int | get_additive_mode (double time=TiMe::Default()) const |
PluginList | get_brdfs (double time=TiMe::Default()) const |
PluginList | get_channels (double time=TiMe::Default()) const |
FloatList | get_opacities (double time=TiMe::Default()) const |
Color | get_transparency (double time=TiMe::Default()) const |
Value | get_transparency_tex (double time=TiMe::Default()) const |
float | get_transparency_tex_mult (double time=TiMe::Default()) const |
ValueList | get_weights (double time=TiMe::Default()) const |
| operator BSDFPluginCategory () |
bool | set_additive_mode (int val, double time=TiMe::Default()) |
bool | set_brdfs (const Plugin *plugins, size_t count, double time=TiMe::Default()) |
template<size_t count> |
bool | set_brdfs (const Plugin(&plugins)[count], double time=TiMe::Default()) |
bool | set_brdfs (const PluginList &pluginList, double time=TiMe::Default()) |
bool | set_channels (const Plugin *plugins, size_t count, double time=TiMe::Default()) |
bool | set_channels (const Plugin(&plugins)[count], double time=TiMe::Default()) |
bool | set_channels (const PluginList &pluginList, double time=TiMe::Default()) |
bool | set_opacities (const float *floats, size_t count, double time=TiMe::Default()) |
bool | set_opacities (const float(&floats)[count], double time=TiMe::Default()) |
bool | set_opacities (const FloatList &floatList, double time=TiMe::Default()) |
bool | set_opacities (FloatList &&floatList, double time=TiMe::Default()) |
bool | set_transparency (const Color &color, double time=TiMe::Default()) |
bool | set_transparency_tex (const AColor &texture, double time=TiMe::Default()) |
bool | set_transparency_tex (const PluginRef &texture, double time=TiMe::Default()) |
bool | set_transparency_tex_mult (float val, double time=TiMe::Default()) |
bool | set_weights (const Value *textures, size_t count, double time=TiMe::Default()) |
bool | set_weights (const Value(&textures)[count], double time=TiMe::Default()) |
bool | set_weights (const ValueList &textureList, double time=TiMe::Default()) |
bool | set_weights (Value(&&textures)[count], double time=TiMe::Default()) |
bool | set_weights (ValueList &&textureList, double time=TiMe::Default()) |
| Plugin () noexcept |
| Default construct an invalid Plugin - not referencing a V-Ray scene object.
| Plugin (const Plugin &plugin) noexcept |
| Copy construct from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
AColor | getAColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
AColor | getAColor (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as AColor.
AColor | getAColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
| This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
AColor | getAColor (const std::string &propertyName, double time=TiMe::Default()) const |
bool | getBool (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
bool | getBool (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as bool.
bool | getBool (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
bool | getBool (const std::string &propertyName, double time=TiMe::Default()) const |
PluginCategories | getCategories () const |
VUtils::CharString | getCharString (const char *propertyName) |
VUtils::CharString | getCharString (const char *propertyName, bool &ok) |
VUtils::CharString | getCharString (const std::string &propertyName) |
VUtils::CharString | getCharString (const std::string &propertyName, bool &ok) |
VUtils::CharString | getCharStringAtTime (const char *propertyName, double time) |
VUtils::CharString | getCharStringAtTime (const char *propertyName, double time, bool &ok) |
VUtils::CharString | getCharStringAtTime (const std::string &propertyName, double time) |
VUtils::CharString | getCharStringAtTime (const std::string &propertyName, double time, bool &ok) |
Color | getColor (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
Color | getColor (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as Color.
Color | getColor (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
Color | getColor (const std::string &propertyName, double time=TiMe::Default()) const |
ColorList | getColorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
ColorList | getColorList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as ColorList.
ColorList | getColorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
ColorList | getColorList (const std::string &propertyName, double time=TiMe::Default()) const |
VUtils::ColorRefList | getColorRefList (const char *propertyName) |
VUtils::ColorRefList | getColorRefList (const char *propertyName, bool &ok) |
VUtils::ColorRefList | getColorRefList (const std::string &propertyName) |
VUtils::ColorRefList | getColorRefList (const std::string &propertyName, bool &ok) |
VUtils::ColorRefList | getColorRefListAtTime (const char *propertyName, double time) |
VUtils::ColorRefList | getColorRefListAtTime (const char *propertyName, double time, bool &ok) |
VUtils::ColorRefList | getColorRefListAtTime (const std::string &propertyName, double time) |
VUtils::ColorRefList | getColorRefListAtTime (const std::string &propertyName, double time, bool &ok) |
double | getDouble (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
double | getDouble (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as double.
double | getDouble (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
double | getDouble (const std::string &propertyName, double time=TiMe::Default()) const |
float | getFloat (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
float | getFloat (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as float.
float | getFloat (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
float | getFloat (const std::string &propertyName, double time=TiMe::Default()) const |
FloatList | getFloatList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
FloatList | getFloatList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as FloatList.
FloatList | getFloatList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
FloatList | getFloatList (const std::string &propertyName, double time=TiMe::Default()) const |
VUtils::FloatRefList | getFloatRefList (const char *propertyName) |
VUtils::FloatRefList | getFloatRefList (const char *propertyName, bool &ok) |
VUtils::FloatRefList | getFloatRefList (const std::string &propertyName) |
VUtils::FloatRefList | getFloatRefList (const std::string &propertyName, bool &ok) |
VUtils::FloatRefList | getFloatRefListAtTime (const char *propertyName, double time) |
VUtils::FloatRefList | getFloatRefListAtTime (const char *propertyName, double time, bool &ok) |
VUtils::FloatRefList | getFloatRefListAtTime (const std::string &propertyName, double time) |
VUtils::FloatRefList | getFloatRefListAtTime (const std::string &propertyName, double time, bool &ok) |
int | getInt (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
int | getInt (const char *propertyName, double time=TiMe::Default()) const |
int | getInt (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
int | getInt (const std::string &propertyName, double time=TiMe::Default()) const |
unsigned long long | getIntegerID () const noexcept |
| Returns the ID of the plugin instance. The ID is unique per scene contained in a VRayRenderer instance. Can be used as a hash value.
IntList | getIntList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
IntList | getIntList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as IntList.
IntList | getIntList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
IntList | getIntList (const std::string &propertyName, double time=TiMe::Default()) const |
VUtils::IntRefList | getIntRefList (const char *propertyName) |
VUtils::IntRefList | getIntRefList (const char *propertyName, bool &ok) |
VUtils::IntRefList | getIntRefList (const std::string &propertyName) |
VUtils::IntRefList | getIntRefList (const std::string &propertyName, bool &ok) |
VUtils::IntRefList | getIntRefListAtTime (const char *propertyName, double time) |
VUtils::IntRefList | getIntRefListAtTime (const char *propertyName, double time, bool &ok) |
VUtils::IntRefList | getIntRefListAtTime (const std::string &propertyName, double time) |
VUtils::IntRefList | getIntRefListAtTime (const std::string &propertyName, double time, bool &ok) |
std::vector< double > | getKeyframeTimes (const char *propertyName) const |
std::vector< double > | getKeyframeTimes (const char *propertyName, bool &ok) const |
std::vector< double > | getKeyframeTimes (const std::string &propertyName) const |
std::vector< double > | getKeyframeTimes (const std::string &propertyName, bool &ok) const |
Matrix | getMatrix (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
Matrix | getMatrix (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as Matrix.
Matrix | getMatrix (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
Matrix | getMatrix (const std::string &propertyName, double time=TiMe::Default()) const |
PluginMeta | getMeta () const |
const char * | getName () const |
PluginRefT< Plugin > | getPlugin (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
PluginRefT< Plugin > | getPlugin (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as a Plugin reference.
PluginRefT< Plugin > | getPlugin (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
PluginRefT< Plugin > | getPlugin (const std::string &propertyName, double time=TiMe::Default()) const |
PluginList | getPluginList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
PluginList | getPluginList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as PluginList.
PluginList | getPluginList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
PluginList | getPluginList (const std::string &propertyName, double time=TiMe::Default()) const |
PropertyRuntimeMeta | getPropertyRuntimeMeta (const char *propertyName) const |
PropertyRuntimeMeta | getPropertyRuntimeMeta (const std::string &propertyName) const |
VRayRenderer * | getRenderer () const noexcept |
| Return the renderer this Plugin is associated with, can be null on empty plugins.
std::string | getString (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
std::string | getString (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as string.
std::string | getString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
std::string | getString (const std::string &propertyName, double time=TiMe::Default()) const |
StringList | getStringList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
StringList | getStringList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as StringList.
StringList | getStringList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
StringList | getStringList (const std::string &propertyName, double time=TiMe::Default()) const |
VUtils::CharStringRefList | getStringRefList (const char *propertyName) |
VUtils::CharStringRefList | getStringRefList (const char *propertyName, bool &ok) |
VUtils::CharStringRefList | getStringRefList (const std::string &propertyName) |
VUtils::CharStringRefList | getStringRefList (const std::string &propertyName, bool &ok) |
VUtils::CharStringRefList | getStringRefListAtTime (const char *propertyName, double time) |
VUtils::CharStringRefList | getStringRefListAtTime (const char *propertyName, double time, bool &ok) |
VUtils::CharStringRefList | getStringRefListAtTime (const std::string &propertyName, double time) |
VUtils::CharStringRefList | getStringRefListAtTime (const std::string &propertyName, double time, bool &ok) |
Transform | getTransform (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
Transform | getTransform (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as Transform.
Transform | getTransform (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
Transform | getTransform (const std::string &propertyName, double time=TiMe::Default()) const |
TransformList | getTransformList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
TransformList | getTransformList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as TransformList.
TransformList | getTransformList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
TransformList | getTransformList (const std::string &propertyName, double time=TiMe::Default()) const |
const char * | getType () const |
| Returns the type of this plugin as string.
PluginTypeId | getTypeId () const noexcept |
| Returns the type id of this plugin as long.
Value | getValue (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
Value | getValue (const char *propertyName, double time=TiMe::Default()) const |
Value | getValue (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
Value | getValue (const std::string &propertyName, double time=TiMe::Default()) const |
std::string | getValueAsString (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
std::string | getValueAsString (const char *propertyName, double time=TiMe::Default()) const |
std::string | getValueAsString (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
std::string | getValueAsString (const std::string &propertyName, double time=TiMe::Default()) const |
ValueList | getValueList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
ValueList | getValueList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as ValueList. Works only if it really is a generic list.
ValueList | getValueList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
ValueList | getValueList (const std::string &propertyName, double time=TiMe::Default()) const |
VUtils::ValueRefList | getValueRefList (const char *propertyName) |
VUtils::ValueRefList | getValueRefList (const char *propertyName, bool &ok) |
VUtils::ValueRefList | getValueRefList (const std::string &propertyName) |
VUtils::ValueRefList | getValueRefList (const std::string &propertyName, bool &ok) |
VUtils::ValueRefList | getValueRefListAtTime (const char *propertyName, double time) |
VUtils::ValueRefList | getValueRefListAtTime (const char *propertyName, double time, bool &ok) |
VUtils::ValueRefList | getValueRefListAtTime (const std::string &propertyName, double time) |
VUtils::ValueRefList | getValueRefListAtTime (const std::string &propertyName, double time, bool &ok) |
Vector | getVector (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
Vector | getVector (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as Vector.
Vector | getVector (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
Vector | getVector (const std::string &propertyName, double time=TiMe::Default()) const |
VectorList | getVectorList (const char *propertyName, bool &ok, double time=TiMe::Default()) const |
VectorList | getVectorList (const char *propertyName, double time=TiMe::Default()) const |
| Returns the value of a property as VectorList.
VectorList | getVectorList (const std::string &propertyName, bool &ok, double time=TiMe::Default()) const |
VectorList | getVectorList (const std::string &propertyName, double time=TiMe::Default()) const |
VUtils::VectorRefList | getVectorRefList (const char *propertyName) |
VUtils::VectorRefList | getVectorRefList (const char *propertyName, bool &ok) |
VUtils::VectorRefList | getVectorRefList (const std::string &propertyName) |
VUtils::VectorRefList | getVectorRefList (const std::string &propertyName, bool &ok) |
VUtils::VectorRefList | getVectorRefListAtTime (const char *propertyName, double time) |
VUtils::VectorRefList | getVectorRefListAtTime (const char *propertyName, double time, bool &ok) |
VUtils::VectorRefList | getVectorRefListAtTime (const std::string &propertyName, double time) |
VUtils::VectorRefList | getVectorRefListAtTime (const std::string &propertyName, double time, bool &ok) |
bool | isEmpty () const noexcept |
bool | isNotEmpty () const noexcept |
bool | isPropertyAnimated (const char *propertyName) const |
bool | isPropertyAnimated (const std::string &propertyName) const |
bool | isValid () const |
bool | operator!= (const Plugin &plugin) const noexcept |
| Returns false if both Plugins belong to the same renderer and point to the same scene object instance.
Plugin & | operator= (const Plugin &plugin) noexcept |
| Assign from another Plugin. They both point to the same underlying object. This is like having T& a=x; T& b=x;.
bool | operator== (const Plugin &plugin) const noexcept |
| Returns true if both Plugins belong to the same renderer and point to the same scene object instance.
bool | setArray (const char *propertyName, const char *const data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const Color data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const double data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const float data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const int data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const std::string data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const Transform data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const Value values[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, const Vector data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const char *propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const char *const data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const Color data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const double data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const float data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const int data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const std::string data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const Transform data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const Value values[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, const Vector data[], size_t count, double time=TiMe::Default()) |
bool | setArray (const std::string &propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default()) |
bool | setArrayAtTime (const char *propertyName, const Color data[], size_t count, double time) |
bool | setArrayAtTime (const char *propertyName, const double data[], size_t count, double time) |
bool | setArrayAtTime (const char *propertyName, const float data[], size_t count, double time) |
bool | setArrayAtTime (const char *propertyName, const int data[], size_t count, double time) |
bool | setArrayAtTime (const char *propertyName, const Plugin data[], size_t count, double time) |
bool | setArrayAtTime (const char *propertyName, const std::string data[], size_t count, double time) |
bool | setArrayAtTime (const char *propertyName, const Vector data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const Color data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const double data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const float data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const int data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const Plugin data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const std::string data[], size_t count, double time) |
bool | setArrayAtTime (const std::string &propertyName, const Vector data[], size_t count, double time) |
bool | setName (const char *newName) |
bool | setName (const std::string &newName) |
bool | setValue (const char *propertyName, ColorList &&value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const AColor &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const bool value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const char *str, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const Color &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const ColorList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const double value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const float value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const FloatList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const int value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const IntList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const Matrix &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const PluginList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const std::string &str, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const StringList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const Transform &transform, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const TransformList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const Value &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const Value(&arr)[count], double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const ValueList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const Vector &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const VectorList &value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const void *data, size_t size, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, const VUtils::CharString &str) |
bool | setValue (const char *propertyName, const VUtils::CharStringRefList &stringList) |
bool | setValue (const char *propertyName, const VUtils::ColorRefList &colorList) |
bool | setValue (const char *propertyName, const VUtils::FloatRefList &floatList) |
bool | setValue (const char *propertyName, const VUtils::IntRefList &intList) |
bool | setValue (const char *propertyName, const VUtils::TransformRefList &transformList) |
bool | setValue (const char *propertyName, const VUtils::ValueRefList &valueList) |
bool | setValue (const char *propertyName, const VUtils::VectorRefList &vectorList) |
bool | setValue (const char *propertyName, FloatList &&value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, IntList &&value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, Value &&value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, Value(&&arr)[count], double time=TiMe::Default()) |
bool | setValue (const char *propertyName, ValueList &&value, double time=TiMe::Default()) |
bool | setValue (const char *propertyName, VectorList &&value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, ColorList &&value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const AColor &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const bool value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const char *str, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const Color &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const ColorList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const double value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const float value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const FloatList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const int value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const IntList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const Matrix &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const PluginList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const std::string &str, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const StringList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const Transform &transform, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const TransformList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const Value &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const Value(&arr)[count], double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const ValueList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const Vector &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const VectorList &value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const void *data, size_t size, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, const VUtils::CharString &str) |
bool | setValue (const std::string &propertyName, const VUtils::CharStringRefList &stringList) |
bool | setValue (const std::string &propertyName, const VUtils::ColorRefList &colorList) |
bool | setValue (const std::string &propertyName, const VUtils::FloatRefList &floatList) |
bool | setValue (const std::string &propertyName, const VUtils::IntRefList &intList) |
bool | setValue (const std::string &propertyName, const VUtils::TransformRefList &transformList) |
bool | setValue (const std::string &propertyName, const VUtils::ValueRefList &valueList) |
bool | setValue (const std::string &propertyName, const VUtils::VectorRefList &vectorList) |
bool | setValue (const std::string &propertyName, FloatList &&value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, IntList &&value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, Value &&value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, Value(&&arr)[count], double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, ValueList &&value, double time=TiMe::Default()) |
bool | setValue (const std::string &propertyName, VectorList &&value, double time=TiMe::Default()) |
bool | setValueAsString (const char *propertyName, const char *value) |
bool | setValueAsString (const char *propertyName, const std::string &value) |
bool | setValueAsString (const std::string &propertyName, const char *value) |
bool | setValueAsString (const std::string &propertyName, const std::string &value) |
bool | setValueAsStringAtTime (const char *propertyName, const char *value, double time) |
bool | setValueAsStringAtTime (const char *propertyName, const std::string &value, double time) |
bool | setValueAsStringAtTime (const std::string &propertyName, const char *value, double time) |
bool | setValueAsStringAtTime (const std::string &propertyName, const std::string &value, double time) |
bool | setValueAtTime (const char *propertyName, const AColor &value, double time) |
bool | setValueAtTime (const char *propertyName, const bool value, double time) |
bool | setValueAtTime (const char *propertyName, const char *str, double time) |
bool | setValueAtTime (const char *propertyName, const Color &value, double time) |
bool | setValueAtTime (const char *propertyName, const ColorList &value, double time) |
bool | setValueAtTime (const char *propertyName, const double value, double time) |
bool | setValueAtTime (const char *propertyName, const float value, double time) |
bool | setValueAtTime (const char *propertyName, const FloatList &value, double time) |
bool | setValueAtTime (const char *propertyName, const int value, double time) |
bool | setValueAtTime (const char *propertyName, const IntList &value, double time) |
bool | setValueAtTime (const char *propertyName, const Matrix &value, double time) |
bool | setValueAtTime (const char *propertyName, const PluginList &value, double time) |
bool | setValueAtTime (const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time) |
bool | setValueAtTime (const char *propertyName, const std::string &str, double time) |
bool | setValueAtTime (const char *propertyName, const StringList &value, double time) |
bool | setValueAtTime (const char *propertyName, const Transform &transform, double time) |
bool | setValueAtTime (const char *propertyName, const Value &value, double time) |
bool | setValueAtTime (const char *propertyName, const ValueList &value, double time) |
bool | setValueAtTime (const char *propertyName, const Vector &value, double time) |
bool | setValueAtTime (const char *propertyName, const VectorList &value, double time) |
bool | setValueAtTime (const char *propertyName, const void *data, size_t size, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::CharString &str, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::CharStringRefList &stringList, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::ColorRefList &colorList, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::FloatRefList &floatList, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::IntRefList &intList, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::TransformRefList &transformList, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::ValueRefList &valueList, double time) |
bool | setValueAtTime (const char *propertyName, const VUtils::VectorRefList &vectorList, double time) |
bool | setValueAtTime (const std::string &propertyName, const AColor &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const bool value, double time) |
bool | setValueAtTime (const std::string &propertyName, const char *str, double time) |
bool | setValueAtTime (const std::string &propertyName, const Color &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const ColorList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const double value, double time) |
bool | setValueAtTime (const std::string &propertyName, const float value, double time) |
bool | setValueAtTime (const std::string &propertyName, const FloatList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const int value, double time) |
bool | setValueAtTime (const std::string &propertyName, const IntList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const Matrix &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const PluginList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time) |
bool | setValueAtTime (const std::string &propertyName, const std::string &str, double time) |
bool | setValueAtTime (const std::string &propertyName, const StringList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const Transform &transform, double time) |
bool | setValueAtTime (const std::string &propertyName, const Value &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const ValueList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const Vector &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const VectorList &value, double time) |
bool | setValueAtTime (const std::string &propertyName, const void *data, size_t size, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::CharString &str, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::CharStringRefList &stringList, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::ColorRefList &colorList, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::FloatRefList &floatList, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::IntRefList &intList, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::TransformRefList &transformList, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::ValueRefList &valueList, double time) |
bool | setValueAtTime (const std::string &propertyName, const VUtils::VectorRefList &vectorList, double time) |
void | swap (Plugin &plugin) noexcept |
| Swaps the underlying scene object instance reference and associated renderer reference.
std::string | toString () const |
| Returns a string representation of the plugin which currently is the name of the plugin.
