VRay SDK for C++
Loading...
Searching...
No Matches
VRay::Plugins::CameraPhysical Class Reference
Defines a physical camera when present in the scene. Affects DoF, exposure, motion blur etc. [gpuSupport=(partial)]. More...
#include <vrayplugins.hpp>
Inheritance diagram for VRay::Plugins::CameraPhysical:
VRay::Plugin
Public Member Functions
float get_anisotropy (double time=TiMe::Default()) const
bool get_blades_enable (double time=TiMe::Default()) const
int get_blades_num (double time=TiMe::Default()) const
float get_blades_rotation (double time=TiMe::Default()) const
bool get_bmpaperture_affects_exposure (double time=TiMe::Default()) const
bool get_bmpaperture_enable (double time=TiMe::Default()) const
int get_bmpaperture_resolution (double time=TiMe::Default()) const
Value get_bmpaperture_tex (double time=TiMe::Default()) const
Value get_camera_shader_tex (double time=TiMe::Default()) const
float get_center_bias (double time=TiMe::Default()) const
float get_distortion (double time=TiMe::Default()) const
Value get_distortion_tex (double time=TiMe::Default()) const
int get_distortion_type (double time=TiMe::Default()) const
float get_dof_display_threshold (double time=TiMe::Default()) const
bool get_dont_affect_settings (double time=TiMe::Default()) const
bool get_enable_thin_lens_equation (double time=TiMe::Default()) const
int get_exposure (double time=TiMe::Default()) const
float get_exposure_value (double time=TiMe::Default()) const
float get_f_number (double time=TiMe::Default()) const
float get_film_width (double time=TiMe::Default()) const
float get_focal_length (double time=TiMe::Default()) const
float get_focus_distance (double time=TiMe::Default()) const
float get_fov (double time=TiMe::Default()) const
float get_horizontal_offset (double time=TiMe::Default()) const
float get_horizontal_shift (double time=TiMe::Default()) const
float get_ISO (double time=TiMe::Default()) const
float get_latency (double time=TiMe::Default()) const
std::string get_lens_file (double time=TiMe::Default()) const
float get_lens_shift (double time=TiMe::Default()) const
float get_optical_vignetting (double time=TiMe::Default()) const
float get_rolling_shutter_duration (double time=TiMe::Default()) const
int get_rolling_shutter_mode (double time=TiMe::Default()) const
std::string get_scene_name (double time=TiMe::Default()) const
float get_shutter_angle (double time=TiMe::Default()) const
float get_shutter_offset (double time=TiMe::Default()) const
float get_shutter_speed (double time=TiMe::Default()) const
bool get_specify_focus (double time=TiMe::Default()) const
bool get_specify_fov (double time=TiMe::Default()) const
int get_subdivs (double time=TiMe::Default()) const
float get_target_distance (double time=TiMe::Default()) const
bool get_targeted (double time=TiMe::Default()) const
int get_type (double time=TiMe::Default()) const
bool get_use_dof (double time=TiMe::Default()) const
bool get_use_moblur (double time=TiMe::Default()) const
float get_vertical_offset (double time=TiMe::Default()) const
float get_vignetting (double time=TiMe::Default()) const
Color get_white_balance (double time=TiMe::Default()) const
float get_zoom_factor (double time=TiMe::Default()) const
 operator SettingsPluginCategory ()
bool set_anisotropy (float val, double time=TiMe::Default())
bool set_blades_enable (bool val, double time=TiMe::Default())
bool set_blades_num (int val, double time=TiMe::Default())
bool set_blades_rotation (float val, double time=TiMe::Default())
bool set_bmpaperture_affects_exposure (bool val, double time=TiMe::Default())
bool set_bmpaperture_enable (bool val, double time=TiMe::Default())
bool set_bmpaperture_resolution (int val, double time=TiMe::Default())
bool set_bmpaperture_tex (const AColor &texture, double time=TiMe::Default())
bool set_bmpaperture_tex (const PluginRef &texture, double time=TiMe::Default())
bool set_camera_shader_tex (const AColor &texture, double time=TiMe::Default())
bool set_camera_shader_tex (const PluginRef &texture, double time=TiMe::Default())
bool set_center_bias (float val, double time=TiMe::Default())
bool set_distortion (float val, double time=TiMe::Default())
bool set_distortion_tex (const AColor &texture, double time=TiMe::Default())
bool set_distortion_tex (const PluginRef &texture, double time=TiMe::Default())
bool set_distortion_type (int val, double time=TiMe::Default())
bool set_dof_display_threshold (float val, double time=TiMe::Default())
bool set_dont_affect_settings (bool val, double time=TiMe::Default())
bool set_enable_thin_lens_equation (bool val, double time=TiMe::Default())
bool set_exposure (int val, double time=TiMe::Default())
bool set_exposure_value (float val, double time=TiMe::Default())
bool set_f_number (float val, double time=TiMe::Default())
bool set_film_width (float val, double time=TiMe::Default())
bool set_focal_length (float val, double time=TiMe::Default())
bool set_focus_distance (float val, double time=TiMe::Default())
bool set_fov (float val, double time=TiMe::Default())
bool set_horizontal_offset (float val, double time=TiMe::Default())
bool set_horizontal_shift (float val, double time=TiMe::Default())
bool set_ISO (float val, double time=TiMe::Default())
bool set_latency (float val, double time=TiMe::Default())
bool set_lens_file (const char *str, double time=TiMe::Default())
bool set_lens_file (const std::string &str, double time=TiMe::Default())
bool set_lens_shift (float val, double time=TiMe::Default())
bool set_optical_vignetting (float val, double time=TiMe::Default())
bool set_rolling_shutter_duration (float val, double time=TiMe::Default())
bool set_rolling_shutter_mode (int val, double time=TiMe::Default())
bool set_scene_name (const char *str, double time=TiMe::Default())
bool set_scene_name (const std::string &str, double time=TiMe::Default())
bool set_shutter_angle (float val, double time=TiMe::Default())
bool set_shutter_offset (float val, double time=TiMe::Default())
bool set_shutter_speed (float val, double time=TiMe::Default())
bool set_specify_focus (bool val, double time=TiMe::Default())
bool set_specify_fov (bool val, double time=TiMe::Default())
bool set_subdivs (int val, double time=TiMe::Default())
bool set_target_distance (float val, double time=TiMe::Default())
bool set_targeted (bool val, double time=TiMe::Default())
bool set_type (int val, double time=TiMe::Default())
bool set_use_dof (bool val, double time=TiMe::Default())
bool set_use_moblur (bool val, double time=TiMe::Default())
bool set_vertical_offset (float val, double time=TiMe::Default())
bool set_vignetting (float val, double time=TiMe::Default())
bool set_white_balance (const Color &color, double time=TiMe::Default())
bool set_zoom_factor (float val, double time=TiMe::Default())
- Public Member Functions inherited from VRay::Plugin
 Plugin () noexcept
 Default construct an invalid Plugin - not referencing a V-Ray scene object.
 Plugin (const Plugin &plugin) noexcept
 Copy construct from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
AColor getAColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const
AColor getAColor (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as AColor.
AColor getAColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
 This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
AColor getAColor (const std::string &propertyName, double time=TiMe::Default()) const
bool getBool (const char *propertyName, bool &ok, double time=TiMe::Default()) const
bool getBool (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as bool.
bool getBool (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
bool getBool (const std::string &propertyName, double time=TiMe::Default()) const
PluginCategories getCategories () const
VUtils::CharString getCharString (const char *propertyName)
VUtils::CharString getCharString (const char *propertyName, bool &ok)
VUtils::CharString getCharString (const std::string &propertyName)
VUtils::CharString getCharString (const std::string &propertyName, bool &ok)
VUtils::CharString getCharStringAtTime (const char *propertyName, double time)
VUtils::CharString getCharStringAtTime (const char *propertyName, double time, bool &ok)
VUtils::CharString getCharStringAtTime (const std::string &propertyName, double time)
VUtils::CharString getCharStringAtTime (const std::string &propertyName, double time, bool &ok)
Color getColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Color getColor (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Color.
Color getColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Color getColor (const std::string &propertyName, double time=TiMe::Default()) const
ColorList getColorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
ColorList getColorList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as ColorList.
ColorList getColorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
ColorList getColorList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::ColorRefList getColorRefList (const char *propertyName)
VUtils::ColorRefList getColorRefList (const char *propertyName, bool &ok)
VUtils::ColorRefList getColorRefList (const std::string &propertyName)
VUtils::ColorRefList getColorRefList (const std::string &propertyName, bool &ok)
VUtils::ColorRefList getColorRefListAtTime (const char *propertyName, double time)
VUtils::ColorRefList getColorRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::ColorRefList getColorRefListAtTime (const std::string &propertyName, double time)
VUtils::ColorRefList getColorRefListAtTime (const std::string &propertyName, double time, bool &ok)
double getDouble (const char *propertyName, bool &ok, double time=TiMe::Default()) const
double getDouble (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as double.
double getDouble (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
double getDouble (const std::string &propertyName, double time=TiMe::Default()) const
float getFloat (const char *propertyName, bool &ok, double time=TiMe::Default()) const
float getFloat (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as float.
float getFloat (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
float getFloat (const std::string &propertyName, double time=TiMe::Default()) const
FloatList getFloatList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
FloatList getFloatList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as FloatList.
FloatList getFloatList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
FloatList getFloatList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::FloatRefList getFloatRefList (const char *propertyName)
VUtils::FloatRefList getFloatRefList (const char *propertyName, bool &ok)
VUtils::FloatRefList getFloatRefList (const std::string &propertyName)
VUtils::FloatRefList getFloatRefList (const std::string &propertyName, bool &ok)
VUtils::FloatRefList getFloatRefListAtTime (const char *propertyName, double time)
VUtils::FloatRefList getFloatRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::FloatRefList getFloatRefListAtTime (const std::string &propertyName, double time)
VUtils::FloatRefList getFloatRefListAtTime (const std::string &propertyName, double time, bool &ok)
int getInt (const char *propertyName, bool &ok, double time=TiMe::Default()) const
int getInt (const char *propertyName, double time=TiMe::Default()) const
int getInt (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
int getInt (const std::string &propertyName, double time=TiMe::Default()) const
unsigned long long getIntegerID () const noexcept
 Returns the ID of the plugin instance. The ID is unique per scene contained in a VRayRenderer instance. Can be used as a hash value.
IntList getIntList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
IntList getIntList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as IntList.
IntList getIntList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
IntList getIntList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::IntRefList getIntRefList (const char *propertyName)
VUtils::IntRefList getIntRefList (const char *propertyName, bool &ok)
VUtils::IntRefList getIntRefList (const std::string &propertyName)
VUtils::IntRefList getIntRefList (const std::string &propertyName, bool &ok)
VUtils::IntRefList getIntRefListAtTime (const char *propertyName, double time)
VUtils::IntRefList getIntRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::IntRefList getIntRefListAtTime (const std::string &propertyName, double time)
VUtils::IntRefList getIntRefListAtTime (const std::string &propertyName, double time, bool &ok)
std::vector< double > getKeyframeTimes (const char *propertyName) const
std::vector< double > getKeyframeTimes (const char *propertyName, bool &ok) const
std::vector< double > getKeyframeTimes (const std::string &propertyName) const
std::vector< double > getKeyframeTimes (const std::string &propertyName, bool &ok) const
Matrix getMatrix (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Matrix getMatrix (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Matrix.
Matrix getMatrix (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Matrix getMatrix (const std::string &propertyName, double time=TiMe::Default()) const
PluginMeta getMeta () const
const char * getName () const
PluginRefT< PlugingetPlugin (const char *propertyName, bool &ok, double time=TiMe::Default()) const
PluginRefT< PlugingetPlugin (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as a Plugin reference.
PluginRefT< PlugingetPlugin (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
PluginRefT< PlugingetPlugin (const std::string &propertyName, double time=TiMe::Default()) const
PluginList getPluginList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
PluginList getPluginList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as PluginList.
PluginList getPluginList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
PluginList getPluginList (const std::string &propertyName, double time=TiMe::Default()) const
PropertyRuntimeMeta getPropertyRuntimeMeta (const char *propertyName) const
PropertyRuntimeMeta getPropertyRuntimeMeta (const std::string &propertyName) const
VRayRenderergetRenderer () const noexcept
 Return the renderer this Plugin is associated with, can be null on empty plugins.
std::string getString (const char *propertyName, bool &ok, double time=TiMe::Default()) const
std::string getString (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as string.
std::string getString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
std::string getString (const std::string &propertyName, double time=TiMe::Default()) const
StringList getStringList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
StringList getStringList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as StringList.
StringList getStringList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
StringList getStringList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::CharStringRefList getStringRefList (const char *propertyName)
VUtils::CharStringRefList getStringRefList (const char *propertyName, bool &ok)
VUtils::CharStringRefList getStringRefList (const std::string &propertyName)
VUtils::CharStringRefList getStringRefList (const std::string &propertyName, bool &ok)
VUtils::CharStringRefList getStringRefListAtTime (const char *propertyName, double time)
VUtils::CharStringRefList getStringRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::CharStringRefList getStringRefListAtTime (const std::string &propertyName, double time)
VUtils::CharStringRefList getStringRefListAtTime (const std::string &propertyName, double time, bool &ok)
Transform getTransform (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Transform getTransform (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Transform.
Transform getTransform (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Transform getTransform (const std::string &propertyName, double time=TiMe::Default()) const
TransformList getTransformList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
TransformList getTransformList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as TransformList.
TransformList getTransformList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
TransformList getTransformList (const std::string &propertyName, double time=TiMe::Default()) const
const char * getType () const
 Returns the type of this plugin as string.
PluginTypeId getTypeId () const noexcept
 Returns the type id of this plugin as long.
Value getValue (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Value getValue (const char *propertyName, double time=TiMe::Default()) const
Value getValue (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Value getValue (const std::string &propertyName, double time=TiMe::Default()) const
std::string getValueAsString (const char *propertyName, bool &ok, double time=TiMe::Default()) const
std::string getValueAsString (const char *propertyName, double time=TiMe::Default()) const
std::string getValueAsString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
std::string getValueAsString (const std::string &propertyName, double time=TiMe::Default()) const
ValueList getValueList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
ValueList getValueList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as ValueList. Works only if it really is a generic list.
ValueList getValueList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
ValueList getValueList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::ValueRefList getValueRefList (const char *propertyName)
VUtils::ValueRefList getValueRefList (const char *propertyName, bool &ok)
VUtils::ValueRefList getValueRefList (const std::string &propertyName)
VUtils::ValueRefList getValueRefList (const std::string &propertyName, bool &ok)
VUtils::ValueRefList getValueRefListAtTime (const char *propertyName, double time)
VUtils::ValueRefList getValueRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::ValueRefList getValueRefListAtTime (const std::string &propertyName, double time)
VUtils::ValueRefList getValueRefListAtTime (const std::string &propertyName, double time, bool &ok)
Vector getVector (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Vector getVector (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Vector.
Vector getVector (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Vector getVector (const std::string &propertyName, double time=TiMe::Default()) const
VectorList getVectorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
VectorList getVectorList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as VectorList.
VectorList getVectorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
VectorList getVectorList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::VectorRefList getVectorRefList (const char *propertyName)
VUtils::VectorRefList getVectorRefList (const char *propertyName, bool &ok)
VUtils::VectorRefList getVectorRefList (const std::string &propertyName)
VUtils::VectorRefList getVectorRefList (const std::string &propertyName, bool &ok)
VUtils::VectorRefList getVectorRefListAtTime (const char *propertyName, double time)
VUtils::VectorRefList getVectorRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::VectorRefList getVectorRefListAtTime (const std::string &propertyName, double time)
VUtils::VectorRefList getVectorRefListAtTime (const std::string &propertyName, double time, bool &ok)
bool isEmpty () const noexcept
bool isNotEmpty () const noexcept
bool isPropertyAnimated (const char *propertyName) const
bool isPropertyAnimated (const std::string &propertyName) const
bool isValid () const
bool operator!= (const Plugin &plugin) const noexcept
 Returns false if both Plugins belong to the same renderer and point to the same scene object instance.
Pluginoperator= (const Plugin &plugin) noexcept
 Assign from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
bool operator== (const Plugin &plugin) const noexcept
 Returns true if both Plugins belong to the same renderer and point to the same scene object instance.
bool setArray (const char *propertyName, const char *const data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Color data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const double data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const float data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const int data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const std::string data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Transform data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Value values[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Vector data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const char *const data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Color data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const double data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const float data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const int data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const std::string data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Transform data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Value values[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Vector data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())
bool setArrayAtTime (const char *propertyName, const Color data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const double data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const float data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const int data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const Plugin data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const std::string data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const Vector data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const Color data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const double data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const float data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const int data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const Plugin data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const std::string data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const Vector data[], size_t count, double time)
bool setName (const char *newName)
bool setName (const std::string &newName)
bool setValue (const char *propertyName, ColorList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, const AColor &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const bool value, double time=TiMe::Default())
bool setValue (const char *propertyName, const char *str, double time=TiMe::Default())
bool setValue (const char *propertyName, const Color &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const ColorList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const double value, double time=TiMe::Default())
bool setValue (const char *propertyName, const float value, double time=TiMe::Default())
bool setValue (const char *propertyName, const FloatList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const int value, double time=TiMe::Default())
bool setValue (const char *propertyName, const IntList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Matrix &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const PluginList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())
bool setValue (const char *propertyName, const std::string &str, double time=TiMe::Default())
bool setValue (const char *propertyName, const StringList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Transform &transform, double time=TiMe::Default())
bool setValue (const char *propertyName, const TransformList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Value &value, double time=TiMe::Default())
template<size_t count>
bool setValue (const char *propertyName, const Value(&arr)[count], double time=TiMe::Default())
bool setValue (const char *propertyName, const ValueList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Vector &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const VectorList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const void *data, size_t size, double time=TiMe::Default())
bool setValue (const char *propertyName, const VUtils::CharString &str)
bool setValue (const char *propertyName, const VUtils::CharStringRefList &stringList)
bool setValue (const char *propertyName, const VUtils::ColorRefList &colorList)
bool setValue (const char *propertyName, const VUtils::FloatRefList &floatList)
bool setValue (const char *propertyName, const VUtils::IntRefList &intList)
bool setValue (const char *propertyName, const VUtils::TransformRefList &transformList)
bool setValue (const char *propertyName, const VUtils::ValueRefList &valueList)
bool setValue (const char *propertyName, const VUtils::VectorRefList &vectorList)
bool setValue (const char *propertyName, FloatList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, IntList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, Value &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, Value(&&arr)[count], double time=TiMe::Default())
bool setValue (const char *propertyName, ValueList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, VectorList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, ColorList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const AColor &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const bool value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const char *str, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Color &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const ColorList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const double value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const float value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const FloatList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const int value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const IntList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Matrix &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const PluginList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const std::string &str, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const StringList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Transform &transform, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const TransformList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Value &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Value(&arr)[count], double time=TiMe::Default())
bool setValue (const std::string &propertyName, const ValueList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Vector &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const VectorList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const void *data, size_t size, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const VUtils::CharString &str)
bool setValue (const std::string &propertyName, const VUtils::CharStringRefList &stringList)
bool setValue (const std::string &propertyName, const VUtils::ColorRefList &colorList)
bool setValue (const std::string &propertyName, const VUtils::FloatRefList &floatList)
bool setValue (const std::string &propertyName, const VUtils::IntRefList &intList)
bool setValue (const std::string &propertyName, const VUtils::TransformRefList &transformList)
bool setValue (const std::string &propertyName, const VUtils::ValueRefList &valueList)
bool setValue (const std::string &propertyName, const VUtils::VectorRefList &vectorList)
bool setValue (const std::string &propertyName, FloatList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, IntList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, Value &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, Value(&&arr)[count], double time=TiMe::Default())
bool setValue (const std::string &propertyName, ValueList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, VectorList &&value, double time=TiMe::Default())
bool setValueAsString (const char *propertyName, const char *value)
bool setValueAsString (const char *propertyName, const std::string &value)
bool setValueAsString (const std::string &propertyName, const char *value)
bool setValueAsString (const std::string &propertyName, const std::string &value)
bool setValueAsStringAtTime (const char *propertyName, const char *value, double time)
bool setValueAsStringAtTime (const char *propertyName, const std::string &value, double time)
bool setValueAsStringAtTime (const std::string &propertyName, const char *value, double time)
bool setValueAsStringAtTime (const std::string &propertyName, const std::string &value, double time)
bool setValueAtTime (const char *propertyName, const AColor &value, double time)
bool setValueAtTime (const char *propertyName, const bool value, double time)
bool setValueAtTime (const char *propertyName, const char *str, double time)
bool setValueAtTime (const char *propertyName, const Color &value, double time)
bool setValueAtTime (const char *propertyName, const ColorList &value, double time)
bool setValueAtTime (const char *propertyName, const double value, double time)
bool setValueAtTime (const char *propertyName, const float value, double time)
bool setValueAtTime (const char *propertyName, const FloatList &value, double time)
bool setValueAtTime (const char *propertyName, const int value, double time)
bool setValueAtTime (const char *propertyName, const IntList &value, double time)
bool setValueAtTime (const char *propertyName, const Matrix &value, double time)
bool setValueAtTime (const char *propertyName, const PluginList &value, double time)
bool setValueAtTime (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time)
bool setValueAtTime (const char *propertyName, const std::string &str, double time)
bool setValueAtTime (const char *propertyName, const StringList &value, double time)
bool setValueAtTime (const char *propertyName, const Transform &transform, double time)
bool setValueAtTime (const char *propertyName, const Value &value, double time)
bool setValueAtTime (const char *propertyName, const ValueList &value, double time)
bool setValueAtTime (const char *propertyName, const Vector &value, double time)
bool setValueAtTime (const char *propertyName, const VectorList &value, double time)
bool setValueAtTime (const char *propertyName, const void *data, size_t size, double time)
bool setValueAtTime (const char *propertyName, const VUtils::CharString &str, double time)
bool setValueAtTime (const char *propertyName, const VUtils::CharStringRefList &stringList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::ColorRefList &colorList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::FloatRefList &floatList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::IntRefList &intList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::TransformRefList &transformList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::ValueRefList &valueList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::VectorRefList &vectorList, double time)
bool setValueAtTime (const std::string &propertyName, const AColor &value, double time)
bool setValueAtTime (const std::string &propertyName, const bool value, double time)
bool setValueAtTime (const std::string &propertyName, const char *str, double time)
bool setValueAtTime (const std::string &propertyName, const Color &value, double time)
bool setValueAtTime (const std::string &propertyName, const ColorList &value, double time)
bool setValueAtTime (const std::string &propertyName, const double value, double time)
bool setValueAtTime (const std::string &propertyName, const float value, double time)
bool setValueAtTime (const std::string &propertyName, const FloatList &value, double time)
bool setValueAtTime (const std::string &propertyName, const int value, double time)
bool setValueAtTime (const std::string &propertyName, const IntList &value, double time)
bool setValueAtTime (const std::string &propertyName, const Matrix &value, double time)
bool setValueAtTime (const std::string &propertyName, const PluginList &value, double time)
bool setValueAtTime (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time)
bool setValueAtTime (const std::string &propertyName, const std::string &str, double time)
bool setValueAtTime (const std::string &propertyName, const StringList &value, double time)
bool setValueAtTime (const std::string &propertyName, const Transform &transform, double time)
bool setValueAtTime (const std::string &propertyName, const Value &value, double time)
bool setValueAtTime (const std::string &propertyName, const ValueList &value, double time)
bool setValueAtTime (const std::string &propertyName, const Vector &value, double time)
bool setValueAtTime (const std::string &propertyName, const VectorList &value, double time)
bool setValueAtTime (const std::string &propertyName, const void *data, size_t size, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::CharString &str, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::CharStringRefList &stringList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::ColorRefList &colorList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::FloatRefList &floatList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::IntRefList &intList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::TransformRefList &transformList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::ValueRefList &valueList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::VectorRefList &vectorList, double time)
void swap (Plugin &plugin) noexcept
 Swaps the underlying scene object instance reference and associated renderer reference.
std::string toString () const
 Returns a string representation of the plugin which currently is the name of the plugin.
Static Public Member Functions
static constexpr const char * getType ()
 Return the name of the plugin type.
static constexpr const PluginTypeId getTypeId ()
 Plugin type ID.
Additional Inherited Members
- Protected Member Functions inherited from VRay::Plugin
 Plugin (VRayRenderer &renderer, const char *name)
 Plugin (VRayRenderer &renderer, InstanceId id) noexcept
 Plugin (VRayRenderer &renderer, InstanceId id, int typeIdIdx) noexcept
 Plugin (VRayRenderer &renderer, InstanceId id, PluginTypeId typeId) noexcept
InstanceId id () const
template<typename T , int TYPE>
bool setArrayAtTimeTemplate (const char *propertyName, size_t count, const T &value, double time)
template<typename LengthFn , typename PointerFn >
bool setStringArrayTemplate (const char *propertyName, size_t count, LengthFn lengthAt, PointerFn pointerAt, double time)
bool setValueAtTimeTemplate (const char *propertyName, const T &value, double time)
- Protected Attributes inherited from VRay::Plugin
InstanceId internalId
const VRayRendererpRenderer
Detailed Description
Member Function Documentation
◆ get_anisotropy()
float VRay::Plugins::CameraPhysical::get_anisotropy ( double  time = TiMe::Default()) const
inline
Bokeh anisotropy [UI Guides] minValue=-1, maxValue=1, gpuSupport=full [Default value] 0
◆ get_blades_enable()
bool VRay::Plugins::CameraPhysical::get_blades_enable ( double  time = TiMe::Default()) const
inline
Set to true to enable Bokeh effects [UI Guides] gpuSupport=full [Default value] 0
◆ get_blades_num()
int VRay::Plugins::CameraPhysical::get_blades_num ( double  time = TiMe::Default()) const
inline
Number of blades - 0 disables Bokeh [UI Guides] enableIf: ?blades_enable=1, minValue=2, maxValue=20, gpuSupport=full [Default value] 5
◆ get_blades_rotation()
float VRay::Plugins::CameraPhysical::get_blades_rotation ( double  time = TiMe::Default()) const
inline
Blade rotation in radians [UI Guides] gpuSupport=full [Default value] 0
◆ get_bmpaperture_affects_exposure()
bool VRay::Plugins::CameraPhysical::get_bmpaperture_affects_exposure ( double  time = TiMe::Default()) const
inline
This will make the Bitmap Aperture's size and shape affect the exposure [UI Guides] enableIf: ?bmpaperture_enable=1, displayName=Bitmap affects exposure, gpuSupport=full [Default value] 1
◆ get_bmpaperture_enable()
bool VRay::Plugins::CameraPhysical::get_bmpaperture_enable ( double  time = TiMe::Default()) const
inline
Set to true to enable the use of bitmap aperture [UI Guides] displayName=Bitmap aperture, minValue=1, maxValue=2048, gpuSupport=full [Default value] 0
◆ get_bmpaperture_resolution()
int VRay::Plugins::CameraPhysical::get_bmpaperture_resolution ( double  time = TiMe::Default()) const
inline
Texture sampling resolution for the importance sampling [UI Guides] enableIf: ?bmpaperture_enable=1, displayName=Bitmap resolution, gpuSupport=full [Default value] 512
◆ get_bmpaperture_tex()
Value VRay::Plugins::CameraPhysical::get_bmpaperture_tex ( double  time = TiMe::Default()) const
inline
Aperture texture to use when bmpaperture_enable=1. The aperture is open where the texture is white. [UI Guides] enableIf: ?bmpaperture_enable=1, displayName=Bitmap aperture texture, attributes=textureSlot, gpuSupport=full
◆ get_camera_shader_tex()
Value VRay::Plugins::CameraPhysical::get_camera_shader_tex ( double  time = TiMe::Default()) const
inline
Camera shader [UI Guides] displayName=Camera shader texture, attributes=textureSlot, gpuSupport=full
◆ get_center_bias()
float VRay::Plugins::CameraPhysical::get_center_bias ( double  time = TiMe::Default()) const
inline
Bias toward the center of the lens for DOF sampling [UI Guides] minValue=-100, maxValue=100, gpuSupport=full [Default value] 0
◆ get_distortion()
float VRay::Plugins::CameraPhysical::get_distortion ( double  time = TiMe::Default()) const
inline
Distortion amount [UI Guides] enableIf: ?distortion_type=0; ?distortion_type=1, gpuSupport=full [Default value] 0
◆ get_distortion_tex()
Value VRay::Plugins::CameraPhysical::get_distortion_tex ( double  time = TiMe::Default()) const
inline
Distortion texture to use when distortion_type=3. Values are in image space - (0,0) maps to bottom left, (1,1) maps to top right. [UI Guides] displayName=Distortion texture, enableIf: ?distortion_type=3, gpuSupport=none
◆ get_distortion_type()
int VRay::Plugins::CameraPhysical::get_distortion_type ( double  time = TiMe::Default()) const
inline
Type of optical distortion (0 - Quadratic, 1 - Cubic, 2 - Lens file, 3 - Texture) [UI Guides] enum=0:Quadratic;1:Cubic;2:Lens file;3:Texture, gpuSupport=partial [Default value] 0
◆ get_dof_display_threshold()
float VRay::Plugins::CameraPhysical::get_dof_display_threshold ( double  time = TiMe::Default()) const
inline
Display threshold for depth-of-field [UI Guides] gpuSupport=none [Default value] 0.001
◆ get_dont_affect_settings()
bool VRay::Plugins::CameraPhysical::get_dont_affect_settings ( double  time = TiMe::Default()) const
inline
This is here so we can suppress a PhysicalCamera node from affecting the main VRayRenderer sequence and frame data. [UI Guides] gpuSupport=full [Default value] 0
◆ get_enable_thin_lens_equation()
bool VRay::Plugins::CameraPhysical::get_enable_thin_lens_equation ( double  time = TiMe::Default()) const
inline
Determine if the focus distance will affect the fov or focal length calculation due to thin lens equation [UI Guides] displayName=Enable thin lens equation, gpuSupport=none [Default value] 1
◆ get_exposure()
int VRay::Plugins::CameraPhysical::get_exposure ( double  time = TiMe::Default()) const
inline
0 - disable exposure color correction; 1 - physical exposure color correction; 2 - exposure color correction from exposure value [UI Guides] enum=0:No exposure;1:Physical Exposure;2:Exposure Value, gpuSupport=full [Default value] 1
◆ get_exposure_value()
float VRay::Plugins::CameraPhysical::get_exposure_value ( double  time = TiMe::Default()) const
inline
Exposure value to use with exposure mode 2 [UI Guides] displayName=Exposure value, enableIf: ?exposure=2, gpuSupport=full [Default value] 0
◆ get_f_number()
float VRay::Plugins::CameraPhysical::get_f_number ( double  time = TiMe::Default()) const
inline
F-stop [UI Guides] displayName=F-stop, minValue=0.01, gpuSupport=full [Default value] 8
◆ get_film_width()
float VRay::Plugins::CameraPhysical::get_film_width ( double  time = TiMe::Default()) const
inline
Film gate in mm [UI Guides] minValue=0, gpuSupport=full [Default value] 36
◆ get_focal_length()
float VRay::Plugins::CameraPhysical::get_focal_length ( double  time = TiMe::Default()) const
inline
Focal length in mm [UI Guides] minValue=0, gpuSupport=full [Default value] 40
◆ get_focus_distance()
float VRay::Plugins::CameraPhysical::get_focus_distance ( double  time = TiMe::Default()) const
inline
Focus distance in world units (if specify_focus=1). Affects the lens light attenuation and thin lens model. [UI Guides] enableIf: ?specify_focus=1, quantityType=distance, minValue=0, gpuSupport=full [Default value] 200
◆ get_fov()
float VRay::Plugins::CameraPhysical::get_fov ( double  time = TiMe::Default()) const
inline
The FOV value (in radians) to use when specify_fov is true [UI Guides] enableIf: ?specify_fov=1, gpuSupport=full [Default value] 1.5708
◆ get_horizontal_offset()
float VRay::Plugins::CameraPhysical::get_horizontal_offset ( double  time = TiMe::Default()) const
inline
The horizontal offset [UI Guides] displayName=Horizontal shift, gpuSupport=full [Default value] 0
◆ get_horizontal_shift()
float VRay::Plugins::CameraPhysical::get_horizontal_shift ( double  time = TiMe::Default()) const
inline
The horizontal lens shift [UI Guides] displayName=Horizontal tilt, gpuSupport=full [Default value] 0
◆ get_ISO()
float VRay::Plugins::CameraPhysical::get_ISO ( double  time = TiMe::Default()) const
inline
Sensor sensitivity (unbounded) [UI Guides] minValue=0, enableIf: ?exposure=1, gpuSupport=none [Default value] 200
◆ get_latency()
float VRay::Plugins::CameraPhysical::get_latency ( double  time = TiMe::Default()) const
inline
Shutter latency in seconds for video camera [UI Guides] enableIf: ?type=2, gpuSupport=none [Default value] 0
◆ get_lens_file()
std::string VRay::Plugins::CameraPhysical::get_lens_file ( double  time = TiMe::Default()) const
inline
LENS file with camera lens-type image distortion description [UI Guides] fileAsset=vrlens, enableIf: ?distortion_type=2, gpuSupport=full [Default value]
◆ get_lens_shift()
float VRay::Plugins::CameraPhysical::get_lens_shift ( double  time = TiMe::Default()) const
inline
Lens shift [UI Guides] displayName=Vertical tilt, gpuSupport=full [Default value] 0
◆ get_optical_vignetting()
float VRay::Plugins::CameraPhysical::get_optical_vignetting ( double  time = TiMe::Default()) const
inline
Optical vignetting ("cat's eye bokeh") amount [UI Guides] minValue=-3, maxValue=3, gpuSupport=full [Default value] 0
◆ get_rolling_shutter_duration()
float VRay::Plugins::CameraPhysical::get_rolling_shutter_duration ( double  time = TiMe::Default()) const
inline
Rolling shutter duration (the time for the shutter to pass through the image) in seconds^-1 [UI Guides] displayName=Rolling shutter speed, enableIf: ?use_moblur!=0, ?rolling_shutter_mode!=0, minValue=0, gpuSupport=full [Default value] 200
◆ get_rolling_shutter_mode()
int VRay::Plugins::CameraPhysical::get_rolling_shutter_mode ( double  time = TiMe::Default()) const
inline
Rolling shutter mode: 0=Disabled, 1=Top to bottom, 2=Bottom to top, 3=Left to right, 4=Right to left [UI Guides] enableIf: ?use_moblur!=0, enum=0:Disabled;1:Top to bottom;2:Bottom to top;3:Left to right;4:Right to left, gpuSupport=full [Default value] 0
◆ get_scene_name()
std::string VRay::Plugins::CameraPhysical::get_scene_name ( double  time = TiMe::Default()) const
inline
The original scene name of the camera associated with the plugin [UI Guides] displayName=Scene name, gpuSupport=full [Default value]
◆ get_shutter_angle()
float VRay::Plugins::CameraPhysical::get_shutter_angle ( double  time = TiMe::Default()) const
inline
Shutter angle in degrees for movie camera [UI Guides] enableIf: ?type=1, minValue=0, maxValue=360, gpuSupport=full [Default value] 180
◆ get_shutter_offset()
float VRay::Plugins::CameraPhysical::get_shutter_offset ( double  time = TiMe::Default()) const
inline
Shutter offset in degrees for movie camera [UI Guides] enableIf: ?type=1, minValue=-360, maxValue=360, gpuSupport=full [Default value] 0
◆ get_shutter_speed()
float VRay::Plugins::CameraPhysical::get_shutter_speed ( double  time = TiMe::Default()) const
inline
The shutter speed in seconds^-1 for still camera [UI Guides] enableIf: ?type=0, minValue=0, gpuSupport=full [Default value] 300
◆ get_specify_focus()
bool VRay::Plugins::CameraPhysical::get_specify_focus ( double  time = TiMe::Default()) const
inline
Set to true to enable the focus_distance parameter [UI Guides] gpuSupport=full [Default value] 0
◆ get_specify_fov()
bool VRay::Plugins::CameraPhysical::get_specify_fov ( double  time = TiMe::Default()) const
inline
Set to true to use explicit field of view from the "fov" value and false to use the focal length [UI Guides] gpuSupport=full [Default value] 0
◆ get_subdivs()
int VRay::Plugins::CameraPhysical::get_subdivs ( double  time = TiMe::Default()) const
inline
Deprecated. This has no effect. [UI Guides] gpuSupport=none [Default value] 1
◆ get_target_distance()
float VRay::Plugins::CameraPhysical::get_target_distance ( double  time = TiMe::Default()) const
inline
Target distance (if specify_focus=0). Affects only the distance of the focal plane. [UI Guides] enableIf: ?specify_focus=0, quantityType=distance, minValue=0, gpuSupport=full [Default value] 200
◆ get_targeted()
bool VRay::Plugins::CameraPhysical::get_targeted ( double  time = TiMe::Default()) const
inline
Has no effect. Target distance is used when the focus distance is not used (if specify_focus=0). [UI Guides] gpuSupport=full [Default value] 1
◆ get_type()
int VRay::Plugins::CameraPhysical::get_type ( double  time = TiMe::Default()) const
inline
This defines how the shutter works (0 - Still camera, 1 - Movie camera, 2 - Video camera [UI Guides] enum=0:Still;1:Movie;2:Video, minValue=0, gpuSupport=partial [Default value] 0
◆ get_use_dof()
bool VRay::Plugins::CameraPhysical::get_use_dof ( double  time = TiMe::Default()) const
inline
Set to true to enable raytraced depth of field effect [UI Guides] displayName=Enable DOF, gpuSupport=full [Default value] 0
◆ get_use_moblur()
bool VRay::Plugins::CameraPhysical::get_use_moblur ( double  time = TiMe::Default()) const
inline
Set to true to enable motion blur [UI Guides] displayName=Enable Motion Blur, gpuSupport=full [Default value] 0
◆ get_vertical_offset()
float VRay::Plugins::CameraPhysical::get_vertical_offset ( double  time = TiMe::Default()) const
inline
The vertical offset [UI Guides] displayName=Vertical shift, gpuSupport=full [Default value] 0
◆ get_vignetting()
float VRay::Plugins::CameraPhysical::get_vignetting ( double  time = TiMe::Default()) const
inline
Strength of vignetting effect [UI Guides] minValue=0, gpuSupport=full [Default value] 1
◆ get_white_balance()
Color VRay::Plugins::CameraPhysical::get_white_balance ( double  time = TiMe::Default()) const
inline
White point color [UI Guides] gpuSupport=full [Default value] Color(1, 1, 1)
◆ get_zoom_factor()
float VRay::Plugins::CameraPhysical::get_zoom_factor ( double  time = TiMe::Default()) const
inline
Zoom factor [UI Guides] minValue=0, gpuSupport=full [Default value] 1
◆ set_anisotropy()
bool VRay::Plugins::CameraPhysical::set_anisotropy ( float  val,
inline
◆ set_blades_enable()
bool VRay::Plugins::CameraPhysical::set_blades_enable ( bool  val,
inline
◆ set_blades_num()
bool VRay::Plugins::CameraPhysical::set_blades_num ( int  val,
inline
◆ set_blades_rotation()
bool VRay::Plugins::CameraPhysical::set_blades_rotation ( float  val,
inline
◆ set_bmpaperture_affects_exposure()
bool VRay::Plugins::CameraPhysical::set_bmpaperture_affects_exposure ( bool  val,
inline
◆ set_bmpaperture_enable()
bool VRay::Plugins::CameraPhysical::set_bmpaperture_enable ( bool  val,
inline
◆ set_bmpaperture_resolution()
bool VRay::Plugins::CameraPhysical::set_bmpaperture_resolution ( int  val,
inline
◆ set_bmpaperture_tex() [1/2]
bool VRay::Plugins::CameraPhysical::set_bmpaperture_tex ( const AColor texture,
inline
◆ set_bmpaperture_tex() [2/2]
bool VRay::Plugins::CameraPhysical::set_bmpaperture_tex ( const PluginRef texture,
inline
◆ set_camera_shader_tex() [1/2]
bool VRay::Plugins::CameraPhysical::set_camera_shader_tex ( const AColor texture,
inline
◆ set_camera_shader_tex() [2/2]
bool VRay::Plugins::CameraPhysical::set_camera_shader_tex ( const PluginRef texture,
inline
◆ set_center_bias()
bool VRay::Plugins::CameraPhysical::set_center_bias ( float  val,
inline
◆ set_distortion()
bool VRay::Plugins::CameraPhysical::set_distortion ( float  val,
inline
◆ set_distortion_tex() [1/2]
bool VRay::Plugins::CameraPhysical::set_distortion_tex ( const AColor texture,
inline
◆ set_distortion_tex() [2/2]
bool VRay::Plugins::CameraPhysical::set_distortion_tex ( const PluginRef texture,
inline
◆ set_distortion_type()
bool VRay::Plugins::CameraPhysical::set_distortion_type ( int  val,
inline
◆ set_dof_display_threshold()
bool VRay::Plugins::CameraPhysical::set_dof_display_threshold ( float  val,
inline
◆ set_dont_affect_settings()
bool VRay::Plugins::CameraPhysical::set_dont_affect_settings ( bool  val,
inline
◆ set_enable_thin_lens_equation()
bool VRay::Plugins::CameraPhysical::set_enable_thin_lens_equation ( bool  val,
inline
◆ set_exposure()
bool VRay::Plugins::CameraPhysical::set_exposure ( int  val,
inline
◆ set_exposure_value()
bool VRay::Plugins::CameraPhysical::set_exposure_value ( float  val,
inline
◆ set_f_number()
bool VRay::Plugins::CameraPhysical::set_f_number ( float  val,
inline
◆ set_film_width()
bool VRay::Plugins::CameraPhysical::set_film_width ( float  val,
inline
◆ set_focal_length()
bool VRay::Plugins::CameraPhysical::set_focal_length ( float  val,
inline
◆ set_focus_distance()
bool VRay::Plugins::CameraPhysical::set_focus_distance ( float  val,
inline
◆ set_fov()
bool VRay::Plugins::CameraPhysical::set_fov ( float  val,
inline
◆ set_horizontal_offset()
bool VRay::Plugins::CameraPhysical::set_horizontal_offset ( float  val,
inline
◆ set_horizontal_shift()
bool VRay::Plugins::CameraPhysical::set_horizontal_shift ( float  val,
inline
◆ set_ISO()
bool VRay::Plugins::CameraPhysical::set_ISO ( float  val,
inline
◆ set_latency()
bool VRay::Plugins::CameraPhysical::set_latency ( float  val,
inline
◆ set_lens_file() [1/2]
bool VRay::Plugins::CameraPhysical::set_lens_file ( const char *  str,
inline
◆ set_lens_file() [2/2]
bool VRay::Plugins::CameraPhysical::set_lens_file ( const std::string &  str,
inline
◆ set_lens_shift()
bool VRay::Plugins::CameraPhysical::set_lens_shift ( float  val,
inline
◆ set_optical_vignetting()
bool VRay::Plugins::CameraPhysical::set_optical_vignetting ( float  val,
inline
◆ set_rolling_shutter_duration()
bool VRay::Plugins::CameraPhysical::set_rolling_shutter_duration ( float  val,
inline
◆ set_rolling_shutter_mode()
bool VRay::Plugins::CameraPhysical::set_rolling_shutter_mode ( int  val,
inline
◆ set_scene_name() [1/2]
bool VRay::Plugins::CameraPhysical::set_scene_name ( const char *  str,
inline
◆ set_scene_name() [2/2]
bool VRay::Plugins::CameraPhysical::set_scene_name ( const std::string &  str,
inline
◆ set_shutter_angle()
bool VRay::Plugins::CameraPhysical::set_shutter_angle ( float  val,
inline
◆ set_shutter_offset()
bool VRay::Plugins::CameraPhysical::set_shutter_offset ( float  val,
inline
◆ set_shutter_speed()
bool VRay::Plugins::CameraPhysical::set_shutter_speed ( float  val,
inline
◆ set_specify_focus()
bool VRay::Plugins::CameraPhysical::set_specify_focus ( bool  val,
inline
◆ set_specify_fov()
bool VRay::Plugins::CameraPhysical::set_specify_fov ( bool  val,
inline
◆ set_subdivs()
bool VRay::Plugins::CameraPhysical::set_subdivs ( int  val,
inline
◆ set_target_distance()
bool VRay::Plugins::CameraPhysical::set_target_distance ( float  val,
inline
◆ set_targeted()
bool VRay::Plugins::CameraPhysical::set_targeted ( bool  val,
inline
◆ set_type()
bool VRay::Plugins::CameraPhysical::set_type ( int  val,
inline
◆ set_use_dof()
bool VRay::Plugins::CameraPhysical::set_use_dof ( bool  val,
inline
◆ set_use_moblur()
bool VRay::Plugins::CameraPhysical::set_use_moblur ( bool  val,
inline
◆ set_vertical_offset()
bool VRay::Plugins::CameraPhysical::set_vertical_offset ( float  val,
inline
◆ set_vignetting()
bool VRay::Plugins::CameraPhysical::set_vignetting ( float  val,
inline
◆ set_white_balance()
bool VRay::Plugins::CameraPhysical::set_white_balance ( const Color color,
inline
◆ set_zoom_factor()
bool VRay::Plugins::CameraPhysical::set_zoom_factor ( float  val,
inline
The documentation for this class was generated from the following file:
