VRay SDK for C++
Loading...
Searching...
No Matches
VRay::Plugins::Instancer Class Reference
Top-level geometry plugin. Efficiently instances objects in the scene. Often used for particles and vegetation. [gpuSupport=(partial)]. More...
#include <vrayplugins.hpp>
Inheritance diagram for VRay::Plugins::Instancer:
VRay::Plugin
Public Member Functions
ColorList get_acceleration_pp (double time=TiMe::Default()) const
FloatList get_age_pp (double time=TiMe::Default()) const
ColorList get_colors (double time=TiMe::Default()) const
ColorList get_emission_pp (double time=TiMe::Default()) const
PluginList get_extra_channels (double time=TiMe::Default()) const
ValueList get_instances (double time=TiMe::Default()) const
PluginRef get_instances_material_override (double time=TiMe::Default()) const
 Use override material even if particle has a material specified.
FloatList get_lifespan_pp (double time=TiMe::Default()) const
int get_nsamples (double time=TiMe::Default()) const
FloatList get_opacity_pp (double time=TiMe::Default()) const
int get_render_ids_gen_mode (double time=TiMe::Default()) const
bool get_shading_needs_ids (double time=TiMe::Default()) const
bool get_use_additional_params (double time=TiMe::Default()) const
bool get_use_direct_velocity (double time=TiMe::Default()) const
int get_use_time_instancing (double time=TiMe::Default()) const
bool get_use_visibility (double time=TiMe::Default()) const
ColorList get_user_color_pp_1 (double time=TiMe::Default()) const
ColorList get_user_color_pp_2 (double time=TiMe::Default()) const
ColorList get_user_color_pp_3 (double time=TiMe::Default()) const
ColorList get_user_color_pp_4 (double time=TiMe::Default()) const
ColorList get_user_color_pp_5 (double time=TiMe::Default()) const
FloatList get_user_float_pp_1 (double time=TiMe::Default()) const
FloatList get_user_float_pp_2 (double time=TiMe::Default()) const
FloatList get_user_float_pp_3 (double time=TiMe::Default()) const
FloatList get_user_float_pp_4 (double time=TiMe::Default()) const
FloatList get_user_float_pp_5 (double time=TiMe::Default()) const
bool get_visible (double time=TiMe::Default()) const
 operator GeometryPluginCategory ()
bool set_acceleration_pp (ColorList &&colorList, double time=TiMe::Default())
bool set_acceleration_pp (const Color *colors, size_t count, double time=TiMe::Default())
template<size_t count>
bool set_acceleration_pp (const Color(&colors)[count], double time=TiMe::Default())
bool set_acceleration_pp (const ColorList &colorList, double time=TiMe::Default())
bool set_age_pp (const float *floats, size_t count, double time=TiMe::Default())
bool set_age_pp (const float(&floats)[count], double time=TiMe::Default())
bool set_age_pp (const FloatList &floatList, double time=TiMe::Default())
bool set_age_pp (FloatList &&floatList, double time=TiMe::Default())
bool set_colors (ColorList &&colorList, double time=TiMe::Default())
bool set_colors (const Color *colors, size_t count, double time=TiMe::Default())
bool set_colors (const Color(&colors)[count], double time=TiMe::Default())
bool set_colors (const ColorList &colorList, double time=TiMe::Default())
bool set_emission_pp (ColorList &&colorList, double time=TiMe::Default())
bool set_emission_pp (const Color *colors, size_t count, double time=TiMe::Default())
bool set_emission_pp (const Color(&colors)[count], double time=TiMe::Default())
bool set_emission_pp (const ColorList &colorList, double time=TiMe::Default())
bool set_extra_channels (const Plugin *plugins, size_t count, double time=TiMe::Default())
bool set_extra_channels (const Plugin(&plugins)[count], double time=TiMe::Default())
bool set_extra_channels (const PluginList &pluginList, double time=TiMe::Default())
bool set_instances (const Value *values, size_t count, double time=TiMe::Default())
bool set_instances (const Value(&values)[count], double time=TiMe::Default())
bool set_instances (const ValueList &list, double time=TiMe::Default())
bool set_instances (Value(&&values)[count], double time=TiMe::Default())
bool set_instances (ValueList &&list, double time=TiMe::Default())
bool set_instances_material_override (const PluginRef &plugin, double time=TiMe::Default())
bool set_lifespan_pp (const float *floats, size_t count, double time=TiMe::Default())
bool set_lifespan_pp (const float(&floats)[count], double time=TiMe::Default())
bool set_lifespan_pp (const FloatList &floatList, double time=TiMe::Default())
bool set_lifespan_pp (FloatList &&floatList, double time=TiMe::Default())
bool set_nsamples (int val, double time=TiMe::Default())
bool set_opacity_pp (const float *floats, size_t count, double time=TiMe::Default())
bool set_opacity_pp (const float(&floats)[count], double time=TiMe::Default())
bool set_opacity_pp (const FloatList &floatList, double time=TiMe::Default())
bool set_opacity_pp (FloatList &&floatList, double time=TiMe::Default())
bool set_render_ids_gen_mode (int val, double time=TiMe::Default())
bool set_shading_needs_ids (bool val, double time=TiMe::Default())
bool set_use_additional_params (bool val, double time=TiMe::Default())
bool set_use_direct_velocity (bool val, double time=TiMe::Default())
bool set_use_time_instancing (int val, double time=TiMe::Default())
bool set_use_visibility (bool val, double time=TiMe::Default())
bool set_user_color_pp_1 (ColorList &&colorList, double time=TiMe::Default())
bool set_user_color_pp_1 (const Color *colors, size_t count, double time=TiMe::Default())
bool set_user_color_pp_1 (const Color(&colors)[count], double time=TiMe::Default())
bool set_user_color_pp_1 (const ColorList &colorList, double time=TiMe::Default())
bool set_user_color_pp_2 (ColorList &&colorList, double time=TiMe::Default())
bool set_user_color_pp_2 (const Color *colors, size_t count, double time=TiMe::Default())
bool set_user_color_pp_2 (const Color(&colors)[count], double time=TiMe::Default())
bool set_user_color_pp_2 (const ColorList &colorList, double time=TiMe::Default())
bool set_user_color_pp_3 (ColorList &&colorList, double time=TiMe::Default())
bool set_user_color_pp_3 (const Color *colors, size_t count, double time=TiMe::Default())
bool set_user_color_pp_3 (const Color(&colors)[count], double time=TiMe::Default())
bool set_user_color_pp_3 (const ColorList &colorList, double time=TiMe::Default())
bool set_user_color_pp_4 (ColorList &&colorList, double time=TiMe::Default())
bool set_user_color_pp_4 (const Color *colors, size_t count, double time=TiMe::Default())
bool set_user_color_pp_4 (const Color(&colors)[count], double time=TiMe::Default())
bool set_user_color_pp_4 (const ColorList &colorList, double time=TiMe::Default())
bool set_user_color_pp_5 (ColorList &&colorList, double time=TiMe::Default())
bool set_user_color_pp_5 (const Color *colors, size_t count, double time=TiMe::Default())
bool set_user_color_pp_5 (const Color(&colors)[count], double time=TiMe::Default())
bool set_user_color_pp_5 (const ColorList &colorList, double time=TiMe::Default())
bool set_user_float_pp_1 (const float *floats, size_t count, double time=TiMe::Default())
bool set_user_float_pp_1 (const float(&floats)[count], double time=TiMe::Default())
bool set_user_float_pp_1 (const FloatList &floatList, double time=TiMe::Default())
bool set_user_float_pp_1 (FloatList &&floatList, double time=TiMe::Default())
bool set_user_float_pp_2 (const float *floats, size_t count, double time=TiMe::Default())
bool set_user_float_pp_2 (const float(&floats)[count], double time=TiMe::Default())
bool set_user_float_pp_2 (const FloatList &floatList, double time=TiMe::Default())
bool set_user_float_pp_2 (FloatList &&floatList, double time=TiMe::Default())
bool set_user_float_pp_3 (const float *floats, size_t count, double time=TiMe::Default())
bool set_user_float_pp_3 (const float(&floats)[count], double time=TiMe::Default())
bool set_user_float_pp_3 (const FloatList &floatList, double time=TiMe::Default())
bool set_user_float_pp_3 (FloatList &&floatList, double time=TiMe::Default())
bool set_user_float_pp_4 (const float *floats, size_t count, double time=TiMe::Default())
bool set_user_float_pp_4 (const float(&floats)[count], double time=TiMe::Default())
bool set_user_float_pp_4 (const FloatList &floatList, double time=TiMe::Default())
bool set_user_float_pp_4 (FloatList &&floatList, double time=TiMe::Default())
bool set_user_float_pp_5 (const float *floats, size_t count, double time=TiMe::Default())
bool set_user_float_pp_5 (const float(&floats)[count], double time=TiMe::Default())
bool set_user_float_pp_5 (const FloatList &floatList, double time=TiMe::Default())
bool set_user_float_pp_5 (FloatList &&floatList, double time=TiMe::Default())
bool set_visible (bool val, double time=TiMe::Default())
- Public Member Functions inherited from VRay::Plugin
 Plugin () noexcept
 Default construct an invalid Plugin - not referencing a V-Ray scene object.
 Plugin (const Plugin &plugin) noexcept
 Copy construct from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
AColor getAColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const
AColor getAColor (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as AColor.
AColor getAColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
 This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
AColor getAColor (const std::string &propertyName, double time=TiMe::Default()) const
bool getBool (const char *propertyName, bool &ok, double time=TiMe::Default()) const
bool getBool (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as bool.
bool getBool (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
bool getBool (const std::string &propertyName, double time=TiMe::Default()) const
PluginCategories getCategories () const
Color getColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Color getColor (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Color.
Color getColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Color getColor (const std::string &propertyName, double time=TiMe::Default()) const
ColorList getColorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
ColorList getColorList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as ColorList.
ColorList getColorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
ColorList getColorList (const std::string &propertyName, double time=TiMe::Default()) const
double getDouble (const char *propertyName, bool &ok, double time=TiMe::Default()) const
double getDouble (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as double.
double getDouble (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
double getDouble (const std::string &propertyName, double time=TiMe::Default()) const
float getFloat (const char *propertyName, bool &ok, double time=TiMe::Default()) const
float getFloat (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as float.
float getFloat (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
float getFloat (const std::string &propertyName, double time=TiMe::Default()) const
FloatList getFloatList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
FloatList getFloatList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as FloatList.
FloatList getFloatList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
FloatList getFloatList (const std::string &propertyName, double time=TiMe::Default()) const
int getInt (const char *propertyName, bool &ok, double time=TiMe::Default()) const
int getInt (const char *propertyName, double time=TiMe::Default()) const
int getInt (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
int getInt (const std::string &propertyName, double time=TiMe::Default()) const
unsigned long long getIntegerID () const noexcept
 Returns the ID of the plugin instance. The ID is unique per scene contained in a VRayRenderer instance. Can be used as a hash value.
IntList getIntList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
IntList getIntList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as IntList.
IntList getIntList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
IntList getIntList (const std::string &propertyName, double time=TiMe::Default()) const
std::vector< double > getKeyframeTimes (const char *propertyName) const
std::vector< double > getKeyframeTimes (const char *propertyName, bool &ok) const
std::vector< double > getKeyframeTimes (const std::string &propertyName) const
std::vector< double > getKeyframeTimes (const std::string &propertyName, bool &ok) const
Matrix getMatrix (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Matrix getMatrix (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Matrix.
Matrix getMatrix (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Matrix getMatrix (const std::string &propertyName, double time=TiMe::Default()) const
PluginMeta getMeta () const
const char * getName () const
PluginRefT< PlugingetPlugin (const char *propertyName, bool &ok, double time=TiMe::Default()) const
PluginRefT< PlugingetPlugin (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as a Plugin reference.
PluginRefT< PlugingetPlugin (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
PluginRefT< PlugingetPlugin (const std::string &propertyName, double time=TiMe::Default()) const
PluginList getPluginList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
PluginList getPluginList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as PluginList.
PluginList getPluginList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
PluginList getPluginList (const std::string &propertyName, double time=TiMe::Default()) const
PropertyRuntimeMeta getPropertyRuntimeMeta (const char *propertyName) const
PropertyRuntimeMeta getPropertyRuntimeMeta (const std::string &propertyName) const
PropertyState getPropertyState (const char *propertyName) const
PropertyState getPropertyState (const std::string &propertyName) const
VRayRenderergetRenderer () const noexcept
 Return the renderer this Plugin is associated with, can be null on empty plugins.
std::string getString (const char *propertyName, bool &ok, double time=TiMe::Default()) const
std::string getString (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as string.
std::string getString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
std::string getString (const std::string &propertyName, double time=TiMe::Default()) const
StringList getStringList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
StringList getStringList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as StringList.
StringList getStringList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
StringList getStringList (const std::string &propertyName, double time=TiMe::Default()) const
Transform getTransform (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Transform getTransform (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Transform.
Transform getTransform (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Transform getTransform (const std::string &propertyName, double time=TiMe::Default()) const
TransformList getTransformList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
TransformList getTransformList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as TransformList.
TransformList getTransformList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
TransformList getTransformList (const std::string &propertyName, double time=TiMe::Default()) const
const char * getType () const
 Returns the type of this plugin as string.
PluginTypeId getTypeId () const noexcept
 Returns the type id of this plugin as long.
Value getValue (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Value getValue (const char *propertyName, double time=TiMe::Default()) const
Value getValue (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Value getValue (const std::string &propertyName, double time=TiMe::Default()) const
std::string getValueAsString (const char *propertyName, bool &ok, double time=TiMe::Default()) const
std::string getValueAsString (const char *propertyName, double time=TiMe::Default()) const
std::string getValueAsString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
std::string getValueAsString (const std::string &propertyName, double time=TiMe::Default()) const
ValueList getValueList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
ValueList getValueList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as ValueList. Works only if it really is a generic list.
ValueList getValueList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
ValueList getValueList (const std::string &propertyName, double time=TiMe::Default()) const
Vector getVector (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Vector getVector (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Vector.
Vector getVector (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Vector getVector (const std::string &propertyName, double time=TiMe::Default()) const
VectorList getVectorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
VectorList getVectorList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as VectorList.
VectorList getVectorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
VectorList getVectorList (const std::string &propertyName, double time=TiMe::Default()) const
bool isEmpty () const noexcept
bool isNotEmpty () const noexcept
bool isPropertyAnimated (const char *propertyName) const
bool isPropertyAnimated (const std::string &propertyName) const
bool isValid () const
bool operator!= (const Plugin &plugin) const noexcept
 Returns false if both Plugins belong to the same renderer and point to the same scene object instance.
bool operator< (const Plugin &plugin) const noexcept
bool operator<= (const Plugin &plugin) const noexcept
Pluginoperator= (const Plugin &plugin) noexcept
 Assign from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
bool operator== (const Plugin &plugin) const noexcept
 Returns true if both Plugins belong to the same renderer and point to the same scene object instance.
bool operator> (const Plugin &plugin) const noexcept
bool operator>= (const Plugin &plugin) const noexcept
bool setArray (const char *propertyName, const char *const data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Color data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const double data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const float data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const int data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const std::string data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Transform data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Value values[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Vector data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const char *const data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Color data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const double data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const float data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const int data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const std::string data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Transform data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Value values[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Vector data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())
bool setName (const char *newName)
bool setName (const std::string &newName)
bool setValue (const char *propertyName, ColorList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, const AColor &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const bool value, double time=TiMe::Default())
bool setValue (const char *propertyName, const char *str, double time=TiMe::Default())
bool setValue (const char *propertyName, const Color &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const ColorList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const double value, double time=TiMe::Default())
bool setValue (const char *propertyName, const float value, double time=TiMe::Default())
bool setValue (const char *propertyName, const FloatList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const int value, double time=TiMe::Default())
bool setValue (const char *propertyName, const IntList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Matrix &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const PluginList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())
bool setValue (const char *propertyName, const std::string &str, double time=TiMe::Default())
bool setValue (const char *propertyName, const StringList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Transform &transform, double time=TiMe::Default())
bool setValue (const char *propertyName, const TransformList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Value &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Value(&arr)[count], double time=TiMe::Default())
bool setValue (const char *propertyName, const ValueList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Vector &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const VectorList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const void *data, size_t size, double time=TiMe::Default())
bool setValue (const char *propertyName, FloatList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, IntList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, Value &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, Value(&&arr)[count], double time=TiMe::Default())
bool setValue (const char *propertyName, ValueList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, VectorList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, ColorList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const AColor &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const bool value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const char *str, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Color &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const ColorList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const double value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const float value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const FloatList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const int value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const IntList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Matrix &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const PluginList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const std::string &str, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const StringList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Transform &transform, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const TransformList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Value &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Value(&arr)[count], double time=TiMe::Default())
bool setValue (const std::string &propertyName, const ValueList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Vector &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const VectorList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const void *data, size_t size, double time=TiMe::Default())
bool setValue (const std::string &propertyName, FloatList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, IntList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, Value &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, Value(&&arr)[count], double time=TiMe::Default())
bool setValue (const std::string &propertyName, ValueList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, VectorList &&value, double time=TiMe::Default())
bool setValueAsString (const char *propertyName, const char *value)
bool setValueAsString (const char *propertyName, const std::string &value)
bool setValueAsString (const std::string &propertyName, const char *value)
bool setValueAsString (const std::string &propertyName, const std::string &value)
void swap (Plugin &plugin) noexcept
 Swaps the underlying scene object instance reference and associated renderer reference.
std::string toString () const
 Returns a string representation of the plugin which currently is the name of the plugin.
Static Public Member Functions
static constexpr const char * getType ()
 Return the name of the plugin type.
static constexpr const PluginTypeId getTypeId ()
 Plugin type ID.
Additional Inherited Members
- Public Types inherited from VRay::Plugin
enum class  PropertyState : int { Invalid = 0 , Default = 1 , NotAnimated = 2 , Animated = 3 }
- Protected Member Functions inherited from VRay::Plugin
 Plugin (VRayRenderer &renderer, const char *name)
 Plugin (VRayRenderer &renderer, InstanceId id) noexcept
 Plugin (VRayRenderer &renderer, InstanceId id, int typeIdIdx) noexcept
 Plugin (VRayRenderer &renderer, InstanceId id, PluginTypeId typeId) noexcept
InstanceId id () const
template<typename T , int TYPE>
bool setArrayAtTimeTemplate (const char *propertyName, size_t count, const T &value, double time)
template<typename LengthFn , typename PointerFn >
bool setStringArrayTemplate (const char *propertyName, size_t count, LengthFn lengthAt, PointerFn pointerAt, double time)
bool setValueAtTimeTemplate (const char *propertyName, const T &value, double time)
- Protected Attributes inherited from VRay::Plugin
InstanceId internalId
const VRayRendererpRenderer
Detailed Description
Member Function Documentation
◆ get_acceleration_pp()
ColorList VRay::Plugins::Instancer::get_acceleration_pp ( double  time = TiMe::Default()) const
inline
Per-particle acceleration. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_age_pp()
FloatList VRay::Plugins::Instancer::get_age_pp ( double  time = TiMe::Default()) const
inline
Per-particle age. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_colors()
ColorList VRay::Plugins::Instancer::get_colors ( double  time = TiMe::Default()) const
inline
Per-particle diffuse color. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_emission_pp()
ColorList VRay::Plugins::Instancer::get_emission_pp ( double  time = TiMe::Default()) const
inline
Per-particle emission color. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_extra_channels()
PluginList VRay::Plugins::Instancer::get_extra_channels ( double  time = TiMe::Default()) const
inline
Extra channels that hold auxiliary instances data [UI Guides] gpuSupport=full
◆ get_instances()
ValueList VRay::Plugins::Instancer::get_instances ( double  time = TiMe::Default()) const
inline
A list of N+1 elements where N is the number of instances; the first element is a time value, the rest are lists with elements: particle id, transform, velocity transform, hasInstanceTime, instanceTime, additional_params_flags, additional_param_1, ..., additional_param_N, visibility, node, node, node, ... [UI Guides] gpuSupport=full
◆ get_lifespan_pp()
FloatList VRay::Plugins::Instancer::get_lifespan_pp ( double  time = TiMe::Default()) const
inline
Per-particle lifespan. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_nsamples()
int VRay::Plugins::Instancer::get_nsamples ( double  time = TiMe::Default()) const
inline
Number of transform samples for motion blur [UI Guides] gpuSupport=full [Default value] 0
◆ get_opacity_pp()
FloatList VRay::Plugins::Instancer::get_opacity_pp ( double  time = TiMe::Default()) const
inline
Per-particle opacity. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_render_ids_gen_mode()
int VRay::Plugins::Instancer::get_render_ids_gen_mode ( double  time = TiMe::Default()) const
inline
Values for this parameter other than 0 are EXPERIMENTAL and WORK IN PROGRESS. This parameter tells the Instancer how to generate the render IDs for its instances. 0 - each instance has the same render ID as its source Node. 1 - all instances have the same render ID even those generated from different Nodes. 2 - all instances have different render IDs even those generated from the same Node. [UI Guides] displayName=Render IDs Mode, enum=0:Same as source Node;1:Same for all instances;2:Different for all instances [Default value] 0
◆ get_shading_needs_ids()
bool VRay::Plugins::Instancer::get_shading_needs_ids ( double  time = TiMe::Default()) const
inline
Set to true if the particle shade data sent to the instanced geometry needs to include the particle ID. [UI Guides] gpuSupport=none [Default value] 0
◆ get_use_additional_params()
bool VRay::Plugins::Instancer::get_use_additional_params ( double  time = TiMe::Default()) const
inline
If this is set to 'true' the lists in the 'instances' parameter have additional parameters after 'time instancing' parameters - an int with flags indicating what parameters follow and after that the parameters that follow. Their types depend on the flags in the int and are in a strictly defined order. New flags may be added and additional parameters for them can be added at the end of the chain. The flags are defined in HierarchicalParameterizedNodeParameters in an enum. [UI Guides] gpuSupport=full [Default value] 0
◆ get_use_direct_velocity()
bool VRay::Plugins::Instancer::get_use_direct_velocity ( double  time = TiMe::Default()) const
inline
Directly interpolate particle velocity. [UI Guides] gpuSupport=full [Default value] 0
◆ get_use_time_instancing()
int VRay::Plugins::Instancer::get_use_time_instancing ( double  time = TiMe::Default()) const
inline
If this is set to 1 or 2 the 'instances' parameter will contain the elements hasInstanceTime (bool) and instanceTime (double). Otherwise, they should not be present.0 - no time instancing applied. 1 - time instancing applied - only sequential times/samples permitted2 - time instancing applied - arbitrary times/samples permitted (used along with TimeInstancedGeom) [UI Guides] gpuSupport=full [Default value] 0
◆ get_use_visibility()
bool VRay::Plugins::Instancer::get_use_visibility ( double  time = TiMe::Default()) const
inline
Use particle visibility. If set to 'true' the lists in the 'instances' parameter have particle visibility parameter after 'additional parameters'. [UI Guides] gpuSupport=full [Default value] 0
◆ get_user_color_pp_1()
ColorList VRay::Plugins::Instancer::get_user_color_pp_1 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userVector1PP. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_user_color_pp_2()
ColorList VRay::Plugins::Instancer::get_user_color_pp_2 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userVector2PP. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_user_color_pp_3()
ColorList VRay::Plugins::Instancer::get_user_color_pp_3 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userVector3PP. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_user_color_pp_4()
ColorList VRay::Plugins::Instancer::get_user_color_pp_4 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userVector4PP. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_user_color_pp_5()
ColorList VRay::Plugins::Instancer::get_user_color_pp_5 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userVector5PP. [UI Guides] gpuSupport=none [Default value] ColorList()
◆ get_user_float_pp_1()
FloatList VRay::Plugins::Instancer::get_user_float_pp_1 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userScalar1PP. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_user_float_pp_2()
FloatList VRay::Plugins::Instancer::get_user_float_pp_2 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userScalar2PP. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_user_float_pp_3()
FloatList VRay::Plugins::Instancer::get_user_float_pp_3 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userScalar3PP. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_user_float_pp_4()
FloatList VRay::Plugins::Instancer::get_user_float_pp_4 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userScalar4PP. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_user_float_pp_5()
FloatList VRay::Plugins::Instancer::get_user_float_pp_5 ( double  time = TiMe::Default()) const
inline
Corresponds to Maya's userScalar5PP. [UI Guides] gpuSupport=none [Default value] FloatList()
◆ get_visible()
bool VRay::Plugins::Instancer::get_visible ( double  time = TiMe::Default()) const
inline
If false, no geometry will be generated and rendered [UI Guides] gpuSupport=full [Default value] 1
◆ set_acceleration_pp()
bool VRay::Plugins::Instancer::set_acceleration_pp ( const ColorList &  colorList,
inline
◆ set_age_pp()
bool VRay::Plugins::Instancer::set_age_pp ( const FloatList &  floatList,
inline
◆ set_colors()
bool VRay::Plugins::Instancer::set_colors ( const ColorList &  colorList,
inline
◆ set_emission_pp()
bool VRay::Plugins::Instancer::set_emission_pp ( const ColorList &  colorList,
inline
◆ set_extra_channels()
bool VRay::Plugins::Instancer::set_extra_channels ( const PluginList &  pluginList,
inline
◆ set_instances()
bool VRay::Plugins::Instancer::set_instances ( const ValueList &  list,
inline
◆ set_lifespan_pp()
bool VRay::Plugins::Instancer::set_lifespan_pp ( const FloatList &  floatList,
inline
◆ set_nsamples()
bool VRay::Plugins::Instancer::set_nsamples ( int  val,
inline
◆ set_opacity_pp()
bool VRay::Plugins::Instancer::set_opacity_pp ( const FloatList &  floatList,
inline
◆ set_render_ids_gen_mode()
bool VRay::Plugins::Instancer::set_render_ids_gen_mode ( int  val,
inline
◆ set_shading_needs_ids()
bool VRay::Plugins::Instancer::set_shading_needs_ids ( bool  val,
inline
◆ set_use_additional_params()
bool VRay::Plugins::Instancer::set_use_additional_params ( bool  val,
inline
◆ set_use_direct_velocity()
bool VRay::Plugins::Instancer::set_use_direct_velocity ( bool  val,
inline
◆ set_use_time_instancing()
bool VRay::Plugins::Instancer::set_use_time_instancing ( int  val,
inline
◆ set_use_visibility()
bool VRay::Plugins::Instancer::set_use_visibility ( bool  val,
inline
◆ set_user_color_pp_1()
bool VRay::Plugins::Instancer::set_user_color_pp_1 ( const ColorList &  colorList,
inline
◆ set_user_color_pp_2()
bool VRay::Plugins::Instancer::set_user_color_pp_2 ( const ColorList &  colorList,
inline
◆ set_user_color_pp_3()
bool VRay::Plugins::Instancer::set_user_color_pp_3 ( const ColorList &  colorList,
inline
◆ set_user_color_pp_4()
bool VRay::Plugins::Instancer::set_user_color_pp_4 ( const ColorList &  colorList,
inline
◆ set_user_color_pp_5()
bool VRay::Plugins::Instancer::set_user_color_pp_5 ( const ColorList &  colorList,
inline
◆ set_user_float_pp_1()
bool VRay::Plugins::Instancer::set_user_float_pp_1 ( const FloatList &  floatList,
inline
◆ set_user_float_pp_2()
bool VRay::Plugins::Instancer::set_user_float_pp_2 ( const FloatList &  floatList,
inline
◆ set_user_float_pp_3()
bool VRay::Plugins::Instancer::set_user_float_pp_3 ( const FloatList &  floatList,
inline
◆ set_user_float_pp_4()
bool VRay::Plugins::Instancer::set_user_float_pp_4 ( const FloatList &  floatList,
inline
◆ set_user_float_pp_5()
bool VRay::Plugins::Instancer::set_user_float_pp_5 ( const FloatList &  floatList,
inline
◆ set_visible()
bool VRay::Plugins::Instancer::set_visible ( bool  val,
inline
The documentation for this class was generated from the following file:
