VRay SDK for C++
Loading...
Searching...
No Matches
VRay::Plugins::PhxShaderSimGeom Class Reference
This plugin is created when rendering the Phoenix or V-Ray Volume Grid container in Volumetric Geometry, Volumetric Heat Haze or Isosurface render modes. Other render modes use either the PhoenixMeshPlugin, or the PhoenixVolPlugin. [gpuSupport=(partial)]. More...
#include <vrayplugins.hpp>
Inheritance diagram for VRay::Plugins::PhxShaderSimGeom:
VRay::Plugin
Public Member Functions
int get_gpu_di_mode (double time=TiMe::Default()) const
int get_gpu_gi_mode (double time=TiMe::Default()) const
int get_gpu_samples_count (double time=TiMe::Default()) const
PluginRef get_phoenix_sim (double time=TiMe::Default()) const
 operator GeometrySourcePluginCategory ()
 operator SettingsPluginCategory ()
bool set_gpu_di_mode (int val, double time=TiMe::Default())
bool set_gpu_gi_mode (int val, double time=TiMe::Default())
bool set_gpu_samples_count (int val, double time=TiMe::Default())
bool set_phoenix_sim (const PluginRef &plugin, double time=TiMe::Default())
- Public Member Functions inherited from VRay::Plugin
 Plugin () noexcept
 Default construct an invalid Plugin - not referencing a V-Ray scene object.
 Plugin (const Plugin &plugin) noexcept
 Copy construct from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
AColor getAColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const
AColor getAColor (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as AColor.
AColor getAColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
 This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
AColor getAColor (const std::string &propertyName, double time=TiMe::Default()) const
bool getBool (const char *propertyName, bool &ok, double time=TiMe::Default()) const
bool getBool (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as bool.
bool getBool (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
bool getBool (const std::string &propertyName, double time=TiMe::Default()) const
PluginCategories getCategories () const
VUtils::CharString getCharString (const char *propertyName)
VUtils::CharString getCharString (const char *propertyName, bool &ok)
VUtils::CharString getCharString (const std::string &propertyName)
VUtils::CharString getCharString (const std::string &propertyName, bool &ok)
VUtils::CharString getCharStringAtTime (const char *propertyName, double time)
VUtils::CharString getCharStringAtTime (const char *propertyName, double time, bool &ok)
VUtils::CharString getCharStringAtTime (const std::string &propertyName, double time)
VUtils::CharString getCharStringAtTime (const std::string &propertyName, double time, bool &ok)
Color getColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Color getColor (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Color.
Color getColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Color getColor (const std::string &propertyName, double time=TiMe::Default()) const
ColorList getColorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
ColorList getColorList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as ColorList.
ColorList getColorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
ColorList getColorList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::ColorRefList getColorRefList (const char *propertyName)
VUtils::ColorRefList getColorRefList (const char *propertyName, bool &ok)
VUtils::ColorRefList getColorRefList (const std::string &propertyName)
VUtils::ColorRefList getColorRefList (const std::string &propertyName, bool &ok)
VUtils::ColorRefList getColorRefListAtTime (const char *propertyName, double time)
VUtils::ColorRefList getColorRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::ColorRefList getColorRefListAtTime (const std::string &propertyName, double time)
VUtils::ColorRefList getColorRefListAtTime (const std::string &propertyName, double time, bool &ok)
double getDouble (const char *propertyName, bool &ok, double time=TiMe::Default()) const
double getDouble (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as double.
double getDouble (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
double getDouble (const std::string &propertyName, double time=TiMe::Default()) const
float getFloat (const char *propertyName, bool &ok, double time=TiMe::Default()) const
float getFloat (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as float.
float getFloat (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
float getFloat (const std::string &propertyName, double time=TiMe::Default()) const
FloatList getFloatList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
FloatList getFloatList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as FloatList.
FloatList getFloatList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
FloatList getFloatList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::FloatRefList getFloatRefList (const char *propertyName)
VUtils::FloatRefList getFloatRefList (const char *propertyName, bool &ok)
VUtils::FloatRefList getFloatRefList (const std::string &propertyName)
VUtils::FloatRefList getFloatRefList (const std::string &propertyName, bool &ok)
VUtils::FloatRefList getFloatRefListAtTime (const char *propertyName, double time)
VUtils::FloatRefList getFloatRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::FloatRefList getFloatRefListAtTime (const std::string &propertyName, double time)
VUtils::FloatRefList getFloatRefListAtTime (const std::string &propertyName, double time, bool &ok)
int getInt (const char *propertyName, bool &ok, double time=TiMe::Default()) const
int getInt (const char *propertyName, double time=TiMe::Default()) const
int getInt (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
int getInt (const std::string &propertyName, double time=TiMe::Default()) const
unsigned long long getIntegerID () const noexcept
 Returns the ID of the plugin instance. The ID is unique per scene contained in a VRayRenderer instance. Can be used as a hash value.
IntList getIntList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
IntList getIntList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as IntList.
IntList getIntList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
IntList getIntList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::IntRefList getIntRefList (const char *propertyName)
VUtils::IntRefList getIntRefList (const char *propertyName, bool &ok)
VUtils::IntRefList getIntRefList (const std::string &propertyName)
VUtils::IntRefList getIntRefList (const std::string &propertyName, bool &ok)
VUtils::IntRefList getIntRefListAtTime (const char *propertyName, double time)
VUtils::IntRefList getIntRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::IntRefList getIntRefListAtTime (const std::string &propertyName, double time)
VUtils::IntRefList getIntRefListAtTime (const std::string &propertyName, double time, bool &ok)
std::vector< double > getKeyframeTimes (const char *propertyName) const
std::vector< double > getKeyframeTimes (const char *propertyName, bool &ok) const
std::vector< double > getKeyframeTimes (const std::string &propertyName) const
std::vector< double > getKeyframeTimes (const std::string &propertyName, bool &ok) const
Matrix getMatrix (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Matrix getMatrix (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Matrix.
Matrix getMatrix (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Matrix getMatrix (const std::string &propertyName, double time=TiMe::Default()) const
PluginMeta getMeta () const
const char * getName () const
PluginRefT< PlugingetPlugin (const char *propertyName, bool &ok, double time=TiMe::Default()) const
PluginRefT< PlugingetPlugin (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as a Plugin reference.
PluginRefT< PlugingetPlugin (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
PluginRefT< PlugingetPlugin (const std::string &propertyName, double time=TiMe::Default()) const
PluginList getPluginList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
PluginList getPluginList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as PluginList.
PluginList getPluginList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
PluginList getPluginList (const std::string &propertyName, double time=TiMe::Default()) const
PropertyRuntimeMeta getPropertyRuntimeMeta (const char *propertyName) const
PropertyRuntimeMeta getPropertyRuntimeMeta (const std::string &propertyName) const
VRayRenderergetRenderer () const noexcept
 Return the renderer this Plugin is associated with, can be null on empty plugins.
std::string getString (const char *propertyName, bool &ok, double time=TiMe::Default()) const
std::string getString (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as string.
std::string getString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
std::string getString (const std::string &propertyName, double time=TiMe::Default()) const
StringList getStringList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
StringList getStringList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as StringList.
StringList getStringList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
StringList getStringList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::CharStringRefList getStringRefList (const char *propertyName)
VUtils::CharStringRefList getStringRefList (const char *propertyName, bool &ok)
VUtils::CharStringRefList getStringRefList (const std::string &propertyName)
VUtils::CharStringRefList getStringRefList (const std::string &propertyName, bool &ok)
VUtils::CharStringRefList getStringRefListAtTime (const char *propertyName, double time)
VUtils::CharStringRefList getStringRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::CharStringRefList getStringRefListAtTime (const std::string &propertyName, double time)
VUtils::CharStringRefList getStringRefListAtTime (const std::string &propertyName, double time, bool &ok)
Transform getTransform (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Transform getTransform (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Transform.
Transform getTransform (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Transform getTransform (const std::string &propertyName, double time=TiMe::Default()) const
TransformList getTransformList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
TransformList getTransformList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as TransformList.
TransformList getTransformList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
TransformList getTransformList (const std::string &propertyName, double time=TiMe::Default()) const
const char * getType () const
 Returns the type of this plugin as string.
PluginTypeId getTypeId () const noexcept
 Returns the type id of this plugin as long.
Value getValue (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Value getValue (const char *propertyName, double time=TiMe::Default()) const
Value getValue (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Value getValue (const std::string &propertyName, double time=TiMe::Default()) const
std::string getValueAsString (const char *propertyName, bool &ok, double time=TiMe::Default()) const
std::string getValueAsString (const char *propertyName, double time=TiMe::Default()) const
std::string getValueAsString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
std::string getValueAsString (const std::string &propertyName, double time=TiMe::Default()) const
ValueList getValueList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
ValueList getValueList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as ValueList. Works only if it really is a generic list.
ValueList getValueList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
ValueList getValueList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::ValueRefList getValueRefList (const char *propertyName)
VUtils::ValueRefList getValueRefList (const char *propertyName, bool &ok)
VUtils::ValueRefList getValueRefList (const std::string &propertyName)
VUtils::ValueRefList getValueRefList (const std::string &propertyName, bool &ok)
VUtils::ValueRefList getValueRefListAtTime (const char *propertyName, double time)
VUtils::ValueRefList getValueRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::ValueRefList getValueRefListAtTime (const std::string &propertyName, double time)
VUtils::ValueRefList getValueRefListAtTime (const std::string &propertyName, double time, bool &ok)
Vector getVector (const char *propertyName, bool &ok, double time=TiMe::Default()) const
Vector getVector (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as Vector.
Vector getVector (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
Vector getVector (const std::string &propertyName, double time=TiMe::Default()) const
VectorList getVectorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const
VectorList getVectorList (const char *propertyName, double time=TiMe::Default()) const
 Returns the value of a property as VectorList.
VectorList getVectorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const
VectorList getVectorList (const std::string &propertyName, double time=TiMe::Default()) const
VUtils::VectorRefList getVectorRefList (const char *propertyName)
VUtils::VectorRefList getVectorRefList (const char *propertyName, bool &ok)
VUtils::VectorRefList getVectorRefList (const std::string &propertyName)
VUtils::VectorRefList getVectorRefList (const std::string &propertyName, bool &ok)
VUtils::VectorRefList getVectorRefListAtTime (const char *propertyName, double time)
VUtils::VectorRefList getVectorRefListAtTime (const char *propertyName, double time, bool &ok)
VUtils::VectorRefList getVectorRefListAtTime (const std::string &propertyName, double time)
VUtils::VectorRefList getVectorRefListAtTime (const std::string &propertyName, double time, bool &ok)
bool isEmpty () const noexcept
bool isNotEmpty () const noexcept
bool isPropertyAnimated (const char *propertyName) const
bool isPropertyAnimated (const std::string &propertyName) const
bool isValid () const
bool operator!= (const Plugin &plugin) const noexcept
 Returns false if both Plugins belong to the same renderer and point to the same scene object instance.
Pluginoperator= (const Plugin &plugin) noexcept
 Assign from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
bool operator== (const Plugin &plugin) const noexcept
 Returns true if both Plugins belong to the same renderer and point to the same scene object instance.
bool setArray (const char *propertyName, const char *const data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Color data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const double data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const float data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const int data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const std::string data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Transform data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Value values[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, const Vector data[], size_t count, double time=TiMe::Default())
bool setArray (const char *propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const char *const data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Color data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const double data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const float data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const int data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const std::string data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Transform data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Value values[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, const Vector data[], size_t count, double time=TiMe::Default())
bool setArray (const std::string &propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())
bool setArrayAtTime (const char *propertyName, const Color data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const double data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const float data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const int data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const Plugin data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const std::string data[], size_t count, double time)
bool setArrayAtTime (const char *propertyName, const Vector data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const Color data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const double data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const float data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const int data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const Plugin data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const std::string data[], size_t count, double time)
bool setArrayAtTime (const std::string &propertyName, const Vector data[], size_t count, double time)
bool setName (const char *newName)
bool setName (const std::string &newName)
bool setValue (const char *propertyName, ColorList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, const AColor &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const bool value, double time=TiMe::Default())
bool setValue (const char *propertyName, const char *str, double time=TiMe::Default())
bool setValue (const char *propertyName, const Color &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const ColorList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const double value, double time=TiMe::Default())
bool setValue (const char *propertyName, const float value, double time=TiMe::Default())
bool setValue (const char *propertyName, const FloatList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const int value, double time=TiMe::Default())
bool setValue (const char *propertyName, const IntList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Matrix &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const PluginList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())
bool setValue (const char *propertyName, const std::string &str, double time=TiMe::Default())
bool setValue (const char *propertyName, const StringList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Transform &transform, double time=TiMe::Default())
bool setValue (const char *propertyName, const TransformList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Value &value, double time=TiMe::Default())
template<size_t count>
bool setValue (const char *propertyName, const Value(&arr)[count], double time=TiMe::Default())
bool setValue (const char *propertyName, const ValueList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const Vector &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const VectorList &value, double time=TiMe::Default())
bool setValue (const char *propertyName, const void *data, size_t size, double time=TiMe::Default())
bool setValue (const char *propertyName, const VUtils::CharString &str)
bool setValue (const char *propertyName, const VUtils::CharStringRefList &stringList)
bool setValue (const char *propertyName, const VUtils::ColorRefList &colorList)
bool setValue (const char *propertyName, const VUtils::FloatRefList &floatList)
bool setValue (const char *propertyName, const VUtils::IntRefList &intList)
bool setValue (const char *propertyName, const VUtils::TransformRefList &transformList)
bool setValue (const char *propertyName, const VUtils::ValueRefList &valueList)
bool setValue (const char *propertyName, const VUtils::VectorRefList &vectorList)
bool setValue (const char *propertyName, FloatList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, IntList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, Value &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, Value(&&arr)[count], double time=TiMe::Default())
bool setValue (const char *propertyName, ValueList &&value, double time=TiMe::Default())
bool setValue (const char *propertyName, VectorList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, ColorList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const AColor &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const bool value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const char *str, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Color &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const ColorList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const double value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const float value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const FloatList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const int value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const IntList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Matrix &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const PluginList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const std::string &str, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const StringList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Transform &transform, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const TransformList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Value &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Value(&arr)[count], double time=TiMe::Default())
bool setValue (const std::string &propertyName, const ValueList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const Vector &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const VectorList &value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const void *data, size_t size, double time=TiMe::Default())
bool setValue (const std::string &propertyName, const VUtils::CharString &str)
bool setValue (const std::string &propertyName, const VUtils::CharStringRefList &stringList)
bool setValue (const std::string &propertyName, const VUtils::ColorRefList &colorList)
bool setValue (const std::string &propertyName, const VUtils::FloatRefList &floatList)
bool setValue (const std::string &propertyName, const VUtils::IntRefList &intList)
bool setValue (const std::string &propertyName, const VUtils::TransformRefList &transformList)
bool setValue (const std::string &propertyName, const VUtils::ValueRefList &valueList)
bool setValue (const std::string &propertyName, const VUtils::VectorRefList &vectorList)
bool setValue (const std::string &propertyName, FloatList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, IntList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, Value &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, Value(&&arr)[count], double time=TiMe::Default())
bool setValue (const std::string &propertyName, ValueList &&value, double time=TiMe::Default())
bool setValue (const std::string &propertyName, VectorList &&value, double time=TiMe::Default())
bool setValueAsString (const char *propertyName, const char *value)
bool setValueAsString (const char *propertyName, const std::string &value)
bool setValueAsString (const std::string &propertyName, const char *value)
bool setValueAsString (const std::string &propertyName, const std::string &value)
bool setValueAsStringAtTime (const char *propertyName, const char *value, double time)
bool setValueAsStringAtTime (const char *propertyName, const std::string &value, double time)
bool setValueAsStringAtTime (const std::string &propertyName, const char *value, double time)
bool setValueAsStringAtTime (const std::string &propertyName, const std::string &value, double time)
bool setValueAtTime (const char *propertyName, const AColor &value, double time)
bool setValueAtTime (const char *propertyName, const bool value, double time)
bool setValueAtTime (const char *propertyName, const char *str, double time)
bool setValueAtTime (const char *propertyName, const Color &value, double time)
bool setValueAtTime (const char *propertyName, const ColorList &value, double time)
bool setValueAtTime (const char *propertyName, const double value, double time)
bool setValueAtTime (const char *propertyName, const float value, double time)
bool setValueAtTime (const char *propertyName, const FloatList &value, double time)
bool setValueAtTime (const char *propertyName, const int value, double time)
bool setValueAtTime (const char *propertyName, const IntList &value, double time)
bool setValueAtTime (const char *propertyName, const Matrix &value, double time)
bool setValueAtTime (const char *propertyName, const PluginList &value, double time)
bool setValueAtTime (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time)
bool setValueAtTime (const char *propertyName, const std::string &str, double time)
bool setValueAtTime (const char *propertyName, const StringList &value, double time)
bool setValueAtTime (const char *propertyName, const Transform &transform, double time)
bool setValueAtTime (const char *propertyName, const Value &value, double time)
bool setValueAtTime (const char *propertyName, const ValueList &value, double time)
bool setValueAtTime (const char *propertyName, const Vector &value, double time)
bool setValueAtTime (const char *propertyName, const VectorList &value, double time)
bool setValueAtTime (const char *propertyName, const void *data, size_t size, double time)
bool setValueAtTime (const char *propertyName, const VUtils::CharString &str, double time)
bool setValueAtTime (const char *propertyName, const VUtils::CharStringRefList &stringList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::ColorRefList &colorList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::FloatRefList &floatList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::IntRefList &intList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::TransformRefList &transformList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::ValueRefList &valueList, double time)
bool setValueAtTime (const char *propertyName, const VUtils::VectorRefList &vectorList, double time)
bool setValueAtTime (const std::string &propertyName, const AColor &value, double time)
bool setValueAtTime (const std::string &propertyName, const bool value, double time)
bool setValueAtTime (const std::string &propertyName, const char *str, double time)
bool setValueAtTime (const std::string &propertyName, const Color &value, double time)
bool setValueAtTime (const std::string &propertyName, const ColorList &value, double time)
bool setValueAtTime (const std::string &propertyName, const double value, double time)
bool setValueAtTime (const std::string &propertyName, const float value, double time)
bool setValueAtTime (const std::string &propertyName, const FloatList &value, double time)
bool setValueAtTime (const std::string &propertyName, const int value, double time)
bool setValueAtTime (const std::string &propertyName, const IntList &value, double time)
bool setValueAtTime (const std::string &propertyName, const Matrix &value, double time)
bool setValueAtTime (const std::string &propertyName, const PluginList &value, double time)
bool setValueAtTime (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time)
bool setValueAtTime (const std::string &propertyName, const std::string &str, double time)
bool setValueAtTime (const std::string &propertyName, const StringList &value, double time)
bool setValueAtTime (const std::string &propertyName, const Transform &transform, double time)
bool setValueAtTime (const std::string &propertyName, const Value &value, double time)
bool setValueAtTime (const std::string &propertyName, const ValueList &value, double time)
bool setValueAtTime (const std::string &propertyName, const Vector &value, double time)
bool setValueAtTime (const std::string &propertyName, const VectorList &value, double time)
bool setValueAtTime (const std::string &propertyName, const void *data, size_t size, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::CharString &str, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::CharStringRefList &stringList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::ColorRefList &colorList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::FloatRefList &floatList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::IntRefList &intList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::TransformRefList &transformList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::ValueRefList &valueList, double time)
bool setValueAtTime (const std::string &propertyName, const VUtils::VectorRefList &vectorList, double time)
void swap (Plugin &plugin) noexcept
 Swaps the underlying scene object instance reference and associated renderer reference.
std::string toString () const
 Returns a string representation of the plugin which currently is the name of the plugin.
Static Public Member Functions
static constexpr const char * getType ()
 Return the name of the plugin type.
static constexpr const PluginTypeId getTypeId ()
 Plugin type ID.
Additional Inherited Members
- Protected Member Functions inherited from VRay::Plugin
 Plugin (VRayRenderer &renderer, const char *name)
 Plugin (VRayRenderer &renderer, InstanceId id) noexcept
 Plugin (VRayRenderer &renderer, InstanceId id, int typeIdIdx) noexcept
 Plugin (VRayRenderer &renderer, InstanceId id, PluginTypeId typeId) noexcept
InstanceId id () const
template<typename T , int TYPE>
bool setArrayAtTimeTemplate (const char *propertyName, size_t count, const T &value, double time)
template<typename LengthFn , typename PointerFn >
bool setStringArrayTemplate (const char *propertyName, size_t count, LengthFn lengthAt, PointerFn pointerAt, double time)
bool setValueAtTimeTemplate (const char *propertyName, const T &value, double time)
- Protected Attributes inherited from VRay::Plugin
InstanceId internalId
const VRayRendererpRenderer
Detailed Description
Member Function Documentation
◆ get_gpu_di_mode()
int VRay::Plugins::PhxShaderSimGeom::get_gpu_di_mode ( double  time = TiMe::Default()) const
inline
Mode for DI computations on the GPU [UI Guides] gpuSupport=none [Default value] 2
◆ get_gpu_gi_mode()
int VRay::Plugins::PhxShaderSimGeom::get_gpu_gi_mode ( double  time = TiMe::Default()) const
inline
Mode for GI computations on the GPU [UI Guides] gpuSupport=none [Default value] 2
◆ get_gpu_samples_count()
int VRay::Plugins::PhxShaderSimGeom::get_gpu_samples_count ( double  time = TiMe::Default()) const
inline
Samples count for cache computation on the GPU [UI Guides] gpuSupport=none [Default value] 1
◆ get_phoenix_sim()
PluginRef VRay::Plugins::PhxShaderSimGeom::get_phoenix_sim ( double  time = TiMe::Default()) const
inline
A plugin that supports PhoenixSimInterface and can be used to load a Phoenix frame [UI Guides] gpuSupport=full
◆ set_gpu_di_mode()
bool VRay::Plugins::PhxShaderSimGeom::set_gpu_di_mode ( int  val,
inline
◆ set_gpu_gi_mode()
bool VRay::Plugins::PhxShaderSimGeom::set_gpu_gi_mode ( int  val,
inline
◆ set_gpu_samples_count()
bool VRay::Plugins::PhxShaderSimGeom::set_gpu_samples_count ( int  val,
inline
◆ set_phoenix_sim()
bool VRay::Plugins::PhxShaderSimGeom::set_phoenix_sim ( const PluginRef plugin,
inline
The documentation for this class was generated from the following file:
