); }
42904 float get_amount(double time = TiMe::Default()) const { return getFloat("amount", time); }
42905
42909 bool set_relative(bool val, double time = TiMe::Default()) { return setValue("relative", val, time); }
42913 bool get_relative(double time = TiMe::Default()) const { return getBool("relative", time); }
42914
42918 bool set_zero_subdivs_optimization(bool val, double time = TiMe::Default()) { return setValue("zero_subdivs_optimization", val, time); }
42922 bool get_zero_subdivs_optimization(double time = TiMe::Default()) const { return getBool("zero_subdivs_optimization", time); }
42923};
42924
42926class SettingsEXR : public Plugin {
42927public:
42929 static constexpr const PluginTypeId getTypeId() { return 0x77A2174E; }
42931 static constexpr const char* getType() { return "SettingsEXR"; }
42932
42933 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
42934
42938 bool set_compression(int val, double time = TiMe::Default()) { return setValue("compression", val, time); }
42942 int get_compression(double time = TiMe::Default()) const { return getInt("compression", time); }
42943
42947 bool set_bits_per_channel(int val, double time = TiMe::Default()) { return setValue("bits_per_channel", val, time); }
42951 int get_bits_per_channel(double time = TiMe::Default()) const { return getInt("bits_per_channel", time); }
42952
42955 bool set_extra_attributes(const char* str, double time = TiMe::Default()) { return setValue("extra_attributes", str, time); }
42958 bool set_extra_attributes(const std::string& str, double time = TiMe::Default()) { return setValue("extra_attributes", str, time); }
42961 std::string get_extra_attributes(double time = TiMe::Default()) const { return getString("extra_attributes", time); }
42962
42966 bool set_auto_data_window(int val, double time = TiMe::Default()) { return setValue("auto_data_window", val, time); }
42970 int get_auto_data_window(double time = TiMe::Default()) const { return getInt("auto_data_window", time); }
42971
42974 bool set_write_integer_ids(bool val, double time = TiMe::Default()) { return setValue("write_integer_ids", val, time); }
42977 bool get_write_integer_ids(double time = TiMe::Default()) const { return getBool("write_integer_ids", time); }
42978
42981 bool set_multipart(bool val, double time = TiMe::Default()) { return setValue("multipart", val, time); }
42984 bool get_multipart(double time = TiMe::Default()) const { return getBool("multipart", time); }
42985
42989 bool set_deep_alpha_colors(int val, double time = TiMe::Default()) { return setValue("deep_alpha_colors", val, time); }
42993 int get_deep_alpha_colors(double time = TiMe::Default()) const { return getInt("deep_alpha_colors", time); }
42994
42996 bool set_display_window(const IntList& intList, double time = TiMe::Default()) { return setValue("display_window", intList, time); }
42997 bool set_display_window(IntList&& intList, double time = TiMe::Default()) { return setValue("display_window", std::move(intList), time); }
42998 bool set_display_window(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("display_window", ints, count, time); }
42999 template<size_t count> bool set_display_window(const int (&ints)[count], double time = TiMe::Default()) { return setArray("display_window", ints, count, time); }
43001 IntList get_display_window(double time = TiMe::Default()) const { return getIntList("display_window", time); }
43002
43004 bool set_data_window_offset(const IntList& intList, double time = TiMe::Default()) { return setValue("data_window_offset", intList, time); }
43005 bool set_data_window_offset(IntList&& intList, double time = TiMe::Default()) { return setValue("data_window_offset", std::move(intList), time); }
43006 bool set_data_window_offset(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("data_window_offset", ints, count, time); }
43007 template<size_t count> bool set_data_window_offset(const int (&ints)[count], double time = TiMe::Default()) { return setArray("data_window_offset", ints, count, time); }
43009 IntList get_data_window_offset(double time = TiMe::Default()) const { return getIntList("data_window_offset", time); }
43010};
43011
43014public:
43016 static constexpr const PluginTypeId getTypeId() { return 0x778236C1; }
43018 static constexpr const char* getType() { return "SettingsEnvironment"; }
43019
43020 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43021
43025 bool set_bg_color(const Color& color, double time = TiMe::Default()) { return setValue("bg_color", color, time); }
43029 Color get_bg_color(double time = TiMe::Default()) const { return getColor("bg_color", time); }
43030
43033 bool set_bg_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bg_tex", texture, time); }
43036 bool set_bg_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("bg_tex", texture, time); }
43039 Value get_bg_tex(double time = TiMe::Default()) const { return getValue("bg_tex", time); }
43040
43044 bool set_bg_tex_mult(float val, double time = TiMe::Default()) { return setValue("bg_tex_mult", val, time); }
43048 float get_bg_tex_mult(double time = TiMe::Default()) const { return getFloat("bg_tex_mult", time); }
43049
43053 bool set_gi_color(const Color& color, double time = TiMe::Default()) { return setValue("gi_color", color, time); }
43057 Color get_gi_color(double time = TiMe::Default()) const { return getColor("gi_color", time); }
43058
43061 bool set_gi_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("gi_tex", texture, time); }
43064 bool set_gi_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("gi_tex", texture, time); }
43067 Value get_gi_tex(double time = TiMe::Default()) const { return getValue("gi_tex", time); }
43068
43072 bool set_gi_tex_mult(float val, double time = TiMe::Default()) { return setValue("gi_tex_mult", val, time); }
43076 float get_gi_tex_mult(double time = TiMe::Default()) const { return getFloat("gi_tex_mult", time); }
43077
43081 bool set_reflect_color(const Color& color, double time = TiMe::Default()) { return setValue("reflect_color", color, time); }
43085 Color get_reflect_color(double time = TiMe::Default()) const { return getColor("reflect_color", time); }
43086
43089 bool set_reflect_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("reflect_tex", texture, time); }
43092 bool set_reflect_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("reflect_tex", texture, time); }
43095 Value get_reflect_tex(double time = TiMe::Default()) const { return getValue("reflect_tex", time); }
43096
43100 bool set_reflect_tex_mult(float val, double time = TiMe::Default()) { return setValue("reflect_tex_mult", val, time); }
43104 float get_reflect_tex_mult(double time = TiMe::Default()) const { return getFloat("reflect_tex_mult", time); }
43105
43109 bool set_refract_color(const Color& color, double time = TiMe::Default()) { return setValue("refract_color", color, time); }
43113 Color get_refract_color(double time = TiMe::Default()) const { return getColor("refract_color", time); }
43114
43117 bool set_refract_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("refract_tex", texture, time); }
43120 bool set_refract_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("refract_tex", texture, time); }
43123 Value get_refract_tex(double time = TiMe::Default()) const { return getValue("refract_tex", time); }
43124
43128 bool set_refract_tex_mult(float val, double time = TiMe::Default()) { return setValue("refract_tex_mult", val, time); }
43132 float get_refract_tex_mult(double time = TiMe::Default()) const { return getFloat("refract_tex_mult", time); }
43133
43137 bool set_secondary_matte_color(const Color& color, double time = TiMe::Default()) { return setValue("secondary_matte_color", color, time); }
43141 Color get_secondary_matte_color(double time = TiMe::Default()) const { return getColor("secondary_matte_color", time); }
43142
43145 bool set_secondary_matte_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("secondary_matte_tex", texture, time); }
43148 bool set_secondary_matte_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("secondary_matte_tex", texture, time); }
43151 Value get_secondary_matte_tex(double time = TiMe::Default()) const { return getValue("secondary_matte_tex", time); }
43152
43156 bool set_secondary_matte_tex_mult(float val, double time = TiMe::Default()) { return setValue("secondary_matte_tex_mult", val, time); }
43160 float get_secondary_matte_tex_mult(double time = TiMe::Default()) const { return getFloat("secondary_matte_tex_mult", time); }
43161
43163 bool set_environment_volume(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("environment_volume", pluginList, time); }
43164 bool set_environment_volume(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("environment_volume", plugins, count, time); }
43165 template<size_t count> bool set_environment_volume(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("environment_volume", plugins, count, time); }
43167 PluginList get_environment_volume(double time = TiMe::Default()) const { return getPluginList("environment_volume", time); }
43168
43171 bool set_num_environment_objects(int val, double time = TiMe::Default()) { return setValue("num_environment_objects", val, time); }
43174 int get_num_environment_objects(double time = TiMe::Default()) const { return getInt("num_environment_objects", time); }
43175
43178 bool set_global_light_level(const Color& color, double time = TiMe::Default()) { return setValue("global_light_level", color, time); }
43181 Color get_global_light_level(double time = TiMe::Default()) const { return getColor("global_light_level", time); }
43182
43186 bool set_use_bg(bool val, double time = TiMe::Default()) { return setValue("use_bg", val, time); }
43190 bool get_use_bg(double time = TiMe::Default()) const { return getBool("use_bg", time); }
43191
43195 bool set_use_gi(bool val, double time = TiMe::Default()) { return setValue("use_gi", val, time); }
43199 bool get_use_gi(double time = TiMe::Default()) const { return getBool("use_gi", time); }
43200
43204 bool set_use_reflect(bool val, double time = TiMe::Default()) { return setValue("use_reflect", val, time); }
43208 bool get_use_reflect(double time = TiMe::Default()) const { return getBool("use_reflect", time); }
43209
43213 bool set_use_refract(bool val, double time = TiMe::Default()) { return setValue("use_refract", val, time); }
43217 bool get_use_refract(double time = TiMe::Default()) const { return getBool("use_refract", time); }
43218
43222 bool set_use_secondary_matte(bool val, double time = TiMe::Default()) { return setValue("use_secondary_matte", val, time); }
43226 bool get_use_secondary_matte(double time = TiMe::Default()) const { return getBool("use_secondary_matte", time); }
43227};
43228
43230class SettingsGI : public Plugin {
43231public:
43233 static constexpr const PluginTypeId getTypeId() { return 0x77747685; }
43235 static constexpr const char* getType() { return "SettingsGI"; }
43236
43237 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43238
43242 bool set_on(bool val, double time = TiMe::Default()) { return setValue("on", val, time); }
43246 bool get_on(double time = TiMe::Default()) const { return getBool("on", time); }
43247
43251 bool set_refract_caustics(bool val, double time = TiMe::Default()) { return setValue("refract_caustics", val, time); }
43255 bool get_refract_caustics(double time = TiMe::Default()) const { return getBool("refract_caustics", time); }
43256
43260 bool set_reflect_caustics(int val, double time = TiMe::Default()) { return setValue("reflect_caustics", val, time); }
43264 int get_reflect_caustics(double time = TiMe::Default()) const { return getInt("reflect_caustics", time); }
43265
43269 bool set_saturation(float val, double time = TiMe::Default()) { return setValue("saturation", val, time); }
43273 float get_saturation(double time = TiMe::Default()) const { return getFloat("saturation", time); }
43274
43278 bool set_contrast(float val, double time = TiMe::Default()) { return setValue("contrast", val, time); }
43282 float get_contrast(double time = TiMe::Default()) const { return getFloat("contrast", time); }
43283
43287 bool set_contrast_base(float val, double time = TiMe::Default()) { return setValue("contrast_base", val, time); }
43291 float get_contrast_base(double time = TiMe::Default()) const { return getFloat("contrast_base", time); }
43292
43296 bool set_primary_engine(int val, double time = TiMe::Default()) { return setValue("primary_engine", val, time); }
43300 int get_primary_engine(double time = TiMe::Default()) const { return getInt("primary_engine", time); }
43301
43305 bool set_primary_multiplier(float val, double time = TiMe::Default()) { return setValue("primary_multiplier", val, time); }
43309 float get_primary_multiplier(double time = TiMe::Default()) const { return getFloat("primary_multiplier", time); }
43310
43314 bool set_secondary_engine(int val, double time = TiMe::Default()) { return setValue("secondary_engine", val, time); }
43318 int get_secondary_engine(double time = TiMe::Default()) const { return getInt("secondary_engine", time); }
43319
43323 bool set_secondary_multiplier(float val, double time = TiMe::Default()) { return setValue("secondary_multiplier", val, time); }
43327 float get_secondary_multiplier(double time = TiMe::Default()) const { return getFloat("secondary_multiplier", time); }
43328
43332 bool set_ray_distance_on(bool val, double time = TiMe::Default()) { return setValue("ray_distance_on", val, time); }
43336 bool get_ray_distance_on(double time = TiMe::Default()) const { return getBool("ray_distance_on", time); }
43337
43341 bool set_ray_distance(float val, double time = TiMe::Default()) { return setValue("ray_distance", val, time); }
43345 float get_ray_distance(double time = TiMe::Default()) const { return getFloat("ray_distance", time); }
43346
43350 bool set_ao_on(bool val, double time = TiMe::Default()) { return setValue("ao_on", val, time); }
43354 bool get_ao_on(double time = TiMe::Default()) const { return getBool("ao_on", time); }
43355
43359 bool set_ao_amount(float val, double time = TiMe::Default()) { return setValue("ao_amount", val, time); }
43363 float get_ao_amount(double time = TiMe::Default()) const { return getFloat("ao_amount", time); }
43364
43368 bool set_ao_radius(float val, double time = TiMe::Default()) { return setValue("ao_radius", val, time); }
43372 float get_ao_radius(double time = TiMe::Default()) const { return getFloat("ao_radius", time); }
43373
43377 bool set_ao_subdivs(int val, double time = TiMe::Default()) { return setValue("ao_subdivs", val, time); }
43381 int get_ao_subdivs(double time = TiMe::Default()) const { return getInt("ao_subdivs", time); }
43382};
43383
43386public:
43388 static constexpr const PluginTypeId getTypeId() { return 0x78A4B9EC; }
43390 static constexpr const char* getType() { return "SettingsGaussianSplats"; }
43391
43392 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43393
43397 bool set_decodeFromSRGB(bool val, double time = TiMe::Default()) { return setValue("decodeFromSRGB", val, time); }
43401 bool get_decodeFromSRGB(double time = TiMe::Default()) const { return getBool("decodeFromSRGB", time); }
43402
43406 bool set_filtering(float val, double time = TiMe::Default()) { return setValue("filtering", val, time); }
43410 float get_filtering(double time = TiMe::Default()) const { return getFloat("filtering", time); }
43411};
43412
43414class SettingsHair : public Plugin {
43415public:
43417 static constexpr const PluginTypeId getTypeId() { return 0x782A84F5; }
43419 static constexpr const char* getType() { return "SettingsHair"; }
43420
43421 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43422
43425 bool set_min_hair_width(float val, double time = TiMe::Default()) { return setValue("min_hair_width", val, time); }
43428 float get_min_hair_width(double time = TiMe::Default()) const { return getFloat("min_hair_width", time); }
43429};
43430
43433public:
43435 static constexpr const PluginTypeId getTypeId() { return 0x7774767A; }
43437 static constexpr const char* getType() { return "SettingsImageSampler"; }
43438
43439 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43440
43444 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
43448 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
43449
43453 bool set_min_shade_rate(int val, double time = TiMe::Default()) { return setValue("min_shade_rate", val, time); }
43457 int get_min_shade_rate(double time = TiMe::Default()) const { return getInt("min_shade_rate", time); }
43458
43462 bool set_fixed_subdivs(int val, double time = TiMe::Default()) { return setValue("fixed_subdivs", val, time); }
43466 int get_fixed_subdivs(double time = TiMe::Default()) const { return getInt("fixed_subdivs", time); }
43467
43471 bool set_fixed_per_pixel_filtering(bool val, double time = TiMe::Default()) { return setValue("fixed_per_pixel_filtering", val, time); }
43475 bool get_fixed_per_pixel_filtering(double time = TiMe::Default()) const { return getBool("fixed_per_pixel_filtering", time); }
43476
43480 bool set_dmc_minSubdivs(int val, double time = TiMe::Default()) { return setValue("dmc_minSubdivs", val, time); }
43484 int get_dmc_minSubdivs(double time = TiMe::Default()) const { return getInt("dmc_minSubdivs", time); }
43485
43489 bool set_dmc_maxSubdivs(int val, double time = TiMe::Default()) { return setValue("dmc_maxSubdivs", val, time); }
43493 int get_dmc_maxSubdivs(double time = TiMe::Default()) const { return getInt("dmc_maxSubdivs", time); }
43494
43498 bool set_dmc_threshold(float val, double time = TiMe::Default()) { return setValue("dmc_threshold", val, time); }
43502 float get_dmc_threshold(double time = TiMe::Default()) const { return getFloat("dmc_threshold", time); }
43503
43507 bool set_dmc_per_pixel_filtering(bool val, double time = TiMe::Default()) { return setValue("dmc_per_pixel_filtering", val, time); }
43511 bool get_dmc_per_pixel_filtering(double time = TiMe::Default()) const { return getBool("dmc_per_pixel_filtering", time); }
43512
43516 bool set_dmc_adaptivity_clamp(float val, double time = TiMe::Default()) { return setValue("dmc_adaptivity_clamp", val, time); }
43520 float get_dmc_adaptivity_clamp(double time = TiMe::Default()) const { return getFloat("dmc_adaptivity_clamp", time); }
43521
43524 bool set_dmc_fireflyRemoval(float val, double time = TiMe::Default()) { return setValue("dmc_fireflyRemoval", val, time); }
43527 float get_dmc_fireflyRemoval(double time = TiMe::Default()) const { return getFloat("dmc_fireflyRemoval", time); }
43528
43532 bool set_subdivision_minRate(int val, double time = TiMe::Default()) { return setValue("subdivision_minRate", val, time); }
43536 int get_subdivision_minRate(double time = TiMe::Default()) const { return getInt("subdivision_minRate", time); }
43537
43541 bool set_subdivision_maxRate(int val, double time = TiMe::Default()) { return setValue("subdivision_maxRate", val, time); }
43545 int get_subdivision_maxRate(double time = TiMe::Default()) const { return getInt("subdivision_maxRate", time); }
43546
43550 bool set_subdivision_jitter(bool val, double time = TiMe::Default()) { return setValue("subdivision_jitter", val, time); }
43554 bool get_subdivision_jitter(double time = TiMe::Default()) const { return getBool("subdivision_jitter", time); }
43555
43559 bool set_subdivision_threshold(float val, double time = TiMe::Default()) { return setValue("subdivision_threshold", val, time); }
43563 float get_subdivision_threshold(double time = TiMe::Default()) const { return getFloat("subdivision_threshold", time); }
43564
43568 bool set_subdivision_edges(bool val, double time = TiMe::Default()) { return setValue("subdivision_edges", val, time); }
43572 bool get_subdivision_edges(double time = TiMe::Default()) const { return getBool("subdivision_edges", time); }
43573
43577 bool set_subdivision_normals(bool val, double time = TiMe::Default()) { return setValue("subdivision_normals", val, time); }
43581 bool get_subdivision_normals(double time = TiMe::Default()) const { return getBool("subdivision_normals", time); }
43582
43586 bool set_subdivision_normals_threshold(float val, double time = TiMe::Default()) { return setValue("subdivision_normals_threshold", val, time); }
43590 float get_subdivision_normals_threshold(double time = TiMe::Default()) const { return getFloat("subdivision_normals_threshold", time); }
43591
43595 bool set_progressive_minSubdivs(int val, double time = TiMe::Default()) { return setValue("progressive_minSubdivs", val, time); }
43599 int get_progressive_minSubdivs(double time = TiMe::Default()) const { return getInt("progressive_minSubdivs", time); }
43600
43604 bool set_progressive_maxSubdivs(int val, double time = TiMe::Default()) { return setValue("progressive_maxSubdivs", val, time); }
43608 int get_progressive_maxSubdivs(double time = TiMe::Default()) const { return getInt("progressive_maxSubdivs", time); }
43609
43613 bool set_progressive_threshold(float val, double time = TiMe::Default()) { return setValue("progressive_threshold", val, time); }
43617 float get_progressive_threshold(double time = TiMe::Default()) const { return getFloat("progressive_threshold", time); }
43618
43622 bool set_progressive_maxTime(float val, double time = TiMe::Default()) { return setValue("progressive_maxTime", val, time); }
43626 float get_progressive_maxTime(double time = TiMe::Default()) const { return getFloat("progressive_maxTime", time); }
43627
43631 bool set_progressive_bundleSize(int val, double time = TiMe::Default()) { return setValue("progressive_bundleSize", val, time); }
43635 int get_progressive_bundleSize(double time = TiMe::Default()) const { return getInt("progressive_bundleSize", time); }
43636
43640 bool set_progressive_showMask(bool val, double time = TiMe::Default()) { return setValue("progressive_showMask", val, time); }
43644 bool get_progressive_showMask(double time = TiMe::Default()) const { return getBool("progressive_showMask", time); }
43645
43649 bool set_progressive_progNoiseThreshold(int val, double time = TiMe::Default()) { return setValue("progressive_progNoiseThreshold", val, time); }
43653 int get_progressive_progNoiseThreshold(double time = TiMe::Default()) const { return getInt("progressive_progNoiseThreshold", time); }
43654
43658 bool set_progressive_effectsUpdate(int val, double time = TiMe::Default()) { return setValue("progressive_effectsUpdate", val, time); }
43662 int get_progressive_effectsUpdate(double time = TiMe::Default()) const { return getInt("progressive_effectsUpdate", time); }
43663
43667 bool set_render_mask_mode(int val, double time = TiMe::Default()) { return setValue("render_mask_mode", val, time); }
43671 int get_render_mask_mode(double time = TiMe::Default()) const { return getInt("render_mask_mode", time); }
43672
43676 bool set_render_mask_texture(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("render_mask_texture", texturefloat, time); }
43680 bool set_render_mask_texture(float texturefloat, double time = TiMe::Default()) { return setValue("render_mask_texture", texturefloat, time); }
43684 Value get_render_mask_texture(double time = TiMe::Default()) const { return getValue("render_mask_texture", time); }
43685
43688 bool set_render_mask_objects(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("render_mask_objects", pluginList, time); }
43689 bool set_render_mask_objects(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("render_mask_objects", plugins, count, time); }
43690 template<size_t count> bool set_render_mask_objects(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("render_mask_objects", plugins, count, time); }
43693 PluginList get_render_mask_objects(double time = TiMe::Default()) const { return getPluginList("render_mask_objects", time); }
43694
43698 bool set_render_mask_object_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("render_mask_object_ids", intList, time); }
43699 bool set_render_mask_object_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("render_mask_object_ids", std::move(intList), time); }
43700 bool set_render_mask_object_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("render_mask_object_ids", ints, count, time); }
43701 template<size_t count> bool set_render_mask_object_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("render_mask_object_ids", ints, count, time); }
43705 IntList get_render_mask_object_ids(double time = TiMe::Default()) const { return getIntList("render_mask_object_ids", time); }
43706
43710 bool set_render_mask_clear(int val, double time = TiMe::Default()) { return setValue("render_mask_clear", val, time); }
43714 int get_render_mask_clear(double time = TiMe::Default()) const { return getInt("render_mask_clear", time); }
43715
43719 bool set_progressive_autoswitch_effectsresult(bool val, double time = TiMe::Default()) { return setValue("progressive_autoswitch_effectsresult", val, time); }
43723 bool get_progressive_autoswitch_effectsresult(double time = TiMe::Default()) const { return getBool("progressive_autoswitch_effectsresult", time); }
43724};
43725
43728public:
43730 static constexpr const PluginTypeId getTypeId() { return 0x777476D5; }
43732 static constexpr const char* getType() { return "SettingsIrradianceMap"; }
43733
43734 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43735
43739 bool set_min_rate(int val, double time = TiMe::Default()) { return setValue("min_rate", val, time); }
43743 int get_min_rate(double time = TiMe::Default()) const { return getInt("min_rate", time); }
43744
43748 bool set_max_rate(int val, double time = TiMe::Default()) { return setValue("max_rate", val, time); }
43752 int get_max_rate(double time = TiMe::Default()) const { return getInt("max_rate", time); }
43753
43757 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
43761 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
43762
43766 bool set_interp_samples(int val, double time = TiMe::Default()) { return setValue("interp_samples", val, time); }
43770 int get_interp_samples(double time = TiMe::Default()) const { return getInt("interp_samples", time); }
43771
43775 bool set_calc_interp_samples(int val, double time = TiMe::Default()) { return setValue("calc_interp_samples", val, time); }
43779 int get_calc_interp_samples(double time = TiMe::Default()) const { return getInt("calc_interp_samples", time); }
43780
43784 bool set_interp_frames(int val, double time = TiMe::Default()) { return setValue("interp_frames", val, time); }
43788 int get_interp_frames(double time = TiMe::Default()) const { return getInt("interp_frames", time); }
43789
43793 bool set_color_threshold(float val, double time = TiMe::Default()) { return setValue("color_threshold", val, time); }
43797 float get_color_threshold(double time = TiMe::Default()) const { return getFloat("color_threshold", time); }
43798
43802 bool set_normal_threshold(float val, double time = TiMe::Default()) { return setValue("normal_threshold", val, time); }
43806 float get_normal_threshold(double time = TiMe::Default()) const { return getFloat("normal_threshold", time); }
43807
43811 bool set_distance_threshold(float val, double time = TiMe::Default()) { return setValue("distance_threshold", val, time); }
43815 float get_distance_threshold(double time = TiMe::Default()) const { return getFloat("distance_threshold", time); }
43816
43820 bool set_detail_enhancement(bool val, double time = TiMe::Default()) { return setValue("detail_enhancement", val, time); }
43824 bool get_detail_enhancement(double time = TiMe::Default()) const { return getBool("detail_enhancement", time); }
43825
43829 bool set_detail_radius(float val, double time = TiMe::Default()) { return setValue("detail_radius", val, time); }
43833 float get_detail_radius(double time = TiMe::Default()) const { return getFloat("detail_radius", time); }
43834
43838 bool set_detail_subdivs_mult(float val, double time = TiMe::Default()) { return setValue("detail_subdivs_mult", val, time); }
43842 float get_detail_subdivs_mult(double time = TiMe::Default()) const { return getFloat("detail_subdivs_mult", time); }
43843
43847 bool set_detail_scale(int val, double time = TiMe::Default()) { return setValue("detail_scale", val, time); }
43851 int get_detail_scale(double time = TiMe::Default()) const { return getInt("detail_scale", time); }
43852
43856 bool set_randomize_samples(bool val, double time = TiMe::Default()) { return setValue("randomize_samples", val, time); }
43860 bool get_randomize_samples(double time = TiMe::Default()) const { return getBool("randomize_samples", time); }
43861
43865 bool set_interpolation_mode(int val, double time = TiMe::Default()) { return setValue("interpolation_mode", val, time); }
43869 int get_interpolation_mode(double time = TiMe::Default()) const { return getInt("interpolation_mode", time); }
43870
43874 bool set_lookup_mode(int val, double time = TiMe::Default()) { return setValue("lookup_mode", val, time); }
43878 int get_lookup_mode(double time = TiMe::Default()) const { return getInt("lookup_mode", time); }
43879
43883 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
43887 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
43888
43892 bool set_dont_delete(bool val, double time = TiMe::Default()) { return setValue("dont_delete", val, time); }
43896 bool get_dont_delete(double time = TiMe::Default()) const { return getBool("dont_delete", time); }
43897
43901 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
43905 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
43909 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
43910
43914 bool set_show_samples(bool val, double time = TiMe::Default()) { return setValue("show_samples", val, time); }
43918 bool get_show_samples(double time = TiMe::Default()) const { return getBool("show_samples", time); }
43919
43923 bool set_show_calc_phase(bool val, double time = TiMe::Default()) { return setValue("show_calc_phase", val, time); }
43927 bool get_show_calc_phase(double time = TiMe::Default()) const { return getBool("show_calc_phase", time); }
43928
43932 bool set_show_direct_light(bool val, double time = TiMe::Default()) { return setValue("show_direct_light", val, time); }
43936 bool get_show_direct_light(double time = TiMe::Default()) const { return getBool("show_direct_light", time); }
43937
43941 bool set_multiple_views(bool val, double time = TiMe::Default()) { return setValue("multiple_views", val, time); }
43945 bool get_multiple_views(double time = TiMe::Default()) const { return getBool("multiple_views", time); }
43946
43950 bool set_multipass(bool val, double time = TiMe::Default()) { return setValue("multipass", val, time); }
43954 bool get_multipass(double time = TiMe::Default()) const { return getBool("multipass", time); }
43955
43959 bool set_check_sample_visibility(bool val, double time = TiMe::Default()) { return setValue("check_sample_visibility", val, time); }
43963 bool get_check_sample_visibility(double time = TiMe::Default()) const { return getBool("check_sample_visibility", time); }
43964
43968 bool set_auto_save(bool val, double time = TiMe::Default()) { return setValue("auto_save", val, time); }
43972 bool get_auto_save(double time = TiMe::Default()) const { return getBool("auto_save", time); }
43973
43977 bool set_auto_save_file(const char* str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
43981 bool set_auto_save_file(const std::string& str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
43985 std::string get_auto_save_file(double time = TiMe::Default()) const { return getString("auto_save_file", time); }
43986};
43987
43989class SettingsJPEG : public Plugin {
43990public:
43992 static constexpr const PluginTypeId getTypeId() { return 0x77A21752; }
43994 static constexpr const char* getType() { return "SettingsJPEG"; }
43995
43996 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
43997
44001 bool set_quality(int val, double time = TiMe::Default()) { return setValue("quality", val, time); }
44005 int get_quality(double time = TiMe::Default()) const { return getInt("quality", time); }
44006};
44007
44010public:
44012 static constexpr const PluginTypeId getTypeId() { return 0x777476D7; }
44014 static constexpr const char* getType() { return "SettingsLightCache"; }
44015
44016 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
44017
44021 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
44025 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
44026
44030 bool set_sample_size(float val, double time = TiMe::Default()) { return setValue("sample_size", val, time); }
44034 float get_sample_size(double time = TiMe::Default()) const { return getFloat("sample_size", time); }
44035
44039 bool set_filter_type(int val, double time = TiMe::Default()) { return setValue("filter_type", val, time); }
44043 int get_filter_type(double time = TiMe::Default()) const { return getInt("filter_type", time); }
44044
44048 bool set_filter_samples(int val, double time = TiMe::Default()) { return setValue("filter_samples", val, time); }
44052 int get_filter_samples(double time = TiMe::Default()) const { return getInt("filter_samples", time); }
44053
44057 bool set_filter_size(float val, double time = TiMe::Default()) { return setValue("filter_size", val, time); }
44061 float get_filter_size(double time = TiMe::Default()) const { return getFloat("filter_size", time); }
44062
44066 bool set_prefilter(bool val, double time = TiMe::Default()) { return setValue("prefilter", val, time); }
44070 bool get_prefilter(double time = TiMe::Default()) const { return getBool("prefilter", time); }
44071
44075 bool set_prefilter_samples(int val, double time = TiMe::Default()) { return setValue("prefilter_samples", val, time); }
44079 int get_prefilter_samples(double time = TiMe::Default()) const { return getInt("prefilter_samples", time); }
44080
44084 bool set_depth(int val, double time = TiMe::Default()) { return setValue("depth", val, time); }
44088 int get_depth(double time = TiMe::Default()) const { return getInt("depth", time); }
44089
44093 bool set_show_calc_phase(bool val, double time = TiMe::Default()) { return setValue("show_calc_phase", val, time); }
44097 bool get_show_calc_phase(double time = TiMe::Default()) const { return getBool("show_calc_phase", time); }
44098
44102 bool set_store_direct_light(bool val, double time = TiMe::Default()) { return setValue("store_direct_light", val, time); }
44106 bool get_store_direct_light(double time = TiMe::Default()) const { return getBool("store_direct_light", time); }
44107
44111 bool set_world_scale(bool val, double time = TiMe::Default()) { return setValue("world_scale", val, time); }
44115 bool get_world_scale(double time = TiMe::Default()) const { return getBool("world_scale", time); }
44116
44120 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
44124 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
44125
44129 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
44133 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
44137 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
44138
44142 bool set_dont_delete(bool val, double time = TiMe::Default()) { return setValue("dont_delete", val, time); }
44146 bool get_dont_delete(double time = TiMe::Default()) const { return getBool("dont_delete", time); }
44147
44151 bool set_auto_save(bool val, double time = TiMe::Default()) { return setValue("auto_save", val, time); }
44155 bool get_auto_save(double time = TiMe::Default()) const { return getBool("auto_save", time); }
44156
44160 bool set_auto_save_file(const char* str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
44164 bool set_auto_save_file(const std::string& str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
44168 std::string get_auto_save_file(double time = TiMe::Default()) const { return getString("auto_save_file", time); }
44169
44173 bool set_num_passes(int val, double time = TiMe::Default()) { return setValue("num_passes", val, time); }
44177 int get_num_passes(double time = TiMe::Default()) const { return getInt("num_passes", time); }
44178
44182 bool set_use_for_glossy_rays(bool val, double time = TiMe::Default()) { return setValue("use_for_glossy_rays", val, time); }
44186 bool get_use_for_glossy_rays(double time = TiMe::Default()) const { return getBool("use_for_glossy_rays", time); }
44187
44191 bool set_adaptive_sampling(bool val, double time = TiMe::Default()) { return setValue("adaptive_sampling", val, time); }
44195 bool get_adaptive_sampling(double time = TiMe::Default()) const { return getBool("adaptive_sampling", time); }
44196
44200 bool set_premultiplied(bool val, double time = TiMe::Default()) { return setValue("premultiplied", val, time); }
44204 bool get_premultiplied(double time = TiMe::Default()) const { return getBool("premultiplied", time); }
44205
44209 bool set_multiple_views(bool val, double time = TiMe::Default()) { return setValue("multiple_views", val, time); }
44213 bool get_multiple_views(double time = TiMe::Default()) const { return getBool("multiple_views", time); }
44214
44218 bool set_retrace_enabled(bool val, double time = TiMe::Default()) { return setValue("retrace_enabled", val, time); }
44222 bool get_retrace_enabled(double time = TiMe::Default()) const { return getBool("retrace_enabled", time); }
44223
44227 bool set_retrace_threshold(float val, double time = TiMe::Default()) { return setValue("retrace_threshold", val, time); }
44231 float get_retrace_threshold(double time = TiMe::Default()) const { return getFloat("retrace_threshold", time); }
44232
44236 bool set_retrace_leak_prevention(float val, double time = TiMe::Default()) { return setValue("retrace_leak_prevention", val, time); }
44240 float get_retrace_leak_prevention(double time = TiMe::Default()) const { return getFloat("retrace_leak_prevention", time); }
44241
44245 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
44249 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
44250
44254 bool set_path_guiding(bool val, double time = TiMe::Default()) { return setValue("path_guiding", val, time); }
44258 bool get_path_guiding(double time = TiMe::Default()) const { return getBool("path_guiding", time); }
44259};
44260
44263public:
44265 static constexpr const PluginTypeId getTypeId() { return 0x77DE86C8; }
44267 static constexpr const char* getType() { return "SettingsLightLinker"; }
44268
44270 bool set_ignored_lights(const ValueList& list, double time = TiMe::Default()) { return setValue("ignored_lights", list, time); }
44271 bool set_ignored_lights(ValueList&& list, double time = TiMe::Default()) { return setValue("ignored_lights", std::move(list), time); }
44272 bool set_ignored_lights(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("ignored_lights", values, count, time); }
44273 template<size_t count> bool set_ignored_lights(const Value (&values)[count], double time = TiMe::Default()) { return setArray("ignored_lights", values, count, time); }
44274 template<size_t count> bool set_ignored_lights(Value (&&values)[count], double time = TiMe::Default()) { return setArray("ignored_lights", values, count, time); }
44276 ValueList get_ignored_lights(double time = TiMe::Default()) const { return getValueList("ignored_lights", time); }
44277
44279 bool set_ignored_shadow_lights(const ValueList& list, double time = TiMe::Default()) { return setValue("ignored_shadow_lights", list, time); }
44280 bool set_ignored_shadow_lights(ValueList&& list, double time = TiMe::Default()) { return setValue("ignored_shadow_lights", std::move(list), time); }
44281 bool set_ignored_shadow_lights(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("ignored_shadow_lights", values, count, time); }
44282 template<size_t count> bool set_ignored_shadow_lights(const Value (&values)[count], double time = TiMe::Default()) { return setArray("ignored_shadow_lights", values, count, time); }
44283 template<size_t count> bool set_ignored_shadow_lights(Value (&&values)[count], double time = TiMe::Default()) { return setArray("ignored_shadow_lights", values, count, time); }
44285 ValueList get_ignored_shadow_lights(double time = TiMe::Default()) const { return getValueList("ignored_shadow_lights", time); }
44286
44288 bool set_include_exclude_light_flags(const IntList& intList, double time = TiMe::Default()) { return setValue("include_exclude_light_flags", intList, time); }
44289 bool set_include_exclude_light_flags(IntList&& intList, double time = TiMe::Default()) { return setValue("include_exclude_light_flags", std::move(intList), time); }
44290 bool set_include_exclude_light_flags(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("include_exclude_light_flags", ints, count, time); }
44291 template<size_t count> bool set_include_exclude_light_flags(const int (&ints)[count], double time = TiMe::Default()) { return setArray("include_exclude_light_flags", ints, count, time); }
44293 IntList get_include_exclude_light_flags(double time = TiMe::Default()) const { return getIntList("include_exclude_light_flags", time); }
44294
44296 bool set_include_exclude_shadow_flags(const IntList& intList, double time = TiMe::Default()) { return setValue("include_exclude_shadow_flags", intList, time); }
44297 bool set_include_exclude_shadow_flags(IntList&& intList, double time = TiMe::Default()) { return setValue("include_exclude_shadow_flags", std::move(intList), time); }
44298 bool set_include_exclude_shadow_flags(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("include_exclude_shadow_flags", ints, count, time); }
44299 template<size_t count> bool set_include_exclude_shadow_flags(const int (&ints)[count], double time = TiMe::Default()) { return setArray("include_exclude_shadow_flags", ints, count, time); }
44301 IntList get_include_exclude_shadow_flags(double time = TiMe::Default()) const { return getIntList("include_exclude_shadow_flags", time); }
44302};
44303
44306public:
44308 static constexpr const PluginTypeId getTypeId() { return 0x77CEA39A; }
44310 static constexpr const char* getType() { return "SettingsLightTree"; }
44311
44312 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
44313
44317 bool set_on(bool val, double time = TiMe::Default()) { return setValue("on", val, time); }
44321 bool get_on(double time = TiMe::Default()) const { return getBool("on", time); }
44322
44326 bool set_solids_enabled(int val, double time = TiMe::Default()) { return setValue("solids_enabled", val, time); }
44330 int get_solids_enabled(double time = TiMe::Default()) const { return getInt("solids_enabled", time); }
44331
44335 bool set_build_quality(int val, double time = TiMe::Default()) { return setValue("build_quality", val, time); }
44339 int get_build_quality(double time = TiMe::Default()) const { return getInt("build_quality", time); }
44340};
44341
44344public:
44346 static constexpr const PluginTypeId getTypeId() { return 0x7857FFA1; }
44348 static constexpr const char* getType() { return "SettingsMemoryTracker"; }
44349
44350 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
44351
44354 bool set_output_enabled(bool val, double time = TiMe::Default()) { return setValue("output_enabled", val, time); }
44357 bool get_output_enabled(double time = TiMe::Default()) const { return getBool("output_enabled", time); }
44358
44361 bool set_scene_name(const char* str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
44364 bool set_scene_name(const std::string& str, double time = TiMe::Default()) { return setValue("scene_name", str, time); }
44367 std::string get_scene_name(double time = TiMe::Default()) const { return getString("scene_name", time); }
44368
44371 bool set_output_directory(const char* str, double time = TiMe::Default()) { return setValue("output_directory", str, time); }
44374 bool set_output_directory(const std::string& str, double time = TiMe::Default()) { return setValue("output_directory", str, time); }
44377 std::string get_output_directory(double time = TiMe::Default()) const { return getString("output_directory", time); }
44378
44381 bool set_output_file_prefix(const char* str, double time = TiMe::Default()) { return setValue("output_file_prefix", str, time); }
44384 bool set_output_file_prefix(const std::string& str, double time = TiMe::Default()) { return setValue("output_file_prefix", str, time); }
44387 std::string get_output_file_prefix(double time = TiMe::Default()) const { return getString("output_file_prefix", time); }
44388};
44389
44392public:
44394 static constexpr const PluginTypeId getTypeId() { return 0x7783463D; }
44396 static constexpr const char* getType() { return "SettingsMotionBlur"; }
44397
44398 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
44399
44403 bool set_on(bool val, double time = TiMe::Default()) { return setValue("on", val, time); }
44407 bool get_on(double time = TiMe::Default()) const { return getBool("on", time); }
44408
44412 bool set_geom_samples(int val, double time = TiMe::Default()) { return setValue("geom_samples", val, time); }
44416 int get_geom_samples(double time = TiMe::Default()) const { return getInt("geom_samples", time); }
44417
44421 bool set_low_samples(int val, double time = TiMe::Default()) { return setValue("low_samples", val, time); }
44425 int get_low_samples(double time = TiMe::Default()) const { return getInt("low_samples", time); }
44426
44430 bool set_duration(float val, double time = TiMe::Default()) { return setValue("duration", val, time); }
44434 float get_duration(double time = TiMe::Default()) const { return getFloat("duration", time); }
44435
44439 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
44443 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
44444
44448 bool set_bias(float val, double time = TiMe::Default()) { return setValue("bias", val, time); }
44452 float get_bias(double time = TiMe::Default()) const { return getFloat("bias", time); }
44453
44457 bool set_shutter_efficiency(float val, double time = TiMe::Default()) { return setValue("shutter_efficiency", val, time); }
44461 float get_shutter_efficiency(double time = TiMe::Default()) const { return getFloat("shutter_efficiency", time); }
44462
44466 bool set_interval_center(float val, double time = TiMe::Default()) { return setValue("interval_center", val, time); }
44470 float get_interval_center(double time = TiMe::Default()) const { return getFloat("interval_center", time); }
44471
44475 bool set_camera_motion_blur(bool val, double time = TiMe::Default()) { return setValue("camera_motion_blur", val, time); }
44479 bool get_camera_motion_blur(double time = TiMe::Default()) const { return getBool("camera_motion_blur", time); }
44480
44484 bool set_sampling_type(int val, double time = TiMe::Default()) { return setValue("sampling_type", val, time); }
44488 int get_sampling_type(double time = TiMe::Default()) const { return getInt("sampling_type", time); }
44489};
44490
44492class SettingsOptions : public Plugin {
44493public:
44495 static constexpr const PluginTypeId getTypeId() { return 0x778395ED; }
44497 static constexpr const char* getType() { return "SettingsOptions"; }
44498
44499 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
44500
44504 bool set_geom_displacement(bool val, double time = TiMe::Default()) { return setValue("geom_displacement", val, time); }
44508 bool get_geom_displacement(double time = TiMe::Default()) const { return getBool("geom_displacement", time); }
44509
44513 bool set_geom_doHidden(bool val, double time = TiMe::Default()) { return setValue("geom_doHidden", val, time); }
44517 bool get_geom_doHidden(double time = TiMe::Default()) const { return getBool("geom_doHidden", time); }
44518
44522 bool set_light_doLights(bool val, double time = TiMe::Default()) { return setValue("light_doLights", val, time); }
44526 bool get_light_doLights(double time = TiMe::Default()) const { return getBool("light_doLights", time); }
44527
44531 bool set_light_doDefaultLights(bool val, double time = TiMe::Default()) { return setValue("light_doDefaultLights", val, time); }
44535 bool get_light_doDefaultLights(double time = TiMe::Default()) const { return getBool("light_doDefaultLights", time); }
44536
44540 bool set_light_doHiddenLights(bool val, double time = TiMe::Default()) { return setValue("light_doHiddenLights", val, time); }
44544 bool get_light_doHiddenLights(double time = TiMe::Default()) const { return getBool("light_doHiddenLights", time); }
44545
44549 bool set_light_doShadows(bool val, double time = TiMe::Default()) { return setValue("light_doShadows", val, time); }
44553 bool get_light_doShadows(double time = TiMe::Default()) const { return getBool("light_doShadows", time); }
44554
44558 bool set_light_onlyGI(bool val, double time = TiMe::Default()) { return setValue("light_onlyGI", val, time); }
44562 bool get_light_onlyGI(double time = TiMe::Default()) const { return getBool("light_onlyGI", time); }
44563
44567 bool set_light_disableSelfIllumination(bool val, double time = TiMe::Default()) { return setValue("light_disableSelfIllumination", val, time); }
44571 bool get_light_disableSelfIllumination(double time = TiMe::Default()) const { return getBool("light_disableSelfIllumination", time); }
44572
44576 bool set_gi_dontRenderImage(bool val, double time = TiMe::Default()) { return setValue("gi_dontRenderImage", val, time); }
44580 bool get_gi_dontRenderImage(double time = TiMe::Default()) const { return getBool("gi_dontRenderImage", time); }
44581
44585 bool set_mtl_reflectionRefraction(bool val, double time = TiMe::Default()) { return setValue("mtl_reflectionRefraction", val, time); }
44589 bool get_mtl_reflectionRefraction(double time = TiMe::Default()) const { return getBool("mtl_reflectionRefraction", time); }
44590
44594 bool set_mtl_limitDepth(bool val, double time = TiMe::Default()) { return setValue("mtl_limitDepth", val, time); }
44598 bool get_mtl_limitDepth(double time = TiMe::Default()) const { return getBool("mtl_limitDepth", time); }
44599
44603 bool set_mtl_maxDepth(int val, double time = TiMe::Default()) { return setValue("mtl_maxDepth", val, time); }
44607 int get_mtl_maxDepth(double time = TiMe::Default()) const { return getInt("mtl_maxDepth", time); }
44608
44612 bool set_mtl_doMaps(bool val, double time = TiMe::Default()) { return setValue("mtl_doMaps", val, time); }
44616 bool get_mtl_doMaps(double time = TiMe::Default()) const { return getBool("mtl_doMaps", time); }
44617
44621 bool set_mtl_filterMaps(bool val, double time = TiMe::Default()) { return setValue("mtl_filterMaps", val, time); }
44625 bool get_mtl_filterMaps(double time = TiMe::Default()) const { return getBool("mtl_filterMaps", time); }
44626
44630 bool set_mtl_SSSEnabled(bool val, double time = TiMe::Default()) { return setValue("mtl_SSSEnabled", val, time); }
44634 bool get_mtl_SSSEnabled(double time = TiMe::Default()) const { return getBool("mtl_SSSEnabled", time); }
44635
44639 bool set_mtl_filterMapsForSecondaryRays(bool val, double time = TiMe::Default()) { return setValue("mtl_filterMapsForSecondaryRays", val, time); }
44643 bool get_mtl_filterMapsForSecondaryRays(double time = TiMe::Default()) const { return getBool("mtl_filterMapsForSecondaryRays", time); }
44644
44648 bool set_mtl_transpMaxLevels(int val, double time = TiMe::Default()) { return setValue("mtl_transpMaxLevels", val, time); }
44652 int get_mtl_transpMaxLevels(double time = TiMe::Default()) const { return getInt("mtl_transpMaxLevels", time); }
44653
44657 bool set_mtl_transpCutoff(float val, double time = TiMe::Default()) { return setValue("mtl_transpCutoff", val, time); }
44661 float get_mtl_transpCutoff(double time = TiMe::Default()) const { return getFloat("mtl_transpCutoff", time); }
44662
44666 bool set_mtl_override_on(bool val, double time = TiMe::Default()) { return setValue("mtl_override_on", val, time); }
44670 bool get_mtl_override_on(double time = TiMe::Default()) const { return getBool("mtl_override_on", time); }
44671
44675 bool set_mtl_glossy(bool val, double time = TiMe::Default()) { return setValue("mtl_glossy", val, time); }
44679 bool get_mtl_glossy(double time = TiMe::Default()) const { return getBool("mtl_glossy", time); }
44680
44684 bool set_mtl_uninvertedNormalBump(bool val, double time = TiMe::Default()) { return setValue("mtl_uninvertedNormalBump", val, time); }
44688 bool get_mtl_uninvertedNormalBump(double time = TiMe::Default()) const { return getBool("mtl_uninvertedNormalBump", time); }
44689
44693 bool set_mtl_matteShadowMode(int val, double time = TiMe::Default()) { return setValue("mtl_matteShadowMode", val, time); }
44697 int get_mtl_matteShadowMode(double time = TiMe::Default()) const { return getInt("mtl_matteShadowMode", time); }
44698
44702 bool set_mtl_stochasticBump(bool val, double time = TiMe::Default()) { return setValue("mtl_stochasticBump", val, time); }
44706 bool get_mtl_stochasticBump(double time = TiMe::Default()) const { return getBool("mtl_stochasticBump", time); }
44707
44711 bool set_geom_backfaceCull(bool val, double time = TiMe::Default()) { return setValue("geom_backfaceCull", val, time); }
44715 bool get_geom_backfaceCull(double time = TiMe::Default()) const { return getBool("geom_backfaceCull", time); }
44716
44720 bool set_ray_bias(float val, double time = TiMe::Default()) { return setValue("ray_bias", val, time); }
44724 float get_ray_bias(double time = TiMe::Default()) const { return getFloat("ray_bias", time); }
44725
44729 bool set_gi_texFilteringMultiplier(float val, double time = TiMe::Default()) { return setValue("gi_texFilteringMultiplier", val, time); }
44733 float get_gi_texFilteringMultiplier(double time = TiMe::Default()) const { return getFloat("gi_texFilteringMultiplier", time); }
44734
44738 bool set_misc_abortOnMissingAsset(bool val, double time = TiMe::Default()) { return setValue("misc_abortOnMissingAsset", val, time); }
44742 bool get_misc_abortOnMissingAsset(double time = TiMe::Default()) const { return getBool("misc_abortOnMissingAsset", time); }
44743
44747 bool set_misc_transferAssets(bool val, double time = TiMe::Default()) { return setValue("misc_transferAssets", val, time); }
44751 bool get_misc_transferAssets(double time = TiMe::Default()) const { return getBool("misc_transferAssets", time); }
44752
44756 bool set_misc_useCachedAssets(bool val, double time = TiMe::Default()) { return setValue("misc_useCachedAssets", val, time); }
44760 bool get_misc_useCachedAssets(double time = TiMe::Default()) const { return getBool("misc_useCachedAssets", time); }
44761
44765 bool set_dr_assetsCacheLimitType(int val, double time = TiMe::Default()) { return setValue("dr_assetsCacheLimitType", val, time); }
44769 int get_dr_assetsCacheLimitType(double time = TiMe::Default()) const { return getInt("dr_assetsCacheLimitType", time); }
44770
44774 bool set_dr_assetsCacheLimitValue(float val, double time = TiMe::Default()) { return setValue("dr_assetsCacheLimitValue", val, time); }
44778 float get_dr_assetsCacheLimitValue(double time = TiMe::Default()) const { return getFloat("dr_assetsCacheLimitValue", time); }
44779
44783 bool set_dr_overwriteLocalCacheSettings(bool val, double time = TiMe::Default()) { return setValue("dr_overwriteLocalCacheSettings", val, time); }
44787 bool get_dr_overwriteLocalCacheSettings(double time = TiMe::Default()) const { return getBool("dr_overwriteLocalCacheSettings", time); }
44788
44792 bool set_ray_max_intensity_on(bool val, double time = TiMe::Default()) { return setValue("ray_max_intensity_on", val, time); }
44796 bool get_ray_max_intensity_on(double time = TiMe::Default()) const { return getBool("ray_max_intensity_on", time); }
44797
44801 bool set_ray_max_intensity(float val, double time = TiMe::Default()) { return setValue("ray_max_intensity", val, time); }
44805 float get_ray_max_intensity(double time = TiMe::Default()) const { return getFloat("ray_max_intensity", time); }
44806
44810 bool set_probabilistic_lights_on(int val, double time = TiMe::Default()) { return setValue("probabilistic_lights_on", val, time); }
44814 int get_probabilistic_lights_on(double time = TiMe::Default()) const { return getInt("probabilistic_lights_on", time); }
44815
44819 bool set_num_probabilistic_lights(int val, double time = TiMe::Default()) { return setValue("num_probabilistic_lights", val, time); }
44823 int get_num_probabilistic_lights(double time = TiMe::Default()) const { return getInt("num_probabilistic_lights", time); }
44824
44828 bool set_probabilistic_vol_on(bool val, double time = TiMe::Default()) { return setValue("probabilistic_vol_on", val, time); }
44832 bool get_probabilistic_vol_on(double time = TiMe::Default()) const { return getBool("probabilistic_vol_on", time); }
44833
44837 bool set_probabilistic_vol_samples(int val, double time = TiMe::Default()) { return setValue("probabilistic_vol_samples", val, time); }
44841 int get_probabilistic_vol_samples(double time = TiMe::Default()) const { return getInt("probabilistic_vol_samples", time); }
44842
44846 bool set_probabilistic_vol_gi_samples(int val, double time = TiMe::Default()) { return setValue("probabilistic_vol_gi_samples", val, time); }
44850 int get_probabilistic_vol_gi_samples(double time = TiMe::Default()) const { return getInt("probabilistic_vol_gi_samples", time); }
44851
44855 bool set_probabilistic_vol_mis(bool val, double time = TiMe::Default()) { return setValue("probabilistic_vol_mis", val, time); }
44859 bool get_probabilistic_vol_mis(double time = TiMe::Default()) const { return getBool("probabilistic_vol_mis", time); }
44860
44864 bool set_misc_lowThreadPriority(int val, double time = TiMe::Default()) { return setValue("misc_lowThreadPriority", val, time); }
44868 int get_misc_lowThreadPriority(double time = TiMe::Default()) const { return getInt("misc_lowThreadPriority", time); }
44869
44873 bool set_misc_consistentLightingElements(bool val, double time = TiMe::Default()) { return setValue("misc_consistentLightingElements", val, time); }
44877 bool get_misc_consistentLightingElements(double time = TiMe::Default()) const { return getBool("misc_consistentLightingElements", time); }
44878
44882 bool set_lightSelect_metadata(bool val, double time = TiMe::Default()) { return setValue("lightSelect_metadata", val, time); }
44886 bool get_lightSelect_metadata(double time = TiMe::Default()) const { return getBool("lightSelect_metadata", time); }
44887
44891 bool set_light_minPixelSize(float val, double time = TiMe::Default()) { return setValue("light_minPixelSize", val, time); }
44895 float get_light_minPixelSize(double time = TiMe::Default()) const { return getFloat("light_minPixelSize", time); }
44896};
44897
44899class SettingsOutput : public Plugin {
44900public:
44902 static constexpr const PluginTypeId getTypeId() { return 0x7782AC56; }
44904 static constexpr const char* getType() { return "SettingsOutput"; }
44905
44906 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
44907
44911 bool set_img_width(int val, double time = TiMe::Default()) { return setValue("img_width", val, time); }
44915 int get_img_width(double time = TiMe::Default()) const { return getInt("img_width", time); }
44916
44920 bool set_img_height(int val, double time = TiMe::Default()) { return setValue("img_height", val, time); }
44924 int get_img_height(double time = TiMe::Default()) const { return getInt("img_height", time); }
44925
44929 bool set_img_pixelAspect(float val, double time = TiMe::Default()) { return setValue("img_pixelAspect", val, time); }
44933 float get_img_pixelAspect(double time = TiMe::Default()) const { return getFloat("img_pixelAspect", time); }
44934
44938 bool set_img_file(const char* str, double time = TiMe::Default()) { return setValue("img_file", str, time); }
44942 bool set_img_file(const std::string& str, double time = TiMe::Default()) { return setValue("img_file", str, time); }
44946 std::string get_img_file(double time = TiMe::Default()) const { return getString("img_file", time); }
44947
44951 bool set_img_dir(const char* str, double time = TiMe::Default()) { return setValue("img_dir", str, time); }
44955 bool set_img_dir(const std::string& str, double time = TiMe::Default()) { return setValue("img_dir", str, time); }
44959 std::string get_img_dir(double time = TiMe::Default()) const { return getString("img_dir", time); }
44960
44964 bool set_img_file_add_dot(bool val, double time = TiMe::Default()) { return setValue("img_file_add_dot", val, time); }
44968 bool get_img_file_add_dot(double time = TiMe::Default()) const { return getBool("img_file_add_dot", time); }
44969
44972 bool set_img_file_needFrameNumber(bool val, double time = TiMe::Default()) { return setValue("img_file_needFrameNumber", val, time); }
44975 bool get_img_file_needFrameNumber(double time = TiMe::Default()) const { return getBool("img_file_needFrameNumber", time); }
44976
44979 bool set_img_separateAlpha(bool val, double time = TiMe::Default()) { return setValue("img_separateAlpha", val, time); }
44982 bool get_img_separateAlpha(double time = TiMe::Default()) const { return getBool("img_separateAlpha", time); }
44983
44986 bool set_img_noAlpha(bool val, double time = TiMe::Default()) { return setValue("img_noAlpha", val, time); }
44989 bool get_img_noAlpha(double time = TiMe::Default()) const { return getBool("img_noAlpha", time); }
44990
44994 bool set_img_dontSaveRgbChannel(int val, double time = TiMe::Default()) { return setValue("img_dontSaveRgbChannel", val, time); }
44998 int get_img_dontSaveRgbChannel(double time = TiMe::Default()) const { return getInt("img_dontSaveRgbChannel", time); }
44999
45002 bool set_img_saveVelocityZeroBase(bool val, double time = TiMe::Default()) { return setValue("img_saveVelocityZeroBase", val, time); }
45005 bool get_img_saveVelocityZeroBase(double time = TiMe::Default()) const { return getBool("img_saveVelocityZeroBase", time); }
45006
45009 bool set_img_apply_cc_channels(bool val, double time = TiMe::Default()) { return setValue("img_apply_cc_channels", val, time); }
45012 bool get_img_apply_cc_channels(double time = TiMe::Default()) const { return getBool("img_apply_cc_channels", time); }
45013
45016 bool set_img_deepFile(bool val, double time = TiMe::Default()) { return setValue("img_deepFile", val, time); }
45019 bool get_img_deepFile(double time = TiMe::Default()) const { return getBool("img_deepFile", time); }
45020
45023 bool set_img_rawFile(bool val, double time = TiMe::Default()) { return setValue("img_rawFile", val, time); }
45026 bool get_img_rawFile(double time = TiMe::Default()) const { return getBool("img_rawFile", time); }
45027
45030 bool set_img_rawFileVFB(int val, double time = TiMe::Default()) { return setValue("img_rawFileVFB", val, time); }
45033 int get_img_rawFileVFB(double time = TiMe::Default()) const { return getInt("img_rawFileVFB", time); }
45034
45037 bool set_img_rawFileSaveColorCorrections(bool val, double time = TiMe::Default()) { return setValue("img_rawFileSaveColorCorrections", val, time); }
45040 bool get_img_rawFileSaveColorCorrections(double time = TiMe::Default()) const { return getBool("img_rawFileSaveColorCorrections", time); }
45041
45044 bool set_img_rawFileSaveColorCorrectionsRenderElements(bool val, double time = TiMe::Default()) { return setValue("img_rawFileSaveColorCorrectionsRenderElements", val, time); }
45047 bool get_img_rawFileSaveColorCorrectionsRenderElements(double time = TiMe::Default()) const { return getBool("img_rawFileSaveColorCorrectionsRenderElements", time); }
45048
45051 bool set_img_saveCryptomattesSeparately(bool val, double time = TiMe::Default()) { return setValue("img_saveCryptomattesSeparately", val, time); }
45054 bool get_img_saveCryptomattesSeparately(double time = TiMe::Default()) const { return getBool("img_saveCryptomattesSeparately", time); }
45055
45059 bool set_img_clearMode(int val, double time = TiMe::Default()) { return setValue("img_clearMode", val, time); }
45063 int get_img_clearMode(double time = TiMe::Default()) const { return getInt("img_clearMode", time); }
45064
45068 bool set_anim_start(double val, double time = TiMe::Default()) { return setValue("anim_start", val, time); }
45072 double get_anim_start(double time = TiMe::Default()) const { return getDouble("anim_start", time); }
45073
45077 bool set_anim_end(double val, double time = TiMe::Default()) { return setValue("anim_end", val, time); }
45081 double get_anim_end(double time = TiMe::Default()) const { return getDouble("anim_end", time); }
45082
45086 bool set_anim_frame_padding(int val, double time = TiMe::Default()) { return setValue("anim_frame_padding", val, time); }
45090 int get_anim_frame_padding(double time = TiMe::Default()) const { return getInt("anim_frame_padding", time); }
45091
45094 bool set_anim_renumber_on(bool val, double time = TiMe::Default()) { return setValue("anim_renumber_on", val, time); }
45097 bool get_anim_renumber_on(double time = TiMe::Default()) const { return getBool("anim_renumber_on", time); }
45098
45102 bool set_anim_renumber_start(float val, double time = TiMe::Default()) { return setValue("anim_renumber_start", val, time); }
45106 float get_anim_renumber_start(double time = TiMe::Default()) const { return getFloat("anim_renumber_start", time); }
45107
45111 bool set_anim_renumber_step(float val, double time = TiMe::Default()) { return setValue("anim_renumber_step", val, time); }
45115 float get_anim_renumber_step(double time = TiMe::Default()) const { return getFloat("anim_renumber_step", time); }
45116
45120 bool set_anim_ren_frame_start(float val, double time = TiMe::Default()) { return setValue("anim_ren_frame_start", val, time); }
45124 float get_anim_ren_frame_start(double time = TiMe::Default()) const { return getFloat("anim_ren_frame_start", time); }
45125
45129 bool set_frame_start(int val, double time = TiMe::Default()) { return setValue("frame_start", val, time); }
45133 int get_frame_start(double time = TiMe::Default()) const { return getInt("frame_start", time); }
45134
45138 bool set_frames_per_second(float val, double time = TiMe::Default()) { return setValue("frames_per_second", val, time); }
45142 float get_frames_per_second(double time = TiMe::Default()) const { return getFloat("frames_per_second", time); }
45143
45145 bool set_frames(const ValueList& list, double time = TiMe::Default()) { return setValue("frames", list, time); }
45146 bool set_frames(ValueList&& list, double time = TiMe::Default()) { return setValue("frames", std::move(list), time); }
45147 bool set_frames(const Value* values, size_t count, double time = TiMe::Default()) { return setArray("frames", values, count, time); }
45148 template<size_t count> bool set_frames(const Value (&values)[count], double time = TiMe::Default()) { return setArray("frames", values, count, time); }
45149 template<size_t count> bool set_frames(Value (&&values)[count], double time = TiMe::Default()) { return setArray("frames", values, count, time); }
45151 ValueList get_frames(double time = TiMe::Default()) const { return getValueList("frames", time); }
45152
45156 bool set_rgn_left(float val, double time = TiMe::Default()) { return setValue("rgn_left", val, time); }
45160 float get_rgn_left(double time = TiMe::Default()) const { return getFloat("rgn_left", time); }
45161
45165 bool set_rgn_width(float val, double time = TiMe::Default()) { return setValue("rgn_width", val, time); }
45169 float get_rgn_width(double time = TiMe::Default()) const { return getFloat("rgn_width", time); }
45170
45174 bool set_rgn_top(float val, double time = TiMe::Default()) { return setValue("rgn_top", val, time); }
45178 float get_rgn_top(double time = TiMe::Default()) const { return getFloat("rgn_top", time); }
45179
45183 bool set_rgn_height(float val, double time = TiMe::Default()) { return setValue("rgn_height", val, time); }
45187 float get_rgn_height(double time = TiMe::Default()) const { return getFloat("rgn_height", time); }
45188
45192 bool set_bmp_width(int val, double time = TiMe::Default()) { return setValue("bmp_width", val, time); }
45196 int get_bmp_width(double time = TiMe::Default()) const { return getInt("bmp_width", time); }
45197
45201 bool set_bmp_height(int val, double time = TiMe::Default()) { return setValue("bmp_height", val, time); }
45205 int get_bmp_height(double time = TiMe::Default()) const { return getInt("bmp_height", time); }
45206
45210 bool set_r_left(int val, double time = TiMe::Default()) { return setValue("r_left", val, time); }
45214 int get_r_left(double time = TiMe::Default()) const { return getInt("r_left", time); }
45215
45219 bool set_r_width(int val, double time = TiMe::Default()) { return setValue("r_width", val, time); }
45223 int get_r_width(double time = TiMe::Default()) const { return getInt("r_width", time); }
45224
45228 bool set_r_top(int val, double time = TiMe::Default()) { return setValue("r_top", val, time); }
45232 int get_r_top(double time = TiMe::Default()) const { return getInt("r_top", time); }
45233
45237 bool set_r_height(int val, double time = TiMe::Default()) { return setValue("r_height", val, time); }
45241 int get_r_height(double time = TiMe::Default()) const { return getInt("r_height", time); }
45242
45245 bool set_poly_regions(const char* str, double time = TiMe::Default()) { return setValue("poly_regions", str, time); }
45248 bool set_poly_regions(const std::string& str, double time = TiMe::Default()) { return setValue("poly_regions", str, time); }
45251 std::string get_poly_regions(double time = TiMe::Default()) const { return getString("poly_regions", time); }
45252
45255 bool set_frame_stamp_enabled(bool val, double time = TiMe::Default()) { return setValue("frame_stamp_enabled", val, time); }
45258 bool get_frame_stamp_enabled(double time = TiMe::Default()) const { return getBool("frame_stamp_enabled", time); }
45259
45262 bool set_frame_stamp_text(const char* str, double time = TiMe::Default()) { return setValue("frame_stamp_text", str, time); }
45265 bool set_frame_stamp_text(const std::string& str, double time = TiMe::Default()) { return setValue("frame_stamp_text", str, time); }
45268 std::string get_frame_stamp_text(double time = TiMe::Default()) const { return getString("frame_stamp_text", time); }
45269
45272 bool set_relements_separateFolders(bool val, double time = TiMe::Default()) { return setValue("relements_separateFolders", val, time); }
45275 bool get_relements_separateFolders(double time = TiMe::Default()) const { return getBool("relements_separateFolders", time); }
45276
45279 bool set_relements_separate_rgba(bool val, double time = TiMe::Default()) { return setValue("relements_separate_rgba", val, time); }
45282 bool get_relements_separate_rgba(double time = TiMe::Default()) const { return getBool("relements_separate_rgba", time); }
45283
45286 bool set_relements_divider(const char* str, double time = TiMe::Default()) { return setValue("relements_divider", str, time); }
45289 bool set_relements_divider(const std::string& str, double time = TiMe::Default()) { return setValue("relements_divider", str, time); }
45292 std::string get_relements_divider(double time = TiMe::Default()) const { return getString("relements_divider", time); }
45293
45296 bool set_film_offset_x(float val, double time = TiMe::Default()) { return setValue("film_offset_x", val, time); }
45299 float get_film_offset_x(double time = TiMe::Default()) const { return getFloat("film_offset_x", time); }
45300
45303 bool set_film_offset_y(float val, double time = TiMe::Default()) { return setValue("film_offset_y", val, time); }
45306 float get_film_offset_y(double time = TiMe::Default()) const { return getFloat("film_offset_y", time); }
45307};
45308
45310class SettingsPNG : public Plugin {
45311public:
45313 static constexpr const PluginTypeId getTypeId() { return 0x77A2174F; }
45315 static constexpr const char* getType() { return "SettingsPNG"; }
45316
45317 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
45318
45322 bool set_compression(int val, double time = TiMe::Default()) { return setValue("compression", val, time); }
45326 int get_compression(double time = TiMe::Default()) const { return getInt("compression", time); }
45327
45331 bool set_bits_per_channel(int val, double time = TiMe::Default()) { return setValue("bits_per_channel", val, time); }
45335 int get_bits_per_channel(double time = TiMe::Default()) const { return getInt("bits_per_channel", time); }
45336};
45337
45340public:
45342 static constexpr const PluginTypeId getTypeId() { return 0x77828030; }
45344 static constexpr const char* getType() { return "SettingsPhotonMap"; }
45345
45346 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
45347
45351 bool set_bounces(int val, double time = TiMe::Default()) { return setValue("bounces", val, time); }
45355 int get_bounces(double time = TiMe::Default()) const { return getInt("bounces", time); }
45356
45360 bool set_max_photons(int val, double time = TiMe::Default()) { return setValue("max_photons", val, time); }
45364 int get_max_photons(double time = TiMe::Default()) const { return getInt("max_photons", time); }
45365
45369 bool set_prefilter(bool val, double time = TiMe::Default()) { return setValue("prefilter", val, time); }
45373 bool get_prefilter(double time = TiMe::Default()) const { return getBool("prefilter", time); }
45374
45378 bool set_prefilter_samples(int val, double time = TiMe::Default()) { return setValue("prefilter_samples", val, time); }
45382 int get_prefilter_samples(double time = TiMe::Default()) const { return getInt("prefilter_samples", time); }
45383
45387 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
45391 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
45392
45396 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
45400 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
45404 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
45405
45409 bool set_auto_search_distance(bool val, double time = TiMe::Default()) { return setValue("auto_search_distance", val, time); }
45413 bool get_auto_search_distance(double time = TiMe::Default()) const { return getBool("auto_search_distance", time); }
45414
45418 bool set_search_distance(float val, double time = TiMe::Default()) { return setValue("search_distance", val, time); }
45422 float get_search_distance(double time = TiMe::Default()) const { return getFloat("search_distance", time); }
45423
45427 bool set_convex_hull_estimate(bool val, double time = TiMe::Default()) { return setValue("convex_hull_estimate", val, time); }
45431 bool get_convex_hull_estimate(double time = TiMe::Default()) const { return getBool("convex_hull_estimate", time); }
45432
45436 bool set_dont_delete(bool val, double time = TiMe::Default()) { return setValue("dont_delete", val, time); }
45440 bool get_dont_delete(double time = TiMe::Default()) const { return getBool("dont_delete", time); }
45441
45445 bool set_auto_save(bool val, double time = TiMe::Default()) { return setValue("auto_save", val, time); }
45449 bool get_auto_save(double time = TiMe::Default()) const { return getBool("auto_save", time); }
45450
45454 bool set_auto_save_file(const char* str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
45458 bool set_auto_save_file(const std::string& str, double time = TiMe::Default()) { return setValue("auto_save_file", str, time); }
45462 std::string get_auto_save_file(double time = TiMe::Default()) const { return getString("auto_save_file", time); }
45463
45467 bool set_store_direct_light(bool val, double time = TiMe::Default()) { return setValue("store_direct_light", val, time); }
45471 bool get_store_direct_light(double time = TiMe::Default()) const { return getBool("store_direct_light", time); }
45472
45476 bool set_multiplier(float val, double time = TiMe::Default()) { return setValue("multiplier", val, time); }
45480 float get_multiplier(double time = TiMe::Default()) const { return getFloat("multiplier", time); }
45481
45485 bool set_max_density(float val, double time = TiMe::Default()) { return setValue("max_density", val, time); }
45489 float get_max_density(double time = TiMe::Default()) const { return getFloat("max_density", time); }
45490
45494 bool set_retrace_corners(float val, double time = TiMe::Default()) { return setValue("retrace_corners", val, time); }
45498 float get_retrace_corners(double time = TiMe::Default()) const { return getFloat("retrace_corners", time); }
45499
45503 bool set_retrace_bounces(int val, double time = TiMe::Default()) { return setValue("retrace_bounces", val, time); }
45507 int get_retrace_bounces(double time = TiMe::Default()) const { return getInt("retrace_bounces", time); }
45508
45512 bool set_show_calc_phase(bool val, double time = TiMe::Default()) { return setValue("show_calc_phase", val, time); }
45516 bool get_show_calc_phase(double time = TiMe::Default()) const { return getBool("show_calc_phase", time); }
45517};
45518
45521public:
45523 static constexpr const PluginTypeId getTypeId() { return 0x4AF455610; }
45525 static constexpr const char* getType() { return "SettingsPtexBaker"; }
45526
45527 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
45528
45531 bool set_objects(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("objects", pluginList, time); }
45532 bool set_objects(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("objects", plugins, count, time); }
45533 template<size_t count> bool set_objects(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("objects", plugins, count, time); }
45536 PluginList get_objects(double time = TiMe::Default()) const { return getPluginList("objects", time); }
45537
45540 bool set_texture_name(const char* str, double time = TiMe::Default()) { return setValue("texture_name", str, time); }
45543 bool set_texture_name(const std::string& str, double time = TiMe::Default()) { return setValue("texture_name", str, time); }
45546 std::string get_texture_name(double time = TiMe::Default()) const { return getString("texture_name", time); }
45547
45551 bool set_world_space_res(bool val, double time = TiMe::Default()) { return setValue("world_space_res", val, time); }
45555 bool get_world_space_res(double time = TiMe::Default()) const { return getBool("world_space_res", time); }
45556
45560 bool set_res_u(int val, double time = TiMe::Default()) { return setValue("res_u", val, time); }
45564 int get_res_u(double time = TiMe::Default()) const { return getInt("res_u", time); }
45565
45569 bool set_res_v(int val, double time = TiMe::Default()) { return setValue("res_v", val, time); }
45573 int get_res_v(double time = TiMe::Default()) const { return getInt("res_v", time); }
45574
45578 bool set_length_u(float val, double time = TiMe::Default()) { return setValue("length_u", val, time); }
45582 float get_length_u(double time = TiMe::Default()) const { return getFloat("length_u", time); }
45583
45587 bool set_length_v(float val, double time = TiMe::Default()) { return setValue("length_v", val, time); }
45591 float get_length_v(double time = TiMe::Default()) const { return getFloat("length_v", time); }
45592
45596 bool set_camera_independent_shading(bool val, double time = TiMe::Default()) { return setValue("camera_independent_shading", val, time); }
45600 bool get_camera_independent_shading(double time = TiMe::Default()) const { return getBool("camera_independent_shading", time); }
45601
45605 bool set_samplers_per_texel(int val, double time = TiMe::Default()) { return setValue("samplers_per_texel", val, time); }
45609 int get_samplers_per_texel(double time = TiMe::Default()) const { return getInt("samplers_per_texel", time); }
45610
45614 bool set_surface_offset(float val, double time = TiMe::Default()) { return setValue("surface_offset", val, time); }
45618 float get_surface_offset(double time = TiMe::Default()) const { return getFloat("surface_offset", time); }
45619
45623 bool set_visibility_test_rays(int val, double time = TiMe::Default()) { return setValue("visibility_test_rays", val, time); }
45627 int get_visibility_test_rays(double time = TiMe::Default()) const { return getInt("visibility_test_rays", time); }
45628
45632 bool set_visibility_test_ray_max_length_factor(float val, double time = TiMe::Default()) { return setValue("visibility_test_ray_max_length_factor", val, time); }
45636 float get_visibility_test_ray_max_length_factor(double time = TiMe::Default()) const { return getFloat("visibility_test_ray_max_length_factor", time); }
45637
45641 bool set_resolution_multiplier(float val, double time = TiMe::Default()) { return setValue("resolution_multiplier", val, time); }
45645 float get_resolution_multiplier(double time = TiMe::Default()) const { return getFloat("resolution_multiplier", time); }
45646
45650 bool set_force_quads(bool val, double time = TiMe::Default()) { return setValue("force_quads", val, time); }
45654 bool get_force_quads(double time = TiMe::Default()) const { return getBool("force_quads", time); }
45655
45659 bool set_generate_mipmaps(bool val, double time = TiMe::Default()) { return setValue("generate_mipmaps", val, time); }
45663 bool get_generate_mipmaps(double time = TiMe::Default()) const { return getBool("generate_mipmaps", time); }
45664
45668 bool set_multichannel_file(bool val, double time = TiMe::Default()) { return setValue("multichannel_file", val, time); }
45672 bool get_multichannel_file(double time = TiMe::Default()) const { return getBool("multichannel_file", time); }
45673
45677 bool set_border_mode_u(int val, double time = TiMe::Default()) { return setValue("border_mode_u", val, time); }
45681 int get_border_mode_u(double time = TiMe::Default()) const { return getInt("border_mode_u", time); }
45682
45686 bool set_border_mode_v(int val, double time = TiMe::Default()) { return setValue("border_mode_v", val, time); }
45690 int get_border_mode_v(double time = TiMe::Default()) const { return getInt("border_mode_v", time); }
45691
45695 bool set_data_format(int val, double time = TiMe::Default()) { return setValue("data_format", val, time); }
45699 int get_data_format(double time = TiMe::Default()) const { return getInt("data_format", time); }
45700
45704 bool set_projection_baking(int val, double time = TiMe::Default()) { return setValue("projection_baking", val, time); }
45708 int get_projection_baking(double time = TiMe::Default()) const { return getInt("projection_baking", time); }
45709
45713 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
45717 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
45718
45722 bool set_normal(int val, double time = TiMe::Default()) { return setValue("normal", val, time); }
45726 int get_normal(double time = TiMe::Default()) const { return getInt("normal", time); }
45727
45731 bool set_ray_offset(float val, double time = TiMe::Default()) { return setValue("ray_offset", val, time); }
45735 float get_ray_offset(double time = TiMe::Default()) const { return getFloat("ray_offset", time); }
45736
45740 bool set_max_depth(float val, double time = TiMe::Default()) { return setValue("max_depth", val, time); }
45744 float get_max_depth(double time = TiMe::Default()) const { return getFloat("max_depth", time); }
45745
45749 bool set_write_faces_degrees(bool val, double time = TiMe::Default()) { return setValue("write_faces_degrees", val, time); }
45753 bool get_write_faces_degrees(double time = TiMe::Default()) const { return getBool("write_faces_degrees", time); }
45754
45758 bool set_write_faces_vertices(bool val, double time = TiMe::Default()) { return setValue("write_faces_vertices", val, time); }
45762 bool get_write_faces_vertices(double time = TiMe::Default()) const { return getBool("write_faces_vertices", time); }
45763
45767 bool set_write_vertex_positions(bool val, double time = TiMe::Default()) { return setValue("write_vertex_positions", val, time); }
45771 bool get_write_vertex_positions(double time = TiMe::Default()) const { return getBool("write_vertex_positions", time); }
45772};
45773
45775class SettingsRTEngine : public Plugin {
45776public:
45778 static constexpr const PluginTypeId getTypeId() { return 0x77FD52C5; }
45780 static constexpr const char* getType() { return "SettingsRTEngine"; }
45781
45782 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
45783
45787 bool set_trace_depth(int val, double time = TiMe::Default()) { return setValue("trace_depth", val, time); }
45791 int get_trace_depth(double time = TiMe::Default()) const { return getInt("trace_depth", time); }
45792
45796 bool set_gi_depth(int val, double time = TiMe::Default()) { return setValue("gi_depth", val, time); }
45800 int get_gi_depth(double time = TiMe::Default()) const { return getInt("gi_depth", time); }
45801
45805 bool set_cpu_bundle_size(int val, double time = TiMe::Default()) { return setValue("cpu_bundle_size", val, time); }
45809 int get_cpu_bundle_size(double time = TiMe::Default()) const { return getInt("cpu_bundle_size", time); }
45810
45814 bool set_cpu_samples_per_pixel(int val, double time = TiMe::Default()) { return setValue("cpu_samples_per_pixel", val, time); }
45818 int get_cpu_samples_per_pixel(double time = TiMe::Default()) const { return getInt("cpu_samples_per_pixel", time); }
45819
45823 bool set_gpu_bundle_size(int val, double time = TiMe::Default()) { return setValue("gpu_bundle_size", val, time); }
45827 int get_gpu_bundle_size(double time = TiMe::Default()) const { return getInt("gpu_bundle_size", time); }
45828
45832 bool set_gpu_samples_per_pixel(int val, double time = TiMe::Default()) { return setValue("gpu_samples_per_pixel", val, time); }
45836 int get_gpu_samples_per_pixel(double time = TiMe::Default()) const { return getInt("gpu_samples_per_pixel", time); }
45837
45841 bool set_low_gpu_thread_priority(bool val, double time = TiMe::Default()) { return setValue("low_gpu_thread_priority", val, time); }
45845 bool get_low_gpu_thread_priority(double time = TiMe::Default()) const { return getBool("low_gpu_thread_priority", time); }
45846
45850 bool set_coherent_tracing(bool val, double time = TiMe::Default()) { return setValue("coherent_tracing", val, time); }
45854 bool get_coherent_tracing(double time = TiMe::Default()) const { return getBool("coherent_tracing", time); }
45855
45859 bool set_stereo_mode(bool val, double time = TiMe::Default()) { return setValue("stereo_mode", val, time); }
45863 bool get_stereo_mode(double time = TiMe::Default()) const { return getBool("stereo_mode", time); }
45864
45868 bool set_stereo_eye_distance(float val, double time = TiMe::Default()) { return setValue("stereo_eye_distance", val, time); }
45872 float get_stereo_eye_distance(double time = TiMe::Default()) const { return getFloat("stereo_eye_distance", time); }
45873
45877 bool set_stereo_focus(int val, double time = TiMe::Default()) { return setValue("stereo_focus", val, time); }
45881 int get_stereo_focus(double time = TiMe::Default()) const { return getInt("stereo_focus", time); }
45882
45886 bool set_opencl_texsize(int val, double time = TiMe::Default()) { return setValue("opencl_texsize", val, time); }
45890 int get_opencl_texsize(double time = TiMe::Default()) const { return getInt("opencl_texsize", time); }
45891
45895 bool set_opencl_resizeTextures(int val, double time = TiMe::Default()) { return setValue("opencl_resizeTextures", val, time); }
45899 int get_opencl_resizeTextures(double time = TiMe::Default()) const { return getInt("opencl_resizeTextures", time); }
45900
45904 bool set_opencl_textureFormat(int val, double time = TiMe::Default()) { return setValue("opencl_textureFormat", val, time); }
45908 int get_opencl_textureFormat(double time = TiMe::Default()) const { return getInt("opencl_textureFormat", time); }
45909
45913 bool set_progressive_samples_per_pixel(bool val, double time = TiMe::Default()) { return setValue("progressive_samples_per_pixel", val, time); }
45917 bool get_progressive_samples_per_pixel(double time = TiMe::Default()) const { return getBool("progressive_samples_per_pixel", time); }
45918
45922 bool set_undersampling(int val, double time = TiMe::Default()) { return setValue("undersampling", val, time); }
45926 int get_undersampling(double time = TiMe::Default()) const { return getInt("undersampling", time); }
45927
45931 bool set_disable_render_elements(bool val, double time = TiMe::Default()) { return setValue("disable_render_elements", val, time); }
45935 bool get_disable_render_elements(double time = TiMe::Default()) const { return getBool("disable_render_elements", time); }
45936
45940 bool set_max_render_time(float val, double time = TiMe::Default()) { return setValue("max_render_time", val, time); }
45944 float get_max_render_time(double time = TiMe::Default()) const { return getFloat("max_render_time", time); }
45945
45949 bool set_max_sample_level(int val, double time = TiMe::Default()) { return setValue("max_sample_level", val, time); }
45953 int get_max_sample_level(double time = TiMe::Default()) const { return getInt("max_sample_level", time); }
45954
45958 bool set_noise_threshold(float val, double time = TiMe::Default()) { return setValue("noise_threshold", val, time); }
45962 float get_noise_threshold(double time = TiMe::Default()) const { return getFloat("noise_threshold", time); }
45963
45967 bool set_max_draw_interval(int val, double time = TiMe::Default()) { return setValue("max_draw_interval", val, time); }
45971 int get_max_draw_interval(double time = TiMe::Default()) const { return getInt("max_draw_interval", time); }
45972
45976 bool set_min_draw_interval(int val, double time = TiMe::Default()) { return setValue("min_draw_interval", val, time); }
45980 int get_min_draw_interval(double time = TiMe::Default()) const { return getInt("min_draw_interval", time); }
45981
45985 bool set_interactive(int val, double time = TiMe::Default()) { return setValue("interactive", val, time); }
45989 int get_interactive(double time = TiMe::Default()) const { return getInt("interactive", time); }
45990
45993 bool set_enable_bucket_sampler(int val, double time = TiMe::Default()) { return setValue("enable_bucket_sampler", val, time); }
45996 int get_enable_bucket_sampler(double time = TiMe::Default()) const { return getInt("enable_bucket_sampler", time); }
45997
46001 bool set_out_of_core(bool val, double time = TiMe::Default()) { return setValue("out_of_core", val, time); }
46005 bool get_out_of_core(double time = TiMe::Default()) const { return getBool("out_of_core", time); }
46006
46010 bool set_disable_auto_rpp(bool val, double time = TiMe::Default()) { return setValue("disable_auto_rpp", val, time); }
46014 bool get_disable_auto_rpp(double time = TiMe::Default()) const { return getBool("disable_auto_rpp", time); }
46015
46019 bool set_out_of_core_textures(bool val, double time = TiMe::Default()) { return setValue("out_of_core_textures", val, time); }
46023 bool get_out_of_core_textures(double time = TiMe::Default()) const { return getBool("out_of_core_textures", time); }
46024
46028 bool set_out_of_core_textures_threshold(int val, double time = TiMe::Default()) { return setValue("out_of_core_textures_threshold", val, time); }
46032 int get_out_of_core_textures_threshold(double time = TiMe::Default()) const { return getInt("out_of_core_textures_threshold", time); }
46033};
46034
46037public:
46039 static constexpr const PluginTypeId getTypeId() { return 0x7782AD81; }
46041 static constexpr const char* getType() { return "SettingsRaycaster"; }
46042
46043 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46044
46048 bool set_maxLevels(int val, double time = TiMe::Default()) { return setValue("maxLevels", val, time); }
46052 int get_maxLevels(double time = TiMe::Default()) const { return getInt("maxLevels", time); }
46053
46057 bool set_minLeafSize(float val, double time = TiMe::Default()) { return setValue("minLeafSize", val, time); }
46061 float get_minLeafSize(double time = TiMe::Default()) const { return getFloat("minLeafSize", time); }
46062
46066 bool set_faceLevelCoef(float val, double time = TiMe::Default()) { return setValue("faceLevelCoef", val, time); }
46070 float get_faceLevelCoef(double time = TiMe::Default()) const { return getFloat("faceLevelCoef", time); }
46071
46075 bool set_dynMemLimit(int val, double time = TiMe::Default()) { return setValue("dynMemLimit", val, time); }
46079 int get_dynMemLimit(double time = TiMe::Default()) const { return getInt("dynMemLimit", time); }
46080
46084 bool set_optLevel(int val, double time = TiMe::Default()) { return setValue("optLevel", val, time); }
46088 int get_optLevel(double time = TiMe::Default()) const { return getInt("optLevel", time); }
46089
46093 bool set_embreeUse(bool val, double time = TiMe::Default()) { return setValue("embreeUse", val, time); }
46097 bool get_embreeUse(double time = TiMe::Default()) const { return getBool("embreeUse", time); }
46098
46102 bool set_embreeUseMB(bool val, double time = TiMe::Default()) { return setValue("embreeUseMB", val, time); }
46106 bool get_embreeUseMB(double time = TiMe::Default()) const { return getBool("embreeUseMB", time); }
46107
46111 bool set_embreeHair(bool val, double time = TiMe::Default()) { return setValue("embreeHair", val, time); }
46115 bool get_embreeHair(double time = TiMe::Default()) const { return getBool("embreeHair", time); }
46116
46120 bool set_embreeLowMemory(bool val, double time = TiMe::Default()) { return setValue("embreeLowMemory", val, time); }
46124 bool get_embreeLowMemory(double time = TiMe::Default()) const { return getBool("embreeLowMemory", time); }
46125
46129 bool set_embreeRayPackets(bool val, double time = TiMe::Default()) { return setValue("embreeRayPackets", val, time); }
46133 bool get_embreeRayPackets(double time = TiMe::Default()) const { return getBool("embreeRayPackets", time); }
46134};
46135
46138public:
46140 static constexpr const PluginTypeId getTypeId() { return 0x7791E981; }
46142 static constexpr const char* getType() { return "SettingsRegionsGenerator"; }
46143
46144 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46145
46148 bool set_xc(int val, double time = TiMe::Default()) { return setValue("xc", val, time); }
46151 int get_xc(double time = TiMe::Default()) const { return getInt("xc", time); }
46152
46155 bool set_yc(int val, double time = TiMe::Default()) { return setValue("yc", val, time); }
46158 int get_yc(double time = TiMe::Default()) const { return getInt("yc", time); }
46159
46163 bool set_xymeans(int val, double time = TiMe::Default()) { return setValue("xymeans", val, time); }
46167 int get_xymeans(double time = TiMe::Default()) const { return getInt("xymeans", time); }
46168
46172 bool set_seqtype(int val, double time = TiMe::Default()) { return setValue("seqtype", val, time); }
46176 int get_seqtype(double time = TiMe::Default()) const { return getInt("seqtype", time); }
46177
46180 bool set_reverse(bool val, double time = TiMe::Default()) { return setValue("reverse", val, time); }
46183 bool get_reverse(double time = TiMe::Default()) const { return getBool("reverse", time); }
46184
46188 bool set_dynbuckets(int val, double time = TiMe::Default()) { return setValue("dynbuckets", val, time); }
46192 int get_dynbuckets(double time = TiMe::Default()) const { return getInt("dynbuckets", time); }
46193};
46194
46197public:
46199 static constexpr const PluginTypeId getTypeId() { return 0x77C04E11; }
46201 static constexpr const char* getType() { return "SettingsRenderChannels"; }
46202
46203 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46204
46208 bool set_unfiltered_fragment_method(int val, double time = TiMe::Default()) { return setValue("unfiltered_fragment_method", val, time); }
46212 int get_unfiltered_fragment_method(double time = TiMe::Default()) const { return getInt("unfiltered_fragment_method", time); }
46213
46217 bool set_deep_merge_mode(int val, double time = TiMe::Default()) { return setValue("deep_merge_mode", val, time); }
46221 int get_deep_merge_mode(double time = TiMe::Default()) const { return getInt("deep_merge_mode", time); }
46222
46226 bool set_deep_merge_coeff(float val, double time = TiMe::Default()) { return setValue("deep_merge_coeff", val, time); }
46230 float get_deep_merge_coeff(double time = TiMe::Default()) const { return getFloat("deep_merge_coeff", time); }
46231
46235 bool set_deep_exclude_RGB(bool val, double time = TiMe::Default()) { return setValue("deep_exclude_RGB", val, time); }
46239 bool get_deep_exclude_RGB(double time = TiMe::Default()) const { return getBool("deep_exclude_RGB", time); }
46240};
46241
46243class SettingsSGI : public Plugin {
46244public:
46246 static constexpr const PluginTypeId getTypeId() { return 0x77CEF08D; }
46248 static constexpr const char* getType() { return "SettingsSGI"; }
46249
46250 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46251
46255 bool set_bits_per_channel(int val, double time = TiMe::Default()) { return setValue("bits_per_channel", val, time); }
46259 int get_bits_per_channel(double time = TiMe::Default()) const { return getInt("bits_per_channel", time); }
46260};
46261
46263class SettingsTGA : public Plugin {
46264public:
46266 static constexpr const PluginTypeId getTypeId() { return 0x77CFDB51; }
46268 static constexpr const char* getType() { return "SettingsTGA"; }
46269
46270 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46271
46275 bool set_compression(int val, double time = TiMe::Default()) { return setValue("compression", val, time); }
46279 int get_compression(double time = TiMe::Default()) const { return getInt("compression", time); }
46280};
46281
46283class SettingsTIFF : public Plugin {
46284public:
46286 static constexpr const PluginTypeId getTypeId() { return 0x77AFD676; }
46288 static constexpr const char* getType() { return "SettingsTIFF"; }
46289
46290 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46291
46295 bool set_bits_per_channel(int val, double time = TiMe::Default()) { return setValue("bits_per_channel", val, time); }
46299 int get_bits_per_channel(double time = TiMe::Default()) const { return getInt("bits_per_channel", time); }
46300
46304 bool set_interleaved(bool val, double time = TiMe::Default()) { return setValue("interleaved", val, time); }
46308 bool get_interleaved(double time = TiMe::Default()) const { return getBool("interleaved", time); }
46309};
46310
46313public:
46315 static constexpr const PluginTypeId getTypeId() { return 0x782A3051; }
46317 static constexpr const char* getType() { return "SettingsTextureCache"; }
46318
46319 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46320
46323 bool set_cache_size(int val, double time = TiMe::Default()) { return setValue("cache_size", val, time); }
46326 int get_cache_size(double time = TiMe::Default()) const { return getInt("cache_size", time); }
46327
46330 bool set_max_mipmap_resolution(int val, double time = TiMe::Default()) { return setValue("max_mipmap_resolution", val, time); }
46333 int get_max_mipmap_resolution(double time = TiMe::Default()) const { return getInt("max_mipmap_resolution", time); }
46334};
46335
46338public:
46340 static constexpr const PluginTypeId getTypeId() { return 0x77A104B2; }
46342 static constexpr const char* getType() { return "SettingsUnitsInfo"; }
46343
46344 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46345
46348 bool set_meters_scale(float val, double time = TiMe::Default()) { return setValue("meters_scale", val, time); }
46351 float get_meters_scale(double time = TiMe::Default()) const { return getFloat("meters_scale", time); }
46352
46355 bool set_photometric_scale(float val, double time = TiMe::Default()) { return setValue("photometric_scale", val, time); }
46358 float get_photometric_scale(double time = TiMe::Default()) const { return getFloat("photometric_scale", time); }
46359
46362 bool set_scene_upDir(const Vector& vector, double time = TiMe::Default()) { return setValue("scene_upDir", vector, time); }
46365 Vector get_scene_upDir(double time = TiMe::Default()) const { return getVector("scene_upDir", time); }
46366
46369 bool set_seconds_scale(float val, double time = TiMe::Default()) { return setValue("seconds_scale", val, time); }
46372 float get_seconds_scale(double time = TiMe::Default()) const { return getFloat("seconds_scale", time); }
46373
46376 bool set_frames_scale(float val, double time = TiMe::Default()) { return setValue("frames_scale", val, time); }
46379 float get_frames_scale(double time = TiMe::Default()) const { return getFloat("frames_scale", time); }
46380
46384 bool set_rgb_color_space(int val, double time = TiMe::Default()) { return setValue("rgb_color_space", val, time); }
46388 int get_rgb_color_space(double time = TiMe::Default()) const { return getInt("rgb_color_space", time); }
46389
46393 bool set_coordinate_system(int val, double time = TiMe::Default()) { return setValue("coordinate_system", val, time); }
46397 int get_coordinate_system(double time = TiMe::Default()) const { return getInt("coordinate_system", time); }
46398
46402 bool set_ocio_config_file(const char* str, double time = TiMe::Default()) { return setValue("ocio_config_file", str, time); }
46406 bool set_ocio_config_file(const std::string& str, double time = TiMe::Default()) { return setValue("ocio_config_file", str, time); }
46410 std::string get_ocio_config_file(double time = TiMe::Default()) const { return getString("ocio_config_file", time); }
46411};
46412
46414class SettingsVFB : public Plugin {
46415public:
46417 static constexpr const PluginTypeId getTypeId() { return 0x77ECDF71; }
46419 static constexpr const char* getType() { return "SettingsVFB"; }
46420
46421 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46422
46425 bool set_version(int val, double time = TiMe::Default()) { return setValue("version", val, time); }
46428 int get_version(double time = TiMe::Default()) const { return getInt("version", time); }
46429
46432 bool set_bloom_weight(float val, double time = TiMe::Default()) { return setValue("bloom_weight", val, time); }
46435 float get_bloom_weight(double time = TiMe::Default()) const { return getFloat("bloom_weight", time); }
46436
46439 bool set_bloom_mask_intensity(float val, double time = TiMe::Default()) { return setValue("bloom_mask_intensity", val, time); }
46442 float get_bloom_mask_intensity(double time = TiMe::Default()) const { return getFloat("bloom_mask_intensity", time); }
46443
46446 bool set_glare_on(bool val, double time = TiMe::Default()) { return setValue("glare_on", val, time); }
46449 bool get_glare_on(double time = TiMe::Default()) const { return getBool("glare_on", time); }
46450
46453 bool set_glare_weight(float val, double time = TiMe::Default()) { return setValue("glare_weight", val, time); }
46456 float get_glare_weight(double time = TiMe::Default()) const { return getFloat("glare_weight", time); }
46457
46460 bool set_glare_size(float val, double time = TiMe::Default()) { return setValue("glare_size", val, time); }
46463 float get_glare_size(double time = TiMe::Default()) const { return getFloat("glare_size", time); }
46464
46467 bool set_glare_type(int val, double time = TiMe::Default()) { return setValue("glare_type", val, time); }
46470 int get_glare_type(double time = TiMe::Default()) const { return getInt("glare_type", time); }
46471
46474 bool set_glare_mode(int val, double time = TiMe::Default()) { return setValue("glare_mode", val, time); }
46477 int get_glare_mode(double time = TiMe::Default()) const { return getInt("glare_mode", time); }
46478
46481 bool set_glare_image_path(const char* str, double time = TiMe::Default()) { return setValue("glare_image_path", str, time); }
46484 bool set_glare_image_path(const std::string& str, double time = TiMe::Default()) { return setValue("glare_image_path", str, time); }
46487 std::string get_glare_image_path(double time = TiMe::Default()) const { return getString("glare_image_path", time); }
46488
46491 bool set_glare_obstacle_image_path(const char* str, double time = TiMe::Default()) { return setValue("glare_obstacle_image_path", str, time); }
46494 bool set_glare_obstacle_image_path(const std::string& str, double time = TiMe::Default()) { return setValue("glare_obstacle_image_path", str, time); }
46497 std::string get_glare_obstacle_image_path(double time = TiMe::Default()) const { return getString("glare_obstacle_image_path", time); }
46498
46501 bool set_glare_diffraction_on(bool val, double time = TiMe::Default()) { return setValue("glare_diffraction_on", val, time); }
46504 bool get_glare_diffraction_on(double time = TiMe::Default()) const { return getBool("glare_diffraction_on", time); }
46505
46508 bool set_glare_use_obstacle_image(bool val, double time = TiMe::Default()) { return setValue("glare_use_obstacle_image", val, time); }
46511 bool get_glare_use_obstacle_image(double time = TiMe::Default()) const { return getBool("glare_use_obstacle_image", time); }
46512
46515 bool set_glare_cam_blades_on(bool val, double time = TiMe::Default()) { return setValue("glare_cam_blades_on", val, time); }
46518 bool get_glare_cam_blades_on(double time = TiMe::Default()) const { return getBool("glare_cam_blades_on", time); }
46519
46522 bool set_glare_cam_num_blades(int val, double time = TiMe::Default()) { return setValue("glare_cam_num_blades", val, time); }
46525 int get_glare_cam_num_blades(double time = TiMe::Default()) const { return getInt("glare_cam_num_blades", time); }
46526
46529 bool set_glare_cam_rotation(float val, double time = TiMe::Default()) { return setValue("glare_cam_rotation", val, time); }
46532 float get_glare_cam_rotation(double time = TiMe::Default()) const { return getFloat("glare_cam_rotation", time); }
46533
46536 bool set_glare_cam_fnumber(float val, double time = TiMe::Default()) { return setValue("glare_cam_fnumber", val, time); }
46539 float get_glare_cam_fnumber(double time = TiMe::Default()) const { return getFloat("glare_cam_fnumber", time); }
46540
46543 bool set_glare_mask_intensity(float val, double time = TiMe::Default()) { return setValue("glare_mask_intensity", val, time); }
46546 float get_glare_mask_intensity(double time = TiMe::Default()) const { return getFloat("glare_mask_intensity", time); }
46547
46550 bool set_interactive(bool val, double time = TiMe::Default()) { return setValue("interactive", val, time); }
46553 bool get_interactive(double time = TiMe::Default()) const { return getBool("interactive", time); }
46554
46557 bool set_hardware_accelerated(bool val, double time = TiMe::Default()) { return setValue("hardware_accelerated", val, time); }
46560 bool get_hardware_accelerated(double time = TiMe::Default()) const { return getBool("hardware_accelerated", time); }
46561
46564 bool set_display_srgb(bool val, double time = TiMe::Default()) { return setValue("display_srgb", val, time); }
46567 bool get_display_srgb(double time = TiMe::Default()) const { return getBool("display_srgb", time); }
46568
46571 bool set_filter_rotation(float val, double time = TiMe::Default()) { return setValue("filter_rotation", val, time); }
46574 float get_filter_rotation(double time = TiMe::Default()) const { return getFloat("filter_rotation", time); }
46575
46578 bool set_use_occlusion(bool val, double time = TiMe::Default()) { return setValue("use_occlusion", val, time); }
46581 bool get_use_occlusion(double time = TiMe::Default()) const { return getBool("use_occlusion", time); }
46582
46585 bool set_occlusion_symmetric(bool val, double time = TiMe::Default()) { return setValue("occlusion_symmetric", val, time); }
46588 bool get_occlusion_symmetric(double time = TiMe::Default()) const { return getBool("occlusion_symmetric", time); }
46589
46592 bool set_occlusion_percent(float val, double time = TiMe::Default()) { return setValue("occlusion_percent", val, time); }
46595 float get_occlusion_percent(double time = TiMe::Default()) const { return getFloat("occlusion_percent", time); }
46596
46599 bool set_occlusion_rotation(float val, double time = TiMe::Default()) { return setValue("occlusion_rotation", val, time); }
46602 float get_occlusion_rotation(double time = TiMe::Default()) const { return getFloat("occlusion_rotation", time); }
46603
46606 bool set_occlusion_arc(float val, double time = TiMe::Default()) { return setValue("occlusion_arc", val, time); }
46609 float get_occlusion_arc(double time = TiMe::Default()) const { return getFloat("occlusion_arc", time); }
46610
46613 bool set_use_grating(bool val, double time = TiMe::Default()) { return setValue("use_grating", val, time); }
46616 bool get_use_grating(double time = TiMe::Default()) const { return getBool("use_grating", time); }
46617
46620 bool set_grating_length(float val, double time = TiMe::Default()) { return setValue("grating_length", val, time); }
46623 float get_grating_length(double time = TiMe::Default()) const { return getFloat("grating_length", time); }
46624
46627 bool set_grating_slope(float val, double time = TiMe::Default()) { return setValue("grating_slope", val, time); }
46630 float get_grating_slope(double time = TiMe::Default()) const { return getFloat("grating_slope", time); }
46631
46634 bool set_grating_strength(float val, double time = TiMe::Default()) { return setValue("grating_strength", val, time); }
46637 float get_grating_strength(double time = TiMe::Default()) const { return getFloat("grating_strength", time); }
46638
46641 bool set_grating_density(float val, double time = TiMe::Default()) { return setValue("grating_density", val, time); }
46644 float get_grating_density(double time = TiMe::Default()) const { return getFloat("grating_density", time); }
46645
46648 bool set_grating_zoom(float val, double time = TiMe::Default()) { return setValue("grating_zoom", val, time); }
46651 float get_grating_zoom(double time = TiMe::Default()) const { return getFloat("grating_zoom", time); }
46652
46655 bool set_use_scratch(bool val, double time = TiMe::Default()) { return setValue("use_scratch", val, time); }
46658 bool get_use_scratch(double time = TiMe::Default()) const { return getBool("use_scratch", time); }
46659
46662 bool set_scr_pattern(int val, double time = TiMe::Default()) { return setValue("scr_pattern", val, time); }
46665 int get_scr_pattern(double time = TiMe::Default()) const { return getInt("scr_pattern", time); }
46666
46669 bool set_scr_symmetric(bool val, double time = TiMe::Default()) { return setValue("scr_symmetric", val, time); }
46672 bool get_scr_symmetric(double time = TiMe::Default()) const { return getBool("scr_symmetric", time); }
46673
46676 bool set_scr_multiglare_count(int val, double time = TiMe::Default()) { return setValue("scr_multiglare_count", val, time); }
46679 int get_scr_multiglare_count(double time = TiMe::Default()) const { return getInt("scr_multiglare_count", time); }
46680
46683 bool set_scr_seed(int val, double time = TiMe::Default()) { return setValue("scr_seed", val, time); }
46686 int get_scr_seed(double time = TiMe::Default()) const { return getInt("scr_seed", time); }
46687
46690 bool set_scr_density(float val, double time = TiMe::Default()) { return setValue("scr_density", val, time); }
46693 float get_scr_density(double time = TiMe::Default()) const { return getFloat("scr_density", time); }
46694
46697 bool set_scr_strength(float val, double time = TiMe::Default()) { return setValue("scr_strength", val, time); }
46700 float get_scr_strength(double time = TiMe::Default()) const { return getFloat("scr_strength", time); }
46701
46704 bool set_scr_slope_variance(float val, double time = TiMe::Default()) { return setValue("scr_slope_variance", val, time); }
46707 float get_scr_slope_variance(double time = TiMe::Default()) const { return getFloat("scr_slope_variance", time); }
46708
46711 bool set_scr_width_variance(float val, double time = TiMe::Default()) { return setValue("scr_width_variance", val, time); }
46714 float get_scr_width_variance(double time = TiMe::Default()) const { return getFloat("scr_width_variance", time); }
46715
46718 bool set_scr_length(float val, double time = TiMe::Default()) { return setValue("scr_length", val, time); }
46721 float get_scr_length(double time = TiMe::Default()) const { return getFloat("scr_length", time); }
46722
46725 bool set_scr_zoom(float val, double time = TiMe::Default()) { return setValue("scr_zoom", val, time); }
46728 float get_scr_zoom(double time = TiMe::Default()) const { return getFloat("scr_zoom", time); }
46729
46732 bool set_scr_rotation(float val, double time = TiMe::Default()) { return setValue("scr_rotation", val, time); }
46735 float get_scr_rotation(double time = TiMe::Default()) const { return getFloat("scr_rotation", time); }
46736
46739 bool set_use_dust(bool val, double time = TiMe::Default()) { return setValue("use_dust", val, time); }
46742 bool get_use_dust(double time = TiMe::Default()) const { return getBool("use_dust", time); }
46743
46746 bool set_dust_pattern(int val, double time = TiMe::Default()) { return setValue("dust_pattern", val, time); }
46749 int get_dust_pattern(double time = TiMe::Default()) const { return getInt("dust_pattern", time); }
46750
46753 bool set_dust_radius_variance(float val, double time = TiMe::Default()) { return setValue("dust_radius_variance", val, time); }
46756 float get_dust_radius_variance(double time = TiMe::Default()) const { return getFloat("dust_radius_variance", time); }
46757
46760 bool set_dust_strength(float val, double time = TiMe::Default()) { return setValue("dust_strength", val, time); }
46763 float get_dust_strength(double time = TiMe::Default()) const { return getFloat("dust_strength", time); }
46764
46767 bool set_dust_density(float val, double time = TiMe::Default()) { return setValue("dust_density", val, time); }
46770 float get_dust_density(double time = TiMe::Default()) const { return getFloat("dust_density", time); }
46771
46774 bool set_dust_zoom(float val, double time = TiMe::Default()) { return setValue("dust_zoom", val, time); }
46777 float get_dust_zoom(double time = TiMe::Default()) const { return getFloat("dust_zoom", time); }
46778
46781 bool set_dust_rotation(float val, double time = TiMe::Default()) { return setValue("dust_rotation", val, time); }
46784 float get_dust_rotation(double time = TiMe::Default()) const { return getFloat("dust_rotation", time); }
46785
46788 bool set_dust_jitter(float val, double time = TiMe::Default()) { return setValue("dust_jitter", val, time); }
46791 float get_dust_jitter(double time = TiMe::Default()) const { return getFloat("dust_jitter", time); }
46792
46795 bool set_obst_image_zoom(float val, double time = TiMe::Default()) { return setValue("obst_image_zoom", val, time); }
46798 float get_obst_image_zoom(double time = TiMe::Default()) const { return getFloat("obst_image_zoom", time); }
46799
46802 bool set_obst_image_rotation(float val, double time = TiMe::Default()) { return setValue("obst_image_rotation", val, time); }
46805 float get_obst_image_rotation(double time = TiMe::Default()) const { return getFloat("obst_image_rotation", time); }
46806
46809 bool set_obst_image_strength(float val, double time = TiMe::Default()) { return setValue("obst_image_strength", val, time); }
46812 float get_obst_image_strength(double time = TiMe::Default()) const { return getFloat("obst_image_strength", time); }
46813
46816 bool set_cc_settings(const IntList& intList, double time = TiMe::Default()) { return setValue("cc_settings", intList, time); }
46817 bool set_cc_settings(IntList&& intList, double time = TiMe::Default()) { return setValue("cc_settings", std::move(intList), time); }
46818 bool set_cc_settings(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("cc_settings", ints, count, time); }
46819 template<size_t count> bool set_cc_settings(const int (&ints)[count], double time = TiMe::Default()) { return setArray("cc_settings", ints, count, time); }
46822 IntList get_cc_settings(double time = TiMe::Default()) const { return getIntList("cc_settings", time); }
46823
46826 bool set_enable_vfb2(bool val, double time = TiMe::Default()) { return setValue("enable_vfb2", val, time); }
46829 bool get_enable_vfb2(double time = TiMe::Default()) const { return getBool("enable_vfb2", time); }
46830
46833 bool set_vfb2_layers(const char* str, double time = TiMe::Default()) { return setValue("vfb2_layers", str, time); }
46836 bool set_vfb2_layers(const std::string& str, double time = TiMe::Default()) { return setValue("vfb2_layers", str, time); }
46839 std::string get_vfb2_layers(double time = TiMe::Default()) const { return getString("vfb2_layers", time); }
46840
46843 bool set_dont_affect_settings(bool val, double time = TiMe::Default()) { return setValue("dont_affect_settings", val, time); }
46846 bool get_dont_affect_settings(double time = TiMe::Default()) const { return getBool("dont_affect_settings", time); }
46847};
46848
46850class SettingsVRST : public Plugin {
46851public:
46853 static constexpr const PluginTypeId getTypeId() { return 0x77FC9106; }
46855 static constexpr const char* getType() { return "SettingsVRST"; }
46856
46857 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46858
46862 bool set_compression(int val, double time = TiMe::Default()) { return setValue("compression", val, time); }
46866 int get_compression(double time = TiMe::Default()) const { return getInt("compression", time); }
46867
46871 bool set_bits_per_channel(int val, double time = TiMe::Default()) { return setValue("bits_per_channel", val, time); }
46875 int get_bits_per_channel(double time = TiMe::Default()) const { return getInt("bits_per_channel", time); }
46876};
46877
46880public:
46882 static constexpr const PluginTypeId getTypeId() { return 0x4AEB76620; }
46884 static constexpr const char* getType() { return "SettingsVertexBaker"; }
46885
46886 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46887
46889 bool set_objects(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("objects", pluginList, time); }
46890 bool set_objects(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("objects", plugins, count, time); }
46891 template<size_t count> bool set_objects(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("objects", plugins, count, time); }
46893 PluginList get_objects(double time = TiMe::Default()) const { return getPluginList("objects", time); }
46894
46896 bool set_color_set_name(const char* str, double time = TiMe::Default()) { return setValue("color_set_name", str, time); }
46898 bool set_color_set_name(const std::string& str, double time = TiMe::Default()) { return setValue("color_set_name", str, time); }
46900 std::string get_color_set_name(double time = TiMe::Default()) const { return getString("color_set_name", time); }
46901
46904 bool set_bake_rgb_color(int val, double time = TiMe::Default()) { return setValue("bake_rgb_color", val, time); }
46907 int get_bake_rgb_color(double time = TiMe::Default()) const { return getInt("bake_rgb_color", time); }
46908
46911 bool set_bake_alpha(int val, double time = TiMe::Default()) { return setValue("bake_alpha", val, time); }
46914 int get_bake_alpha(double time = TiMe::Default()) const { return getInt("bake_alpha", time); }
46915};
46916
46918class SphereFade : public Plugin {
46919public:
46921 static constexpr const PluginTypeId getTypeId() { return 0xBFB13F4; }
46923 static constexpr const char* getType() { return "SphereFade"; }
46924
46925 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
46926
46927 operator VolumetricPluginCategory() { return *static_cast<VolumetricPluginCategory*>(static_cast<Plugin*>(this)); }
46928
46930 bool set_gizmos(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("gizmos", pluginList, time); }
46931 bool set_gizmos(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("gizmos", plugins, count, time); }
46932 template<size_t count> bool set_gizmos(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("gizmos", plugins, count, time); }
46934 PluginList get_gizmos(double time = TiMe::Default()) const { return getPluginList("gizmos", time); }
46935
46938 bool set_empty_color(const Color& color, double time = TiMe::Default()) { return setValue("empty_color", color, time); }
46941 Color get_empty_color(double time = TiMe::Default()) const { return getColor("empty_color", time); }
46942
46945 bool set_affect_alpha(bool val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
46948 bool get_affect_alpha(double time = TiMe::Default()) const { return getBool("affect_alpha", time); }
46949
46952 bool set_falloff(float val, double time = TiMe::Default()) { return setValue("falloff", val, time); }
46955 float get_falloff(double time = TiMe::Default()) const { return getFloat("falloff", time); }
46956};
46957
46959class SphereFadeGizmo : public Plugin {
46960public:
46962 static constexpr const PluginTypeId getTypeId() { return 0xBFB13F5; }
46964 static constexpr const char* getType() { return "SphereFadeGizmo"; }
46965
46968 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
46971 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
46972
46975 bool set_radius(float val, double time = TiMe::Default()) { return setValue("radius", val, time); }
46978 float get_radius(double time = TiMe::Default()) const { return getFloat("radius", time); }
46979
46982 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
46985 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
46986
46989 bool set_shape(int val, double time = TiMe::Default()) { return setValue("shape", val, time); }
46992 int get_shape(double time = TiMe::Default()) const { return getInt("shape", time); }
46993};
46994
46997public:
46999 static constexpr const PluginTypeId getTypeId() { return 0xBF99916; }
47001 static constexpr const char* getType() { return "SphericalHarmonicsExporter"; }
47002
47003 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
47004
47007 bool set_anim_on(bool val, double time = TiMe::Default()) { return setValue("anim_on", val, time); }
47010 bool get_anim_on(double time = TiMe::Default()) const { return getBool("anim_on", time); }
47011
47014 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
47017 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
47018
47021 bool set_bands(int val, double time = TiMe::Default()) { return setValue("bands", val, time); }
47024 int get_bands(double time = TiMe::Default()) const { return getInt("bands", time); }
47025
47028 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
47031 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
47032
47035 bool set_bounces(int val, double time = TiMe::Default()) { return setValue("bounces", val, time); }
47038 int get_bounces(double time = TiMe::Default()) const { return getInt("bounces", time); }
47039
47042 bool set_ray_bias(float val, double time = TiMe::Default()) { return setValue("ray_bias", val, time); }
47045 float get_ray_bias(double time = TiMe::Default()) const { return getFloat("ray_bias", time); }
47046
47050 bool set_file_name(const char* str, double time = TiMe::Default()) { return setValue("file_name", str, time); }
47054 bool set_file_name(const std::string& str, double time = TiMe::Default()) { return setValue("file_name", str, time); }
47058 std::string get_file_name(double time = TiMe::Default()) const { return getString("file_name", time); }
47059
47062 bool set_file_format(int val, double time = TiMe::Default()) { return setValue("file_format", val, time); }
47065 int get_file_format(double time = TiMe::Default()) const { return getInt("file_format", time); }
47066
47069 bool set_per_normal(bool val, double time = TiMe::Default()) { return setValue("per_normal", val, time); }
47072 bool get_per_normal(double time = TiMe::Default()) const { return getBool("per_normal", time); }
47073
47076 bool set_hit_recording(bool val, double time = TiMe::Default()) { return setValue("hit_recording", val, time); }
47079 bool get_hit_recording(double time = TiMe::Default()) const { return getBool("hit_recording", time); }
47080
47083 bool set_max_mem_usage(int val, double time = TiMe::Default()) { return setValue("max_mem_usage", val, time); }
47086 int get_max_mem_usage(double time = TiMe::Default()) const { return getInt("max_mem_usage", time); }
47087
47090 bool set_object_space(bool val, double time = TiMe::Default()) { return setValue("object_space", val, time); }
47093 bool get_object_space(double time = TiMe::Default()) const { return getBool("object_space", time); }
47094
47097 bool set_adaptive_on(bool val, double time = TiMe::Default()) { return setValue("adaptive_on", val, time); }
47100 bool get_adaptive_on(double time = TiMe::Default()) const { return getBool("adaptive_on", time); }
47101
47104 bool set_adaptive_thresh(float val, double time = TiMe::Default()) { return setValue("adaptive_thresh", val, time); }
47107 float get_adaptive_thresh(double time = TiMe::Default()) const { return getFloat("adaptive_thresh", time); }
47108
47111 bool set_adaptive_depth(int val, double time = TiMe::Default()) { return setValue("adaptive_depth", val, time); }
47114 int get_adaptive_depth(double time = TiMe::Default()) const { return getInt("adaptive_depth", time); }
47115
47118 bool set_adaptive_edge(float val, double time = TiMe::Default()) { return setValue("adaptive_edge", val, time); }
47121 float get_adaptive_edge(double time = TiMe::Default()) const { return getFloat("adaptive_edge", time); }
47122
47125 bool set_save_obj(bool val, double time = TiMe::Default()) { return setValue("save_obj", val, time); }
47128 bool get_save_obj(double time = TiMe::Default()) const { return getBool("save_obj", time); }
47129
47131 bool set_node(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("node", plugin, time); }
47133 PluginRef get_node(double time = TiMe::Default()) const { return getPlugin("node", time); }
47134};
47135
47138public:
47140 static constexpr const PluginTypeId getTypeId() { return 0xBFB1052; }
47142 static constexpr const char* getType() { return "SphericalHarmonicsRenderer"; }
47143
47144 operator SettingsPluginCategory() { return *static_cast<SettingsPluginCategory*>(static_cast<Plugin*>(this)); }
47145
47149 bool set_file_name(const char* str, double time = TiMe::Default()) { return setValue("file_name", str, time); }
47153 bool set_file_name(const std::string& str, double time = TiMe::Default()) { return setValue("file_name", str, time); }
47157 std::string get_file_name(double time = TiMe::Default()) const { return getString("file_name", time); }
47158
47161 bool set_use_single_vrsh(int val, double time = TiMe::Default()) { return setValue("use_single_vrsh", val, time); }
47164 int get_use_single_vrsh(double time = TiMe::Default()) const { return getInt("use_single_vrsh", time); }
47165
47168 bool set_precalc_light_per_frame(int val, double time = TiMe::Default()) { return setValue("precalc_light_per_frame", val, time); }
47171 int get_precalc_light_per_frame(double time = TiMe::Default()) const { return getInt("precalc_light_per_frame", time); }
47172
47175 bool set_sample_environment(int val, double time = TiMe::Default()) { return setValue("sample_environment", val, time); }
47178 int get_sample_environment(double time = TiMe::Default()) const { return getInt("sample_environment", time); }
47179
47182 bool set_is_hemispherical(int val, double time = TiMe::Default()) { return setValue("is_hemispherical", val, time); }
47185 int get_is_hemispherical(double time = TiMe::Default()) const { return getInt("is_hemispherical", time); }
47186
47189 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
47192 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
47193
47196 bool set_apply_filtering(int val, double time = TiMe::Default()) { return setValue("apply_filtering", val, time); }
47199 int get_apply_filtering(double time = TiMe::Default()) const { return getInt("apply_filtering", time); }
47200
47203 bool set_filter_strength(float val, double time = TiMe::Default()) { return setValue("filter_strength", val, time); }
47206 float get_filter_strength(double time = TiMe::Default()) const { return getFloat("filter_strength", time); }
47207};
47208
47210class SunLight : public Plugin {
47211public:
47213 static constexpr const PluginTypeId getTypeId() { return 0x77919714; }
47215 static constexpr const char* getType() { return "SunLight"; }
47216
47217 operator GeometryPluginCategory() { return *static_cast<GeometryPluginCategory*>(static_cast<Plugin*>(this)); }
47218
47219 operator LightPluginCategory() { return *static_cast<LightPluginCategory*>(static_cast<Plugin*>(this)); }
47220
47224 bool set_enabled(bool val, double time = TiMe::Default()) { return setValue("enabled", val, time); }
47228 bool get_enabled(double time = TiMe::Default()) const { return getBool("enabled", time); }
47229
47233 bool set_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("transform", transform, time); }
47237 Transform get_transform(double time = TiMe::Default()) const { return getTransform("transform", time); }
47238
47241 bool set_pivot_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("pivot_offset", vector, time); }
47244 Vector get_pivot_offset(double time = TiMe::Default()) const { return getVector("pivot_offset", time); }
47245
47249 bool set_color(const AColor& acolor, double time = TiMe::Default()) { return setValue("color", acolor, time); }
47253 AColor get_color(double time = TiMe::Default()) const { return getAColor("color", time); }
47254
47257 bool set_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
47260 bool set_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color_tex", texture, time); }
47263 Value get_color_tex(double time = TiMe::Default()) const { return getValue("color_tex", time); }
47264
47268 bool set_affectDiffuse(bool val, double time = TiMe::Default()) { return setValue("affectDiffuse", val, time); }
47272 bool get_affectDiffuse(double time = TiMe::Default()) const { return getBool("affectDiffuse", time); }
47273
47277 bool set_affectSpecular(bool val, double time = TiMe::Default()) { return setValue("affectSpecular", val, time); }
47281 bool get_affectSpecular(double time = TiMe::Default()) const { return getBool("affectSpecular", time); }
47282
47286 bool set_affectAtmospherics(bool val, double time = TiMe::Default()) { return setValue("affectAtmospherics", val, time); }
47290 bool get_affectAtmospherics(double time = TiMe::Default()) const { return getBool("affectAtmospherics", time); }
47291
47295 bool set_diffuse_contribution(float val, double time = TiMe::Default()) { return setValue("diffuse_contribution", val, time); }
47299 float get_diffuse_contribution(double time = TiMe::Default()) const { return getFloat("diffuse_contribution", time); }
47300
47304 bool set_specular_contribution(float val, double time = TiMe::Default()) { return setValue("specular_contribution", val, time); }
47308 float get_specular_contribution(double time = TiMe::Default()) const { return getFloat("specular_contribution", time); }
47309
47313 bool set_atmospherics_contribution(float val, double time = TiMe::Default()) { return setValue("atmospherics_contribution", val, time); }
47317 float get_atmospherics_contribution(double time = TiMe::Default()) const { return getFloat("atmospherics_contribution", time); }
47318
47322 bool set_use_global_light_level(bool val, double time = TiMe::Default()) { return setValue("use_global_light_level", val, time); }
47326 bool get_use_global_light_level(double time = TiMe::Default()) const { return getBool("use_global_light_level", time); }
47327
47331 bool set_scene_name(const StringList& stringList, double time = TiMe::Default()) { return setValue("scene_name", stringList, time); }
47335 StringList get_scene_name(double time = TiMe::Default()) const { return getStringList("scene_name", time); }
47336
47340 bool set_bumped_below_surface_check(bool val, double time = TiMe::Default()) { return setValue("bumped_below_surface_check", val, time); }
47344 bool get_bumped_below_surface_check(double time = TiMe::Default()) const { return getBool("bumped_below_surface_check", time); }
47345
47349 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
47353 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
47354
47358 bool set_shadows(bool val, double time = TiMe::Default()) { return setValue("shadows", val, time); }
47362 bool get_shadows(double time = TiMe::Default()) const { return getBool("shadows", time); }
47363
47367 bool set_shadowColor(const Color& color, double time = TiMe::Default()) { return setValue("shadowColor", color, time); }
47371 Color get_shadowColor(double time = TiMe::Default()) const { return getColor("shadowColor", time); }
47372
47374 bool set_shadow_color(const Color& color, double time = TiMe::Default()) { return setValue("shadow_color", color, time); }
47376 Color get_shadow_color(double time = TiMe::Default()) const { return getColor("shadow_color", time); }
47377
47380 bool set_shadowColor_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
47383 bool set_shadowColor_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadowColor_tex", texture, time); }
47386 Value get_shadowColor_tex(double time = TiMe::Default()) const { return getValue("shadowColor_tex", time); }
47387
47389 bool set_shadow_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("shadow_color_tex", texture, time); }
47391 bool set_shadow_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("shadow_color_tex", texture, time); }
47393 Value get_shadow_color_tex(double time = TiMe::Default()) const { return getValue("shadow_color_tex", time); }
47394
47398 bool set_shadowBias(float val, double time = TiMe::Default()) { return setValue("shadowBias", val, time); }
47402 float get_shadowBias(double time = TiMe::Default()) const { return getFloat("shadowBias", time); }
47403
47407 bool set_photonSubdivs(int val, double time = TiMe::Default()) { return setValue("photonSubdivs", val, time); }
47411 int get_photonSubdivs(double time = TiMe::Default()) const { return getInt("photonSubdivs", time); }
47412
47416 bool set_causticSubdivs(int val, double time = TiMe::Default()) { return setValue("causticSubdivs", val, time); }
47420 int get_causticSubdivs(double time = TiMe::Default()) const { return getInt("causticSubdivs", time); }
47421
47425 bool set_diffuseMult(float val, double time = TiMe::Default()) { return setValue("diffuseMult", val, time); }
47429 float get_diffuseMult(double time = TiMe::Default()) const { return getFloat("diffuseMult", time); }
47430
47434 bool set_causticMult(float val, double time = TiMe::Default()) { return setValue("causticMult", val, time); }
47438 float get_causticMult(double time = TiMe::Default()) const { return getFloat("causticMult", time); }
47439
47443 bool set_cutoffThreshold(float val, double time = TiMe::Default()) { return setValue("cutoffThreshold", val, time); }
47447 float get_cutoffThreshold(double time = TiMe::Default()) const { return getFloat("cutoffThreshold", time); }
47448
47452 bool set_is_instance_prototype(int val, double time = TiMe::Default()) { return setValue("is_instance_prototype", val, time); }
47456 int get_is_instance_prototype(double time = TiMe::Default()) const { return getInt("is_instance_prototype", time); }
47457
47460 bool set_channels(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels", pluginList, time); }
47461 bool set_channels(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
47462 template<size_t count> bool set_channels(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels", plugins, count, time); }
47465 PluginList get_channels(double time = TiMe::Default()) const { return getPluginList("channels", time); }
47466
47469 bool set_channels_raw(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_raw", pluginList, time); }
47470 bool set_channels_raw(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
47471 template<size_t count> bool set_channels_raw(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_raw", plugins, count, time); }
47474 PluginList get_channels_raw(double time = TiMe::Default()) const { return getPluginList("channels_raw", time); }
47475
47478 bool set_channels_diffuse(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_diffuse", pluginList, time); }
47479 bool set_channels_diffuse(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
47480 template<size_t count> bool set_channels_diffuse(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_diffuse", plugins, count, time); }
47483 PluginList get_channels_diffuse(double time = TiMe::Default()) const { return getPluginList("channels_diffuse", time); }
47484
47487 bool set_channels_specular(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_specular", pluginList, time); }
47488 bool set_channels_specular(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
47489 template<size_t count> bool set_channels_specular(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_specular", plugins, count, time); }
47492 PluginList get_channels_specular(double time = TiMe::Default()) const { return getPluginList("channels_specular", time); }
47493
47496 bool set_channels_full(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("channels_full", pluginList, time); }
47497 bool set_channels_full(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
47498 template<size_t count> bool set_channels_full(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("channels_full", plugins, count, time); }
47501 PluginList get_channels_full(double time = TiMe::Default()) const { return getPluginList("channels_full", time); }
47502
47506 bool set_lpe_label(const char* str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
47510 bool set_lpe_label(const std::string& str, double time = TiMe::Default()) { return setValue("lpe_label", str, time); }
47514 std::string get_lpe_label(double time = TiMe::Default()) const { return getString("lpe_label", time); }
47515
47519 bool set_decay_near_on(bool val, double time = TiMe::Default()) { return setValue("decay_near_on", val, time); }
47523 bool get_decay_near_on(double time = TiMe::Default()) const { return getBool("decay_near_on", time); }
47524
47528 bool set_decay_near_start(float val, double time = TiMe::Default()) { return setValue("decay_near_start", val, time); }
47532 float get_decay_near_start(double time = TiMe::Default()) const { return getFloat("decay_near_start", time); }
47533
47537 bool set_decay_near_end(float val, double time = TiMe::Default()) { return setValue("decay_near_end", val, time); }
47541 float get_decay_near_end(double time = TiMe::Default()) const { return getFloat("decay_near_end", time); }
47542
47546 bool set_decay_far_on(bool val, double time = TiMe::Default()) { return setValue("decay_far_on", val, time); }
47550 bool get_decay_far_on(double time = TiMe::Default()) const { return getBool("decay_far_on", time); }
47551
47555 bool set_decay_far_start(float val, double time = TiMe::Default()) { return setValue("decay_far_start", val, time); }
47559 float get_decay_far_start(double time = TiMe::Default()) const { return getFloat("decay_far_start", time); }
47560
47564 bool set_decay_far_end(float val, double time = TiMe::Default()) { return setValue("decay_far_end", val, time); }
47568 float get_decay_far_end(double time = TiMe::Default()) const { return getFloat("decay_far_end", time); }
47569
47573 bool set_units(int val, double time = TiMe::Default()) { return setValue("units", val, time); }
47577 int get_units(double time = TiMe::Default()) const { return getInt("units", time); }
47578
47582 bool set_intensity(float val, double time = TiMe::Default()) { return setValue("intensity", val, time); }
47586 float get_intensity(double time = TiMe::Default()) const { return getFloat("intensity", time); }
47587
47590 bool set_intensity_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
47593 bool set_intensity_tex(float texturefloat, double time = TiMe::Default()) { return setValue("intensity_tex", texturefloat, time); }
47596 Value get_intensity_tex(double time = TiMe::Default()) const { return getValue("intensity_tex", time); }
47597
47601 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
47605 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
47606
47610 bool set_invisible(bool val, double time = TiMe::Default()) { return setValue("invisible", val, time); }
47614 bool get_invisible(double time = TiMe::Default()) const { return getBool("invisible", time); }
47615
47619 bool set_storeWithIrradianceMap(bool val, double time = TiMe::Default()) { return setValue("storeWithIrradianceMap", val, time); }
47623 bool get_storeWithIrradianceMap(double time = TiMe::Default()) const { return getBool("storeWithIrradianceMap", time); }
47624
47628 bool set_affectReflections(bool val, double time = TiMe::Default()) { return setValue("affectReflections", val, time); }
47632 bool get_affectReflections(double time = TiMe::Default()) const { return getBool("affectReflections", time); }
47633
47637 bool set_noDecay(bool val, double time = TiMe::Default()) { return setValue("noDecay", val, time); }
47641 bool get_noDecay(double time = TiMe::Default()) const { return getBool("noDecay", time); }
47642
47646 bool set_doubleSided(bool val, double time = TiMe::Default()) { return setValue("doubleSided", val, time); }
47650 bool get_doubleSided(double time = TiMe::Default()) const { return getBool("doubleSided", time); }
47651
47655 bool set_objectID(int val, double time = TiMe::Default()) { return setValue("objectID", val, time); }
47659 int get_objectID(double time = TiMe::Default()) const { return getInt("objectID", time); }
47660
47664 bool set_useMIS(bool val, double time = TiMe::Default()) { return setValue("useMIS", val, time); }
47668 bool get_useMIS(double time = TiMe::Default()) const { return getBool("useMIS", time); }
47669
47673 bool set_intensity_multiplier(float val, double time = TiMe::Default()) { return setValue("intensity_multiplier", val, time); }
47677 float get_intensity_multiplier(double time = TiMe::Default()) const { return getFloat("intensity_multiplier", time); }
47678
47682 bool set_target_transform(const Transform& transform, double time = TiMe::Default()) { return setValue("target_transform", transform, time); }
47686 Transform get_target_transform(double time = TiMe::Default()) const { return getTransform("target_transform", time); }
47687
47691 bool set_turbidity(float val, double time = TiMe::Default()) { return setValue("turbidity", val, time); }
47695 float get_turbidity(double time = TiMe::Default()) const { return getFloat("turbidity", time); }
47696
47700 bool set_ozone(float val, double time = TiMe::Default()) { return setValue("ozone", val, time); }
47704 float get_ozone(double time = TiMe::Default()) const { return getFloat("ozone", time); }
47705
47709 bool set_size_multiplier(float val, double time = TiMe::Default()) { return setValue("size_multiplier", val, time); }
47713 float get_size_multiplier(double time = TiMe::Default()) const { return getFloat("size_multiplier", time); }
47714
47718 bool set_sky_model(int val, double time = TiMe::Default()) { return setValue("sky_model", val, time); }
47722 int get_sky_model(double time = TiMe::Default()) const { return getInt("sky_model", time); }
47723
47727 bool set_horiz_illum(float val, double time = TiMe::Default()) { return setValue("horiz_illum", val, time); }
47731 float get_horiz_illum(double time = TiMe::Default()) const { return getFloat("horiz_illum", time); }
47732
47736 bool set_altitude(float val, double time = TiMe::Default()) { return setValue("altitude", val, time); }
47740 float get_altitude(double time = TiMe::Default()) const { return getFloat("altitude", time); }
47741
47745 bool set_color_mode(int val, double time = TiMe::Default()) { return setValue("color_mode", val, time); }
47749 int get_color_mode(double time = TiMe::Default()) const { return getInt("color_mode", time); }
47750
47754 bool set_filter_color(const Color& color, double time = TiMe::Default()) { return setValue("filter_color", color, time); }
47758 Color get_filter_color(double time = TiMe::Default()) const { return getColor("filter_color", time); }
47759
47763 bool set_ground_albedo(const Color& color, double time = TiMe::Default()) { return setValue("ground_albedo", color, time); }
47767 Color get_ground_albedo(double time = TiMe::Default()) const { return getColor("ground_albedo", time); }
47768
47772 bool set_blend_angle(float val, double time = TiMe::Default()) { return setValue("blend_angle", val, time); }
47776 float get_blend_angle(double time = TiMe::Default()) const { return getFloat("blend_angle", time); }
47777
47781 bool set_horizon_offset(float val, double time = TiMe::Default()) { return setValue("horizon_offset", val, time); }
47785 float get_horizon_offset(double time = TiMe::Default()) const { return getFloat("horizon_offset", time); }
47786
47790 bool set_water_vapour(float val, double time = TiMe::Default()) { return setValue("water_vapour", val, time); }
47794 float get_water_vapour(double time = TiMe::Default()) const { return getFloat("water_vapour", time); }
47795
47799 bool set_up_vector(const Vector& vector, double time = TiMe::Default()) { return setValue("up_vector", vector, time); }
47803 Vector get_up_vector(double time = TiMe::Default()) const { return getVector("up_vector", time); }
47804
47808 bool set_atmos_shadows(bool val, double time = TiMe::Default()) { return setValue("atmos_shadows", val, time); }
47812 bool get_atmos_shadows(double time = TiMe::Default()) const { return getBool("atmos_shadows", time); }
47813
47817 bool set_shadow_subdivs(int val, double time = TiMe::Default()) { return setValue("shadow_subdivs", val, time); }
47821 int get_shadow_subdivs(double time = TiMe::Default()) const { return getInt("shadow_subdivs", time); }
47822
47826 bool set_photon_radius(float val, double time = TiMe::Default()) { return setValue("photon_radius", val, time); }
47830 float get_photon_radius(double time = TiMe::Default()) const { return getFloat("photon_radius", time); }
47831
47835 bool set_clouds_on(bool val, double time = TiMe::Default()) { return setValue("clouds_on", val, time); }
47839 bool get_clouds_on(double time = TiMe::Default()) const { return getBool("clouds_on", time); }
47840
47844 bool set_clouds_ground_shadows(bool val, double time = TiMe::Default()) { return setValue("clouds_ground_shadows", val, time); }
47848 bool get_clouds_ground_shadows(double time = TiMe::Default()) const { return getBool("clouds_ground_shadows", time); }
47849
47853 bool set_clouds_density(float val, double time = TiMe::Default()) { return setValue("clouds_density", val, time); }
47857 float get_clouds_density(double time = TiMe::Default()) const { return getFloat("clouds_density", time); }
47858
47862 bool set_clouds_variety(float val, double time = TiMe::Default()) { return setValue("clouds_variety", val, time); }
47866 float get_clouds_variety(double time = TiMe::Default()) const { return getFloat("clouds_variety", time); }
47867
47871 bool set_clouds_cirrus_amount(float val, double time = TiMe::Default()) { return setValue("clouds_cirrus_amount", val, time); }
47875 float get_clouds_cirrus_amount(double time = TiMe::Default()) const { return getFloat("clouds_cirrus_amount", time); }
47876
47880 bool set_clouds_offset_x(float val, double time = TiMe::Default()) { return setValue("clouds_offset_x", val, time); }
47884 float get_clouds_offset_x(double time = TiMe::Default()) const { return getFloat("clouds_offset_x", time); }
47885
47889 bool set_clouds_offset_y(float val, double time = TiMe::Default()) { return setValue("clouds_offset_y", val, time); }
47893 float get_clouds_offset_y(double time = TiMe::Default()) const { return getFloat("clouds_offset_y", time); }
47894
47898 bool set_clouds_height(float val, double time = TiMe::Default()) { return setValue("clouds_height", val, time); }
47902 float get_clouds_height(double time = TiMe::Default()) const { return getFloat("clouds_height", time); }
47903
47907 bool set_clouds_thickness(float val, double time = TiMe::Default()) { return setValue("clouds_thickness", val, time); }
47911 float get_clouds_thickness(double time = TiMe::Default()) const { return getFloat("clouds_thickness", time); }
47912
47916 bool set_clouds_phase_x(float val, double time = TiMe::Default()) { return setValue("clouds_phase_x", val, time); }
47920 float get_clouds_phase_x(double time = TiMe::Default()) const { return getFloat("clouds_phase_x", time); }
47921
47925 bool set_clouds_phase_y(float val, double time = TiMe::Default()) { return setValue("clouds_phase_y", val, time); }
47929 float get_clouds_phase_y(double time = TiMe::Default()) const { return getFloat("clouds_phase_y", time); }
47930
47934 bool set_clouds_enscape_compatibility(bool val, double time = TiMe::Default()) { return setValue("clouds_enscape_compatibility", val, time); }
47938 bool get_clouds_enscape_compatibility(double time = TiMe::Default()) const { return getBool("clouds_enscape_compatibility", time); }
47939
47943 bool set_clouds_density_multiplier(float val, double time = TiMe::Default()) { return setValue("clouds_density_multiplier", val, time); }
47947 float get_clouds_density_multiplier(double time = TiMe::Default()) const { return getFloat("clouds_density_multiplier", time); }
47948
47952 bool set_clouds_seed(int val, double time = TiMe::Default()) { return setValue("clouds_seed", val, time); }
47956 int get_clouds_seed(double time = TiMe::Default()) const { return getInt("clouds_seed", time); }
47957
47961 bool set_clouds_contrails_on(bool val, double time = TiMe::Default()) { return setValue("clouds_contrails_on", val, time); }
47965 bool get_clouds_contrails_on(double time = TiMe::Default()) const { return getBool("clouds_contrails_on", time); }
47966
47970 bool set_clouds_contrails_num_planes(int val, double time = TiMe::Default()) { return setValue("clouds_contrails_num_planes", val, time); }
47974 int get_clouds_contrails_num_planes(double time = TiMe::Default()) const { return getInt("clouds_contrails_num_planes", time); }
47975
47979 bool set_clouds_contrails_strength(float val, double time = TiMe::Default()) { return setValue("clouds_contrails_strength", val, time); }
47983 float get_clouds_contrails_strength(double time = TiMe::Default()) const { return getFloat("clouds_contrails_strength", time); }
47984
47988 bool set_clouds_contrails_distortion(float val, double time = TiMe::Default()) { return setValue("clouds_contrails_distortion", val, time); }
47992 float get_clouds_contrails_distortion(double time = TiMe::Default()) const { return getFloat("clouds_contrails_distortion", time); }
47993
47997 bool set_clouds_contrails_offset_x(float val, double time = TiMe::Default()) { return setValue("clouds_contrails_offset_x", val, time); }
48001 float get_clouds_contrails_offset_x(double time = TiMe::Default()) const { return getFloat("clouds_contrails_offset_x", time); }
48002
48006 bool set_clouds_contrails_offset_y(float val, double time = TiMe::Default()) { return setValue("clouds_contrails_offset_y", val, time); }
48010 float get_clouds_contrails_offset_y(double time = TiMe::Default()) const { return getFloat("clouds_contrails_offset_y", time); }
48011
48015 bool set_clouds_contrails_time(float val, double time = TiMe::Default()) { return setValue("clouds_contrails_time", val, time); }
48019 float get_clouds_contrails_time(double time = TiMe::Default()) const { return getFloat("clouds_contrails_time", time); }
48020};
48021
48023class TexAColor : public Plugin {
48024public:
48026 static constexpr const PluginTypeId getTypeId() { return 0x4AB257560; }
48028 static constexpr const char* getType() { return "TexAColor"; }
48029
48030 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
48031
48033 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
48035 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
48036
48039 bool set_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
48042 bool set_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
48045 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
48046};
48047
48049class TexAColorChannel : public Plugin {
48050public:
48052 static constexpr const PluginTypeId getTypeId() { return 0x77FD558F; }
48054 static constexpr const char* getType() { return "TexAColorChannel"; }
48055
48056 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
48057
48061 bool set_color_a(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
48065 bool set_color_a(const AColor& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
48069 Value get_color_a(double time = TiMe::Default()) const { return getValue("color_a", time); }
48070
48074 bool set_mult_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mult_a", texturefloat, time); }
48078 bool set_mult_a(float texturefloat, double time = TiMe::Default()) { return setValue("mult_a", texturefloat, time); }
48082 Value get_mult_a(double time = TiMe::Default()) const { return getValue("mult_a", time); }
48083
48087 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
48091 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
48092};
48093
48095class TexAColorOp : public Plugin {
48096public:
48098 static constexpr const PluginTypeId getTypeId() { return 0x7782F94E; }
48100 static constexpr const char* getType() { return "TexAColorOp"; }
48101
48102 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
48103
48107 bool set_color_a(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
48111 bool set_color_a(const AColor& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
48115 Value get_color_a(double time = TiMe::Default()) const { return getValue("color_a", time); }
48116
48119 bool set_color_b(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
48122 bool set_color_b(const AColor& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
48125 Value get_color_b(double time = TiMe::Default()) const { return getValue("color_b", time); }
48126
48130 bool set_mult_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mult_a", texturefloat, time); }
48134 bool set_mult_a(float texturefloat, double time = TiMe::Default()) { return setValue("mult_a", texturefloat, time); }
48138 Value get_mult_a(double time = TiMe::Default()) const { return getValue("mult_a", time); }
48139
48143 bool set_mult_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mult_b", texturefloat, time); }
48147 bool set_mult_b(float texturefloat, double time = TiMe::Default()) { return setValue("mult_b", texturefloat, time); }
48151 Value get_mult_b(double time = TiMe::Default()) const { return getValue("mult_b", time); }
48152
48155 bool set_result_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("result_alpha", texturefloat, time); }
48158 bool set_result_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("result_alpha", texturefloat, time); }
48161 Value get_result_alpha(double time = TiMe::Default()) const { return getValue("result_alpha", time); }
48162
48166 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
48170 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
48171
48173 PluginRef out_product() const { return PluginRef(*this, "product"); }
48174
48176 PluginRef out_division() const { return PluginRef(*this, "division"); }
48177
48179 PluginRef out_minimum() const { return PluginRef(*this, "minimum"); }
48180
48182 PluginRef out_maximum() const { return PluginRef(*this, "maximum"); }
48183
48185 PluginRef out_sum() const { return PluginRef(*this, "sum"); }
48186
48188 PluginRef out_difference() const { return PluginRef(*this, "difference"); }
48189
48191 PluginRef out_absolute_difference() const { return PluginRef(*this, "absolute_difference"); }
48192
48194 PluginRef out_lower_intensity_color() const { return PluginRef(*this, "lower_intensity_color"); }
48195
48197 PluginRef out_greater_intensity_color() const { return PluginRef(*this, "greater_intensity_color"); }
48198
48200 PluginRef out_result_a() const { return PluginRef(*this, "result_a"); }
48201
48203 PluginRef out_result_b() const { return PluginRef(*this, "result_b"); }
48204
48206 PluginRef out_red() const { return PluginRef(*this, "red"); }
48207
48209 PluginRef out_green() const { return PluginRef(*this, "green"); }
48210
48212 PluginRef out_blue() const { return PluginRef(*this, "blue"); }
48213
48215 PluginRef out_alpha() const { return PluginRef(*this, "alpha"); }
48216
48218 PluginRef out_intensity() const { return PluginRef(*this, "intensity"); }
48219
48221 PluginRef out_power() const { return PluginRef(*this, "power"); }
48222
48224 PluginRef out_sin() const { return PluginRef(*this, "sin"); }
48225
48227 PluginRef out_cos() const { return PluginRef(*this, "cos"); }
48228
48230 PluginRef out_asin() const { return PluginRef(*this, "asin"); }
48231
48233 PluginRef out_acos() const { return PluginRef(*this, "acos"); }
48234
48236 PluginRef out_atan() const { return PluginRef(*this, "atan"); }
48237
48239 PluginRef out_atan2() const { return PluginRef(*this, "atan2"); }
48240
48242 PluginRef out_abs() const { return PluginRef(*this, "abs"); }
48243
48245 PluginRef out_ceil() const { return PluginRef(*this, "ceil"); }
48246
48248 PluginRef out_exp() const { return PluginRef(*this, "exp"); }
48249
48251 PluginRef out_floor() const { return PluginRef(*this, "floor"); }
48252
48254 PluginRef out_log() const { return PluginRef(*this, "log"); }
48255
48257 PluginRef out_log10() const { return PluginRef(*this, "log10"); }
48258
48260 PluginRef out_sqrt() const { return PluginRef(*this, "sqrt"); }
48261
48263 PluginRef out_fmod() const { return PluginRef(*this, "fmod"); }
48264
48266 PluginRef out_average() const { return PluginRef(*this, "average"); }
48267
48269 PluginRef out_tan() const { return PluginRef(*this, "tan"); }
48270
48272 PluginRef out_bias_schlick() const { return PluginRef(*this, "bias_schlick"); }
48273
48275 PluginRef out_gain_schlick() const { return PluginRef(*this, "gain_schlick"); }
48276
48278 PluginRef out_bias_perlin() const { return PluginRef(*this, "bias_perlin"); }
48279
48281 PluginRef out_gain_perlin() const { return PluginRef(*this, "gain_perlin"); }
48282};
48283
48286public:
48288 static constexpr const PluginTypeId getTypeId() { return 0x781C5009; }
48290 static constexpr const char* getType() { return "TexAnimationCurve"; }
48291
48292 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
48293
48296 bool set_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
48299 bool set_input(float texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
48302 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
48303
48306 bool set_points(const FloatList& floatList, double time = TiMe::Default()) { return setValue("points", floatList, time); }
48307 bool set_points(FloatList&& floatList, double time = TiMe::Default()) { return setValue("points", std::move(floatList), time); }
48308 bool set_points(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("points", floats, count, time); }
48309 template<size_t count> bool set_points(const float (&floats)[count], double time = TiMe::Default()) { return setArray("points", floats, count, time); }
48312 FloatList get_points(double time = TiMe::Default()) const { return getFloatList("points", time); }
48313
48317 bool set_tangent_types(const IntList& intList, double time = TiMe::Default()) { return setValue("tangent_types", intList, time); }
48318 bool set_tangent_types(IntList&& intList, double time = TiMe::Default()) { return setValue("tangent_types", std::move(intList), time); }
48319 bool set_tangent_types(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("tangent_types", ints, count, time); }
48320 template<size_t count> bool set_tangent_types(const int (&ints)[count], double time = TiMe::Default()) { return setArray("tangent_types", ints, count, time); }
48324 IntList get_tangent_types(double time = TiMe::Default()) const { return getIntList("tangent_types", time); }
48325
48329 bool set_pre_infinity_type(int val, double time = TiMe::Default()) { return setValue("pre_infinity_type", val, time); }
48333 int get_pre_infinity_type(double time = TiMe::Default()) const { return getInt("pre_infinity_type", time); }
48334
48338 bool set_post_infinity_type(int val, double time = TiMe::Default()) { return setValue("post_infinity_type", val, time); }
48342 int get_post_infinity_type(double time = TiMe::Default()) const { return getInt("post_infinity_type", time); }
48343
48346 bool set_weighted(bool val, double time = TiMe::Default()) { return setValue("weighted", val, time); }
48349 bool get_weighted(double time = TiMe::Default()) const { return getBool("weighted", time); }
48350};
48351
48354public:
48356 static constexpr const PluginTypeId getTypeId() { return 0xBFCBA4D; }
48358 static constexpr const char* getType() { return "TexBerconDistortion"; }
48359
48360 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
48361
48365 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
48369 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
48370
48374 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
48378 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
48379
48383 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
48387 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
48388
48392 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
48396 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
48397
48401 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
48405 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
48409 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
48410
48414 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
48418 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
48422 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
48423
48427 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
48431 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
48435 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
48436
48440 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
48444 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
48448 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
48449
48453 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
48457 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
48461 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
48462
48464 PluginRef out_color() const { return PluginRef(*this, "color"); }
48465
48467 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
48468
48470 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
48471
48473 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
48474
48477 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
48480 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
48481
48485 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
48489 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
48490
48494 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
48498 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
48499
48503 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
48507 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
48508
48512 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
48516 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
48517
48521 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
48525 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
48526
48530 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
48534 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
48535
48539 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
48543 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
48544
48548 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
48552 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
48553
48557 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
48561 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
48562
48566 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
48570 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
48571
48575 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
48579 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
48580
48584 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
48588 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
48589
48593 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
48597 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
48598
48602 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
48606 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
48607
48610 bool set_cam_space(bool val, double time = TiMe::Default()) { return setValue("cam_space", val, time); }
48613 bool get_cam_space(double time = TiMe::Default()) const { return getBool("cam_space", time); }
48614
48616 bool set_map_source(const PluginRef& texture, double time = TiMe::Default()) { return setValue("map_source", texture, time); }
48618 bool set_map_source(const AColor& texture, double time = TiMe::Default()) { return setValue("map_source", texture, time); }
48620 Value get_map_source(double time = TiMe::Default()) const { return getValue("map_source", time); }
48621
48623 bool set_dist_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
48625 bool set_dist_map(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
48627 Value get_dist_map(double time = TiMe::Default()) const { return getValue("dist_map", time); }
48628
48630 bool set_dist_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
48632 bool set_dist_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
48634 Value get_dist_map2(double time = TiMe::Default()) const { return getValue("dist_map2", time); }
48635
48638 bool set_dist_str(float val, double time = TiMe::Default()) { return setValue("dist_str", val, time); }
48641 float get_dist_str(double time = TiMe::Default()) const { return getFloat("dist_str", time); }
48642
48645 bool set_use_dist(bool val, double time = TiMe::Default()) { return setValue("use_dist", val, time); }
48648 bool get_use_dist(double time = TiMe::Default()) const { return getBool("use_dist", time); }
48649};
48650
48652class TexBerconGrad : public Plugin {
48653public:
48655 static constexpr const PluginTypeId getTypeId() { return 0xBFCAB11; }
48657 static constexpr const char* getType() { return "TexBerconGrad"; }
48658
48659 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
48660
48664 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
48668 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
48669
48673 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
48677 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
48678
48682 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
48686 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
48687
48691 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
48695 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
48696
48700 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
48704 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
48708 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
48709
48713 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
48717 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
48721 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
48722
48726 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
48730 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
48734 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
48735
48739 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
48743 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
48747 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
48748
48752 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
48756 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
48760 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
48761
48763 PluginRef out_color() const { return PluginRef(*this, "color"); }
48764
48766 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
48767
48769 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
48770
48772 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
48773
48776 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
48779 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
48780
48784 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
48788 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
48789
48793 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
48797 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
48798
48802 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
48806 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
48807
48811 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
48815 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
48816
48820 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
48824 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
48825
48829 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
48833 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
48834
48838 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
48842 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
48843
48847 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
48851 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
48852
48856 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
48860 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
48861
48865 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
48869 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
48870
48874 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
48878 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
48879
48883 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
48887 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
48888
48892 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
48896 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
48897
48901 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
48905 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
48906
48909 bool set_cam_space(bool val, double time = TiMe::Default()) { return setValue("cam_space", val, time); }
48912 bool get_cam_space(double time = TiMe::Default()) const { return getBool("cam_space", time); }
48913
48917 bool set_positions(float val, double time = TiMe::Default()) { return setValue("positions", val, time); }
48921 float get_positions(double time = TiMe::Default()) const { return getFloat("positions", time); }
48922
48925 bool set_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("colors", textureList, time); }
48926 bool set_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("colors", std::move(textureList), time); }
48927 bool set_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("colors", textures, count, time); }
48928 template<size_t count> bool set_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("colors", textures, count, time); }
48929 template<size_t count> bool set_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("colors", textures, count, time); }
48932 ValueList get_colors(double time = TiMe::Default()) const { return getValueList("colors", time); }
48933
48936 bool set_texture_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
48939 bool set_texture_map(const AColor& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
48942 Value get_texture_map(double time = TiMe::Default()) const { return getValue("texture_map", time); }
48943
48947 bool set_gradient_type(int val, double time = TiMe::Default()) { return setValue("gradient_type", val, time); }
48951 int get_gradient_type(double time = TiMe::Default()) const { return getInt("gradient_type", time); }
48952
48956 bool set_interpolation(int val, double time = TiMe::Default()) { return setValue("interpolation", val, time); }
48960 int get_interpolation(double time = TiMe::Default()) const { return getInt("interpolation", time); }
48961
48965 bool set_ior(float val, double time = TiMe::Default()) { return setValue("ior", val, time); }
48969 float get_ior(double time = TiMe::Default()) const { return getFloat("ior", time); }
48970
48974 bool set_reverse(int val, double time = TiMe::Default()) { return setValue("reverse", val, time); }
48978 int get_reverse(double time = TiMe::Default()) const { return getInt("reverse", time); }
48979
48983 bool set_range_min(float val, double time = TiMe::Default()) { return setValue("range_min", val, time); }
48987 float get_range_min(double time = TiMe::Default()) const { return getFloat("range_min", time); }
48988
48992 bool set_range_max(float val, double time = TiMe::Default()) { return setValue("range_max", val, time); }
48996 float get_range_max(double time = TiMe::Default()) const { return getFloat("range_max", time); }
48997
49001 bool set_range_loop(int val, double time = TiMe::Default()) { return setValue("range_loop", val, time); }
49005 int get_range_loop(double time = TiMe::Default()) const { return getInt("range_loop", time); }
49006
49010 bool set_use_dist(int val, double time = TiMe::Default()) { return setValue("use_dist", val, time); }
49014 int get_use_dist(double time = TiMe::Default()) const { return getInt("use_dist", time); }
49015
49019 bool set_dist_str(float val, double time = TiMe::Default()) { return setValue("dist_str", val, time); }
49023 float get_dist_str(double time = TiMe::Default()) const { return getFloat("dist_str", time); }
49024
49027 bool set_dist_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
49030 bool set_dist_map(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
49033 Value get_dist_map(double time = TiMe::Default()) const { return getValue("dist_map", time); }
49034
49038 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
49042 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
49043
49047 bool set_normal_type(int val, double time = TiMe::Default()) { return setValue("normal_type", val, time); }
49051 int get_normal_type(double time = TiMe::Default()) const { return getInt("normal_type", time); }
49052
49056 bool set_normal_function(int val, double time = TiMe::Default()) { return setValue("normal_function", val, time); }
49060 int get_normal_function(double time = TiMe::Default()) const { return getInt("normal_function", time); }
49061
49065 bool set_use_curve_input(bool val, double time = TiMe::Default()) { return setValue("use_curve_input", val, time); }
49069 bool get_use_curve_input(double time = TiMe::Default()) const { return getBool("use_curve_input", time); }
49070
49072 PluginRef out_curve_output() const { return PluginRef(*this, "curve_output"); }
49073
49077 bool set_curve_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("curve_input", texturefloat, time); }
49081 bool set_curve_input(float texturefloat, double time = TiMe::Default()) { return setValue("curve_input", texturefloat, time); }
49085 Value get_curve_input(double time = TiMe::Default()) const { return getValue("curve_input", time); }
49086};
49087
49089class TexBerconNoise : public Plugin {
49090public:
49092 static constexpr const PluginTypeId getTypeId() { return 0xBFCB9FD; }
49094 static constexpr const char* getType() { return "TexBerconNoise"; }
49095
49096 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
49097
49101 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
49105 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
49106
49110 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
49114 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
49115
49119 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
49123 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
49124
49128 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
49132 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
49133
49137 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
49141 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
49145 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
49146
49150 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
49154 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
49158 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
49159
49163 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
49167 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
49171 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
49172
49176 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
49180 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
49184 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
49185
49189 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
49193 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
49197 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
49198
49200 PluginRef out_color() const { return PluginRef(*this, "color"); }
49201
49203 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
49204
49206 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
49207
49209 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
49210
49213 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
49216 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
49217
49221 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
49225 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
49226
49230 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
49234 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
49235
49239 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
49243 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
49244
49248 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
49252 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
49253
49257 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
49261 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
49262
49266 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
49270 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
49271
49275 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
49279 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
49280
49284 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
49288 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
49289
49293 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
49297 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
49298
49302 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
49306 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
49307
49311 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
49315 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
49316
49320 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
49324 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
49325
49329 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
49333 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
49334
49338 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
49342 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
49343
49346 bool set_cam_space(bool val, double time = TiMe::Default()) { return setValue("cam_space", val, time); }
49349 bool get_cam_space(double time = TiMe::Default()) const { return getBool("cam_space", time); }
49350
49354 bool set_noise_color1(const Color& color, double time = TiMe::Default()) { return setValue("noise_color1", color, time); }
49358 Color get_noise_color1(double time = TiMe::Default()) const { return getColor("noise_color1", time); }
49359
49363 bool set_noise_color2(const Color& color, double time = TiMe::Default()) { return setValue("noise_color2", color, time); }
49367 Color get_noise_color2(double time = TiMe::Default()) const { return getColor("noise_color2", time); }
49368
49371 bool set_noise_map1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map1", texture, time); }
49374 bool set_noise_map1(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map1", texture, time); }
49377 Value get_noise_map1(double time = TiMe::Default()) const { return getValue("noise_map1", time); }
49378
49381 bool set_noise_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map2", texture, time); }
49384 bool set_noise_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map2", texture, time); }
49387 Value get_noise_map2(double time = TiMe::Default()) const { return getValue("noise_map2", time); }
49388
49392 bool set_noise_size(float val, double time = TiMe::Default()) { return setValue("noise_size", val, time); }
49396 float get_noise_size(double time = TiMe::Default()) const { return getFloat("noise_size", time); }
49397
49401 bool set_low_tresh(float val, double time = TiMe::Default()) { return setValue("low_tresh", val, time); }
49405 float get_low_tresh(double time = TiMe::Default()) const { return getFloat("low_tresh", time); }
49406
49410 bool set_high_tresh(float val, double time = TiMe::Default()) { return setValue("high_tresh", val, time); }
49414 float get_high_tresh(double time = TiMe::Default()) const { return getFloat("high_tresh", time); }
49415
49419 bool set_uvw_dist(int val, double time = TiMe::Default()) { return setValue("uvw_dist", val, time); }
49423 int get_uvw_dist(double time = TiMe::Default()) const { return getInt("uvw_dist", time); }
49424
49428 bool set_noise_function(int val, double time = TiMe::Default()) { return setValue("noise_function", val, time); }
49432 int get_noise_function(double time = TiMe::Default()) const { return getInt("noise_function", time); }
49433
49437 bool set_noise_phase(float val, double time = TiMe::Default()) { return setValue("noise_phase", val, time); }
49441 float get_noise_phase(double time = TiMe::Default()) const { return getFloat("noise_phase", time); }
49442
49446 bool set_worley_spread(float val, double time = TiMe::Default()) { return setValue("worley_spread", val, time); }
49450 float get_worley_spread(double time = TiMe::Default()) const { return getFloat("worley_spread", time); }
49451
49455 bool set_worley_F1(float val, double time = TiMe::Default()) { return setValue("worley_F1", val, time); }
49459 float get_worley_F1(double time = TiMe::Default()) const { return getFloat("worley_F1", time); }
49460
49464 bool set_worley_F2(float val, double time = TiMe::Default()) { return setValue("worley_F2", val, time); }
49468 float get_worley_F2(double time = TiMe::Default()) const { return getFloat("worley_F2", time); }
49469
49473 bool set_worley_F3(float val, double time = TiMe::Default()) { return setValue("worley_F3", val, time); }
49477 float get_worley_F3(double time = TiMe::Default()) const { return getFloat("worley_F3", time); }
49478
49482 bool set_worley_F4(float val, double time = TiMe::Default()) { return setValue("worley_F4", val, time); }
49486 float get_worley_F4(double time = TiMe::Default()) const { return getFloat("worley_F4", time); }
49487
49491 bool set_worley_distance(int val, double time = TiMe::Default()) { return setValue("worley_distance", val, time); }
49495 int get_worley_distance(double time = TiMe::Default()) const { return getInt("worley_distance", time); }
49496
49500 bool set_fractal_type(int val, double time = TiMe::Default()) { return setValue("fractal_type", val, time); }
49504 int get_fractal_type(double time = TiMe::Default()) const { return getInt("fractal_type", time); }
49505
49509 bool set_fractal_levels(float val, double time = TiMe::Default()) { return setValue("fractal_levels", val, time); }
49513 float get_fractal_levels(double time = TiMe::Default()) const { return getFloat("fractal_levels", time); }
49514
49518 bool set_fractal_offset(float val, double time = TiMe::Default()) { return setValue("fractal_offset", val, time); }
49522 float get_fractal_offset(double time = TiMe::Default()) const { return getFloat("fractal_offset", time); }
49523
49527 bool set_fractal_gain(float val, double time = TiMe::Default()) { return setValue("fractal_gain", val, time); }
49531 float get_fractal_gain(double time = TiMe::Default()) const { return getFloat("fractal_gain", time); }
49532
49536 bool set_fractal_lacunarity(float val, double time = TiMe::Default()) { return setValue("fractal_lacunarity", val, time); }
49540 float get_fractal_lacunarity(double time = TiMe::Default()) const { return getFloat("fractal_lacunarity", time); }
49541
49545 bool set_fractal_H(float val, double time = TiMe::Default()) { return setValue("fractal_H", val, time); }
49549 float get_fractal_H(double time = TiMe::Default()) const { return getFloat("fractal_H", time); }
49550
49554 bool set_use_dist(bool val, double time = TiMe::Default()) { return setValue("use_dist", val, time); }
49558 bool get_use_dist(double time = TiMe::Default()) const { return getBool("use_dist", time); }
49559
49563 bool set_dist_str(float val, double time = TiMe::Default()) { return setValue("dist_str", val, time); }
49567 float get_dist_str(double time = TiMe::Default()) const { return getFloat("dist_str", time); }
49568
49571 bool set_dist_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
49574 bool set_dist_map(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
49577 Value get_dist_map(double time = TiMe::Default()) const { return getValue("dist_map", time); }
49578
49581 bool set_dist_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
49584 bool set_dist_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
49587 Value get_dist_map2(double time = TiMe::Default()) const { return getValue("dist_map2", time); }
49588
49591 bool set_tex_size(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_size", texture, time); }
49594 bool set_tex_size(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_size", texture, time); }
49597 Value get_tex_size(double time = TiMe::Default()) const { return getValue("tex_size", time); }
49598
49601 bool set_tex_low(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_low", texture, time); }
49604 bool set_tex_low(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_low", texture, time); }
49607 Value get_tex_low(double time = TiMe::Default()) const { return getValue("tex_low", time); }
49608
49611 bool set_tex_high(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_high", texture, time); }
49614 bool set_tex_high(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_high", texture, time); }
49617 Value get_tex_high(double time = TiMe::Default()) const { return getValue("tex_high", time); }
49618
49621 bool set_tex_phase(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_phase", texture, time); }
49624 bool set_tex_phase(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_phase", texture, time); }
49627 Value get_tex_phase(double time = TiMe::Default()) const { return getValue("tex_phase", time); }
49628
49631 bool set_tex_spread(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_spread", texture, time); }
49634 bool set_tex_spread(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_spread", texture, time); }
49637 Value get_tex_spread(double time = TiMe::Default()) const { return getValue("tex_spread", time); }
49638
49641 bool set_tex_F1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_F1", texture, time); }
49644 bool set_tex_F1(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_F1", texture, time); }
49647 Value get_tex_F1(double time = TiMe::Default()) const { return getValue("tex_F1", time); }
49648
49651 bool set_tex_F2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_F2", texture, time); }
49654 bool set_tex_F2(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_F2", texture, time); }
49657 Value get_tex_F2(double time = TiMe::Default()) const { return getValue("tex_F2", time); }
49658
49661 bool set_tex_F3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_F3", texture, time); }
49664 bool set_tex_F3(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_F3", texture, time); }
49667 Value get_tex_F3(double time = TiMe::Default()) const { return getValue("tex_F3", time); }
49668
49671 bool set_tex_F4(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_F4", texture, time); }
49674 bool set_tex_F4(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_F4", texture, time); }
49677 Value get_tex_F4(double time = TiMe::Default()) const { return getValue("tex_F4", time); }
49678
49681 bool set_tex_levels(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_levels", texture, time); }
49684 bool set_tex_levels(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_levels", texture, time); }
49687 Value get_tex_levels(double time = TiMe::Default()) const { return getValue("tex_levels", time); }
49688
49691 bool set_tex_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_offset", texture, time); }
49694 bool set_tex_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_offset", texture, time); }
49697 Value get_tex_offset(double time = TiMe::Default()) const { return getValue("tex_offset", time); }
49698
49701 bool set_tex_gain(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_gain", texture, time); }
49704 bool set_tex_gain(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_gain", texture, time); }
49707 Value get_tex_gain(double time = TiMe::Default()) const { return getValue("tex_gain", time); }
49708
49711 bool set_tex_lacunarity(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_lacunarity", texture, time); }
49714 bool set_tex_lacunarity(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_lacunarity", texture, time); }
49717 Value get_tex_lacunarity(double time = TiMe::Default()) const { return getValue("tex_lacunarity", time); }
49718
49721 bool set_tex_exponent(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_exponent", texture, time); }
49724 bool set_tex_exponent(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_exponent", texture, time); }
49727 Value get_tex_exponent(double time = TiMe::Default()) const { return getValue("tex_exponent", time); }
49728
49732 bool set_use_curve_input(bool val, double time = TiMe::Default()) { return setValue("use_curve_input", val, time); }
49736 bool get_use_curve_input(double time = TiMe::Default()) const { return getBool("use_curve_input", time); }
49737
49739 PluginRef out_curve_output() const { return PluginRef(*this, "curve_output"); }
49740
49744 bool set_curve_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("curve_input", texturefloat, time); }
49748 bool set_curve_input(float texturefloat, double time = TiMe::Default()) { return setValue("curve_input", texturefloat, time); }
49752 Value get_curve_input(double time = TiMe::Default()) const { return getValue("curve_input", time); }
49753};
49754
49756class TexBerconTile : public Plugin {
49757public:
49759 static constexpr const PluginTypeId getTypeId() { return 0xBFCB9CB; }
49761 static constexpr const char* getType() { return "TexBerconTile"; }
49762
49763 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
49764
49768 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
49772 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
49773
49777 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
49781 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
49782
49786 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
49790 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
49791
49795 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
49799 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
49800
49804 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
49808 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
49812 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
49813
49817 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
49821 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
49825 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
49826
49830 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
49834 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
49838 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
49839
49843 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
49847 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
49851 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
49852
49856 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
49860 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
49864 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
49865
49867 PluginRef out_color() const { return PluginRef(*this, "color"); }
49868
49870 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
49871
49873 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
49874
49876 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
49877
49880 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
49883 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
49884
49888 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
49892 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
49893
49897 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
49901 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
49902
49906 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
49910 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
49911
49915 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
49919 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
49920
49924 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
49928 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
49929
49933 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
49937 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
49938
49942 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
49946 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
49947
49951 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
49955 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
49956
49960 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
49964 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
49965
49969 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
49973 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
49974
49978 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
49982 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
49983
49987 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
49991 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
49992
49996 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
50000 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
50001
50005 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
50009 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
50010
50013 bool set_cam_space(bool val, double time = TiMe::Default()) { return setValue("cam_space", val, time); }
50016 bool get_cam_space(double time = TiMe::Default()) const { return getBool("cam_space", time); }
50017
50021 bool set_noise_color1(const Color& color, double time = TiMe::Default()) { return setValue("noise_color1", color, time); }
50025 Color get_noise_color1(double time = TiMe::Default()) const { return getColor("noise_color1", time); }
50026
50030 bool set_noise_color2(const Color& color, double time = TiMe::Default()) { return setValue("noise_color2", color, time); }
50034 Color get_noise_color2(double time = TiMe::Default()) const { return getColor("noise_color2", time); }
50035
50039 bool set_noise_color3(const Color& color, double time = TiMe::Default()) { return setValue("noise_color3", color, time); }
50043 Color get_noise_color3(double time = TiMe::Default()) const { return getColor("noise_color3", time); }
50044
50047 bool set_noise_map1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map1", texture, time); }
50050 bool set_noise_map1(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map1", texture, time); }
50053 Value get_noise_map1(double time = TiMe::Default()) const { return getValue("noise_map1", time); }
50054
50057 bool set_noise_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map2", texture, time); }
50060 bool set_noise_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map2", texture, time); }
50063 Value get_noise_map2(double time = TiMe::Default()) const { return getValue("noise_map2", time); }
50064
50068 bool set_lock_edge(bool val, double time = TiMe::Default()) { return setValue("lock_edge", val, time); }
50072 bool get_lock_edge(double time = TiMe::Default()) const { return getBool("lock_edge", time); }
50073
50076 bool set_noise_map3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map3", texture, time); }
50079 bool set_noise_map3(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map3", texture, time); }
50082 Value get_noise_map3(double time = TiMe::Default()) const { return getValue("noise_map3", time); }
50083
50087 bool set_tile_size(float val, double time = TiMe::Default()) { return setValue("tile_size", val, time); }
50091 float get_tile_size(double time = TiMe::Default()) const { return getFloat("tile_size", time); }
50092
50096 bool set_tile_style(int val, double time = TiMe::Default()) { return setValue("tile_style", val, time); }
50100 int get_tile_style(double time = TiMe::Default()) const { return getInt("tile_style", time); }
50101
50105 bool set_tile_width(float val, double time = TiMe::Default()) { return setValue("tile_width", val, time); }
50109 float get_tile_width(double time = TiMe::Default()) const { return getFloat("tile_width", time); }
50110
50114 bool set_tile_height(float val, double time = TiMe::Default()) { return setValue("tile_height", val, time); }
50118 float get_tile_height(double time = TiMe::Default()) const { return getFloat("tile_height", time); }
50119
50123 bool set_edge_width(float val, double time = TiMe::Default()) { return setValue("edge_width", val, time); }
50127 float get_edge_width(double time = TiMe::Default()) const { return getFloat("edge_width", time); }
50128
50132 bool set_edge_height(float val, double time = TiMe::Default()) { return setValue("edge_height", val, time); }
50136 float get_edge_height(double time = TiMe::Default()) const { return getFloat("edge_height", time); }
50137
50141 bool set_tile_width2(float val, double time = TiMe::Default()) { return setValue("tile_width2", val, time); }
50145 float get_tile_width2(double time = TiMe::Default()) const { return getFloat("tile_width2", time); }
50146
50150 bool set_tile_height2(float val, double time = TiMe::Default()) { return setValue("tile_height2", val, time); }
50154 float get_tile_height2(double time = TiMe::Default()) const { return getFloat("tile_height2", time); }
50155
50159 bool set_edge_width2(float val, double time = TiMe::Default()) { return setValue("edge_width2", val, time); }
50163 float get_edge_width2(double time = TiMe::Default()) const { return getFloat("edge_width2", time); }
50164
50168 bool set_edge_height2(float val, double time = TiMe::Default()) { return setValue("edge_height2", val, time); }
50172 float get_edge_height2(double time = TiMe::Default()) const { return getFloat("edge_height2", time); }
50173
50177 bool set_soften(int val, double time = TiMe::Default()) { return setValue("soften", val, time); }
50181 int get_soften(double time = TiMe::Default()) const { return getInt("soften", time); }
50182
50186 bool set_soften_rad(float val, double time = TiMe::Default()) { return setValue("soften_rad", val, time); }
50190 float get_soften_rad(double time = TiMe::Default()) const { return getFloat("soften_rad", time); }
50191
50195 bool set_round(bool val, double time = TiMe::Default()) { return setValue("round", val, time); }
50199 bool get_round(double time = TiMe::Default()) const { return getBool("round", time); }
50200
50204 bool set_round_rad(float val, double time = TiMe::Default()) { return setValue("round_rad", val, time); }
50208 float get_round_rad(double time = TiMe::Default()) const { return getFloat("round_rad", time); }
50209
50213 bool set_map_uv(bool val, double time = TiMe::Default()) { return setValue("map_uv", val, time); }
50217 bool get_map_uv(double time = TiMe::Default()) const { return getBool("map_uv", time); }
50218
50222 bool set_uv_channel(int val, double time = TiMe::Default()) { return setValue("uv_channel", val, time); }
50226 int get_uv_channel(double time = TiMe::Default()) const { return getInt("uv_channel", time); }
50227
50231 bool set_auto(int val, double time = TiMe::Default()) { return setValue("auto", val, time); }
50235 int get_auto(double time = TiMe::Default()) const { return getInt("auto", time); }
50236
50240 bool set_rand_X(float val, double time = TiMe::Default()) { return setValue("rand_X", val, time); }
50244 float get_rand_X(double time = TiMe::Default()) const { return getFloat("rand_X", time); }
50245
50249 bool set_rand_Y(float val, double time = TiMe::Default()) { return setValue("rand_Y", val, time); }
50253 float get_rand_Y(double time = TiMe::Default()) const { return getFloat("rand_Y", time); }
50254
50258 bool set_rand_SX(float val, double time = TiMe::Default()) { return setValue("rand_SX", val, time); }
50262 float get_rand_SX(double time = TiMe::Default()) const { return getFloat("rand_SX", time); }
50263
50267 bool set_rand_SY(float val, double time = TiMe::Default()) { return setValue("rand_SY", val, time); }
50271 float get_rand_SY(double time = TiMe::Default()) const { return getFloat("rand_SY", time); }
50272
50276 bool set_lock(bool val, double time = TiMe::Default()) { return setValue("lock", val, time); }
50280 bool get_lock(double time = TiMe::Default()) const { return getBool("lock", time); }
50281
50285 bool set_rot_uv(int val, double time = TiMe::Default()) { return setValue("rot_uv", val, time); }
50289 int get_rot_uv(double time = TiMe::Default()) const { return getInt("rot_uv", time); }
50290
50294 bool set_rand_rot(float val, double time = TiMe::Default()) { return setValue("rand_rot", val, time); }
50298 float get_rand_rot(double time = TiMe::Default()) const { return getFloat("rand_rot", time); }
50299
50303 bool set_flip_X(bool val, double time = TiMe::Default()) { return setValue("flip_X", val, time); }
50307 bool get_flip_X(double time = TiMe::Default()) const { return getBool("flip_X", time); }
50308
50312 bool set_flip_Y(bool val, double time = TiMe::Default()) { return setValue("flip_Y", val, time); }
50316 bool get_flip_Y(double time = TiMe::Default()) const { return getBool("flip_Y", time); }
50317
50321 bool set_center(bool val, double time = TiMe::Default()) { return setValue("center", val, time); }
50325 bool get_center(double time = TiMe::Default()) const { return getBool("center", time); }
50326
50330 bool set_center_channel(int val, double time = TiMe::Default()) { return setValue("center_channel", val, time); }
50334 int get_center_channel(double time = TiMe::Default()) const { return getInt("center_channel", time); }
50335
50339 bool set_rand_Z(bool val, double time = TiMe::Default()) { return setValue("rand_Z", val, time); }
50343 bool get_rand_Z(double time = TiMe::Default()) const { return getBool("rand_Z", time); }
50344
50348 bool set_pattern(const char* str, double time = TiMe::Default()) { return setValue("pattern", str, time); }
50352 bool set_pattern(const std::string& str, double time = TiMe::Default()) { return setValue("pattern", str, time); }
50356 std::string get_pattern(double time = TiMe::Default()) const { return getString("pattern", time); }
50357
50361 bool set_use_dist(bool val, double time = TiMe::Default()) { return setValue("use_dist", val, time); }
50365 bool get_use_dist(double time = TiMe::Default()) const { return getBool("use_dist", time); }
50366
50370 bool set_dist_str(float val, double time = TiMe::Default()) { return setValue("dist_str", val, time); }
50374 float get_dist_str(double time = TiMe::Default()) const { return getFloat("dist_str", time); }
50375
50378 bool set_dist_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
50381 bool set_dist_map(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
50384 Value get_dist_map(double time = TiMe::Default()) const { return getValue("dist_map", time); }
50385
50388 bool set_dist_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
50391 bool set_dist_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
50394 Value get_dist_map2(double time = TiMe::Default()) const { return getValue("dist_map2", time); }
50395
50398 bool set_tex_soften_rad(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_soften_rad", texture, time); }
50401 bool set_tex_soften_rad(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_soften_rad", texture, time); }
50404 Value get_tex_soften_rad(double time = TiMe::Default()) const { return getValue("tex_soften_rad", time); }
50405
50408 bool set_tex_round_rad(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_round_rad", texture, time); }
50411 bool set_tex_round_rad(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_round_rad", texture, time); }
50414 Value get_tex_round_rad(double time = TiMe::Default()) const { return getValue("tex_round_rad", time); }
50415};
50416
50418class TexBerconWood : public Plugin {
50419public:
50421 static constexpr const PluginTypeId getTypeId() { return 0xBFCB1FB; }
50423 static constexpr const char* getType() { return "TexBerconWood"; }
50424
50425 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
50426
50430 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
50434 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
50435
50439 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
50443 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
50444
50448 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
50452 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
50453
50457 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
50461 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
50462
50466 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
50470 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
50474 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
50475
50479 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
50483 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
50487 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
50488
50492 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
50496 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
50500 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
50501
50505 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
50509 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
50513 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
50514
50518 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
50522 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
50526 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
50527
50529 PluginRef out_color() const { return PluginRef(*this, "color"); }
50530
50532 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
50533
50535 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
50536
50538 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
50539
50542 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
50545 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
50546
50550 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
50554 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
50555
50559 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
50563 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
50564
50568 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
50572 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
50573
50577 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
50581 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
50582
50586 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
50590 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
50591
50595 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
50599 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
50600
50604 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
50608 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
50609
50613 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
50617 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
50618
50622 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
50626 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
50627
50631 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
50635 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
50636
50640 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
50644 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
50645
50649 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
50653 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
50654
50658 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
50662 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
50663
50667 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
50671 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
50672
50675 bool set_cam_space(bool val, double time = TiMe::Default()) { return setValue("cam_space", val, time); }
50678 bool get_cam_space(double time = TiMe::Default()) const { return getBool("cam_space", time); }
50679
50683 bool set_noise_color1(const Color& color, double time = TiMe::Default()) { return setValue("noise_color1", color, time); }
50687 Color get_noise_color1(double time = TiMe::Default()) const { return getColor("noise_color1", time); }
50688
50692 bool set_noise_color2(const Color& color, double time = TiMe::Default()) { return setValue("noise_color2", color, time); }
50696 Color get_noise_color2(double time = TiMe::Default()) const { return getColor("noise_color2", time); }
50697
50701 bool set_noise_color3(const Color& color, double time = TiMe::Default()) { return setValue("noise_color3", color, time); }
50705 Color get_noise_color3(double time = TiMe::Default()) const { return getColor("noise_color3", time); }
50706
50709 bool set_noise_map1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map1", texture, time); }
50712 bool set_noise_map1(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map1", texture, time); }
50715 Value get_noise_map1(double time = TiMe::Default()) const { return getValue("noise_map1", time); }
50716
50719 bool set_noise_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map2", texture, time); }
50722 bool set_noise_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map2", texture, time); }
50725 Value get_noise_map2(double time = TiMe::Default()) const { return getValue("noise_map2", time); }
50726
50730 bool set_grain_lock(bool val, double time = TiMe::Default()) { return setValue("grain_lock", val, time); }
50734 bool get_grain_lock(double time = TiMe::Default()) const { return getBool("grain_lock", time); }
50735
50738 bool set_noise_map3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("noise_map3", texture, time); }
50741 bool set_noise_map3(const AColor& texture, double time = TiMe::Default()) { return setValue("noise_map3", texture, time); }
50744 Value get_noise_map3(double time = TiMe::Default()) const { return getValue("noise_map3", time); }
50745
50749 bool set_rand_seed(float val, double time = TiMe::Default()) { return setValue("rand_seed", val, time); }
50753 float get_rand_seed(double time = TiMe::Default()) const { return getFloat("rand_seed", time); }
50754
50758 bool set_wood_type(int val, double time = TiMe::Default()) { return setValue("wood_type", val, time); }
50762 int get_wood_type(double time = TiMe::Default()) const { return getInt("wood_type", time); }
50763
50767 bool set_wood_size(float val, double time = TiMe::Default()) { return setValue("wood_size", val, time); }
50771 float get_wood_size(double time = TiMe::Default()) const { return getFloat("wood_size", time); }
50772
50776 bool set_low_tresh(float val, double time = TiMe::Default()) { return setValue("low_tresh", val, time); }
50780 float get_low_tresh(double time = TiMe::Default()) const { return getFloat("low_tresh", time); }
50781
50785 bool set_high_tresh(float val, double time = TiMe::Default()) { return setValue("high_tresh", val, time); }
50789 float get_high_tresh(double time = TiMe::Default()) const { return getFloat("high_tresh", time); }
50790
50794 bool set_wood_skew(float val, double time = TiMe::Default()) { return setValue("wood_skew", val, time); }
50798 float get_wood_skew(double time = TiMe::Default()) const { return getFloat("wood_skew", time); }
50799
50803 bool set_width_var(float val, double time = TiMe::Default()) { return setValue("width_var", val, time); }
50807 float get_width_var(double time = TiMe::Default()) const { return getFloat("width_var", time); }
50808
50812 bool set_gain_var(float val, double time = TiMe::Default()) { return setValue("gain_var", val, time); }
50816 float get_gain_var(double time = TiMe::Default()) const { return getFloat("gain_var", time); }
50817
50821 bool set_trunk_str(float val, double time = TiMe::Default()) { return setValue("trunk_str", val, time); }
50825 float get_trunk_str(double time = TiMe::Default()) const { return getFloat("trunk_str", time); }
50826
50830 bool set_trunk_freq(float val, double time = TiMe::Default()) { return setValue("trunk_freq", val, time); }
50834 float get_trunk_freq(double time = TiMe::Default()) const { return getFloat("trunk_freq", time); }
50835
50839 bool set_radial_str(float val, double time = TiMe::Default()) { return setValue("radial_str", val, time); }
50843 float get_radial_str(double time = TiMe::Default()) const { return getFloat("radial_str", time); }
50844
50848 bool set_radial_freq(float val, double time = TiMe::Default()) { return setValue("radial_freq", val, time); }
50852 float get_radial_freq(double time = TiMe::Default()) const { return getFloat("radial_freq", time); }
50853
50857 bool set_radial_z(float val, double time = TiMe::Default()) { return setValue("radial_z", val, time); }
50861 float get_radial_z(double time = TiMe::Default()) const { return getFloat("radial_z", time); }
50862
50866 bool set_angle_str(float val, double time = TiMe::Default()) { return setValue("angle_str", val, time); }
50870 float get_angle_str(double time = TiMe::Default()) const { return getFloat("angle_str", time); }
50871
50875 bool set_angle_freq(float val, double time = TiMe::Default()) { return setValue("angle_freq", val, time); }
50879 float get_angle_freq(double time = TiMe::Default()) const { return getFloat("angle_freq", time); }
50880
50884 bool set_angle_rad(float val, double time = TiMe::Default()) { return setValue("angle_rad", val, time); }
50888 float get_angle_rad(double time = TiMe::Default()) const { return getFloat("angle_rad", time); }
50889
50893 bool set_grain_str(float val, double time = TiMe::Default()) { return setValue("grain_str", val, time); }
50897 float get_grain_str(double time = TiMe::Default()) const { return getFloat("grain_str", time); }
50898
50902 bool set_grain_freq(float val, double time = TiMe::Default()) { return setValue("grain_freq", val, time); }
50906 float get_grain_freq(double time = TiMe::Default()) const { return getFloat("grain_freq", time); }
50907
50911 bool set_use_dist(bool val, double time = TiMe::Default()) { return setValue("use_dist", val, time); }
50915 bool get_use_dist(double time = TiMe::Default()) const { return getBool("use_dist", time); }
50916
50920 bool set_dist_str(float val, double time = TiMe::Default()) { return setValue("dist_str", val, time); }
50924 float get_dist_str(double time = TiMe::Default()) const { return getFloat("dist_str", time); }
50925
50928 bool set_dist_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
50931 bool set_dist_map(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map", texture, time); }
50934 Value get_dist_map(double time = TiMe::Default()) const { return getValue("dist_map", time); }
50935
50938 bool set_dist_map2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
50941 bool set_dist_map2(const AColor& texture, double time = TiMe::Default()) { return setValue("dist_map2", texture, time); }
50944 Value get_dist_map2(double time = TiMe::Default()) const { return getValue("dist_map2", time); }
50945
50949 bool set_samples(int val, double time = TiMe::Default()) { return setValue("samples", val, time); }
50953 int get_samples(double time = TiMe::Default()) const { return getInt("samples", time); }
50954
50957 bool set_tex_size(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_size", texture, time); }
50960 bool set_tex_size(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_size", texture, time); }
50963 Value get_tex_size(double time = TiMe::Default()) const { return getValue("tex_size", time); }
50964
50967 bool set_tex_low(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_low", texture, time); }
50970 bool set_tex_low(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_low", texture, time); }
50973 Value get_tex_low(double time = TiMe::Default()) const { return getValue("tex_low", time); }
50974
50977 bool set_tex_high(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_high", texture, time); }
50980 bool set_tex_high(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_high", texture, time); }
50983 Value get_tex_high(double time = TiMe::Default()) const { return getValue("tex_high", time); }
50984
50987 bool set_tex_skew(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_skew", texture, time); }
50990 bool set_tex_skew(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_skew", texture, time); }
50993 Value get_tex_skew(double time = TiMe::Default()) const { return getValue("tex_skew", time); }
50994
50997 bool set_tex_width_var(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_width_var", texture, time); }
51000 bool set_tex_width_var(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_width_var", texture, time); }
51003 Value get_tex_width_var(double time = TiMe::Default()) const { return getValue("tex_width_var", time); }
51004
51007 bool set_tex_gain_var(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_gain_var", texture, time); }
51010 bool set_tex_gain_var(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_gain_var", texture, time); }
51013 Value get_tex_gain_var(double time = TiMe::Default()) const { return getValue("tex_gain_var", time); }
51014
51017 bool set_tex_trunk_str(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_trunk_str", texture, time); }
51020 bool set_tex_trunk_str(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_trunk_str", texture, time); }
51023 Value get_tex_trunk_str(double time = TiMe::Default()) const { return getValue("tex_trunk_str", time); }
51024
51027 bool set_tex_trunk_freq(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_trunk_freq", texture, time); }
51030 bool set_tex_trunk_freq(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_trunk_freq", texture, time); }
51033 Value get_tex_trunk_freq(double time = TiMe::Default()) const { return getValue("tex_trunk_freq", time); }
51034
51037 bool set_tex_radial_str(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_radial_str", texture, time); }
51040 bool set_tex_radial_str(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_radial_str", texture, time); }
51043 Value get_tex_radial_str(double time = TiMe::Default()) const { return getValue("tex_radial_str", time); }
51044
51047 bool set_tex_radial_freq(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_radial_freq", texture, time); }
51050 bool set_tex_radial_freq(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_radial_freq", texture, time); }
51053 Value get_tex_radial_freq(double time = TiMe::Default()) const { return getValue("tex_radial_freq", time); }
51054
51057 bool set_tex_z_str(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_z_str", texture, time); }
51060 bool set_tex_z_str(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_z_str", texture, time); }
51063 Value get_tex_z_str(double time = TiMe::Default()) const { return getValue("tex_z_str", time); }
51064
51067 bool set_tex_ang_str(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_ang_str", texture, time); }
51070 bool set_tex_ang_str(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_ang_str", texture, time); }
51073 Value get_tex_ang_str(double time = TiMe::Default()) const { return getValue("tex_ang_str", time); }
51074
51077 bool set_tex_ang_freq(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_ang_freq", texture, time); }
51080 bool set_tex_ang_freq(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_ang_freq", texture, time); }
51083 Value get_tex_ang_freq(double time = TiMe::Default()) const { return getValue("tex_ang_freq", time); }
51084
51087 bool set_tex_ang_rad(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_ang_rad", texture, time); }
51090 bool set_tex_ang_rad(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_ang_rad", texture, time); }
51093 Value get_tex_ang_rad(double time = TiMe::Default()) const { return getValue("tex_ang_rad", time); }
51094
51097 bool set_tex_grain_str(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_grain_str", texture, time); }
51100 bool set_tex_grain_str(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_grain_str", texture, time); }
51103 Value get_tex_grain_str(double time = TiMe::Default()) const { return getValue("tex_grain_str", time); }
51104
51107 bool set_tex_grain_freq(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tex_grain_freq", texture, time); }
51110 bool set_tex_grain_freq(const AColor& texture, double time = TiMe::Default()) { return setValue("tex_grain_freq", texture, time); }
51113 Value get_tex_grain_freq(double time = TiMe::Default()) const { return getValue("tex_grain_freq", time); }
51114
51118 bool set_use_curve_input(bool val, double time = TiMe::Default()) { return setValue("use_curve_input", val, time); }
51122 bool get_use_curve_input(double time = TiMe::Default()) const { return getBool("use_curve_input", time); }
51123
51125 PluginRef out_curve_output() const { return PluginRef(*this, "curve_output"); }
51126
51130 bool set_curve_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("curve_input", texturefloat, time); }
51134 bool set_curve_input(float texturefloat, double time = TiMe::Default()) { return setValue("curve_input", texturefloat, time); }
51138 Value get_curve_input(double time = TiMe::Default()) const { return getValue("curve_input", time); }
51139};
51140
51142class TexBezierCurve : public Plugin {
51143public:
51145 static constexpr const PluginTypeId getTypeId() { return 0x77B04362; }
51147 static constexpr const char* getType() { return "TexBezierCurve"; }
51148
51149 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
51150
51153 bool set_input_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input_float", texturefloat, time); }
51156 bool set_input_float(float texturefloat, double time = TiMe::Default()) { return setValue("input_float", texturefloat, time); }
51159 Value get_input_float(double time = TiMe::Default()) const { return getValue("input_float", time); }
51160
51163 bool set_points(const FloatList& floatList, double time = TiMe::Default()) { return setValue("points", floatList, time); }
51164 bool set_points(FloatList&& floatList, double time = TiMe::Default()) { return setValue("points", std::move(floatList), time); }
51165 bool set_points(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("points", floats, count, time); }
51166 template<size_t count> bool set_points(const float (&floats)[count], double time = TiMe::Default()) { return setArray("points", floats, count, time); }
51169 FloatList get_points(double time = TiMe::Default()) const { return getFloatList("points", time); }
51170
51174 bool set_types(const IntList& intList, double time = TiMe::Default()) { return setValue("types", intList, time); }
51175 bool set_types(IntList&& intList, double time = TiMe::Default()) { return setValue("types", std::move(intList), time); }
51176 bool set_types(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("types", ints, count, time); }
51177 template<size_t count> bool set_types(const int (&ints)[count], double time = TiMe::Default()) { return setArray("types", ints, count, time); }
51181 IntList get_types(double time = TiMe::Default()) const { return getIntList("types", time); }
51182
51185 bool set_num_bezier_points(int val, double time = TiMe::Default()) { return setValue("num_bezier_points", val, time); }
51188 int get_num_bezier_points(double time = TiMe::Default()) const { return getInt("num_bezier_points", time); }
51189
51192 bool set_use_end_tangents(bool val, double time = TiMe::Default()) { return setValue("use_end_tangents", val, time); }
51195 bool get_use_end_tangents(double time = TiMe::Default()) const { return getBool("use_end_tangents", time); }
51196
51200 bool set_out_of_range_type(int val, double time = TiMe::Default()) { return setValue("out_of_range_type", val, time); }
51204 int get_out_of_range_type(double time = TiMe::Default()) const { return getInt("out_of_range_type", time); }
51205
51209 bool set_gpu_curve_mode(int val, double time = TiMe::Default()) { return setValue("gpu_curve_mode", val, time); }
51213 int get_gpu_curve_mode(double time = TiMe::Default()) const { return getInt("gpu_curve_mode", time); }
51214
51217 bool set_clamp(bool val, double time = TiMe::Default()) { return setValue("clamp", val, time); }
51220 bool get_clamp(double time = TiMe::Default()) const { return getBool("clamp", time); }
51221
51224 bool set_clamp_value_min(float val, double time = TiMe::Default()) { return setValue("clamp_value_min", val, time); }
51227 float get_clamp_value_min(double time = TiMe::Default()) const { return getFloat("clamp_value_min", time); }
51228
51231 bool set_clamp_value_max(float val, double time = TiMe::Default()) { return setValue("clamp_value_max", val, time); }
51234 float get_clamp_value_max(double time = TiMe::Default()) const { return getFloat("clamp_value_max", time); }
51235};
51236
51239public:
51241 static constexpr const PluginTypeId getTypeId() { return 0x782B1808; }
51243 static constexpr const char* getType() { return "TexBezierCurveColor"; }
51244
51245 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
51246
51249 bool set_input_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input_color", texture, time); }
51252 bool set_input_color(const AColor& texture, double time = TiMe::Default()) { return setValue("input_color", texture, time); }
51255 Value get_input_color(double time = TiMe::Default()) const { return getValue("input_color", time); }
51256
51259 bool set_points_r(const FloatList& floatList, double time = TiMe::Default()) { return setValue("points_r", floatList, time); }
51260 bool set_points_r(FloatList&& floatList, double time = TiMe::Default()) { return setValue("points_r", std::move(floatList), time); }
51261 bool set_points_r(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("points_r", floats, count, time); }
51262 template<size_t count> bool set_points_r(const float (&floats)[count], double time = TiMe::Default()) { return setArray("points_r", floats, count, time); }
51265 FloatList get_points_r(double time = TiMe::Default()) const { return getFloatList("points_r", time); }
51266
51269 bool set_points_g(const FloatList& floatList, double time = TiMe::Default()) { return setValue("points_g", floatList, time); }
51270 bool set_points_g(FloatList&& floatList, double time = TiMe::Default()) { return setValue("points_g", std::move(floatList), time); }
51271 bool set_points_g(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("points_g", floats, count, time); }
51272 template<size_t count> bool set_points_g(const float (&floats)[count], double time = TiMe::Default()) { return setArray("points_g", floats, count, time); }
51275 FloatList get_points_g(double time = TiMe::Default()) const { return getFloatList("points_g", time); }
51276
51279 bool set_points_b(const FloatList& floatList, double time = TiMe::Default()) { return setValue("points_b", floatList, time); }
51280 bool set_points_b(FloatList&& floatList, double time = TiMe::Default()) { return setValue("points_b", std::move(floatList), time); }
51281 bool set_points_b(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("points_b", floats, count, time); }
51282 template<size_t count> bool set_points_b(const float (&floats)[count], double time = TiMe::Default()) { return setArray("points_b", floats, count, time); }
51285 FloatList get_points_b(double time = TiMe::Default()) const { return getFloatList("points_b", time); }
51286
51290 bool set_types_r(const IntList& intList, double time = TiMe::Default()) { return setValue("types_r", intList, time); }
51291 bool set_types_r(IntList&& intList, double time = TiMe::Default()) { return setValue("types_r", std::move(intList), time); }
51292 bool set_types_r(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("types_r", ints, count, time); }
51293 template<size_t count> bool set_types_r(const int (&ints)[count], double time = TiMe::Default()) { return setArray("types_r", ints, count, time); }
51297 IntList get_types_r(double time = TiMe::Default()) const { return getIntList("types_r", time); }
51298
51302 bool set_types_g(const IntList& intList, double time = TiMe::Default()) { return setValue("types_g", intList, time); }
51303 bool set_types_g(IntList&& intList, double time = TiMe::Default()) { return setValue("types_g", std::move(intList), time); }
51304 bool set_types_g(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("types_g", ints, count, time); }
51305 template<size_t count> bool set_types_g(const int (&ints)[count], double time = TiMe::Default()) { return setArray("types_g", ints, count, time); }
51309 IntList get_types_g(double time = TiMe::Default()) const { return getIntList("types_g", time); }
51310
51314 bool set_types_b(const IntList& intList, double time = TiMe::Default()) { return setValue("types_b", intList, time); }
51315 bool set_types_b(IntList&& intList, double time = TiMe::Default()) { return setValue("types_b", std::move(intList), time); }
51316 bool set_types_b(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("types_b", ints, count, time); }
51317 template<size_t count> bool set_types_b(const int (&ints)[count], double time = TiMe::Default()) { return setArray("types_b", ints, count, time); }
51321 IntList get_types_b(double time = TiMe::Default()) const { return getIntList("types_b", time); }
51322
51325 bool set_num_bezier_points_r(int val, double time = TiMe::Default()) { return setValue("num_bezier_points_r", val, time); }
51328 int get_num_bezier_points_r(double time = TiMe::Default()) const { return getInt("num_bezier_points_r", time); }
51329
51332 bool set_num_bezier_points_g(int val, double time = TiMe::Default()) { return setValue("num_bezier_points_g", val, time); }
51335 int get_num_bezier_points_g(double time = TiMe::Default()) const { return getInt("num_bezier_points_g", time); }
51336
51339 bool set_num_bezier_points_b(int val, double time = TiMe::Default()) { return setValue("num_bezier_points_b", val, time); }
51342 int get_num_bezier_points_b(double time = TiMe::Default()) const { return getInt("num_bezier_points_b", time); }
51343
51346 bool set_use_end_tangents_r(bool val, double time = TiMe::Default()) { return setValue("use_end_tangents_r", val, time); }
51349 bool get_use_end_tangents_r(double time = TiMe::Default()) const { return getBool("use_end_tangents_r", time); }
51350
51353 bool set_use_end_tangents_g(bool val, double time = TiMe::Default()) { return setValue("use_end_tangents_g", val, time); }
51356 bool get_use_end_tangents_g(double time = TiMe::Default()) const { return getBool("use_end_tangents_g", time); }
51357
51360 bool set_use_end_tangents_b(bool val, double time = TiMe::Default()) { return setValue("use_end_tangents_b", val, time); }
51363 bool get_use_end_tangents_b(double time = TiMe::Default()) const { return getBool("use_end_tangents_b", time); }
51364
51368 bool set_out_of_range_type_r(int val, double time = TiMe::Default()) { return setValue("out_of_range_type_r", val, time); }
51372 int get_out_of_range_type_r(double time = TiMe::Default()) const { return getInt("out_of_range_type_r", time); }
51373
51377 bool set_out_of_range_type_g(int val, double time = TiMe::Default()) { return setValue("out_of_range_type_g", val, time); }
51381 int get_out_of_range_type_g(double time = TiMe::Default()) const { return getInt("out_of_range_type_g", time); }
51382
51386 bool set_out_of_range_type_b(int val, double time = TiMe::Default()) { return setValue("out_of_range_type_b", val, time); }
51390 int get_out_of_range_type_b(double time = TiMe::Default()) const { return getInt("out_of_range_type_b", time); }
51391};
51392
51394class TexBifrostVVMix : public Plugin {
51395public:
51397 static constexpr const PluginTypeId getTypeId() { return 0x780C7436; }
51399 static constexpr const char* getType() { return "TexBifrostVVMix"; }
51400
51401 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
51402
51405 bool set_velocity_mult(float val, double time = TiMe::Default()) { return setValue("velocity_mult", val, time); }
51408 float get_velocity_mult(double time = TiMe::Default()) const { return getFloat("velocity_mult", time); }
51409
51412 bool set_vorticity_mult(float val, double time = TiMe::Default()) { return setValue("vorticity_mult", val, time); }
51415 float get_vorticity_mult(double time = TiMe::Default()) const { return getFloat("vorticity_mult", time); }
51416
51418 bool set_velocity_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("velocity_tex", texture, time); }
51420 bool set_velocity_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("velocity_tex", texture, time); }
51422 Value get_velocity_tex(double time = TiMe::Default()) const { return getValue("velocity_tex", time); }
51423
51425 bool set_vorticity_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("vorticity_tex", texture, time); }
51427 bool set_vorticity_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("vorticity_tex", texture, time); }
51429 Value get_vorticity_tex(double time = TiMe::Default()) const { return getValue("vorticity_tex", time); }
51430
51432 PluginRef out_out_value() const { return PluginRef(*this, "out_value"); }
51433};
51434
51437public:
51439 static constexpr const PluginTypeId getTypeId() { return 0x77B157D0; }
51441 static constexpr const char* getType() { return "TexBillboardParticle"; }
51442
51443 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
51444
51448 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
51452 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
51453
51457 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
51461 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
51462
51466 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
51470 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
51471
51475 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
51479 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
51480
51484 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
51488 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
51492 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
51493
51497 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
51501 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
51505 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
51506
51510 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
51514 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
51518 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
51519
51523 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
51527 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
51531 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
51532
51536 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
51540 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
51544 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
51545
51547 PluginRef out_color() const { return PluginRef(*this, "color"); }
51548
51550 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
51551
51553 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
51554
51556 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
51557
51560 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
51563 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
51564
51568 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
51572 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
51573
51577 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
51581 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
51582
51586 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
51590 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
51591
51595 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
51599 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
51600
51604 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
51608 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
51609
51613 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
51617 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
51618
51622 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
51626 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
51627
51631 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
51635 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
51636
51640 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
51644 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
51645
51649 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
51653 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
51654
51658 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
51662 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
51663
51667 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
51671 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
51672
51676 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
51680 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
51681
51685 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
51689 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
51690
51692 bool set_clr_txt(const PluginRef& texture, double time = TiMe::Default()) { return setValue("clr_txt", texture, time); }
51694 bool set_clr_txt(const AColor& texture, double time = TiMe::Default()) { return setValue("clr_txt", texture, time); }
51696 Value get_clr_txt(double time = TiMe::Default()) const { return getValue("clr_txt", time); }
51697
51700 bool set_NormalType(int val, double time = TiMe::Default()) { return setValue("NormalType", val, time); }
51703 int get_NormalType(double time = TiMe::Default()) const { return getInt("NormalType", time); }
51704
51707 bool set_Direction(int val, double time = TiMe::Default()) { return setValue("Direction", val, time); }
51710 int get_Direction(double time = TiMe::Default()) const { return getInt("Direction", time); }
51711
51714 bool set_TextureSpace(int val, double time = TiMe::Default()) { return setValue("TextureSpace", val, time); }
51717 int get_TextureSpace(double time = TiMe::Default()) const { return getInt("TextureSpace", time); }
51718
51721 bool set_Shape(int val, double time = TiMe::Default()) { return setValue("Shape", val, time); }
51724 int get_Shape(double time = TiMe::Default()) const { return getInt("Shape", time); }
51725
51728 bool set_FollowVelocity(int val, double time = TiMe::Default()) { return setValue("FollowVelocity", val, time); }
51731 int get_FollowVelocity(double time = TiMe::Default()) const { return getInt("FollowVelocity", time); }
51732
51735 bool set_SelfShadow(float val, double time = TiMe::Default()) { return setValue("SelfShadow", val, time); }
51738 float get_SelfShadow(double time = TiMe::Default()) const { return getFloat("SelfShadow", time); }
51739
51742 bool set_UseShading(int val, double time = TiMe::Default()) { return setValue("UseShading", val, time); }
51745 int get_UseShading(double time = TiMe::Default()) const { return getInt("UseShading", time); }
51746
51749 bool set_AmbientType(int val, double time = TiMe::Default()) { return setValue("AmbientType", val, time); }
51752 int get_AmbientType(double time = TiMe::Default()) const { return getInt("AmbientType", time); }
51753
51755 bool set_AmbienceClr(const PluginRef& texture, double time = TiMe::Default()) { return setValue("AmbienceClr", texture, time); }
51757 bool set_AmbienceClr(const AColor& texture, double time = TiMe::Default()) { return setValue("AmbienceClr", texture, time); }
51759 Value get_AmbienceClr(double time = TiMe::Default()) const { return getValue("AmbienceClr", time); }
51760
51762 bool set_AmbientClr(const PluginRef& texture, double time = TiMe::Default()) { return setValue("AmbientClr", texture, time); }
51764 bool set_AmbientClr(const AColor& texture, double time = TiMe::Default()) { return setValue("AmbientClr", texture, time); }
51766 Value get_AmbientClr(double time = TiMe::Default()) const { return getValue("AmbientClr", time); }
51767
51770 bool set_AmbientPart(float val, double time = TiMe::Default()) { return setValue("AmbientPart", val, time); }
51773 float get_AmbientPart(double time = TiMe::Default()) const { return getFloat("AmbientPart", time); }
51774
51778 bool set_SpecularType(int val, double time = TiMe::Default()) { return setValue("SpecularType", val, time); }
51782 int get_SpecularType(double time = TiMe::Default()) const { return getInt("SpecularType", time); }
51783
51785 bool set_SpecularClr(const PluginRef& texture, double time = TiMe::Default()) { return setValue("SpecularClr", texture, time); }
51787 bool set_SpecularClr(const AColor& texture, double time = TiMe::Default()) { return setValue("SpecularClr", texture, time); }
51789 Value get_SpecularClr(double time = TiMe::Default()) const { return getValue("SpecularClr", time); }
51790
51793 bool set_SpecularPart(float val, double time = TiMe::Default()) { return setValue("SpecularPart", val, time); }
51796 float get_SpecularPart(double time = TiMe::Default()) const { return getFloat("SpecularPart", time); }
51797
51800 bool set_SpecularCoeff(float val, double time = TiMe::Default()) { return setValue("SpecularCoeff", val, time); }
51803 float get_SpecularCoeff(double time = TiMe::Default()) const { return getFloat("SpecularCoeff", time); }
51804
51808 bool set_IrradianceType(int val, double time = TiMe::Default()) { return setValue("IrradianceType", val, time); }
51812 int get_IrradianceType(double time = TiMe::Default()) const { return getInt("IrradianceType", time); }
51813
51815 bool set_IrradianceClr(const PluginRef& texture, double time = TiMe::Default()) { return setValue("IrradianceClr", texture, time); }
51817 bool set_IrradianceClr(const AColor& texture, double time = TiMe::Default()) { return setValue("IrradianceClr", texture, time); }
51819 Value get_IrradianceClr(double time = TiMe::Default()) const { return getValue("IrradianceClr", time); }
51820
51823 bool set_IrradiancePart(float val, double time = TiMe::Default()) { return setValue("IrradiancePart", val, time); }
51826 float get_IrradiancePart(double time = TiMe::Default()) const { return getFloat("IrradiancePart", time); }
51827
51831 bool set_RadianceType(int val, double time = TiMe::Default()) { return setValue("RadianceType", val, time); }
51835 int get_RadianceType(double time = TiMe::Default()) const { return getInt("RadianceType", time); }
51836
51838 bool set_RadianceClr(const PluginRef& texture, double time = TiMe::Default()) { return setValue("RadianceClr", texture, time); }
51840 bool set_RadianceClr(const AColor& texture, double time = TiMe::Default()) { return setValue("RadianceClr", texture, time); }
51842 Value get_RadianceClr(double time = TiMe::Default()) const { return getValue("RadianceClr", time); }
51843
51846 bool set_RadiancePart(float val, double time = TiMe::Default()) { return setValue("RadiancePart", val, time); }
51849 float get_RadiancePart(double time = TiMe::Default()) const { return getFloat("RadiancePart", time); }
51850
51853 bool set_ColourBurn(float val, double time = TiMe::Default()) { return setValue("ColourBurn", val, time); }
51856 float get_ColourBurn(double time = TiMe::Default()) const { return getFloat("ColourBurn", time); }
51857};
51858
51860class TexBitmap : public Plugin {
51861public:
51863 static constexpr const PluginTypeId getTypeId() { return 0x777473C9; }
51865 static constexpr const char* getType() { return "TexBitmap"; }
51866
51867 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
51868
51872 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
51876 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
51877
51881 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
51885 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
51886
51890 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
51894 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
51895
51899 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
51903 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
51904
51908 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
51912 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
51916 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
51917
51921 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
51925 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
51929 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
51930
51934 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
51938 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
51942 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
51943
51947 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
51951 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
51955 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
51956
51960 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
51964 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
51968 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
51969
51971 PluginRef out_color() const { return PluginRef(*this, "color"); }
51972
51974 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
51975
51977 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
51978
51980 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
51981
51984 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
51987 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
51988
51992 bool set_tile(int val, double time = TiMe::Default()) { return setValue("tile", val, time); }
51996 int get_tile(double time = TiMe::Default()) const { return getInt("tile", time); }
51997
52001 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
52005 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
52006
52010 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
52014 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
52015
52019 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
52023 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
52024
52028 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
52032 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
52033
52037 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
52041 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
52042
52046 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
52050 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
52051
52055 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
52059 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
52060
52064 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
52068 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
52069
52073 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
52077 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
52078
52082 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
52086 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
52087
52091 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
52095 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
52096
52100 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
52104 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
52105
52109 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
52113 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
52114
52118 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
52122 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
52123
52126 bool set_bitmap(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("bitmap", plugin, time); }
52129 PluginRef get_bitmap(double time = TiMe::Default()) const { return getPlugin("bitmap", time); }
52130
52133 bool set_default_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("default_color", texture, time); }
52136 bool set_default_color(const AColor& texture, double time = TiMe::Default()) { return setValue("default_color", texture, time); }
52139 Value get_default_color(double time = TiMe::Default()) const { return getValue("default_color", time); }
52140};
52141
52143class TexBlend : public Plugin {
52144public:
52146 static constexpr const PluginTypeId getTypeId() { return 0x77747289; }
52148 static constexpr const char* getType() { return "TexBlend"; }
52149
52150 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
52151
52154 bool set_color_a(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
52157 bool set_color_a(const AColor& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
52160 Value get_color_a(double time = TiMe::Default()) const { return getValue("color_a", time); }
52161
52164 bool set_color_b(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
52167 bool set_color_b(const AColor& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
52170 Value get_color_b(double time = TiMe::Default()) const { return getValue("color_b", time); }
52171
52174 bool set_blend_amount(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("blend_amount", texturefloat, time); }
52177 bool set_blend_amount(float texturefloat, double time = TiMe::Default()) { return setValue("blend_amount", texturefloat, time); }
52180 Value get_blend_amount(double time = TiMe::Default()) const { return getValue("blend_amount", time); }
52181
52184 bool set_composite(bool val, double time = TiMe::Default()) { return setValue("composite", val, time); }
52187 bool get_composite(double time = TiMe::Default()) const { return getBool("composite", time); }
52188};
52189
52192public:
52194 static constexpr const PluginTypeId getTypeId() { return 0x77CE8201; }
52196 static constexpr const char* getType() { return "TexBlendBumpNormal"; }
52197
52198 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
52199
52203 bool set_normalMap1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("normalMap1", texture, time); }
52207 bool set_normalMap1(const AColor& texture, double time = TiMe::Default()) { return setValue("normalMap1", texture, time); }
52211 Value get_normalMap1(double time = TiMe::Default()) const { return getValue("normalMap1", time); }
52212
52216 bool set_normalMapWeight1(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("normalMapWeight1", texturefloat, time); }
52220 bool set_normalMapWeight1(float texturefloat, double time = TiMe::Default()) { return setValue("normalMapWeight1", texturefloat, time); }
52224 Value get_normalMapWeight1(double time = TiMe::Default()) const { return getValue("normalMapWeight1", time); }
52225
52229 bool set_normalMap2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("normalMap2", texture, time); }
52233 bool set_normalMap2(const AColor& texture, double time = TiMe::Default()) { return setValue("normalMap2", texture, time); }
52237 Value get_normalMap2(double time = TiMe::Default()) const { return getValue("normalMap2", time); }
52238
52242 bool set_normalMapWeight2(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("normalMapWeight2", texturefloat, time); }
52246 bool set_normalMapWeight2(float texturefloat, double time = TiMe::Default()) { return setValue("normalMapWeight2", texturefloat, time); }
52250 Value get_normalMapWeight2(double time = TiMe::Default()) const { return getValue("normalMapWeight2", time); }
52251
52255 bool set_bumpMap1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bumpMap1", texture, time); }
52259 bool set_bumpMap1(const AColor& texture, double time = TiMe::Default()) { return setValue("bumpMap1", texture, time); }
52263 Value get_bumpMap1(double time = TiMe::Default()) const { return getValue("bumpMap1", time); }
52264
52268 bool set_bumpMapWeight1(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bumpMapWeight1", texturefloat, time); }
52272 bool set_bumpMapWeight1(float texturefloat, double time = TiMe::Default()) { return setValue("bumpMapWeight1", texturefloat, time); }
52276 Value get_bumpMapWeight1(double time = TiMe::Default()) const { return getValue("bumpMapWeight1", time); }
52277
52281 bool set_bumpMap2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bumpMap2", texture, time); }
52285 bool set_bumpMap2(const AColor& texture, double time = TiMe::Default()) { return setValue("bumpMap2", texture, time); }
52289 Value get_bumpMap2(double time = TiMe::Default()) const { return getValue("bumpMap2", time); }
52290
52294 bool set_bumpMapWeight2(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bumpMapWeight2", texturefloat, time); }
52298 bool set_bumpMapWeight2(float texturefloat, double time = TiMe::Default()) { return setValue("bumpMapWeight2", texturefloat, time); }
52302 Value get_bumpMapWeight2(double time = TiMe::Default()) const { return getValue("bumpMapWeight2", time); }
52303
52307 bool set_sharpen(bool val, double time = TiMe::Default()) { return setValue("sharpen", val, time); }
52311 bool get_sharpen(double time = TiMe::Default()) const { return getBool("sharpen", time); }
52312};
52313
52315class TexBulge : public Plugin {
52316public:
52318 static constexpr const PluginTypeId getTypeId() { return 0xBF37731; }
52320 static constexpr const char* getType() { return "TexBulge"; }
52321
52322 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
52323
52327 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
52331 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
52332
52336 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
52340 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
52341
52345 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
52349 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
52350
52354 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
52358 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
52359
52363 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
52367 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
52371 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
52372
52376 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
52380 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
52384 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
52385
52389 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
52393 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
52397 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
52398
52402 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
52406 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
52410 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
52411
52415 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
52419 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
52423 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
52424
52426 PluginRef out_color() const { return PluginRef(*this, "color"); }
52427
52429 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
52430
52432 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
52433
52435 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
52436
52439 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
52442 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
52443
52447 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
52451 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
52452
52456 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
52460 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
52461
52465 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
52469 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
52470
52474 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
52478 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
52479
52483 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
52487 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
52488
52492 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
52496 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
52497
52501 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
52505 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
52506
52510 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
52514 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
52515
52519 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
52523 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
52524
52528 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
52532 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
52533
52537 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
52541 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
52542
52546 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
52550 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
52551
52555 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
52559 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
52560
52564 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
52568 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
52569
52573 bool set_u_width(float val, double time = TiMe::Default()) { return setValue("u_width", val, time); }
52577 float get_u_width(double time = TiMe::Default()) const { return getFloat("u_width", time); }
52578
52582 bool set_v_width(float val, double time = TiMe::Default()) { return setValue("v_width", val, time); }
52586 float get_v_width(double time = TiMe::Default()) const { return getFloat("v_width", time); }
52587};
52588
52591public:
52593 static constexpr const PluginTypeId getTypeId() { return 0x7886D329; }
52595 static constexpr const char* getType() { return "TexBump2Glossiness"; }
52596
52597 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
52598
52600 PluginRef out_out_dbg_moment1() const { return PluginRef(*this, "out_dbg_moment1"); }
52601
52603 PluginRef out_out_dbg_moment2() const { return PluginRef(*this, "out_dbg_moment2"); }
52604
52606 PluginRef out_out_dbg_sigma() const { return PluginRef(*this, "out_dbg_sigma"); }
52607
52610 bool set_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("map", texture, time); }
52613 bool set_map(const AColor& texture, double time = TiMe::Default()) { return setValue("map", texture, time); }
52616 Value get_map(double time = TiMe::Default()) const { return getValue("map", time); }
52617
52620 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
52623 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
52624
52628 bool set_bump_amount(float val, double time = TiMe::Default()) { return setValue("bump_amount", val, time); }
52632 float get_bump_amount(double time = TiMe::Default()) const { return getFloat("bump_amount", time); }
52633
52637 bool set_base_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness", texturefloat, time); }
52641 bool set_base_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("base_glossiness", texturefloat, time); }
52645 Value get_base_glossiness(double time = TiMe::Default()) const { return getValue("base_glossiness", time); }
52646
52649 bool set_use_roughness(bool val, double time = TiMe::Default()) { return setValue("use_roughness", val, time); }
52652 bool get_use_roughness(double time = TiMe::Default()) const { return getBool("use_roughness", time); }
52653
52657 bool set_bump_mode(int val, double time = TiMe::Default()) { return setValue("bump_mode", val, time); }
52661 int get_bump_mode(double time = TiMe::Default()) const { return getInt("bump_mode", time); }
52662
52666 bool set_filter_mode(int val, double time = TiMe::Default()) { return setValue("filter_mode", val, time); }
52670 int get_filter_mode(double time = TiMe::Default()) const { return getInt("filter_mode", time); }
52671
52675 bool set_filter_width(float val, double time = TiMe::Default()) { return setValue("filter_width", val, time); }
52679 float get_filter_width(double time = TiMe::Default()) const { return getFloat("filter_width", time); }
52680
52684 bool set_filter_sharpness(float val, double time = TiMe::Default()) { return setValue("filter_sharpness", val, time); }
52688 float get_filter_sharpness(double time = TiMe::Default()) const { return getFloat("filter_sharpness", time); }
52689
52693 bool set_filter_max_eccentricity(float val, double time = TiMe::Default()) { return setValue("filter_max_eccentricity", val, time); }
52697 float get_filter_max_eccentricity(double time = TiMe::Default()) const { return getFloat("filter_max_eccentricity", time); }
52698
52702 bool set_filter_blur(float val, double time = TiMe::Default()) { return setValue("filter_blur", val, time); }
52706 float get_filter_blur(double time = TiMe::Default()) const { return getFloat("filter_blur", time); }
52707};
52708
52710class TexC4DNoise : public Plugin {
52711public:
52713 static constexpr const PluginTypeId getTypeId() { return 0x7868267C; }
52715 static constexpr const char* getType() { return "TexC4DNoise"; }
52716
52717 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
52718
52719 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
52720
52724 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
52728 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
52729
52733 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
52737 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
52738
52742 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
52746 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
52747
52751 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
52755 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
52756
52760 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
52764 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
52768 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
52769
52773 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
52777 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
52781 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
52782
52786 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
52790 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
52794 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
52795
52799 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
52803 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
52807 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
52808
52812 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
52816 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
52820 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
52821
52823 PluginRef out_color() const { return PluginRef(*this, "color"); }
52824
52826 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
52827
52829 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
52830
52832 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
52833
52836 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
52839 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
52840
52844 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
52848 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
52849
52853 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
52857 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
52858
52862 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
52866 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
52867
52871 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
52875 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
52876
52880 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
52884 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
52885
52889 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
52893 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
52894
52898 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
52902 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
52903
52907 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
52911 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
52912
52916 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
52920 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
52921
52925 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
52929 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
52930
52934 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
52938 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
52939
52943 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
52947 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
52948
52952 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
52956 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
52957
52961 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
52965 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
52966
52970 bool set_octaves(float val, double time = TiMe::Default()) { return setValue("octaves", val, time); }
52974 float get_octaves(double time = TiMe::Default()) const { return getFloat("octaves", time); }
52975
52979 bool set_anim_speed(float val, double time = TiMe::Default()) { return setValue("anim_speed", val, time); }
52983 float get_anim_speed(double time = TiMe::Default()) const { return getFloat("anim_speed", time); }
52984
52988 bool set_time_period(float val, double time = TiMe::Default()) { return setValue("time_period", val, time); }
52992 float get_time_period(double time = TiMe::Default()) const { return getFloat("time_period", time); }
52993
52997 bool set_low_clip(float val, double time = TiMe::Default()) { return setValue("low_clip", val, time); }
53001 float get_low_clip(double time = TiMe::Default()) const { return getFloat("low_clip", time); }
53002
53006 bool set_high_clip(float val, double time = TiMe::Default()) { return setValue("high_clip", val, time); }
53010 float get_high_clip(double time = TiMe::Default()) const { return getFloat("high_clip", time); }
53011
53015 bool set_brightness(float val, double time = TiMe::Default()) { return setValue("brightness", val, time); }
53019 float get_brightness(double time = TiMe::Default()) const { return getFloat("brightness", time); }
53020
53024 bool set_contrast(float val, double time = TiMe::Default()) { return setValue("contrast", val, time); }
53028 float get_contrast(double time = TiMe::Default()) const { return getFloat("contrast", time); }
53029
53033 bool set_movement(const Vector& vector, double time = TiMe::Default()) { return setValue("movement", vector, time); }
53037 Vector get_movement(double time = TiMe::Default()) const { return getVector("movement", time); }
53038
53042 bool set_cycles(float val, double time = TiMe::Default()) { return setValue("cycles", val, time); }
53046 float get_cycles(double time = TiMe::Default()) const { return getFloat("cycles", time); }
53047
53051 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
53055 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
53056
53060 bool set_space(int val, double time = TiMe::Default()) { return setValue("space", val, time); }
53064 int get_space(double time = TiMe::Default()) const { return getInt("space", time); }
53065
53069 bool set_seed(int val, double time = TiMe::Default()) { return setValue("seed", val, time); }
53073 int get_seed(double time = TiMe::Default()) const { return getInt("seed", time); }
53074
53078 bool set_lacunarity(float val, double time = TiMe::Default()) { return setValue("lacunarity", val, time); }
53082 float get_lacunarity(double time = TiMe::Default()) const { return getFloat("lacunarity", time); }
53083
53087 bool set_gain(float val, double time = TiMe::Default()) { return setValue("gain", val, time); }
53091 float get_gain(double time = TiMe::Default()) const { return getFloat("gain", time); }
53092
53096 bool set_color1(const AColor& acolor, double time = TiMe::Default()) { return setValue("color1", acolor, time); }
53100 AColor get_color1(double time = TiMe::Default()) const { return getAColor("color1", time); }
53101
53105 bool set_color2(const AColor& acolor, double time = TiMe::Default()) { return setValue("color2", acolor, time); }
53109 AColor get_color2(double time = TiMe::Default()) const { return getAColor("color2", time); }
53110
53114 bool set_global_scale(float val, double time = TiMe::Default()) { return setValue("global_scale", val, time); }
53118 float get_global_scale(double time = TiMe::Default()) const { return getFloat("global_scale", time); }
53119
53123 bool set_relative_scale(const Vector& vector, double time = TiMe::Default()) { return setValue("relative_scale", vector, time); }
53127 Vector get_relative_scale(double time = TiMe::Default()) const { return getVector("relative_scale", time); }
53128
53132 bool set_speed(float val, double time = TiMe::Default()) { return setValue("speed", val, time); }
53136 float get_speed(double time = TiMe::Default()) const { return getFloat("speed", time); }
53137
53141 bool set_absolute(bool val, double time = TiMe::Default()) { return setValue("absolute", val, time); }
53145 bool get_absolute(double time = TiMe::Default()) const { return getBool("absolute", time); }
53146
53149 bool set_parameter_hash_version(int val, double time = TiMe::Default()) { return setValue("parameter_hash_version", val, time); }
53152 int get_parameter_hash_version(double time = TiMe::Default()) const { return getInt("parameter_hash_version", time); }
53153
53156 bool set_parameter_hash(int val, double time = TiMe::Default()) { return setValue("parameter_hash", val, time); }
53159 int get_parameter_hash(double time = TiMe::Default()) const { return getInt("parameter_hash", time); }
53160};
53161
53163class TexCellular : public Plugin {
53164public:
53166 static constexpr const PluginTypeId getTypeId() { return 0xBF69B8A; }
53168 static constexpr const char* getType() { return "TexCellular"; }
53169
53170 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
53171
53172 operator TextureVectorPluginCategory() { return *static_cast<TextureVectorPluginCategory*>(static_cast<Plugin*>(this)); }
53173
53177 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
53181 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
53182
53186 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
53190 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
53191
53195 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
53199 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
53200
53204 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
53208 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
53209
53213 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
53217 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
53221 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
53222
53226 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
53230 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
53234 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
53235
53239 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
53243 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
53247 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
53248
53252 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
53256 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
53260 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
53261
53265 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
53269 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
53273 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
53274
53276 PluginRef out_color() const { return PluginRef(*this, "color"); }
53277
53279 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
53280
53282 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
53283
53285 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
53286
53289 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
53292 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
53293
53297 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
53301 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
53302
53306 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
53310 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
53311
53315 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
53319 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
53320
53324 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
53328 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
53329
53333 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
53337 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
53338
53342 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
53346 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
53347
53351 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
53355 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
53356
53360 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
53364 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
53365
53369 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
53373 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
53374
53378 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
53382 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
53383
53387 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
53391 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
53392
53396 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
53400 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
53401
53405 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
53409 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
53410
53414 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
53418 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
53419
53422 bool set_center_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("center_color", texture, time); }
53425 bool set_center_color(const AColor& texture, double time = TiMe::Default()) { return setValue("center_color", texture, time); }
53428 Value get_center_color(double time = TiMe::Default()) const { return getValue("center_color", time); }
53429
53432 bool set_edge_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("edge_color", texture, time); }
53435 bool set_edge_color(const AColor& texture, double time = TiMe::Default()) { return setValue("edge_color", texture, time); }
53438 Value get_edge_color(double time = TiMe::Default()) const { return getValue("edge_color", time); }
53439
53443 bool set_bg_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bg_color", texture, time); }
53447 bool set_bg_color(const AColor& texture, double time = TiMe::Default()) { return setValue("bg_color", texture, time); }
53451 Value get_bg_color(double time = TiMe::Default()) const { return getValue("bg_color", time); }
53452
53456 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
53460 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
53461
53465 bool set_spread(float val, double time = TiMe::Default()) { return setValue("spread", val, time); }
53469 float get_spread(double time = TiMe::Default()) const { return getFloat("spread", time); }
53470
53474 bool set_density(float val, double time = TiMe::Default()) { return setValue("density", val, time); }
53478 float get_density(double time = TiMe::Default()) const { return getFloat("density", time); }
53479
53483 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
53487 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
53488
53492 bool set_low(float val, double time = TiMe::Default()) { return setValue("low", val, time); }
53496 float get_low(double time = TiMe::Default()) const { return getFloat("low", time); }
53497
53501 bool set_middle(float val, double time = TiMe::Default()) { return setValue("middle", val, time); }
53505 float get_middle(double time = TiMe::Default()) const { return getFloat("middle", time); }
53506
53510 bool set_high(float val, double time = TiMe::Default()) { return setValue("high", val, time); }
53514 float get_high(double time = TiMe::Default()) const { return getFloat("high", time); }
53515
53519 bool set_fractal(bool val, double time = TiMe::Default()) { return setValue("fractal", val, time); }
53523 bool get_fractal(double time = TiMe::Default()) const { return getBool("fractal", time); }
53524
53528 bool set_fractal_iterations(float val, double time = TiMe::Default()) { return setValue("fractal_iterations", val, time); }
53532 float get_fractal_iterations(double time = TiMe::Default()) const { return getFloat("fractal_iterations", time); }
53533
53537 bool set_fractal_roughness(float val, double time = TiMe::Default()) { return setValue("fractal_roughness", val, time); }
53541 float get_fractal_roughness(double time = TiMe::Default()) const { return getFloat("fractal_roughness", time); }
53542
53544 PluginRef out_components() const { return PluginRef(*this, "components"); }
53545};
53546
53548class TexChecker : public Plugin {
53549public:
53551 static constexpr const PluginTypeId getTypeId() { return 0x77744CA6; }
53553 static constexpr const char* getType() { return "TexChecker"; }
53554
53555 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
53556
53560 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
53564 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
53565
53569 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
53573 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
53574
53578 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
53582 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
53583
53587 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
53591 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
53592
53596 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
53600 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
53604 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
53605
53609 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
53613 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
53617 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
53618
53622 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
53626 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
53630 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
53631
53635 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
53639 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
53643 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
53644
53648 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
53652 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
53656 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
53657
53659 PluginRef out_color() const { return PluginRef(*this, "color"); }
53660
53662 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
53663
53665 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
53666
53668 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
53669
53672 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
53675 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
53676
53680 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
53684 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
53685
53689 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
53693 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
53694
53698 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
53702 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
53703
53707 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
53711 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
53712
53716 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
53720 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
53721
53725 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
53729 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
53730
53734 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
53738 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
53739
53743 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
53747 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
53748
53752 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
53756 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
53757
53761 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
53765 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
53766
53770 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
53774 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
53775
53779 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
53783 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
53784
53788 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
53792 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
53793
53797 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
53801 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
53802
53806 bool set_white_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("white_color", texture, time); }
53810 bool set_white_color(const AColor& texture, double time = TiMe::Default()) { return setValue("white_color", texture, time); }
53814 Value get_white_color(double time = TiMe::Default()) const { return getValue("white_color", time); }
53815
53819 bool set_black_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("black_color", texture, time); }
53823 bool set_black_color(const AColor& texture, double time = TiMe::Default()) { return setValue("black_color", texture, time); }
53827 Value get_black_color(double time = TiMe::Default()) const { return getValue("black_color", time); }
53828
53832 bool set_contrast(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("contrast", texturefloat, time); }
53836 bool set_contrast(float texturefloat, double time = TiMe::Default()) { return setValue("contrast", texturefloat, time); }
53840 Value get_contrast(double time = TiMe::Default()) const { return getValue("contrast", time); }
53841};
53842
53844class TexClamp : public Plugin {
53845public:
53847 static constexpr const PluginTypeId getTypeId() { return 0x4ABB666D8; }
53849 static constexpr const char* getType() { return "TexClamp"; }
53850
53851 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
53852
53855 bool set_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
53858 bool set_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
53861 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
53862
53865 bool set_min_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("min_color", texture, time); }
53868 bool set_min_color(const AColor& texture, double time = TiMe::Default()) { return setValue("min_color", texture, time); }
53871 Value get_min_color(double time = TiMe::Default()) const { return getValue("min_color", time); }
53872
53875 bool set_max_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("max_color", texture, time); }
53878 bool set_max_color(const AColor& texture, double time = TiMe::Default()) { return setValue("max_color", texture, time); }
53881 Value get_max_color(double time = TiMe::Default()) const { return getValue("max_color", time); }
53882};
53883
53885class TexCloth : public Plugin {
53886public:
53888 static constexpr const PluginTypeId getTypeId() { return 0xBF3772A; }
53890 static constexpr const char* getType() { return "TexCloth"; }
53891
53892 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
53893
53897 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
53901 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
53902
53906 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
53910 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
53911
53915 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
53919 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
53920
53924 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
53928 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
53929
53933 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
53937 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
53941 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
53942
53946 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
53950 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
53954 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
53955
53959 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
53963 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
53967 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
53968
53972 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
53976 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
53980 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
53981
53985 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
53989 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
53993 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
53994
53996 PluginRef out_color() const { return PluginRef(*this, "color"); }
53997
53999 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
54000
54002 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
54003
54005 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
54006
54009 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
54012 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
54013
54017 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
54021 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
54022
54026 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
54030 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
54031
54035 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
54039 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
54040
54044 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
54048 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
54049
54053 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
54057 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
54058
54062 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
54066 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
54067
54071 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
54075 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
54076
54080 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
54084 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
54085
54089 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
54093 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
54094
54098 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
54102 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
54103
54107 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
54111 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
54112
54116 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
54120 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
54121
54125 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
54129 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
54130
54134 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
54138 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
54139
54142 bool set_gap_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("gap_color", texture, time); }
54145 bool set_gap_color(const AColor& texture, double time = TiMe::Default()) { return setValue("gap_color", texture, time); }
54148 Value get_gap_color(double time = TiMe::Default()) const { return getValue("gap_color", time); }
54149
54152 bool set_u_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("u_color", texture, time); }
54155 bool set_u_color(const AColor& texture, double time = TiMe::Default()) { return setValue("u_color", texture, time); }
54158 Value get_u_color(double time = TiMe::Default()) const { return getValue("u_color", time); }
54159
54162 bool set_v_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("v_color", texture, time); }
54165 bool set_v_color(const AColor& texture, double time = TiMe::Default()) { return setValue("v_color", texture, time); }
54168 Value get_v_color(double time = TiMe::Default()) const { return getValue("v_color", time); }
54169
54173 bool set_u_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("u_width", texturefloat, time); }
54177 bool set_u_width(float texturefloat, double time = TiMe::Default()) { return setValue("u_width", texturefloat, time); }
54181 Value get_u_width(double time = TiMe::Default()) const { return getValue("u_width", time); }
54182
54186 bool set_v_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("v_width", texturefloat, time); }
54190 bool set_v_width(float texturefloat, double time = TiMe::Default()) { return setValue("v_width", texturefloat, time); }
54194 Value get_v_width(double time = TiMe::Default()) const { return getValue("v_width", time); }
54195
54199 bool set_u_wave(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("u_wave", texturefloat, time); }
54203 bool set_u_wave(float texturefloat, double time = TiMe::Default()) { return setValue("u_wave", texturefloat, time); }
54207 Value get_u_wave(double time = TiMe::Default()) const { return getValue("u_wave", time); }
54208
54212 bool set_v_wave(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("v_wave", texturefloat, time); }
54216 bool set_v_wave(float texturefloat, double time = TiMe::Default()) { return setValue("v_wave", texturefloat, time); }
54220 Value get_v_wave(double time = TiMe::Default()) const { return getValue("v_wave", time); }
54221
54225 bool set_randomness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("randomness", texturefloat, time); }
54229 bool set_randomness(float texturefloat, double time = TiMe::Default()) { return setValue("randomness", texturefloat, time); }
54233 Value get_randomness(double time = TiMe::Default()) const { return getValue("randomness", time); }
54234
54238 bool set_width_spread(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("width_spread", texturefloat, time); }
54242 bool set_width_spread(float texturefloat, double time = TiMe::Default()) { return setValue("width_spread", texturefloat, time); }
54246 Value get_width_spread(double time = TiMe::Default()) const { return getValue("width_spread", time); }
54247
54251 bool set_bright_spread(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("bright_spread", texturefloat, time); }
54255 bool set_bright_spread(float texturefloat, double time = TiMe::Default()) { return setValue("bright_spread", texturefloat, time); }
54259 Value get_bright_spread(double time = TiMe::Default()) const { return getValue("bright_spread", time); }
54260};
54261
54263class TexColor2Scalar : public Plugin {
54264public:
54266 static constexpr const PluginTypeId getTypeId() { return 0x77B108BF; }
54268 static constexpr const char* getType() { return "TexColor2Scalar"; }
54269
54270 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
54271
54273 bool set_clr_txt(const PluginRef& texture, double time = TiMe::Default()) { return setValue("clr_txt", texture, time); }
54275 bool set_clr_txt(const AColor& texture, double time = TiMe::Default()) { return setValue("clr_txt", texture, time); }
54277 Value get_clr_txt(double time = TiMe::Default()) const { return getValue("clr_txt", time); }
54278
54280 bool set_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mult", texturefloat, time); }
54282 bool set_mult(float texturefloat, double time = TiMe::Default()) { return setValue("mult", texturefloat, time); }
54284 Value get_mult(double time = TiMe::Default()) const { return getValue("mult", time); }
54285
54288 bool set_use_alpha(int val, double time = TiMe::Default()) { return setValue("use_alpha", val, time); }
54291 int get_use_alpha(double time = TiMe::Default()) const { return getInt("use_alpha", time); }
54292};
54293
54295class TexColor8Mix : public Plugin {
54296public:
54298 static constexpr const PluginTypeId getTypeId() { return 0x77A21B98; }
54300 static constexpr const char* getType() { return "TexColor8Mix"; }
54301
54302 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
54303
54307 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
54311 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
54312
54316 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
54320 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
54321
54325 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
54329 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
54330
54334 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
54338 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
54339
54343 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
54347 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
54351 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
54352
54356 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
54360 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
54364 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
54365
54369 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
54373 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
54377 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
54378
54382 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
54386 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
54390 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
54391
54395 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
54399 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
54403 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
54404
54406 PluginRef out_color() const { return PluginRef(*this, "color"); }
54407
54409 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
54410
54412 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
54413
54415 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
54416
54418 bool set_base_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("base_color", texture, time); }
54420 bool set_base_color(const AColor& texture, double time = TiMe::Default()) { return setValue("base_color", texture, time); }
54422 Value get_base_color(double time = TiMe::Default()) const { return getValue("base_color", time); }
54423
54425 bool set_color1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
54427 bool set_color1(const AColor& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
54429 Value get_color1(double time = TiMe::Default()) const { return getValue("color1", time); }
54430
54434 bool set_mode1(int val, double time = TiMe::Default()) { return setValue("mode1", val, time); }
54438 int get_mode1(double time = TiMe::Default()) const { return getInt("mode1", time); }
54439
54441 bool set_weight1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight1", texture, time); }
54443 bool set_weight1(const AColor& texture, double time = TiMe::Default()) { return setValue("weight1", texture, time); }
54445 Value get_weight1(double time = TiMe::Default()) const { return getValue("weight1", time); }
54446
54449 bool set_alpha1(bool val, double time = TiMe::Default()) { return setValue("alpha1", val, time); }
54452 bool get_alpha1(double time = TiMe::Default()) const { return getBool("alpha1", time); }
54453
54456 bool set_inuse1(bool val, double time = TiMe::Default()) { return setValue("inuse1", val, time); }
54459 bool get_inuse1(double time = TiMe::Default()) const { return getBool("inuse1", time); }
54460
54462 bool set_color2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
54464 bool set_color2(const AColor& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
54466 Value get_color2(double time = TiMe::Default()) const { return getValue("color2", time); }
54467
54471 bool set_mode2(int val, double time = TiMe::Default()) { return setValue("mode2", val, time); }
54475 int get_mode2(double time = TiMe::Default()) const { return getInt("mode2", time); }
54476
54478 bool set_weight2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight2", texture, time); }
54480 bool set_weight2(const AColor& texture, double time = TiMe::Default()) { return setValue("weight2", texture, time); }
54482 Value get_weight2(double time = TiMe::Default()) const { return getValue("weight2", time); }
54483
54486 bool set_alpha2(bool val, double time = TiMe::Default()) { return setValue("alpha2", val, time); }
54489 bool get_alpha2(double time = TiMe::Default()) const { return getBool("alpha2", time); }
54490
54493 bool set_inuse2(bool val, double time = TiMe::Default()) { return setValue("inuse2", val, time); }
54496 bool get_inuse2(double time = TiMe::Default()) const { return getBool("inuse2", time); }
54497
54499 bool set_color3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color3", texture, time); }
54501 bool set_color3(const AColor& texture, double time = TiMe::Default()) { return setValue("color3", texture, time); }
54503 Value get_color3(double time = TiMe::Default()) const { return getValue("color3", time); }
54504
54508 bool set_mode3(int val, double time = TiMe::Default()) { return setValue("mode3", val, time); }
54512 int get_mode3(double time = TiMe::Default()) const { return getInt("mode3", time); }
54513
54515 bool set_weight3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight3", texture, time); }
54517 bool set_weight3(const AColor& texture, double time = TiMe::Default()) { return setValue("weight3", texture, time); }
54519 Value get_weight3(double time = TiMe::Default()) const { return getValue("weight3", time); }
54520
54523 bool set_alpha3(bool val, double time = TiMe::Default()) { return setValue("alpha3", val, time); }
54526 bool get_alpha3(double time = TiMe::Default()) const { return getBool("alpha3", time); }
54527
54530 bool set_inuse3(bool val, double time = TiMe::Default()) { return setValue("inuse3", val, time); }
54533 bool get_inuse3(double time = TiMe::Default()) const { return getBool("inuse3", time); }
54534
54536 bool set_color4(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color4", texture, time); }
54538 bool set_color4(const AColor& texture, double time = TiMe::Default()) { return setValue("color4", texture, time); }
54540 Value get_color4(double time = TiMe::Default()) const { return getValue("color4", time); }
54541
54545 bool set_mode4(int val, double time = TiMe::Default()) { return setValue("mode4", val, time); }
54549 int get_mode4(double time = TiMe::Default()) const { return getInt("mode4", time); }
54550
54552 bool set_weight4(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight4", texture, time); }
54554 bool set_weight4(const AColor& texture, double time = TiMe::Default()) { return setValue("weight4", texture, time); }
54556 Value get_weight4(double time = TiMe::Default()) const { return getValue("weight4", time); }
54557
54560 bool set_alpha4(bool val, double time = TiMe::Default()) { return setValue("alpha4", val, time); }
54563 bool get_alpha4(double time = TiMe::Default()) const { return getBool("alpha4", time); }
54564
54567 bool set_inuse4(bool val, double time = TiMe::Default()) { return setValue("inuse4", val, time); }
54570 bool get_inuse4(double time = TiMe::Default()) const { return getBool("inuse4", time); }
54571
54573 bool set_color5(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color5", texture, time); }
54575 bool set_color5(const AColor& texture, double time = TiMe::Default()) { return setValue("color5", texture, time); }
54577 Value get_color5(double time = TiMe::Default()) const { return getValue("color5", time); }
54578
54582 bool set_mode5(int val, double time = TiMe::Default()) { return setValue("mode5", val, time); }
54586 int get_mode5(double time = TiMe::Default()) const { return getInt("mode5", time); }
54587
54589 bool set_weight5(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight5", texture, time); }
54591 bool set_weight5(const AColor& texture, double time = TiMe::Default()) { return setValue("weight5", texture, time); }
54593 Value get_weight5(double time = TiMe::Default()) const { return getValue("weight5", time); }
54594
54597 bool set_alpha5(bool val, double time = TiMe::Default()) { return setValue("alpha5", val, time); }
54600 bool get_alpha5(double time = TiMe::Default()) const { return getBool("alpha5", time); }
54601
54604 bool set_inuse5(bool val, double time = TiMe::Default()) { return setValue("inuse5", val, time); }
54607 bool get_inuse5(double time = TiMe::Default()) const { return getBool("inuse5", time); }
54608
54610 bool set_color6(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color6", texture, time); }
54612 bool set_color6(const AColor& texture, double time = TiMe::Default()) { return setValue("color6", texture, time); }
54614 Value get_color6(double time = TiMe::Default()) const { return getValue("color6", time); }
54615
54619 bool set_mode6(int val, double time = TiMe::Default()) { return setValue("mode6", val, time); }
54623 int get_mode6(double time = TiMe::Default()) const { return getInt("mode6", time); }
54624
54626 bool set_weight6(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight6", texture, time); }
54628 bool set_weight6(const AColor& texture, double time = TiMe::Default()) { return setValue("weight6", texture, time); }
54630 Value get_weight6(double time = TiMe::Default()) const { return getValue("weight6", time); }
54631
54634 bool set_alpha6(bool val, double time = TiMe::Default()) { return setValue("alpha6", val, time); }
54637 bool get_alpha6(double time = TiMe::Default()) const { return getBool("alpha6", time); }
54638
54641 bool set_inuse6(bool val, double time = TiMe::Default()) { return setValue("inuse6", val, time); }
54644 bool get_inuse6(double time = TiMe::Default()) const { return getBool("inuse6", time); }
54645
54647 bool set_color7(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color7", texture, time); }
54649 bool set_color7(const AColor& texture, double time = TiMe::Default()) { return setValue("color7", texture, time); }
54651 Value get_color7(double time = TiMe::Default()) const { return getValue("color7", time); }
54652
54656 bool set_mode7(int val, double time = TiMe::Default()) { return setValue("mode7", val, time); }
54660 int get_mode7(double time = TiMe::Default()) const { return getInt("mode7", time); }
54661
54663 bool set_weight7(const PluginRef& texture, double time = TiMe::Default()) { return setValue("weight7", texture, time); }
54665 bool set_weight7(const AColor& texture, double time = TiMe::Default()) { return setValue("weight7", texture, time); }
54667 Value get_weight7(double time = TiMe::Default()) const { return getValue("weight7", time); }
54668
54671 bool set_alpha7(bool val, double time = TiMe::Default()) { return setValue("alpha7", val, time); }
54674 bool get_alpha7(double time = TiMe::Default()) const { return getBool("alpha7", time); }
54675
54678 bool set_inuse7(bool val, double time = TiMe::Default()) { return setValue("inuse7", val, time); }
54681 bool get_inuse7(double time = TiMe::Default()) const { return getBool("inuse7", time); }
54682};
54683
54685class TexColorAndAlpha : public Plugin {
54686public:
54688 static constexpr const PluginTypeId getTypeId() { return 0x77C074BD; }
54690 static constexpr const char* getType() { return "TexColorAndAlpha"; }
54691
54692 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
54693
54696 bool set_color_input(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_input", texture, time); }
54699 bool set_color_input(const AColor& texture, double time = TiMe::Default()) { return setValue("color_input", texture, time); }
54702 Value get_color_input(double time = TiMe::Default()) const { return getValue("color_input", time); }
54703
54706 bool set_alpha_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_input", texturefloat, time); }
54709 bool set_alpha_input(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_input", texturefloat, time); }
54712 Value get_alpha_input(double time = TiMe::Default()) const { return getValue("alpha_input", time); }
54713};
54714
54716class TexColorAverage : public Plugin {
54717public:
54719 static constexpr const PluginTypeId getTypeId() { return 0x77DF4729; }
54721 static constexpr const char* getType() { return "TexColorAverage"; }
54722
54723 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
54724
54727 bool set_input(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
54730 bool set_input(const AColor& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
54733 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
54734
54737 bool set_factor(float val, double time = TiMe::Default()) { return setValue("factor", val, time); }
54740 float get_factor(double time = TiMe::Default()) const { return getFloat("factor", time); }
54741};
54742
54745public:
54747 static constexpr const PluginTypeId getTypeId() { return 0x781C024A; }
54749 static constexpr const char* getType() { return "TexColorCondition"; }
54750
54751 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
54752
54755 bool set_color_a(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
54758 bool set_color_a(const AColor& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
54761 Value get_color_a(double time = TiMe::Default()) const { return getValue("color_a", time); }
54762
54765 bool set_alpha_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_a", texturefloat, time); }
54768 bool set_alpha_a(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_a", texturefloat, time); }
54771 Value get_alpha_a(double time = TiMe::Default()) const { return getValue("alpha_a", time); }
54772
54775 bool set_color_b(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
54778 bool set_color_b(const AColor& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
54781 Value get_color_b(double time = TiMe::Default()) const { return getValue("color_b", time); }
54782
54785 bool set_alpha_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_b", texturefloat, time); }
54788 bool set_alpha_b(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_b", texturefloat, time); }
54791 Value get_alpha_b(double time = TiMe::Default()) const { return getValue("alpha_b", time); }
54792
54795 bool set_condition(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("condition", texturefloat, time); }
54798 bool set_condition(float texturefloat, double time = TiMe::Default()) { return setValue("condition", texturefloat, time); }
54801 Value get_condition(double time = TiMe::Default()) const { return getValue("condition", time); }
54802};
54803
54805class TexColorConstant : public Plugin {
54806public:
54808 static constexpr const PluginTypeId getTypeId() { return 0x781C0249; }
54810 static constexpr const char* getType() { return "TexColorConstant"; }
54811
54812 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
54813
54816 bool set_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
54819 bool set_color(const AColor& texture, double time = TiMe::Default()) { return setValue("color", texture, time); }
54822 Value get_color(double time = TiMe::Default()) const { return getValue("color", time); }
54823
54826 bool set_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
54829 bool set_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
54832 Value get_alpha(double time = TiMe::Default()) const { return getValue("alpha", time); }
54833};
54834
54836class TexColorCorrect : public Plugin {
54837public:
54839 static constexpr const PluginTypeId getTypeId() { return 0x781C02AD; }
54841 static constexpr const char* getType() { return "TexColorCorrect"; }
54842
54843 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
54844
54847 bool set_in_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("in_color", texture, time); }
54850 bool set_in_color(const AColor& texture, double time = TiMe::Default()) { return setValue("in_color", texture, time); }
54853 Value get_in_color(double time = TiMe::Default()) const { return getValue("in_color", time); }
54854
54857 bool set_in_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("in_alpha", texturefloat, time); }
54860 bool set_in_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("in_alpha", texturefloat, time); }
54863 Value get_in_alpha(double time = TiMe::Default()) const { return getValue("in_alpha", time); }
54864
54867 bool set_unpremultiply_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("unpremultiply_input", texturefloat, time); }
54870 bool set_unpremultiply_input(float texturefloat, double time = TiMe::Default()) { return setValue("unpremultiply_input", texturefloat, time); }
54873 Value get_unpremultiply_input(double time = TiMe::Default()) const { return getValue("unpremultiply_input", time); }
54874
54877 bool set_premultiply_result(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("premultiply_result", texturefloat, time); }
54880 bool set_premultiply_result(float texturefloat, double time = TiMe::Default()) { return setValue("premultiply_result", texturefloat, time); }
54883 Value get_premultiply_result(double time = TiMe::Default()) const { return getValue("premultiply_result", time); }
54884
54887 bool set_hue_shift(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hue_shift", texturefloat, time); }
54890 bool set_hue_shift(float texturefloat, double time = TiMe::Default()) { return setValue("hue_shift", texturefloat, time); }
54893 Value get_hue_shift(double time = TiMe::Default()) const { return getValue("hue_shift", time); }
54894
54897 bool set_sat_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sat_gain", texturefloat, time); }
54900 bool set_sat_gain(float texturefloat, double time = TiMe::Default()) { return setValue("sat_gain", texturefloat, time); }
54903 Value get_sat_gain(double time = TiMe::Default()) const { return getValue("sat_gain", time); }
54904
54907 bool set_val_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("val_gain", texturefloat, time); }
54910 bool set_val_gain(float texturefloat, double time = TiMe::Default()) { return setValue("val_gain", texturefloat, time); }
54913 Value get_val_gain(double time = TiMe::Default()) const { return getValue("val_gain", time); }
54914
54917 bool set_col_gain(const PluginRef& texture, double time = TiMe::Default()) { return setValue("col_gain", texture, time); }
54920 bool set_col_gain(const AColor& texture, double time = TiMe::Default()) { return setValue("col_gain", texture, time); }
54923 Value get_col_gain(double time = TiMe::Default()) const { return getValue("col_gain", time); }
54924
54927 bool set_col_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("col_offset", texture, time); }
54930 bool set_col_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("col_offset", texture, time); }
54933 Value get_col_offset(double time = TiMe::Default()) const { return getValue("col_offset", time); }
54934
54937 bool set_col_gamma(const PluginRef& texture, double time = TiMe::Default()) { return setValue("col_gamma", texture, time); }
54940 bool set_col_gamma(const AColor& texture, double time = TiMe::Default()) { return setValue("col_gamma", texture, time); }
54943 Value get_col_gamma(double time = TiMe::Default()) const { return getValue("col_gamma", time); }
54944
54947 bool set_col_clamp(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("col_clamp", texturefloat, time); }
54950 bool set_col_clamp(float texturefloat, double time = TiMe::Default()) { return setValue("col_clamp", texturefloat, time); }
54953 Value get_col_clamp(double time = TiMe::Default()) const { return getValue("col_clamp", time); }
54954
54957 bool set_col_clamp_min(const PluginRef& texture, double time = TiMe::Default()) { return setValue("col_clamp_min", texture, time); }
54960 bool set_col_clamp_min(const AColor& texture, double time = TiMe::Default()) { return setValue("col_clamp_min", texture, time); }
54963 Value get_col_clamp_min(double time = TiMe::Default()) const { return getValue("col_clamp_min", time); }
54964
54967 bool set_col_clamp_max(const PluginRef& texture, double time = TiMe::Default()) { return setValue("col_clamp_max", texture, time); }
54970 bool set_col_clamp_max(const AColor& texture, double time = TiMe::Default()) { return setValue("col_clamp_max", texture, time); }
54973 Value get_col_clamp_max(double time = TiMe::Default()) const { return getValue("col_clamp_max", time); }
54974
54977 bool set_alpha_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_gain", texturefloat, time); }
54980 bool set_alpha_gain(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_gain", texturefloat, time); }
54983 Value get_alpha_gain(double time = TiMe::Default()) const { return getValue("alpha_gain", time); }
54984
54987 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
54990 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
54993 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
54994
54997 bool set_alpha_gamma(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_gamma", texturefloat, time); }
55000 bool set_alpha_gamma(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_gamma", texturefloat, time); }
55003 Value get_alpha_gamma(double time = TiMe::Default()) const { return getValue("alpha_gamma", time); }
55004
55007 bool set_alpha_clamp(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_clamp", texturefloat, time); }
55010 bool set_alpha_clamp(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_clamp", texturefloat, time); }
55013 Value get_alpha_clamp(double time = TiMe::Default()) const { return getValue("alpha_clamp", time); }
55014
55017 bool set_alpha_clamp_min(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_clamp_min", texturefloat, time); }
55020 bool set_alpha_clamp_min(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_clamp_min", texturefloat, time); }
55023 Value get_alpha_clamp_min(double time = TiMe::Default()) const { return getValue("alpha_clamp_min", time); }
55024
55027 bool set_alpha_clamp_max(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_clamp_max", texturefloat, time); }
55030 bool set_alpha_clamp_max(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_clamp_max", texturefloat, time); }
55033 Value get_alpha_clamp_max(double time = TiMe::Default()) const { return getValue("alpha_clamp_max", time); }
55034};
55035
55037class TexColorCurve : public Plugin {
55038public:
55040 static constexpr const PluginTypeId getTypeId() { return 0x77DF47F9; }
55042 static constexpr const char* getType() { return "TexColorCurve"; }
55043
55044 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55045
55047 bool set_input(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
55049 bool set_input(const AColor& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
55051 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
55052
55054 bool set_inputScalar(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("inputScalar", texturefloat, time); }
55056 bool set_inputScalar(float texturefloat, double time = TiMe::Default()) { return setValue("inputScalar", texturefloat, time); }
55058 Value get_inputScalar(double time = TiMe::Default()) const { return getValue("inputScalar", time); }
55059
55062 bool set_rkeys(const FloatList& floatList, double time = TiMe::Default()) { return setValue("rkeys", floatList, time); }
55063 bool set_rkeys(FloatList&& floatList, double time = TiMe::Default()) { return setValue("rkeys", std::move(floatList), time); }
55064 bool set_rkeys(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("rkeys", floats, count, time); }
55065 template<size_t count> bool set_rkeys(const float (&floats)[count], double time = TiMe::Default()) { return setArray("rkeys", floats, count, time); }
55068 FloatList get_rkeys(double time = TiMe::Default()) const { return getFloatList("rkeys", time); }
55069
55072 bool set_gkeys(const FloatList& floatList, double time = TiMe::Default()) { return setValue("gkeys", floatList, time); }
55073 bool set_gkeys(FloatList&& floatList, double time = TiMe::Default()) { return setValue("gkeys", std::move(floatList), time); }
55074 bool set_gkeys(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("gkeys", floats, count, time); }
55075 template<size_t count> bool set_gkeys(const float (&floats)[count], double time = TiMe::Default()) { return setArray("gkeys", floats, count, time); }
55078 FloatList get_gkeys(double time = TiMe::Default()) const { return getFloatList("gkeys", time); }
55079
55082 bool set_bkeys(const FloatList& floatList, double time = TiMe::Default()) { return setValue("bkeys", floatList, time); }
55083 bool set_bkeys(FloatList&& floatList, double time = TiMe::Default()) { return setValue("bkeys", std::move(floatList), time); }
55084 bool set_bkeys(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("bkeys", floats, count, time); }
55085 template<size_t count> bool set_bkeys(const float (&floats)[count], double time = TiMe::Default()) { return setArray("bkeys", floats, count, time); }
55088 FloatList get_bkeys(double time = TiMe::Default()) const { return getFloatList("bkeys", time); }
55089
55092 bool set_use_alpha(bool val, double time = TiMe::Default()) { return setValue("use_alpha", val, time); }
55095 bool get_use_alpha(double time = TiMe::Default()) const { return getBool("use_alpha", time); }
55096
55099 bool set_akeys(const FloatList& floatList, double time = TiMe::Default()) { return setValue("akeys", floatList, time); }
55100 bool set_akeys(FloatList&& floatList, double time = TiMe::Default()) { return setValue("akeys", std::move(floatList), time); }
55101 bool set_akeys(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("akeys", floats, count, time); }
55102 template<size_t count> bool set_akeys(const float (&floats)[count], double time = TiMe::Default()) { return setArray("akeys", floats, count, time); }
55105 FloatList get_akeys(double time = TiMe::Default()) const { return getFloatList("akeys", time); }
55106};
55107
55110public:
55112 static constexpr const PluginTypeId getTypeId() { return 0x77ECD766; }
55114 static constexpr const char* getType() { return "TexColorExponential"; }
55115
55116 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55117
55119 bool set_input(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
55121 bool set_input(const AColor& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
55123 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
55124
55126 bool set_factor(const PluginRef& texture, double time = TiMe::Default()) { return setValue("factor", texture, time); }
55128 bool set_factor(const AColor& texture, double time = TiMe::Default()) { return setValue("factor", texture, time); }
55130 Value get_factor(double time = TiMe::Default()) const { return getValue("factor", time); }
55131
55135 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
55139 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
55140
55143 bool set_use_alpha(bool val, double time = TiMe::Default()) { return setValue("use_alpha", val, time); }
55146 bool get_use_alpha(double time = TiMe::Default()) const { return getBool("use_alpha", time); }
55147};
55148
55150class TexColorLogic : public Plugin {
55151public:
55153 static constexpr const PluginTypeId getTypeId() { return 0x781C024D; }
55155 static constexpr const char* getType() { return "TexColorLogic"; }
55156
55157 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
55158
55161 bool set_color_a(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
55164 bool set_color_a(const AColor& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
55167 Value get_color_a(double time = TiMe::Default()) const { return getValue("color_a", time); }
55168
55171 bool set_color_b(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
55174 bool set_color_b(const AColor& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
55177 Value get_color_b(double time = TiMe::Default()) const { return getValue("color_b", time); }
55178
55181 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
55184 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
55185};
55186
55188class TexColorMask : public Plugin {
55189public:
55191 static constexpr const PluginTypeId getTypeId() { return 0x781C02AE; }
55193 static constexpr const char* getType() { return "TexColorMask"; }
55194
55195 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55196
55199 bool set_in_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("in_color", texture, time); }
55202 bool set_in_color(const AColor& texture, double time = TiMe::Default()) { return setValue("in_color", texture, time); }
55205 Value get_in_color(double time = TiMe::Default()) const { return getValue("in_color", time); }
55206
55209 bool set_in_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("in_alpha", texturefloat, time); }
55212 bool set_in_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("in_alpha", texturefloat, time); }
55215 Value get_in_alpha(double time = TiMe::Default()) const { return getValue("in_alpha", time); }
55216
55219 bool set_preserve_color(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("preserve_color", texturefloat, time); }
55222 bool set_preserve_color(float texturefloat, double time = TiMe::Default()) { return setValue("preserve_color", texturefloat, time); }
55225 Value get_preserve_color(double time = TiMe::Default()) const { return getValue("preserve_color", time); }
55226
55229 bool set_mask(const PluginRef& texture, double time = TiMe::Default()) { return setValue("mask", texture, time); }
55232 bool set_mask(const AColor& texture, double time = TiMe::Default()) { return setValue("mask", texture, time); }
55235 Value get_mask(double time = TiMe::Default()) const { return getValue("mask", time); }
55236
55239 bool set_mask_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mask_alpha", texturefloat, time); }
55242 bool set_mask_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("mask_alpha", texturefloat, time); }
55245 Value get_mask_alpha(double time = TiMe::Default()) const { return getValue("mask_alpha", time); }
55246
55249 bool set_mask_alpha_is_luminance(float val, double time = TiMe::Default()) { return setValue("mask_alpha_is_luminance", val, time); }
55252 float get_mask_alpha_is_luminance(double time = TiMe::Default()) const { return getFloat("mask_alpha_is_luminance", time); }
55253};
55254
55257public:
55259 static constexpr const PluginTypeId getTypeId() { return 0x77DEF6B2; }
55261 static constexpr const char* getType() { return "TexColorMathBasic"; }
55262
55263 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55264
55267 bool set_op(int val, double time = TiMe::Default()) { return setValue("op", val, time); }
55270 int get_op(double time = TiMe::Default()) const { return getInt("op", time); }
55271
55274 bool set_alpha(bool val, double time = TiMe::Default()) { return setValue("alpha", val, time); }
55277 bool get_alpha(double time = TiMe::Default()) const { return getBool("alpha", time); }
55278
55281 bool set_input1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input1", texture, time); }
55284 bool set_input1(const AColor& texture, double time = TiMe::Default()) { return setValue("input1", texture, time); }
55287 Value get_input1(double time = TiMe::Default()) const { return getValue("input1", time); }
55288
55291 bool set_input2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input2", texture, time); }
55294 bool set_input2(const AColor& texture, double time = TiMe::Default()) { return setValue("input2", texture, time); }
55297 Value get_input2(double time = TiMe::Default()) const { return getValue("input2", time); }
55298};
55299
55301class TexColorSwitch : public Plugin {
55302public:
55304 static constexpr const PluginTypeId getTypeId() { return 0x77D00236; }
55306 static constexpr const char* getType() { return "TexColorSwitch"; }
55307
55308 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55309
55310 operator TextureIntPluginCategory() { return *static_cast<TextureIntPluginCategory*>(static_cast<Plugin*>(this)); }
55311
55315 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
55319 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
55320
55324 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
55328 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
55329
55333 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
55337 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
55338
55342 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
55346 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
55347
55351 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
55355 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
55359 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
55360
55364 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
55368 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
55372 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
55373
55377 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
55381 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
55385 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
55386
55390 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
55394 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
55398 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
55399
55403 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
55407 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
55411 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
55412
55414 PluginRef out_color() const { return PluginRef(*this, "color"); }
55415
55417 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
55418
55420 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
55421
55423 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
55424
55426 bool set_default_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("default_color", texture, time); }
55428 bool set_default_color(const AColor& texture, double time = TiMe::Default()) { return setValue("default_color", texture, time); }
55430 Value get_default_color(double time = TiMe::Default()) const { return getValue("default_color", time); }
55431
55434 bool set_switch_value(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("switch_value", textureint, time); }
55437 bool set_switch_value(int textureint, double time = TiMe::Default()) { return setValue("switch_value", textureint, time); }
55440 Value get_switch_value(double time = TiMe::Default()) const { return getValue("switch_value", time); }
55441
55443 bool set_color0(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color0", texture, time); }
55445 bool set_color0(const AColor& texture, double time = TiMe::Default()) { return setValue("color0", texture, time); }
55447 Value get_color0(double time = TiMe::Default()) const { return getValue("color0", time); }
55448
55451 bool set_value0(int val, double time = TiMe::Default()) { return setValue("value0", val, time); }
55454 int get_value0(double time = TiMe::Default()) const { return getInt("value0", time); }
55455
55457 bool set_color1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
55459 bool set_color1(const AColor& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
55461 Value get_color1(double time = TiMe::Default()) const { return getValue("color1", time); }
55462
55465 bool set_value1(int val, double time = TiMe::Default()) { return setValue("value1", val, time); }
55468 int get_value1(double time = TiMe::Default()) const { return getInt("value1", time); }
55469
55471 bool set_color2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
55473 bool set_color2(const AColor& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
55475 Value get_color2(double time = TiMe::Default()) const { return getValue("color2", time); }
55476
55479 bool set_value2(int val, double time = TiMe::Default()) { return setValue("value2", val, time); }
55482 int get_value2(double time = TiMe::Default()) const { return getInt("value2", time); }
55483
55485 bool set_color3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color3", texture, time); }
55487 bool set_color3(const AColor& texture, double time = TiMe::Default()) { return setValue("color3", texture, time); }
55489 Value get_color3(double time = TiMe::Default()) const { return getValue("color3", time); }
55490
55493 bool set_value3(int val, double time = TiMe::Default()) { return setValue("value3", val, time); }
55496 int get_value3(double time = TiMe::Default()) const { return getInt("value3", time); }
55497
55499 bool set_color4(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color4", texture, time); }
55501 bool set_color4(const AColor& texture, double time = TiMe::Default()) { return setValue("color4", texture, time); }
55503 Value get_color4(double time = TiMe::Default()) const { return getValue("color4", time); }
55504
55507 bool set_value4(int val, double time = TiMe::Default()) { return setValue("value4", val, time); }
55510 int get_value4(double time = TiMe::Default()) const { return getInt("value4", time); }
55511
55513 bool set_color5(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color5", texture, time); }
55515 bool set_color5(const AColor& texture, double time = TiMe::Default()) { return setValue("color5", texture, time); }
55517 Value get_color5(double time = TiMe::Default()) const { return getValue("color5", time); }
55518
55521 bool set_value5(int val, double time = TiMe::Default()) { return setValue("value5", val, time); }
55524 int get_value5(double time = TiMe::Default()) const { return getInt("value5", time); }
55525
55527 bool set_color6(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color6", texture, time); }
55529 bool set_color6(const AColor& texture, double time = TiMe::Default()) { return setValue("color6", texture, time); }
55531 Value get_color6(double time = TiMe::Default()) const { return getValue("color6", time); }
55532
55535 bool set_value6(int val, double time = TiMe::Default()) { return setValue("value6", val, time); }
55538 int get_value6(double time = TiMe::Default()) const { return getInt("value6", time); }
55539
55541 bool set_color7(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color7", texture, time); }
55543 bool set_color7(const AColor& texture, double time = TiMe::Default()) { return setValue("color7", texture, time); }
55545 Value get_color7(double time = TiMe::Default()) const { return getValue("color7", time); }
55546
55549 bool set_value7(int val, double time = TiMe::Default()) { return setValue("value7", val, time); }
55552 int get_value7(double time = TiMe::Default()) const { return getInt("value7", time); }
55553};
55554
55556class TexColorToFloat : public Plugin {
55557public:
55559 static constexpr const PluginTypeId getTypeId() { return 0x77BF8DE1; }
55561 static constexpr const char* getType() { return "TexColorToFloat"; }
55562
55563 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
55564
55567 bool set_input(const PluginRef& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
55570 bool set_input(const AColor& texture, double time = TiMe::Default()) { return setValue("input", texture, time); }
55573 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
55574};
55575
55577class TexCombineColor : public Plugin {
55578public:
55580 static constexpr const PluginTypeId getTypeId() { return 0x77BF6416; }
55582 static constexpr const char* getType() { return "TexCombineColor"; }
55583
55584 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55585
55589 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
55593 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
55594
55597 bool set_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
55600 bool set_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
55603 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
55604
55608 bool set_texture_multiplier(float val, double time = TiMe::Default()) { return setValue("texture_multiplier", val, time); }
55612 float get_texture_multiplier(double time = TiMe::Default()) const { return getFloat("texture_multiplier", time); }
55613
55616 bool set_result_invert(bool val, double time = TiMe::Default()) { return setValue("result_invert", val, time); }
55619 bool get_result_invert(double time = TiMe::Default()) const { return getBool("result_invert", time); }
55620
55623 bool set_result_multiplier(float val, double time = TiMe::Default()) { return setValue("result_multiplier", val, time); }
55626 float get_result_multiplier(double time = TiMe::Default()) const { return getFloat("result_multiplier", time); }
55627};
55628
55631public:
55633 static constexpr const PluginTypeId getTypeId() { return 0x77BFB362; }
55635 static constexpr const char* getType() { return "TexCombineColorLightMtl"; }
55636
55637 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55638
55642 bool set_color(const Color& color, double time = TiMe::Default()) { return setValue("color", color, time); }
55646 Color get_color(double time = TiMe::Default()) const { return getColor("color", time); }
55647
55651 bool set_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
55655 bool set_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
55659 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
55660
55663 bool set_result_multiplier(float val, double time = TiMe::Default()) { return setValue("result_multiplier", val, time); }
55666 float get_result_multiplier(double time = TiMe::Default()) const { return getFloat("result_multiplier", time); }
55667};
55668
55670class TexCombineFloat : public Plugin {
55671public:
55673 static constexpr const PluginTypeId getTypeId() { return 0x77B15F69; }
55675 static constexpr const char* getType() { return "TexCombineFloat"; }
55676
55677 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
55678
55682 bool set_value(float val, double time = TiMe::Default()) { return setValue("value", val, time); }
55686 float get_value(double time = TiMe::Default()) const { return getFloat("value", time); }
55687
55690 bool set_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
55693 bool set_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
55696 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
55697
55701 bool set_texture_multiplier(float val, double time = TiMe::Default()) { return setValue("texture_multiplier", val, time); }
55705 float get_texture_multiplier(double time = TiMe::Default()) const { return getFloat("texture_multiplier", time); }
55706
55710 bool set_texture_clamp(bool val, double time = TiMe::Default()) { return setValue("texture_clamp", val, time); }
55714 bool get_texture_clamp(double time = TiMe::Default()) const { return getBool("texture_clamp", time); }
55715
55719 bool set_result_multiplier(float val, double time = TiMe::Default()) { return setValue("result_multiplier", val, time); }
55723 float get_result_multiplier(double time = TiMe::Default()) const { return getFloat("result_multiplier", time); }
55724};
55725
55727class TexCompMax : public Plugin {
55728public:
55730 static constexpr const PluginTypeId getTypeId() { return 0x77BF851C; }
55732 static constexpr const char* getType() { return "TexCompMax"; }
55733
55734 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55735
55739 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
55743 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
55744
55748 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
55752 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
55753
55757 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
55761 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
55762
55766 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
55770 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
55771
55775 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
55779 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
55783 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
55784
55788 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
55792 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
55796 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
55797
55801 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
55805 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
55809 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
55810
55814 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
55818 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
55822 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
55823
55827 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
55831 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
55835 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
55836
55838 PluginRef out_color() const { return PluginRef(*this, "color"); }
55839
55841 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
55842
55844 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
55845
55847 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
55848
55852 bool set_sourceA(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sourceA", texture, time); }
55856 bool set_sourceA(const AColor& texture, double time = TiMe::Default()) { return setValue("sourceA", texture, time); }
55860 Value get_sourceA(double time = TiMe::Default()) const { return getValue("sourceA", time); }
55861
55865 bool set_sourceB(const PluginRef& texture, double time = TiMe::Default()) { return setValue("sourceB", texture, time); }
55869 bool set_sourceB(const AColor& texture, double time = TiMe::Default()) { return setValue("sourceB", texture, time); }
55873 Value get_sourceB(double time = TiMe::Default()) const { return getValue("sourceB", time); }
55874
55878 bool set_operator(int val, double time = TiMe::Default()) { return setValue("operator", val, time); }
55882 int get_operator(double time = TiMe::Default()) const { return getInt("operator", time); }
55883
55887 bool set_mix_amount(float val, double time = TiMe::Default()) { return setValue("mix_amount", val, time); }
55891 float get_mix_amount(double time = TiMe::Default()) const { return getFloat("mix_amount", time); }
55892};
55893
55896public:
55898 static constexpr const PluginTypeId getTypeId() { return 0x784BEA1D; }
55900 static constexpr const char* getType() { return "TexComplexFresnel"; }
55901
55902 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
55903
55907 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
55911 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
55912
55916 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
55920 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
55921
55925 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
55929 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
55930
55934 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
55938 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
55939
55943 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
55947 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
55951 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
55952
55956 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
55960 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
55964 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
55965
55969 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
55973 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
55977 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
55978
55982 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
55986 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
55990 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
55991
55995 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
55999 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
56003 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
56004
56006 PluginRef out_color() const { return PluginRef(*this, "color"); }
56007
56009 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
56010
56012 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
56013
56015 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
56016
56020 bool set_n_red(float val, double time = TiMe::Default()) { return setValue("n_red", val, time); }
56024 float get_n_red(double time = TiMe::Default()) const { return getFloat("n_red", time); }
56025
56029 bool set_n_green(float val, double time = TiMe::Default()) { return setValue("n_green", val, time); }
56033 float get_n_green(double time = TiMe::Default()) const { return getFloat("n_green", time); }
56034
56038 bool set_n_blue(float val, double time = TiMe::Default()) { return setValue("n_blue", val, time); }
56042 float get_n_blue(double time = TiMe::Default()) const { return getFloat("n_blue", time); }
56043
56047 bool set_k_red(float val, double time = TiMe::Default()) { return setValue("k_red", val, time); }
56051 float get_k_red(double time = TiMe::Default()) const { return getFloat("k_red", time); }
56052
56056 bool set_k_green(float val, double time = TiMe::Default()) { return setValue("k_green", val, time); }
56060 float get_k_green(double time = TiMe::Default()) const { return getFloat("k_green", time); }
56061
56065 bool set_k_blue(float val, double time = TiMe::Default()) { return setValue("k_blue", val, time); }
56069 float get_k_blue(double time = TiMe::Default()) const { return getFloat("k_blue", time); }
56070
56074 bool set_gamma(float val, double time = TiMe::Default()) { return setValue("gamma", val, time); }
56078 float get_gamma(double time = TiMe::Default()) const { return getFloat("gamma", time); }
56079
56083 bool set_hue(float val, double time = TiMe::Default()) { return setValue("hue", val, time); }
56087 float get_hue(double time = TiMe::Default()) const { return getFloat("hue", time); }
56088
56092 bool set_sat(float val, double time = TiMe::Default()) { return setValue("sat", val, time); }
56096 float get_sat(double time = TiMe::Default()) const { return getFloat("sat", time); }
56097};
56098
56100class TexComposite : public Plugin {
56101public:
56103 static constexpr const PluginTypeId getTypeId() { return 0x781C011E; }
56105 static constexpr const char* getType() { return "TexComposite"; }
56106
56107 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
56108
56111 bool set_color_a(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
56114 bool set_color_a(const AColor& texture, double time = TiMe::Default()) { return setValue("color_a", texture, time); }
56117 Value get_color_a(double time = TiMe::Default()) const { return getValue("color_a", time); }
56118
56121 bool set_alpha_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_a", texturefloat, time); }
56124 bool set_alpha_a(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_a", texturefloat, time); }
56127 Value get_alpha_a(double time = TiMe::Default()) const { return getValue("alpha_a", time); }
56128
56131 bool set_color_b(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
56134 bool set_color_b(const AColor& texture, double time = TiMe::Default()) { return setValue("color_b", texture, time); }
56137 Value get_color_b(double time = TiMe::Default()) const { return getValue("color_b", time); }
56138
56141 bool set_alpha_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_b", texturefloat, time); }
56144 bool set_alpha_b(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_b", texturefloat, time); }
56147 Value get_alpha_b(double time = TiMe::Default()) const { return getValue("alpha_b", time); }
56148
56151 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
56154 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
56155
56158 bool set_factor(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("factor", texturefloat, time); }
56161 bool set_factor(float texturefloat, double time = TiMe::Default()) { return setValue("factor", texturefloat, time); }
56164 Value get_factor(double time = TiMe::Default()) const { return getValue("factor", time); }
56165};
56166
56168class TexCondition : public Plugin {
56169public:
56171 static constexpr const PluginTypeId getTypeId() { return 0x77A1A85C; }
56173 static constexpr const char* getType() { return "TexCondition"; }
56174
56175 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
56176
56180 bool set_operation(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("operation", textureint, time); }
56184 bool set_operation(int textureint, double time = TiMe::Default()) { return setValue("operation", textureint, time); }
56188 Value get_operation(double time = TiMe::Default()) const { return getValue("operation", time); }
56189
56192 bool set_op_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("op_a", texturefloat, time); }
56195 bool set_op_a(float texturefloat, double time = TiMe::Default()) { return setValue("op_a", texturefloat, time); }
56198 Value get_op_a(double time = TiMe::Default()) const { return getValue("op_a", time); }
56199
56202 bool set_op_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("op_b", texturefloat, time); }
56205 bool set_op_b(float texturefloat, double time = TiMe::Default()) { return setValue("op_b", texturefloat, time); }
56208 Value get_op_b(double time = TiMe::Default()) const { return getValue("op_b", time); }
56209
56212 bool set_result_true(const PluginRef& texture, double time = TiMe::Default()) { return setValue("result_true", texture, time); }
56215 bool set_result_true(const AColor& texture, double time = TiMe::Default()) { return setValue("result_true", texture, time); }
56218 Value get_result_true(double time = TiMe::Default()) const { return getValue("result_true", time); }
56219
56222 bool set_result_false(const PluginRef& texture, double time = TiMe::Default()) { return setValue("result_false", texture, time); }
56225 bool set_result_false(const AColor& texture, double time = TiMe::Default()) { return setValue("result_false", texture, time); }
56228 Value get_result_false(double time = TiMe::Default()) const { return getValue("result_false", time); }
56229
56231 PluginRef out_color() const { return PluginRef(*this, "color"); }
56232};
56233
56235class TexCondition2 : public Plugin {
56236public:
56238 static constexpr const PluginTypeId getTypeId() { return 0x77BF3B11; }
56240 static constexpr const char* getType() { return "TexCondition2"; }
56241
56242 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
56243
56247 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
56251 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
56252
56255 bool set_first_term(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("first_term", texturefloat, time); }
56258 bool set_first_term(float texturefloat, double time = TiMe::Default()) { return setValue("first_term", texturefloat, time); }
56261 Value get_first_term(double time = TiMe::Default()) const { return getValue("first_term", time); }
56262
56265 bool set_second_term(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("second_term", texturefloat, time); }
56268 bool set_second_term(float texturefloat, double time = TiMe::Default()) { return setValue("second_term", texturefloat, time); }
56271 Value get_second_term(double time = TiMe::Default()) const { return getValue("second_term", time); }
56272
56275 bool set_color_if_true(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_if_true", texture, time); }
56278 bool set_color_if_true(const AColor& texture, double time = TiMe::Default()) { return setValue("color_if_true", texture, time); }
56281 Value get_color_if_true(double time = TiMe::Default()) const { return getValue("color_if_true", time); }
56282
56285 bool set_color_if_false(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_if_false", texture, time); }
56288 bool set_color_if_false(const AColor& texture, double time = TiMe::Default()) { return setValue("color_if_false", texture, time); }
56291 Value get_color_if_false(double time = TiMe::Default()) const { return getValue("color_if_false", time); }
56292};
56293
56295class TexCurvature : public Plugin {
56296public:
56298 static constexpr const PluginTypeId getTypeId() { return 0xBFFB878; }
56300 static constexpr const char* getType() { return "TexCurvature"; }
56301
56302 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
56303
56307 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
56311 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
56312
56316 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
56320 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
56321
56325 bool set_sample_spread(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("sample_spread", texturefloat, time); }
56329 bool set_sample_spread(float texturefloat, double time = TiMe::Default()) { return setValue("sample_spread", texturefloat, time); }
56333 Value get_sample_spread(double time = TiMe::Default()) const { return getValue("sample_spread", time); }
56334
56338 bool set_out_color_min(float val, double time = TiMe::Default()) { return setValue("out_color_min", val, time); }
56342 float get_out_color_min(double time = TiMe::Default()) const { return getFloat("out_color_min", time); }
56343
56347 bool set_out_color_max(float val, double time = TiMe::Default()) { return setValue("out_color_max", val, time); }
56351 float get_out_color_max(double time = TiMe::Default()) const { return getFloat("out_color_max", time); }
56352
56356 bool set_scale(float val, double time = TiMe::Default()) { return setValue("scale", val, time); }
56360 float get_scale(double time = TiMe::Default()) const { return getFloat("scale", time); }
56361
56365 bool set_trace_distance(float val, double time = TiMe::Default()) { return setValue("trace_distance", val, time); }
56369 float get_trace_distance(double time = TiMe::Default()) const { return getFloat("trace_distance", time); }
56370
56374 bool set_threshold(float val, double time = TiMe::Default()) { return setValue("threshold", val, time); }
56378 float get_threshold(double time = TiMe::Default()) const { return getFloat("threshold", time); }
56379
56383 bool set_out_color_gain(float val, double time = TiMe::Default()) { return setValue("out_color_gain", val, time); }
56387 float get_out_color_gain(double time = TiMe::Default()) const { return getFloat("out_color_gain", time); }
56388
56392 bool set_out_color_lift(float val, double time = TiMe::Default()) { return setValue("out_color_lift", val, time); }
56396 float get_out_color_lift(double time = TiMe::Default()) const { return getFloat("out_color_lift", time); }
56397
56401 bool set_out_color_gamma(float val, double time = TiMe::Default()) { return setValue("out_color_gamma", val, time); }
56405 float get_out_color_gamma(double time = TiMe::Default()) const { return getFloat("out_color_gamma", time); }
56406
56410 bool set_out_color_pivot(float val, double time = TiMe::Default()) { return setValue("out_color_pivot", val, time); }
56414 float get_out_color_pivot(double time = TiMe::Default()) const { return getFloat("out_color_pivot", time); }
56415
56419 bool set_out_color_clamp(bool val, double time = TiMe::Default()) { return setValue("out_color_clamp", val, time); }
56423 bool get_out_color_clamp(double time = TiMe::Default()) const { return getBool("out_color_clamp", time); }
56424
56427 bool set_ignore_bump(bool val, double time = TiMe::Default()) { return setValue("ignore_bump", val, time); }
56430 bool get_ignore_bump(double time = TiMe::Default()) const { return getBool("ignore_bump", time); }
56431};
56432
56434class TexCustomBitmap : public Plugin {
56435public:
56437 static constexpr const PluginTypeId getTypeId() { return 0x77CF8FED; }
56439 static constexpr const char* getType() { return "TexCustomBitmap"; }
56440
56441 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
56442
56446 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
56450 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
56451
56455 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
56459 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
56460
56464 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
56468 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
56469
56473 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
56477 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
56478
56482 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
56486 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
56490 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
56491
56495 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
56499 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
56503 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
56504
56508 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
56512 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
56516 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
56517
56521 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
56525 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
56529 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
56530
56534 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
56538 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
56542 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
56543
56545 PluginRef out_color() const { return PluginRef(*this, "color"); }
56546
56548 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
56549
56551 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
56552
56554 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
56555
56558 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
56561 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
56562
56566 bool set_tile(int val, double time = TiMe::Default()) { return setValue("tile", val, time); }
56570 int get_tile(double time = TiMe::Default()) const { return getInt("tile", time); }
56571
56575 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
56579 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
56580
56584 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
56588 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
56589
56593 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
56597 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
56598
56602 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
56606 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
56607
56611 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
56615 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
56616
56620 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
56624 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
56625
56629 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
56633 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
56634
56638 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
56642 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
56643
56647 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
56651 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
56652
56656 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
56660 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
56661
56665 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
56669 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
56670
56674 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
56678 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
56679
56683 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
56687 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
56688
56692 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
56696 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
56697};
56698
56700class TexDent : public Plugin {
56701public:
56703 static constexpr const PluginTypeId getTypeId() { return 0x784A8A7A; }
56705 static constexpr const char* getType() { return "TexDent"; }
56706
56707 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
56708
56712 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
56716 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
56717
56721 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
56725 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
56726
56730 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
56734 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
56735
56739 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
56743 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
56744
56748 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
56752 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
56756 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
56757
56761 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
56765 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
56769 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
56770
56774 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
56778 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
56782 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
56783
56787 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
56791 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
56795 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
56796
56800 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
56804 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
56808 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
56809
56811 PluginRef out_color() const { return PluginRef(*this, "color"); }
56812
56814 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
56815
56817 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
56818
56820 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
56821
56824 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
56827 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
56828
56832 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
56836 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
56837
56841 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
56845 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
56846
56850 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
56854 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
56855
56859 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
56863 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
56864
56868 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
56872 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
56873
56877 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
56881 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
56882
56886 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
56890 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
56891
56895 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
56899 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
56900
56904 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
56908 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
56909
56913 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
56917 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
56918
56922 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
56926 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
56927
56931 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
56935 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
56936
56940 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
56944 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
56945
56949 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
56953 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
56954
56957 bool set_color1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
56960 bool set_color1(const AColor& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
56963 Value get_color1(double time = TiMe::Default()) const { return getValue("color1", time); }
56964
56967 bool set_color2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
56970 bool set_color2(const AColor& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
56973 Value get_color2(double time = TiMe::Default()) const { return getValue("color2", time); }
56974
56978 bool set_size(float val, double time = TiMe::Default()) { return setValue("size", val, time); }
56982 float get_size(double time = TiMe::Default()) const { return getFloat("size", time); }
56983
56987 bool set_strength(float val, double time = TiMe::Default()) { return setValue("strength", val, time); }
56991 float get_strength(double time = TiMe::Default()) const { return getFloat("strength", time); }
56992
56996 bool set_iterations(int val, double time = TiMe::Default()) { return setValue("iterations", val, time); }
57000 int get_iterations(double time = TiMe::Default()) const { return getInt("iterations", time); }
57001};
57002
57004class TexDirt : public Plugin {
57005public:
57007 static constexpr const PluginTypeId getTypeId() { return 0xBF4F23A; }
57009 static constexpr const char* getType() { return "TexDirt"; }
57010
57011 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
57012
57016 bool set_white_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("white_color", texture, time); }
57020 bool set_white_color(const AColor& texture, double time = TiMe::Default()) { return setValue("white_color", texture, time); }
57024 Value get_white_color(double time = TiMe::Default()) const { return getValue("white_color", time); }
57025
57029 bool set_black_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("black_color", texture, time); }
57033 bool set_black_color(const AColor& texture, double time = TiMe::Default()) { return setValue("black_color", texture, time); }
57037 Value get_black_color(double time = TiMe::Default()) const { return getValue("black_color", time); }
57038
57042 bool set_radius(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("radius", texturefloat, time); }
57046 bool set_radius(float texturefloat, double time = TiMe::Default()) { return setValue("radius", texturefloat, time); }
57050 Value get_radius(double time = TiMe::Default()) const { return getValue("radius", time); }
57051
57055 bool set_distribution(float val, double time = TiMe::Default()) { return setValue("distribution", val, time); }
57059 float get_distribution(double time = TiMe::Default()) const { return getFloat("distribution", time); }
57060
57064 bool set_falloff(float val, double time = TiMe::Default()) { return setValue("falloff", val, time); }
57068 float get_falloff(double time = TiMe::Default()) const { return getFloat("falloff", time); }
57069
57073 bool set_subdivs(int val, double time = TiMe::Default()) { return setValue("subdivs", val, time); }
57077 int get_subdivs(double time = TiMe::Default()) const { return getInt("subdivs", time); }
57078
57082 bool set_bias_x(float val, double time = TiMe::Default()) { return setValue("bias_x", val, time); }
57086 float get_bias_x(double time = TiMe::Default()) const { return getFloat("bias_x", time); }
57087
57091 bool set_bias_y(float val, double time = TiMe::Default()) { return setValue("bias_y", val, time); }
57095 float get_bias_y(double time = TiMe::Default()) const { return getFloat("bias_y", time); }
57096
57100 bool set_bias_z(float val, double time = TiMe::Default()) { return setValue("bias_z", val, time); }
57104 float get_bias_z(double time = TiMe::Default()) const { return getFloat("bias_z", time); }
57105
57109 bool set_ignore_for_gi(bool val, double time = TiMe::Default()) { return setValue("ignore_for_gi", val, time); }
57113 bool get_ignore_for_gi(double time = TiMe::Default()) const { return getBool("ignore_for_gi", time); }
57114
57118 bool set_ignore_bump(bool val, double time = TiMe::Default()) { return setValue("ignore_bump", val, time); }
57122 bool get_ignore_bump(double time = TiMe::Default()) const { return getBool("ignore_bump", time); }
57123
57127 bool set_consider_same_object_only(int val, double time = TiMe::Default()) { return setValue("consider_same_object_only", val, time); }
57131 int get_consider_same_object_only(double time = TiMe::Default()) const { return getInt("consider_same_object_only", time); }
57132
57136 bool set_user_attribute(const char* str, double time = TiMe::Default()) { return setValue("user_attribute", str, time); }
57140 bool set_user_attribute(const std::string& str, double time = TiMe::Default()) { return setValue("user_attribute", str, time); }
57144 std::string get_user_attribute(double time = TiMe::Default()) const { return getString("user_attribute", time); }
57145
57149 bool set_invert_normal(bool val, double time = TiMe::Default()) { return setValue("invert_normal", val, time); }
57153 bool get_invert_normal(double time = TiMe::Default()) const { return getBool("invert_normal", time); }
57154
57158 bool set_affect_alpha(bool val, double time = TiMe::Default()) { return setValue("affect_alpha", val, time); }
57162 bool get_affect_alpha(double time = TiMe::Default()) const { return getBool("affect_alpha", time); }
57163
57167 bool set_double_sided(bool val, double time = TiMe::Default()) { return setValue("double_sided", val, time); }
57171 bool get_double_sided(double time = TiMe::Default()) const { return getBool("double_sided", time); }
57172
57176 bool set_work_with_transparency(bool val, double time = TiMe::Default()) { return setValue("work_with_transparency", val, time); }
57180 bool get_work_with_transparency(double time = TiMe::Default()) const { return getBool("work_with_transparency", time); }
57181
57185 bool set_ignore_self_occlusion(bool val, double time = TiMe::Default()) { return setValue("ignore_self_occlusion", val, time); }
57189 bool get_ignore_self_occlusion(double time = TiMe::Default()) const { return getBool("ignore_self_occlusion", time); }
57190
57194 bool set_thin_mode(bool val, double time = TiMe::Default()) { return setValue("thin_mode", val, time); }
57198 bool get_thin_mode(double time = TiMe::Default()) const { return getBool("thin_mode", time); }
57199
57203 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
57207 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
57208
57212 bool set_environment_occlusion(bool val, double time = TiMe::Default()) { return setValue("environment_occlusion", val, time); }
57216 bool get_environment_occlusion(double time = TiMe::Default()) const { return getBool("environment_occlusion", time); }
57217
57221 bool set_affect_reflection_elements(bool val, double time = TiMe::Default()) { return setValue("affect_reflection_elements", val, time); }
57225 bool get_affect_reflection_elements(double time = TiMe::Default()) const { return getBool("affect_reflection_elements", time); }
57226
57230 bool set_glossiness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("glossiness", texturefloat, time); }
57234 bool set_glossiness(float texturefloat, double time = TiMe::Default()) { return setValue("glossiness", texturefloat, time); }
57238 Value get_glossiness(double time = TiMe::Default()) const { return getValue("glossiness", time); }
57239
57242 bool set_render_nodes(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("render_nodes", pluginList, time); }
57243 bool set_render_nodes(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("render_nodes", plugins, count, time); }
57244 template<size_t count> bool set_render_nodes(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("render_nodes", plugins, count, time); }
57247 PluginList get_render_nodes(double time = TiMe::Default()) const { return getPluginList("render_nodes", time); }
57248
57252 bool set_render_nodes_inclusive(bool val, double time = TiMe::Default()) { return setValue("render_nodes_inclusive", val, time); }
57256 bool get_render_nodes_inclusive(double time = TiMe::Default()) const { return getBool("render_nodes_inclusive", time); }
57257
57261 bool set_use_texture_for_excluded(bool val, double time = TiMe::Default()) { return setValue("use_texture_for_excluded", val, time); }
57265 bool get_use_texture_for_excluded(double time = TiMe::Default()) const { return getBool("use_texture_for_excluded", time); }
57266
57269 bool set_affect_result_nodes(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("affect_result_nodes", pluginList, time); }
57270 bool set_affect_result_nodes(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("affect_result_nodes", plugins, count, time); }
57271 template<size_t count> bool set_affect_result_nodes(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("affect_result_nodes", plugins, count, time); }
57274 PluginList get_affect_result_nodes(double time = TiMe::Default()) const { return getPluginList("affect_result_nodes", time); }
57275
57279 bool set_affect_result_nodes_inclusive(bool val, double time = TiMe::Default()) { return setValue("affect_result_nodes_inclusive", val, time); }
57283 bool get_affect_result_nodes_inclusive(double time = TiMe::Default()) const { return getBool("affect_result_nodes_inclusive", time); }
57284
57288 bool set_subdivs_as_samples(bool val, double time = TiMe::Default()) { return setValue("subdivs_as_samples", val, time); }
57292 bool get_subdivs_as_samples(double time = TiMe::Default()) const { return getBool("subdivs_as_samples", time); }
57293
57297 bool set_screen_space_radius(bool val, double time = TiMe::Default()) { return setValue("screen_space_radius", val, time); }
57301 bool get_screen_space_radius(double time = TiMe::Default()) const { return getBool("screen_space_radius", time); }
57302
57306 bool set_streaks_ambient(bool val, double time = TiMe::Default()) { return setValue("streaks_ambient", val, time); }
57310 bool get_streaks_ambient(double time = TiMe::Default()) const { return getBool("streaks_ambient", time); }
57311
57315 bool set_streaks_inner(bool val, double time = TiMe::Default()) { return setValue("streaks_inner", val, time); }
57319 bool get_streaks_inner(double time = TiMe::Default()) const { return getBool("streaks_inner", time); }
57320
57324 bool set_streaks_blur(bool val, double time = TiMe::Default()) { return setValue("streaks_blur", val, time); }
57328 bool get_streaks_blur(double time = TiMe::Default()) const { return getBool("streaks_blur", time); }
57329
57333 bool set_blur(float val, double time = TiMe::Default()) { return setValue("blur", val, time); }
57337 float get_blur(double time = TiMe::Default()) const { return getFloat("blur", time); }
57338
57342 bool set_streaks_size(float val, double time = TiMe::Default()) { return setValue("streaks_size", val, time); }
57346 float get_streaks_size(double time = TiMe::Default()) const { return getFloat("streaks_size", time); }
57347
57351 bool set_streaks_density(float val, double time = TiMe::Default()) { return setValue("streaks_density", val, time); }
57355 float get_streaks_density(double time = TiMe::Default()) const { return getFloat("streaks_density", time); }
57356};
57357
57360public:
57362 static constexpr const PluginTypeId getTypeId() { return 0x77B07476; }
57364 static constexpr const char* getType() { return "TexDisplacacementRestrict"; }
57365
57366 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
57367
57369 bool set_input_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input_tex", texturefloat, time); }
57371 bool set_input_tex(float texturefloat, double time = TiMe::Default()) { return setValue("input_tex", texturefloat, time); }
57373 Value get_input_tex(double time = TiMe::Default()) const { return getValue("input_tex", time); }
57374
57377 bool set_max_displacement(float val, double time = TiMe::Default()) { return setValue("max_displacement", val, time); }
57380 float get_max_displacement(double time = TiMe::Default()) const { return getFloat("max_displacement", time); }
57381};
57382
57384class TexDistance : public Plugin {
57385public:
57387 static constexpr const PluginTypeId getTypeId() { return 0x77EE19E5; }
57389 static constexpr const char* getType() { return "TexDistance"; }
57390
57391 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
57392
57396 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
57400 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
57401
57405 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
57409 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
57410
57414 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
57418 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
57419
57423 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
57427 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
57428
57432 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
57436 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
57440 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
57441
57445 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
57449 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
57453 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
57454
57458 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
57462 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
57466 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
57467
57471 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
57475 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
57479 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
57480
57484 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
57488 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
57492 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
57493
57495 PluginRef out_color() const { return PluginRef(*this, "color"); }
57496
57498 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
57499
57501 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
57502
57504 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
57505
57509 bool set_distance(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("distance", texturefloat, time); }
57513 bool set_distance(float texturefloat, double time = TiMe::Default()) { return setValue("distance", texturefloat, time); }
57517 Value get_distance(double time = TiMe::Default()) const { return getValue("distance", time); }
57518
57522 bool set_far_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("far_tex", texture, time); }
57526 bool set_far_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("far_tex", texture, time); }
57530 Value get_far_tex(double time = TiMe::Default()) const { return getValue("far_tex", time); }
57531
57535 bool set_near_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("near_tex", texture, time); }
57539 bool set_near_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("near_tex", texture, time); }
57543 Value get_near_tex(double time = TiMe::Default()) const { return getValue("near_tex", time); }
57544
57548 bool set_inside_separate(bool val, double time = TiMe::Default()) { return setValue("inside_separate", val, time); }
57552 bool get_inside_separate(double time = TiMe::Default()) const { return getBool("inside_separate", time); }
57553
57557 bool set_inside_solid(bool val, double time = TiMe::Default()) { return setValue("inside_solid", val, time); }
57561 bool get_inside_solid(double time = TiMe::Default()) const { return getBool("inside_solid", time); }
57562
57566 bool set_inside_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("inside_tex", texture, time); }
57570 bool set_inside_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("inside_tex", texture, time); }
57574 Value get_inside_tex(double time = TiMe::Default()) const { return getValue("inside_tex", time); }
57575
57579 bool set_outside_separate(bool val, double time = TiMe::Default()) { return setValue("outside_separate", val, time); }
57583 bool get_outside_separate(double time = TiMe::Default()) const { return getBool("outside_separate", time); }
57584
57588 bool set_outside_solid(bool val, double time = TiMe::Default()) { return setValue("outside_solid", val, time); }
57592 bool get_outside_solid(double time = TiMe::Default()) const { return getBool("outside_solid", time); }
57593
57597 bool set_outside_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("outside_tex", texture, time); }
57601 bool set_outside_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("outside_tex", texture, time); }
57605 Value get_outside_tex(double time = TiMe::Default()) const { return getValue("outside_tex", time); }
57606
57609 bool set_objects(const PluginList& pluginList, double time = TiMe::Default()) { return setValue("objects", pluginList, time); }
57610 bool set_objects(const Plugin* plugins, size_t count, double time = TiMe::Default()) { return setArray("objects", plugins, count, time); }
57611 template<size_t count> bool set_objects(const Plugin (&plugins)[count], double time = TiMe::Default()) { return setArray("objects", plugins, count, time); }
57614 PluginList get_objects(double time = TiMe::Default()) const { return getPluginList("objects", time); }
57615};
57616
57619public:
57621 static constexpr const PluginTypeId getTypeId() { return 0x77B0E971; }
57623 static constexpr const char* getType() { return "TexDistanceBetween"; }
57624
57625 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
57626
57629 bool set_point1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("point1", texture, time); }
57632 bool set_point1(const AColor& texture, double time = TiMe::Default()) { return setValue("point1", texture, time); }
57635 Value get_point1(double time = TiMe::Default()) const { return getValue("point1", time); }
57636
57639 bool set_point2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("point2", texture, time); }
57642 bool set_point2(const AColor& texture, double time = TiMe::Default()) { return setValue("point2", texture, time); }
57645 Value get_point2(double time = TiMe::Default()) const { return getValue("point2", time); }
57646
57648 bool set_transform1(const PluginRef& texturetransform, double time = TiMe::Default()) { return setValue("transform1", texturetransform, time); }
57650 bool set_transform1(const Transform& texturetransform, double time = TiMe::Default()) { return setValue("transform1", texturetransform, time); }
57652 Value get_transform1(double time = TiMe::Default()) const { return getValue("transform1", time); }
57653
57655 bool set_transform2(const PluginRef& texturetransform, double time = TiMe::Default()) { return setValue("transform2", texturetransform, time); }
57657 bool set_transform2(const Transform& texturetransform, double time = TiMe::Default()) { return setValue("transform2", texturetransform, time); }
57659 Value get_transform2(double time = TiMe::Default()) const { return getValue("transform2", time); }
57660
57662 PluginRef out_distance() const { return PluginRef(*this, "distance"); }
57663};
57664
57667public:
57669 static constexpr const PluginTypeId getTypeId() { return 0x781C52C6; }
57671 static constexpr const char* getType() { return "TexDistanceToObject"; }
57672
57673 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
57674
57676 bool set_object(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("object", plugin, time); }
57678 PluginRef get_object(double time = TiMe::Default()) const { return getPlugin("object", time); }
57679};
57680
57682class TexEdges : public Plugin {
57683public:
57685 static constexpr const PluginTypeId getTypeId() { return 0x77BF1785; }
57687 static constexpr const char* getType() { return "TexEdges"; }
57688
57689 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
57690
57694 bool set_edges_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("edges_tex", texture, time); }
57698 bool set_edges_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("edges_tex", texture, time); }
57702 Value get_edges_tex(double time = TiMe::Default()) const { return getValue("edges_tex", time); }
57703
57707 bool set_bg_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("bg_tex", texture, time); }
57711 bool set_bg_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("bg_tex", texture, time); }
57715 Value get_bg_tex(double time = TiMe::Default()) const { return getValue("bg_tex", time); }
57716
57720 bool set_show_hidden_edges(bool val, double time = TiMe::Default()) { return setValue("show_hidden_edges", val, time); }
57724 bool get_show_hidden_edges(double time = TiMe::Default()) const { return getBool("show_hidden_edges", time); }
57725
57729 bool set_width_type(int val, double time = TiMe::Default()) { return setValue("width_type", val, time); }
57733 int get_width_type(double time = TiMe::Default()) const { return getInt("width_type", time); }
57734
57738 bool set_pixel_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("pixel_width", texturefloat, time); }
57742 bool set_pixel_width(float texturefloat, double time = TiMe::Default()) { return setValue("pixel_width", texturefloat, time); }
57746 Value get_pixel_width(double time = TiMe::Default()) const { return getValue("pixel_width", time); }
57747
57751 bool set_world_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("world_width", texturefloat, time); }
57755 bool set_world_width(float texturefloat, double time = TiMe::Default()) { return setValue("world_width", texturefloat, time); }
57759 Value get_world_width(double time = TiMe::Default()) const { return getValue("world_width", time); }
57760
57764 bool set_show_subtriangles(bool val, double time = TiMe::Default()) { return setValue("show_subtriangles", val, time); }
57768 bool get_show_subtriangles(double time = TiMe::Default()) const { return getBool("show_subtriangles", time); }
57769
57773 bool set_raytraced(bool val, double time = TiMe::Default()) { return setValue("raytraced", val, time); }
57777 bool get_raytraced(double time = TiMe::Default()) const { return getBool("raytraced", time); }
57778
57782 bool set_raytraced_consider_same_object_only(bool val, double time = TiMe::Default()) { return setValue("raytraced_consider_same_object_only", val, time); }
57786 bool get_raytraced_consider_same_object_only(double time = TiMe::Default()) const { return getBool("raytraced_consider_same_object_only", time); }
57787
57791 bool set_raytraced_mode(int val, double time = TiMe::Default()) { return setValue("raytraced_mode", val, time); }
57795 int get_raytraced_mode(double time = TiMe::Default()) const { return getInt("raytraced_mode", time); }
57796};
57797
57799class TexExtMaterialID : public Plugin {
57800public:
57802 static constexpr const PluginTypeId getTypeId() { return 0xC05CE5C; }
57804 static constexpr const char* getType() { return "TexExtMaterialID"; }
57805
57806 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
57807
57808 operator TextureIntPluginCategory() { return *static_cast<TextureIntPluginCategory*>(static_cast<Plugin*>(this)); }
57809
57812 bool set_ids_list(const IntList& intList, double time = TiMe::Default()) { return setValue("ids_list", intList, time); }
57813 bool set_ids_list(IntList&& intList, double time = TiMe::Default()) { return setValue("ids_list", std::move(intList), time); }
57814 bool set_ids_list(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ids_list", ints, count, time); }
57815 template<size_t count> bool set_ids_list(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ids_list", ints, count, time); }
57818 IntList get_ids_list(double time = TiMe::Default()) const { return getIntList("ids_list", time); }
57819
57822 bool set_voxels_face_basis(const IntList& intList, double time = TiMe::Default()) { return setValue("voxels_face_basis", intList, time); }
57823 bool set_voxels_face_basis(IntList&& intList, double time = TiMe::Default()) { return setValue("voxels_face_basis", std::move(intList), time); }
57824 bool set_voxels_face_basis(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("voxels_face_basis", ints, count, time); }
57825 template<size_t count> bool set_voxels_face_basis(const int (&ints)[count], double time = TiMe::Default()) { return setArray("voxels_face_basis", ints, count, time); }
57828 IntList get_voxels_face_basis(double time = TiMe::Default()) const { return getIntList("voxels_face_basis", time); }
57829
57832 bool set_packing_mode(int val, double time = TiMe::Default()) { return setValue("packing_mode", val, time); }
57835 int get_packing_mode(double time = TiMe::Default()) const { return getInt("packing_mode", time); }
57836};
57837
57839class TexFalloff : public Plugin {
57840public:
57842 static constexpr const PluginTypeId getTypeId() { return 0x77A21239; }
57844 static constexpr const char* getType() { return "TexFalloff"; }
57845
57846 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
57847
57851 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
57855 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
57856
57860 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
57864 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
57865
57869 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
57873 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
57874
57878 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
57882 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
57883
57887 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
57891 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
57895 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
57896
57900 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
57904 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
57908 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
57909
57913 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
57917 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
57921 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
57922
57926 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
57930 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
57934 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
57935
57939 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
57943 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
57947 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
57948
57950 PluginRef out_color() const { return PluginRef(*this, "color"); }
57951
57953 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
57954
57956 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
57957
57959 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
57960
57964 bool set_color1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
57968 bool set_color1(const AColor& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
57972 Value get_color1(double time = TiMe::Default()) const { return getValue("color1", time); }
57973
57977 bool set_color2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
57981 bool set_color2(const AColor& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
57985 Value get_color2(double time = TiMe::Default()) const { return getValue("color2", time); }
57986
57990 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
57994 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
57995
57999 bool set_direction_type(int val, double time = TiMe::Default()) { return setValue("direction_type", val, time); }
58003 int get_direction_type(double time = TiMe::Default()) const { return getInt("direction_type", time); }
58004
58008 bool set_node_ref_offset(const Vector& vector, double time = TiMe::Default()) { return setValue("node_ref_offset", vector, time); }
58012 Vector get_node_ref_offset(double time = TiMe::Default()) const { return getVector("node_ref_offset", time); }
58013
58017 bool set_fresnel_ior(float val, double time = TiMe::Default()) { return setValue("fresnel_ior", val, time); }
58021 float get_fresnel_ior(double time = TiMe::Default()) const { return getFloat("fresnel_ior", time); }
58022
58026 bool set_dist_extrapolate(bool val, double time = TiMe::Default()) { return setValue("dist_extrapolate", val, time); }
58030 bool get_dist_extrapolate(double time = TiMe::Default()) const { return getBool("dist_extrapolate", time); }
58031
58035 bool set_dist_near(float val, double time = TiMe::Default()) { return setValue("dist_near", val, time); }
58039 float get_dist_near(double time = TiMe::Default()) const { return getFloat("dist_near", time); }
58040
58044 bool set_dist_far(float val, double time = TiMe::Default()) { return setValue("dist_far", val, time); }
58048 float get_dist_far(double time = TiMe::Default()) const { return getFloat("dist_far", time); }
58049
58053 bool set_explicit_dir(const Vector& vector, double time = TiMe::Default()) { return setValue("explicit_dir", vector, time); }
58057 Vector get_explicit_dir(double time = TiMe::Default()) const { return getVector("explicit_dir", time); }
58058
58060 PluginRef out_blend_output() const { return PluginRef(*this, "blend_output"); }
58061
58065 bool set_use_blend_input(bool val, double time = TiMe::Default()) { return setValue("use_blend_input", val, time); }
58069 bool get_use_blend_input(double time = TiMe::Default()) const { return getBool("use_blend_input", time); }
58070
58074 bool set_blend_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("blend_input", texturefloat, time); }
58078 bool set_blend_input(float texturefloat, double time = TiMe::Default()) { return setValue("blend_input", texturefloat, time); }
58082 Value get_blend_input(double time = TiMe::Default()) const { return getValue("blend_input", time); }
58083};
58084
58086class TexFloat : public Plugin {
58087public:
58089 static constexpr const PluginTypeId getTypeId() { return 0x77DD9629; }
58091 static constexpr const char* getType() { return "TexFloat"; }
58092
58093 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58094
58097 bool set_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
58100 bool set_input(float texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
58103 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
58104};
58105
58108public:
58110 static constexpr const PluginTypeId getTypeId() { return 0x783952FE; }
58112 static constexpr const char* getType() { return "TexFloatComposite"; }
58113
58114 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58115
58118 bool set_float_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58121 bool set_float_a(float texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58124 Value get_float_a(double time = TiMe::Default()) const { return getValue("float_a", time); }
58125
58128 bool set_float_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58131 bool set_float_b(float texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58134 Value get_float_b(double time = TiMe::Default()) const { return getValue("float_b", time); }
58135
58138 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
58141 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
58142
58145 bool set_factor(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("factor", texturefloat, time); }
58148 bool set_factor(float texturefloat, double time = TiMe::Default()) { return setValue("factor", texturefloat, time); }
58151 Value get_factor(double time = TiMe::Default()) const { return getValue("factor", time); }
58152};
58153
58156public:
58158 static constexpr const PluginTypeId getTypeId() { return 0x783951D2; }
58160 static constexpr const char* getType() { return "TexFloatCondition"; }
58161
58162 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58163
58166 bool set_float_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58169 bool set_float_a(float texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58172 Value get_float_a(double time = TiMe::Default()) const { return getValue("float_a", time); }
58173
58176 bool set_float_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58179 bool set_float_b(float texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58182 Value get_float_b(double time = TiMe::Default()) const { return getValue("float_b", time); }
58183
58186 bool set_condition(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("condition", texturefloat, time); }
58189 bool set_condition(float texturefloat, double time = TiMe::Default()) { return setValue("condition", texturefloat, time); }
58192 Value get_condition(double time = TiMe::Default()) const { return getValue("condition", time); }
58193};
58194
58196class TexFloatConstant : public Plugin {
58197public:
58199 static constexpr const PluginTypeId getTypeId() { return 0x78395235; }
58201 static constexpr const char* getType() { return "TexFloatConstant"; }
58202
58203 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58204
58207 bool set_in_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("in_float", texturefloat, time); }
58210 bool set_in_float(float texturefloat, double time = TiMe::Default()) { return setValue("in_float", texturefloat, time); }
58213 Value get_in_float(double time = TiMe::Default()) const { return getValue("in_float", time); }
58214};
58215
58217class TexFloatCorrect : public Plugin {
58218public:
58220 static constexpr const PluginTypeId getTypeId() { return 0x7839781C; }
58222 static constexpr const char* getType() { return "TexFloatCorrect"; }
58223
58224 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58225
58228 bool set_in_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("in_float", texturefloat, time); }
58231 bool set_in_float(float texturefloat, double time = TiMe::Default()) { return setValue("in_float", texturefloat, time); }
58234 Value get_in_float(double time = TiMe::Default()) const { return getValue("in_float", time); }
58235
58238 bool set_gain(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gain", texturefloat, time); }
58241 bool set_gain(float texturefloat, double time = TiMe::Default()) { return setValue("gain", texturefloat, time); }
58244 Value get_gain(double time = TiMe::Default()) const { return getValue("gain", time); }
58245
58248 bool set_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("offset", texturefloat, time); }
58251 bool set_offset(float texturefloat, double time = TiMe::Default()) { return setValue("offset", texturefloat, time); }
58254 Value get_offset(double time = TiMe::Default()) const { return getValue("offset", time); }
58255
58258 bool set_gamma(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gamma", texturefloat, time); }
58261 bool set_gamma(float texturefloat, double time = TiMe::Default()) { return setValue("gamma", texturefloat, time); }
58264 Value get_gamma(double time = TiMe::Default()) const { return getValue("gamma", time); }
58265
58268 bool set_clamp(int val, double time = TiMe::Default()) { return setValue("clamp", val, time); }
58271 int get_clamp(double time = TiMe::Default()) const { return getInt("clamp", time); }
58272
58275 bool set_clamp_min(float val, double time = TiMe::Default()) { return setValue("clamp_min", val, time); }
58278 float get_clamp_min(double time = TiMe::Default()) const { return getFloat("clamp_min", time); }
58279
58282 bool set_clamp_max(float val, double time = TiMe::Default()) { return setValue("clamp_max", val, time); }
58285 float get_clamp_max(double time = TiMe::Default()) const { return getFloat("clamp_max", time); }
58286};
58287
58289class TexFloatLogic : public Plugin {
58290public:
58292 static constexpr const PluginTypeId getTypeId() { return 0x783952F9; }
58294 static constexpr const char* getType() { return "TexFloatLogic"; }
58295
58296 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58297
58300 bool set_float_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58303 bool set_float_a(float texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58306 Value get_float_a(double time = TiMe::Default()) const { return getValue("float_a", time); }
58307
58310 bool set_float_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58313 bool set_float_b(float texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58316 Value get_float_b(double time = TiMe::Default()) const { return getValue("float_b", time); }
58317
58320 bool set_operation(int val, double time = TiMe::Default()) { return setValue("operation", val, time); }
58323 int get_operation(double time = TiMe::Default()) const { return getInt("operation", time); }
58324};
58325
58327class TexFloatMask : public Plugin {
58328public:
58330 static constexpr const PluginTypeId getTypeId() { return 0x78395297; }
58332 static constexpr const char* getType() { return "TexFloatMask"; }
58333
58334 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58335
58338 bool set_in_float(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("in_float", texturefloat, time); }
58341 bool set_in_float(float texturefloat, double time = TiMe::Default()) { return setValue("in_float", texturefloat, time); }
58344 Value get_in_float(double time = TiMe::Default()) const { return getValue("in_float", time); }
58345
58348 bool set_mask(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mask", texturefloat, time); }
58351 bool set_mask(float texturefloat, double time = TiMe::Default()) { return setValue("mask", texturefloat, time); }
58354 Value get_mask(double time = TiMe::Default()) const { return getValue("mask", time); }
58355};
58356
58358class TexFloatOp : public Plugin {
58359public:
58361 static constexpr const PluginTypeId getTypeId() { return 0x7782F94D; }
58363 static constexpr const char* getType() { return "TexFloatOp"; }
58364
58365 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58366
58370 bool set_float_a(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58374 bool set_float_a(float texturefloat, double time = TiMe::Default()) { return setValue("float_a", texturefloat, time); }
58378 Value get_float_a(double time = TiMe::Default()) const { return getValue("float_a", time); }
58379
58382 bool set_float_b(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58385 bool set_float_b(float texturefloat, double time = TiMe::Default()) { return setValue("float_b", texturefloat, time); }
58388 Value get_float_b(double time = TiMe::Default()) const { return getValue("float_b", time); }
58389
58391 PluginRef out_product() const { return PluginRef(*this, "product"); }
58392
58394 PluginRef out_ratio() const { return PluginRef(*this, "ratio"); }
58395
58397 PluginRef out_sum() const { return PluginRef(*this, "sum"); }
58398
58400 PluginRef out_difference() const { return PluginRef(*this, "difference"); }
58401
58403 PluginRef out_power() const { return PluginRef(*this, "power"); }
58404
58406 PluginRef out_sin() const { return PluginRef(*this, "sin"); }
58407
58409 PluginRef out_cos() const { return PluginRef(*this, "cos"); }
58410
58412 PluginRef out_asin() const { return PluginRef(*this, "asin"); }
58413
58415 PluginRef out_acos() const { return PluginRef(*this, "acos"); }
58416
58418 PluginRef out_atan() const { return PluginRef(*this, "atan"); }
58419
58421 PluginRef out_atan2() const { return PluginRef(*this, "atan2"); }
58422
58424 PluginRef out_min() const { return PluginRef(*this, "min"); }
58425
58427 PluginRef out_max() const { return PluginRef(*this, "max"); }
58428
58430 PluginRef out_abs() const { return PluginRef(*this, "abs"); }
58431
58433 PluginRef out_ceil() const { return PluginRef(*this, "ceil"); }
58434
58436 PluginRef out_exp() const { return PluginRef(*this, "exp"); }
58437
58439 PluginRef out_floor() const { return PluginRef(*this, "floor"); }
58440
58442 PluginRef out_log() const { return PluginRef(*this, "log"); }
58443
58445 PluginRef out_log10() const { return PluginRef(*this, "log10"); }
58446
58448 PluginRef out_sqrt() const { return PluginRef(*this, "sqrt"); }
58449
58451 PluginRef out_fmod() const { return PluginRef(*this, "fmod"); }
58452
58454 PluginRef out_average() const { return PluginRef(*this, "average"); }
58455
58457 PluginRef out_tan() const { return PluginRef(*this, "tan"); }
58458
58460 PluginRef out_bias_schlick() const { return PluginRef(*this, "bias_schlick"); }
58461
58463 PluginRef out_gain_schlick() const { return PluginRef(*this, "gain_schlick"); }
58464
58466 PluginRef out_bias_perlin() const { return PluginRef(*this, "bias_perlin"); }
58467
58469 PluginRef out_gain_perlin() const { return PluginRef(*this, "gain_perlin"); }
58470
58475 bool set_mode(int val, double time = TiMe::Default()) { return setValue("mode", val, time); }
58480 int get_mode(double time = TiMe::Default()) const { return getInt("mode", time); }
58481};
58482
58485public:
58487 static constexpr const PluginTypeId getTypeId() { return 0x77ECD80C; }
58489 static constexpr const char* getType() { return "TexFloatPerVertexHairSampler"; }
58490
58491 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
58492
58495 bool set_vertex_values(const FloatList& floatList, double time = TiMe::Default()) { return setValue("vertex_values", floatList, time); }
58496 bool set_vertex_values(FloatList&& floatList, double time = TiMe::Default()) { return setValue("vertex_values", std::move(floatList), time); }
58497 bool set_vertex_values(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("vertex_values", floats, count, time); }
58498 template<size_t count> bool set_vertex_values(const float (&floats)[count], double time = TiMe::Default()) { return setArray("vertex_values", floats, count, time); }
58501 FloatList get_vertex_values(double time = TiMe::Default()) const { return getFloatList("vertex_values", time); }
58502};
58503
58505class TexFloatToColor : public Plugin {
58506public:
58508 static constexpr const PluginTypeId getTypeId() { return 0x77BF8B25; }
58510 static constexpr const char* getType() { return "TexFloatToColor"; }
58511
58512 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
58513
58516 bool set_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
58519 bool set_input(float texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
58522 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
58523
58526 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
58529 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
58530};
58531
58533class TexForestColor : public Plugin {
58534public:
58536 static constexpr const PluginTypeId getTypeId() { return 0x782AF530; }
58538 static constexpr const char* getType() { return "TexForestColor"; }
58539
58540 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
58541
58544 bool set_maps_list(const ValueList& textureList, double time = TiMe::Default()) { return setValue("maps_list", textureList, time); }
58545 bool set_maps_list(ValueList&& textureList, double time = TiMe::Default()) { return setValue("maps_list", std::move(textureList), time); }
58546 bool set_maps_list(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("maps_list", textures, count, time); }
58547 template<size_t count> bool set_maps_list(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("maps_list", textures, count, time); }
58548 template<size_t count> bool set_maps_list(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("maps_list", textures, count, time); }
58551 ValueList get_maps_list(double time = TiMe::Default()) const { return getValueList("maps_list", time); }
58552
58556 bool set_probabilities_list(const FloatList& floatList, double time = TiMe::Default()) { return setValue("probabilities_list", floatList, time); }
58557 bool set_probabilities_list(FloatList&& floatList, double time = TiMe::Default()) { return setValue("probabilities_list", std::move(floatList), time); }
58558 bool set_probabilities_list(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("probabilities_list", floats, count, time); }
58559 template<size_t count> bool set_probabilities_list(const float (&floats)[count], double time = TiMe::Default()) { return setArray("probabilities_list", floats, count, time); }
58563 FloatList get_probabilities_list(double time = TiMe::Default()) const { return getFloatList("probabilities_list", time); }
58564
58568 bool set_default_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("default_color", texture, time); }
58572 bool set_default_color(const AColor& texture, double time = TiMe::Default()) { return setValue("default_color", texture, time); }
58576 Value get_default_color(double time = TiMe::Default()) const { return getValue("default_color", time); }
58577
58581 bool set_map_id_mode(int val, double time = TiMe::Default()) { return setValue("map_id_mode", val, time); }
58585 int get_map_id_mode(double time = TiMe::Default()) const { return getInt("map_id_mode", time); }
58586
58590 bool set_tint_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("tint_color", texture, time); }
58594 bool set_tint_color(const AColor& texture, double time = TiMe::Default()) { return setValue("tint_color", texture, time); }
58598 Value get_tint_color(double time = TiMe::Default()) const { return getValue("tint_color", time); }
58599
58603 bool set_tint_override(int val, double time = TiMe::Default()) { return setValue("tint_override", val, time); }
58607 int get_tint_override(double time = TiMe::Default()) const { return getInt("tint_override", time); }
58608
58612 bool set_tint_min(float val, double time = TiMe::Default()) { return setValue("tint_min", val, time); }
58616 float get_tint_min(double time = TiMe::Default()) const { return getFloat("tint_min", time); }
58617
58621 bool set_tint_max(float val, double time = TiMe::Default()) { return setValue("tint_max", val, time); }
58625 float get_tint_max(double time = TiMe::Default()) const { return getFloat("tint_max", time); }
58626
58630 bool set_tint_mode(int val, double time = TiMe::Default()) { return setValue("tint_mode", val, time); }
58634 int get_tint_mode(double time = TiMe::Default()) const { return getInt("tint_mode", time); }
58635
58639 bool set_tint_map_mode(int val, double time = TiMe::Default()) { return setValue("tint_map_mode", val, time); }
58643 int get_tint_map_mode(double time = TiMe::Default()) const { return getInt("tint_map_mode", time); }
58644
58648 bool set_tint_mix_mode(int val, double time = TiMe::Default()) { return setValue("tint_mix_mode", val, time); }
58652 int get_tint_mix_mode(double time = TiMe::Default()) const { return getInt("tint_mix_mode", time); }
58653
58657 bool set_tint_variation(float val, double time = TiMe::Default()) { return setValue("tint_variation", val, time); }
58661 float get_tint_variation(double time = TiMe::Default()) const { return getFloat("tint_variation", time); }
58662
58666 bool set_tint_color_1(const Color& color, double time = TiMe::Default()) { return setValue("tint_color_1", color, time); }
58670 Color get_tint_color_1(double time = TiMe::Default()) const { return getColor("tint_color_1", time); }
58671
58675 bool set_tint_color_2(const Color& color, double time = TiMe::Default()) { return setValue("tint_color_2", color, time); }
58679 Color get_tint_color_2(double time = TiMe::Default()) const { return getColor("tint_color_2", time); }
58680
58684 bool set_apply_corrections(bool val, double time = TiMe::Default()) { return setValue("apply_corrections", val, time); }
58688 bool get_apply_corrections(double time = TiMe::Default()) const { return getBool("apply_corrections", time); }
58689
58693 bool set_source_geom_map_channel(int val, double time = TiMe::Default()) { return setValue("source_geom_map_channel", val, time); }
58697 int get_source_geom_map_channel(double time = TiMe::Default()) const { return getInt("source_geom_map_channel", time); }
58698};
58699
58701class TexFresnel : public Plugin {
58702public:
58704 static constexpr const PluginTypeId getTypeId() { return 0x77744DD1; }
58706 static constexpr const char* getType() { return "TexFresnel"; }
58707
58708 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
58709
58713 bool set_fresnel_ior(float val, double time = TiMe::Default()) { return setValue("fresnel_ior", val, time); }
58717 float get_fresnel_ior(double time = TiMe::Default()) const { return getFloat("fresnel_ior", time); }
58718
58722 bool set_refract_ior(float val, double time = TiMe::Default()) { return setValue("refract_ior", val, time); }
58726 float get_refract_ior(double time = TiMe::Default()) const { return getFloat("refract_ior", time); }
58727
58731 bool set_white_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("white_color", texture, time); }
58735 bool set_white_color(const AColor& texture, double time = TiMe::Default()) { return setValue("white_color", texture, time); }
58739 Value get_white_color(double time = TiMe::Default()) const { return getValue("white_color", time); }
58740
58744 bool set_black_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("black_color", texture, time); }
58748 bool set_black_color(const AColor& texture, double time = TiMe::Default()) { return setValue("black_color", texture, time); }
58752 Value get_black_color(double time = TiMe::Default()) const { return getValue("black_color", time); }
58753
58756 bool set_fresnel_ior_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("fresnel_ior_tex", texturefloat, time); }
58759 bool set_fresnel_ior_tex(float texturefloat, double time = TiMe::Default()) { return setValue("fresnel_ior_tex", texturefloat, time); }
58762 Value get_fresnel_ior_tex(double time = TiMe::Default()) const { return getValue("fresnel_ior_tex", time); }
58763
58766 bool set_refract_ior_tex(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("refract_ior_tex", texturefloat, time); }
58769 bool set_refract_ior_tex(float texturefloat, double time = TiMe::Default()) { return setValue("refract_ior_tex", texturefloat, time); }
58772 Value get_refract_ior_tex(double time = TiMe::Default()) const { return getValue("refract_ior_tex", time); }
58773
58777 bool set_contribute_to_fresnel_ior_re(bool val, double time = TiMe::Default()) { return setValue("contribute_to_fresnel_ior_re", val, time); }
58781 bool get_contribute_to_fresnel_ior_re(double time = TiMe::Default()) const { return getBool("contribute_to_fresnel_ior_re", time); }
58782};
58783
58785class TexGradRamp : public Plugin {
58786public:
58788 static constexpr const PluginTypeId getTypeId() { return 0xBF80F61; }
58790 static constexpr const char* getType() { return "TexGradRamp"; }
58791
58792 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
58793
58797 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
58801 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
58802
58806 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
58810 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
58811
58815 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
58819 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
58820
58824 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
58828 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
58829
58833 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
58837 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
58841 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
58842
58846 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
58850 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
58854 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
58855
58859 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
58863 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
58867 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
58868
58872 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
58876 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
58880 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
58881
58885 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
58889 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
58893 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
58894
58896 PluginRef out_color() const { return PluginRef(*this, "color"); }
58897
58899 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
58900
58902 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
58903
58905 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
58906
58909 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
58912 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
58913
58917 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
58921 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
58922
58926 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
58930 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
58931
58935 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
58939 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
58940
58944 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
58948 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
58949
58953 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
58957 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
58958
58962 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
58966 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
58967
58971 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
58975 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
58976
58980 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
58984 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
58985
58989 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
58993 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
58994
58998 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
59002 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
59003
59007 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
59011 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
59012
59016 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
59020 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
59021
59025 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
59029 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
59030
59034 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
59038 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
59039
59043 bool set_positions(const FloatList& floatList, double time = TiMe::Default()) { return setValue("positions", floatList, time); }
59044 bool set_positions(FloatList&& floatList, double time = TiMe::Default()) { return setValue("positions", std::move(floatList), time); }
59045 bool set_positions(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("positions", floats, count, time); }
59046 template<size_t count> bool set_positions(const float (&floats)[count], double time = TiMe::Default()) { return setArray("positions", floats, count, time); }
59050 FloatList get_positions(double time = TiMe::Default()) const { return getFloatList("positions", time); }
59051
59054 bool set_colors(const ValueList& textureList, double time = TiMe::Default()) { return setValue("colors", textureList, time); }
59055 bool set_colors(ValueList&& textureList, double time = TiMe::Default()) { return setValue("colors", std::move(textureList), time); }
59056 bool set_colors(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("colors", textures, count, time); }
59057 template<size_t count> bool set_colors(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("colors", textures, count, time); }
59058 template<size_t count> bool set_colors(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("colors", textures, count, time); }
59061 ValueList get_colors(double time = TiMe::Default()) const { return getValueList("colors", time); }
59062
59066 bool set_texture_map(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
59070 bool set_texture_map(const AColor& texture, double time = TiMe::Default()) { return setValue("texture_map", texture, time); }
59074 Value get_texture_map(double time = TiMe::Default()) const { return getValue("texture_map", time); }
59075
59079 bool set_gradient_type(int val, double time = TiMe::Default()) { return setValue("gradient_type", val, time); }
59083 int get_gradient_type(double time = TiMe::Default()) const { return getInt("gradient_type", time); }
59084
59088 bool set_interpolation(const IntList& intList, double time = TiMe::Default()) { return setValue("interpolation", intList, time); }
59089 bool set_interpolation(IntList&& intList, double time = TiMe::Default()) { return setValue("interpolation", std::move(intList), time); }
59090 bool set_interpolation(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("interpolation", ints, count, time); }
59091 template<size_t count> bool set_interpolation(const int (&ints)[count], double time = TiMe::Default()) { return setArray("interpolation", ints, count, time); }
59095 IntList get_interpolation(double time = TiMe::Default()) const { return getIntList("interpolation", time); }
59096
59100 bool set_noise_amount(float val, double time = TiMe::Default()) { return setValue("noise_amount", val, time); }
59104 float get_noise_amount(double time = TiMe::Default()) const { return getFloat("noise_amount", time); }
59105
59109 bool set_noise_type(int val, double time = TiMe::Default()) { return setValue("noise_type", val, time); }
59113 int get_noise_type(double time = TiMe::Default()) const { return getInt("noise_type", time); }
59114
59118 bool set_noise_size(float val, double time = TiMe::Default()) { return setValue("noise_size", val, time); }
59122 float get_noise_size(double time = TiMe::Default()) const { return getFloat("noise_size", time); }
59123
59127 bool set_noise_phase(float val, double time = TiMe::Default()) { return setValue("noise_phase", val, time); }
59131 float get_noise_phase(double time = TiMe::Default()) const { return getFloat("noise_phase", time); }
59132
59136 bool set_noise_levels(float val, double time = TiMe::Default()) { return setValue("noise_levels", val, time); }
59140 float get_noise_levels(double time = TiMe::Default()) const { return getFloat("noise_levels", time); }
59141
59145 bool set_noise_treshold_low(float val, double time = TiMe::Default()) { return setValue("noise_treshold_low", val, time); }
59149 float get_noise_treshold_low(double time = TiMe::Default()) const { return getFloat("noise_treshold_low", time); }
59150
59154 bool set_noise_treshold_high(float val, double time = TiMe::Default()) { return setValue("noise_treshold_high", val, time); }
59158 float get_noise_treshold_high(double time = TiMe::Default()) const { return getFloat("noise_treshold_high", time); }
59159
59163 bool set_noise_smooth(float val, double time = TiMe::Default()) { return setValue("noise_smooth", val, time); }
59167 float get_noise_smooth(double time = TiMe::Default()) const { return getFloat("noise_smooth", time); }
59168
59172 bool set_gradient_position(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("gradient_position", texturefloat, time); }
59176 bool set_gradient_position(float texturefloat, double time = TiMe::Default()) { return setValue("gradient_position", texturefloat, time); }
59180 Value get_gradient_position(double time = TiMe::Default()) const { return getValue("gradient_position", time); }
59181};
59182
59184class TexGradient : public Plugin {
59185public:
59187 static constexpr const PluginTypeId getTypeId() { return 0x77A2123A; }
59189 static constexpr const char* getType() { return "TexGradient"; }
59190
59191 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
59192
59196 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
59200 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
59201
59205 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
59209 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
59210
59214 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
59218 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
59219
59223 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
59227 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
59228
59232 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
59236 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
59240 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
59241
59245 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
59249 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
59253 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
59254
59258 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
59262 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
59266 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
59267
59271 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
59275 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
59279 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
59280
59284 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
59288 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
59292 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
59293
59295 PluginRef out_color() const { return PluginRef(*this, "color"); }
59296
59298 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
59299
59301 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
59302
59304 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
59305
59308 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
59311 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
59312
59316 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
59320 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
59321
59325 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
59329 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
59330
59334 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
59338 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
59339
59343 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
59347 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
59348
59352 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
59356 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
59357
59361 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
59365 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
59366
59370 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
59374 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
59375
59379 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
59383 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
59384
59388 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
59392 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
59393
59397 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
59401 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
59402
59406 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
59410 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
59411
59415 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
59419 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
59420
59424 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
59428 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
59429
59433 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
59437 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
59438
59442 bool set_color1(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
59446 bool set_color1(const AColor& texture, double time = TiMe::Default()) { return setValue("color1", texture, time); }
59450 Value get_color1(double time = TiMe::Default()) const { return getValue("color1", time); }
59451
59455 bool set_color2(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
59459 bool set_color2(const AColor& texture, double time = TiMe::Default()) { return setValue("color2", texture, time); }
59463 Value get_color2(double time = TiMe::Default()) const { return getValue("color2", time); }
59464
59468 bool set_color3(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color3", texture, time); }
59472 bool set_color3(const AColor& texture, double time = TiMe::Default()) { return setValue("color3", texture, time); }
59476 Value get_color3(double time = TiMe::Default()) const { return getValue("color3", time); }
59477
59481 bool set_has_textures(bool val, double time = TiMe::Default()) { return setValue("has_textures", val, time); }
59485 bool get_has_textures(double time = TiMe::Default()) const { return getBool("has_textures", time); }
59486
59490 bool set_middle(float val, double time = TiMe::Default()) { return setValue("middle", val, time); }
59494 float get_middle(double time = TiMe::Default()) const { return getFloat("middle", time); }
59495
59499 bool set_type(int val, double time = TiMe::Default()) { return setValue("type", val, time); }
59503 int get_type(double time = TiMe::Default()) const { return getInt("type", time); }
59504
59508 bool set_noise_amount(float val, double time = TiMe::Default()) { return setValue("noise_amount", val, time); }
59512 float get_noise_amount(double time = TiMe::Default()) const { return getFloat("noise_amount", time); }
59513
59517 bool set_noise_size(float val, double time = TiMe::Default()) { return setValue("noise_size", val, time); }
59521 float get_noise_size(double time = TiMe::Default()) const { return getFloat("noise_size", time); }
59522
59526 bool set_noise_type(int val, double time = TiMe::Default()) { return setValue("noise_type", val, time); }
59530 int get_noise_type(double time = TiMe::Default()) const { return getInt("noise_type", time); }
59531
59535 bool set_noise_iterations(float val, double time = TiMe::Default()) { return setValue("noise_iterations", val, time); }
59539 float get_noise_iterations(double time = TiMe::Default()) const { return getFloat("noise_iterations", time); }
59540
59544 bool set_noise_phase(float val, double time = TiMe::Default()) { return setValue("noise_phase", val, time); }
59548 float get_noise_phase(double time = TiMe::Default()) const { return getFloat("noise_phase", time); }
59549
59553 bool set_noise_low(float val, double time = TiMe::Default()) { return setValue("noise_low", val, time); }
59557 float get_noise_low(double time = TiMe::Default()) const { return getFloat("noise_low", time); }
59558
59562 bool set_noise_high(float val, double time = TiMe::Default()) { return setValue("noise_high", val, time); }
59566 float get_noise_high(double time = TiMe::Default()) const { return getFloat("noise_high", time); }
59567
59571 bool set_noise_smooth(float val, double time = TiMe::Default()) { return setValue("noise_smooth", val, time); }
59575 float get_noise_smooth(double time = TiMe::Default()) const { return getFloat("noise_smooth", time); }
59576};
59577
59579class TexGranite : public Plugin {
59580public:
59582 static constexpr const PluginTypeId getTypeId() { return 0xBF69FCC; }
59584 static constexpr const char* getType() { return "TexGranite"; }
59585
59586 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
59587
59591 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
59595 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
59596
59600 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
59604 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
59605
59609 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
59613 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
59614
59618 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
59622 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
59623
59627 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
59631 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
59635 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
59636
59640 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
59644 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
59648 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
59649
59653 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
59657 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
59661 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
59662
59666 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
59670 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
59674 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
59675
59679 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
59683 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
59687 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
59688
59690 PluginRef out_color() const { return PluginRef(*this, "color"); }
59691
59693 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
59694
59696 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
59697
59699 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
59700
59703 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
59706 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
59707
59711 bool set_wrap(bool val, double time = TiMe::Default()) { return setValue("wrap", val, time); }
59715 bool get_wrap(double time = TiMe::Default()) const { return getBool("wrap", time); }
59716
59720 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
59724 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
59725
59729 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
59733 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
59734
59738 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
59742 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
59743
59747 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
59751 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
59752
59756 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
59760 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
59761
59765 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
59769 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
59770
59774 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
59778 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
59779
59783 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
59787 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
59788
59792 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
59796 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
59797
59801 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
59805 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
59806
59810 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
59814 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
59815
59819 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
59823 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
59824
59828 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
59832 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
59833
59837 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
59841 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
59842
59846 bool set_color1_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color1_tex", texture, time); }
59850 bool set_color1_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color1_tex", texture, time); }
59854 Value get_color1_tex(double time = TiMe::Default()) const { return getValue("color1_tex", time); }
59855
59859 bool set_color2_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color2_tex", texture, time); }
59863 bool set_color2_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color2_tex", texture, time); }
59867 Value get_color2_tex(double time = TiMe::Default()) const { return getValue("color2_tex", time); }
59868
59872 bool set_color3_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color3_tex", texture, time); }
59876 bool set_color3_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("color3_tex", texture, time); }
59880 Value get_color3_tex(double time = TiMe::Default()) const { return getValue("color3_tex", time); }
59881
59885 bool set_filler_color_tex(const PluginRef& texture, double time = TiMe::Default()) { return setValue("filler_color_tex", texture, time); }
59889 bool set_filler_color_tex(const AColor& texture, double time = TiMe::Default()) { return setValue("filler_color_tex", texture, time); }
59893 Value get_filler_color_tex(double time = TiMe::Default()) const { return getValue("filler_color_tex", time); }
59894
59898 bool set_cell_size(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("cell_size", texturefloat, time); }
59902 bool set_cell_size(float texturefloat, double time = TiMe::Default()) { return setValue("cell_size", texturefloat, time); }
59906 Value get_cell_size(double time = TiMe::Default()) const { return getValue("cell_size", time); }
59907
59911 bool set_density(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("density", texturefloat, time); }
59915 bool set_density(float texturefloat, double time = TiMe::Default()) { return setValue("density", texturefloat, time); }
59919 Value get_density(double time = TiMe::Default()) const { return getValue("density", time); }
59920
59924 bool set_mix_ratio(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("mix_ratio", texturefloat, time); }
59928 bool set_mix_ratio(float texturefloat, double time = TiMe::Default()) { return setValue("mix_ratio", texturefloat, time); }
59932 Value get_mix_ratio(double time = TiMe::Default()) const { return getValue("mix_ratio", time); }
59933
59937 bool set_spottyness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("spottyness", texturefloat, time); }
59941 bool set_spottyness(float texturefloat, double time = TiMe::Default()) { return setValue("spottyness", texturefloat, time); }
59945 Value get_spottyness(double time = TiMe::Default()) const { return getValue("spottyness", time); }
59946
59950 bool set_randomness(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("randomness", texturefloat, time); }
59954 bool set_randomness(float texturefloat, double time = TiMe::Default()) { return setValue("randomness", texturefloat, time); }
59958 Value get_randomness(double time = TiMe::Default()) const { return getValue("randomness", time); }
59959
59963 bool set_threshold(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("threshold", texturefloat, time); }
59967 bool set_threshold(float texturefloat, double time = TiMe::Default()) { return setValue("threshold", texturefloat, time); }
59971 Value get_threshold(double time = TiMe::Default()) const { return getValue("threshold", time); }
59972
59975 bool set_creases(bool val, double time = TiMe::Default()) { return setValue("creases", val, time); }
59978 bool get_creases(double time = TiMe::Default()) const { return getBool("creases", time); }
59979};
59980
59982class TexGrid : public Plugin {
59983public:
59985 static constexpr const PluginTypeId getTypeId() { return 0x7782A7A7; }
59987 static constexpr const char* getType() { return "TexGrid"; }
59988
59989 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
59990
59994 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
59998 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
59999
60003 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
60007 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
60008
60012 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
60016 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
60017
60021 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
60025 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
60026
60030 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
60034 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
60038 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
60039
60043 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
60047 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
60051 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
60052
60056 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
60060 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
60064 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
60065
60069 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
60073 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
60077 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
60078
60082 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
60086 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
60090 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
60091
60093 PluginRef out_color() const { return PluginRef(*this, "color"); }
60094
60096 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
60097
60099 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
60100
60102 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
60103
60106 bool set_uvwgen(const PluginRef& plugin, double time = TiMe::Default()) { return setValue("uvwgen", plugin, time); }
60109 PluginRef get_uvwgen(double time = TiMe::Default()) const { return getPlugin("uvwgen", time); }
60110
60114 bool set_placement_type(int val, double time = TiMe::Default()) { return setValue("placement_type", val, time); }
60118 int get_placement_type(double time = TiMe::Default()) const { return getInt("placement_type", time); }
60119
60123 bool set_u(float val, double time = TiMe::Default()) { return setValue("u", val, time); }
60127 float get_u(double time = TiMe::Default()) const { return getFloat("u", time); }
60128
60132 bool set_v(float val, double time = TiMe::Default()) { return setValue("v", val, time); }
60136 float get_v(double time = TiMe::Default()) const { return getFloat("v", time); }
60137
60141 bool set_w(float val, double time = TiMe::Default()) { return setValue("w", val, time); }
60145 float get_w(double time = TiMe::Default()) const { return getFloat("w", time); }
60146
60150 bool set_h(float val, double time = TiMe::Default()) { return setValue("h", val, time); }
60154 float get_h(double time = TiMe::Default()) const { return getFloat("h", time); }
60155
60159 bool set_jitter(float val, double time = TiMe::Default()) { return setValue("jitter", val, time); }
60163 float get_jitter(double time = TiMe::Default()) const { return getFloat("jitter", time); }
60164
60168 bool set_tile_u(bool val, double time = TiMe::Default()) { return setValue("tile_u", val, time); }
60172 bool get_tile_u(double time = TiMe::Default()) const { return getBool("tile_u", time); }
60173
60177 bool set_tile_v(bool val, double time = TiMe::Default()) { return setValue("tile_v", val, time); }
60181 bool get_tile_v(double time = TiMe::Default()) const { return getBool("tile_v", time); }
60182
60186 bool set_uv_noise_on(bool val, double time = TiMe::Default()) { return setValue("uv_noise_on", val, time); }
60190 bool get_uv_noise_on(double time = TiMe::Default()) const { return getBool("uv_noise_on", time); }
60191
60195 bool set_uv_noise_animate(bool val, double time = TiMe::Default()) { return setValue("uv_noise_animate", val, time); }
60199 bool get_uv_noise_animate(double time = TiMe::Default()) const { return getBool("uv_noise_animate", time); }
60200
60204 bool set_uv_noise_amount(float val, double time = TiMe::Default()) { return setValue("uv_noise_amount", val, time); }
60208 float get_uv_noise_amount(double time = TiMe::Default()) const { return getFloat("uv_noise_amount", time); }
60209
60213 bool set_uv_noise_levels(float val, double time = TiMe::Default()) { return setValue("uv_noise_levels", val, time); }
60217 float get_uv_noise_levels(double time = TiMe::Default()) const { return getFloat("uv_noise_levels", time); }
60218
60222 bool set_uv_noise_size(float val, double time = TiMe::Default()) { return setValue("uv_noise_size", val, time); }
60226 float get_uv_noise_size(double time = TiMe::Default()) const { return getFloat("uv_noise_size", time); }
60227
60231 bool set_un_noise_phase(float val, double time = TiMe::Default()) { return setValue("un_noise_phase", val, time); }
60235 float get_un_noise_phase(double time = TiMe::Default()) const { return getFloat("un_noise_phase", time); }
60236
60239 bool set_line_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("line_color", texture, time); }
60242 bool set_line_color(const AColor& texture, double time = TiMe::Default()) { return setValue("line_color", texture, time); }
60245 Value get_line_color(double time = TiMe::Default()) const { return getValue("line_color", time); }
60246
60249 bool set_fill_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("fill_color", texture, time); }
60252 bool set_fill_color(const AColor& texture, double time = TiMe::Default()) { return setValue("fill_color", texture, time); }
60255 Value get_fill_color(double time = TiMe::Default()) const { return getValue("fill_color", time); }
60256
60260 bool set_u_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("u_width", texturefloat, time); }
60264 bool set_u_width(float texturefloat, double time = TiMe::Default()) { return setValue("u_width", texturefloat, time); }
60268 Value get_u_width(double time = TiMe::Default()) const { return getValue("u_width", time); }
60269
60273 bool set_v_width(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("v_width", texturefloat, time); }
60277 bool set_v_width(float texturefloat, double time = TiMe::Default()) { return setValue("v_width", texturefloat, time); }
60281 Value get_v_width(double time = TiMe::Default()) const { return getValue("v_width", time); }
60282};
60283
60285class TexHSVToRGB : public Plugin {
60286public:
60288 static constexpr const PluginTypeId getTypeId() { return 0x77B09576; }
60290 static constexpr const char* getType() { return "TexHSVToRGB"; }
60291
60292 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60293
60296 bool set_inHsv(const PluginRef& texture, double time = TiMe::Default()) { return setValue("inHsv", texture, time); }
60299 bool set_inHsv(const AColor& texture, double time = TiMe::Default()) { return setValue("inHsv", texture, time); }
60302 Value get_inHsv(double time = TiMe::Default()) const { return getValue("inHsv", time); }
60303
60305 PluginRef out_color() const { return PluginRef(*this, "color"); }
60306};
60307
60310public:
60312 static constexpr const PluginTypeId getTypeId() { return 0x77DFE20D; }
60314 static constexpr const char* getType() { return "TexHairRootSampler"; }
60315
60316 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60317
60320 bool set_root_values(const ColorList& colorList, double time = TiMe::Default()) { return setValue("root_values", colorList, time); }
60321 bool set_root_values(ColorList&& colorList, double time = TiMe::Default()) { return setValue("root_values", std::move(colorList), time); }
60322 bool set_root_values(const Color* colors, size_t count, double time = TiMe::Default()) { return setArray("root_values", colors, count, time); }
60323 template<size_t count> bool set_root_values(const Color (&colors)[count], double time = TiMe::Default()) { return setArray("root_values", colors, count, time); }
60326 ColorList get_root_values(double time = TiMe::Default()) const { return getColorList("root_values", time); }
60327};
60328
60330class TexHairSampler : public Plugin {
60331public:
60333 static constexpr const PluginTypeId getTypeId() { return 0x77ECDBED; }
60335 static constexpr const char* getType() { return "TexHairSampler"; }
60336
60338 PluginRef out_distance_along_strand() const { return PluginRef(*this, "distance_along_strand"); }
60339
60341 PluginRef out_distance_along_strand_absolute() const { return PluginRef(*this, "distance_along_strand_absolute"); }
60342
60344 PluginRef out_position_across_strand() const { return PluginRef(*this, "position_across_strand"); }
60345
60347 PluginRef out_hair_color() const { return PluginRef(*this, "hair_color"); }
60348
60350 PluginRef out_hair_incandescence() const { return PluginRef(*this, "hair_incandescence"); }
60351
60353 PluginRef out_hair_transparency() const { return PluginRef(*this, "hair_transparency"); }
60354
60356 PluginRef out_random_by_strand() const { return PluginRef(*this, "random_by_strand"); }
60357
60361 bool set_hair_max_distance(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("hair_max_distance", texturefloat, time); }
60365 bool set_hair_max_distance(float texturefloat, double time = TiMe::Default()) { return setValue("hair_max_distance", texturefloat, time); }
60369 Value get_hair_max_distance(double time = TiMe::Default()) const { return getValue("hair_max_distance", time); }
60370};
60371
60373class TexICC : public Plugin {
60374public:
60376 static constexpr const PluginTypeId getTypeId() { return 0x4AEAB4890; }
60378 static constexpr const char* getType() { return "TexICC"; }
60379
60380 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60381
60384 bool set_basemap(const PluginRef& texture, double time = TiMe::Default()) { return setValue("basemap", texture, time); }
60387 bool set_basemap(const AColor& texture, double time = TiMe::Default()) { return setValue("basemap", texture, time); }
60390 Value get_basemap(double time = TiMe::Default()) const { return getValue("basemap", time); }
60391
60395 bool set_file(const char* str, double time = TiMe::Default()) { return setValue("file", str, time); }
60399 bool set_file(const std::string& str, double time = TiMe::Default()) { return setValue("file", str, time); }
60403 std::string get_file(double time = TiMe::Default()) const { return getString("file", time); }
60404
60407 bool set_render_intent(int val, double time = TiMe::Default()) { return setValue("render_intent", val, time); }
60410 int get_render_intent(double time = TiMe::Default()) const { return getInt("render_intent", time); }
60411
60414 bool set_blackpoint(bool val, double time = TiMe::Default()) { return setValue("blackpoint", val, time); }
60417 bool get_blackpoint(double time = TiMe::Default()) const { return getBool("blackpoint", time); }
60418};
60419
60421class TexIDIntegerMap : public Plugin {
60422public:
60424 static constexpr const PluginTypeId getTypeId() { return 0x77F0A985; }
60426 static constexpr const char* getType() { return "TexIDIntegerMap"; }
60427
60428 operator TextureIntPluginCategory() { return *static_cast<TextureIntPluginCategory*>(static_cast<Plugin*>(this)); }
60429
60432 bool set_id_tex(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("id_tex", textureint, time); }
60435 bool set_id_tex(int textureint, double time = TiMe::Default()) { return setValue("id_tex", textureint, time); }
60438 Value get_id_tex(double time = TiMe::Default()) const { return getValue("id_tex", time); }
60439
60442 bool set_ids(const IntList& intList, double time = TiMe::Default()) { return setValue("ids", intList, time); }
60443 bool set_ids(IntList&& intList, double time = TiMe::Default()) { return setValue("ids", std::move(intList), time); }
60444 bool set_ids(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
60445 template<size_t count> bool set_ids(const int (&ints)[count], double time = TiMe::Default()) { return setArray("ids", ints, count, time); }
60448 IntList get_ids(double time = TiMe::Default()) const { return getIntList("ids", time); }
60449
60452 bool set_values(const IntList& intList, double time = TiMe::Default()) { return setValue("values", intList, time); }
60453 bool set_values(IntList&& intList, double time = TiMe::Default()) { return setValue("values", std::move(intList), time); }
60454 bool set_values(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("values", ints, count, time); }
60455 template<size_t count> bool set_values(const int (&ints)[count], double time = TiMe::Default()) { return setArray("values", ints, count, time); }
60458 IntList get_values(double time = TiMe::Default()) const { return getIntList("values", time); }
60459
60462 bool set_default(int val, double time = TiMe::Default()) { return setValue("default", val, time); }
60465 int get_default(double time = TiMe::Default()) const { return getInt("default", time); }
60466
60469 bool set_nsamples(int val, double time = TiMe::Default()) { return setValue("nsamples", val, time); }
60472 int get_nsamples(double time = TiMe::Default()) const { return getInt("nsamples", time); }
60473};
60474
60476class TexInt : public Plugin {
60477public:
60479 static constexpr const PluginTypeId getTypeId() { return 0x77EDC552; }
60481 static constexpr const char* getType() { return "TexInt"; }
60482
60483 operator TextureIntPluginCategory() { return *static_cast<TextureIntPluginCategory*>(static_cast<Plugin*>(this)); }
60484
60487 bool set_input(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("input", textureint, time); }
60490 bool set_input(int textureint, double time = TiMe::Default()) { return setValue("input", textureint, time); }
60493 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
60494};
60495
60497class TexIntToFloat : public Plugin {
60498public:
60500 static constexpr const PluginTypeId getTypeId() { return 0x77FDCE6C; }
60502 static constexpr const char* getType() { return "TexIntToFloat"; }
60503
60504 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
60505
60508 bool set_input(const PluginRef& textureint, double time = TiMe::Default()) { return setValue("input", textureint, time); }
60511 bool set_input(int textureint, double time = TiMe::Default()) { return setValue("input", textureint, time); }
60514 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
60515};
60516
60518class TexInterpLinear : public Plugin {
60519public:
60521 static constexpr const PluginTypeId getTypeId() { return 0x77B0277E; }
60523 static constexpr const char* getType() { return "TexInterpLinear"; }
60524
60525 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
60526
60528 bool set_input(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
60530 bool set_input(float texturefloat, double time = TiMe::Default()) { return setValue("input", texturefloat, time); }
60532 Value get_input(double time = TiMe::Default()) const { return getValue("input", time); }
60533
60535 bool set_oldrange_min(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("oldrange_min", texturefloat, time); }
60537 bool set_oldrange_min(float texturefloat, double time = TiMe::Default()) { return setValue("oldrange_min", texturefloat, time); }
60539 Value get_oldrange_min(double time = TiMe::Default()) const { return getValue("oldrange_min", time); }
60540
60542 bool set_oldrange_max(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("oldrange_max", texturefloat, time); }
60544 bool set_oldrange_max(float texturefloat, double time = TiMe::Default()) { return setValue("oldrange_max", texturefloat, time); }
60546 Value get_oldrange_max(double time = TiMe::Default()) const { return getValue("oldrange_max", time); }
60547
60549 bool set_newrange_min(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("newrange_min", texturefloat, time); }
60551 bool set_newrange_min(float texturefloat, double time = TiMe::Default()) { return setValue("newrange_min", texturefloat, time); }
60553 Value get_newrange_min(double time = TiMe::Default()) const { return getValue("newrange_min", time); }
60554
60556 bool set_newrange_max(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("newrange_max", texturefloat, time); }
60558 bool set_newrange_max(float texturefloat, double time = TiMe::Default()) { return setValue("newrange_max", texturefloat, time); }
60560 Value get_newrange_max(double time = TiMe::Default()) const { return getValue("newrange_max", time); }
60561};
60562
60564class TexInvert : public Plugin {
60565public:
60567 static constexpr const PluginTypeId getTypeId() { return 0x4AB191AE1; }
60569 static constexpr const char* getType() { return "TexInvert"; }
60570
60571 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60572
60575 bool set_texture(const PluginRef& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
60578 bool set_texture(const AColor& texture, double time = TiMe::Default()) { return setValue("texture", texture, time); }
60581 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
60582
60585 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
60588 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
60589
60591 PluginRef out_color() const { return PluginRef(*this, "color"); }
60592};
60593
60595class TexInvertFloat : public Plugin {
60596public:
60598 static constexpr const PluginTypeId getTypeId() { return 0x780B8B01; }
60600 static constexpr const char* getType() { return "TexInvertFloat"; }
60601
60602 operator TextureFloatPluginCategory() { return *static_cast<TextureFloatPluginCategory*>(static_cast<Plugin*>(this)); }
60603
60606 bool set_texture(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("texture", texturefloat, time); }
60609 bool set_texture(float texturefloat, double time = TiMe::Default()) { return setValue("texture", texturefloat, time); }
60612 Value get_texture(double time = TiMe::Default()) const { return getValue("texture", time); }
60613};
60614
60616class TexLayered : public Plugin {
60617public:
60619 static constexpr const PluginTypeId getTypeId() { return 0x77925D21; }
60621 static constexpr const char* getType() { return "TexLayered"; }
60622
60623 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60624
60628 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
60632 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
60633
60637 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
60641 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
60642
60646 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
60650 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
60651
60655 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
60659 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
60660
60664 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
60668 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
60672 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
60673
60677 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
60681 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
60685 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
60686
60690 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
60694 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
60698 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
60699
60703 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
60707 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
60711 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
60712
60716 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
60720 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
60724 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
60725
60727 PluginRef out_color() const { return PluginRef(*this, "color"); }
60728
60730 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
60731
60733 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
60734
60736 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
60737
60740 bool set_textures(const ValueList& textureList, double time = TiMe::Default()) { return setValue("textures", textureList, time); }
60741 bool set_textures(ValueList&& textureList, double time = TiMe::Default()) { return setValue("textures", std::move(textureList), time); }
60742 bool set_textures(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("textures", textures, count, time); }
60743 template<size_t count> bool set_textures(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("textures", textures, count, time); }
60744 template<size_t count> bool set_textures(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("textures", textures, count, time); }
60747 ValueList get_textures(double time = TiMe::Default()) const { return getValueList("textures", time); }
60748
60752 bool set_blend_modes(const IntList& intList, double time = TiMe::Default()) { return setValue("blend_modes", intList, time); }
60753 bool set_blend_modes(IntList&& intList, double time = TiMe::Default()) { return setValue("blend_modes", std::move(intList), time); }
60754 bool set_blend_modes(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("blend_modes", ints, count, time); }
60755 template<size_t count> bool set_blend_modes(const int (&ints)[count], double time = TiMe::Default()) { return setArray("blend_modes", ints, count, time); }
60759 IntList get_blend_modes(double time = TiMe::Default()) const { return getIntList("blend_modes", time); }
60760
60763 bool set_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
60766 bool set_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
60769 Value get_alpha(double time = TiMe::Default()) const { return getValue("alpha", time); }
60770};
60771
60773class TexLayeredMax : public Plugin {
60774public:
60776 static constexpr const PluginTypeId getTypeId() { return 0x77B0C1FE; }
60778 static constexpr const char* getType() { return "TexLayeredMax"; }
60779
60780 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60781
60785 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
60789 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
60790
60794 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
60798 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
60799
60803 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
60807 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
60808
60812 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
60816 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
60817
60821 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
60825 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
60829 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
60830
60834 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
60838 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
60842 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
60843
60847 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
60851 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
60855 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
60856
60860 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
60864 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
60868 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
60869
60873 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
60877 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
60881 Value get_nouvw_color(double time = TiMe::Default()) const { return getValue("nouvw_color", time); }
60882
60884 PluginRef out_color() const { return PluginRef(*this, "color"); }
60885
60887 PluginRef out_out_transparency() const { return PluginRef(*this, "out_transparency"); }
60888
60890 PluginRef out_out_alpha() const { return PluginRef(*this, "out_alpha"); }
60891
60893 PluginRef out_out_intensity() const { return PluginRef(*this, "out_intensity"); }
60894
60897 bool set_textures(const ValueList& textureList, double time = TiMe::Default()) { return setValue("textures", textureList, time); }
60898 bool set_textures(ValueList&& textureList, double time = TiMe::Default()) { return setValue("textures", std::move(textureList), time); }
60899 bool set_textures(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("textures", textures, count, time); }
60900 template<size_t count> bool set_textures(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("textures", textures, count, time); }
60901 template<size_t count> bool set_textures(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("textures", textures, count, time); }
60904 ValueList get_textures(double time = TiMe::Default()) const { return getValueList("textures", time); }
60905
60908 bool set_masks(const ValueList& textureList, double time = TiMe::Default()) { return setValue("masks", textureList, time); }
60909 bool set_masks(ValueList&& textureList, double time = TiMe::Default()) { return setValue("masks", std::move(textureList), time); }
60910 bool set_masks(const Value* textures, size_t count, double time = TiMe::Default()) { return setArray("masks", textures, count, time); }
60911 template<size_t count> bool set_masks(const Value (&textures)[count], double time = TiMe::Default()) { return setArray("masks", textures, count, time); }
60912 template<size_t count> bool set_masks(Value (&&textures)[count], double time = TiMe::Default()) { return setArray("masks", textures, count, time); }
60915 ValueList get_masks(double time = TiMe::Default()) const { return getValueList("masks", time); }
60916
60920 bool set_blend_modes(const IntList& intList, double time = TiMe::Default()) { return setValue("blend_modes", intList, time); }
60921 bool set_blend_modes(IntList&& intList, double time = TiMe::Default()) { return setValue("blend_modes", std::move(intList), time); }
60922 bool set_blend_modes(const int* ints, size_t count, double time = TiMe::Default()) { return setArray("blend_modes", ints, count, time); }
60923 template<size_t count> bool set_blend_modes(const int (&ints)[count], double time = TiMe::Default()) { return setArray("blend_modes", ints, count, time); }
60927 IntList get_blend_modes(double time = TiMe::Default()) const { return getIntList("blend_modes", time); }
60928
60932 bool set_opacities(const FloatList& floatList, double time = TiMe::Default()) { return setValue("opacities", floatList, time); }
60933 bool set_opacities(FloatList&& floatList, double time = TiMe::Default()) { return setValue("opacities", std::move(floatList), time); }
60934 bool set_opacities(const float* floats, size_t count, double time = TiMe::Default()) { return setArray("opacities", floats, count, time); }
60935 template<size_t count> bool set_opacities(const float (&floats)[count], double time = TiMe::Default()) { return setArray("opacities", floats, count, time); }
60939 FloatList get_opacities(double time = TiMe::Default()) const { return getFloatList("opacities", time); }
60940
60943 bool set_allow_negative_colors(bool val, double time = TiMe::Default()) { return setValue("allow_negative_colors", val, time); }
60946 bool get_allow_negative_colors(double time = TiMe::Default()) const { return getBool("allow_negative_colors", time); }
60947
60950 bool set_alpha(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
60953 bool set_alpha(float texturefloat, double time = TiMe::Default()) { return setValue("alpha", texturefloat, time); }
60956 Value get_alpha(double time = TiMe::Default()) const { return getValue("alpha", time); }
60957};
60958
60960class TexLayeredNuke : public Plugin {
60961public:
60963 static constexpr const PluginTypeId getTypeId() { return 0x782A2DA4; }
60965 static constexpr const char* getType() { return "TexLayeredNuke"; }
60966
60967 operator TexturePluginCategory() { return *static_cast<TexturePluginCategory*>(static_cast<Plugin*>(this)); }
60968
60972 bool set_compatibility_with(int val, double time = TiMe::Default()) { return setValue("compatibility_with", val, time); }
60976 int get_compatibility_with(double time = TiMe::Default()) const { return getInt("compatibility_with", time); }
60977
60981 bool set_alpha_from_intensity(int val, double time = TiMe::Default()) { return setValue("alpha_from_intensity", val, time); }
60985 int get_alpha_from_intensity(double time = TiMe::Default()) const { return getInt("alpha_from_intensity", time); }
60986
60990 bool set_invert(bool val, double time = TiMe::Default()) { return setValue("invert", val, time); }
60994 bool get_invert(double time = TiMe::Default()) const { return getBool("invert", time); }
60995
60999 bool set_invert_alpha(bool val, double time = TiMe::Default()) { return setValue("invert_alpha", val, time); }
61003 bool get_invert_alpha(double time = TiMe::Default()) const { return getBool("invert_alpha", time); }
61004
61008 bool set_color_mult(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
61012 bool set_color_mult(const AColor& texture, double time = TiMe::Default()) { return setValue("color_mult", texture, time); }
61016 Value get_color_mult(double time = TiMe::Default()) const { return getValue("color_mult", time); }
61017
61021 bool set_color_offset(const PluginRef& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
61025 bool set_color_offset(const AColor& texture, double time = TiMe::Default()) { return setValue("color_offset", texture, time); }
61029 Value get_color_offset(double time = TiMe::Default()) const { return getValue("color_offset", time); }
61030
61034 bool set_alpha_mult(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
61038 bool set_alpha_mult(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_mult", texturefloat, time); }
61042 Value get_alpha_mult(double time = TiMe::Default()) const { return getValue("alpha_mult", time); }
61043
61047 bool set_alpha_offset(const PluginRef& texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
61051 bool set_alpha_offset(float texturefloat, double time = TiMe::Default()) { return setValue("alpha_offset", texturefloat, time); }
61055 Value get_alpha_offset(double time = TiMe::Default()) const { return getValue("alpha_offset", time); }
61056
61060 bool set_nouvw_color(const PluginRef& texture, double time = TiMe::Default()) { return setValue("nouvw_color", texture, time); }
61064 bool set_nouvw_color(const AColor& texture, double time = TiMe::Default()) { return setValue("nouvw_color"
